Does the screen display anything when it intitialises, early in the uboot process, or is garbage the first thing you see?  Also, do you see anything in the xorg logs that would give you more information?
Expand
Sadly that is what it show even during the uboot phase.
About xorg, I don't have any X server installed at the moment (to keep the dmesg a bit cleaner... with Xorg installed it was really a mess...)
Do you suggest to make some other try with it installed?
Thanks
Cheers Mix
Thanks
Cheers Mix
Expand
Not really. I was just wondering whether it was an xorg issue, but if the message is from uboot, then you are right that something is wrong at a deeper level.  Guess we'll just have to wait a little longer.
Despite reading the Armbian Documentation many times, I'm still really hazy about applying the uboot video mode options:
How to reconfigure video output?
This affect current kernel only.
U-Boot supports HDMI and LCD output on Allwinner sunxi SoCs, LCD output requires the CONFIG_VIDEO_LCD_MODE Kconfig value to be set.
The sunxi U-Boot driver supports the following video-mode options:
monitor=[none|dvi|hdmi|lcd|vga|composite-*] - Select the video output to use
none: Disable video output.
dvi/hdmi: Selects output over the hdmi connector with dvi resp. hdmi output format, if edid is used the format is automatically selected.
lcd: Selects video output to a LCD screen.
vga: Selects video output over the VGA connector.
composite-pal/composite-ntsc/composite-pal-m/composite-pal-nc: Selects composite video output, note the specified resolution is ignored with composite video output.
Defaults to monitor=dvi.
hpd=[0|1] - Enable use of the HDMI HotPlug Detect feature 0: Disabled. Configure DVI/HDMI output even if no cable is detected 1: Enabled. Fallback to the LCD / VGA / none in that order (if available) Defaults to hpd=1.
hpd_delay=<int> - How long to wait for the HDMI HPD signal in milliseconds When the monitor and the board power up at the same time, it may take some time for the monitor to assert the HPD signal. This configures how long to wait for the HPD signal before assuming no cable is connected. Defaults to hpd_delay=500.
edid=[0|1] - Enable use of DDC + EDID to get monitor info 0: Disabled. 1: Enabled. If valid EDID info was read from the monitor the EDID info will overrides the xres, yres and refresh from the video-mode env. variable. Defaults to edid=1.
overscan_x/overscan_y=<int> - Set x/y overscan value This configures a black border on the left and right resp. top and bottom to deal with overscanning displays. Defaults to overscan_x=32 and overscan_y=20 for composite monitors, 0 for other monitors.
For example to always use the HDMI connector, even if no cable is inserted, using edid info when available and otherwise initalizing it at 1024x768@60Hz, use: setenv video-mode sunxi:1024x768-24@60,monitor=dvi,hpd=0,edid=0.
Parameters regarding video must be saved into U-Boot environment file since they must be read before reading boot script. You can do this by adding saveenv command at the end of boot script (boot.cmd). Remember to recompile boot.cmd to boot.scr and note that changes will come into action after second boot.
Expand
Cheers!
So I finally tried installing the latest 5.4.43 build from Armbian.
  I applied your overlay, compiled and loaded from armbianEnv.txt and added the
setenv video-mode sunxi:1024x600,monitor=lcd,hpd=0,edid=1
line.
For me, the backlight works, but nothing else does.
  I decompiled the /boot/dtb/allwinner/sun50i-a64-pine64.dtb file,
changed the
  dsi@1ca0000 {
                        compatible = "allwinner,sun50i-a64-mipi-dsi";
                        reg = <0x1ca0000 0x1000>;
                        interrupts = <0x00 0x59 0x04>;
                        clocks = <0x02 0x1c>;
                        resets = <0x02 0x05>;
                        phys = <0x41>;
                        phy-names = "dphy";
                        status = "disabled";
                        #address-cells = <0x01>;
                        #size-cells = <0x00>;
                        phandle = <0x84>;
                        port {
                                endpoint {
                                        remote-endpoint = <0x42>;
                                        phandle = <0x1e>;
section to
  dsi@1ca0000 {
                        phys = <0x41>;
                        phy-names = "dphy";
                        status = "enabled";
                        phandle = <0x84>;
                        port {
                                endpoint {
                                        phandle = <0x1e>;
I couldn't find any other references in that file
 and recompiled it.
dmesg | grep dsi lists nothing, while
dmesg | grep mipi
[    3.505719] vcc-mipi: Bringing 2900000uV into 3300000-3300000uV
[    6.603912] Modules linked in: cpufreq_dt zram sch_fq_codel  g_serial libcomposite ip_tables x_tables autofs4 realtek axp20x_usb_power pinctrl_axp209 axp20x_regulator phy_sun6i_mipi_dphy dwmac_sun8i mdio_mux i2c_mv64xxx pwm_bl
and
 dmesg | grep display
root@pine64:~# dmesg | grep drm
[    5.394228] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
I also tried adding
feiyang_fy07024di26a30
and sun6i_mipi_dsi
to /etc/modules.
  with same result.
