How you can help test upcoming Armbian 26.05 images?
Igor replied to Igor's topic in Advanced users - Development
Tested: - Odroid C4 / HC4 - Tinkerboard - Odroid XU4 - Rockpi E - Today
Hi, I'm using it at the moment as a containers server, thanks for link. I not that changing kernel may run in trouble, so I still keep the 6.1.115 and wait for update. Thanks for your help Regards
Hi there, I recently upgraded my Orange Pi 5 Plus to "Armbian 26.5.1" and noticed in the MOTD (on logins) that it is still showing version "26.2.1". I found differences in this 2 files, and the latter is the one used as reference for MOTD: cat /etc/os-release: PRETTY_NAME="Armbian 26.5.1 trixie" NAME="Debian GNU/Linux" VERSION_ID="13" VERSION="13 (trixie)" VERSION_CODENAME=trixie DEBIAN_VERSION_FULL=13.5 ID=debian HOME_URL="https://www.armbian.com" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" ARMBIAN_PRETTY_NAME="Armbian 26.5.1 trixie" cat /etc/armbian-release: # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi5-plus BOARD_NAME="Orange Pi 5 Plus" BOARDFAMILY=rockchip-rk3588 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=77f919f6c LINUXFAMILY=rockchip64 ARCH=arm64 BOOT_SOC=rk3588 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image KERNEL_TARGET=current,edge,vendor KERNEL_TEST_TARGET=vendor,current FORCE_BOOTSCRIPT_UPDATE= FORCE_UBOOT_UPDATE= OVERLAY_DIR="/boot/dtb/rockchip/overlay" VENDOR="Armbian" VENDORCOLOR="247;16;0" VENDORDOCS="https://docs.armbian.com" VENDORURL="https://www.armbian.com" VENDORSUPPORT="https://forum.armbian.com" VENDORBUGS="https://www.armbian.com/bugs" BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" VERSION=26.2.1 REVISION=26.2.1 BRANCH=edge Can somebody explain why armbian-release doesn't get properly updated? I belive this is not the first time I see this, I recall seeing this behaviour from previuos upgrades too. Thanks!
These Chinese people are very creative. I never imagined seeing a TV box with a SATA port. @Astlin You will need to interact with the .dts file to build a .dtb file with this capability. Before taking any action, check if your board is not from this other JP-Box project. https://github.com/armbian/build/blob/main/patch/kernel/archive/rockchip64-7.1/dt/rk3566-jp-tvbox.dts The topic you should interact with is this one here: https://forum.armbian.com/topic/31887-jianpian-rk3566-tv-box-8g32g-develop-log/#comment-175700 I don't actually have access to the JP-box @Astlin. If you are using the H96 max RK3566 firmware, the SATA port may not be enabled, but you can enable kernel changes within the Armbian compilation menu and insert your changes into the board's DTS file. https://github.com/armbian/build/blob/main/patch/kernel/archive/rockchip64-7.1/dt/rk3566-h96-tvbox.dts I believe the person responsible for this sign is @tdleiyao @ning have tested our DTB file on JianPian device https://github.com/armbian/build/blob/main/config/boards/jp-tvbox-3566.tvb If you have time, we can update the JP-box project in the correct topic. https://forum.armbian.com/topic/31887-jianpian-rk3566-tv-box-8g32g-develop-log/#comment-175700 I have maintained a sample repository with the necessary data to enable RK3566 cards in Armbian. https://github.com/hqnicolas/ArmBoardBringUp The reason JP-box isn't working is that it was enabled in kernel 6.6, and we're already on 7.1, nobody updates this since then. You can use the H96 modifications as start point. this modifications apply to the JP-box, but some functions, such as the SATA port, require customization. -
OK, good that you see the higher voltage selected. I have also seen it, but was on a NanoPi-R6C, although it did not work with RPi5 27W PSU, but OK with HP tablet 45W PSU. The rest is then a matter of kernel and DTB. My ROCK5B runs fine with rolling release/latest Linux kernels (Debian Sid, Opensuse Tumbleweed), currently 7.0.10 version. Don't know about NixOS (on aarch64), but maybe first get some basic stability with standard Armbian Trixie image (mainline based). It gets tricky when you mix vendor and mainline/distro based. Also vendor (6.1.115) can show various issues if you try/use various external HW. Like an mt9721u USB stick of mine causes a failure in paging on ROCK3A, so need reboot, then it works, but don't know for how long (weeks or months)
Yes, true. Meaning dirty spi Yes and no. If SPI is detected and valid it is used. However if this one detects a microsd card with a boot loader it will chain-load this one to ultimately load the os from microsd. Having mixups between vendor and mainline u-boot and/or mixed blobs (like ddr training) this will much likely cause issues.
