  2. Hello and thanks for your answer. Seems that no, I'm trying R-studio now and it's finding 7 superblocks, and for now it has found 5000+ files... Will try to get this back after the scanning.
  3. For anyone looking for simple instructions to install the official Armbian image for "H96 Max V56" (as of August 30th, 2025) using a Linux PC (e.g. Ubuntu Desktop 24.04): 1. Install the "rkdeveloptool" tool first, as instructed in: https://docs.radxa.com/en/zero/zero3/low-level-dev/rkdeveloptool?host-os=debian sudo apt-get update sudo apt-get install -y libudev-dev libusb-1.0-0-dev dh-autoreconf pkg-config libusb-1.0 build-essential git wget git clone https://github.com/rockchip-linux/rkdeveloptool cd rkdeveloptool autoreconf -i ./configure make -j $(nproc) sudo cp rkdeveloptool /usr/local/sbin/ At the time of writing, this installed version 1.32. If you installed "rkdeveloptool" from Ubuntu's repos, it would install version 1.0 which may work, but let's be on the safe side here... 2. Connect and boot the device to loader/maskrom mode 2.1 While pressing the reset button (back/right) with a pin, connect the USB 2.0 port (back/left) and the power cable. Gotta be careful here not to miss the reset button pressing while connecting the cables. 2.2 Use the rkdeveloptool tool to identify the device and the mode it is on ("loader" or "maskrom"). $ rkdeveloptool ld ...should show the connected device if point 2.1 was successful - e.g. on my 8GB RAM device it printed this: DevNo=1 Vid=0x2207,Pid=0x350a,LocationID=304 Loader Or after I had already flashed Armbian, it would show: DevNo=1 Vid=0x2207,Pid=0x350a,LocationID=304 Maskrom (If you installed "rkdeveloptool" from Ubuntu's repo, the command is "rkdeveloptool list" if I recall correctly - every other "rkdeveloptool" command following though is the same) Now grab the latest release of Armbian for this device. At the time of writing it was: https://github.com/armbian/community/releases/download/25.11.0-trunk.106/Armbian_community_25.11.0-trunk.106_H96-tvbox-3566_bookworm_current_6.12.44_minimal.img.xz (the name of the device is on the filename) Extract the included .img file with (sudo apt install xz-tools): $ unxz Armbian_community_25.11.0-trunk.106_H96-tvbox-3566_bookworm_current_6.12.44_minimal.img.xz 2.2.1 If in "loader" mode (see the last part of the command's output above), simply flash Armbian directly. E.g. $ sudo rkdeveloptool wl 0x0 Armbian_community_25.11.0-trunk.106_H96-tvbox-3566_bookworm_current_6.12.44_minimal.img (if you attempt to flash the attached bootloaders, you'll get a "device not supported" error - Armbian already contains a bootloader) 2.2.2 If in "maskrom" mode (e.g. if you are re-flashing Armbian), flash the bootloader first: # For the 8GB RAM device use the attached (in this post) H96-MAX-8gb-MiniLoaderAll.bin file $ sudo rkdeveloptool db H96-MAX-8gb-MiniLoaderAll.bin # For the 4GB RAM device use the attached (in this post) H96-MAX-4gb-MiniLoaderAll.bin file $ sudo rkdeveloptool db H96-MAX-4gb-MiniLoaderAll.bin ...and then re-flash Armbian as you did the first time: $ sudo rkdeveloptool wl 0x0 Armbian_community_25.11.0-trunk.106_H96-tvbox-3566_bookworm_current_6.12.44_minimal.img 2.3 Reboot the device with: $ sudo rkdeveloptool rd Done! If all goes well, once you reboot the device you will be asked to set a root password and optionally a sudo user. Rebooting afterwards you should now be greeted with: _ _ _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ __ ___ _ __ _ __ _ _ _ _ (_) |_ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ / _/ _ \ ' \| ' \ || | ' \| | _| || | /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|_\__\___/_|_|_|_|_|_\_,_|_||_|_|\__|\_, | |___| |__/ v25.11 rolling for h96-tvbox-3566 running Armbian Linux 6.12.44-current-rockchip64 Packages: Debian stable (bookworm), possible distro upgrade (trixie) Updates: Kernel upgrade enabled and 2 packages available for upgrade Support: for advanced users (rolling release) IPv4: (LAN) 192.168.1.10 (WAN) 1.2.3.4 Performance: Load: 3% Uptime: 2 min Memory usage: 2% of 7.50G CPU temp: 40°C Usage of /: 3% of 57G Commands: Configuration : armbian-config Upgrade : armbian-upgrade Monitoring : htop Last login: Sat Aug 30 12:47:54 2025 Key points: - If you do this the first time, it's obviously a matter of just flashing the latest Armbian image directly. - You don't need to open the device or compile Armbian. - It's simpler than 2 years ago when I bought the device thanks to people like @Hqnicolas (muito obrigado Nicolas!) H96-MAX-4gb-MiniLoaderAll.bin H96-MAX-8gb-MiniLoaderAll.bin
  5. please be more specific, what happened exactly? where did you get that statement that netplan or networkmanager are not supposed to touch firewall settings? when you bring a network interface up or down that can obviously affect firewall rules.