So we are at least some people, who still wants to get the feiyang display getting work on the pine64.
@Learnincurve
Looks like the kernel 5.4 has not all bits to get it work.
With the 5.6 kernel we are at the same state as 2 years before. The whole DE-pipeline is recognized, but the panel remains out of order because of the vblank issue.
@Gavinb
Could you do us a favor an test the panel wit the 5.6 kernel? If it is working we could maybe find out the differences.
I comment some findings at your github tree for the display patch.
The option that I see, we are have now:
Asking on irc channel of linux-sunix or the linux-sunxi mailinglist how the vblank isusse can be debugged.
Any improvements?
If you can share a dts/dtb and current instructions, I will try to take time in the coming days to test on my board and panel.
I was able to test the LCD7 with Pine64+ some time ago. I lost some work done with a 'rm *' in the wrong dir but i still have the sd card with the dtb if someone would like to 'decompile' it and compare.
What i can recall from the tests are:
* u-boot had hdmi and dsi disabled, so no initial display, only when kernel is up
* the kernel tested  had dsi support,  linux-next (jan 9) [next-20200109], no patches were needed only the patch from @Clément Peron to fix that backlight dim issue.
If you can fetch that specific  linux-next version, only dts with dsi enabled is required.
Refer to: https://groups.google.com/g/linux-sunxi/c/q-RxYnlRqog/m/PQ5pE2kEAQAJ
* try to fetch that version, rebuild.
If you have Pine64 LTS 1.2 , some people reported hw issue, check if that is the case..
Hi @lex and thank you for responding!  I do have a 2GB Pine64+, so would be very interested to take a look at your .dtb
If you could make it available on/to this thread that would be really great!  My guess is that is should also work with the latest kernel.
BR.
--Marius--
Closer:
dmesg | grep dsi
[    2.179940] OF: /soc/dsi@1ca0000: could not get #phy-cells for /soc/pinctrl@1c20800/rgmii-pins
[    2.179949] sun6i-mipi-dsi 1ca0000.dsi: Couldn't get the MIPI D-PHY
Looking at the         pinctrl@1c20800  section, there are quite a few differences between the original and @lex's file, so not sure how much to transpose.
Transposing the whole section is giving far more duplicated phandle errors, so stopping here.
dtc -f -O dtb -o sun50i-a64-pine64-plus.dtb sun50i-a64-pine64-plus_EDITED.dts
sun50i-a64-pine64-plus_EDITED.dts:722.13-726.6: ERROR (explicit_phandles): /soc/pinctrl@1c20800/csi-pins: duplicated phandle 0x3e (seen before at /soc/syscon@1c00000)
sun50i-a64-pine64-plus_EDITED.dts:742.14-748.6: ERROR (explicit_phandles): /soc/pinctrl@1c20800/mmc0-pins: duplicated phandle 0x21 (seen before at /soc/bus@1000000/mixer@100000/ports/port@1/endpoint@1)
sun50i-a64-pine64-plus_EDITED.dts:750.14-756.6: ERROR (explicit_phandles): /soc/pinctrl@1c20800/mmc1-pins: duplicated phandle 0x24 (seen before at /soc/syscon@1c00000/sram@1d00000/sram-section@0)
sun50i-a64-pine64-plus_EDITED.dts:791.17-795.6: ERROR (explicit_phandles): /soc/pinctrl@1c20800/spdif-tx-pin: duplicated phandle 0x2c (seen before at /soc/phy@1c19400)
sun50i-a64-pine64-plus_EDITED.dts:815.15-819.6: ERROR (explicit_phandles): /soc/pinctrl@1c20800/uart1-pins: duplicated phandle 0x2f (seen before at /soc/dma-controller@1c02000)
sun50i-a64-pine64-plus_EDITED.dts:1249.14-1252.7: ERROR (explicit_phandles): /soc/dsi@1ca0000/port/endpoint: duplicated phandle 0x1c (seen before at /soc/lcd-controller@1c0c000/ports/port@0/endpoint@1)
sun50i-a64-pine64-plus_EDITED.dts:1312.15-1315.8: ERROR (explicit_phandles): /soc/hdmi@1ee0000/ports/port@0/endpoint: duplicated phandle 0x23 (seen before at /soc/pinctrl@1c20800)
sun50i-a64-pine64-plus_EDITED.dts:1341.15-1350.5: ERROR (explicit_phandles): /soc/rtc@1f00000: duplicated phandle 0x2e (seen before at /soc/pinctrl@1c20800/uart0-pb-pins)
sun50i-a64-pine64-plus_EDITED.dts:1417.19-1453.5: ERROR (explicit_phandles): /soc/pinctrl@1f02c00: duplicated phandle 0x35 (seen before at /soc/pinctrl@1c20800/i2c0-pins)
Warning: Input tree has errors, output forced
Hopefully someone who knows anything about dtb (as I know nothing), will be able to sort out the mess and post back with advice or edited file
Closer again.
