  2. It seems that eMMC has built-in boot partitions. eMMC devices are not just "raw storage" (like SD-Cards) they have special reserved hardware partitions defined by the JEDEC eMMC standard. These include: boot0 – a small partition (usually a few MB) reserved for bootloader code. boot1 – a second small boot partition, often used as a backup. RPMB (Replay Protected Memory Block) – a secure partition for keys and counters. The SoC’s boot ROM (first-stage loader) can be configured to read directly from boot0 or boot1 when powering on. Also, these partitions are read-only to decrease the risk of having corrupted boot code. Beware that they’re not used by the Linux filesystem unless explicitly written to (usually via dd when flashing U-Boot).
  3. Hi, I am using Nanopi Neo board and I need RS485 driver to control DE pin automatically. I have prepared DTS Overlay file: /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&uart1>; __overlay__ { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart1_pins &uart1_de_pin>; rs485-rts-gpios = <&gpio6 8 0>; /* PG8 active-low */ linux,rs485-enabled-at-boot-time; rs485-rts-delay = <0 300>; }; }; fragment@1 { target = <&uart2>; __overlay__ { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart2_pins &uart2_de_pin>; rs485-rts-gpios = <&gpio0 2 0>; /* PA2 active-low */ linux,rs485-enabled-at-boot-time; rs485-rts-delay = <0 300>; }; }; }; I produced dtbo file from dts one with the command: dtc -@ -I dts -O dtb -o rs485.dtbo rs485.dts I copied this rs485.dtbo file to /boot/dtb/overlay. Also I added rs485 string to ArmbianEnv.txt and rebooted. But only TX works, RX doesn't. What should I do else to make it work?
  4. The guidance I found is on Github, nexbox-a95x-arm https://github.com/berci9ke101/nexbox-a95x-armbianbian. I think its similar to some guidance I looked at when I first looked at Armbian and how I got Coreelec to run on my A95X box
  5. Hi! With latest edge 6.15.4 the board boots fine, shutdown also clean and complete but on reboot it does not again start up. Need to powercycle😒 I gets stuck et end of shutdown. Same for latest bookworm image (I think it's 6.12x). Earlier ones did work. => Any other board also affected? => Is for reboot the watchdog involved? T.
  6. Hi and thanks! Tested now but no luck. Compiled edge 6.15.4 Linux nanopiduo2 6.15.4-edge-sunxi #1 SMP Fri Jun 27 10:13:43 UTC 2025 armv7l GNU/Linux now i get Device creation failed: -14. [h264 @ 0x11f9b40] No device available for decoder: device type drm needed for codec h264. Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> wrapped_avframe (native)) Device setup failed for decoder on input stream #0:0 : Bad address [AVIOContext @ 0x11ac030] Statistics: 498846 bytes read, 0 seeks command as follows: ffmpeg -v trace -re -hwaccel drm -i Big_Buck_Bunny_720_10s_10MB.mp4 -f null - also tried fbdev output but same result. ffmpeg version is still ffmpeg -v ffmpeg version 5.1.7-0+deb12u1 Copyright (c) 2000-2025 the FFmpeg developers built with gcc 12 (Debian 12.2.0-14+deb12u1) configuration: --prefix=/usr --extra-version=0+deb12u1 --toolchain=hardened --libdir=/usr/lib/arm-linux-gnueabihf --incdir=/usr/include/arm-linux-gnueabihf --arch=arm --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librist --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --disable-sndio --enable-libjxl --enable-pocketsphinx --enable-librsvg --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-libplacebo --enable-librav1e --enable-shared libavutil 57. 28.100 / 57. 28.100 libavcodec 59. 37.100 / 59. 37.100 libavformat 59. 27.100 / 59. 27.100 libavdevice 59. 7.100 / 59. 7.100 libavfilter 8. 44.100 / 8. 44.100 libswscale 6. 7.100 / 6. 7.100 libswresample 4. 7.100 / 4. 7.100 libpostproc 56. 6.100 / 56. 6.100 Unfortunately there are countless forks of ffmpeg. I used the one from here https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/ As of now I haven't found anything about a current kernel and ffmpeg working on any H3, only stuff back in 2019 and/or kernel 4.x 🙂 I also tried several extraargs=cma=### up to 256M but all same error. I really woud love to get some more tech background on "how stuff works" which may help me troubleshoot. => Can we enable debug output from the cedrus driver? How? => Can we enable debug output from thev4l2 layer? How? => Which libraries are involved, eg. v4l2request, other v4l2* which may need additional install/update? => Do in need v4l2-util / v4l2-ctl to configure some stuff? If yes, what exactly? (Remember, Its currently for file playback. I know about for cam capture) => Could the v4l2loopback help? => Can anybody confirm it really works on H3 maybe on an OrangePi board? If yes I can pull the Opi device tree and compare for possible differences. T.
