CCNORTH Posted October 26, 2019 Posted October 26, 2019 On 10/17/2019 at 5:36 PM, CCNORTH said: Hi Great thanks Balbes150 for the last 2 years with your Armbian images. I have different S912/S905x2 boxes, and no preblem to start Armbian. But my last Boxes comes with Android 9 and with by update the "aml_autoscript.zip" come this error E : footer is wrong update package verification took 0.0´s (result 1) E : signature verification failed E : error 21 When i downgrade to android 8 i have no problems. But my next buy are S905x3 boxes and here is only Android 9 Can anyone help my? thanks Ok, I solved the problem!! Only on Android 9: when the „Aml_autoscript.zip“ ist update and the Box restart, press the „Flash button “ 10sec,(on my boxes is the Flash button rear the Audiojack“) then Boot the Box in Armbian from sdcard.
MrEnderfall Posted October 26, 2019 Posted October 26, 2019 Is WIFI chip at x96mini working now? Or it will never work?
amirul Posted November 6, 2019 Posted November 6, 2019 On 10/25/2019 at 9:05 PM, balbes150 said: New image 20191025 DEV. TX9 Pro (S912) no hdmi sound
hardy021 Posted November 7, 2019 Posted November 7, 2019 On 10/26/2019 at 2:37 PM, CCNORTH said: Ok, I solved the problem!! Only on Android 9: when the „Aml_autoscript.zip“ ist update and the Box restart, press the „Flash button “ 10sec,(on my boxes is the Flash button rear the Audiojack“) then Boot the Box in Armbian from sdcard. Hi everybody and especially CCNORT! I just received my box (2 days) and i have the same problem I tried your solution but nothing works... Can you check my step and tell me if i'm doing wrong? I have a A95X (with the S905X3), i downloaded the "armbian 5.98 aml-g12 Debian buster default 5.3.0 desktop" I burned it on a SDcard class 10 with the "ImageWriter" software Then, into the uEnv.ini and extlinux.conf file, i modified the dtb file with "menson-gxl-s905x-nexbox-a95x.dtb" (i guess it's the right dtb file for my box) I put the SDcard into the slot and switch on the box. Into the update menu, i selected the "aml_autoscript" After the reboot, i have the same error as you and tried to reboot with the "flash button" pressed 10 sec. But i stay with the same boot screen "A95X" and on the LCD screen, we juste see "boot". I let the screen like 3 min and nothing happen ^^ Has anyone an idea of what i'm doing wrong? (sorry for my english xD)
Reddwarf Posted November 7, 2019 Posted November 7, 2019 Will Armbian run ok on this box? https://www.banggood.com/HK1-Max-Plus-RK3368PRO-Octa-Core-4GB-RAM-64GB-ROM-1000M-LAN-5G-WIFI-bluetooth4_0-Android-9_0-4K-TV-Box-p-1587903.html?akmClientCountry=NO&utm_design=18&utm_source=emarsys&utm_medium=Mail_19double1106_deal&utm_campaign=newsletteremarsys&utm_content=elaine&sc_src=email_3987263&sc_eh=4cf6ad6b4e799ac51&sc_llid=623319&sc_lid=164755977&sc_uid=W5qZnmzqQl&ID=533601&cur_warehouse=CN
balbes150 Posted November 10, 2019 Author Posted November 10, 2019 On 11/7/2019 at 7:55 PM, Reddwarf said: Will Armbian run ok on this box? RK3368PRO - not support
amirul Posted November 10, 2019 Posted November 10, 2019 Armbian_5.99_Aml-g12_Ubuntu_bionic_next_5.4.0-rc6-next-20191108_desktop meson-gxm-q200.dtb on T95Z Plus (s912) -> no sound
