Odroid C2 Armbian 5.44 Ubuntu- Bionic XFCE 4.12/ -
1. system lost eth0 connection after 5 minutes work ( DHCP or Static number IP )
2. sometimes not reboot properly - i have to unconnected from power
I think this is the same situation as Nano pi k2. Kernel 4.14 does not working properly with amlogic S905 devices
The latest armbian for Nano pi k2 also lost eth0 connection after 10-15 minutes
Absolutely and fundamentally incorrect.  Legacy u-boot does not properly configure the memory space for the patched kernel.  That may not be the issue with C2, however that is the issue with K2
if absolutely wrong why do I have problem? System lost eth0 connection after 3-5 minutes? kernel 4.14 odroid c2 armbian 5.44 bionic.
I will try it fix tomorrow.... now i formatted micro-sd card
As I said, it is a U-boot problem, not a kernel problem that is the issue with the K2, so the comparison is incorrect and has nothing to do with the blanket of "S905 devices".  The only issues I know of with C2 on mainline *kernel* involve the eMMC clock speeds needing throttled, but we have that accounted for.
I checked the settings eth0, DNS, uninstalled even the network-manager, interfaces, even saved the resolv.conf settings in the head file. and I definitely say meson-driver loses eth0 in Armbian odroid c2 and nanopi k2. etho works about 5-10 minutes. After ping yahoo.com name or service not known - ping 192.168.1.1 destination host unreachable. With all valid eth0 settings. In nano pi k2 I can switch to wlan0 in the odroid I need to reset
34 minutes ago, radek said:
meson8b-dwmac does not works
strange :(
I do use
Linux odroid-c2 4.14.40-odroidc2 #53 SMP PREEMPT Fri May 11 09:18:03 CEST 2018 aarch64 aarch64 aarch64 GNU/Linux
root@odroid-c2:/var/log# lsmod
Module                  Size  Used by
dwmac_meson8b          16384  0
meson_drm              45056  3 meson_dw_hdmi
stmmac_platform        20480  2 dwmac_generic,dwmac_meson8b
drm_kms_helper        188416  3 meson_dw_hdmi,meson_drm,dw_hdmi
stmmac                114688  3 stmmac_platform,dwmac_generic,dwmac_meson8b
and dont have any disconnects - my C2 is running several days...
The only problem is that I have a massise growing file names /var/log/wtmp :(
In dmesg it shown after 1-2 days:
[62910.273705] systemd-journald[1405]: Failed to open system journal: No space left on device
[62910.274272] systemd-journald[1405]: Failed to open system journal: No space left on device
[62910.274562] systemd-journald[1405]: Failed to open system journal: No space left on device
[62910.275904] systemd-journald[1405]: Failed to open system journal: No space left on device
[62910.276227] systemd-journald[1405]: Failed to open system journal: No space left on device
4 hours ago, radek said:
just do not tell me everything is fine
Did I ever?  I simply pointed out that a blanket statement such as "Kernel 4.14 is bad for Amlogic S905 devices" was incorrect.  I then pointed to a possible cause of the problem, memory corruption.
on others images eth0 driver is stmmaceth.. and this driver works
What is the kernel being used on these images?  4.9?  The meson8b-dwmac driver is an extension of the stmmaceth driver, with adjustments specific to differences in the IP block implementation in the Meson and Meson64 SoC's (S905).
This could be a tx-delay issue on the C2.
The K2 is WIP.  I update it as I have time, interest, and resources.
memory is good. I hava 6 images on 6 different micro-sd cards. 1. Armbian 5.38 Jessie XFCE  / 2. Android 6.0.1 / 3. Harkernel Ubuntu 16.04 Mate 1.12.1 / 4. Armbian 5.30 XFCE Ubuntu 16.04 / 5. Armbian 5.43 Debian 9 XFCE  / 6. Armbian 5.44 Ubuntu 18.04 XFCE ... sory android not that story but works perfectly.  Ubuntu 16.04 Mate from Hardkernel team. works perfekt. Armbian Jessie 5.38 works perfectly but slowly maybe slow micro-sd... never mind no problem, - stmmaceth driver. All these images works but strange is that Armbian 5.43 Debian 9 is on meson8b-dwmac driver and works also !!!!
Problem is Armbian 5.44 Ubuntu 18.04 - driver meson8b-dwmac.... lost connection very quickly 3-5 minutes...
I have also Nanopi K2 Armbian 5.38 ubuntu 16.04 also driver meson8b-dwmac. also lost connection but after 10-15 minutes. Needs more time to crash. But this have wifi and i can switch to wifi. But this image hangs very often without purpose. I think when i use browsers.
I really check everything. manualy configured eth0, interfaces, network manager install uninstall, edit resolv.conf... etc. Every time the same strange story. After reboot eth0 exist and when i run apt-get upgrade or apt-get install packages i have lost internet. Just doing nothing only fetching packages....
