Gengan Posted March 27, 2020 Posted March 27, 2020 I tried Linux 5.4 on my Rock64 v2.0. Ethernet is not working, which makes the board pretty useless. Unfortunately I don't remember the dmesg error string... is this a known issue? Do you need help investigating it?
archetech Posted April 7, 2020 Posted April 7, 2020 Update: kernel 5.6.0 boots on my V2. I just installed latest ayufan ubu focal unstable image and its been ok for a day now. Time will tell if this becomes my main image vs arch/manjaro/armbian. I'll try armbian again when a stable release is out with this kernel.
suberimakuri Posted April 13, 2020 Posted April 13, 2020 How are you getting on @archetech? On micro SD with ayufan focal 5.6 release 0.10.10 I got 10m crash then 20m crash then 2hr before shutting down to try with emmc (failed). Posted in IRC and saved paste bin. Rock64 4gb.
archetech Posted April 13, 2020 Posted April 13, 2020 Hey suber. I just installed LXDE 10 on mine and it's a blast....no big issues really surprised at how it runs cool and smooth. Uses about half of my 1 GB ram and some swap space with Ffox hexchat lxterm open. I'll try KDE Plasma soon. Thing about rock64 boards is there's 3 versions and I had to try a few distros until I came back to ayufan after he finally caught up on his images. He must know this board well I assume. Board sat for a month here. I was too frustrated with it. So try arch manjaro armbian too. IMO the various devs focus on different uboot / kernel / userspace versions and that introduces issues. It's an arm thing due to building for chip families vs individual boards/versions. Try not to give up too fast on it. It's not a great or popular board for obvious reasons (cheap) but once it works it's a relief. I would use an sdcard first then if thats ok, an emmc.
Gengan Posted July 5, 2020 Posted July 5, 2020 A big "thank you" to the Armbian team for the rockchip kernel update to Linux 5.4. I upgraded from the legacy kernel to the current one last night without a single issue. Ethernet now works like a charm and boot time is reduced, though I haven't properly measured it. Just a question: the standby LED (red one) now blinks twice every second. What does it mean?
Werner Posted July 5, 2020 Posted July 5, 2020 38 minutes ago, Gengan said: A big "thank you" to the Armbian team for the rockchip kernel update to Linux 5.4. I upgraded from the legacy kernel to the current one last night without a single issue. Ethernet now works like a charm and boot time is reduced, though I haven't properly measured it. Just a question: the standby LED (red one) now blinks twice every second. What does it mean? Probably a "heartbeat". Do something like "du -a /sys |grep led|grep red|grep trigger" to find the trigger file. You can feed it with "on", "off" if you like to have it constant. As for myself I like having it on heartbeat on my SBCs since it indicates if they are under load (beat will become faster) or if the kernel freezes (heartbeat stops).
Technicavolous Posted July 5, 2020 Posted July 5, 2020 4 hours ago, Werner said: As for myself I like having it on heartbeat on my SBCs since it indicates if they are under load (beat will become faster) or if the kernel freezes (heartbeat stops). Does this update vary the heartbeat speed with load?
Technicavolous Posted July 5, 2020 Posted July 5, 2020 4 hours ago, Werner said: As for myself I like having it on heartbeat on my SBCs since it indicates if they are under load (beat will become faster) or if the kernel freezes (heartbeat stops). I also like to reference the heartbeat but sometimes I've thought to have it code out a load level in morse ;]
Werner Posted July 5, 2020 Posted July 5, 2020 1 hour ago, Technicavolous said: Does this update vary the heartbeat speed with load? Um I don't quite understand what you are asking for? The higher the load the faster the heartbeat will become.
Technicavolous Posted July 5, 2020 Posted July 5, 2020 I thought I had edited that out ... total 'oops' moment ... 1
yam1 Posted July 5, 2020 Posted July 5, 2020 Anything wrong with the spi driver for rock3328 or the rock64v2 hardware? My spi tft displays are way too slow when compared with h3 boards (5.7 kernel). Any ideas?
