A test version of the image Armbian for TV boxes on the basis of RK3328. Tested on MVR9
http://freaktab.com/forum/tv-player-support/rockchip-based-tv-players/rk3328-devices/653167-bqeel-mvr9-rk3328-quad-core-64bit-cortex-a53-android-7-2-16gb-2-4ghz-wifi-bt4
All basic functions work. For running. Download. Unpack. To record on the SD card. Connect the SD card to TV box, connect a keyboard and mouse. To turn the power on the TV box. The system should start within 2-3 minutes. You must perform the initial configuration of Armbian.
https://yadi.sk/d/DSO6euzB3ahemo
https://mega.nz/#F!zoZywCTQ!9sNfXIAB3m_DyLl5I8P94w
The system of choosing the correct dtb has changed.
Please note, now it should be done on a different principle (files do not need to be copied).
To select the desired dtb, you need to change the line in the text file "/extlinux/extlinux.conf". In the line "FDT" you need to change the name of the file that the system will use at startup. The list of available files (names to specify in the configuration) can be found in the "dtb"directory. If you do not know exactly what file you need , you can enter all available names in turn and check the operation of the system. In accordance with this, the system installation script in eMMC has been changed. The steps to install the system on the eMMC remain the same.
Added a utility to full backup and restore the entire eMMC "ddbr". Checked mode the backup MVR9. Now if you try to check the recovery mode.
The order of installation in eMMC.
1. Download, unzip and burn the image to SD card.
2. Start Armbian on the TV box and perform the initial setup of the system.
3. If the system works correctly and you are satisfied, run the utility "ddbr" and create a full backup of eMMC (this is a prerequisite).
4. Rename the file "/boot/mvr9-uboot.img" in "/boot/uboot.img".
5. Run as user "root" script "/boot/create-mbr-linux.sh"
6. To run the script "/root/install.sh"
Pay attention to the correct operation of the installation procedure need to comply strictly with the order of the steps.
Thanks balbes150.  I'm going to try this on the RK3328 boxes I own as soon as I get a chance.  I'll report back.  Do you have a collection of dtb's for RK3328 boxes anywhere?
Thanks,
Rob
Installed this onto my "SCISHION AI ONE Android 8.1 TV Box - SILVER US PLUG" crap RK3328 box using the "px30-evb-ddr3-lvds-v10" dtb file.  It loads, but when I enter admin and 1234, says "login incorrect".
I must be doing something wrong.  By using "root" instead of "admin", I now have installed Armbian on my RK3328 box.  The Ethernet does NOT work.  Now the question I have is, by changing the device tree and restarting the box, does it use the just installed device tree??
This is my procedure.  I shut down, Linux, remove the microSD card, and connect it to my Windows 10 computer.  I then open the microSD card, and copy a device tree (ex.px30-evb-ddr3-lvds-v10.dtb) to the root of the microSD card, and rename it to dtb.img.  I remove it from my computer (safely) and re-insert it back into my Android box, that is running Android.  I then open the terminal emulator, and type "reboot update", it reboots back into Armbian desktop.  I enter my password and then check the network, and it shows no valid connection found.  I have done the same procedure for almost all of the device trees from the included folder.
So, it appears, that it is NOT using the device trees that I keep changing.
Expand
In this version, only automatic use of dtb by ID is used. The option to manually assign an arbitrary dtb will be in the next versions of the images.
The new version of images 20180831 with support for the standard use of dtb (with manual copying of the desired option to the root of the FAT partition with the name " dtb.img"). If you are using automatic dtb mode, your system is not fully functional (some hardware is not working) or the system does not start at all. You can try to manually add your own version of the dtb file (copy from the directory "/dtb" or use files from other systems Libreelec, Armbian, etc.). To do this, copy the desired option to the root of the FAT partition and rename it to "dtb.img" (in the same way as is done in the images Armbian\Libreelec for Amlogic).
  On 8/31/2018 at 8:47 AM, jeanrhum said:
Yes, I have v88 mini III. I'll try to test your image this week-end.
