OK, as I thought, not enough 'headroom' rock5b:/local/ssdata/nocow # btrfs inspect-internal list-chunks 2 btrfs inspect-internal list-chunks 2 Devid PNumber Type/profile PStart Length PEnd LNumber LStart Usage% ----- ------- ----------------- -------- --------- -------- ------- -------- ------ 1 1 System/single 1.00MiB 4.00MiB 5.00MiB 4 2.30GiB 0.39 1 2 Metadata/single 5.00MiB 8.00MiB 13.00MiB 1 5.00MiB 35.74 1 3 Data/single 13.00MiB 8.00MiB 21.00MiB 2 13.00MiB 100.00 1 4 Data/single 21.00MiB 1.00GiB 1.02GiB 3 21.00MiB 53.20 1 5 Metadata/single 1.02GiB 208.00MiB 1.22GiB 5 2.31GiB 23.51 1 6 Data/single 1.22GiB 512.00MiB 1.72GiB 6 2.51GiB 84.35 1 7 Data/single 1.72GiB 512.00MiB 2.22GiB 7 3.01GiB 86.48 1 8 Metadata/single 2.22GiB 256.00MiB 2.47GiB 8 3.51GiB 33.67 1 9 Metadata/single 2.47GiB 256.00MiB 2.72GiB 9 3.76GiB 14.43 1 10 Data/single 2.72GiB 1.00GiB 3.72GiB 10 4.01GiB 83.88 1 11 Data/single 3.72GiB 1.00GiB 4.72GiB 11 5.01GiB 97.23 1 12 Data/single 4.72GiB 1.00GiB 5.72GiB 12 6.01GiB 55.02 1 13 Data/single 5.72GiB 1.00GiB 6.72GiB 13 7.01GiB 85.21 1 14 Data/single 6.72GiB 1.00GiB 7.72GiB 14 8.01GiB 58.04 1 15 Data/single 7.72GiB 1.00GiB 8.72GiB 15 9.01GiB 82.03 1 16 Data/single 8.72GiB 1.00GiB 9.72GiB 16 10.01GiB 28.15 1 17 Metadata/single 9.72GiB 256.00MiB 9.97GiB 17 11.01GiB 10.30 1 18 Data/single 9.97GiB 1.00GiB 10.97GiB 18 11.26GiB 99.83 1 19 Metadata/single 10.97GiB 256.00MiB 11.22GiB 19 12.26GiB 0.58 1 20 Metadata/single 11.22GiB 256.00MiB 11.47GiB 20 12.51GiB 5.22 1 21 Metadata/single 11.47GiB 256.00MiB 11.72GiB 21 12.76GiB 0.49 1 22 Metadata/single 11.72GiB 256.00MiB 11.97GiB 22 13.01GiB 0.27 1 23 Metadata/single 11.97GiB 27.00MiB 12.00GiB 23 13.26GiB 0.06 Then doing various balance actions, then again replace action, see result below: [334356.515225] [ T207531] BTRFS info (device loop0p2): balance: start -mlimit=3 -slimit=3 [334356.516261] [ T207531] BTRFS info (device loop0p2): relocating block group 14236516352 flags metadata [334356.608520] [ T207531] BTRFS info (device loop0p2): found 1 extents, stage: move data extents [334356.655369] [ T207531] BTRFS info (device loop0p2): relocating block group 13968080896 flags metadata [334356.882397] [ T207531] BTRFS info (device loop0p2): found 44 extents, stage: move data extents [334356.974962] [ T207531] BTRFS info (device loop0p2): relocating block group 13699645440 flags metadata [334357.145812] [ T207531] BTRFS info (device loop0p2): found 77 extents, stage: move data extents [334357.223337] [ T207531] BTRFS info (device loop0p2): balance: ended with status: 0 [334402.346978] [ T207580] BTRFS info (device loop0p2): balance: start -mlimit=6 -slimit=6 [334402.347912] [ T207580] BTRFS info (device loop0p2): relocating block group 13431209984 flags metadata [334403.120645] [ T207580] BTRFS info (device loop0p2): found 841 extents, stage: move data extents [334403.372968] [ T207580] BTRFS info (device loop0p2): relocating block group 13162774528 flags metadata [334403.613848] [ T207580] BTRFS info (device loop0p2): found 94 extents, stage: move data extents [334403.743610] [ T207580] BTRFS info (device loop0p2): relocating block group 11820597248 flags metadata [334404.526435] [ T207580] BTRFS info (device loop0p2): found 1666 extents, stage: move data extents [334404.798554] [ T207580] BTRFS info (device loop0p2): relocating block group 4035969024 flags metadata [334406.059117] [ T207580] BTRFS info (device loop0p2): found 2363 extents, stage: move data extents [334406.374011] [ T207580] BTRFS info (device loop0p2): relocating block group 3767533568 flags metadata [334407.879438] [ T207580] BTRFS info (device loop0p2): found 5433 extents, stage: move data extents [334408.284506] [ T207580] BTRFS info (device loop0p2): relocating block group 2475687936 flags metadata [334413.884083] [ T207580] BTRFS info (device loop0p2): found 9463 extents, stage: move data extents [334414.690177] [ T207580] BTRFS info (device loop0p2): balance: ended with status: 0 [334530.694011] [ T207693] BTRFS info (device loop0p2): balance: start -dlimit=2 [334530.694839] [ T207693] BTRFS info (device loop0p2): relocating block group 12089032704 flags data [334534.205097] [ T207693] BTRFS info (device loop0p2): found 1897 extents, stage: move data extents [334534.491352] [ T207693] BTRFS