The solution I've found is to use a HDMI to VGA converter and use the VGA port
@Sancho perfect. I will try it out and will inform you later. I have also discovered that the power adaptors packed with the iSG Box are low quality and some of those can't even reach 1,5 A. Which can cause instability issues and failed HA updates, install, armbian crashes, etc. -
aliexpress.com/item/1005011593571835.html Teclast P50Ai which should be almost identical T60 AI now lurks at a price of 68 euro shipped in EU for some time. aliexpress.com/item/1005011827691576.html Telcast T60Ai comes at around 120 euro shipped in EU. I note that these may be last units of a production batch. As far as I can see, https://github.com/jonas5/orangepi-4pro-armbian may be the hope for newer kernel with GPU acceleration. - Last week
Hi @sven-ola thank you so much for the detailed and thoughtful response — and for taking the time to actually try it yourself! The DKMS approach makes perfect sense; it's clean, survives kernel updates automatically, and fits right in with what's already working on the board for bcmdhd. I'll follow your instructions for b2c2-flexcop-usb. Really appreciate the effort you put into this! 🙏
Thanks for sharing the header file. I have downloaded that and deployed using dpkg -i <packge name> In order to deploy the VFD, the steps I have followed are given here. I have enclosed the attachment that contains commands and their outcome to keep this post shorter. Below given error message while trying to start the openvfd.service root@x98h:~/linux_openvfd#systemctl daemon-reload root@x98h:~/linux_openvfd# systemctl start openvfd.service Job for openvfd.service failed because the control process exited with error code. See "systemctl status openvfd.service" and "journalctl -xeu openvfd.service" for details. root@x98h:~/linux_openvfd# systemctl status openvfd.service × openvfd.service - openvfd Loaded: loaded (/etc/systemd/system/openvfd.service; disabled; preset: ena> Active: failed (Result: exit-code) since Tue 2026-06-02 00:07:40 IST; 4min> Process: 2297 ExecStartPre=/usr/bin/sh -c . /etc/openvfd.conf; /usr/sbin/mo> Process: 2299 ExecStopPost=/usr/sbin/rmmod openvfd (code=exited, status=1/F> CPU: 47ms Jun 02 00:07:40 x98h systemd[1]: Starting openvfd.service - openvfd... Jun 02 00:07:40 x98h sh[2298]: modprobe: ERROR: could not insert 'openvfd': Exe> Jun 02 00:07:40 x98h systemd[1]: openvfd.service: Control process exited, code=> Jun 02 00:07:40 x98h rmmod[2299]: rmmod: ERROR: Module openvfd is not currently> Jun 02 00:07:40 x98h systemd[1]: openvfd.service: Failed with result 'exit-code> Jun 02 00:07:40 x98h systemd[1]: Failed to start openvfd.service - openvfd. Jun 02 00:07:40 x98h systemd[1]: Failed to start openvfd.service - openvfd. ░░ Subject: A start job for unit openvfd.service has failed ░░ Defined-By: systemd ░░ Support: https://www.debian.org/support ░░ ░░ A start job for unit openvfd.service has finished with a failure. ░░ ░░ The job identifier is 782 and the job result is failed. Jun 02 00:15:18 x98h systemd[1]: Starting openvfd.service - openvfd... ░░ Subject: A start job for unit openvfd.service has begun execution ░░ Defined-By: systemd ░░ Support: https://www.debian.org/support ░░ ░░ A start job for unit openvfd.service has begun execution. ░░ ░░ The job identifier is 855. Jun 02 00:15:18 x98h sh[2317]: modprobe: ERROR: could not insert 'openvfd': Exec format error Jun 02 00:15:18 x98h systemd[1]: openvfd.service: Control process exited, code=exited, status=1/FAILURE ░░ Subject: Unit process exited ░░ Defined-By: systemd ░░ Support: https://www.debian.org/support ░░ ░░ An ExecStartPre= process belonging to unit openvfd.service has exited. ░░ ░░ The process' exit code is 'exited' and its exit status