CCNORTH Posted November 12, 2019 Posted November 12, 2019 On 11/7/2019 at 5:37 PM, hardy021 said: Hi everybody and especially CCNORT! I just received my box (2 days) and i have the same problem I tried your solution but nothing works... Can you check my step and tell me if i'm doing wrong? I have a A95X (with the S905X3), i downloaded the "armbian 5.98 aml-g12 Debian buster default 5.3.0 desktop" I burned it on a SDcard class 10 with the "ImageWriter" software Then, into the uEnv.ini and extlinux.conf file, i modified the dtb file with "menson-gxl-s905x-nexbox-a95x.dtb" (i guess it's the right dtb file for my box) I put the SDcard into the slot and switch on the box. Into the update menu, i selected the "aml_autoscript" After the reboot, i have the same error as you and tried to reboot with the "flash button" pressed 10 sec. But i stay with the same boot screen "A95X" and on the LCD screen, we juste see "boot". I let the screen like 3 min and nothing happen ^^ Has anyone an idea of what i'm doing wrong? (sorry for my english xD) Hi I think you have the wrong dtb file. Your Box have the S905X3 chip. For this chip you need sm1 dtb file. like "meson-sm1-sei610" or other file with "sm1" gxbb = S905 gxl= S905x gxm=S912 g12a= S905x2 g12b=S922 sm1=S905x3
Dhammika Posted November 13, 2019 Posted November 13, 2019 On 6/4/2019 at 4:23 AM, Gossamer said: Building modules, stage 2. MODPOST 1 modules /bin/sh: 1: scripts/mod/modpost: Exec format error scripts/Makefile.modpost:92: recipe for target '__modpost' failed make[2]: *** [__modpost] Error 2 Makefile:1556: recipe for target 'modules' failed make[1]: *** [modules] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-5.0.2-aml-s905' Makefile:1640: recipe for target 'modules' failed make: *** [modules] Error 2 this time I got this after some time compiling.... Has anyone found a solution to this? I am stuck here as well.
balbes150 Posted November 13, 2019 Author Posted November 13, 2019 The results of the first tests on Ugoos x2pro. First impressions are very positive. This model has support for all hardware (including WiFi) on the new core 5. Heating under load (full-screen video via browser) does not exceed 53 degrees. Given that the Android firmware for Ugoos models is considered one of the best, it is a good option for use at home both for working with media content and as a mini PC. And for those who need maximum performance - AM6 with s922x. https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s905x2/776917-x2-cube-amlogic-s905x2-android-9-0-2-16gb-emmc-dual-wifi-gig-lan-usb3-0-samba-server?p=789162#post789162 3
lgranie Posted November 14, 2019 Posted November 14, 2019 (edited) On 11/12/2019 at 7:10 AM, balbes150 said: Update Image 5.99 Hi, Just try this version (debian server) on a x96 max (4/32). It boots well. I can change root password and create an account. But I don't get Ethernet working (not try wifi yet). I've tried with menson-g12a-x96-max.dtb and menson-g12a-x96-max-rmii.dtb without success. What is the differences between this 2 dtb? Regards, Laurent. Edited November 14, 2019 by lgranie
balbes150 Posted November 14, 2019 Author Posted November 14, 2019 1 hour ago, lgranie said: What is the differences between this 2 dtb? menson-g12a-x96-max.dtb - LAN 1Gb menson-g12a-x96-max-rmii.dtb - LAN 100Mb
lgranie Posted November 14, 2019 Posted November 14, 2019 13 minutes ago, balbes150 said: menson-g12a-x96-max.dtb - LAN 1Gb menson-g12a-x96-max-rmii.dtb - LAN 100Mb Thx! As I understand the 4/32 is a 1000M (https://www.aliexpress.com/item/32947778094.html?spm=a2g0s.9042311.0.0.55024c4dmVsp26). I will try again with menson-g12a-x96-max.dtb. How can I confirm that? lspci? lsmod? What I am looking for?