info (device loop0p2): found 1897 extents, stage: update data pointers [334534.625126] [ T207693] BTRFS info (device loop0p2): relocating block group 10746855424 flags data [334536.605759] [ T207693] BTRFS info (device loop0p2): found 16316 extents, stage: move data extents [334537.056028] [ T207693] BTRFS info (device loop0p2): found 16316 extents, stage: update data pointers [334537.361629] [ T207693] BTRFS info (device loop0p2): balance: ended with status: 0 [334614.951029] [ T207803] BTRFS info (device loop0p2): dev_replace from /dev/loop0p2 (devid 1) to /dev/loop1p2 started [334654.572435] [ T207803] BTRFS info (device loop0p2): dev_replace from /dev/loop0p2 (devid 1) to /dev/loop1p2 finished So vendor I would need to do the same with vendor kernel on same images, I made exact copies, so can be done, however starting with vendor kernel requires system reboot (and other bootloader), so not sure when I can do this.
sorry for the typo, it is Kernel 6.12.30 that still doesn't support usb
Minh Tiến Nguyễn replied to Minh Tiến Nguyễn's topic in Allwinner sunxi
Sorry for late reply Currently i only use this display to show content which already in the board The touch is not so reliable and it seem with the same config it still not working the same for each flash new image, i still need to change the touch matrix value. But for now i think i can accept it Actually I now wonder that maybe color is reversed because of speed of SPI. Because when i set in init command 0x1000036 0x08 or 0x48 or 0x28 it already have BGR bit 3 (as i share the image in document above. ) is 1. Also can i ask you about How to build armbian image for this board Orange pi zero 2w, i want to improve security for this project, so i want to have configure more about init boot, kernel, ... I heard someone use buildroot, someone use https://github.com/orangepi-xunlong/orangepi-build in here for H616, someone use OS Manjiro..., Have you ever try one, which do you suggest most ? - Yesterday
@KrzyPacu it seems there is an issue with your kernel source code (or minimal headers). Ensure to install kernel headers for your distribution/version first If it still doesn't point to your headers/source path, you can pass it as a variable when executing make. Something like: sudo make module-install KDIR=/path/to/your/headers/build -
It is Allwinner H618, Quad-core ARM Cortex™-A53 processor. Yes it is external USB network card, which I used just to be able to send logs made via armbianmonitor to the internet. The state You see in the logs is just latest stage of many different attempts: with custom overlays and/or fixes on the sun50i-h618-bananapi-m4-zero.dtb (decompile, fix, compile, boot). In addition have tried some patches using H616 files. I also found problem is due to, PHY isn't properly powered on, based on topic: https://github.com/armbian/build/pull/6617 but after plenty of tries didnt manage to make it work ;(
Hello everyone, I'm currently working on a custom firmware project for the Allwinner V851S/V851SS SoC (e.g., dash cam or smart camera). I've reached the stage where I need to modify and re-sign the firmware images (TOC0/TOC1) for use with tools like PhoenixCard. Unfortunately, the tools found on GitHub (e.g., dragonsecboot, pack_tools, boot0, etc.) are often incomplete or fail to build due to missing references (e.g., rsa_sign_main, GetFullPath, etc.). 🔍 I'm looking for a complete and working version of the following tools: dragonsecboot pack boot0 sunxi_tools Full config files such as dragon_toc.cfg, sys_config.fex Working pack_tools with all required source files Full Tina SDK for V851S or V851SS 🎯 My goal is to properly sign and rebuild TOC0/TOC1 and PACKAGE images, and build a customized embedded Linux system. 📤 If anyone has the official SDK or a working toolchain, I’d really appreciate it if you could share it via Google Drive, Mega, Transfer.sh, or any other file host. Thank you in advance to anyone who can help 🙏