I see that we boast about the number of single boards I have:
VS Mecool RK3399         FireFly RK3399     OrangePI RK3399 ,  Odroid XU4               Asus Tinker         MIQI                Cubieboard 4                    Khadas VIM2         FA NanoPiM3        Rock64              Odroid C2               FA NanoPI K2         Khadas VIM1            Minix Neo X7           Cubieboard 5         BananaPiM3        Pine H64       , Le Potato,  Renegade from Libre computers ,      Orangepi Lite 2                Orangepi OnePLUS   RaspberryPI 3+     OrangePI Prime          OrangePIPC2            Pine A64-LTS             OrangePI WIN PLUS         BananaPIM64       Pine 64+                   FA NanoPIA64       NanoPIM2       BananaPiM2Ultra      OrangePi2PlusE         OrangePi2          BananapiM2+               Odroid C1+                   Hummingboard      BananaPiM2        RaspberryPi2              Olimex Lime2                  Creator CI20 ,  (  Nano pi K1 plus - iam waiting for delivery form china. )
I use it in production on a daily basis tasks and I can tell every model which one is sucked up, which overheats, does not hold the cpu clocking that the image that works on it. I can also say a lot about micro-SD cards. I use finally only sandisk and samsung.
Maybe these are 2 problems?
Iam personally didnt use the Desktop & Browsers, becausse - from my personal view - a Desktop and WebBrowser need more than 2GB of Ram to work properly. Mostly because I often have more than 30 tabs open :) So your C2 could run into low memory before if there are some scripts at the webpages.
The second problem which sound familiar to me is that I sometime cant "apt upgrade" / fetch packages via "apt install" - BUT thats only a file-lock of the automatic package-installer.
So I can do a "apt update" but when the automatic updater is running I cant "apt upgrade" or install a package.
In this case I do use "ps -ef|grep apt" and if I see more apt-command-lines in working state I do wait some minutes and check again.
When the commands are ready then I could do my "apt upgrade"
But I did never lost the connection to the internet - because when the automatic updater is running I allways could do successfull a "ping 8.8.8.8"
Not a surprise. We don't have any supported Bionic builds so there may be issues with beta/testing builds (since they are made only for testing and not for everyday use). They need to be compared to Xenial builds with the same kernel before claiming kernel issues.
And I don't see any useful logs (dmesg, armbianmonitor -u / armbianmonitor -U, ifconfig, ethtool -S, route) that could help diagnose the problem (especially since Bionic images are still testing and testing without providing logs won't help us find problems if there are any)
guidol it is no problem with automatic upgrades .. i usually uninstall unattended-upgrades and I dont use it.
OK finally.;  I report that such a problem exists and I ask you to keep this in mind as the bionic will come out of the test. There are many images that I do not have to immediately have ubuntu 18.04. The problem concerns the odroid  c2 and nano pi k2, kernel 4.14, armbian kernel more than 5.38. Thank you for your attention, I wish you a good evening.
But you still didn't deliver the needed information so that this 'bug report' is useful to solve things.. Just read again the post of @zador.blood.stained. If you want that a developer has this on his todo list (or 'to keep in mind list'). Things aren't solved by: there's a bug, now it's up to you to solve it... Things are solved by giving as much information as possible to understand what's going wrong. Why should a dev even think about takes this on his 'todo' list when the users aren't willig to deliver at least the needed informations to have a clue what's going on.
Otherwise the Drepper/Poettering-approach how to react to 'bugs' seems to be reasonable...  :rolleyes: (there's probably some sarcasm inside the last part... )
ifconfig
eth0      Link encap:Ethernet  HWaddr c2:2d:dc:69:09:b8
          inet addr:192.168.1.13  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::bef9:68eb:35ba:dabc/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:2597 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1839 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:2651519 (2.6 MB)  TX bytes:846389 (846.3 KB)
          Interrupt:17
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:104 errors:0 dropped:0 overruns:0 frame:0
          TX packets:104 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:8882 (8.8 KB)  TX bytes:8882 (8.8 KB)
wlan0     Link encap:Ethernet  HWaddr b0:f1:ec:29:d5:5a
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
ethtool eth0
Settings for eth0:
    Supported ports: [ TP MII ]
    Supported link modes:   10baseT/Half 10baseT/Full
                            100baseT/Half 100baseT/Full
                            1000baseT/Full
    Supported pause frame use: Symmetric Receive-only
    Supports auto-negotiation: Yes
    Advertised link modes:  10baseT/Half 10baseT/Full
                            1000baseT/Full
    Advertised pause frame use: No
    Advertised auto-negotiation: Yes
    Link partner advertised link modes:  10baseT/Half 10baseT/Full
    Link partner advertised pause frame use: Symmetric
    Link partner advertised auto-negotiation: Yes
    Speed: 100Mb/s
    Duplex: Full
    Port: MII
    PHYAD: 0
    Transceiver: external
    Auto-negotiation: on
    Supports Wake-on: ug
    Wake-on: d
    Current message level: 0x0000003f (63)
                   drv probe link timer ifdown ifup
    Link detected: yes
armbianmonitor -u
System diagnosis information will now be uploaded to http://ix.io/1b8J
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         gateway         0.0.0.0         UG    100    0        0 eth0
link-local      *               255.255.0.0     U     1000   0        0 eth0
192.168.1.0     *               255.255.255.0   U     100    0        0 eth0
after lost eth0 and switch to wlan0.:
ifconfig
          RX packets:6805 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4405 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:7294757 (7.2 MB)  TX bytes:1189808 (1.1 MB)
          Interrupt:17
          RX packets:463 errors:0 dropped:0 overruns:0 frame:0
          TX packets:463 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:34169 (34.1 KB)  TX bytes:34169 (34.1 KB)
          inet addr:192.168.1.17  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::bc1b:678c:a64a:b67c/64 Scope:Link
          RX packets:3080 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2584 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:3017837 (3.0 MB)  TX bytes:973929 (973.9 KB)
