mikerr Posted February 13, 2017 Posted February 13, 2017 Nothing in armbian for rockchip yet ? Rockchip RK3288 Cortex-A17 Quad-core 1.8GHz ARM Mali-T764 GPU 2GB RTL8211E-VB-CG GB LAN
Igor Posted February 13, 2017 Posted February 13, 2017 MiQi (which is very similar) is under research and development. We got two boards two weeks ago. Support for ASUS board is unknown - we don't have any contacts yet.
richardk Posted February 13, 2017 Posted February 13, 2017 Sadly MiQi doesn't seem to be getting the funding it needs, only 2% of goal on indiegogo so far. Asus Tinkerboard isn't very available, either. Also
Tido Posted February 13, 2017 Posted February 13, 2017 The first time I looked closely to the first picture. This is a really brilliant move from ASUS, an exact copy of the connectors placing and size, combined with a real CPU, twice as much RAM. If the camera and display connector even have the same ports - hallelujah Really neat, the colored GPI/O pins Brilliant - as long as Rockchip and ASUS send their code upstream. 2
jernej Posted February 13, 2017 Posted February 13, 2017 On 2/13/2017 at 2:32 PM, richardk said: Sadly MiQi doesn't seem to be getting the funding it needs, only 2% of goal on indiegogo so far. Yes, their campaign failed, but you can still buy this board here: https://mqmaker.com/product/miqi-2gb-ram-fress-shipping/ On 2/13/2017 at 2:46 PM, Tido said: Brilliant - as long as Rockchip and ASUS send their code upstream. SoC used in these two boards is also used in Chromebook, which means that almost all HW has mainline drivers in Linux and U-Boot. However, someone is working on VPU driver, but it should be already usable.
smv1210 Posted February 27, 2017 Posted February 27, 2017 (edited) Hi, Are there any plans to build Armbian for this board (have just got it today ) ??? http://hackaday.com/2017/02/15/review-the-asus-tinker-board/ Edited February 27, 2017 by zador.blood.stained Merged here
tkaiser Posted March 1, 2017 Posted March 1, 2017 Here's dmesg output from TinkerOS: http://sprunge.us/JYcg So ASUS is either pretty lazy or in the usual 'port and forget' mood (shipping kernel 4.4.16 while 4.4 LTS is already at 4.4.52 in the meantime) and they use well known and boring AP6212 to provide Wi-Fi/BT. So if power setup is identical between MiQi and Tinker Board all that's missing is adding a single line to /etc/modules and BT stuff.
TonyMac32 Posted March 4, 2017 Posted March 4, 2017 I've got a Tinker Board, had it about a week (they were very briefly available on Amazon, actually, as soon as it shipped the page was taken down). I'm actually posting from it, was running some updates/etc. It is truly identical to the Pi form factor wise, I slapped it into a Pi case. I stuck an initial impressions on my blog, but more or less the 4 usb ports are through a hub, the gigabit ethernet is tied directly into the SoC so that makes it's networking amazingly better than the Pi. Wifi is snappy, especially when considering the "chip-tenna" it's using for an aerial. Tinker OS is horribly unstable in my experience. The desktop crashes regularly and you have to reboot, or continue your work by switching to another terminal and living with the CLI. 0 graphic acceleration of any kind from what I can see, I have it hooked up to a 4k monitor, it appears to be upscaling a 1080p desktop and then putting a 4k mouse on top of it? The mouse is nice and crisp (and tiny) and everything else is kind of blurry. I've seen some noise concerning mainline patches for the Tinker board, hopefully those pan out. And hopefully someone decides to let us use the graphics subsystem properly.
jernej Posted March 4, 2017 Posted March 4, 2017 On 3/4/2017 at 6:58 AM, TonyMac32 said: The mouse is nice and crisp (and tiny) and everything else is kind of blurry. Expand I'm pretty sure that both of your assumptions are correct. A lot of SoCs have special buffer for mouse pointer which get blended a top of everything else. I'm pretty sure that's the case here too. IIRC I heard that RK3288 supports 1080p max and 4K is just upscaled version of that. About other issues - MiQi board with same SoC has definetly working GPU and VPU drivers, so I think this is only temporary issue.