It sounds like you're in a tough spot with your x88 box, but there are definitely a few things you can try to unbrick it. Check Power Supply: As you mentioned, the power supply might be outputting 13V, which is not ideal. It's crucial to have a stable 5V supply for the device to boot properly. If you can, try using a different power adapter (5V, 2A) and see if that helps stabilize the boot process. Use a Correct Recovery Image: Make sure you're using the correct image for the box. It seems like you were trying to burn the image directly, but if the process was interrupted, it could leave your internal storage in an inconsistent state. Try downloading the official firmware for your box model from the manufacturer's site (if available) or from trusted forums where users with similar devices share their files. Try the USB Burning Tool: Some boxes like this one can be recovered using a tool like the USB Burning Tool (if it's based on Rockchip). You can try flashing the firmware through USB using the tool while the box is in recovery mode. Here’s a general approach: Download and install the USB Burning Tool. Put your box into MaskROM Mode (this usually involves shorting specific pins or pressing a button while plugging the box into your computer via USB). Connect your device to the PC and use the USB Burning Tool to flash the firmware. Serial Console Output: If you're comfortable with it, connecting a serial console to the box can give you a lot of insight into where things are failing. This could help identify whether it's a hardware or software issue. The serial output could give you error messages that could point to a specific issue (e.g., faulty bootloader or file system corruption). SD Card Recovery: If you can't get it to boot from the internal flash, continue using the SD card with a stable Armbian image. If the internal storage is corrupt, you might still be able to boot and recover your box through the SD card by reinstalling the firmware on the internal storage via the system running off the SD card. If you haven't already, you could also try reaching out to the manufacturer or seller for support, as they might be able to help you with the recovery process. But if that’s not an option, digging into the serial console is definitely your best bet. Good luck! Hopefully, you'll be able to get your device back up and running soon.
Good day, respected Balbes150. Please advise an Armbian build for the Roc-rk3588s-pc v1.1, with support for an M.2 NVMe SSD, intended to be used as a "smart home" server. The image will be installed on an SD card. The single-board computer is connected to the home router via Ethernet cable. HDMI is only used temporarily to connect to a TV for initial setup (further configuration will be done via SSH). The board will run Docker containers. Thank you so much in advance!
Truenox replied to Truenox's topic in Radxa Rock Pi S
Hello, Any update of this? -
They will provide you new drivers only if you will pay them to do that for you. End users, including this project, can do nothing about - we have negative budget and can only do best-effort work to keep those drivers at least operational with recent kernels: https://github.com/armbian/build/tree/main/patch/misc while bulk of the patches goes directly to the Git of specific driver. What you are hoping exceeds ability of amateur maintainers, those few people that are actually looking into the code and fix bugs that are made by kernel API changes. HW vendor is usually long gone from there - their development capacity is also limited and they are focused into current products. FYI -
A10 / A20 hdmi support was reported as broken and bug was recorded https://armbian.atlassian.net/browse/AR-2674 some time ago. -
there are a few caveats that may need a bit of attention It is documented somewhere that if you use channel 0, the driver would automatically select an appropriate channel / frequency. However, it seemed that back then initially while I tested it, that didn't seem to work. (i'm not sure if it may have changed) hence to list the channels one needs to run iw list and you would get a list of channels like such * 2412 MHz [1] (20.0 dBm) * 2417 MHz [2] (20.0 dBm) * 2422 MHz [3] (20.0 dBm) * 2427 MHz [4] (20.0 dBm) * 2432 MHz [5] (20.0 dBm) * 2437 MHz [6] (20.0 dBm) * 2442 MHz [7] (20.0 dBm) * 2447 MHz [8] (20.0 dBm) * 2452 MHz [9] (20.0 dBm) * 2457 MHz [10] (20.0 dBm) * 2462 MHz [11] (20.0 dBm) * 2467 MHz [12] (20.0 dBm) * 2472 MHz [13] (20.0 dBm) * 2484 MHz [14] (20.0 dBm) * 5170 MHz [34] (disabled) * 5180 MHz [36] (20.0 dBm) * 5200 MHz [40] (20.0 dBm) * 5220 MHz [44] (20.0 