I installed ARMBIAN 5.44 testing Ubuntu 18.04 LTS 4.14.40-odroidc2 on my C2 and it is working fine at this time,
but it hangs with the command "shutdown -r now" - I have to power off/on.
Now I did get the advice to update to U-Boot V2018.03
On my C2 dpkg does show me as actual installed:
linux-u-boot-odroidc2-next  5.44  arm64  Uboot loader 2017.11
Via "apt-cache search" or at http://apt.armbian.com/pool/main/l/linux-u-boot-odroidc2-next/ I couldnt find nothing newer than the installed version or
linux-u-boot-next-odroidc2_5.38_arm64.deb 25-Jan-2018 07:48 206K
In /etc/apt/sources.list.d/armbian.list I got as the only armbian-source:
deb http://apt.armbian.com bionic main bionic-utils bionic-desktop
So could please point me anyone the the v2018.03 U-boot as .deb or how could I compile it for myself?
As Info I only did find that: https://github.com/armbian/build/pull/913
Thanks in advance :)
22 minutes ago, Igor said:
"committed 8 hours ago" :D
Alright! ;) so I will wait some time for the next up & reboot.
Many thanks @Igor
22 hours ago, Igor said:
https://github.com/armbian/upload/commit/761f38516873149506f886eec78abcf65653ffc6
apt update & upgrade on the stable branch. Nightly building still offline.
Hmm @Igor thats seems to be the moment when a Odroid C2 doesnt use eMMC  (mmcblk0) as boot-device, but a uSD-Card (mmcblk1).
Entpacken von linux-u-boot-odroidc2-next (5.45) über (5.44) ...
linux-u-boot-odroidc2-next (5.45) wird eingerichtet ...
Device /dev/mmcblk0 does not exist, skipping
root@odroid-c2:~# ls /dev/mmc*
/dev/mmcblk1  /dev/mmcblk1p1
Is there any way/command to configure this u-boot for a uSD-Card?
wget http://apt.armbian.com/pool/main/l/linux-u-boot-odroidc2-next/linux-u-boot-next-odroidc2_5.45_arm64.deb
and
dpkg -i ./linux-u-boot-next-odroidc2_5.45_arm64.deb
doenst did the "trick"
dpkg does show it as installed. but I dont think it was successful:
root@odroid-c2:~# dpkg -l|grep boot
linux-u-boot-odroidc2-next            5.45                                arm64        Uboot loader 2018.03
inside the .deb/tar I did found the platform_install.sh:
DIR=/usr/lib/linux-u-boot-next-odroidc2_5.45_arm64
write_uboot_platform ()
    dd if=$1/bl1.bin.hardkernel of=$2 bs=1 count=442 conv=fsync > /dev/null 2>&1;
    dd if=$1/bl1.bin.hardkernel of=$2 bs=512 skip=1 seek=1 conv=fsync > /dev/null 2>&1;
    dd if=$1/u-boot.bin of=$2 bs=512 seek=97 conv=fsync > /dev/null 2>&1
$1 will be the DIR /usr/lib/linux-u-boot-next-odroidc2_5.45_arm64
but what will be $2 (for of=) ?
Maybe /dev/mmcblk1 ?
DEVICE=/dev/mmcblk1 dpkg -i linux-u-boot-next-odroidc2_5.45_arm64.deb
Installation seem to went fine:
root@odroid-c2:/home/guido# DEVICE=/dev/mmcblk1 dpkg -i ./linux-u-boot-next-odroidc2_5.45_arm64.deb
(Lese Datenbank ... 72496 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von .../linux-u-boot-next-odroidc2_5.45_arm64.deb ...
Entpacken von linux-u-boot-odroidc2-next (5.45) über (5.45) ...
Updating u-boot on /dev/mmcblk1
but after a power off/on reboot for activating the new u-boot the C2 doenst reboot complete neither after a "reboot" nor a "shutdown -r now"
Is there any way to check the successfull installation or is there any chance that the reboot also wont work after the new u-boot 2018.3?
With serial console to see if thingie was booted with a new u-boot. I assume you don't have one?
OK, when there is no other way I will install a TTL-serial-USB-Dongle on the C2 and check if the new u-boot is used....have to check where is the TTL-Prt on the C2 :)
I think all Odroid's have 1.8V TTL logic :(
https://forum.odroid.com/viewtopic.php?f=53&amp;t=4758
too bad all my Dongles have 3.3/5V (CP2102 and CH340G).
The serial Dongle from FriendlyARM has the same connector but not only a other pinout but also only 3.3V and 5V.
Maybe I burned now my serial Port with 3.3V?
I dont know, but the C2 only makes trouble to me....
First he allways  he want to boot eMMC as first (switch only at later models) so I cant reformat my messed-up emmc with a sdcard-boot and now the serial-TTL isnt a 3.3V/5V standard :(
I couldnt get any data out of the serial port :(
I used some Jumper-Wire - also did try to switch rx/tx but no data from the port.
I used 3 several TTL-Dongles - maybe my serial debug port is defective?
"same" problem - but with the NanoPi Core2 (using the image for the NanoPi Neo Plus2) - via "apt upgrade" :
Setting up linux-u-boot-nanopineoplus2-next (5.45.180521) ...
root@nanopi-core2:~# ls /dev/mmc*
/dev/mmcblk2  /dev/mmcblk2boot0  /dev/mmcblk2boot1  /dev/mmcblk2p1
/dev/mmcblk2  is the internal emmc of the NanoPi Core2 (there is no sd-card inserted - armbian was installed via armbian-config from sd-card to emmc)
As Information:  System diagnosis information will now be uploaded to http://ix.io/1aZk
But at http://apt.armbian.com/pool/main/l/linux-u-boot-nanopineoplus2-next/
there isnt a 5.45.180521 u-boot .deb
[EDIT]
OK I did found it :)
wget http://beta.armbian.com/pool/main/l/linux-u-boot-nanopineoplus2-next/linux-u-boot-next-nanopineoplus2_5.45.180521_arm64.deb
DEVICE=/dev/mmcblk2 dpkg -i ./linux-u-boot-next-nanopineoplus2_5.45.180521_arm64.deb
Updating u-boot on /dev/mmcblk2
Unfortunately with a clean install of Armbian Odroid c2 on an SD-CARD and linux-u-boot-odroidc2-next 5.45 (u-boot 2018.03) my C2 still hangs on "shutdown -r now" with updated u-boot.
Thoughts on things to poke to find the source of the problem?
Matthew
I'm away from my computer, are we using the BayLibre patchset on C2?  If not the u-boot might not function properly, I remember Neil saying we needed those patches for Le Potato to use mainline u-boot.