  7. @Jean-Francois Lessard sorry for making you confused. Device tree source for tm16xx driver that I convert from a working openvfd.conf is below /dts-v1/; /plugin/; #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/leds/common.h> &{/} { display_client: spi { #address-cells = <1>; #size-cells = <0>; compatible = "spi-gpio"; sck-gpios = < 7 GPIO_ACTIVE_HIGH>; mosi-gpios = < 2 GPIO_ACTIVE_HIGH>; cs-gpios = < 12 GPIO_ACTIVE_LOW>; num-chipselects = <1>; display@0 { compatible = "fdhisi,fd628"; reg = <0>; spi-3wire; spi-lsb-first; spi-max-frequency = <500000>; digits { #address-cells = <1>; #size-cells = <0>; 01 02 03 04 }; leds { #address-cells = <2>; #size-cells = <0>; led@{GRID0},0 { reg = <{GRID0} 0>; function = "apps"; }; led@{GRID1},1 { reg = <{GRID1} 1>; function = "setup"; }; led@{GRID2},2 { reg = <{GRID2} 2>; function = LED_FUNCTION_USB; }; led@{GRID3},3 { reg = <{GRID3} 3>; function = LED_FUNCTION_SD; }; led@{GRID4},4 { reg = <{GRID4} 4>; function = "colon"; }; led@{GRID5},5 { reg = <{GRID5} 5>; function = "hdmi"; }; led@{GRID6},6 { reg = <{GRID6} 6>; function = "video"; }; }; }; }; }; The convert script I downloaded from this commit https://github.com/jefflessard/tm16xx-display/blob/a93b257ed4c73780fcdefbb1f1dd189599cf6ecc/vfdconf-convert Can you please help get it to work? Thanks!
  8. @Nick A based on chatgpt with website research, it depends on with box meaning that mine still have a h313, its cortex a53. 64 bit, then what is it? (I can give you more proof that mine is allwinner h313)
  9. Everything you wish for here is achievable with pure U-Boot technology. A long time ago, I tried to practice how to realize this here in the forum, but my lesson from it was: You can't teach old dogs new tricks, and Armbian users want to celebrate their cargo cult and hope that it will magically fulfill their wishes.
  10. I think Thunderbird, Firefox and other programs should configure firewall as well, of course without any information about that.
  11. Yesterday
  12. I have a ssh connection with my TV BOX (it is a AMLOGIC with S912), in my etc/ssh/sshd_config I have "UsePAM yes" and without any delay for connection, and probably it was not the problem of your delay in the start connection. In addition, I installed a vnc service to work remotely using the graphical interface. Either ssh and vnc Viewer (xtightvncviewer in my Debian Desktop) run pretty well. Please, check your basic network services, as well, fix the IP in the TV BOX. In my case I did some adjusts such: cat /etc/network/interfaces auto lo iface lo inet loopback auto eth0 iface eth0 inet static address 192.168.15.22 netmask 255.255.255.0 gateway 192.168.15.1 dns-nameservers 8.8.8.8 1.1.1.1 There are some network services that can be impling in your delay by ssh (it is robust, old and fast application of Linux) I hope to help you too.
  13. Hi everyone, i manage to extract the .dtb file from the recovery partition of the rk3528-X88pro13-android. This is the board number : X88PRO 13-D4-V1.1 (2023-04-12). Maybe it will be useful to someone 😉 rk3528-x88pro13-android.dtb
  14. Overlay was renamed at some point to just uart5 `/boot/dtb/allwinner/overlay/sun50i-h616-uart5.dtbo` (without `ph5`), so `overlays=uart5` works and is available at /dev/ttyS1
  15. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
  16. nice, thank you for your feedback
  17. hi, I am unable to boot Armbian on Gamebox G11 Pro. I am able to boot CoreElec and Emuelec easily via sd card. I have tried every tip and trick to boot it, lot of Armbian versions and forks. Can you suggest a suitable armbian dtb file for the same. The most reliable method to boot it.
  18. Great to see continued development for RK3318/RK3328 boards, Armbian support really helps unlock their full potential for lightweight Linux projects.
  19. @usual user The USB and Ethernet ports are exposed, but how would that work exactly? I don't know how to make the software boot from USB or Ethernet and even if I did I don't know what to boot into that can write an image file to the emmc chip. I can find no info on this on radxa or armbian sources.
