Hi Dear Friends!
I'm having trouble using the onboard analog soundcard from my OrangePi Zero +. I already enabled analog-in in armbian-config, but when I try to run some application that uses the sound card, it has an error.
In this example I'm trying to use the direwolf app that serves to decode FSK audio.
The error also repeats when I try to use svxlink.
Captura de tela de 2018-06-27 15:48:30.png
23 minutes ago, guidol said:
Did you see your analog soundcard at
aplay -l
Did you create a /etc/asound.conf for the default soundcard?
Yes, but the audio does not work.
On my orange zero pi I had this problem I managed to solve using Armbian 5.30. But you do not have the Armbian 5.30 for Orange PI Zero Plus. :(
12 minutes ago, Aurélio Radioamador said:
Thank for anwser , Mr. Guidol.
But version 5.46 does not work analog-codec.
Must be a specific problem of the Zero+
because on the normal OPi Zero and Zero Plus H5 I didnt got problems with analog-audio
root@opi-zero-plus-h5(192.168.6.98):~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
/etc/asound.conf:
pcm.!default {
    type hw
    card 0
    device 0
ctl.!default {
    type hw
    card 0
Welcome to ARMBIAN 5.46 testing Ubuntu 18.04 LTS 4.14.48-sunxi64
Linux opi-zero-plus-h5 4.14.48-sunxi64 #14 SMP Thu Jun 7 11:34:46 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
Test with espeak:
espeak -w /tmp/espeak.wav -s150 "Hello how are you today?"; aplay -D plughw:0,0 /tmp/espeak.wav 2>/dev/null
What I find strange is that with the other 2 img linux official from Orangepi Resources (Ubuntu and Debian) the audio worked, however I do not want to use those linux images because I really liked the armbian.
26 minutes ago, martinayotte said:
Did you loaded the analog-codec overlay ?
Hi Mr martin,
I enabled analog-codec in armbian-config and i create asound.conf ...
Should I do something else?
Thanks reply.
Hi Mr martin,
Thanks reply.
4 hours ago, guidol said:
Test with espeak:
 And analog input ? You do test If work? Here not work input and output ..
My board is Orange Pi zero plus and armbian 5.46 debian ...
Good Morning! I have tested here and found the following:
The audio output is working perfectly.
Only the microphone audio input is not working.
And I need to use the microphone audio input from the card in my project.
WOW!!! I'm very very very happy..
Problem solved.
For Mainline, do this
 1) alsamixer
2) press TAB (Make sure it falls to F4: CAPTURE)
3) Move to Mic1 (Use arrow keys)
4) Press SPACE and (L R Capture will appear)
I just needed to enable LINE IN on alxamixer.
  Subdevices: 1/1
/etc/asound.conf:
pcm.!default {
    type hw
    card 0
    device 0
ctl.!default {
    type hw
    card 0
Test with espeak:
Hello:
I' have a orange pi zero with stretch so, and always I use ESPEAK, but now show me the next error:
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
And it sounds bad!! really bad!
What's wrong between espeak and stretch???
Regards.
For sounds espeak like on every other computer.
I do redirecting the "errors" via 2>/dev/null
out of sight ;)
Do you use the expansion-pcb or only wires for conncting to the audio pins?
I use expansion-pcb, but another OPZ I can only run it with sudo. What's wrong?? Stretch works fine, but don't for espeak-ng! It does not sound good espeak-ng.
thanks for your answer.
