Very good, thank you very much. Stupid question – I have a Raspberry pi5 and the manual mentions rpi4b. Will that work?
No it is not.
I've learned that I can pass BRANCH=vendor and I can confirm that everything works with the vendor 6.1.x kernel. I'd rather not be stuck with this old version but just wanted to confirm that it works with my setup.
I can report back that the above mentioned HAT works well well with the Kioxia SSD I have. So this problem very likely has something to do with armbian, and is not hardware related. -
hmm just thinking out loud atm, which usually start gibberish and in the end from a coaster it holds something usable ... Rgd the ROCK2F, I noticed "GPIO pin 2 & 4 " could be used to power up the device, which is possible with different boards too... Now I suppose an USB to TTL ( 3,3 V, TXD, RXD, GND and +5 V. ) wont dot the job in this case to power up the board, but I'm sure there is something available avoiding to solder ... The usb-c port can be used both for data and power, so an USB2LAN (x)Gbit adaptor can be used to make this a cheap wifi2lan bridge :-).
Hi everyone, I'm using the Orange Pi Zero 3 and would really appreciate a lightweight desktop image with just the XFCE desktop, a web browser, and basic tools (like file manager, terminal, etc.) with video acceleration. The current Armbian desktop image works, but it includes a lot of software I don’t need. I’m looking for something more minimal — just enough for light use and a faster experience. Does anyone have (or know how to build) a stripped-down XFCE image for this board? Thanks in advance!
@dale git clone https://github.com/NickAlilovic/build.git --branch v20251014
take note that these functions are done by other repos with specificity using the name Armbian, as an example ophub is (ab)using the name Armbian without permission and they do not contribute to the core development process. Rather they trick users into thinking they get support here and therefore (ab)using our resources. everyone in the community has this as the main feature of a TV box -
@Amaliacan you please share the devfmc and armbian image version names/link that you have used to make the box booting? Is sound, wired and wireless networks working for you in this approach? I have a x96 x4 box with S905x4 chipset 4/64 GB model. I am trying to load Armbian. So far Devfmc version boots, network is also working. I am unable to boot into Armbian of any version.
@Tomi Skies It could be your gpio settings. You need to extract your original android dts. https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/page/4/#comment-187672
Hi, thanks a lot for pointing me in the right direction. Indeed so far I am booting from the SD card. I have erased eMMC with multitool via SSH, as multitool as well is not visible via HDMI. Used the newer images as suggested, same situation: everything works via SSH cmd line, no output on HDMI. Log contains mainly errors as the ones posted above.
Thanks for the answer, @amazingfate! I guess there might be e bug in the driver. Once I have more time (if I have) I will issue a bug report to the kernel devs and will try ti test and send required info. Regards, Tano
Maybe not? root@rp-satellite-01:~# for X in 0 1;do echo "mmcblk${X}: $(cat /sys/block/mmcblk${X}/device/type)";done mmcblk0: SD mmcblk1: SD root@rp-satellite-01:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sdb 8:16 1 238.3G 0 disk └─sdb1 8:17 1 238.3G 0 part /media/usb mmcblk1 179:0 0 59.6G 0 disk └─mmcblk1p1 179:1 0 59G 0 part /var/log.hdd / mmcblk0 179:32 0 3.6G 0 disk └─mmcblk0p1 179:33 0 3.5G 0 part zram0 252:0 0 233.1M 0 disk [SWAP] zram1 252:1 0 50M 0 disk /var/log zram2 252:2 0 0B 0 disk root@rp-satellite-01:~#
Any news around here? I'm trying to communicate an OrangePi Zero 2W with an MKS SGEN L by Serial connection and there's no way.
Collabora is proud to sponsor this year's annual GStreamer conference, taking place in London, UK. Join us as we showcase the latest with machine learning analytics, WirePlumber, and more. View the full article
Orange Pi 5 Pro - extend SPI4 to 5 chipselect
Rafael Junio replied to Rafael Junio's topic in Rockchip
I was able to extend, thanks everyone for the support. I attached my final dts, I also changed from spi4 to spi1, because I double check the pinount and spi4 is not mapped. In the original pinout armbian spi1 = orange pi 5 pro spi4. rk3588s-spi1-5cs-spidev.dts -
Thanks for your sharing! While I was trying to perform the upgrade for a Pine64, I happily notice that the latest release of armbian-config actually have an option for the distro upgrade. By following the wizard, Debian was upgrade to trixie.
How to help Armbian about the new Orange pi sbc, orange pi 6 plus?
Werner replied to olivetree's topic in New boards
Hi, difficult task since there is no support for the whole chip family in the framework yet, but first steps are here:https://github.com/armbian/build/pull/8364 I suggest to start by getting familiar with the framework and how the mentioned pending pr it put together. moved -
The way the Debian .iso installer does it: sudo apt-get -o APT::Install-Recommends="true" install task-lxqt-desktop That will install a fully functional desktop with a minimal set of applications. If you set Install-Recommends to false, or any other way of installing it (i.e. lxqt), in my experience, the result may not be quite functional.
@remlei I'did uploading this imagem, is minimal, i hope help you! https://drive.google.com/file/d/1esroAyxq2D2kJ5XPB2_pofQ473B-h1_S/view
Dont write that "fbi works correctly", when it is not. The display remains white, and the kernel doesn't show any errors. * Re-check your wiring * Disconnect the touch part of the LCD pins * Try reversing the polarity: dc-gpios = <&pio 2 6 1>; << change the 1 to 0 reset-gpios = <&pio 2 9 1>; << change the 1 to 0 If the CPU is successful sending the reset signal, the data/command, the chip select and any bytes through SPI, at least the LCD should turn black.
I know this is older, but you need fping6 as well. See inside my install script for Zabbix server https://github.com/sgjava/install-zabbix/blob/589abd9527b1dbd505776a4c80afe8e515aef878/scripts/install.sh#L210
