  2. hi guys, yesterdays announcement of Qualcomm Arduino UNO Q on some Dragonwing SoC ... but heard anybody about it already? how it can be open? some questions ... P.
  3. moved
  4. Not an Armbian image. If you want to use this one, try to get support from where you got the image from.
  5. Yesterday
  6. Hi @Hqnicolas first of all, thanks for all yours and other efforts on this project. I had an eye on it a few months back but only this week did I dig out my two boxes.. A few questions for you if you don't mind answering? I have two boxes, 2GB version I was using for development (Android image) and then full fledged 8GB version. Now, because the boxes were in storage for a year or two I thought I had the 4GB and 8GB version, do you happen to have somewhere the Bootloader image for the 2GB model? I've done a google but can only find the 4 and 8GB version. I was experimenting with Armbian and kinda bloated the image so I'll start from scratch. I went ahead and flashed Armbian on both now without issues, however, I've noticed the Wifi is quite slow on it - around 120-240KB/s download and ping to `1.1.1.1` gives around 30 - 300ms, I've had `top` going at the same time and don't see any high CPU utilization. The Wifi driver is something like `bcmrfm` or alike. Is this normal? I've got my 2GB version hooked up to serial out. I do remember seeing an output in plain English however I can't remember the settings, would you be able to tell me? I've tried the common baud rates with Minicom but no matter what I do I just get a garbled output. The link from previous messages for the SDCard holder is now invalid, could you point me to one that will fit nicely on the board? Finally, from your last post, I see you got the front display displaying data, could you point me in the right direction to code for this? Either C++ or Python will do. I do plan on a monitor for eth, wifi and with time + load + temp possibly. Thanks, Robert.
  7. Thanks for compiling that overlay in to a DTB - i've just tried putting that in to /boot/dtb/rockchip/rk3588-nanopc-t6.dtb, rebooted, and it successfully booted and used HS200 mode for the MMC! [ +0.015056] mmc0: SDHCI controller on fe2e0000.emmc [fe2e0000.emmc] using ADMA [ +0.006109] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ +0.000031] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ +0.000008] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ +0.000023] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 95,32 bit host data width,256 deep fifo [ +0.000004] mmc0: new HS200 MMC card at address 0001 [ +0.000045] dwmmc_rockchip fe2c0000.mmc: Got CD GPIO [ +0.000236] mmcblk0: mmc0:0001 A3A444 230 GiB [ +0.002488] mmcblk0: p1 [ +0.000267] mmcblk0boot0: mmc0:0001 A3A444 4.00 MiB [ +0.000759] mmcblk0boot1: mmc0:0001 A3A444 4.00 MiB [ +0.000672] mmcblk0rpmb: mmc0:0001 A3A444 4.00 MiB, chardev (243:0) I'm puzzled as to why that worked, but the overlay didn't work. I would have grabbed some logs if I could, but there was no display output so I think the only output would have been on the UART? Unfortunately, I bought the version that comes in a case and the UART is on the top side of the board that I can't access. Searching around, it doesn't look like it is easy to pop it out of the case either. Just in case putting it in to user overlays was wrong, I tried reverting to the original DTB, putting the overlay in /boot/dtb-6.12.44-current-rockchip64/rockchip/overlay/rockchip-rk3588-nanopc-t6-emmc.dtbo, activating it via armbian-config, and rebooting. Unfortunately I hit the same issue as before where it wouldn't boot. Is there a way I can debug why the overlay isn't working without getting access to the UART header on the top of the board?
  8. That's already a topic (with a solution): https://forum.armbian.com/topic/55129-trixie-apt-warning-policy-will-reject-signature-within-a-year/
  9. Screenshot is in the original post, it still looks the same now.
  10. @werner, thanks for the information and the clarification on my concern in the documentation. This sounds like an interesting project, I do believe I'll give it a try. Again, thank you for the encouragement and the pointers.