balbes150 Posted November 14, 2019 Author Posted November 14, 2019 I'm opening a new direction-universal image (ver dir NEXT and DEV) for Amlogic+Rockchip+Allwinner. Details can be found in this topic. Please try the new option to run on AML (first of all I am interested in using USB media). 2
geodev Posted November 14, 2019 Posted November 14, 2019 Hello all! I'm currently working on getting a modern Linux kernel working successfully on a w95 (S905W) device. After a lot of work, we have almost everything working as we'd hope. However, WiFi is still evading us. The built-in SSV6051P WiFi chip isn't successfully communicating with the driver, though it does appear to be powering on. Since WiFi works on this device both in AlexELEC and in Android, it's seems to be something that changed when Linux went to the meson drivers instead of using the pseudo-proprietary amlogic kernel and drivers. We're using a slightly modified mainline Arch kernel as our base, but we've been seeing these same problems on Armbian. We've modified the meson-gxl-s905w-p281.dtb with the WiFi implementation given by AlexELEC and our included version of Android, but those modifications have only gotten us to the point of potentially powering on the SSV6051P without actually allowing communication to it. Any time the SSV6051P driver attempts to write to or from an efuse, WiFi memory, or anything related to communication through the SDIO bus to the SSV6051P, it fails silently and returns no result. Does anyone have any experience with this problem, or ones like it? We've been having a lot of trouble figuring this out on our own. Is there anyone who can help us out, or at least point us in the right direction? I understand that WiFi is a real pain to get going on these devices, but we'd even be willing to pay someone if we were able to get this working. Thanks! If this is the wrong place to ask something like this, let me know and I can move it elsewhere. -Andrew geodev55@gmail.com
David0090 Posted November 15, 2019 Posted November 15, 2019 I've been trying to use armbian with a Alfawise A9 4k (2g ram 16gb emmc), but so far I was not able to make the wireless work (can't be detected). I've used the latest image (Armbian_5.99_Aml-g12_Ubuntu_disco_default_5.3.0_20191110.img) , tried a bunch of dtb files, and some do boot (I think the last one I tried was meson-gxl-s905x-p212.dtb ) but the wireless interface never shows up. Any ideas of what I might be doing wrong?
balbes150 Posted November 15, 2019 Author Posted November 15, 2019 13 hours ago, geodev said: I'm currently working on getting a modern Linux kernel working successfully on a w95 (S905W) device. After a lot of work, we have almost everything working as we'd hope. However, WiFi is still evading us. The built-in SSV6051P WiFi chip isn't successfully communicating with the driver, though it does appear to be powering on. Since WiFi works on this device both in AlexELEC and in Android, it's seems to be something that changed when Linux went to the meson drivers instead of using the pseudo-proprietary amlogic kernel and drivers. We're using a slightly modified mainline Arch kernel as our base, but we've been seeing these same problems on Armbian. We've modified the meson-gxl-s905w-p281.dtb with the WiFi implementation given by AlexELEC and our included version of Android, but those modifications have only gotten us to the point of potentially powering on the SSV6051P without actually allowing communication to it. Any time the SSV6051P driver attempts to write to or from an efuse, WiFi memory, or anything related to communication through the SDIO bus to the SSV6051P, it fails silently and returns no result. Does anyone have any experience with this problem, or ones like it? We've been having a lot of trouble figuring this out on our own. Is there anyone who can help us out, or at least point us in the right direction? I understand that WiFi is a real pain to get going on these devices, but we'd even be willing to pay someone if we were able to get this working. Thanks! If this is the wrong place to ask something like this, let me know and I can move it elsewhere. There is no firmware for the main core for this chip. The manufacturer has long ceased to exist and no support for this chip is not and will not be. You're wasting your time on this shit.
lgranie Posted November 15, 2019 Posted November 15, 2019 20 hours ago, balbes150 said: I'm opening a new direction-universal image (ver dir NEXT and DEV) for Amlogic+Rockchip+Allwinner. Details can be found in this topic. Please try the new option to run on AML (first of all I am interested in using USB media). Hi, I tried this yesterday without success : pink characters on a light blue background with a "poor" screen resolution (maybe 640x480) and still no network. This morning I tried CoreElec version 9.2.0. I manage to connect via WiFi but not with Ethernet. I noticed that the dtb filesize differs from 41ko in Armbian (meson-g12a-x96-max.dtb) to 71ko in CoreElec (g12a_s905x2_4g_1gbit.dtb). I noticed to that CoreElec run on a kernel version 4. I imagine that I'm missing something : if there is a dtb call meson-g12a-x96-max.dtb I suppose that it is possible to connect it via Ethernet, no? Regards, Laurent.
balbes150 Posted November 15, 2019 Author Posted November 15, 2019 3 hours ago, lgranie said: This morning I tried CoreElec version 9.2.0. Read the first post of this topic.