  I'm now using the latest "Armbian Focal mainline based kernel 5.8.y" image,  including the updated dtb .deb update.
  I have modified the dtb, changing the dsi section to "okay", and adding the vcc-dsi line and the feiyang panel subsection.
  This is what I'm getting:
dmesg | grep dsi
[    2.263813] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.265832] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.266675] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.267313] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.271430] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.272127] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.272671] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.273211] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.318595] sun4i-drm display-engine: bound 1ca0000.dsi (ops 0xffff800010daf360)
[    6.716321] feiyang-fy07024di26a30d 1ca0000.dsi.0: [drm:feiyang_dsi_probe [panel_feiyang_fy07024di26a30d]] *ERROR* Couldn't get dvdd regulator
[    6.724523] feiyang-fy07024di26a30d 1ca0000.dsi.0: [drm:feiyang_dsi_probe [panel_feiyang_fy07024di26a30d]] *ERROR* Couldn't get dvdd regulator
[    6.739883] feiyang-fy07024di26a30d 1ca0000.dsi.0: [drm:feiyang_dsi_probe [panel_feiyang_fy07024di26a30d]] *ERROR* Couldn't get dvdd regulator
[    6.752834] feiyang-fy07024di26a30d 1ca0000.dsi.0: [drm:feiyang_dsi_probe [panel_feiyang_fy07024di26a30d]] *ERROR* Couldn't get dvdd regulator
[    6.768429] feiyang-fy07024di26a30d 1ca0000.dsi.0: [drm:feiyang_dsi_probe [panel_feiyang_fy07024di26a30d]] *ERROR* Couldn't get dvdd regulator
[    6.784961] feiyang-fy07024di26a30d 1ca0000.dsi.0: [drm:feiyang_dsi_probe [panel_feiyang_fy07024di26a30d]] *ERROR* Couldn't get dvdd regulator
[    6.788281] feiyang-fy07024di26a30d 1ca0000.dsi.0: [drm:feiyang_dsi_probe [panel_feiyang_fy07024di26a30d]] *ERROR* Couldn't get dvdd regulator
[    6.856971] feiyang-fy07024di26a30d 1ca0000.dsi.0: [drm:feiyang_dsi_probe [panel_feiyang_fy07024di26a30d]] *ERROR* Couldn't get dvdd regulator
[    7.081487] feiyang-fy07024di26a30d 1ca0000.dsi.0: [drm:feiyang_dsi_probe [panel_feiyang_fy07024di26a30d]] *ERROR* Couldn't get dvdd regulator
[    7.120322] feiyang-fy07024di26a30d 1ca0000.dsi.0: [drm:feiyang_dsi_probe [panel_feiyang_fy07024di26a30d]] *ERROR* Couldn't get dvdd regulator
[    7.838355] feiyang-fy07024di26a30d 1ca0000.dsi.0: [drm:feiyang_dsi_probe [panel_feiyang_fy07024di26a30d]] *ERROR* Couldn't get dvdd regulator
Any advice on the feiyang dvdd regulator?
I found the following code at https://mjmwired.net/kernel/Documentation/devicetree/bindings/display/panel/feiyang,fy07024di26a30d.txt:
Feiyang FY07024DI26A30-D 7" MIPI-DSI LCD Panel
Required properties:
- compatible: must be "feiyang,fy07024di26a30d"
- reg: DSI virtual channel used by that screen
- avdd-supply: analog regulator dc1 switch
- dvdd-supply: 3v3 digital regulator
- reset-gpios: a GPIO phandle for the reset pin
Optional properties:
- backlight: phandle for the backlight control.