  20. When you do first login, you need to choose correct locales combination and language in desktop should follow - you still need to install desktop packages ... If you don't have locales support in the system, you won't be able to use it in desktop. I think this is the problem. In my case, when I select my own locales (sl_SI.UTF-8) and install those desktop related packages, I have Gnome with Slovene support.
  21. RPi added some checks in their initramfs post-update script which causes this, found here: /etc/initramfs/post-update.d/z50-raspi-firmware: case $flavour in v8|v8-rt|2712|v6|v7|v7l) ;; *) echo "ERROR: Unsupported initramfs version ($initrd_version)" exit 0 ;; esac However there is also another fine in this folder which was added years ago: https://github.com/armbian/build/pull/6039/files#diff-02b9b6fbb77fcab23278cd4a148b3f2c91d2c1361d05f33a21bdab19182caf21R139-R153 That seems to handle initramfs creation properly. So the error message is purely cosmetical. That would give trouble when updating rpi packages from upstream since there would be changes detected. Better solution might be to add a hint to our code stating that the ERROR can be ignored as long as overall initramfs generation was successful.
  22. Additional Info: The "Current" Kernel I found the equivalent code in the Current kernel. It is a clearly a different version of the file, but it looks like the same error is present. I have not tested it. Snippet Source: ./build/cache/sources/linux-kernel-worktree/6.12__rockchip64__arm64/arch/arm64/boot/dts/rockchip/rk3588-orangepi-5-plus.dts &analog_sound { pinctrl-names = "default"; pinctrl-0 = <&hp_detect>; simple-audio-card,aux-devs = <&speaker_amp>, <&headphone_amp>; simple-audio-card,hp-det-gpios = <&gpio1 RK_PD3 GPIO_ACTIVE_LOW>; // This line here: Change GPIO_ACTIVE_LOW to GPIO_ACTIVE_HIGH simple-audio-card,widgets = "Microphone", "Onboard Microphone", "Microphone", "Microphone Jack", "Speaker", "Speaker", "Headphone", "Headphones"; The "Vendor" Kernel I found the equivalent code in the Vendor kernel's devicetree. It is also a clearly different version of the file from the other two kernel trees. But it looks like this particular coding error (for the audio) is not present here. The headphone detection level is set to GPIO_ACTIVE_HIGH. Source: ./build/cache/sources/linux-kernel-worktree/6.1__rk35xx__arm64/arch/arm64/boot/dts/rockchip/rk3588-orangepi-5-plus.dts However in my experience (tested again just now with version 28.5.1), the Vendor kernel seems a bit crippled: No GPU or video acceleration, and no ES8388 analog audio whatsoever (not even at the ultra-low volume I was getting with the Edge kernel). At least the screen, keyboard, mouse, and ethernet works, but with no video acceleration the video is slow and clumsy. I suspect that the best place to look for the audio issue with the Vendor kernel is not to focus on the audio, so much as to focus on what broke on an apparently deeper level.
  23. Last week
  24. still on windows , but microsoft suggests 11 so looking for linux 11
  25. It's worth noting that you don't have to necessarily change anything in the build process. As long as you plan to not insert partitions in the middle, you can: write the image to the card with parted, resize the root partition to whatever you want make a new partition If you want to have more than 4 partitions total, this works best with GPT partition table, but legacy msdos works too with a little more effort `fsck.ext4 -f /dev/foo` where foo is the root partition `resize2fs /dev/foo` after you have the machine booted, you can then mkfs the new partition [you could probably do it in advance of booting the system too] I do this regularly, b/c I typically only partition about 1/2 or 1/4 of the SD card to leave the rest for wear-leveling. Are you trying to do this as a one-off or are you trying to do it for a dozen or more SBCs of the same type?
  26. @fevangelou nice guide. THX! but maybe it would be best to have the instruction in an separate topic! in best case it gets also pinned. so new users can find it much easier than scrolling though 18 pages (in this thread. there is also the 4gb thread) to find it......
  27. Yes I'm aware that I can only rely on the community for any help or tip. I'm now considering to revert back to a bullseye setup with a 5.10 Radxa kernel, but I was kind of reluctant to keep an old version of Debian as my Rockpi is accessible from ouside my network... The Rockpi is powered by a PoE hat, it never had any issue so far but maybe the PoE management is the culprit. I'll try an use the Rockpi with a traditional power supply, but in any case if this is the issue it won't be a sustainable solution for my target setup.
  28. I had the precise information about data-offset from "--examine" mdadm command, and also I was in raid1, that's far less sensitive to error than raid5 or raid0 for example. I would not have been surprised that the resync, if taken to the end, would have worked... But I will never know. As far as I know, I get the data back and I'm very lucky and happy. Thank you
