@zcrselfhttps://github.com/NickAlilovic/build/releases/tag/Mainline try this image.
Armbian supports boards, not bare SoCs. This thread is about xt-q8l-v10 rk3288 board, which is supported by community and not officially. If you want official support, prefer a SBC which is declared as officially supported, like the Asus Tinkerboard. Community supported boards are "best effort", officially supported boards are usually checked before new armbian releases to maintain general support and functionality.
GmP replied to Hqnicolas's topic in Rockchip CPU Boxes
@GBEM , Hi are you sure wifi is attached to sdmmc1 ? here is my log: root@h96-tvbox-3566:~# dmesg | grep -i sdio [ 2.961741] mmc2: new UHS-I speed SDR50 SDIO card at address 390b [ 12.974586] aicbsp: aicbsp_sdio_probe:1 vid:0xC8A1 did:0x0082 [ 12.977567] aicbsp: aicbsp_sdio_probe:2 vid:0xC8A1 did:0x0182 [ 12.977586] aicbsp: aicbsp_sdio_probe after replace:1 [ 12.977595] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 150 MHz [ 12.977600] aicbsp: aicwf_sdio_reg_init [ 12.993394] rwnx_load_firmware :firmware path = /lib/firmware/aic8800_fw/SDIO/aic8800D80/fw_patch_table_8800d80_u02.bin [ 13.093862] rwnx_load_firmware :firmware path = /lib/firmware/aic8800_fw/SDIO/aic8800D80/fw_adid_8800d80_u02.bin [ 13.127689] rwnx_load_firmware :firmware path = /lib/firmware/aic8800_fw/SDIO/aic8800D80/fw_patch_8800d80_u02.bin [ 13.143887] rwnx_load_firmware :firmware path = /lib/firmware/aic8800_fw/SDIO/aic8800D80/fw_patch_8800d80_u02_ext0.bin [ 13.400664] rwnx_load_firmware :firmware path = /lib/firmware/aic8800_fw/SDIO/aic8800D80/fmacfw_8800d80_u02.bin [ 14.275914] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 150 MHz [ 14.275939] aicsdio: aicwf_sdio_reg_init [ 14.284873] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 150 MHz [ 14.305375] aicbsp: sdio_err:<aicwf_sdio_bus_pwrctl,1404>: bus down [ 439.182900] aicwf_sdio mmc2:390b:1 wlan0: CLOSE [ 520.391280] aicwf_sdio mmc2:390b:1 wlan0: CLOSE [ 683.043492] aicwf_sdio mmc2:390b:1 wlan0: CLOSE It seems attached to sdmmc2, then in case there is a need a possible device tree could be (73 is 2 B1 as in your file): &sdmmc2 { bus-width = <4>; non-removable; cap-sdio-irq; keep-power-in-suspend; reset-gpios = <&gpio2 9 GPIO_ACTIVE_HIGH>; /* gpio-73 */ status = "okay"; }; -
UPDATE for Multitool Finally I managed to let the Opensource OP-TEE work with the rockchip miniloader! This means that the Multitool should now work on any board, without freezes and booting issues! The new version can be downloaded from the first page of this thread. Please report if it works for you, thanks!
I updated to Armbian 26.2.1 on OPi5, and it can't boot from MTD (rootfs at NVMe), and I have to use SD card to boot to NVMe as workaround. After looking into this issue, I found rkspi_loader.img is no longer available for current (6.18.8 kernel) u-boot pkg and armbian-config flashes u-boot-rockchip-spi.bin ( or similar sata version) to /dev/mtdblock0 and I think this is wrong image for MTD bootloader. If I use older vendor image, which u-boot pkg has rkspi_loader.img, system can boot to NVMe rootfs and I notice that /dev/mtdblock0 has several gpt partitions including u-boot one, and flashing u-boot-rockchip-spi.bin erases partitions in SPI flash. I noticed that several related changes were introduced since 25.11, such as https://github.com/armbian/build/commit/e5b845f9432abb0408287599bba5889a86e6d068 , but I couldn't do quick fix to bring back working rkspi_loader.img because I am not familiar with whole armbian build. One thing to note that if board was flashed with old rkspi_loader.img and not updated with 26.2 MTD image, it still boots to NVMe rootfs, but I have other issues such as video playback not working with 6.18 kernel likely due to mismatch u-boot and kernel version leading to wrong HW initialization. BTW, I checked 26.2 u-boot pkg for Rock 5B (similar rk3588 board), and rkspi_loader.img is still included.
@jock Hi, I have updated the build source for the leds overlay files (leds 6 and 7) for both the the rockchip64 H50 tvbox and the T9 tvbox, for kernels 6.12 (old non scrolling driver) and 6.18 (new scrolling driver) the version for 6.18 is also fine for 6.19. Have a look at my fork in https://github.com/gpaesano/build. Some modifications are just refinements other are functional. I have built all the images and variants on a ubuntu linux and are running well. I am not familiar with pull requests and do not want to be impolite, so If you think there is some added value please support it. All the best @GmP
If anyone is still interested, I have a Helios 64 that I assembled, looked at, but never got around to using for more than a couple hours. Works fine, does not yet have the 2.5GB fix but I have the instructions for same. No idea what to ask for it but it certainly isn't doing me any good sitting on my shelf. Have the manual, SATA drive bay adapters for 2.5" drives and the like. Make me an offer and pay shipping from Oregon. Let's talk!
