I would like to thank to Tony for doing Armbian for Tinker Board. It is very appreciate.
I think that Tinker Board will have big success and Armbian for its, too.
Many thanks again.
U-Boot SPL 2017.05-rc1-armbian (Apr 17 2017 - 00:30:20)
U-Boot 2017.05-rc1-armbian (Apr 17 2017 - 00:30:20 -0400)
Model: Tinker-RK3288
DRAM:  2 GiB
MMC:   dwmmc@ff0c0000: 1
It works!  Figured I'd give it a look.  Will update.
Just to be in picture. When will be Wifi support for Armbian available?
The kernel sources for Tinker Board 1.4 are available, and there fore DTS with Wifi config should be available.
Or is problem somewhere else?
Thanks.
First good job everyone.
This is the first time see the LEDs :D. What version should compile? dev better ?
I have some problems installing openmediavault (erros with nfs-common, and others) .I am very happy with your work. Continue.
Sorry 4my english.
Let me take a look, as I've said before, on my part this is a learning by doing experience.  But I have some unanswered questions on their hardware handling, so the source is good news, even if it is 1.4 (epic buggy)
Can you provide an exact list what should be enabled in kernel configuration or better - login to Github and adjust config accordingly?
Right now only the default works, I haven't gotten the device tree into the dev kernel yet.  Transplanting the compiled device tree from the default into the dev is a messy patch just to see it work.
OK, after patching the Rockchip-wlan Kconfig and Makefiles, and updating the driver, then adding a fix found in a patch on the rockchip-linux site, I have functional WiFi.
So, a silly question, but where is the config saved to after I make kernel config changes?  That's all I need to get a patch submitted.
[edit]  oof, just yanked the resulting patch out of the folder, it's 10 MB. :o  Soooo, what should I do with that?  I'll see if there's a smarter way to replace the driver...
[edit2]  The driver in the miqi distro is v4.3.9 (Sep. 2014) I'm not sure finding the patches will help given the advanced age and huge differences.
KERNEL_SOURCE/.config -> copy out to lib/config/kernel/linux-rockchip-default.config
Check if there is not something too much. 1-2MB is normal.
Thanks Igor!
I went through and don't see a way to shrink it down, there have been multiple revisions.  Versions I've been able to find include 4.3.16, 4.4.0, and 4.4.1.  It looks like a major rewrite took place at 4.4.0, the version in Tinker OS.
The v4.4.0 commit I found shows 335 changed files https://github.com/anthonywong/rtl8723bs/commit/25e88f984ad93891f39822debbe86b2bc9f8035b
Well, if it works, push it.
Edit: Already done, no testing needed any more!
Can any of those MiQi or Tinkerboard owners please check the relevant temperature sensors in idle and when generating some load to get a clue whether this commit needs a correction (exchanging occurences of /sys/class/thermal/thermal_zone1 and /sys/class/thermal/thermal_zone2):
#!/bin/bash
sensors=$(find /sys -name temp)
while true ; do
	for sensor in ${sensors} ; do
		echo -e "${sensor%/*}/$(cat ${sensor%/*}/type): $(cat ${sensor})"
	done
	echo ""
	sleep 5
done
I'm going to test the 4.4.1 tonight, might as well get it up to date as possible if it's going to be that heavy of a change anyway, once verified I'll push it.
Really no one? This will cost you a minute of your life only. Please just open 1 shell and let the above script run and in another one start
for i in 1 2 3 4 ; do stress -c $(( $i * 2 )) -t 15 ; done
And then the output from first script on an online pasteboard service or here in code blocks would be fine to finish the temperature source stuff for all boards we currently support.
Edited by tkaiser
Testing done
nick@tinkerboard:~/Desktop$ sudo ./temp.txt
cat: /sys/devices/virtual/thermal/thermal_zone0/temp: Invalid argument
/sys/devices/virtual/thermal/thermal_zone0/reserve_thermal:
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 56818
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 56818
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 57272
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 55454
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 56363
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 55000
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 62916
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 59090
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 62500
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 60416
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 66153
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 62500
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 68461
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 64166
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 68846
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 65384
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 69615
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 66153
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 66538
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 69230
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 70416
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 66923
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 67307
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 65384
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 63750
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 64166
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 63333
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 62083
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 60833
Hopefully I've done this correctly - if preferred I can paste to GitHub - I have an account where I update markdown files. No programming skills I'm afraid. If there are more tests listed somewhere that need running I'm willing to try, but am often away for periods of weeks.
