orange pi one desktop
apt-get update
apt-get upgrade
https://docs.armbian.com/User-Guide_Getting-Started/
I cannot update and upgrade.
I get these messages
$ apt-get update
Reading package lists... Done
W: chmod 0700 of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (1: Operation not permitted)
E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
E: Unable to lock directory /var/lib/apt/lists/
W: Problem unlinking the file /var/cache/apt/pkgcache.bin - RemoveCaches (13: Permission denied)
W: Problem unlinking the file /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Permission denied)
$ apt-get upgrade
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
Makes no difference if I write sudo first or run su.
How can I update? Thanks.
You need to be root --> # at the command prompt (which you should get after su and the root-password), because as user you cant
apt update & upgrade.
Check the user with the command id
If you running a desktop environment you also have to close something like the software-center or graphical updater.
If only apt update does work then wait for the end of the "daily update" :)
use the command ps -ef|grep apt
to see if apt is working (this is setting the lock file /var/lib/dpkg/lock).
When apt has ended its work (only the grep for apt is shown)
root# ps -ef|grep apt
root      3536  1495  0 17:34 pts/0    00:00:00 grep apt
 then you should be able to
apt upgrade
Use sudo before your commands.
sudo apt-get update && sudo apt-get upgrade
And when I get : E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
Then I do,
sudo rm /var/lib/dpkg/lock
After that it works. Don't know if that's the right way, but it works.
4 hours ago, NicoD said:
Then I do,
Not exactly the best way :) There could be some automated apt process with some purpose in the background. For example, we run index updates (apt update) every 21 days which means usually also at the first boot. This is getting some changes lately ... but on most images, it goes that way.
The best tactic is to wait for a minute that index is updated, then proceed with apt get ...
As I wrote
sudo apt-get update
does not work either.
Nor does
su + enter.
Is it a common error?
Being able to update should be a mundane task.
16 minutes ago, renky said:
Nor does
su + enter.
What does the OPi One after si+enter?
Doenst it ask for the root password.
Did you create at the first boot of armbian a root password ( from 1234 to your password) and a new user?