dBm) * 5240 MHz [48] (20.0 dBm) * 5260 MHz [52] (20.0 dBm) (radar detection) * 5280 MHz [56] (20.0 dBm) (radar detection) ... * 5720 MHz [144] (20.0 dBm) (radar detection) * 5745 MHz [149] (20.0 dBm) * 5765 MHz [153] (20.0 dBm) * 5785 MHz [157] (20.0 dBm) * 5805 MHz [161] (20.0 dBm) * 5825 MHz [165] (20.0 dBm) what I normally do is to do a scan and pick an unused / least used channel : iw wlan0 scan pick an appropriate channel and specify it in hostapd.conf. 5ghz channels (hw_mode=a) delivers a max throughput of like 140 Mbps which is fast. https://docs.armbian.com/WifiPerformance/#uwe-5622 accordingly there are some country specific requirements for 5ghz channel selections and one may like review https://en.wikipedia.org/wiki/List_of_WLAN_channels iw reg set etc I did a google search and some of these resources may be useful https://wiki.archlinux.org/title/NetworkManager https://www.baeldung.com/linux/nmcli-wap-sharing-internet in a same way you may need to set the channel if necessary then that this repo is found in a google search which may be useful https://github.com/pi-top/Wi-Fi-Access-Point-and-Station-Mode/tree/master
I'm trying to compile an LED display driver: https://github.com/arthur-liberman/linux_openvfd I follow this description: https://github.com/bk3a12/openvfd_enable_for_tx3_mini However, I can't build anything and the whole process ends with errors: sh ./scripts/modules-check.sh /home/user/INSTALKI/linux_openvfd/driver/modules.order make -f ./scripts/Makefile.modpost make[3]: *** No rules to make an object '/home/user/INSTALKI/linux_openvfd/driver/modules.order', required by '/home/user/INSTALKI/linux_openvfd/driver/Module.symvers'. Stop. make[2]: *** [/usr/src/linux-headers-6.12.33-current-meson64/Makefile:1897: modpost] Error 2 make[1]: *** [Makefile:224: __sub-make] Error 2 make[1]: Leaving the directory '/usr/src/linux-headers-6.12.33-current-meson64' make: *** [Makefile:5: modules] Error 2
@werner Sorry the delay, I was trying to get the TTL adapter. Here is what I get from the TTL in the first boot after flashing Armbian_community_25.8.0-trunk.228_Orangepi5pro_bookworm_vendor_6.1.115_minimal.img DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18 ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 ch0 ttot7 LPDDR5, 2400MHz channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch1 ttot7 channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch2 ttot7 channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch3 ttot7 channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB Manufacturer ID:0xff DQS rds:l0,l0 CH0 RX Vref:27.1%, TX Vref:20.0%,20.0% DQ rds:h3 h4 h2 h1 h5 h2 h2 h1, h1 h3 h3 h5 h1 h3 h2 h2 DQS rds:l0,h1 CH1 RX Vref:27.9%, TX Vref:21.0%,20.0% DQ rds:l0 h1 h2 h3 h6 h2 h3 h6, h4 h2 h2 h2 h2 h1 h4 l0 DQS rds:l0,l0 CH2 RX Vref:26.7%, TX Vref:19.0%,21.0% DQ rds:h3 l0 l0 l0 h4 h1 h7 h3, h2 l0 h1 l0 h2 h4 h1 h1 DQS rds:l0,h1 CH3 RX Vref:27.9%, TX Vref:20.0%,20.0% DQ rds:h5 h3 h7 h4 h2 h2 h4 h4, h4 h3 h4 h2 h3 h1 h3 h1 stride=0x2, ddr_config=0x6 hash ch_mask0-1 0x20 0x40, bank_mask0-3 0x0 0x2400 0x44800 0x89000, rank_mask0 0 x2000 change to F1: 534MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F2: 1320MHz ch0 ttot8 ch1 ttot8 ch2 ttot8 ch3 ttot8 change to F3: 1968MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F0: 2400MHz ch0 ttot7 ch1 ttot7 ch2 ttot7 ch3 ttot7 out U-Boot SPL board init U-Boot SPL 2017.09 (Jun 13 2025 - 02:18:34) unknown raw ID ff ff ff unrecognized JEDEC id bytes: ff, ff, ff Trying to boot from MMC1 Card did not respond to voltage select! spl: mmc init failed with error: -95 Trying to boot from MMC2 Card did not respond to voltage select! spl: mmc init failed with error: -95 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### # Reset the board to bootrom # Not sure if it matters, but I have a EMMC installed and flashed the image to it using the rkdevelop tool. ( The same way I do to flash the firmware from orangepi site ) Just in case, here are the commands I use ./rkdeveloptool db MiniLoaderAll.bin ./rkdeveloptool wl 0 Armbian_community_25.8.0-trunk.228_Orangepi5pro_bookworm_vendor_6.1.115_minimal.img ./rkdeveloptool rd
Hi, I also tried to run this sensor, tried different ports but to no avail. maybe you found a way to solve this problem?