Is there a specific image you want some feedback ?
Expand
I'm interested in a few things.
1. What will happen if after recording the image, do not change anything in the image manually, connect the SD card with Armbian to the TV box and turn on the power. Whether the system will be able to start automatically.
2. If the system does not start, try to manually add the correct dtb ("dtb.img") and check the launch.
3. If the system can start, check what hardware is running.
  On 8/31/2018 at 9:34 AM, martos said:
Don't boot in automatic, i try dtb
Expand
If you have a dtb that works in any other images (with kernel 4.4), try using it.
i try all dtb rk3328 one by one
for the moment :
i boot on sd on :
xenial-minimal-rock64-0.5.15-136-arm64.img.xz
in read the changelog i see after : "0.6.0: Use SPL/TPL instead of Rockchip's loaders (supports flashing and booting from SPI),"
delete partition 6 and 7 , reboot with usb stick(bionic-minimal-rock64-0.7.9-1067-arm64.img.xz), activate eth1 ( all explain in the post off segv )
If you want I can try to open the box to find rs232 connection to see bootlog.
for the moment :
i boot on sd on :
Expand
What firmware is installed in the TV box now ? If possible, it is better to check on the regular firmware that comes out of the factory. The presence of a log from the UART console will be useful for diagnostics.
on emm is stock android,if i don't have sd it boot .
I find a file dtb in the boot sd on xenial-minimal-rock64-0.5.15-136-arm64.img.xz, i rename it in dtb.img and put in the sd of "Armbian_5.59_Rk3328-tv_Ubuntu_bionic_default_4.4.152_desktop_20180831.img.xz" without success
I open the box and come back
ok so the log is :
U-Boot 2017.09-armbian (Aug 31 2018 - 11:03:12 +0300)
Model: Firefly ROC-RK3328-CC
DRAM:
android boot :
DDR version 1.10 20171106
In
DDR3
333MHz
Bus Width=32 Col=11 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=2048MB
ddrconfig:2
OUT
Boot1 Release Time: 2017-06-12, version: 2.44
ChipType = 0x11, 170
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7456MB
FwPartOffset=2000 , 2000
SdmmcInit=0 2
StorageInit ok = 79048
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x59ba4
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):0ac3e1a
NOTICE:  BL31: Built : 09:14:58, Nov 15 2017
NOTICE:  BL31:Rockchip release version: v1.3
INFO:    ARM GICv2 driver initialized
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 1
INFO:    plat_rockchip_pmu_init: pd status 0xe
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-126-g2a74125 #46        Thu Dec 14 08:21:08 UTC 2017 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.4
INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.02-RK3328-06-02632-g6d55d18 (Jan 24 2018 - 14:26:32)
CPU: rk3328
cpu version = 1
CPU's clock information:
    arm pll = 600000000HZ
    general pll = 491519999HZ
    ddr pll = 664000000HZ
    codec pll = 1200000000HZ
    new pll = 594000000HZ
Board:  Rockchip platform Board
Uboot as second level loader
DRAM:  Found dram banks: 1
Adding bank:0000000000200000(000000007fe00000)
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01e00000
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 20
SdmmcInit = 2 0
storage init OK!
Using default environment
GetParam
remotectl v0.1
pwm freq=0x23c346
pwm_freq_nstime=0x1aa
Load FDT from boot image.
no key node
can't find dts node for fixed
rk816_set_regulator_init vdd_arm init uV:1225000
pmic:rk805
can't find dts node for pwm0
    arm pll = 1200000000HZ
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 2018-01-10#2.44
empty serial no.
normal boot.
checkKey
vbus = 1
board_fbt_key_pressed: ir_keycode = 0x0, frt = 0
no fuel gauge found
no fuel gauge found
can't find power_ctr node for lcdc0
can't find dts node for deviceinfo
rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
left = 0, right = 0, top = 0, bottom = 0, overscan = 0
panel->left = 100 , panel->right = 100 ,panel->top = 100, panel->bottom = 100, p        anel->overscan = 100
tve baseparamer 0x0@0-0
[EDID-EXTEND] It is a  CEA 861 Series Extension.