is 1. Jun 02 00:15:18 x98h rmmod[2318]: rmmod: ERROR: Module openvfd is not currently loaded Jun 02 00:15:18 x98h systemd[1]: openvfd.service: Failed with result 'exit-code'. ░░ Subject: Unit failed ░░ Defined-By: systemd ░░ Support: https://www.debian.org/support ░░ ░░ The unit openvfd.service has entered the 'failed' state with result 'exit-code'. Jun 02 00:15:18 x98h systemd[1]: Failed to start openvfd.service - openvfd. ░░ Subject: A start job for unit openvfd.service has failed ░░ Defined-By: systemd ░░ Support: https://www.debian.org/support ░░ ░░ A start job for unit openvfd.service has finished with a failure. ░░ ░░ The job identifier is 855 and the job result is failed. VFD_Service_Logs.txt
Orange Pi 5B subforum has recurring threads about eMMC boot loops, WiFi/Bluetooth regressions on mainline kernels, and the general "what image actually works on this thing" question. Joshua-Riek's ubuntu-rockchip was a common answer to that for a long time, but it was archived recently. This is a personal continuation fork in case it's useful to anyone working through those same issues. What this is: - Fork of Joshua-Riek/ubuntu-rockchip (archived) — same vendor 6.1 kernel base, not mainline - Therefore: onboard WiFi/BT works (no mainline driver regressions), eMMC boots reliably - Scope: Orange Pi 5B + Ubuntu 24.04 (Noble) only. jammy/oracular/plucky suite configs removed. - Single-maintainer hobby project. Best-effort, no SLA. v1.0.0 contents: - Kernel ABI bumped to 6.1.0-1027.27 - Backported CVE-2026-46333 (ssh-keysign-pwn) — upstream commit 31e62c2ebbfd cherry-picked onto noble-security branch - Build-kernel.sh patched for GCC 14+ host compatibility (the 6.1 vendor tree's -Werror defaults conflict with stricter warning-to-error promotion introduced in GCC 14 and inherited by GCC 15)"— the 6.1 vendor tree fails to compile on Ubuntu 24.04+ / Debian Trixie+ hosts due to -Werror promotion. Fix is KCFLAGS=-Wno-error for the kernel proper plus sed-stripping hardcoded -Werror from libbpf, libsubcmd, objtool, and libperf tool Makefiles. Without this, you can't rebuild Joshua's kernel from source on a modern host. - Tested as a daily driver on OPi 5B hardware with reboot loop test, cpu burn. running 4k screensaver. Known limitations (carried over from upstream): - Mali GPU PPA (panfork-mesa) and jjriek/rockchip userspace PPAs are no longer maintained. Frozen at the versions Joshua left them. Not a competitor to Armbian — different scope, different kernel approach. If you're getting clean results with Armbian on your 5B, stick with what works. This is for the case where Armbian's mainline kernel breaks onboard hardware or you specifically need the Joshua-Riek tree. Credit: this is a continuation, not original work. Joshua-Riek did the heavy lifting; LICENSE, NOTICE, and README all credit upstream. Repo: https://github.com/defcom5-rockchip/ubuntu-rockchip Kernel: https://github.com/defcom5-rockchip/linux-rockchip-rk3588 Release: https://github.com/defcom5-rockchip/ubuntu-rockchip/releases/tag/defcom5-v1.0.0 (1.86GB .img.xz + sha256) Peace, defcom5
I was curious and looked into your script, I see parted uses sizes like 32MiB instead of sector numbers I tend to do when using gdisk or fdisk It is only the function write_uboot_platform_ufs() in the image that deals with 512/4k and then it is no issue for Btrfs as this is not related to CPU page-size issues I hinted earlier. So also older kernel is no issue and also RK3576 cannot do e.g. 16k page-size.
Yeah no problem, heading to GitHub. No forum for Ubuntu and you are not covering the 5b so I tried. They will care about solid performance. defcom5
Hello, has anyone figured out how to get the ethernet working? I have only gotten the ethernet port to work with 100mbps.
