Hello everybody.
I'm little bit confused with this think.
Which libraries are good (best) for H5 OPiZeroPlus board .?
 - WiringPI
 - ArmbianIO
 - GPIOzero
or ..??
I have small script for timer switch, but it is not stably as well as I can.
Button press is not accurate. (some pull-up/down are missing probably)
Thanks for answer or suggestion.
(PS: I'm not a programmer guru)
Hi Jrd,
I also just started programming the OPi Zero Plus and I am using ArmbianIO as I understood the other two are for the Raspberry or don't support the H5. The problem that you describe could be contact bounce maybe? I didn't get to test the buttons in my project yet.
Hans
Within armbian you find following User-Supported options:
ArmbianIO (sysFS) or
userspaceIO (libgpiod),
pyGPIO accesses 'pins' directly through /dev/mem
 ArmbianIO API
https://forum.armbian.com/topic/5655-armbianio-api-proposal/
 User Space IO is Python 3 and Java 8 bindings for user space GPIO, SPI, I2C, PWM and Serial interfaces
https://forum.armbian.com/topic/6523-user-space-io-is-python-3-and-java-8-bindings-for-user-space-gpio-spi-i2c-pwm-and-serial-interfaces/
 pyGPIO - A 'more general' python GPIO library based on pyA20
https://forum.armbian.com/topic/5662-pygpio-a-more-general-python-gpio-library/
