  2. @remlei you can see from the u-boot log that the overlay is not applied because there is the rk322x prefix two times. The overlay must be set literally as usb-otg-peripheral as I wrote above, and not rk322x-usb-otg-peripheral: the rk322x prefix is added automatically. About the OTG functionality, as said your mileage may vary. Unforturnately the rk322x OTG port or driver does not seem to be very collaborative or totally standard compliant.
  3. After installing official Armbian_25.2.1_Orangepi5-plus_bookworm_vendor_6.1.99_xfce_desktop.img to sdcard, then to nvme all is fine, until, I do an apt update & upgrade, after that point chromium fails to run. I explored the logs to see it a failure to load chromium.conf from /etc/chromium.d/chromium.config (failed symbolic link to /etc/armbian/chromium.config). Is there a known workaround besides utilization of firefox?
  4. Finally got around to debug this: Previously I had the system on an nvme drive and the bootloader on spi After reinstalling the system and bootloader both on mmc flash, I eventually ran into the very same issue. According to the logs, the boot bails with the following error: Log1: When I remove the nvme drive, the boot process works just fine for some reason: (boot log after nvme removal) Log2: When I reinstall the nvme, the boot fails again. However, booting from sd-card (using recovery button) and reflashing the bootloader to the mmc fixes the issue as well with the same result as removing the nvme drive had, resulting in the same log2 as above. I had fixed the issue before by reflashing the bootloader to spi but just like yesterday, it eventually stopped booting again until I reflashed the boot loader. There isn't anything particular happening before this occurs, though the last few times it was always after the system had run for some time. After cutting power (without shutdown) and booting it again after a few minutes, the issue would appear. (The device is always cut from power instead of shutting it down, but there was never an error on any drive due to that). The issue also did not show when the device was just turned of (without power) for a day or two. It seems to trigger quite randomly. I already tried to erase the spi flash to avoid any old entries messing up the boot order but without effect. Any clue what I could try next?
  5. The OPi5 uses an es8388 for the analog audio out. I don't know about the OPi5Max or other boards for that matter, as I don't own any other relevant SBC. Good luck!
  6. Good afternoon jock! I'm asking for your help again. The X88 pro 10 128 Gb(X88 PRO-8-RK3318-D4-V1.6) box does not want to work with an LED screen. Arabian-config led-config2 is set, the screen does not respond. There is no display folder in the /sys/class/leds directory. When installing the led-config5, the service works, the check starts, but the display does not light up at all! How do I set it up? Box H96 max It works great on this version and led-config5. 4.036378] spi_gpio i2c-aux-display: cs36 >= max 1 [ 4.036421] spi_master spi0: spi_device register error /i2c-aux-display/aux-display-controller@24 [ 4.036471] spi_master spi0: Failed to create SPI device for /i2c-aux-display/aux-display-controller@24 Box H96 max It works great on this version. v24.11 rolling for RK3318 Box running Armbian Linux 6.11.5-edge-rockchip64 Packages: Debian stable (bookworm) Support: for advanced users (rolling release) Performance: Load: 32% Up time: 12 min Memory usage: 17% of 3.88G CPU temp: 59°C Usage of /: 6% of 114G I attached a photo of the led display chip (the outputs from the led display go to it) AIP16283BT35 (maybe it tm1628 ?) IMG_4802.heic
  7. Thank you for replying me back and the hint. I ordered USB to TTL module Today. I'll debug and get back to you. Best regards alarik.
  8. 6.1.44 root@orion-o6:~# cat /proc/cpuinfo processor : 0 model name : CIX P1 CD8180 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm ssbs sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint st CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 processor : 1 model name : CIX P1 CD8180 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm ssbs sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint st CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd80 CPU revision : 1 processor : 2 model name : CIX P1 CD8180 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm ssbs sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint st CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd80 CPU revision : 1 processor : 3 model name : CIX P1 CD8180 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm ssbs sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint st CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd80 CPU revision : 1 processor : 4 model name : CIX P1 CD8180 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm ssbs sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint st CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd80 CPU revision : 1 processor : 5 model name : CIX P1 CD8180 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm ssbs sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint st CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 processor : 6 model name : CIX P1 CD8180 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm ssbs sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint st CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 processor : 7 model name : CIX P1 CD8180 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm ssbs sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint st CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 processor : 8 model name : CIX P1 CD8180 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm ssbs sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint st CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 processor : 9 model name : CIX P1 CD8180 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm ssbs sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint st CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 processor : 10 model name : CIX P1 CD8180 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm ssbs sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint st CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 processor : 11 model name : CIX P1 CD8180 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm ssbs sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint st CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 6.15-rc5 root@orion-o6:~# cat /proc/cpuinfo processor : 0 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint svei8mt CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 processor : 1 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint svei8mt CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd80 CPU revision : 1 processor : 2 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint svei8mt CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd80 CPU revision : 1 processor : 3 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint svei8mt CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd80 CPU revision : 1 processor : 4 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint svei8mt CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd80 CPU revision : 1 processor : 5 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint svei8mt CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 processor : 6 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint svei8mt CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 processor : 7 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint svei8mt CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 processor : 8 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint svei8mt CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 processor : 9 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint svei8mt CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 processor : 10 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint svei8mt CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 processor : 11 BogoMIPS : 2000.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm jscvt fcma lrcpc dcpop sha3 sm3 sm4 asimddp sha512 sve asimdfhm dit uscat ilrcpc flagm sb paca pacg dcpodp sve2 sveaes svepmull svebitperm svesha3 svesm4 flagm2 frint svei8mt CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd81 CPU revision : 1 ************************************************ 6.1.44 root@orion-o6:~# cat /proc/interrupts CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7 CPU8 CPU9 CPU10 CPU11 9: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 25 Level vgic 11: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 30 Level kvm guest ptimer 12: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer 13: 40190 1155 1103 990 992 4992 4651 2309 2115 1322 1288 1670 GICv3 26 Level arch_timer 18: 3232 0 0 0 0 0 0 0 0 0 0 0 PDCv1 363 Level 6590000.mailbox 19: 4 0 0 0 0 0 0 0 0 0 0 0 PDCv1 359 Level 65a0000.mailbox 20: 1 0 0 0 0 0 0 0 0 0 0 0 PDCv1 378 Level 21: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 379 Level 5070000.mailbox 22: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 207 Level c010000.ddr_ctrl 23: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 210 Level c030000.ddr_ctrl 24: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 213 Level c050000.ddr_ctrl 25: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 216 Level c070000.ddr_ctrl 26: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 35 Level complex_errirq 27: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 39 Level complex_faultirq 28: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 43 Level core_errirq 