ron123456 Posted November 29, 2018 Share Posted November 29, 2018 Hi I am using a NanoPi M1+ device with nanopi-m1-plus_sd_friendlycore-xenial_4.14_armh OS in it. I attached an RTL8188EU WiFi adapter in it. But the **ifconfig** doesn't show up. On doing **lsusb** I get Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 002: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 029: ID 413c:2113 Dell Computer Corp. Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub I tried downloading the driver from https://github.com/lwfinger/rtl8188eu and after issuing the make command, I got this error: make ARCH=arm CROSS_COMPILE= -C /lib/modules/4.11.0-rc4/build M=/home/pi/rtl8188eu modules make[1]: *** /lib/modules/4.11.0-rc4/build: No such file or directory. Stop. Makefile:151: recipe for target 'modules' failed make: *** [modules] Error 2 I also download **linux-headers-generic** package. What is the issue? Link to comment Share on other sites More sharing options...
guidol Posted November 29, 2018 Share Posted November 29, 2018 2 hours ago, ron123456 said: Hi I am using a NanoPi M1+ device with nanopi-m1-plus_sd_friendlycore-xenial_4.14_armh OS in it. I got this error: make ARCH=arm CROSS_COMPILE= -C /lib/modules/4.11.0-rc4/build M=/home/pi/rtl8188eu modules make[1]: *** /lib/modules/4.11.0-rc4/build: No such file or directory. Stop. I also download **linux-headers-generic** package. What is the issue? You are using a 4.14 kernel (of FriendlyCore from FriendlyARM whcih isnt supported in this forum) and your module source is for a 4.11 kernel - thats the issue that doesnt match. You could try armbian images (both also kernel 4.14) fromhttps://www.armbian.com/nanopi-m1-plus/https://dl.armbian.com/nanopim1plus/archive/Armbian_5.65_Nanopim1plus_Ubuntu_bionic_next_4.14.78.7zhttps://dl.armbian.com/nanopim1plus/archive/Armbian_5.65_Nanopim1plus_Debian_stretch_next_4.14.78.7z but the status of the M1+ is for armbian EOS=End od Service - because there are to much other SBCs I dont know if yout USB-WiFi is supported with this armbian-version. Link to comment Share on other sites More sharing options...
martinayotte Posted November 29, 2018 Share Posted November 29, 2018 3 hours ago, ron123456 said: I am using a NanoPi M1+ device Why don't you use the built-in AP6212 WiFi of this NanoPi-M1+ board ? Link to comment Share on other sites More sharing options...
ron123456 Posted November 30, 2018 Author Share Posted November 30, 2018 12 hours ago, martinayotte said: Why don't you use the built-in AP6212 WiFi of this NanoPi-M1+ board ? Actually, I am trying to make a router that can have both Station and AP for wifi to wifi mode Link to comment Share on other sites More sharing options...
ron123456 Posted November 30, 2018 Author Share Posted November 30, 2018 21 hours ago, guidol said: You are using a 4.14 kernel (of FriendlyCore from FriendlyARM whcih isnt supported in this forum) and your module source is for a 4.11 kernel - thats the issue that doesnt match. You could try armbian images (both also kernel 4.14) fromhttps://www.armbian.com/nanopi-m1-plus/https://dl.armbian.com/nanopim1plus/archive/Armbian_5.65_Nanopim1plus_Ubuntu_bionic_next_4.14.78.7zhttps://dl.armbian.com/nanopim1plus/archive/Armbian_5.65_Nanopim1plus_Debian_stretch_next_4.14.78.7z but the status of the M1+ is for armbian EOS=End od Service - because there are to much other SBCs I dont know if yout USB-WiFi is supported with this armbian-version. 10 Hey, I downloaded the Armbian Bionic kernel 4.14.y OS and it detected the RTL8188 wlan adapter. But it is unable to connect to the wifi as station. I am using the internal wifi hardware for AP and external wlan adapter (RTL8188) to connect to the WiFi. On doing ... root@nanopim1plus:~# wpa_supplicant -B -c /etc/wpa_supplicant/wpa_supplicant.conf -i wlxc025e925ab14 I got, Successfully initialized wpa_supplicant nl80211: Could not configure driver mode nl80211: deinit ifname=wlxc025e925ab14 disabled_11b_rates=0 wlxc025e925ab14: Failed to initialize driver interface I dont know how to resolve this? Link to comment Share on other sites More sharing options...
Igor Posted December 2, 2018 Share Posted December 2, 2018 On 11/30/2018 at 1:32 PM, ron123456 said: I dont know how to resolve this? - try using recommended way of connecting to wireless: https://docs.armbian.com/User-Guide_Getting-Started/#how-to-connect-to-wireless - blacklisting internal driver and searching for a better one. (we can't develop armbian, deal with its users and support every wifi on the planet with a few people. Search Github for projects as such: https://github.com/ulli-kroll ) Link to comment Share on other sites More sharing options...