T9 TvBox Sunwell - Pcb Label T9-RK3328-8x4-V1.8
GmP replied to GmP's topic in TV Boxes running Armbian
https://github.com/armbian/community/releases/download/26.2.0-trunk.385/Armbian_community_26.2.0-trunk.385_Rk3318-box_trixie_current_6.18.8_minimal.img.xz this is the latest console build compatible with T9. You will need to configure a little bit the environment after booting to enable all the features via ssh and wired lan. If the device is still on android the best is to follow the tutorial from @jock in -
Regular changes in file /etc/armbian-leds.conf on ODroid-N2
iav replied to iav's topic in Software, Applications, Userspace
Thank you. I couldn't even think of such a thing. Lord, why is it necessary to preserve the state of indicators that are needed precisely to show the state of something? -
@Nick A No problem. Thanks for your Armbian build as well! I am also looking forward to mainline. Currently I still didn't find open source Mesa driver for Allwinner BSP, GLES is only available as pre-compiled binary for Debian (haven't tested it but it's in the Radxa images). There already are mainline Mesa/Linux IMG GPU supports so I hope things can be ported to mainline soon. Please let me know if anyone finds the source code for Mesa BSP.
The second time I built it, the image deb worked and the bcmdhd dkms loaded. > dkms status bcmdhd-spacemit-sdio/101.10.591.84.37-4, 6.18.9-edge-spacemit, riscv64: installed
Bookworm. But my point was the version 35.1 is what got installed when I ran the scripts in the first post. If the script installed 37 for you because you're on Ubuntu then I probably am on the wrong track. Yes I believe it does this. I was just pointing out that drm_prime works for me but I guess that could just be due to different hardware on the device. I'm not using an Orange Pi.
@Brow Mosh AI is wrong. Mainline supports - Your PMIC - Your DRAM timing - Your HDMI (Patches have been around for years but not accepted in mainline yet. I included it in my builds.) - Your regulators Supported in mainline but might need some dts changes. - Your weird SD wiring - Your eMMC layout ( Could be a gpio# issue) If you are booting into the kernel then I believe your SD is somewhat working. Maybe you need few tweaks to your dts or your DRAM settings are off. A failing or cheap SD card could also be your issue. Kernel boots Reaches userspace Shows login banner Without a DTS I can’t help you much. Also, can you post some boot logs. FEL over USB is your last option. It is possible. But I don't think your AI model will help much. I noticed with some AI models they will encourage you to quit when they can't find the correct information. The owner of the AI model wants you to pay for their deep learning version.
Version 3.1.0 Has been released! I won't be going into details like last time, this build also includes the fixes for "known issues" from version 3 Alpha build. Bugs Found? Open a ticket in https://github.com/Harleythetech/openauto-rk3229-armbian/issues Download: Github: OpenAuto RK322x - oark322x-3.1.0-beta
@marcosdsdba Can you take a picture or just tell us the Wi-Fi chip you have on your board?
I buy a different USB uart Usbuart Maybe I can do what you suggest. I need to wait to the item arrives at my home. When It arrives I post here to the device read uart method. -
I am trying to setup Raxda Display 8 HD with Radxa ROCK 3A. On official Radxa OS, I used Rsetup tool to setup overlay for `Radxa Display 8 HD' using official guide. How can I do same on Dedicated applications images with Armbian Linux v6.12 ( Home Assistant ) ? I have read Device Tree overlays guide on armbian docs but I can't find overlay for lcd display in files:
SuzSinclair replied to jock's topic in Rockchip CPU Boxes
Thanks for the feedback , i have finally downloaded this version and burn into sd card , put in sd card then reconnect power, the system normal boot i cant see armbian screen, the blue light is on, and nothing on screen or dark screen can someone point me please what is happening. -
I now found a workaround, basically adding the following to the top of /boot/boot.cmd setenv usbstoragequirks "0x2537:0x1066:u,0x2537:0x1068:u" and running mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr (as shown at the bottom of /boot/boot.cmd However this is not sustainable, and it would still be preferable if the inclusion of armbianEnv.txt could be fixed, ESPECIALLY considering that the download page https://www.armbian.com/odroid-n2/ gives the following (useless due to this issue) advise: On modern kernels adding “video=HDMI-A-1:1920x1080M@60D” to boot /boot/armbianEnv.txt (extraargs=) should force HDMI to 1080p instead of the 4K native resolution.
Probably because nobody had use for those until today. Feel free to send a PR adding whats missing.
Thanks @Sanjay, are you running Trixie? I was trying new driver (r8152) the other days as well, I tried your approach on a fresh install and still having the same issue (I can write to an OMV share with around 220MB, but reading back crashes the 2.5 interface); as far as I read some additional network & power management settings are needed, just didn’t find the right combination so far. Out of curiosity I dusted off the old SD card that still had my initial setup on buster, booted from it and on the same tests I get around 180MB write and 220MB read without any crash. Will spend some more time on it and if not I’ll just leave it as is, I can use the 1g network with no issue, the nas will not be running 24x7 anyway, it’s just for some backups every now and then. Just that my OCD wants the 2.5 interface to be there as well.
tparys replied to Igor's topic in Advanced users - Development
Update on NanoPi M4v2 ... I pulled the most recent Armbian build, and manually ran the build for the M4v2, and it fails on kernel patch "general-gpio-driver-no-sleep". See pastebin at https://paste.armbian.com/puvorasuco for failed build. Checking upstream at https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git, it looks like branch 6.18.y already has the subject patch, and was pushed today. Since both the rockchip and rockchip64 families use mainline kernel, I just submitted a PR that kills that patch for both. See https://github.com/armbian/build/pull/9368.