Efforts to develop firmware for H96 MAX V56 RK3566 4G/32G
usual user replied to Hqnicolas's topic in Rockchip CPU Boxes
The first iteration of mainline kernel driver support has just been posted. So a kernel build with this patch set applied should give a playground for initial experiments. -
Hi, I need help with flashing my tv box or installing it on linux. I would also be happy if you could run an armbian or similar minimal system. I would like to run a website on it at home. I already did it for an old venz v10 for a friend and installed armbian on it and he really liked it, but my couldn't install it with a memory card, the on new box 1. System Information Google Android Tv Box - Android 14 Android Version: 14 (Upside Down Cake) API Level: 34 Android Security Patch Level: 2025-01-01 Rooted Device: No Android ID: 5c4aa62950194797 Build ID: rk3528_box_32-userdebug 14 UTT2.241219.001 eng.hxws.20260124.163421 release-keys Codename: REL Fingerprint: google/blueline/blueline:14/UTT2.241219.001/eng.hxws.20260124.163421:userdebug/release-keys ID: UTT2.241219.001 Incremental: eng.hxws.20260124.163421 Java Runtime Version: Android Runtime 0.9 Java Virtual Machine Version: ART 2.1.0 Java Virtual Machine Heap Size: 128 MB Kernel Architecture: armv7l Kernel Version: 6.1.118 (hxws@PowerEdge-R720-8) (Android 10087095, +pgo, +bolt, +lto, -mlgo, based on clang 17.0.2 of r487747c (https://android.googlesource.com/toolchain/llvm-project d9f89f4d16663d5012e5c09495f3b30ece3d2362), LLD 17.0.2) #124 SMP PREEMPT Wed Jan 21 10:25:12 CST 2026 Tags: release-keys Type: userdebug Google Play Services Version: < None > Huawei Mobile Services Version: OpenSSL 1.1.1 (compatible; BoringSSL) OpenSSL Version: 1.2.13 ZLib Version: 1.2.13 2. Hardware and Processor (CPU/Device) Device Type: TV Manufacturer: Google Model: android_tv_box Brand: google Motherboard: RK3528 Device: blueline Hardware: rk30board Platform: rk3528 Product: blueline Processor: RK3528, 4 cores SoC Model: RockChip RK3528 Core Architecture: 4x ARM Cortex-A53 @ 2016 MHz Instruction Set: 64-bit ARMv8-A (32-bit mode) CPU Version: r0p4 CPU Cores: 4 CPU Clock Range: 408 - 2016 MHz CPU Utilization: 5% Scaler Controller: Interactive Supported ABIs: armeabi-v7a, armeabi Supported 32-bit ABIs: armeabi-v7a, armeabi AES/ASIMD/NEON/PMULL/SHA1/SHA2: Supported 3. Memory and Storage (RAM/Storage) Installed RAM: 2 GB Total Memory: 1920 MB Available Memory: 1221 MB Memory Used: 707 MB (36% of 1.9 GB) Total Internal Storage: 11.00 GB Free Internal storage: 10.11 GB Storage usage: 914 MB (8% of 11 GB) 4. Display and GPU (Display) Display: 1920 x 1080 (Full HD, 16:9) Screen resolution: 1920 x 1080 xdpi / ydpi: 320 / 320 dpi GPU manufacturer: ARM GPU renderer: Mali-450 MP Refresh rate: 60 Hz Default orientation: Landscape OpenGL ES version: 2.0 GPU version: OpenGL ES 2.0 OpenGL ES extensions: (List: GL_EXT_debug_marker, GL_OES_texture_npot, GL_OES_vertex_array_object, GL_OES_compressed_ETC1_RGB8_texture, GL_EXT_compressed_ETC1_RGB8_sub_texture, GL_OES_standard_derivatives, GL_OES_EGL_image, GL_OES_depth24, GL_ARM_rgba8, GL_ARM_mali_shader_binary, GL_OES_depth_texture, GL_OES_packed_depth_stencil, GL_EXT_texture_format_BGRA8888, GL_OES_vertex_half_float, GL_EXT_blend_minmax, GL_OES_EGL_image_external, GL_OES_EGL_sync, GL_OES_rgb8_rgba8, GL_EXT_discards_framebuffer, GL_OES_get_program_binary, GL_ARM_mali_program_binary, GL_EXT_shader_texture_lod) 5. Network and Connections (Network/Bluetooth/USB) Network: WiFi Telephony: None Wi-Fi Status: Enabled SSID: BSSID: 02:00:00:00:00:00 Hidden SSID: No IPv4 Address: 192.168.1.35 IPv6 Address: fe80::5ef3:83b1:27d0:574a Signal Strength: -46 dBm (Excellent) Link Speed: 54 Mbps Frequency: 2427 MHz Gateway: 192.168.1.254 Netmask: 255.255.255.0 DNS1: 192.168.1.254 DHCP Lease Time: 24 hours 5 GHz Band: Supported Wi-Fi Aware: Not Supported