martinayotte Posted April 5, 2019 Author Posted April 5, 2019 15 minutes ago, dreddit said: The legacy fix involves the PH07 but find no reference on the board unless it refers to a gpio pin? Yes, but this PH7 is the SPDIF-OUT for Audio, which is not even connect on OPi3. I doubt this fix has anything to do with reboot issue, especially that this FEX attached this PH7 to "recovery" button ... 0 Quote
martinayotte Posted April 5, 2019 Author Posted April 5, 2019 15 minutes ago, dreddit said: The legacy fix involves the PH07 but find no reference on the board unless it refers to a gpio pin? Yes, but this PH7 is the SPDIF-OUT for Audio, which is not even connect on neither OPi3, OPiOnePlus or OPiLite2. I doubt this fix has anything to do with reboot issue, especially that this FEX attached this PH7 to "recovery" button ... 0 Quote
frozeus Posted April 7, 2019 Posted April 7, 2019 SPIDF-OUT is PL9. I think the legacy version doesn't use the watchdog or not the same to reboot the board. EDIT: I think it uses the ARISC co-processor does someone with the h64 can test if the WDOG works ? /* This should reset the system after 0.5s */ # devmem $((0x030090a0 + 0x0014)) 0x00000001 # devmem $((0x030090a0 + 0x0018)) 0x00000000 # devmem $((0x030090a0 + 0x0018)) 32 0x1 /* This should reset the system after 1s (as recommended in the User Manual) */ # devmem $((0x030090a0 + 0x0014)) 0x00000001 # devmem $((0x030090a0 + 0x0018)) 0x00000000 # devmem $((0x030090a0 + 0x0018)) 32 $((0x1 << 4)) # devmem $((0x030090a0 + 0x0018)) 0x00000010 # devmem $((0x030090a0 + 0x0018)) 32 $((0x1 << 4 | 0x1)) 0 Quote
frozeus Posted April 7, 2019 Posted April 7, 2019 Changing to the R_WDOG instead of WDOG in ATF fix the issue. 0001-HACK-plat-allwinner-common-Use-R_WDOG.patch 0 Quote
martinayotte Posted April 7, 2019 Author Posted April 7, 2019 5 hours ago, froezus said: SPIDF-OUT is PL9. You are better looking at the schematic of any H6 (OPi3, OPiOnePlus, OPILite2) before arguing, PL9 is S-IR-RX, PH7 is really SPDIF-OUT ... 0 Quote
martinayotte Posted April 7, 2019 Author Posted April 7, 2019 47 minutes ago, froezus said: Changing to the R_WDOG instead of WDOG in ATF fix the issue. Where did you find this patch ? We are not seeing it on linux-sunxi ML ... Did you tried out ? 0 Quote
frozeus Posted April 7, 2019 Posted April 7, 2019 12 minutes ago, martinayotte said: You are better looking at the schematic of any H6 (OPi3, OPiOnePlus, OPILite2) before arguing, PL9 is S-IR-RX, PH7 is really SPDIF-OUT ... Oups indeed, My brain switch between IR and SPDIF. The patch is from me and yes I tested it. Still not posted it because it's more a hack. 0 Quote
martinayotte Posted April 7, 2019 Author Posted April 7, 2019 6 minutes ago, froezus said: The patch is from me and yes I tested it. Still not posted it because it's more a hack. Oh ! So, @froezus is in fact Clément Péron ? Alors, bienvenue sur Armbian ... Je preśume que tu es basé en France, selon l'heure de ta patch ? Moi, je suis au Québec ... Je vais donc essayer celle-ci sous peu ! Salutation ! 0 Quote
frozeus Posted April 7, 2019 Posted April 7, 2019 12 minutes ago, martinayotte said: Oh ! So, @froezus is in fact Clément Péron ? Alors, bienvenue sur Armbian ... Je preśume que tu es basé en France, selon l'heure de ta patch ? Moi, je suis au Québec ... Je vais donc essayer celle-ci sous peu ! Salutation ! Oui, salutation à toi aussi ! 0 Quote
martinayotte Posted April 8, 2019 Author Posted April 8, 2019 3 hours ago, froezus said: The patch is from me and yes I tested it. Still not posted it because it's more a hack. Did you got chance to figure out if the changes breaks or works for H3/H5/A64 ? If not, we will need to build different BL31 for H6 differently from H3/H5/A64, since I'm not fluent with ATF, I'm not even sure that Armbian scripts distinguish between those ATF flavors accordingly ... Did you exchange discussions with @megi and @Icenowy and any other about the issue ? Maybe the Official ML will still be a good place ... Thanks for your work, since we struggling about the issue since at least 3 months ... 0 Quote
megi Posted April 8, 2019 Posted April 8, 2019 @froezus Nice! Thank you. I've changed your patch, so that it uses R_WDOG only on H6. https://megous.com/dl/tmp/0001-Fix-reset-issue-on-H6-by-using-R_WDOG.patch It's still a hack, but at least it doesn't touch other SoCs. U-boot will also need patching, because it doesn't use ATF for reset. I tested it on Opi3, and it works. :)) 1 Quote
frozeus Posted April 8, 2019 Posted April 8, 2019 Before trying any patch it would better to first understand, how it works on PineH64. 0 Quote
ilchenko Evgeny Posted April 8, 2019 Posted April 8, 2019 1 hour ago, froezus said: Before trying any patch it would better to first understand, how it works on PineH64. please tell us how to install this patch 0 Quote