Hi! So, I tried this overlay, and the device still did not detect USB. Although when I tried switching the dts file to the topwise a721, the HDMI stopped working but USB devices were correctly detected. On top of that, no the display still does not work even with the topwise device tree. I checked the RAM clock speed with the command you mentioned and it said 432000000, which is much higher than what I found from the boot file from original Android (384000000). Is there a way I can rebuild just u-boot and install it in this working image? -
Share the image of your assembly, preferably server-side.
I think I solved it! In the upgraded system there was no package pahole! After I installed the pahole and reinstalled the package linux-headers-6.12.33-current-x86, I got the BTF stuff as described above in the .config file and I can compile modules! Pfff, finally! I checked the Raspberry Pi 4 version, I see no pahole package installed there, and I can compile modules and zfs. I don't see any BTF stuff in the .config there also. So, I don't know what is really going on here, I should install pahole on arm64 systems as well? And should pahole not be included when you upgrade your system to 25.5.1 ?
Thanks a lot for your help, Igor. That did not make the trick, as the available packages are still in the old form (docker.io instead of docker-ce for example. Nonetheless, I now have a working (but old) docker binary, which is enough for my use case. Now, I will try to build a more recent docker binary. The next problem to solve will be to get the NVMe to work. I'm sorry your F3 died.
Orange pi zero2W supports built in microphone input or not
ag123 replied to QwertyOrange's topic in Allwinner sunxi
accordingly H618 do not have mic in hardware https://www.cnx-software.com/2023/07/03/orange-pi-zero-3-allwinner-h618-sbc-ships-with-up-to-4gb-ram/ hence, an option is to use a usb soundcard / dongle https://www.aliexpress.com/w/wholesale-usb-sound-card.html there are also those 'arduinoish' approaches e.g. to use a ADC module board e.g. https://www.ti.com/lit/ds/symlink/ads1110.pdf https://www.aliexpress.com/w/wholesale-ads1110.html https://www.instructables.com/Arduino-and-the-TI-ADS1110-16-bit-ADC/ but that you would need to hack the pin interfaces to use i2c etc. note it seemed ads1110 is a bit too slow for sound. alternatives are like stm32, which has built-in adc that can go to like 1-2.5 Msps, but you would need to hack the spi interface etc. the 'easiest / cheapest' way seemed to be generic 'usb sound cards' -
Has a fixed image been posted? Just upgraded to 25.5 from 25.2, so havent tested a new image download yet.
probably best to specify location for any sales offer
Banana Pi - Armbian Buildsystem | Development Team
laibsch replied to hexzhen3x7's topic in Advanced users - Development
What is the status here?- 6 replies
- Banana Pi M4 Zero
- Banana Pi M7
(and 18 more)
Tagged with:
- Banana Pi M4 Zero
- Banana Pi M7
- Banana Pi F3
- Banana Pi M5 Pro
- Banana Pi
- Banana Pi BPi-M2+
- Banana Pi BPI-M64
- Banana Pi BPI-M1+
- Banana Pi BPI-M2
- Banana Pi BPI-M2U
- Banana Pi BPI-M2 ZERO
- Banana Pi BPI-M3
- Banana Pi BPI-R2
- Banana Pi BPI-M1
- Banana Pi BPI-M2 Pro
- Banana Pi M5
- Banana Pi BPi-M2S
- Banana Pi BPI-R2 Pro
- Bananapi CM4 io
- Banana Pi Pro
SteeMan replied to Nguyễn Tất Hùng's topic in Amlogic CPU Boxes
@Nguyễn Tất Hùng If you want to use Armbian, you should start here: https://www.armbian.com/amlogic-s9xx-tv-box/ And specifically look at the link to the Status of TV Boxes on Armbian information.
