atula Posted March 6, 2019 Posted March 6, 2019 root@rockpi:~# dmesg|grep serial [ 1.965909] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A [ 1.969249] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A [ 1.972774] ff370000.serial: ttyS1 at MMIO 0xff370000 (irq = 41, base_baud = 1500000) is a 16550A what pin is "ttyS0" ? when "okay" serial@ff1b0000 { .................................... pinctrl-0 = < 0x42 >; status = "disabled"; phandle = < 0xd9 >; network fall 0 Quote
martinayotte Posted March 6, 2019 Posted March 6, 2019 On 3/6/2019 at 12:41 PM, atula said: serial@ff1b0000 { .................................... pinctrl-0 = < 0x42 >; Expand This UART is UART3, and according to DT, it is pins GPIO3_B6 and GPIO3_B7 ... But be aware that those pins are used on most of the boards for the Ethernet GMAC ! Since we still don't have access to RockPi4B schematic, it is a bit hard to confirm ... If you are looking for serial@ff180000, it is UART0, than the pins are GPIO2_C0 and GPIO2_C1, which on some board is a UART connected to BlueTooth. If you are looking at the UART available on Header at usual pin 8/10, it is GPIO4_C3 and GPIO4_C4, which is the UART2 located in node serial@ff1a0000. 0 Quote
atula Posted March 6, 2019 Posted March 6, 2019 I ask more,,,sorry what pin is w1 default pin ? how i find it 0 Quote
martinayotte Posted March 6, 2019 Posted March 6, 2019 On 3/6/2019 at 5:32 PM, atula said: what pin is w1 default pin ? Expand The rockchip-w1-gpios.dtbo overlay has it hard coded to GPIO1_A4, which is available on both RockPro64 and NanoPCT4, but unfortunately not availaible on RockPi4B ... For RockPi4B, you will have to either do yourself a custom build with a patch that change this pin, or decompile/edit/recompile de overlay itself. In longer terms, I will try to make the "param_w1_pin" available and working in /boot/armbianEnv.txt, but it can take while ... 0 Quote
martinayotte Posted March 6, 2019 Posted March 6, 2019 On 3/6/2019 at 5:32 PM, atula said: what pin is w1 default pin ? Expand Finally, the "param_w1_pin" management task didn't took too long ... Commits needed : https://github.com/armbian/build/commit/aba46df74255c7684112a921014dab75bafd3414 https://github.com/armbian/build/commit/e4e34c7f15b33a3a186033a0c40555c208f035ee I've tested it by providing "param_w1_pin=GPIO4_C5" as an alternate pin on RockPro64, and it is now working ... EDIT : additional commits for other RK3399 boards have been added ... 0 Quote
atula Posted March 10, 2019 Posted March 10, 2019 w1 works "param_w1_pin=GPIO4_D5" ok how to find i2c root@rockpi:~# dmesg|grep i2c [ 1.543735] i2c /dev entries driver and root@rockpi:~# ls /dev/*i2c* /dev/i2c-0 /dev/i2c-1 /dev/i2c-3 /dev/i2c-4 i2cdetect find nothing 0 Quote
martinayotte Posted March 10, 2019 Posted March 10, 2019 On 3/10/2019 at 8:50 AM, atula said: i2cdetect find nothing Expand Which I2C are you using, the one on the RockPi Header ? It is I2C7, which need the new overlay just committed ... Which device did you connect to that bus ? 0 Quote
atula Posted March 10, 2019 Posted March 10, 2019 GPIO2_A7, GPIO2_B0, like raspberry or GPIO2_A0, GPIO2_A1 or ? BMP280, ds2482, ds2483 and ADS115... + i have two, rockpi4a and rockpi4b, how i repare MAC adress 0 Quote
martinayotte Posted March 10, 2019 Posted March 10, 2019 On 3/10/2019 at 2:51 PM, atula said: GPIO2_A7, GPIO2_B0, like raspberry or GPIO2_A0, GPIO2_A1 or ? Expand Right ! I2C7 is on GPIO2_A7/GPIO2_B0 ... (but what do you mean by "like raspberry" ?) On 3/10/2019 at 2:51 PM, atula said: i have two, rockpi4a and rockpi4b, how i repare MAC adress Expand What do you mean ? 0 Quote
atula Posted March 10, 2019 Posted March 10, 2019 two same addresses do not work on the same network, the other must be different (dhcp IP) "/dev/i2c-0 /dev/i2c-1 /dev/i2c-3 /dev/i2c-4" none is working 0 Quote
martinayotte Posted March 10, 2019 Posted March 10, 2019 On 3/10/2019 at 3:53 PM, atula said: two same addresses do not work on the same network, the other must be different (dhcp IP) Expand I understand, but are those two RockPi has the same MAC ? On 3/10/2019 at 3:53 PM, atula said: "/dev/i2c-0 /dev/i2c-1 /dev/i2c-3 /dev/i2c-4" none is working Expand As I said, the I2C on the RockPi header are not one of those, it is I2C7 ! You need to enable it either in Main DT or using a overlay for the node i2c@ff160000 0 Quote