Wi-Fi Direct: Supported Bluetooth: Enabled Bluetooth Version: 4+ USB Device - Linux 6.1.118 ehci_hcd EHCI Host Controller: (Serial Number: ff100000.usb, ID: 1D6B-0002, Class: 09/00, Speed: 480 Mbps) USB Device - Linux 6.1.118 xhci_hcd xHCI Host Controller: (Serial Number: xhci-hcd.4.auto, ID: 1D6B-0002, Class: 09/00, Speed: 480 Mbps) USB Device - YICHIP Wireless Device 6. Other Data Audio: HDMI 7.1 Codecs: Widevine L3 (SD only) Wireless Debugging: Enabled IP Address and Port: 192.168.1.35:40729 Wi-Fi pairing code: 642947 IP address and port (for pairing): 192.168.1.35:40035 Device features: (List: android.hardware.audio.output, android.hardware.bluetooth, android.hardware.bluetooth_le, android.hardware.camera, android.hardware.camera.any, android.hardware.camera.external, android.hardware.camera.front, android.hardware.cetherandroid.hdware.mi android.hardware.keystore.app_attest_key, android.hardware.location, android.hardware.location.network)
Thank you @Revellion I just did ``` sudo apt-mark unhold armbian-firmware sudo rm -rf /lib/firmware/qcom/sm8550/ayn/ sudo apt update && sudo apt upgrade ``` and it worked fine
I just ran into the same issue on a FriendlyARM RK3588. Wanted to swap it out with FriendlyWRT to turn it into a router, but now only Armbian SD cards boot. Even after a vendor supported 'factory reset' process via USB. While it may not be intended to be a lock down and just due to poor testing/planning/silo effect, this is really uncool and should either be fixed or a better way to back out than having to manually pull pieces out and DD them over..
Welcome to the latest Armbian Newsletter: your source for the latest developments, community highlights, and behind-the-scenes updates from the world of open-source ARM and RISC-V computing. Armbian v26.5.1 delivers another strong round of improvements across the project, focusing on expanded hardware support, desktop and userland refinements, build framework modernization, and infrastructure enhancements. This release introduces new board images and platform updates, improves Ubuntu 26.04 "Resolute" integration, refines Bianbu desktop support, adds firmware and driver updates including AX210 wireless support, and continues ongoing work to strengthen the build system, CI pipelines, and developer tooling. Numerous kernel, bootloader, and device tree updates further improve stability, compatibility, and performance across a wide range of ARM and x86 platforms, reinforcing Armbian's commitment to providing a reliable and flexible Linux distribution for single-board computers, embedded devices, and edge computing deployments. SPONSORED Join us in making open source better! Every donation helps Armbian improve security, performance, and reliability — so everyone can enjoy a solid foundation for their devices. Release Armbian Quarterly digest · armbian/buildThis quarter’s work centers on three priorities: kernel modernization across SoC families, a redesigned desktop subsystem driven by armbian-config, and substantial expansion of board and platform c…GitHubarmbianNative UFS boot lands on the NanoPi M5Armbian’s next release boots the FriendlyElec NanoPi M5 end-to-end from UFS on a mainline U-Boot, with no proprietary recovery image in the loop. It is the first RK3576 board in the catalogue to reach this state, and the integration pattern paves the way for the others. UFS, the storage classArmbian blogDaniele BriguglioWe rewrote how Armbian installs desktops. Here’s what changedA friendlier, faster, snap-free desktop install in armbian-config If you’ve installed a desktop environment with armbian-config over the last few months, you may have noticed things feel different: there’s a tier you can pick, the browser actually works on every arch, uninstall doesn’t take half your system with it, andArmbian blogIgor PecovnikView the full article