  6. @Ducdanh Nguyen can you see your axp chip? never heard of bigfish. Is that a heat sink on your SOC? Not sure why it has no writing on it. Install this android app it should give you more information https://play.google.com/store/apps/details?id=com.finalwire.aida64&hl=en_CA&pli=1 Did you apply the secure boot patch?
  7. Hello everyone - I started having problems with installing to eMMC and I assume it is related to uboot. It used to work in the past on my devices but it doesn't anymore. The script runs successfully without any errors (besides not finding the ini file, which is irrelevant supposedly). But when trying to boot from eMMC (sd removed), I get a couple of errors (Card did not respond to voltage select), which indicates, that the eMMC can't be found. It tries booting from USB and ETH and ultimately fails. Is anybody else seeing this issue? I'm running a Vontar X3 (identical with HK1 and X96 max). By the way - the eMMC is fine. When I boot from the SD card, I can mount the eMMC ROOT and BOOT partition and they seem all correct.
  8. This does not seem to work anymore. The flashing works but when trying to boot from eMMC, the device can't initialize the eMMC anymore ("Card did not react to voltage select"). Anybody else seeing this problem?
  9. Hello crew, I have similar issues with installing to eMMC. In the past I was able to flash to eMMC and boot from there. I bought a second device (I'm running 2 Vontar X3, which are identical with HK1 and H96 Max, running 905x3) and flashing the newer versions of Armbian does not work anymore. I can run it from the SD card, I can even run the install script, but it will only boot, when the SD card is still in. When I try booting from the eMMC, it does not work. In the past it worked but something seems to have changed over time. I'm going the clean route and flash the original android firmware before trying to flash Armbian, to have a clean environment. I assume it's a change in U-Boot and the eMMC not being initialized correctly. When trying to boot, I get a bunch of "Card did not respond to voltage select! : -110" error messages. Then it tries booting over USB or ETH, which all fails. Does anybody know, how I could make it boot from eMMC again? Who is responsible for uboot? Thanks in advance!
  10. Specifically, your board is "Community Maintained" That means it is not supported by Armbian resources (beyond the automated infrastructure to make builds and host them for the community) https://docs.armbian.com/User-Guide_Board-Support-Rules/#community-maintained
  11. @dale you need a display overlay that is compatible with tm16xx. OpenVFD overlays are NOT supported. You can read README.md and dt-bindings documentation at https://github.com/jefflessard/tm16xx-display But note that there has been many changes recently to the code base since the driver is currently in review process to be upstreamed into mainline kernel (targeting v6.18). So double check which bindings version format has been integrated into Armbian rockchip64. The GitHub repo also contains a vfd-convert utility to automatically convert OpenVFD configuration files to expected tm16xx DTSO. But : 1. It requires OpenVFD conf file, not dtso. 2. You may need to go through file history to get the version matching of what has been integrated into Armbian rockchip64.
  12. If you can solve the problem, please share it with the community.
  13. To replace an image on the eMMC, the MASKROM mode is not necessary. It is only required when the firmware is so damaged that it no longer works, but the signature is still intact and the MASKROM code still executes it. To replace an image, it is sufficient to boot from a rootfs that is not on the eMMC and replace it from there. And the good thing about it is that no device-specific hacks are necessary, just a properly configured bootflow. Furthermore, it is also self-contained, as no external devices with special software or other dependencies are necessary. It can also be automated in such a way that it runs unattended and the user only has to start the process initially.
  14. Customizing image and customizing kernel are different tasks. For latter use the code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } kernel-config command and then copy over the created config file from output to userpatches. The framework will look for custom kernel configuration files and uses them if they're detected. More details here: https://zuckerbude.org/armbian-using-kernel-config/
  15. Yesterday
  16. That seems to have gone away. ? SNILMERG... Now using very small but 1920x1080 screen, xfce terminal text is about 7 microns tall, way too small for my ancient eyes, Simplified keyboard. ctrl&shift&+ magnify's text but when big enough to read, bottom of xfce4 terminal is offscreen below bottom of screen, so cannot see command line. Is there a keycode combo that expands text independently from terminal window size? Thank you.
