Hi Igor,
Thank you for the download but  get the following error:
noname@hc1:~$ sudo apt install wireguard-tools_1.0.20200827-1_bpo10+1_armhf.deb
Reading package lists... Done
Building dependency tree
E: Unable to locate package wireguard-tools_1.0.20200827-1_bpo10+1_armhf.deb
E: Couldn't find any package by glob 'wireguard-tools_1.0.20200827-1_bpo10+1_armhf.deb'
E: Couldn't find any package by regex 'wireguard-tools_1.0.20200827-1_bpo10+1_armhf.deb'
noname@hc1:~$
What I'm doing wrong?
Thanks for helping
ChriWo
wget http://ftp.us.debian.org/debian/pool/main/w/wireguard/wireguard-tools_1.0.20200827-1~bpo10+1_armhf.deb
sudo dpkg -i wireguard-tools_1.0.20200827-1~bpo10+1_armhf.deb
Dear Igor,
Thank you very much with this command
it is working.
Best regards
ChriWo
Hi, this seems to be an issue again with Odroid XU4 + Armbian.
When I try to bring up a Wireguard interface I get:
jul 17 12:52:30 odroidxu4 wg-quick[1940]: [#] ip link add wg0 type wireguard
jul 17 12:52:30 odroidxu4 wg-quick[1949]: Error: Unknown device type.
jul 17 12:52:30 odroidxu4 wg-quick[1952]: Unable to access interface: Protocol not supported
Both wireguard and wireguard tools are up to date, I restarted the device multiple times. "sudo dkms status" doesn't output anything.
Based on "sudo apt update" / "sudo apt dist-upgrade" I'm up to date.
Looks like the wireguard module isn't loaded at all:
$ sudo lsmod | grep wire
<no output>
Version information:
$ uname -a
Linux odroidxu4 5.4.243-odroidxu4 #1 SMP PREEMPT Mon May 22 13:57:29 UTC 2023 armv7l GNU/Linux
$ lsb_release -a
No LSB modules are available.
Distributor ID:	Debian
Description:	Armbian 23.05.1 bookworm
Release:	12
Codename:	bookworm
I tried to find some "odroidxu4 specific kernel headers package", but that fails:
$ sudo dpkg-reconfigure linux-headers-current-odroidxu4
Compiling headers - please wait ...
Makefile:583: arch//Makefile: No existe el fichero o el directorio
make: *** No hay ninguna regla para construir el objetivo 'arch//Makefile'.  Alto.
Makefile:927: scripts/Makefile.ubsan: No existe el fichero o el directorio
make: *** No hay ninguna regla para construir el objetivo 'scripts/Makefile.ubsan'.  Alto.
How can I make Wireguard usable on the OdroidXU4 with Armbian?
Try EDGE kernel. Module for WG should be already in. For this 5.4.y kernel we need to look why headers are broken ...
Hi Igor, thanks for the quick reply!
How can I do that? Is there a specific package I should install? Thanks.
On 7/24/2023 at 2:54 PM, Werner said:
Try with armbian-config -> system -> other
Thanks, that worked. However the edge kernel doesn't seem to have the eCryptfs module (the one which can be used to encrypt home directories: https://man.archlinux.org/man/extra/ecryptfs-utils/ecryptfs-migrate-home.8.en).
When I tried to go back to the current kernel (again with armbian-config -> system -> other), the whole system just didn't start after reboot. I'll have to re-flash my eMMC storage with armbian.
Same Problem here.
I activated the edge kernel, then wireguard worked, but my xu4 can't reboot.
After reboot command, system ist not reachable over the network.
(pull the plug fixes this, but after reboot command, same problem)
any ideas?
apologies to hi-jack this thread Armbian_24.5.2 noble_vendor_6.1.43_gnome-oibaf_desktop version WG can not start after a reboot....
I have enabled and started the services but no good... am i doing something missing ?
could you please provide some steps on how to check and how to enable ?
it appears i have to manually do this command to get it started after a reboot
sudo systemctl enable wg-quick@wg0
sudo systemctl start wg-quick@wg0
sudo wg-quick up wg0
Check if wireguard is present under lsmod
Also check your logs (journal, syslog,...) which should tell you something about why things fail.