panel@0 {
		compatible = "feiyang,fy07024di26a30d";
		reg = <0>;
        avdd-supply = <&reg_dc1sw>;
        dvdd-supply = <&reg_dldo2>;
        reset-gpios = <&pio 3 24 GPIO_ACTIVE_HIGH>; /* LCD-RST: PD24 */ backlight = <&backlight>;
In the regulatotrs section of my active dtb -> dts file I find
  reg_dc1sw = "/soc/rsb@1f03400/pmic@3a3/regulators/dc1sw";
                reg_dcdc1 = "/soc/rsb@1f03400/pmic@3a3/regulators/dcdc1";
                reg_dcdc2 = "/soc/rsb@1f03400/pmic@3a3/regulators/dcdc2";
                reg_dcdc3 = "/soc/rsb@1f03400/pmic@3a3/regulators/dcdc3";
                reg_dcdc4 = "/soc/rsb@1f03400/pmic@3a3/regulators/dcdc4";
                reg_dcdc5 = "/soc/rsb@1f03400/pmic@3a3/regulators/dcdc5";
                reg_dcdc6 = "/soc/rsb@1f03400/pmic@3a3/regulators/dcdc6";
                reg_dldo1 = "/soc/rsb@1f03400/pmic@3a3/regulators/dldo1";
                reg_dldo2 = "/soc/rsb@1f03400/pmic@3a3/regulators/dldo2";
but after editing the dts file like:
panel@0 {
                                reg = <0x00>;
                                reset-gpios = <0x23 0x03 0x18 0x00>;
                                backlight = <0x43>;
It won't compile, so obviously I don't understand. Any tips?
I updated the system with the new dtb package and edited the tree again, this time without the feiyang panel.  Here are the the .dts snippets for dsi and d-phy:
   dsi@1ca0000 {
                        phys = <0x44>;
                        phy-names = "dphy";
                        status = "okay";
                        phandle = <0x8d>;
                        vcc-dsi-supply = <0x04>;
                        port {
                                endpoint {
                                        remote-endpoint = <0x45>;
                                        phandle = <0x20>;
                d-phy@1ca1000 {
                        compatible = "allwinner,sun50i-a64-mipi-dphy\0allwinner,sun6i-a31-mipi-dphy";
                        reg = <0x1ca1000 0x1000>;
                        clocks = <0x02 0x1c 0x02 0x71>;
                        clock-names = "bus\0mod";
                        status = "okay";
                        #phy-cells = <0x00>;
                        phandle = <0x44>;
This time, dmesg is at least not displaying any mipi or dsi-related errors:
# dmesg | grep dsi
[    2.318045] sun4i-drm display-engine: bound 1ca0000.dsi (ops 0xffff800010daf360)
~# dmesg | grep mipi
[    2.275838] vcc-mipi: Bringing 2900000uV into 3300000-3300000uV
so definitely closer.
Now I'm going to re-visit the thread and armbian documentation to see what needs to be done to enable.
Found that this isn't going to work without the Feiyang panel. Where I am stuck now is the reset-gpios for the feiyang panel   dts code extracted from @lex's dtb post earlier in this thread and modified with unique phandles for the current tree:
dsi@1ca0000 {
            phys = <0x44>;
            phy-names = "dphy";
            status = "okay";
            phandle = <0x8d>;
            port {
                endpoint {
                    phandle = <0x20>;
            panel@0 {
                reg = <0x00>;
                avdd-supply = <0x41>;
                dvdd-supply = <0xa5>;
                backlight = <0xb2>;
and the gpios and enable-gpios for the backlight and regulator:
    backlight {
        compatible = "pwm-backlight";
        pwms = <0x4f 0x00 0xc350 0x01>;
        brightness-levels = <0x00 0x0a 0x14 0x1e 0x28 0x32 0x3c 0x46 0x50 0x5a 0x64>;
        default-brightness-level = <0x08>;
        enable-gpios = <0x23 0x07 0x0a 0x00>; Probabløy incorrect
        power-supply = <0xb2>;
        phandle = <0xb1>;
    vdd-backlight {
        compatible = "regulator-fixed";
        regulator-name = "vdd-backlight";
        regulator-min-microvolt = <0x325aa0>;
        regulator-max-microvolt = <0x325aa0>;
        gpio = <0x23 0x03 0x07 0x00>; Probably incorrect
        enable-active-high;
        phandle = <0xb2>;
Hey @Learnincurve, have you gotten any further with this? Do I understand correctly that you can't test it because you don't have the panel?
I'd be willing to test if you'd like :) I have a Pine64-LTS with a LCD panel from Pine64 (and the 'playbox' as well) so if you want I could test stuff? Just tell me what to do!
Cheers!
Cheers!
Expand
Hi p1x313d.
