"This DRAM setup is currently not supported."
qwerty keyboard replied to qwerty keyboard's topic in Allwinner CPU Boxes
Oh, btw your branch throws an APT error around "ntpdate" not having an installation candidate or something. I'm pretty sure there's other issues, but I'm out of the house at this very moment. -
That's nice, I don't have this new board BOM, be free to add the variant, I think board variants are included using a .dtso file for armbian i think we cannot include tirth party drivers, but any changes to .dts could be included into a .dtso file that's a way to enable this variant into mainline armbian -
Good evening everyone. I acquired another X96Q TV Box with the same Armbian-H313 processor, but this time with revision V4.0. I flashed an SD card with the following image: Armbian-unofficial_25.05.0-trunk_X96q-ddr3_bookworm_edge_6.12.11_server.img.xz Surprisingly, the box booted correctly with this version. However, when I tried to install my server, the system prompted me to perform an update. I ran the following command: sudo apt update && sudo apt upgrade After rebooting, the box remained stuck on the red LEDE. Luckily, I hadn't installed it in the internal memory. Here is a photo of the two cases: Here is a photo of the motherboards of both cases: Here is a photo of the X96Q-Armbian-H313 V4.0 boot screen: Here is a photo of the X96Q-Armbian-H313 V4.1 boot screen: Here is the X96Q-Armbian-H313 V4.0 report file: X96Q-Armbian-H313 V4.0.txt Here is the X96Q-Armbian-H313 V4.1 report file: X96Q-Armbian-H313 V4.1.txt Question: Could the difference between version V4.0 and V4.1 of X96Q explain the incompatibility during installation? And how can this be resolved? I would like to use them as servers. Is there any risk if I reinstall, but this time directly to the case's internal memory? Thank you in advancur help.
I made a typing error: Please use the the correct emmc block instead the parition: Extract the DTB file with: dd if=/dev/mmcblk1 of=rk3528-<TV_BOX_NAME>.dtb skip=<START_ADDR> count=<SIZE> bs=1
So I rebuilt the image, applied a patch to integrate the tpm into the dts during the build and it works. I still need to figure out how to make overlays work with GRUB in case we need them. Thank you for your support
You are likely hitting genuine bugs and/or the situation of missing packages. I do not use Cinnamon, so I cannot comment much. Try to see if there is anything relevant in the logs. Check ~/.xsession* files for hints, too. Maybe try a different DE first, set up it to be working and then work on your preferred choice after that. Have a look at APA which is trying to improve the experience of Armbian as an OS, maybe it can help you. Good luck, amigo!
@Igor, supposedly, these images do not boot. Maybe you have a chance to verify on your end.
most likely a bunch of packages that shouldn't have been removed were removed alongside, the joys of GUI package management 1) don't be afraid of the command line 2) see if /var/log/dpkg.log gives any hints what is missing What desktop system were you using before? Try to get it back installed. PS: In your current situation, you can reach a log-in console and command line with Ctrl-Alt-F1 PPS: Reinstalling from scratch might be faster.
I’m currently using the Armbian build system to generate images for the Orange Pi 5 Plus. To use the PREEMPT_RT kernel, I set the BRANCH to current, and with the PREEMPT_RT configuration on the 6.12 kernel I was able to successfully build the image and boot it. However, in this kernel version there are no dtbo files for peripherals like can0, i2c, etc., so I’m unable to use those interfaces. If I set the BRANCH to vendor, I can use the 6.1 kernel, but in order to use a PREEMPT_RT kernel I need to apply the RT patch. The RT patch currently provided is not compatible with the current BRANCH, so kernel build and image creation fail. My question is: while using the 6.12 current kernel, is there any way to copy and use the dtb and dtbo files from the 6.1 vendor kernel?
One interface is for STA (client mode / normal wireless) and one for AP (access point, where you connect to) or P2P (Wi-Fi Direct). Some firmware / drivers enables this by default. Usually it is in Makefile (just example https://github.com/armbian/rtl8723ds/blob/main/Makefile) but it could also be deep in the code. Don't know.
Very simple module for nothing, Segmentation fault
Henrik Larsson replied to Kopia's topic in Allwinner sunxi
With 6.12, no changes as far as I know -
laibsch replied to dev001's topic in Software, Applications, Userspace
Try pipewire instead of pulseaudio -
Orange PI has very good hardware (better than RPI) but bad support of software from factory devellopers. Raspberry PI 5 is a bit slower but we have more support and always new versions. I have both.
@Maurizio Finesso Try editing on a linux machine instead of windows. I've seen some windows machines not be able to read the boot partition
This site deals with Armbian Linux not android. You should direct your question about restoring Android to a more appropriate forum
Hello all, Ok, I'm going to comment on my own question here... I just now installed the Armbian 25.8.0 6.18.0 RC5 xfce version. It's not yet on the nvme drive but, it's significant faster than the 25.5.1 version. Now HD video works on the 5b+. It needs 2 seconds to stabilize but than it is perfectly fine to watch. I use Firefox as my browser. So thanks to the team! Ernst-Jan
Hi all, I would like to ask support for the board EMB-3531. I'm having problem with booting this board from SD card. Here are some informations about this board. I hope that someone can help me with it. Thank you so much! I try to erase the emmc and flash the MiniLoaderAll.bin but it doesn't help. Or i don't have a correct image with armbian for this board. https://my.kos.org.cn:5154/rockchip/EMB3531/emb3531.pdf
Try from here: https://fi.mirror.armbian.de/incoming/igorpecovnik/ (this is going to be next release - first test build).
Your best bet is to compile your own image. It's super easy: "git clone https://github.com/armbian/build.git;cd build;./compile.sh" https://docs.armbian.com/Developer-Guide_Building-with-Docker/ https://docs.armbian.com/Developer-Guide_Build-Preparation/ https://www.youtube.com/watch?v=kQcEFsXEJEE
Iván Reyes replied to tasknodes's topic in Amlogic CPU Boxes
I hope this helps... For the TX3 Mini, I used the distributions listed on https://www.armbian.com/amlogic-s9xx-tv-box/. Here's what I did: * Create a bootable image using Rufus (following the instructions). * Once the image was created, I went to the SD card's storage drive on a PC and made the following changes: * In the root directory of the SD card, I copied the file u-boot-s905x-s912 and pasted it as u-boot.ext. * In extlinux\extlinux.conf, on line 4, I changed it to "fdt /dtb/amlogic/meson-gxl-s905w-tx3-mini.dtb". * I ejected the SD card, inserted it into the TX3 Mini, and turned it on. If it doesn't work, try a different distribution.