For first script the output is :
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 51666
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 50833
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 50416
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 51250
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 50416
/sys/devices/virtual/thermal/thermal_zone1/cpu_thermal: 50833
/sys/devices/virtual/thermal/thermal_zone2/gpu_thermal: 50000
for thermal_zone0/temp  there is output that there is Invalid argument.
For second script ther is output:
stress: info: [2436] dispatching hogs: 2 cpu, 0 io, 0 vm, 0 hdd
stress: info: [2436] successful run completed in 15s
stress: info: [2439] dispatching hogs: 4 cpu, 0 io, 0 vm, 0 hdd
stress: info: [2439] successful run completed in 15s
stress: info: [2449] dispatching hogs: 6 cpu, 0 io, 0 vm, 0 hdd
stress: info: [2449] successful run completed in 15s
stress: info: [2460] dispatching hogs: 8 cpu, 0 io, 0 vm, 0 hdd
stress: info: [2460] successful run completed in 15s
Sorry about that tkaiser, I ran out of time last night to try it out.
Wifi should be available in default nightlies tomorrow, no bluetooth yet.
I probably should have found this topic before posting my own... but is there any reason CONFIG_DNOTIFY is not set for the rockchip config? It is for pretty much every other kernel config. I think it is stopping nfs-common from starting.
You're right
Note: some of the options below are required for NFS root, some for NFS mounting and some for NFS serving.
chromeos/config/armel/config.flavour.chromeos-tegra2:
CONFIG_USB_NET_AX8817X=y
chromeos/config/config.common.chromeos:
+CONFIG_DNOTIFY=y
+CONFIG_DNS_RESOLVER=y
+CONFIG_LOCKD=y
+CONFIG_LOCKD_V4=y
+CONFIG_NETWORK_FILESYSTEMS=y
+CONFIG_NFSD=m
+CONFIG_NFSD_V3=y
+CONFIG_NFSD_V4=y
+CONFIG_NFS_COMMON=y
+CONFIG_NFS_FS=y
+CONFIG_NFS_USE_KERNEL_DNS=y
+CONFIG_NFS_V3=y
+CONFIG_NFS_V4=y
+CONFIG_ROOT_NFS=y
+CONFIG_RPCSEC_GSS_KRB5=y
+CONFIG_SUNRPC=y
+CONFIG_SUNRPC_GSS=y
+CONFIG_USB_USBNET=y
+CONFIG_IP_PNP=y
+CONFIG_IP_PNP_DHCP=y
Maybe that's why i can't install openmediavault.
I edited the file on local linux-rockchip-default.config and work perfctly
whit this config
+CONFIG_DNOTIFY=y
+CONFIG_LOCKD=y
+CONFIG_LOCKD_V4=y
+CONFIG_NFSD=m
+CONFIG_NFSD_V3=y
+CONFIG_NFSD_V4=y
+CONFIG_NFS_FS=y
+CONFIG_NFS_V3=y
+CONFIG_NFS_V4=y
+CONFIG_ROOT_NFS=y
+CONFIG_SUNRPC=y
+CONFIG_IP_PNP=y
NFS is work !!
Now that this is fixed in default config you should be aware that Armbian's build system can be used to generate optimized OMV images:
What's still missing is IRQ redistribution but so far I've not seen anyone posting output of 'sudo armbianmonitor -u', right?
@TonyMac32sent me output from armbianmonitor so I added IRQ distribution routine for MiQi and Tinkerboard and also built an optimized OMV image (just for fun -- default logon credentials are admin/root with pwd 'openmediavault'): http://kaiser-edv.de/tmp/NumpU8/
Background information: http://forum.openmediavault.org/index.php/Thread/17855-Building-OMV-automatically-for-a-bunch-of-different-ARM-dev-boards/
Internal discussion: https://forum.armbian.com/index.php?/topic/3953-preview-generate-omv-images-for-sbc-with-armbian/
http://sprunge.us/NdMK . Here you have. Sorry for not making the changes in github  of NFS . It was too late.
I think there is a problem with reboots. Sometimes it starts correctly after "Shutdown -r now" and others not. I'm looking for why.
1 hour ago, trax69 said:
Thanks but @TonyMac32already provided me with the necessary bits in the meantime :)
Since you're using OMV you should update your image with latest tweaks (IRQ affinity and 'special' OMV settings) or maybe simply give the optimized OMV image I built a few hours ago a try: OMV_3_0_72_Tinkerboard_4.4.63.7z (root password here is 'openmediavault' and will not be changed automatically on first login!)
BTW: it seems there's something wrong regarding 'dwc2_hsotg:usb1'. This is generating an awful lot of IRQs according to your and Tony's debug output.
