fighting with netplan/networkd/networkmanager
tabrisnet replied to tabrisnet's topic in Software, Applications, Userspace
maybe not a strictly a systemd bug... but a netplan stupidity. root@ratatosk:~# ethtool --show-permaddr eth1 Permanent address: not set https://github.com/systemd/systemd/pull/14448/files <-- PR that created this systemd match feature -
Latest armbian update 25.11 trunk 45 also breaks boot...
Thx for your reply. Yes i tried both together. And just one. No difference. # Enable DRM VC4 V3D driver dtoverlay=vc4-kms-v3d # Enable the Touch Display 2 DSI panel dtoverlay=vc4-kms-dsi-ili9881-7inch
@Piotr sTry this image https://github.com/NickAlilovic/build/releases/download/20250306/Armbian-unofficial_25.05.0-trunk_X96q-lpddr3_bookworm_edge_6.12.11_xfce_desktop.img.xz to fix Ethernet you need to edit this file https://github.com/NickAlilovic/build/blob/v20250306/patch/u-boot/u-boot-h616/159-add-x96-q-lpddr3-v1.3-defconfig.patch. Change 16 to 0. Then compile a new image. +&mdio1 { + rmii_phy: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + }; +}; more information can be found here
Which kernel mod needs to be loaded to get battrey support on cubietruck?
Igor replied to pet's topic in Allwinner sunxi
OS is stable, errors you are experiencing are likely related to faulty HW component as @eselarm already exposed. And we would most likely notice such anomaly before it gets to you. There are thousands of users and this is the only report of this kind ... Boards are going to the market at high rate, while users support remains more or less the same in past 10 years https://docs.armbian.com/User-Guide_Board-Support-Rules/ Community builds and their upgrades are untested as size of Armbian can only cope with a small selection of boards we call as "standard support", where we have volunteers behind. Community builds are on Debian / Arch images level, but packed with more features. https://github.com/armbian/community?tab=readme-ov-file#purpose-of-this-repository For those - Armbian provides build and hosting infrastructure, place to meet - this forum - while everything else is anyone's problem. - Today
@buzz89
@prahal - I tried a number of those images but none worked. With RoobiOS I see that all of the blue lights below the SATA ports (i.e. on the underside of the board) light up as blue for a couple of seconds, then they turn off and then they flash twice ... the screen comes on and after a couple of error messages the Installation GUI starts. With the images from the links you provided, I don't get the blue lights (although I do get a yellow network link light). However ... in RoobiOS I'm given the option of various images to install ... including the option for "custom" - I've selected that and entered https://fi.mirror.armbian.de/incoming/prahal/rock-5-itx/archive/Armbian_25.8.1_Rock-5-itx_bookworm_current_6.12.41_minimal.img.xz This gives a circle (of death?!) and "Loading ..." in RoobiOS but I see there's flashing green light on the ethernet port - which suggests that there's activity so maybe it's just a slow download?
Wifi chip model?
... straightforward and smooth.
2
With linux 6.12 the optimizations in /etc/rc.local do not apply anymore since some configuration options have vanished. So if you like to have a stable 2.5Gbit/s network connection without timeouts, linux-6.6 is still recommended (bookworm and trixie). You can build it yourself using an Armbian snapshot (from Dec. 2024) or download a recent linux-6.6.100 from here.
Try to upload the old and new driver to an AI with you overlay included. Here it gives some suggestions for what you can try. The power sequence seems to be changed with the new driver and it might be too fast for your display. It suggests to put some parameters in the overlay to delay some parts, with higher chance with the first 3: Under "dsi0_panel: panel@0 {" prepare-delay-ms = <120>; reset-delay-ms = <50>; init-delay-ms = <150>; enable-delay-ms = <50>; disable-delay-ms = <50>; unprepare-delay-ms = <120>;
BPI-R4 fails to build, missing bl2 firmware
tabrisnet replied to tabrisnet's topic in Other families
https://github.com/armbian/build/pull/8517 appears to fix my SFP problems. -
Ryzer replied to schunckt's topic in Allwinner sunxi
@schunckt Yes, I should have clarified that drm-copy is an argument is for MPV, which according to the guide mentioned above should allow the frame-buffer to be accessed directly. It is worth noting that mpv makes use of ffmpeg under the hood. Tried with ffplay once but did not have much luck with it. last I checked VLC is not supported other than the legacy vaapi. Please see: https://linux-sunxi.org/Sunxi-Cedrus You can use the sample media from linaro: https://samplemedia.linaro.org/ Just to check are you using the ffmpeg-v4l2-request? -
multiple system error messages after latest kernel update
bhouseski replied to bhouseski's topic in Radxa Rock 5B
v25.8.1 for Rock 5B Plus running Armbian Linux 6.1.115-vendor-rk35xx -
That's exactly what I did. I wrote a replacement for the .not_logged_in_yet file in my customize-image.sh with pre-set parameters, just like I create /root/provisioning.sh. I was just wondering if there were any other ways to do this.
Device: Orange Pi 5 Plus DE: KDE-Neon Kernel: 6.1.115-vendor-rk35xx Last Friday, reported after updating KDE-Neon, it no longer boot up to KDE Plasma desktop successfully. After today's system update (using tty), reboot and it boot up successfully to KDE Plasma desktop.
vaapi on Rock5C: rockchip_drv_video.so missing
Tuxifan WasAuchImmer replied to Tuxifan WasAuchImmer's topic in Beginners
Hey, thanks for the reply. So there's actually no VAAPI driver available? Just OpenCL? Also, what is the recommended image for this? -
https://github.com/armbian/build/pull/8447#issuecomment-3195333910
Thiên Thư Lục replied to jock's topic in Rockchip CPU Boxes
@jock @MattWestB thank you for you help! Sorry for the late reply. Im did update the dtb files jock said, and usb 3.0 work better now, but not as stable as 100%. Sometimes it still hang on reboot unless i disconnect the device on usb 3.0 port and re-insert power for complete reboot and booting, and sometimes it boot without recognise the device on usb 3.0 port. And sometimes the WiFi drop connection and reconnect repeatedly many times without dmesg errors, and need manual reboot. So maybe im just unlucky getting the bad batch of H96 Max. Due to the needed of stability, especially with the usb port, i switching to Dell Wyse 3040 for now. It's was fun playing with armbian and rockchip. Thank you for your contribution @jock 🥰