atula Posted March 10, 2019 Posted March 10, 2019 yes, in all RockPi image use the same MAC. in radxa rock it modify in "parameter" txt, raspberry also 0 Quote
atula Posted March 10, 2019 Posted March 10, 2019 i2c work now fine, thank you i try find MAC 0 Quote
atula Posted March 13, 2019 Posted March 13, 2019 WD Black 500GB, PCIe, 3400/2500 MB/s - SSD- M.2 works only Armbian_5.67_Rockpi4b_Debian_stretch_default_4.4.154_desktop_20181210-gpt.img.gz i'll test later other (Kingston 240GB A1000, PCIe NVMe, 1500/1000 MB/s -SSD) SSD disks, other armbian images not working this M.2 SSD disk Armbian_5.73.190128_Rockpi-4b_Debian_stretch_dev_4.20.0.img PCIe NVMe not work can i download Armbian_5.67_Rockpi4b_Debian_stretch_default_4.4.154_desktop_20181210-gpt.img.gz without a desktop this img? 0 Quote
martinayotte Posted March 13, 2019 Posted March 13, 2019 On 3/13/2019 at 3:49 PM, atula said: Armbian_5.73.190128_Rockpi-4b_Debian_stretch_dev_4.20.0.img Expand That is normal that RockPi-4B doesn't work with PCIe, it is not part of current DT ! Maybe in the future ... 0 Quote
atula Posted March 20, 2019 Posted March 20, 2019 On 3/6/2019 at 2:17 PM, martinayotte said: This UART is UART3, and according to DT, it is pins GPIO3_B6 and GPIO3_B7 ... But be aware that those pins are used on most of the boards for the Ethernet GMAC ! Since we still don't have access to RockPi4B schematic, it is a bit hard to confirm ... If you are looking for serial@ff180000, it is UART0, than the pins are GPIO2_C0 and GPIO2_C1, which on some board is a UART connected to BlueTooth. If you are looking at the UART available on Header at usual pin 8/10, it is GPIO4_C3 and GPIO4_C4, which is the UART2 located in node serial@ff1a0000. Expand i have rockpi 4 A model without bluetooth, its possible use serial@ff180000 UART0 gpio like GPIO4_D5, (RX) 0 Quote
martinayotte Posted March 20, 2019 Posted March 20, 2019 On 3/20/2019 at 9:05 PM, atula said: i have rockpi 4 A model without bluetooth, its possible use serial@ff180000 UART0 gpio like GPIO4_D5, (RX) Expand What do you mean ? I don't have Model A schematic ... Is the GPIO2_C0/GPIO2_C1 are available on some header pins ? ... It is not the case for Model B ... 0 Quote
atula Posted March 21, 2019 Posted March 21, 2019 it is the same for both models https://wiki.radxa.com/Rockpi4/hardware/rockpi4#gpio 0 Quote
martinayotte Posted March 21, 2019 Posted March 21, 2019 On 3/21/2019 at 5:56 AM, atula said: it is the same for both model Expand So, this UART0 is not available ... 0 Quote
gufmar Posted April 8, 2019 Posted April 8, 2019 On 3/1/2019 at 3:32 PM, martinayotte said: You need to install DT compiler from : http://ftp.debian.org/debian/pool/main/d/device-tree-compiler/device-tree-compiler_1.4.7-3_arm64.deb Backup /boot/dtb/rockchip/rk3399-rockpi4b.dtb into /boot/dtb/rockchip/rk3399-rockpi4b.dtb-ORIG Decompile the DTB into DTS : dtc -@ -I dtb -O dts -o rk3399-rockpi4b.dts-4.20.0 /boot/dtb/rockchip/rk3399-rockpi4b.dtb Edit the file rk3399-rockpi4b.dts-4.20.0 by changing all the serial node from "disabled" to "okay", then recompile DTB : dtc -@ -I dts -O dtb -o /boot/dtb/rockchip/rk3399-rockpi4b.dtb rk3399-rockpi4b.dts-4.20.0 Expand 2 Thank you very much, this helped a lot! some details who may help others: (note: I'm not an expert) install DT compiler version from the above link, not from online mirrors. to do so cd into temp directory, curl or wget the above url and chown +x the file as executable Then install with apt cd /tmp wget http://ftp.debian.org/debian/pool/main/d/device-tree-compiler/device-tree-compiler_1.4.7-3_arm64.deb sudo chmod +x device-tree-compiler_1.4.7-3_arm64.deb sudo apt install device-tree-compiler_1.4.7-3_arm64.deb decompile DTB to DTS as mentioned above. open the decompiled file and lookup for the interface in the aliases section (e.g. i2c7) You will find the address (e.g. i2c@ff160000) scroll down now to this address and verify that status is set to okay status = "okay"; if not change and re-compile to DTB As I'm not an expert I wonder if it's possible to change or increase the i2c baudrate to 400 kHz ? I found descriptions to add dtparam=i2c_arm=on,i2c_baudrate=400000 to /boot/config.txt As Armbian hasn't this config file I tried to add the same line to /boot/armbianEnv.txt but it doesn't seem to have any effect. 0 Quote
