When trying to upgrade, I get the following error:
root@orangepilite2:~# apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be upgraded:
  armbian-firmware
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/5,755 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
(Reading database ... 38292 files and directories currently installed.)
Preparing to unpack .../armbian-firmware_5.74.190202_all.deb ...
Unpacking armbian-firmware (5.74.190202) over (5.72.190122) ...
dpkg: error processing archive /var/cache/apt/archives/armbian-firmware_5.74.190202_all.deb (--unpack):
 trying to overwrite '/lib/firmware/regulatory.db', which is also in package wireless-regdb 2018.05.09-0ubuntu1~18.04.1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
So it seems there is a duplicate regulatory.db - in the firmware as well as in wireless-regdb
Well, yes. I just wanted to know which one should be kept. So after removing by
apt remove wireless-regdb
I could install armbian-firmware
15 hours ago, sfx2000 said:
in the ubuntu repo's, there's the wireless-crda package
in the debian image it was missing and @igor added it with a commit:
