  2. Werner
    Odroid M2 16G
    There is none. Its csc device. Community supported. You are community
  4. What exact image are you running? Or better yet providing full logs with armbianmonitor -u
  5. Thanks a lot, I´m in doubt about buying the radxa and use it with my hiby r3II or just buy a Fosi Audio DS1 or Fiio Ka13. I have bought nice headphones and I´m sad I can´t use them on my ps5 correctly. If just for that matter what would you do? Thanks again
  6. @Andrés Pérez Domínguez x your board has the UART pins clearly marked on the board. https://linux-sunxi.org/UART Install this to get more u-boot/kernel debug information. I use a CP2102.
  7. Update 3: almost there! root@rk322x-box:~# dmesg | grep -i drm [ 6.738341] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... [ 6.912602] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 6.914174] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 11.565138] [drm] Initialized lima 1.1.0 for 20000000.gpu on minor 0 root@rk322x-box:~# dmesg | grep -i rockchip [ 0.068016] rockchip-gpio 11110000.gpio: probed /pinctrl/gpio@11110000 [ 0.069475] rockchip-gpio 11120000.gpio: probed /pinctrl/gpio@11120000 [ 0.070736] rockchip-gpio 11130000.gpio: probed /pinctrl/gpio@11130000 [ 0.071810] rockchip-gpio 11140000.gpio: probed /pinctrl/gpio@11140000 [ 1.330865] rockchip-rga 20060000.rga: HW Version: 0x04.01 [ 1.339866] rockchip-rga 20060000.rga: Registered rockchip-rga as /dev/video0 [ 1.360435] dwmmc_rockchip 30000000.mmc: IDMAC supports 32-bit address mode. [ 1.360814] dwmmc_rockchip 30010000.mmc: IDMAC supports 32-bit address mode. [ 1.361387] dwmmc_rockchip 30020000.mmc: IDMAC supports 32-bit address mode. [ 1.371466] dwmmc_rockchip 30000000.mmc: Using internal DMA controller. [ 1.371502] dwmmc_rockchip 30000000.mmc: Version ID is 270a [ 1.371594] dwmmc_rockchip 30000000.mmc: DW MMC controller at irq 49,32 bit host data width,256 deep fifo [ 1.372013] dwmmc_rockchip 30000000.mmc: Got CD GPIO [ 1.395186] dwmmc_rockchip 30010000.mmc: Using internal DMA controller. [ 1.395237] dwmmc_rockchip 30010000.mmc: Version ID is 270a [ 1.395356] dwmmc_rockchip 30010000.mmc: DW MMC controller at irq 50,32 bit host data width,256 deep fifo [ 1.395646] dwmmc_rockchip 30010000.mmc: allocated mmc-pwrseq [ 1.402395] dwmmc_rockchip 30020000.mmc: Using internal DMA controller. [ 1.402458] dwmmc_rockchip 30020000.mmc: Version ID is 270a [ 1.402603] dwmmc_rockchip 30020000.mmc: DW MMC controller at irq 51,32 bit host data width,256 deep fifo [ 11.719472] hantro-vpu 20020000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video2 [ 11.723548] hantro-vpu 20020000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3 [ 25.632131] rk_gmac-dwmac 30200000.ethernet end0: PHY [stmmac-0:00] driver [Rockchip integrated EPHY] (irq=POLL) root@rk322x-box:~# dmesg | grep -i hdmi [ 0.055584] /vop@20050000: Fixed dependency cycle(s) with /hdmi@200a0000 [ 0.055722] /hdmi@200a0000: Fixed dependency cycle(s) with /vop@20050000 [ 22.293730] platform 200a0000.hdmi: deferred probe pending: (reason unknown) [ 22.293761] platform hdmi-sound: deferred probe pending: asoc-simple-card: parse error root@rk322x-box:~# ls -l /dev/dri total 0 drwxr-xr-x 2 root root 80 Jan 28 11:49 by-path crw-rw---- 1 root video 226, 0 Jan 28 11:49 card0 crw-rw---- 1 root render 226, 128 Jan 28 11:49 renderD128
  8. I installed Waydroid on an Amlogic Meson GXM (S912) TV box. The SOC has a Mali-T820 GPU, and the box has 2 GB of RAM and 16 GB of eMMC. This was easy to do and Waydroid worked, but it was very slow, even before it heated the SOC to 80°C, which is probably its throttling limit. I removed Waydroid because it was too slow. I wasn't trying anything demanding. Even navigating Android Settings was ridiculously slow. This is a bit surprising because the hardware was designed for running Android. I was not running much else, just Wayfire and one or two Alacritty consoles. I don't think I was running out of memory. Is it possible to get decent Waydroid performance on other arm64 hardware?
  9. Ubuntu Noble variant already supports ZFS on 6.18.y while Trixie was added today: https://github.com/armbian/os/pull/425 Testing: Once automation completes, it will be provided via normal apt update.
  10. Yesterday
  11. Hello. BTT says what BTT Pi and CB1 is same, but realy not. Dunno why i brought what board. But now I owner of this "piece of ****" So. New board, clean install v25.11.2 for BigTreeTech CB1 running Armbian Linux 6.12.58-current-sunxi64 Packages: Debian stable (trixie) armbianEnv: overlays=gpu tft35_spi extraargs=fbcon=rotate:2 fbcon=rotate:2 for screen rotation, because armbian not from btt and didn`t have feature like param_tft35_spi_rotate Next, help me to determine how to enable UARTs and I2C From BIGTREETECH_Pi_V1.2.1 Hardware Pdf UART0: CPUX-UTX CPUX-RX UART2 (May work as i2c0; uart2-pi-pins; i2c0-pins ) Pi5 Pi6 UART3 (May work as i2c2; uart3-pi-pins; i2c2-pi-pins ) Pi9 Pi10 I2C (i2c4-ph-pins; spi1-pins): PH6 PH7 (must work, i`ll think i2c4-ph overlay present) All pins present in sun50i-h616-bigtreetech-cb1-sd, but didnt have overlays for it... I wish to stay uart0 for u-boot console first uart setup for klipper connections to mcu. any help? If I understand right PH6 is 7*32+6=230 gpioinfo output line 230: unnamed input consumer=kernel line 231: unnamed input consumer=kernel
  12. Totally new to this system, need some help where to start and how to do it i have the RK3328, i verified this via AIDA, how can i install armbian system on this one can someone please help which are the correct images etc.. any steps would be highly appreciated. thanks Suz
  13. Does this mean you have a working DTS that fixes the issue with smc starting the the other 3 CPUs successfully?
  14. It boots but does not recognize USB keyboard input. Not possible to login.
  15. hallo @WanJiXianSheng, responding to this image, for the SUB position where the SD card is installed, there are 3 cables, what is their function? Please share here the guide for flashing to Armbian thx..
  16. sven-ola
    Hello @Malay, et.al, after submitting my PullRQ to the Armbian repo, I think it's best to cope first with the annotations I received from that. It complains about missing board photos, and some LLM generated blurb partly valid suggestions, partly not. The current status of Armbian's Spacemit support does not make the RV2 board a good video player: GPU support is missing and I'm pretty unsure if it's possible to include the HW video encoding / decoding feature that is in the chip. Which is 4k@30 with diverse codecs according to the chip description PDF. I am glad, that X11 framebuffer video runs and I am unsure if I can proceed here b/c I am not a video / GPU / EGL / vulkan specialist. Anyhow, thank you for the pointer to the Spacemit FAQ I did not recognize until now. While the PowerVR page from mesa3d states: "no IMG BXE-2-32" (https://docs.mesa3d.org/drivers/powervr.html), the respective Gitee repo contains closed-source BSD licensed Risc64 compiled shard objects (*.so), probably similar to the Nvida binary user space closed drivers that does the GPU support for the big videos cards. This may be worth a look, but as I wrote above, prio task is to bring the support into the Armbian tree. Best // Sven-Ola
  17. http://blog.armbian.com/content/images/2026/01/githubhighlights-2-2.webpThis week’s Armbian development saw a wide range of updates focused on automation, hardware support, and workflow improvements. Key highlights include the introduction of automatic YAML target generation, expanded support for Hetzner ARM64 runners, and enhancements to the redirector update workflow with cache mirror support. Several board-specific fixes and feature additions were made, including improved power cycle handling for meson-sm1 devices and new binary files for RK35 series components. The team also advanced kernel support, notably enabling RDNA2 GPU compatibility and initial kernel 6.18 support for Ayn odin2. Continuous integration and build reliability received attention through Docker-based unit tests and improved artifact management. Overall, these changes reflect ongoing efforts to streamline development processes and broaden hardware compatibility across the Armbian ecosystem. Add automatic target YAML generation from image-info.json. by @igorpecovnik in armbian/armbian.github.io#184Add board-level extension to mask Wayland desktop sessions. by @schwar3kat in armbian/build#9268Add cache mirror support to redirector update workflow. by @igorpecovnik in armbian/armbian.github.io#189Add edge branch support to community targets. by @igorpecovnik in armbian/armbian.github.io#195Add exposed.map download step to download index workflow. by @igorpecovnik in armbian/armbian.github.io#190Add Hetzner server creation with cloud-init, swap, and configurable runners. by @igorpecovnik in armbian/actions#13Add new binary files for various RK35 series components. by @ghhccghk in armbian/rkbin#42Add regulator-boot-on to meson-sm1-odroid and -hc4 to fix power cycle during boot. by @ean365 in armbian/build#9217Add scripts/generate_targets.py to workflow push trigger. by @igorpecovnik in armbian/armbian.github.io#185Add workflow for enabling 16 Hetzner ARM64 runners. by @igorpecovnik in armbian/armbian.github.io#196arm64: enable AMD DC display controller for RDNA2 GPU support. by @igorpecovnik in armbian/build#9273atf: rk3399: fix PL330 DMA controller initialization. by @iav in armbian/build#9285Bump sm8250. by @CodeChenL in armbian/build#9180Change actions folder to actions-report. by @igorpecovnik in armbian/armbian.github.io#188Change exposed.map minimal patterns from bookworm to trixie, add forky as fallback. by @igorpecovnik in armbian/armbian.github.io#194chore: use release-signing policy for Windows artifacts. by @SuperKali in armbian/imager#87ci: add PR build artifacts with public download links. by @SuperKali in armbian/imager#81ci: use Docker containers for unit tests. by @igorpecovnik in armbian/configng#720cli: kernel-dtb: check dtc for version 1.7.2 before producing normalized dts. by @rpardini in armbian/build#9270config: arch: amd64: fix building kernel amd64 target with on arm64 host. by @rpardini in armbian/build#9271deps: update dependencies and document glib vulnerability. by @SuperKali in armbian/imager#88Enable debug. by @igorpecovnik in armbian/actions#14Enable Firefox download from PPA, drop Jammy and Oracular. by @igorpecovnik in armbian/os#424Exclude non-community trunk builds from promotion. by @igorpecovnik in armbian/armbian.github.io#193extension: grub: deploy qemu binary when doing cross build. by @amazingfate in armbian/build#9282feat: add image status warning for nightly builds and community boards. by @SuperKali in armbian/imager#83fix api change since v6.17. by @Spider84 in armbian/bcmdhd-dkms#5fix api change since v6.19. by @amazingfate in armbian/bcmdhd-dkms#6Fix uptime-kuma Docker image detection regex. by @igorpecovnik in armbian/configng#722fix: reduce board image scale and improve CI cache strategy. by @SuperKali in armbian/imager#86fix: regenerate Tauri updater signatures after SignPath code signing. by @SuperKali in armbian/imager#89fix: use any_changed output for reliable changed files detection. by @igorpecovnik in armbian/configng#725fix: use published_at for release sorting. by @igorpecovnik in armbian/community#46Framework: Add "Repeat Build Options" string at the end in case of er…. by @iav in armbian/build#9276framework: add custom_kernel_make_params extension hook. by @iav in armbian/build#9284Generate separate exposed.map patterns for stable and community boards. by @igorpecovnik in armbian/armbian.github.io#192Include community boards in exposed.map generation. by @igorpecovnik in armbian/armbian.github.io#191Initial support for kernel 6.18 on Ayn odin2. by @kasimling in armbian/build#9286mainline: bump to 6.19-rc6. by @EvilOlaf in armbian/build#9278memoize: add user feedback and configurable timeout for flock. by @iav in armbian/build#9262NanoPi R5C: Update to v2026.01; enable BTRFS support. by @okrc in armbian/build#9291orangepi5-plus: u-boot: restore vendor uboot with blobs. by @rpardini in armbian/build#9287orangepi5-plus: u-boot: use mainline ATF; bump to v2026.01; drop funky CE config options. by @rpardini in armbian/build#9261Override new yaml files - drop the code here if it works.. by @igorpecovnik in armbian/os#423radxa-e54c: board config: replace 'hacky' Wayland fix with wayland-sessions-mask extension. by @schwar3kat in armbian/build#9281radxa-zero2/khadas-vim3l: u-boot: disable LWIP. by @rpardini in armbian/build#9272refactor: conditionally hide custom image button when manufacturer is selected. by @SuperKali in armbian/imager#85refactor: standardize redis module and improve workflow reliability. by @igorpecovnik in armbian/configng#723Reload redirector after we check all mirrors. by @igorpecovnik in armbian/armbian.github.io#178Remove browsers from RISC-V desktop app groups. by @igorpecovnik in armbian/armbian.github.io#186Rockchip 6.18.y: drop upstreamed patches. by @igorpecovnik in armbian/build#9288Rockchip EDGE: drop up-streamed patches. by @igorpecovnik in armbian/build#9290rockchip64: station-m3: Enable USB type-C port. by @kasimling in armbian/build#9246rootfs: enable loong64 in qemu binfmt registration. by @igorpecovnik in armbian/build#9279scripts: use git commit date for 'edited' timestamp instead of filesystem mtime. by @igorpecovnik in armbian/armbian.github.io#177Switch Docker module to distribution maintained packages. by @igorpecovnik in armbian/configng#719Update CI documentation to reflect automated target generation. by @igorpecovnik in armbian/documentation#867Use armbian-apps config for app-specific images. by @igorpecovnik in armbian/armbian.github.io#187work-around Ubuntu Rust coreutils bug in dirname affecting linux-headers board-side compile of scripts/mod. by @iav in armbian/build#9264View the full article
  18. so whats the status on this issue is it resolved by running the rolling forky release and using network manager ?
  19. Last week
  20. Endless loop booting Image. I download Image form source: https://dl.armbian.com/odroidxu4/Bookworm_current_minimal-omv Flash Image with Rufus-4.11 --> no problem insert sd-card in odroid hc1 --> blue LED is flashing I ping to odroid with windows 'ping odroid -t -w 100' --> replied 10 seconds, then there was no response for 40 seconds, and it repeated, I wait 30 minutes. I use Image from archive without OpenMedaivault --> Booting Ok I install OMV 7.0 manually described following link: https://docs.openmediavault.org/en/7.x/installation/on_debian.html in first view everything seem fine BUT: after restart and save settings to SD-card --> odroid restarts after 20 seconds, if you do anything with huge load, it restarts, even 'apt update' or 'apt upgrade" I did several tests, buy a new SD-card try 3 different cards, remove hard drive remove PCB and renew thermal interface material, nothing helps. I installed it 5 to 10 times and I did the installation in different ways. Also nothing helps. I use my old working sd-card and I did some test, it works properly. (old means: installation is 2-3 years old) I try 'armbianmonitor -m' --> output: 23:30:52 600/2000 MHz 0.66 19% 6% 11% 0% 0% 1% 37.0 °C 0/3 The frequency changes depending on the load, I used stress -c 8 --> frequencey 1400/2000MHz -> works perfect I try Debian 12 (Bookworm) with OpenMediaVault from armbian download page. (Build Date: Jan 19, 2026) I try 'armbianmonitor -m' --> output: 22:10:52 200/200 MHz 0.66 19% 6% 11% 0% 0% 1% 24.0 °C 0/3 The frequency was always at 200/200MHz. I think I found the error in '/etc/default/cpufrequtils Both values are "0". MAX_SPEED="0" MIN_SPEED="0" I compare it with my old working sd-card. The values there: MAX_SPEED="2000000" MIN_SPEED="600000" I Update the Image: I 'unxz' the image that I had downloaded from armbian page, 'losetup' it, 'mount' the partition and change the value in 'cpufrequtils' to MAX_SPEED="2000000" MIN_SPEED="600000". I 'xz' the image, flash it to my sd-card and now the images works on my Odroid XU4/HC1 perfect. Is this a bug?
  21. I think this is the First version of this board, please use the official release for this https://github.com/armbian/community/releases/ if it doesn't work https://forum.armbian.com/topic/28895-efforts-to-develop-firmware-for-h96-max-v56-rk3566-8g64g/#findComment-183131 ask @Evgenii Egorenko
  22. @shexplorer here are the first 10MB of the internal emmc. Extracted with dd if=/dev/mmcblk1 count=10 bs=1M | gzip > x88pro13_first_10MB_of_mmcblk.gz. please unzip first. see also the solutuion of this page: x88pro13_first_10MB_of_mmcblk1.gz
  23. @user03 Given that you now have a working uboot installed on the emmc, I'm 95% confident that following the standard instructions will let you move your SD card install to emmc. But there are no guarantees.
  24. You can set conditions on which branch uses which uboot. Like this: https://github.com/armbian/build/blob/9aa6e1e29ec2d397bbe223bebaa93bd13ef79818/config/boards/orangepi5-max.csc#L21 If the BRANCH is edge, then use mainline uboot, specifically this tag.
  25. Good afternoon. I have a Rockchip 3566 tablet.oscal pad 70 wifi Is it possible to install Armbian on it? I don't have a device tree (I couldn't find anything at all for the WiFi module except the test report), no drivers, nothing. I've found a related one (the letters at the end are slightly different), but there's a little information. The original Pineta B2 costs 159, plus shipping and taxes...that's 300. But the aforementioned one costs 100 and doesn't require taxes! That's what got me thinking. Prices are in dollars. The bootloader can apparently be unlocked with a simple command (according to Google Assistant!) I need the tablet for learning Linux and watching videos in the browser...will it handle it? Is this even possible for a beginner? Best regards and gratitude... I'm writing using Google Translate, so there may be some inaccuracies... I apologize for that! motherboard R863T-RK3566-DK-V1.0 wifi module wxt42j1001s I don't know what kind of touchscreen and display it has. Will I need to unlock the bootloader? I understand it's probably very difficult...isn't the processor too old for our times? Or is installing Armbian probably not an option, and shouldn't I waste my time on it and buy something else? Thanks from the bottom of my heart to everyone who responded.
  26. It looks like mksclient is python code can be patched. Sovol3D forum Enable LED light toggle in Mainsail I followed the steps and was able to get an LED toggle in Mainsail on my SV06 Ace I did loose the touchscreen control of the LED but that's acceptable. I only need the LED when using the Camera to check for Failed prints and previously left the LED on during printing. Now I can save a little electricity😀. To me this also has pertinent implications to the thread. mksclient must be a python blob that can runs on boot. If were willing to tolerate the "black box" close source nature of mksclient, a touch screen supporting build, targeting the OEM electronics, should be possible.
  27. Armbian 25.11.2 Noble XFCE (BSP Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + Box64 arm64 v0.4.1 3ec5de03c (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + dgVoodoo2 (https://github.com/dege-diosg/dgVoodoo2/releases) + DXVK-stripped v1.6.1 15~60fps@720p box64 environment variables: FF13 Lightning Returns