  Thank you for your support!  No. The problem is not that I don't have the panel, I do.  My problem is lack of understanding and knowledge regarding the Device Tree.
I am at the stage where I am stuck, unable to correctly set the pins (I think) for the panel.
@lex was able to do this, using an earlier kernel and  device tree, but too many internal references in the later available trees have changed, and I'm not smart enough to sort them out.
  If you or anyone else would like to help trying to debug, I'd be very grateful, as this is holding up being able to move to a mainline kernel for anyone with the Pine64+ and the feiyang panel.
Here's my latest logging output:
 dmesg | grep dsi
[    2.261142] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.263148] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.263985] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.264616] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.268920] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.269694] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.270269] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.270807] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    2.316217] sun4i-drm display-engine: bound 1ca0000.dsi (ops 0xffff800010daf360)
[    5.482679] OF: /soc/dsi@1ca0000/panel@0: could not get #gpio-cells for /soc/hdmi@1ee0000/ports/port@0/endpoint
[    5.482717] feiyang-fy07024di26a30d 1ca0000.dsi.0: [drm:feiyang_dsi_probe [panel_feiyang_fy07024di26a30d]] *ERROR* Couldn't get our reset GPIO
[    5.482855] feiyang-fy07024di26a30d: probe of 1ca0000.dsi.0 failed with error -22
attached, you can find my dtb and corresponding dts files, as well as the .dts of @lex's working example sun50i-a64-pine64+_MIPI.dts for patched kernel 5.3/5.4 . @lex's .dtb is attached to his earlier post in this thread, but I can re-attach it if it is no longer available to download. Note that mipi-dsi was only included in mainline from 5.6
sun50i-a64-pine64-plus.dts sun50i-a64-pine64+_MIPI.dts
Update:  I just took out the feiyang panel section in the device tree, as that gives the clearest dmesg indication that the dsi port is working:
dmesg | grep dsi
[    2.315495] sun4i-drm display-engine: bound 1ca0000.dsi (ops 0xffff800010da8a60)
 dmesg | grep panel
[    2.315223] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
Expand
Have also discovered armbianmonitor -u. Dump at
http://ix.io/2E03
http://ix.io/2E03
Expand
As I saw in these data:
[    2.285937] sun6i-mipi-dsi 1ca0000.dsi: supply vcc-dsi not found, using dummy regulator
Maybe it comes from there, because after searching about this error, I found these 2 links:
- https://patchwork.kernel.org/project/linux-arm-kernel/patch/20181026144344.27778-17-jagan@amarulasolutions.com/
- https://gitlab.com/pine64-org/linux/-/commit/6beba7fbeeeee35130dade8766c1797b498d0a3f
And looking at your dts file with panel, I saw that the dldo1 node (phandle 0x04) is labelled as "vcc-hdmi" and it is referenced both in the dsi node (vcc-dsi-supply) and in the hdmi node (hvcc-supply). If I remember well about the legacy kernel, when you activated the panel, the hdmi didn't work anymore. So maybe you can try to deactivate the hdmi part...
I'm a newbie about dts, so be careful about my analysis.
Expand
Good suggestion!   I did try disabling hdmi stuff earlier (without success, but not sure if it was before or after adding the panel, so will try again).  I'm also a DTS-noob and finding it hard to get my head around it.  Hence my spamming of this thread, which it looks like the experts are now filtering out (can't say I blame them).
:love::
Issue is finally fixed in (at least) nightly builds !
There is now a "pine64-7inch-lcd" overlay in /boot/dtb//allwinner/overlay
Just add
 "overlays=pine64-7inch-lcd"
to armbianEnv.txt and screen magically works.
A BIG thank you to the team for fixing this! Pine64 is now ready for mainline kernel goodness!
  On 12/4/2020 at 1:44 PM, eminguez said:
Nice!!!!
Do you happen to have a link to download the latest nightly? https://minio.k-space.ee/armbian/dl/pine64/nightly/Armbian_21.02.0-trunk.7_Pine64_buster_current_5.9.11.img.xz seems to fail for me.
Thanks.
Expand
I cheated and upgraded to nightly from the latest stable build, which you can do from the armbian-config  - System menu. Otherwise I see that all of https://minio.k-space.ee/armbian/ is unavailable at the moment.  The link will probably work again later.
Expand
Work is ongoing on improving infrastructure (load balancing, re-directs, etc.).  And therefore it's probably best to discuss and make forum links to the "original" link, instead of whatever the redirect ends up going to, as the latter is going to vary for people based on their region and some other things.  Also they may go up and down for various reasons, etc.
Edited by TRS-80
add last sentence
