I wish you all good health.
Using the "Armbian" build system, I noticed two bad points:
1 - incomplete cleaning of the source code before starting a new compilation, seen when patches add new files to the tree.
2 - Debian kernel source package includes the git directory.
1) All I do I'm fixing the version kernel (KERNELBRANCH="tag:v4.14.40") and collect several variants for one Board, changing the patchset for each version, adding or removing some.
Before each new compilation I'm doing a test of the purity of the source.
clean_repo()
	display_alert "clean_repo $PWD"
	#git status -s
	git reset --hard HEAD	# First, return the modified files.
	git clean -df			# Then delete all new, added files.
	#git status
compile_kernel()
	# A simple check ensures that we start with a clean slate.
	cd $SRC/cache/sources/$LINUXSOURCEDIR
	if [ "X$(git status -s)" != "X" ]; then
		clean_repo
	fi
2) Manufacturer's code Debian package:      (--exclude='./.git/')
	if [[ $BUILD_KSRC != no ]]; then
		display_alert "Compressing sources for the linux-source package"
		tar cp --directory="$kerneldir" --exclude='./.git/' --owner=root . \
			 | pv -p -b -r -s $(du -sb "$kerneldir" --exclude=='./.git/' | cut -f1) \
			| pixz -4 > $sources_pkg_dir/usr/src/linux-source-${version}-${LINUXFAMILY}.tar.xz
		cp COPYING $sources_pkg_dir/usr/share/doc/linux-source-${version}-${LINUXFAMILY}/LICENSE
	fi
can be changed to view:    (--exclude="[.]git")
		tar cp --directory="$kerneldir" --exclude="[.]git" --exclude="[.]git[a-z]*" --owner=root . \
			 | pv -p -b -r -s $(du -sb "$kerneldir" --exclude="[.]git" --exclude="[.]git[a-z]*" | cut -f1) \
	fi
got fooled by this too in the beginnings.. :P I mostly work with 'CLEAN_LEVEL = sources' when I prepare patches which create new files (https://github.com/armbian/build/blob/d9849de58fcb8fe8f6c0b01d71b61c28a6bc6f35/config/templates/config-example.conf#L6-L10).
your solution looks smart (but to be honest, my git-fu is to low to be sure that this works reliable). You may create a PR where the maintainers will review it this works sufficient? Would save some bandwidth when preparing such patches cause I normally need more than one attempt for a proper patch. :)
large overhead when downloading.
This code is guaranteed to work correctly. I use it for a month. "Clean slate" before you start the compilation, and no issues with the new patches.
Well, then I'm happy to see a PR from it and others probably too.. ;)
overhead isn't that much an issue here.. thanks to fiber at home.. but for sure, if it works reliable I would still use it. :)
:D I am somewhere in the Siberian province and use 3G modem.:(
that's why I like your approach. Problem is, as long as downloading big junks of code doesn't hurt you, you don't care much. You may team up with @Igor or @zador.blood.stained how this can be implemented properly. I guess it should be here:
https://github.com/armbian/build/blob/88ea83e694d8c015c42a9ae6fb163b0e7470755e/lib/general.sh#L32-L81
But, to be honest.. I'm not 100% familiar with this part of the build-script to guide you how this should be done properly. I'm sure, they are.
That's cool.  :) Seeing that the buildscript is used around the world and limited bandwidth helps that people think about issues which aren't 'that much an issue' for those without such limitations. I really hope we can implement it so that it gets default (or at least everyone can set it in the configs) for all armbian users.
I noticed this problem after I stopped the kernel version from moving up on a particular tag and started to change patches to remove errors.
Turned off a few patches to clear the field for observation. And saw that the big aufs patch (it adds a lot of new files) partially applied, causing even more errors, but my fixes have no effect.
  • Igor pinned this topic
Hi Going,
Siberian province sounds nice ! ;-)
After many inspections, it is possible to fix this problem.
Fix incomplete cleaning of the source code.
Removed duplicate code and the unit is not correctly coupled logic.
 lib/general.sh | 42 ++++++++++++++++--------------------------
 1 file changed, 16 insertions(+), 26 deletions(-)
diff --git a/lib/general.sh b/lib/general.sh
index 8de1a352..57ee4e64 100644
--- a/lib/general.sh
+++ b/lib/general.sh
@@ -223,52 +223,42 @@ fetch_from_repo()
 		git remote add origin $url
 	fi
-	local changed=false
 	local local_hash=$(git rev-parse @ 2>/dev/null)
 	case $ref_type in
 		branch)
 		# TODO: grep refs/heads/$name
 		local remote_hash=$(git ls-remote -h $url "$ref_name" | head -1 | cut -f1)
-		[[ -z $local_hash || $local_hash != $remote_hash ]] && changed=true
+		[[ -z $local_hash || $local_hash != $remote_hash ]] && \
+		git fetch --depth 1 origin $ref_name
 		tag)
 		local remote_hash=$(git ls-remote -t $url "$ref_name" | cut -f1)
 		if [[ -z $local_hash || $local_hash != $remote_hash ]]; then
 			remote_hash=$(git ls-remote -t $url "$ref_name^{}" | cut -f1)
-			[[ -z $remote_hash || $local_hash != $remote_hash ]] && changed=true
+			[[ -z $remote_hash || $local_hash != $remote_hash ]] && \
+			git fetch --depth 1 origin tags/$ref_name
 		fi
 		head)
 		local remote_hash=$(git ls-remote $url HEAD | cut -f1)
+		git fetch --depth 1 origin HEAD
 	esac
-	if [[ $changed == true ]]; then
-		# remote was updated, fetch and check out updates
-		display_alert "Fetching updates"
-		case $ref_type in
-			branch) git fetch --depth 1 origin $ref_name ;;
-			tag) git fetch --depth 1 origin tags/$ref_name ;;
-			head) git fetch --depth 1 origin HEAD ;;
-		esac
-		display_alert "Checking out"
-		git checkout -f -q FETCH_HEAD
-	elif [[ -n $(git status -uno --porcelain --ignore-submodules=all) ]]; then
-		# working directory is not clean
-		if [[ $FORCE_CHECKOUT == yes ]]; then
-			git checkout -f -q HEAD
-		else
-			display_alert "Skipping checkout"
-		fi
-	else
-		# working directory is clean, nothing to do
-		display_alert "Up to date"
+	# Return the files that are tracked by git to the initial state.