Juanjo Posted November 15, 2019 Posted November 15, 2019 Hi, Balbes time ago I sent you a PR for GT1-Mini-A DTS which was accepted, today testing your 5.99 image noted that Kernel is 5.4rc6 and the image does not contain that DTB. Which branches contain which versions on your Github ? LE - > 5.2rc ? Master -> 5.4 ? I'm trying to make a PR for 5.4 and also trying to get support for the GT1 WiFi AP6255: https://gitlab.com/baylibre/amlogic/atv/linux/tree/narmstrong/v5.1/aml/integ-5.1-bcmdhd/drivers/net/wireless/bcmdhd TIA
lgranie Posted November 15, 2019 Posted November 15, 2019 (edited) On 11/15/2019 at 2:45 PM, balbes150 said: Read the first post of this topic. Damned! Edited November 16, 2019 by lgranie Back in business
balbes150 Posted November 15, 2019 Author Posted November 15, 2019 27 minutes ago, Juanjo said: Balbes time ago I sent you a PR for GT1-Mini-A DTS which was accepted, today testing your 5.99 image noted that Kernel is 5.4rc6 and the image does not contain that DTB. Which branches contain which versions on your Github ? LE - > 5.2rc ? Master -> 5.4 ? I'm trying to make a PR for 5.4 and also trying to get support for the GT1 WiFi AP6255: The working branch is master. Other branches are used for tests and are not recommended for use.
lgranie Posted November 17, 2019 Posted November 17, 2019 Hi, I would like to say that after restoring this box via USB (to the Android 9 firmware V311P), I got the Ethernet working on balbes150-Armbian 5.99! That's great! See you next time, Laurent.
Spyelite Posted November 17, 2019 Posted November 17, 2019 Hello guys, I have a amlogic s905x 2/16gb from X96,armbian working from SD card with no problem and i want it to boot from eMMC. The command ./install.sh worked properly tried to boot without SD and nothing...just a black screen and no network connection. I though well...maybe if i use armbian-config to transfer the OS to eMMC it might work,it did not...having the same issue. I have access to root_emmc and boot_emmc when booted from SD card. The files from BOOT_EMMC have the following commands in them: exlinux.conf: LABEL Armbian LINUX /zImage INITRD /uInitrd FDTDIR /dtb # FDT /dtb/meson-gxl-s905x-khadas-vim.dtb APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 uEnv.ini: dtb_name=/dtb/meson-gxl-s905x-khadas-vim.dtb bootargs=root=LABEL=ROOT_EMMC rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 I am not sure why it doesn't boot and i did research before writing this message.
Nofan Tasi Posted November 18, 2019 Posted November 18, 2019 On 11/17/2019 at 11:58 AM, Spyelite said: Hello guys, I have a amlogic s905x 2/16gb from X96,armbian working from SD card with no problem and i want it to boot from eMMC. The command ./install.sh worked properly tried to boot without SD and nothing...just a black screen and no network connection. I though well...maybe if i use armbian-config to transfer the OS to eMMC it might work,it did not...having the same issue. I have access to root_emmc and boot_emmc when booted from SD card. The files from BOOT_EMMC have the following commands in them: exlinux.conf: LABEL Armbian LINUX /zImage INITRD /uInitrd FDTDIR /dtb # FDT /dtb/meson-gxl-s905x-khadas-vim.dtb APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 uEnv.ini: dtb_name=/dtb/meson-gxl-s905x-khadas-vim.dtb bootargs=root=LABEL=ROOT_EMMC rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 I am not sure why it doesn't boot and i did research before writing this message. double check if dtb is correct one and present exlinux.conf root LABEL must perhaps also be ROOT_EMMC
balbes150 Posted November 19, 2019 Author Posted November 19, 2019 On 11/17/2019 at 1:58 PM, Spyelite said: I am not sure why it doesn't boot and i did research before writing this message. 1
balbes150 Posted November 22, 2019 Author Posted November 22, 2019 New image DEFAULT Armbian 5.99_201122 I pay attention, in the future I will release versions of NEXT and DEV only in the format of the universal image (which can be run on all devices at once). 2