martinayotte Posted April 8, 2019 Posted April 8, 2019 On 4/8/2019 at 11:55 AM, gufmar said: Then install with apt cd /tmp wget http://ftp.debian.org/debian/pool/main/d/device-tree-compiler/device-tree-compiler_1.4.7-3_arm64. sudo chown +x device-tree-compiler_1.4.7-3_arm64 sudo apt install device-tree-compiler_1.4.7-3_arm64 Expand The normal way to install is to do "dpkg -i device-tree-compiler_1.4.7-3_arm64.deb" ... On 4/8/2019 at 11:55 AM, gufmar said: increase the i2c baudrate to 400 kHz ? Expand It should be done within the DT using "clock-frequency = <400000>;" in the i2c node, nearby the "status" 1 Quote
gufmar Posted April 10, 2019 Posted April 10, 2019 On 4/8/2019 at 2:13 PM, martinayotte said: It should be done within the DT using "clock-frequency = <400000>;" in the i2c node, nearby the "status" Expand perfect solution. works fine. thank you! For thus who try to C&P the above clock-frequency string: Attention it contains non-standard space chars after the number. So compiling to dtb fil fail with an error. Better use clock-frequency = <400000>; 1 Quote
atula Posted June 15, 2019 Posted June 15, 2019 Armbian_5.88_Rockpi-4b_Debian_stretch_default_4.4.180 what pin is w1 default pin ? i not find /boot/dtb/rockchip/overlay i try armbianEnv.txt overlays=w1-gpio param_w1_pin=GPIO4_D2 and root@rockpi:/# lsmod Module Size Used by w1_therm 16384 0 w1_gpio 16384 0 wire 32768 2 w1_gpio,w1_therm but nothing /sys/bus/w1/devices/ 0 Quote
Igor Posted June 15, 2019 Posted June 15, 2019 On 6/15/2019 at 1:16 PM, atula said: i not find /boot/dtb/rockchip/overlay Expand Somebody needs to develop this feature, but since relation between developers and users wishes are extremely extreme, you can't use this feature unless you do it. Here https://github.com/armbian/sunxi-DT-overlays you can observe overlays project made for Allwinner chips. As an example. 0 Quote
martinayotte Posted June 16, 2019 Posted June 16, 2019 On 6/15/2019 at 1:16 PM, atula said: Armbian_5.88_Rockpi-4b_Debian_stretch_default_4.4.180 Expand Overlays are only available with Mainline ... 0 Quote
atula Posted August 4, 2019 Posted August 4, 2019 Debian Buster with Armbian Linux 4.4.184-rockchip64 dev/ttyS2 , dev/ttyS4 not works, only read dev /ttyUSB0 woks fine root@rockpi:~# digitemp_DS9097U -i -s /dev/ttyS4 -c digitemp.conf DigiTemp v3.7.2 Copyright 1996-2018 by Brian C. Lane GNU General Public License v2.0 - http://www.digitemp.com Error 5: DS2480B Adapter Not Detected Error 10: Read COM Failed root@rockpi:~# digitemp_DS9097U -i -s /dev/ttyUSB0 -c digitemp.conf DigiTemp v3.7.2 Copyright 1996-2018 by Brian C. Lane GNU General Public License v2.0 - http://www.digitemp.com Turning off all DS2409 Couplers . Searching the 1-Wire LAN 28208071030000A0 : DS18B20 Temperature Sensor ROM #0 : 28208071030000A0 owfs works i2c adapter but not serial DS2480B, digitemp also.......maybe old systems passive readers works both ...ttyS2 and ....ttyS4 and onewire works also now 0 Quote
atula Posted August 29, 2019 Posted August 29, 2019 serialport /dev/ttyS4 problem is boot. when reconnect tx cable or ds2480 pover after boot it works. problem is only armbian maybe on board SPI1 W25Q64F***.....? 0 Quote
atula Posted October 5, 2019 Posted October 5, 2019 Debian Buster with Armbian Linux 4.4.184-rockchip64 Kingston 240GB A1000 SSD, Samsung 250GB 970 EVO Plus SSD-levy, M.2 2280, PCIe 3.0 x4, NVMe, 3500/2300 MB/s, XPG GAMMIX S5 PCIe Gen3x4 M.2 2280 512 works not support Intel 512GB 660P 1500/1000 MB/s -SSD- M.2, not find it linaro-alip 4.4.154 works and boot Intel 512GB 660P 1500/1000 MB/s -SSD- M.2 from spi XPG GAMMIX S5 PCIe Gen3x4 M.2 2280 512 boot also spi but not stabile Samsung 250GB 970 EVO Plus SSD-, M.2 2280, PCIe 3.0 x4, NVMe, 3500/2300 MB/s, Kingston 240GB A1000 SSD not boot spi 0 Quote