  17. Armbian kernel and BSP Debian/Ubuntu userland
  18. You are still using an old Linux. You need Linux 6.13 or newer. You need to build your own Armbian OS. Also, don't forget the cma=256M kernel argument
  19. I was just wondering if there would be an issue because of different U-Boot and kernel combination in the 2 tests, but that does not seem to be the case. I think there might be some issue with the controller in the eMMC module that is starting to reveal when wear-level is or is getting higher. What fsck commands are done? So how is it fixed and is it fixed or is only metadata corrected and might there be corrupted data-blocks still without knowing. I don't use Ext4, I use Btrfs for rootfs and all other storage devices. In doubt, I use DUP profile for meta data, that is more for HDDs. As said Btrfs allows adhoc or regular scrubs, you will be able to detect where corrupt blocks are if that is the issue. It also might be that there is an issue in the 6.6 kernel that reveals itself when higher write delays or so, maybe update the OS. Maybe mmc-utils can show some issue (I have no experience with it).
  20. reopening after moving to "Software / Applications / Userspace"
  21. You realized the wrong thing: the topic is actual but this is not a forum where to discuss about Android or stock firmwares
  22. Yup, I opened a bug report about this on his github, I have yet to receive an answer. I'm having trouble figuring out if it's a hardware issue or a software issue, since I don't have a second bug to test at the same time. When I try the Makerbase OS on this same board, I don't have connectivity either, but at least, the link led turns on and off with the cable connect/disconnect.
  23. Did you try to build the image with compile.sh and this following setting? INCLUDE_HOME_DIR=yes See https://docs.armbian.com/Developer-Guide_Build-Switches/#advanced
  24. Yeah, also on my laptop (Arch with upstream 6.16 kernel) this problem does not happen, so it shouldn't be because of specific patches to the rtw88 kernel in the RPi kernel repo. It only happens when I use the kernel built with Armbian build system. I am completely clueless about what could be causing this 🤷‍♂️
  25. Sorry that was resolved 2 days ago, but I don't see and never seen this long list. Only 3 options vendor 6.1, 6.12 and edge (6.16), This morning I also seen the u-boot wasn't the good one. I downloaded for rock5-itx, but had linux-u-boot-cyber-aib-rk3588-edge instead of linux-u-boot-rock-5-itx-edge, changed it, rebooted (on 6.16) worked, tried again 6.12, still no display. I needed to arch-chroot on the armbian to take a screenshot (but I've the same dispay on armbian itself): I seen 6.16.4 is now available and work, after /boot/config-6.16.4-edge-rockchip64, gcc 13.3.0 is now again used instead of old 11.x :). Debian Trixie has GCC 14.2.0 CONFIG_CC_VERSION_TEXT="aarch64-linux-gnu-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0" And after changelog on kernel.org, patch for AV1 acceleration had been applied on this version: https://cdn.kernel.org/pub/linux/kernel/v6.x/ChangeLog-6.16.4 Fixes: 003afda97c65 ("media: verisilicon: Enable AV1 decoder on rk3588") Sorry I maybe mix too much subjects in the same post, but: I also seen a minimal IoT version of Trixie for Rock5-itx. Can I made safely a debian os upgrade from apt? Or is it better to wait release for desktop version ? Another point. On armbian, only LLVMpipe is used, I compiled last mesa git on arch, will try to do this for debian too. and some application that need to use EGL+dri (wings3D, blender, obs) report broken DRI2 access. I'm not sure if it's due to some kernel patchs (I reuse the armbian 6.16 kernel on arch), or to the current state of mesa-git. They all works with llvmpipe. Othere applications like PPSSPPSDL work fine without it. Ex, with wings3d + forced zink: MESA_LOADER_DRIVER_OVERRIDE=zink GALLIUM_DRIVER=zink wings3d WARNING: Some incorrect rendering might occur because the selected Vulkan device (Mali-G610) doesn't support base Zink requirements: feats.features.fillModeNonSolid feats.features.shaderClipDistance libEGL warning: egl: failed to create dri2 screen WARNING: Some incorrect rendering might occur because the selected Vulkan device (Mali-G610) doesn't support base Zink requirements: feats.features.fillModeNonSolid feats.features.shaderClipDistance
  26. You can either experiment with the CLEAN_LEVEL switch or use kernel-patch or uboot-patch (depending on what you want to modify) to create proper patch files from the diff.
  27. Did you download stretch already, before I remove it to put up Bionic?