no baseparametr,find best edid mode,vic=16
hdmi_dev->video.vic is 16
hdmi_dev_config_video vic 16 color_output 3 color_output_depth 8
pixel clk is 148500000 tmds clk is 148500000
hsync_pol 1 vsync_pol 1
[HDMI] sucess output HDMI.
hdmi_dev_config_audio
HDMI_AUDIO_FS_48000
rate = 4, tmdsclk = 148500000, N = 6144, CTS = 148500
read logo on state from dts [1]
no fuel gauge found
checkKey
vbus = 1
Hit any key to stop autoboot:  0
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel   @ 0x00280000 (0x00de4fa8)
ramdisk  @ 0x04bf0000 (0x0019d150)
bootrk: do_bootm_linux...
   Loading Device Tree to 0000000004600000, end 000000000461d5c5 ... OK
Add bank:0000000000200000, 0000000008200000
Add bank:000000000a200000, 0000000075e00000
WARNING: could not set reg FDT_ERR_BADOFFSET.
Starting kernel ...
<hit enter to activate fiq debugger>
[    0.000000]  [0:        swapper:    0] Initializing cgroup subsys cpuset
[    0.000000]  [0:        swapper:    0] Initializing cgroup subsys cpuacct
[    0.000000]  [0:        swapper:    0] Linux version 3.10.104 (qiaohy@server1        ) (gcc version 4.9 20150123 (prerelease) (GCC) ) #12 SMP PREEMPT Wed Jan 24 14:2
boot sd :
! DDR version 1.10 20171106
In
DDR3
333MHz
ddrconfig:2
OUT
ChipType = 0x11, 171
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7456MB
SdmmcInit=0 0
BootCapSize=0
UserCapSize=15193MB
FwPartOffset=2000 , 0
StorageInit ok = 212180
Raw SecureMode = 0
LoadTrustBL
No find bl30.bin
No find bl32.bin
Load OK, addr=0x200000, size=0x92d74
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):f947c7e
NOTICE:  BL31: Built : 09:28:45, May 31 2017
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    SPSR = 0x3c9
U-Boot 2017.09-g5aef9f7 (Oct 12 2017 - 09:11:39 +0000), Build: jenkins-linux-build-rock-64-136
Model: Pine64 Rock64
DRAM:  2 GiB
MMC:   rksdmmc@ff500000: 1, rksdmmc@ff520000: 0
*** Warning - bad CRC, using default environment
In:    serial@ff130000
Out:   serial@ff130000
Err:   serial@ff130000
Net:   eth0: ethernet@ff540000
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
invalid extent block
mmc1 is current device
Scanning mmc 1:6...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
259 bytes read in 3 ms (84 KiB/s)
1:      kernel-4.4
Retrieving file: /initrd.img
reading /initrd.img
3504483 bytes read in 157 ms (21.3 MiB/s)
Retrieving file: /Image
reading /Image
18606088 bytes read in 814 ms (21.8 MiB/s)
append: earlycon=uart8250,mmio32,0xff130000 rw root=LABEL=linux-root rootwait rootfstype=ext4 init=/sbin/init coherent_pool=1M ethaddr=da:d1:f5:a1:86:84 eth1addr=da:d1:f5:a1:86:a4 serial=2f1213b77b38289
Retrieving file: /dtb
reading /dtb
42707 bytes read in 5 ms (8.1 MiB/s)
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to 7dbc2000, end 7df19963 ... OK
   Loading Device Tree to 000000007dbb4000, end 000000007dbc16d2 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
escuse me more the start of Armbian_5.59_Rk3328-tv_Ubuntu_bionic_default_4.4.152_desktop_20180831.img.xz
In
DDR3
333MHz
ddrconfig:2
OUT
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7456MB
SdmmcInit=0 0
BootCapSize=0
UserCapSize=15193MB
StorageInit ok = 231192
Raw SecureMode = 0
LoadTrustBL
No find bl30.bin
No find bl32.bin
Load OK, addr=0x200000, size=0xa3bbc
RunBL31 0x10000
NOTICE:  BL31: Built : 12:09:31, Aug 30 2018
INFO:    Using rkfiq sec cpu_context!