29: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 55 Level core_faultirq 30: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 36 Level complex_errirq 31: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 40 Level complex_faultirq 32: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 44 Level core_errirq 33: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 56 Level core_faultirq 34: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 37 Level complex_errirq 35: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 41 Level complex_faultirq 36: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 45 Level core_errirq 37: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 57 Level core_faultirq 38: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 38 Level complex_errirq 39: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 42 Level complex_faultirq 40: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 46 Level core_errirq 41: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 58 Level core_faultirq 42: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 47 Level core_errirq 43: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 59 Level core_faultirq 44: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 48 Level core_errirq 45: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 60 Level core_faultirq 46: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 49 Level core_errirq 47: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 61 Level core_faultirq 48: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 50 Level core_errirq 49: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 62 Level core_faultirq 50: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 51 Level core_errirq 51: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 63 Level core_faultirq 52: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 52 Level core_errirq 53: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 64 Level core_faultirq 54: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 53 Level core_errirq 55: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 65 Level core_faultirq 56: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 54 Level core_errirq 57: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 66 Level core_faultirq 58: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 0 Level dsu_errirq 59: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 1 Level dsu_faultirq 60: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu 68: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 415 Level pcie-local 69: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 412 Edge pcie-aer-c 70: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 413 Edge pcie-aer-f 71: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 414 Edge pcie-aer-nf 72: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 109 Edge arm-smmu-v3-evtq 74: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 114 Edge arm-smmu-v3-gerror 76: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 75497472 Edge PCIe PME, aerdrv 77: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 262 Level 9010000.usb-controller 78: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 263 Level 9010000.usb-controller 79: 0 28 0 0 0 0 0 0 0 0 0 0 ITS-MSI 76021760 Edge nvme0q0 80: 39 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 76021761 Edge nvme0q1 81: 0 3 0 0 0 0 0 0 0 0 0 0 ITS-MSI 76021762 Edge nvme0q2 82: 0 0 3 0 0 0 0 0 0 0 0 0 ITS-MSI 76021763 Edge nvme0q3 83: 0 0 0 21 0 0 0 0 0 0 0 0 ITS-MSI 76021764 Edge nvme0q4 84: 0 0 0 0 1 0 0 0 0 0 0 0 ITS-MSI 76021765 Edge nvme0q5 85: 0 0 0 0 0 36 0 0 0 0 0 0 ITS-MSI 76021766 Edge nvme0q6 86: 0 0 0 0 0 0 52 0 0 0 0 0 ITS-MSI 76021767 Edge nvme0q7 87: 0 0 0 0 0 0 0 2 0 0 0 0 ITS-MSI 76021768 Edge nvme0q8 88: 0 0 0 0 0 0 0 0 5 0 0 0 ITS-MSI 76021769 Edge nvme0q9 89: 0 0 0 0 0 0 0 0 0 21 0 0 ITS-MSI 76021770 Edge nvme0q10 90: 0 0 0 0 0 0 0 0 0 0 8 0 ITS-MSI 76021771 Edge nvme0q11 91: 0 0 0 0 0 0 0 0 0 0 0 55 ITS-MSI 76021772 Edge nvme0q12 92: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 268 Level 9080000.usb-controller, xhci-hcd:usb1 93: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 269 Level 9080000.usb-controller 94: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 274 Level 90f0000.usb-controller, 90f0000.usb-controller 95: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 275 Level 90f0000.usb-controller 96: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 280 Level 9160000.usb-controller, xhci-hcd:usb3 97: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 281 Level 9160000.usb-controller 98: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 252 Level 91d0000.usb-controller, xhci-hcd:usb5 99: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 253 Level 91d0000.usb-controller 100: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 257 Level 91e0000.usb-controller, xhci-hcd:usb7 101: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 258 Level 91e0000.usb-controller 102: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 240 Level 9260000.usb-controller, xhci-hcd:usb9 103: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 241 Level 9260000.usb-controller 104: 14698 0 0 0 0 0 0 0 0 0 0 0 PDCv1 243 Level 9290000.usb-controller, xhci-hcd:usb10 105: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 244 Level 9290000.usb-controller 106: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 246 Level 92c0000.usb-controller, xhci-hcd:usb11 107: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 247 Level 92c0000.usb-controller 108: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 249 Level 92f0000.usb-controller, xhci-hcd:usb12 109: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 250 Level 92f0000.usb-controller 110: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 286 Level cdns-i2c 111: 4 0 0 0 0 0 0 0 0 0 0 0 PDCv1 287 Level cdns-i2c 112: 0 0 0 0 0 0 0 0 0 0 0 0 cdns-gpio 8 Level 1-0030, 1-0031 113: 2 0 0 0 0 0 0 0 0 0 0 0 PDCv1 288 Level cdns-i2c 114: 30 0 0 0 0 0 0 0 0 0 0 0 PDCv1 289 Level cdns-i2c 115: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 290 Level cdns-i2c 116: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 291 Level cdns-i2c 117: 63 0 0 0 0 0 0 0 0 0 0 0 PDCv1 292 Level cdns-i2c 118: 54 398 272 217 1195 3277 2536 1595 828 559 414 388 PDCv1 470 Level sky1_timer 119: 0 0 0 0 0 0 0 0 0 0 0 0 cdns-gpio 6 Edge chromeos-ec 120: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 51 Level 10010000.cmn_pmu 121: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 2 Level arm_dsu_0 122: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 21 Level arm_spe_pmu 123: 6846 0 0 0 0 0 0 0 0 0 0 0 PDCv1 298 Level uart-pl011 124: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 405 Level pcie-local 125: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 402 Edge pcie-aer-c 126: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 403 Edge pcie-aer-f 127: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 404 Edge pcie-aer-nf 128: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 425 Level pcie-local 129: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 422 Edge pcie-aer-c 130: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 423 Edge pcie-aer-f 131: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 424 Edge pcie-aer-nf 132: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 443 Level pcie-local 133: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 440 Edge pcie-aer-c 134: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 441 Edge pcie-aer-f 135: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 442 Edge pcie-aer-nf 136: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 434 Level pcie-local 137: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 431 Edge pcie-aer-c 138: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 432 Edge pcie-aer-f 139: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 433 Edge pcie-aer-nf 140: 0 0 0 0 0 0 0 0 0 0 0 0 cdns-gpio 10 Level hym8563 142: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134217728 Edge PCIe PME, aerdrv 143: 0 0 0 174 0 0 0 0 0 0 0 0 ITS-MSI 134742016 Edge enP1p1s0-0 144: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742017 Edge enP1p1s0-1 145: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742018 Edge enP1p1s0-2 146: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742019 Edge enP1p1s0-3 147: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742020 Edge enP1p1s0-4 148: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742021 Edge enP1p1s0-5 149: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742022 Edge enP1p1s0-6 150: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742023 Edge enP1p1s0-7 151: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742024 Edge enP1p1s0-8 152: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742025 Edge enP1p1s0-9 153: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742026 Edge enP1p1s0-10 154: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742027 Edge enP1p1s0-11 155: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742028 Edge enP1p1s0-12 156: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742029 Edge enP1p1s0-13 157: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742030 Edge enP1p1s0-14 158: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742031 Edge enP1p1s0-15 159: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742032 Edge enP1p1s0-16 160: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742033 Edge enP1p1s0-17 161: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742034 Edge enP1p1s0-18 162: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742035 Edge enP1p1s0-19 163: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742036 Edge enP1p1s0-20 164: 1 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742037 Edge enP1p1s0-21 165: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742038 Edge enP1p1s0-22 166: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742039 Edge enP1p1s0-23 167: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742040 Edge enP1p1s0-24 168: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742041 Edge enP1p1s0-25 169: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742042 Edge enP1p1s0-26 170: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742043 Edge enP1p1s0-27 171: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742044 Edge enP1p1s0-28 172: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742045 Edge enP1p1s0-29 173: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742046 Edge enP1p1s0-30 174: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 134742047 Edge enP1p1s0-31 176: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 293601280 Edge PCIe PME, aerdrv 177: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125568 Edge enP2p49s0-0 178: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125569 Edge enP2p49s0-1 179: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125570 Edge enP2p49s0-2 180: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125571 Edge enP2p49s0-3 181: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125572 Edge enP2p49s0-4 182: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125573 Edge enP2p49s0-5 183: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125574 Edge enP2p49s0-6 184: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125575 Edge enP2p49s0-7 185: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125576 Edge enP2p49s0-8 186: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125577 Edge enP2p49s0-9 187: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125578 Edge enP2p49s0-10 188: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125579 Edge enP2p49s0-11 189: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125580 Edge enP2p49s0-12 190: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125581 Edge enP2p49s0-13 191: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125582 Edge enP2p49s0-14 192: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125583 Edge enP2p49s0-15 193: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125584 Edge enP2p49s0-16 194: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125585 Edge enP2p49s0-17 195: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125586 Edge enP2p49s0-18 196: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125587 Edge enP2p49s0-19 197: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125588 Edge enP2p49s0-20 198: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125589 Edge enP2p49s0-21 199: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125590 Edge enP2p49s0-22 200: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125591 Edge enP2p49s0-23 201: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125592 Edge enP2p49s0-24 202: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125593 Edge enP2p49s0-25 203: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125594 Edge enP2p49s0-26 204: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125595 Edge enP2p49s0-27 205: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125596 Edge enP2p49s0-28 206: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125597 Edge enP2p49s0-29 207: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125598 Edge enP2p49s0-30 208: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-MSI 294125599 Edge enP2p49s0-31 209: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 229 Level 7000000.audio-dsp 211: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 303 Level arm-dma350 212: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 230 Level arm-dma350 213: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 224 Level 7070000.i2s5 214: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 225 Level 7080000.i2s6 215: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 227 Level 70a0000.i2s8 216: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 228 Level 70b0000.i2s9 217: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 328 Level armcb_config 218: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 329 Level armcb_config 219: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 452 Level cix_vi_hw 220: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 453 Level cix_vi_hw 221: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 454 Level cix_vi_hw 222: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 455 Level cix_vi_hw 223: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 456 Level cix_vi_hw 224: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 457 Level cix_vi_hw 225: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 458 Level cix_vi_hw 226: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 459 Level cix_vi_hw 227: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 316 Level 14010000.disp-controller 228: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 332 Level 14064000.dp 229: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 318 Level 14080000.disp-controller 230: 6 0 0 0 0 0 0 0 0 0 0 0 PDCv1 333 Level 140d4000.dp 231: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 320 Level 140f0000.disp-controller 232: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 334 Level 14144000.dp 233: 7681305 0 0 0 0 0 0 0 0 0 0 0 PDCv1 234 Level hda irq 234: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 322 Level 14160000.disp-controller 235: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 335 Level 141b4000.dp 236: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 324 Level 141d0000.disp-controller 237: 0 0 0 0 0 0 0 0 0 0 0 0 PDCv1 336 Level 14224000.dp IPI0: 328 259 272 179 205 1261 957 439 477 315 259 321 Rescheduling interrupts IPI1: 3145 1282 797 587 949 12073 11896 5262 4114 1709 1642 2448 Function call interrupts IPI2: 0 0 0 0 0 0 0 0 0 0 0 0 CPU stop interrupts IPI3: 0 0 0 0 0 0 0 0 0 0 0 0 CPU stop (for crash dump) interrupts IPI4: 17 964 986 769 730 1174 933 1267 1366 1254 1087 938 Timer broadcast interrupts IPI5: 0 0 0 0 0 0 0 0 0 0 0 0 IRQ work interrupts IPI6: 0 0 0 0 0 0 0 0 0 0 0 0 CPU wake-up interrupts IPI7: 0 0 0 0 0 0 0 0 0 0 0 0 Backtrace interrupts Err: 0 root@orion-o6:~# 6.15-rc5 root@orion-o6:~# cat /proc/interrupts CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7 CPU8 CPU9 CPU10 CPU11 9: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 25 Level vgic 10: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 30 Level kvm guest ptimer 11: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer 12: 10381 11172 8258 7956 7099 7771 8184 9342 8704 10114 10261 9369 GICv3 26 Level arch_timer 13: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 107 Edge arm-smmu-v3-evtq 14: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 116 Edge arm-smmu-v3-priq 15: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 112 Edge arm-smmu-v3-gerror 17: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 141 Edge arm-smmu-v3-evtq 18: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 150 Edge arm-smmu-v3-priq 19: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 146 Edge arm-smmu-v3-gerror 23: 5622 0 0 0 0 0 0 0 0 0 0 0 GICv3 330 Level uart-pl011 87: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 294 Level xhci-hcd:usb1 88: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 306 Level xhci-hcd:usb3 89: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 284 Level xhci-hcd:usb5 90: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 289 Level xhci-hcd:usb7 91: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 272 Level xhci-hcd:usb9 92: 15497 0 0 0 0 0 0 0 0 0 0 0 GICv3 275 Level xhci-hcd:usb10 93: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 278 Level xhci-hcd:usb11 94: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 281 Level xhci-hcd:usb12 116: 34 0 0 0 0 0 0 0 0 0 0 0 ITS-PCI-MSIX-0000:91:00.0 0 Edge nvme0q0 117: 0 0 0 0 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu 120: 70 0 0 0 0 0 0 0 0 0 0 0 ITS-PCI-MSIX-0000:91:00.0 1 Edge nvme0q1 121: 0 5 0 0 0 0 0 0 0 0 0 0 ITS-PCI-MSIX-0000:91:00.0 2 Edge nvme0q2 122: 0 0 1 0 0 0 0 0 0 0 0 0 ITS-PCI-MSIX-0000:91:00.0 3 Edge nvme0q3 123: 0 0 0 4 0 0 0 0 0 0 0 0 ITS-PCI-MSIX-0000:91:00.0 4 Edge nvme0q4 124: 0 0 0 0 1 0 0 0 0 0 0 0 ITS-PCI-MSIX-0000:91:00.0 5 Edge nvme0q5 125: 0 0 0 0 0 89 0 0 0 0 0 0 ITS-PCI-MSIX-0000:91:00.0 6 Edge nvme0q6 126: 0 0 0 0 0 0 5 0 0 0 0 0 ITS-PCI-MSIX-0000:91:00.0 7 Edge nvme0q7 127: 0 0 0 0 0 0 0 13 0 0 0 0 ITS-PCI-MSIX-0000:91:00.0 8 Edge nvme0q8 128: 0 0 0 0 0 0 0 0 8 0 0 0 ITS-PCI-MSIX-0000:91:00.0 9 Edge nvme0q9 129: 0 0 0 0 0 0 0 0 0 43 0 0 ITS-PCI-MSIX-0000:91:00.0 10 Edge nvme0q10 130: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-PCI-MSIX-0000:91:00.0 11 Edge nvme0q11 131: 0 0 0 0 0 0 0 0 0 0 0 32 ITS-PCI-MSIX-0000:91:00.0 12 Edge nvme0q12 132: 0 0 0 0 0 0 0 0 0 0 0 0 ITS-PCI-MSIX-0000:31:00.0 0 Edge enp49s0 133: 0 0 198 0 0 0 0 0 0 0 0 0 ITS-PCI-MSIX-0000:01:00.0 0 Edge enp1s0 IPI0: 251 230 262 269 224 254 216 228 162 226 247 192 Rescheduling interrupts IPI1: 6951 6262 6795 2901 3247 5840 3546 2978 3438 3783 3558 4085 Function call interrupts IPI2: 0 0 0 0 0 0 0 0 0 0 0 0 CPU stop interrupts IPI3: 0 0 0 0 0 0 0 0 0 0 0 0 CPU stop NMIs IPI4: 0 0 0 0 0 0 0 0 0 0 0 0 Timer broadcast interrupts IPI5: 1525 872 340 244 292 480 449 506 729 718 675 671 IRQ work interrupts IPI6: 0 0 0 0 0 0 0 0 0 0 0 0 CPU backtrace interrupts IPI7: 0 0 0 0 0 0 0 0 0 0 0 0 KGDB roundup interrupts
  9. No problem installing Armbian stable 23.11 (or 23.8) and then upgrading to 25.2.3. Don't use nightly/trunk... francesco@orangepipc2:~$ uptime 08:32:44 up 29 days, 16:57, 1 user, load average: 0,26, 0,64, 0,36
  10. Hi @Hqnicolas, could you please help to tell me how to flash this official community image? it seems can not upgrade the firmware directly
  11. Hi @Zaf9670, Your situation actually helped find an OBOE in the U-Boot image overlap test, so thank you for that! Can you try with an older image and share the U-Boot output? Also, can you add the following in your armbianEnv.txt: verbosity=8 earlycon=on console=serial I've had better experience with setting console to serial only and earlycon might help the kernel spew out some things earlier on. Groetjes,
  12. Yesterday
  13. It is diffucult to add certain advanced features to both / all base packages versions - which is the core difference between Debian and Ubuntu. And later more difficult and certainly less fun is keeping features operational. This is one of the main points behind providing both variants. Making assembly (Debian Bookworm, Ubuntu Jammy, Noble, ...) is easier, and cover several other aspects too, then adding and maintaining advanced features for both / all. Sometimes its nearly impossible (our resources are not endless and we have to remember we are in open source world - forks compete without contributions to commons) to add something to one, while its relatively easy adding it to another. At the end of the day, it is, like you said, more important that some feature works.
  14. CP2102 are not capable of 1.5 megabaud in linux
  15. $ xz -t Armbian_25.2.1_Khadas-edge2_noble_vendor_6.1.99_gnome_desktop.oowow.img.xz $ echo $? 0 Check your download. Probably corrupted.
  16. wireless-regdb is already installed and apt returns E: Unable to locate package crda for crda. Thanks for trying to help
  17. Some chips that support 1.5Mbaud and more: - FT232R - CH340G - CP2104
  18. GPU blacklisted the panfrost module Has it been resolved? Thank you
  19. Last week
  20. It's the link up/down problem. Never seen this under bullseye but it happens on bookworm
  21. after some research i have (finally) found the original archives form balbes. they can also been burn to the internal eemc. with some work you can run bookworm with kernel 3.10.99 (dont ask why) from the internal storage... https://archive.org/details/amlogic-s805-linux tks for 0jw4tts witch uploaded those files to archive.og !!!
  22. Guys, does anyone know how to enable the TV Box's wifi with the ik316 process? I downloaded armbian, the only thing missing is wifi. Data transmission works with a network cable, only the wifi is having problems. The iso I downloaded was Armbian-unofficial_25.05.0-trunk_X96q-lpddr3_bookworm_edge_6.12.11_xfce_desktop.img.xz
  23. Be aware that the answer might depend on the filesystem you are using on your board Be aware that a resize operation can easily destroy your data or at least make it inaccessible have a look at shrink-backup for "reverse"
  24. @Popolon indeed this issue rot for a long time. I cleaned up my backlog to have more time for armbian. Also I still have quite a few processes to learn about armbian board maintenance still to this day. But you confirm that with mainline 6.12 all is fine ? But, indeed no HDMI out and no audio. I still have a patch for mainline 6.12 in the pipe about a race condition between SATA chip and nvme as far as I remind. I will prioritize data vendor kernel debugging if this mainline patch is not required (and indeed mainline still lacks any multimedia capability, this might be a showstopper for most users) even though I am close to complete testing and send PR for this one. As of now I have confirmed that this mainline patch set does not help vendor as the vendor branch has a hack that workaround the issue that mainline faces about this SATA/nvme race.
  25. 100mbps is enough for all my projects. if not, there are some usb3 gigabit adapters
  26. Looks like the server images uses systemd for network control, but desktop images use network manager. I believe this should build the server images with network manager: ./compile.sh NETWORKING_STACK="network-manager"
  27. Network bridge is added within armbian-config Docker install ... Perhaps open a ticket https://github.com/armbian/configng so this is eventually done properly.