TonyMac32 Posted March 4, 2017 Posted March 4, 2017 That's interesting. I wasn't sure what to make of the inconsistent "upscaled from 1080" notes I've found here and there, and got more confused with the entire mouse thing. There's very little in the way of strange hardware physically on the board, although there is an 8k EEPROM on the bottom side next to the SD card that I can't really account for. Power wise it's using a Rockchip RK808-B, which should mean the SoC has access to battery management and a real time clock, if everything is broken out. To that end there are 2 connections available between the HDMI and Micro-USB, I haven't been brave enough to probe them fully, I'd assume one is purely a 5V in, the other may be for a battery or a hardware reset switch. I'm looking over the datasheets and the (far from complete) schematic. [edit] There is a USB charge monitor onboard: http://www.ti.com/lit/ds/symlink/bq24392.pdf
TonyMac32 Posted March 12, 2017 Posted March 12, 2017 Apologize for back-to-back posts, but Asus just released an updated image for the Tinker Board, available on their uk site: https://www.asus.com/uk/Single-board-Computer/TINKER-BOARD/ I'm getting ready to test it, thought I'd post in case anyone else was interested.
Igor Posted March 12, 2017 Posted March 12, 2017 I am interested if Armbian for MiQi is working out of the box? For kernel wise you might need to add this parameter to armbianEnv.txt to gain proper functionality: fdt_file=rk3288-miniarm Miniarm was "secret" code for this board. In case you can't boot, we need to rebuild boot loader.
TonyMac32 Posted March 12, 2017 Posted March 12, 2017 I'll take a look at that parameter. Out of the box I get a power light and absolutely nothing else using the MiQi image.
Igor Posted March 13, 2017 Posted March 13, 2017 Serial console log would help. I just added WIP build target based on theory. If one have time to build and try. I am confident this image boots. I won't continue from here, since I don't have this board.
smv1210 Posted March 13, 2017 Posted March 13, 2017 I am ready to donate "targetly" (10-15€), in order Igor gets his own board. Anyone joint me with this?
Igor Posted March 13, 2017 Posted March 13, 2017 Thank you, but I am not sure I need another board / new costs. Recently I denied two board donations, from board makers, with this (simplified) explanation: "We can't accept more boards, since we are small amateur group, overwhelmed with work / boards.". If they still want the board here, project is open - they can add it ... or try to make a deal. 1
TonyMac32 Posted March 13, 2017 Posted March 13, 2017 I'll set up a VM and try to build it. Be patient, my software experience is with *much* lower level things (assembly language and firmware) Igor, thanks for all the hard work! 1
smv1210 Posted March 13, 2017 Posted March 13, 2017 I have compiled both WIP image variants for the subject board today; Debian & Ubuntu. But none of them did work Have not tested those with serial console (I do not have the cable)
TonyMac32 Posted March 14, 2017 Posted March 14, 2017 I hacked an adapter for my FTDI Friend together, I tried the default MiQi image, there is nothing on the serial port. I assumed 115200 8N1, is that correct? The output from the ASUSimage looks like this: cap 2048 chipsize_mb=1024 chipsize_mb=1024 size_mb = 2048 U-Boot 2016.09-rc1 (Feb 23 2017 - 17:59:51 +0800) Model: Miniarm-RK3288 DRAM: chipsize_mb=1024 chipsize_mb=1024 size_mb = 2048 2 GiB MMC: dwmmc@ff0c0000: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: Net Initialization Skipped No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf reading /extlinux/extlinux.conf 140 bytes read in 6 ms (22.5 KiB/s) Retrieving file: /hw_intf.conf reading /hw_intf.conf 109 bytes read in 4 ms (26.4 KiB/s) hw_conf.valid = 1 hw_conf.i2c1 = 1 hw_conf.i2c4 = 1 hw_conf.spi2 = 1 hw_conf.pwm2 = 1 hw_conf.pwm3 = 1 hw_conf.uart1 = 1 1: kernel-4.4 Retrieving file: /zImage reading /zImage 6731160 bytes read in 497 ms (12.9 MiB/s) append: earlyprintk console=tty1 root=/dev/mmcblk0p2 rw init=/sbin/init uboot_version=2016.09-rc1 Retrieving file: /rk3288-miniarm.dtb reading /rk3288-miniarm.dtb 45592 bytes read in 8 ms (5.4 MiB/s) ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Device Tree to 1fff1000, end 1ffff617 ... OK Starting kernel ...