Please assist ... after reboot here are the details... note.. i did have this working a few weeks ago... but after sudo update.. it stopped even after a fresh install..
root@orangepi5-plus:~# sudo systemctl status wg-quick@wg0.service
× wg-quick@wg0.service - WireGuard via wg-quick(8) for wg0
     Loaded: loaded (/lib/systemd/system/wg-quick@.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Sat 2024-11-30 00:05:18 AEDT; 1min 31s ago
       Docs: man:wg-quick(8)
             man:wg(8)
            https://www.wireguard.com/
            https://www.wireguard.com/quickstart/
            https://git.zx2c4.com/wireguard-tools/about/src/man/wg-quick.8
            https://git.zx2c4.com/wireguard-tools/about/src/man/wg.8
    Process: 1276 ExecStart=/usr/bin/wg-quick up wg0 (code=exited, status=1/FAILURE)
   Main PID: 1276 (code=exited, status=1/FAILURE)
        CPU: 56ms
Nov 30 00:05:18 orangepi5-plus systemd[1]: Starting WireGuard via wg-quick(8) for wg0...
Nov 30 00:05:18 orangepi5-plus wg-quick[1276]: [#] ip link add wg0 type wireguard
Nov 30 00:05:18 orangepi5-plus wg-quick[1276]: [#] wg setconf wg0 /dev/fd/63
Nov 30 00:05:18 orangepi5-plus wg-quick[1338]: Name or service not known: `myipaddresshereremoved.com:51820'
Nov 30 00:05:18 orangepi5-plus wg-quick[1338]: Configuration parsing error
Nov 30 00:05:18 orangepi5-plus wg-quick[1276]: [#] ip link delete dev wg0
Nov 30 00:05:18 orangepi5-plus systemd[1]: wg-quick@wg0.service: Main process exited, code=exited, status=1/FAILURE
Nov 30 00:05:18 orangepi5-plus systemd[1]: wg-quick@wg0.service: Failed with result 'exit-code'.
Nov 30 00:05:18 orangepi5-plus systemd[1]: Failed to start WireGuard via wg-quick(8) for wg0.
root@orangepi5-plus:~# apt list --installed|grep wireguard
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
wireguard-dkms/jammy,now 1.0.20210606-1 all [installed,automatic]
wireguard-tools/jammy,now 1.0.20210914-1ubuntu2 arm64 [installed,automatic]
wireguard/jammy,now 1.0.20210914-1ubuntu2 all [installed]
root@orangepi5-plus:~# lsmod
Module                  Size  Used by
bnep                   24576  2
nft_masq               16384  1
nft_fib_inet           16384  1
nft_fib_ipv4           16384  1 nft_fib_inet
nft_fib_ipv6           16384  1 nft_fib_inet
nft_fib                16384  3 nft_fib_ipv6,nft_fib_ipv4,nft_fib_inet
nft_reject_inet        16384  6
nf_reject_ipv4         16384  1 nft_reject_inet
nf_reject_ipv6         16384  1 nft_reject_inet
nft_reject             16384  1 nft_reject_inet
nft_ct                 20480  10
wireguard              77824  0
libchacha20poly1305    16384  1 wireguard
chacha_neon            24576  1 libchacha20poly1305
libchacha              16384  1 chacha_neon
poly1305_neon          20480  1 libchacha20poly1305
ip6_udp_tunnel         16384  1 wireguard
udp_tunnel             20480  1 wireguard
libcurve25519_generic    36864  1 wireguard
nft_chain_nat          16384  3
nf_nat                 57344  2 nft_masq,nft_chain_nat
nf_conntrack          135168  3 nf_nat,nft_ct,nft_masq
nf_defrag_ipv6         20480  1 nf_conntrack
nf_defrag_ipv4         16384  1 nf_conntrack
nf_tables             172032  215 nft_ct,nft_reject_inet,nft_fib_ipv6,nft_fib_ipv4,nft_masq,nft_chain_nat,nft_reject,nft_fib,nft_fib_inet
nfnetlink              16384  2 nf_tables
zstd                   16384  8
binfmt_misc            20480  1
joydev                 20480  0
sch_fq_codel           20480  5
fuse                  110592  1
ip_tables              28672  0
ipv6                  438272  89 nf_reject_ipv6,nft_fib_ipv6,wireguard
pgdrv                  16384  0
r8169                  77824  0
panfrost               57344  0
gpu_sched              28672  1 panfrost
Edited by BOFFBOY
removedip
This is likely the error you are running into.  Is that your valid domain name for your wireguard server?
I have had issues with wireguard starting before DNS name resolution is in place which I resolved by using IP addresses in the wireguard config files instead of domain names.
oh my goodness yes you are correct.. when i use the IP address it fixes it..
how can i use domain name in the endpoint ? must be something i need to config ? i missed a step ?
ps i really need to use a domain..
Don't know, as I am fine with using the IP address so never researched further.  I suspect it is a timing issue between DNS starting and wireguard starting.