+	display_alert "Checking out"
+	git checkout -f -q FETCH_HEAD
+	if [ "blank$(git status -s)" != "blank" ]; then
+		# Files that are not tracked by git and were added
+		# when the patch was applied must be removed.
+		display_alert "Cleaning source" "$PWD"
+		git clean -df
 	fi
+	display_alert "Up to date"
 	if [[ -f .gitmodules ]]; then
 		display_alert "Updating submodules" "" "ext"
 		# FML: http://stackoverflow.com/a/17692710
2.13.7
0001-Fix-incomplete-cleaning-of-the-source-code.patch
Check that to understand what it is talking.
Optional patch.
Install at the beginning to see the files added during
the previous patching and compilation.
 lib/main.sh | 9 +++++++++
 1 file changed, 9 insertions(+)
diff --git a/lib/main.sh b/lib/main.sh
index e2e274a1..cdc50156 100644
--- a/lib/main.sh
+++ b/lib/main.sh
@@ -275,6 +275,15 @@ for option in $(tr ',' ' ' <<< "$CLEAN_LEVEL"); do
 	[[ $option != sources ]] && cleaning "$option"
 done
+# Checking for purity src atf, uboot, kernel
+# -it's just information for thought.
+cur_dir=$PWD
+LIST_SRC="$SRC/cache/sources/$ATFSOURCEDIR $SRC/cache/sources/$BOOTSOURCEDIR $SRC/cache/sources/$LINUXSOURCEDIR"
+for IN in $LIST_SRC; do
+	cd $IN; display_alert "In source of $IN dirty files: " "$(git status -s | wc -l)"
+done
+cd $cur_dir
 # Compile u-boot if packed .deb does not exist
 if [[ ! -f $DEST/debs/${CHOSEN_UBOOT}_${REVISION}_${ARCH}.deb ]]; then
 	if [[ -n $ATFSOURCE ]]; then
2.13.7
0002-Check-that-to-understand-what-it-is-talking.patch
I looks OK ... let's test a bit but I guess you can sent a PR to the build script. Thanks!
Ohh - then are my 8MBit here in turkey are better. But when I could get a LTE-Flat it would be faster than the 8MBit ;)
Igor, sorry but the automatic translation does not allow me to understand, you must also send the patches somewhere else? Or is it just enough to put them here? I did not find a description of the patch acceptance procedure in the documentation.
I have a lot of fixes. Well tested I want to send for consideration to acceptance.
In fact, I'm good with the Internet and all the necessary repositories are on a nearby SSD.
There can be several reasons:
- Slow Internet and unwillingness to clean sources every time.
- Inattention, forgetfulness, typo.
- Ignorance of documentation.
In any negative scenario, the source directories must be clean before compiling.
I can add patches but since they are not signed they will retain my name. I want to avoid that whenever possible, especially when author is known. The right way is to create a pull request.
Than is great to hear! Then it is even more important to learn how to do it properly.
Here are some general instructions how to create a pull request on Github:
https://www.armbian.com/get-involved/#submit
https://docs.armbian.com/Process_Contribute
I am pretty sure there must be some guides in your native language if Google translate fails.
Thanks. I saw the applied patches for testing.
I read your links and realized that it is customary to make changes in a separate branch and then pull request.
Of course, first we need to discuss with the community the need to develop new functionality. I will do so in the future.
I'm currently laying out a number of patches that I think are the most important. Although it is not a tradition.
You can apply them on your own behalf, after testing, if you see them reasonable. I don't claim authorship.
Thank you for your understanding.
7 hours ago, going said:
Igor, let's try to open the eyes of users.
Please apply these two patches.
Hey thanks for putting in a lot of effort to make the patches.  Could you submit them as a PR on https://github.com/armbian/build
There are a few others besides igor that can apply discretion and merge practical fixes.
I apologize if I seem rude.
I use automatic translation.
Sometimes the meaning can turn over.
And thank you.
I started working with github.
Now I understand why you don't accept the patches as a patch file
  • Igor unpinned this topic