frozeus Posted April 8, 2019 Posted April 8, 2019 You just need to put it in build/patch/atf/atf-sunxi64/ 0 Quote
martinayotte Posted April 8, 2019 Author Posted April 8, 2019 13 hours ago, megi said: U-boot will also need patching, because it doesn't use ATF for reset. What would be this second patch for the U-Boot "reset" ? EDIT : for the "reboot" patch, I'm confirming : it works ! Thanks a lot to both @froezus and @megi !!! EDIT2 : tested on all my H6, OPiOne+/OPiLite2/OPi3 ... And patch committed in Armbian ! 4 Quote
frozeus Posted April 8, 2019 Posted April 8, 2019 My UART is broken could you test this patch ? https://github.com/clementperon/u-boot/commit/dc1abccb3628aefa6df3d44e027f33d8afc3fc86 Thanks 0 Quote
martinayotte Posted April 8, 2019 Author Posted April 8, 2019 46 minutes ago, froezus said: My UART is broken You should do like me : I have more than a dozen of USB-TTL around, almost every boards have one, so I don't have to waste time unplugging/plugging them while testing. I've even placed a new order on eBay to get more ... 46 minutes ago, froezus said: could you test this patch ? Tested on OPiOnePlus, now doing the OPiLite2 and OPi3 ... Patch is already committed to Armbian ! Thanks a lot for the help ! EDIT : OPiLite2 and OPi3 tested too ... 1 Quote
frozeus Posted April 8, 2019 Posted April 8, 2019 I made a short circuit on my board and the TX pin is no more working... 0 Quote
martinayotte Posted April 8, 2019 Author Posted April 8, 2019 2 minutes ago, froezus said: I made a short circuit on my board and the TX pin is no more working... Oh ! On the board side ... Next time, it is better to short the USB-TTL side, they are less expensive ... 0 Quote
frozeus Posted April 8, 2019 Posted April 8, 2019 4 minutes ago, martinayotte said: Oh ! On the board side ... Next time, it is better to short the USB-TTL side, they are less expensive ... Yes, at least the RX is still working. BTW i have sent the patch for U-Boot if you could add your "Tested-by" tag for the reset patch. Thanks 0 Quote
ilchenko Evgeny Posted April 8, 2019 Posted April 8, 2019 2 hours ago, froezus said: You just need to put it in build/patch/atf/atf-sunxi64/ i cant find this path( 0 Quote
frozeus Posted April 8, 2019 Posted April 8, 2019 It has been merged so no need to add : https://github.com/armbian/build/tree/master/patch/atf/atf-sunxi64 0 Quote
ilchenko Evgeny Posted April 8, 2019 Posted April 8, 2019 2 hours ago, froezus said: It has been merged so no need to add : https://github.com/armbian/build/tree/master/patch/atf/atf-sunxi64 hmmm, orange pi 3 does not support? Only supported boards? how i can fix reboot on orange pi 3 ? 0 Quote
martinayotte Posted April 8, 2019 Author Posted April 8, 2019 3 minutes ago, ilchenko Evgeny said: how i can fix reboot on orange pi 3 ? I've committed both Megi and Froezus patches earlier today in Armbian build scripts, so you simply need to recompile a new U-Boot and install it. 0 Quote
frozeus Posted April 8, 2019 Posted April 8, 2019 I have proposed a proper patch to ATF hope it will be accepted soon https://github.com/ARM-software/arm-trusted-firmware/pull/1926 0 Quote
martinayotte Posted April 9, 2019 Author Posted April 9, 2019 2 hours ago, froezus said: I have proposed a proper patch to ATF hope it will be accepted soon I'm a bit confused ... @megi patch seems to be H6 specific, but yours seen to affect all Allwinners SoC ... Can you details ? ... 0 Quote
frozeus Posted April 9, 2019 Posted April 9, 2019 no the SUNXI_WDT_QUIRK is only set to 1 in sun50i_h6/platform.mk not for all platforms. 0 Quote
Icenowy Posted April 9, 2019 Posted April 9, 2019 I tested on a Rongpin RP-H6B development board, and it also resets properly with normal WDOG. So maybe only OPi's are affected? 0 Quote
dolphs Posted April 9, 2019 Posted April 9, 2019 just compiled fresh full OS image ( Armbian_5.78_Orangepioneplus_Debian_stretch_dev_5.0.7.img ) but alas " reboot " hangs, so therefore my guess is I was too early and will wait another few days building from scratch, thanks for your efforts! :~/armbian/patch/atf/atf-sunxi64$ ls -la total 36 drwxrwxr-x 4 dolphs dolphs 4096 Apr 9 16:32 . drwxrwxr-x 5 dolphs dolphs 4096 Mar 11 00:03 .. -rw-r--r-- 1 root root 902 Apr 9 16:32 0001-Fix-reset-issue-on-H6-by-using-R_WDOG.patch -rw-rw-r-- 1 dolphs dolphs 1112 Mar 11 00:03 add-SRAM-mapping-for-SCPI.patch.disabled drwxrwxr-x 2 dolphs dolphs 4096 Apr 9 16:32 board_pine64so drwxrwxr-x 2 dolphs dolphs 4096 Mar 11 00:03 board_pinebook-a64 -rw-rw-r-- 1 dolphs dolphs 1079 Mar 11 00:03 enable-a53-errata-workaround.patch.disabled -rw-rw-r-- 1 dolphs dolphs 1315 Mar 11 00:03 enable-additional-regulators.patch -rw-rw-r-- 1 dolphs dolphs 525 Mar 11 00:03 set-rsb-to-nonsec.patch Just noticed the patch is added with root user instead of mine, perhaps need to chown it and give it another try? 0 Quote