Igor Posted March 14, 2017 Posted March 14, 2017 Thank you both for trying. This is how we usually begin and sometimes it just work According to this (supposedly working) recipe, we don't miss anything regarding booting ... or do we? We are using mainline u-boot, where things could be changed ... but usually you get something on serial. I can switch to this u-boot source: https://github.com/rockchip-linux/u-boot and we try again. Default MiQi image might not work and at least we have a confirmation now. Good.
TonyMac32 Posted March 14, 2017 Posted March 14, 2017 Looking through the source, the tinker_rk3288.h in the build directory of what I built vs the one at Rockchip linux has a correction on the boot target device number from func(MMC, mmc, 0) to func(MMC, mmc, 1) I could see it stalling the boot, but no serial out? Apparently these were originally configured with an eMMC... https://github.com/rockchip-linux/u-boot/commit/d57b7e1f6707ee5e834e0b2c9ceeaf558455ff4b If I change this in my source files and rebuild, will it be preserved or will the build replace it with the original? (noob question, sorry) [EDIT] Found the script option to turn off checkout. Trying it. [EDIT 2] I'm afraid that single adjustment didn't fix it. It's time to sleep for me, I'll be back later. ;-)
smv1210 Posted March 14, 2017 Posted March 14, 2017 @TonyMac32 Does Ethernet port work correctly on your board (when it is running the Asus native image)?
TonyMac32 Posted March 14, 2017 Posted March 14, 2017 Board revision 1.2. Tinker OS 1.3 and 1.4 both worked. Given the dubious nature of the release, I'm not going to assume all the boards are the same hardware rev level.
TonyMac32 Posted March 15, 2017 Posted March 15, 2017 Pulled out the hex editor to get a closer look at the bootloader to see if it was putting everything where it belongs, and I figured out why I can't see serial terminal, it's on UART2 in this build instead of UART1 like on the ASUS build. So that explains that mystery. I'm sure the sources could have told me that, but somehow the hex editor was easier to follow... I also see references to the now-gone eMMC, so it's probably trying to boot that and hanging. Can't get the build script to give me serial 1 instead of serial 2, but I did change the U-Boot source to the Rockchip Linux one, and I made an even more interesting adapter to ttyS2 and got this: U-Boot SPL 2017.03-rc3-armbian (Mar 14 2017 - 23:21:19) It hung right away just like the mainline, I'm learning my way around to see if it's a device number issue, I'm still seeing the dwmmc@ff0f0000 (that's the eMMC address) popping up in the binary (less than with mainline), I haven't figured out where to turn that off if it's being passed as a parameter somewhere. 1
tkaiser Posted March 15, 2017 Posted March 15, 2017 And another RK3288 device, maybe doing a few things better (eg. barrel plug for DC-IN and not crappy Micro USB, no internal USB hub, mounting holes for large heatsink): http://linksprite.com/wiki/index.php5?title=PcDuino9#Hardware_specifications Well, my last attempt to deal with Linksprite's software was shocking 1
TonyMac32 Posted March 15, 2017 Posted March 15, 2017 On 3/15/2017 at 6:01 PM, tkaiser said: Well, my last attempt to deal with Linksprite's software was shocking Expand ...Literally? Oh dear... :-D