INFO:    SPSR = 0x3c9
DRAM:
--- it stop here ---
Can you stop running Android in u-boot and execute two commands "printenv" and "help" ?  Show the result here.
By the way, you can try to replace the u-boot in the image 5.59, the option from the media that you run. To do this, use dd. Just do not forget when writing u-boot to the media with 5.59 use two commands (with saving MBR).
boot xenial-minimal-rock64-0.5.15-136-arm64.img
=> printenv
arch=arm
baudrate=1500000
board=rock64_rk3328
board_name=rock64_rk3328
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootaa64.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf
boot_mode=unknown
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_targets=mmc0 mmc1 usb0 pxe dhcp
bootargs=earlycon=uart8250,mmio32,0xff130000 rw root=LABEL=linux-root rootwait rootfstype=ext4 init=/sbin/init coherent_pool=1M ethaddr=da:d1:f5:a1:86:84 eth1addr=da:d1:f5:a1:86:a4 serial=2f1213b77b38289
bootcmd=run distro_bootcmd
bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00011:UNDI:003000;setenv bootp_arch 0xb;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_mmc0=setenv devnum 0; run mmc_boot
bootcmd_mmc1=setenv devnum 1; run mmc_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootcmd_usb0=setenv devnum 0; run usb_boot
bootdelay=2
bootfile=/extlinux/extlinux.conf
bootfstype=fat
cpu=armv8
cpuid#=55524b5030393030350000000015051e
devnum=0
devplist=6
devtype=mmc
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
efi_dtb_prefixes=/ /dtb/ /dtb/current/
ethact=ethernet@ff540000
fdt_addr_r=0x01f00000
fdtcontroladdr=7df1db70
fdtfile=rockchip/rk3328-rock64.dtb
fileaddr=1f00000
filesize=0
kernel_addr_r=0x02000000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi
partitions=uuid_disk=${uuid_gpt_disk};name=loader1,start=32K,size=4000K,uuid=${uuid_gpt_loader1};name=reserved1,size=64K,uuid=${uuid_gpt_reserved1};name=reserved2,size=4M,uuid=${uuid_gpt_reserved2};name=loader2,size=4MB,uuid=${uuid_gpt_loader2};name=atf,size=4M,uuid=${uuid_gpt_atf};name=boot,size=112M,bootable,uuid=${uuid_gpt_boot};name=rootfs,size=-,uuid=B921B045-1DF0-41C3-AF44-4C6F280D3FAE;
pxefile_addr_r=0x00600000
ramdisk_addr_r=0x04000000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootaa64.efi; then echo Found EFI removable media binary efi/boot/bootaa64.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
scriptaddr=0x00500000
serial#=2f1213b77b38289
soc=rockchip
stderr=serial@ff130000
stdin=serial@ff130000
stdout=serial@ff130000
usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi
vendor=rockchip
Environment size: 4497/8188 bytes
=> bdinfo
arch_number = 0x00000000
boot_params = 0x00000000
DRAM bank   = 0x00000000
-> start    = 0x00200000
-> size     = 0x7FE00000
baudrate    = 1500000 bps
TLB addr    = 0x7FFF0000
relocaddr   = 0x7FF27000
reloc off   = 0x7FD27000
irq_sp      = 0x7DF1DB60
sp start    = 0x7DF1DB60
Early malloc usage: 470 / 800
fdt_blob = 000000007df1db70
i can't stop android boot. ( hit a key at 0 )
i boot on android
in the shell command
try :
reboot command (usage: reboot [-p] [rebootcommand] )
 hit a key quickly without sucess , android boot ...