  11. What exactly have you installed on the SD card (version, image name), and what steps have you used to install?
  12. same problem, and 25.11.0-trunk.129 img dont work
  13. Hi, I have the same TV Box and would like to install Armbian Linux. Could someone tell me which version to install and how?
  14. I have a TV box with 1.5 GB lpddr3 that has been running Manjaro Arm without any problems for a long time. I used this TV box to add lpddr3 support to the dram driver many years ago. You can get the latest patch for 6GBIT lpddr3 support here: https://github.com/iuncuim/manjaro-h616/blob/main/uboot-t98-h2b-lp3/0007-shrink-ram.patch
  15. From the Circuit Schematic it looks like the Radxa Rock 5B+ RK3588 GPIO0-C0 is the fan I/O, GPIO pin 24, if thats correct. I will verify I can access this on the Armbian distro.
  16. Hello, I have two Orange Pi Zero 2 for two years, I didn't know what to do with it. Yesterday I have installed Armbian_25.5.1_Orangepizero2_noble_current_6.12.23. The serial was a bit buggy during installation (display + key press), I have used option -L with screen: screen -L /dev/ttyUSB0 115200 Thank you for your great work !
  17. Orange pi 5 wifi now supports injection mode using nexmon. Kali distro available from setup menu.
  18. where exactly does this error show up? while downloading with your browser? while writing to the sdcard? while booting? Please elaborate. debug boot issues: https://debug.armbian.de
  19. Hi @loeriver, Yes, it depends a bit on what brand/type and how you connect the USB to serial converter. The ones i use to monitor the serial console on all my SBCs have these spurious events as well, even when I do not connect the +5Vdc on the serial/UART end. For me they are sometimes preventing a full board shutdown as they seem to leach power to the SBC (not sure how this is happening electrically, perhaps some pull-ups allowing current to flow from RX into the Vcc of the board?). You could try to remove the dongle from the system to see if that has any effect to rule this out completely. Groetjes,
  20. Last week
  21. @oscylator678 I used this PPA https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco Mesa 23.0, PanVk has already Vulkan 1.4.
  22. @Fredrik thank you for testing.
  23. It seems like there is a mix-up between specs for the framework and for the OS. A lightweight desktop can run on 512MB, yes but probably not much fun, depending on applications. Won't recommend running a web browser. I'd probably get some existing cheap sbcs with similar specs and play with them to elaborate if the performance is sufficient.
  24. Thank you very much. I will try it. Thank you very much. I will try it.
  25. I can confirm that my changes have now been merged into the upstream linux_openfd repo, so I have deleted my fork. Unfortunately I am unable to edit my instructions, but hopefully it should be clear from the instructions that if my fork is unavailable, then the original repo should be used (alternatively, if a mod could edit the post to remove the reference to my fork, to make the instructions clearer, that would also be appreciated).
  26. Small update. The hack below seems to work as well. $ sudo systemctl edit armbian-hardware-optimize.service Add the following content between comments [Unit] Before=basic.target systemd-networkd.service netplan-wpa-wlan1.service Please note that armbian-hardware-optimize was picked at random to force anything that touches wlan1 to wait until slightly later in the boot process. No tests were done to determine at what exact point in the boot process wlan is "safe" to interact with.
  27. Thanks for the reply, Tall Man. In a way, that was the point. My experience is really only with my home network use and with nvme information displayed by linux tools which seem to insist on the xnypz suffix on the root word nvme. I continued reading up on the general topic overnight and it seems that in the dtb tree world, the focus is on structuring cohesion and delaying actuating instances, so I am guessing different (more general) descriptors are used. My query was whether the precise descriptor was correct as I could see other options possible, one of which had, I think, popped up elsewhere. Since I had seen other reports of difficulties in loading systems to devices, I thought it a remote possibility that a typo had crept in. I still havent found anything definitive in my reading re the formats of the abstractions in the dt stack. I am interested in knowing about this but I as my Armbian is up and running now, and I identified the actual issue for me was a sd card error, the pressure is off . So, I hope this ramble was not too tedious and I do appreciate that you took the time to answer, and again, thanh you cheers
