  2. unsupported build environment. As per documentation Noble is supported only. there are a few others "whitelisted" known mostly to work in the scripts, Zena hasn't yet. Check if your user has access to docker (usermod -aG docker yourusername) and check if docker run hello-world runs properly.
  3. Hello, my Cubitruck with Armbian 23.8.1 Bullseye has the false Time and i can't change this. i don't know who is the problem. "date" says me "Mo 9. Feb 19:24:06 CET 2026" but now we have 05:26, when i set date with "sudo date -s "2026-02-09 05:26:00", it looks like it will be override in the next moment, then "date" says sudo date -s "2026-02-09 05:26:00" Mo 9. Feb 05:26:00 CET 2026 root@cubietruck ~ > date Mo 9. Feb 19:26:27 CET 2026 dmesg | grep -i rtc [ 0.000000] Kernel command line: root=UUID=19cf2f1d-1a31-4890-bc04-a2f1c4e4e021 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=ba110a34-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u rtc-hctosys=0 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 [ 0.000000] Unknown kernel command line parameters "ubootpart=ba110a34-01 ubootsource=mmc rtc-hctosys=0 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory", will be passed to user space. [ 1.553534] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes [ 1.555880] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes [ 1.573650] sunxi-rtc 1c20d00.rtc: registered as rtc0 [ 1.573701] sunxi-rtc 1c20d00.rtc: setting system clock to 2026-02-09T18:15:12 UTC (1770660912) [ 1.755046] axp20x-i2c 1-0034: Backup (RTC) battery charging is enabled [ 2.161281] rtc-hctosys=0 sudo systemctl restart chrony chronyc tracking chronyc sources -v Reference ID : 00000000 () Stratum : 0 Ref time (UTC) : Thu Jan 01 00:00:00 1970 System time : 0.000000000 seconds slow of NTP time Last offset : +0.000000000 seconds RMS offset : 0.000000000 seconds Frequency : 6.181 ppm slow Residual freq : +0.000 ppm Skew : 0.000 ppm Root delay : 1.000000000 seconds Root dispersion : 1.000000000 seconds Update interval : 0.0 seconds Leap status : Not synchronised .-- Source mode '^' = server, '=' = peer, '#' = local clock. / .- Source state '*' = current best, '+' = combined, '-' = not combined, | / 'x' = may be in error, '~' = too variable, '?' = unusable. || .- xxxx [ yyyy ] +/- zzzz || Reachability register (octal) -. | xxxx = adjusted offset, || Log2(Polling interval) --. | | yyyy = measured offset, || \ | | zzzz = estimated error. || | | \ MS Name/IP address Stratum Poll Reach LastRx Last sample =============================================================================== ^? listserver.trexler.at 0 6 0 - +0ns[ +0ns] +/- 0ns ^? time.netzwerge.de 0 6 0 - +0ns[ +0ns] +/- 0ns ^? 2a02:8108:4d82:e400:9677> 0 6 0 - +0ns[ +0ns] +/- 0ns ^? static.179.181.75.5.clie> 0 6 0 - +0ns[ +0ns] +/- 0ns ^? 2a09:e1c1:efc4:1337::123 0 6 0 - +0ns[ +0ns] +/- 0ns ^? 2a01:7e01::f03c:94ff:fee> 2 6 1 0 +50282s[+50282s] +/- 27ms ^? nobody.yourvserver.net 0 6 0 - +0ns[ +0ns] +/- 0ns ^? ctb01.martinmoerch.dk 0 6 0 - +0ns[ +0ns] +/- 0ns ^? fritz.box 0 6 0 - +0ns[ +0ns] +/- 0ns What can be the problem and how can i fix it. Thank you
  4. Malay
    Hello @sven-ola ! It's sad. I had a small hope 🙂 But still, thank you very, very much for your work on the firmware! After removing sudo rm -r cache/ output/ -f and adding the command SKIP_ARMBIAN_REPO=yes - WiFi now works
  5. No works, UART output null. I think that UART is disabld by OEM. because a working tvbox , UART also output is null
  6. Today
  7. After digging into more details, I think Armbian has moved to use new U-Boot generated FIT image u-boot-rockchip-spi.bin for SPI boot, however, it doesn't work to boot NVMe rootfs and sometimes breaks the board and I have to erase SPI to get SD card booting. Couldn't find more information how Armbian does MTD boot now. Note that older vendor SPI bootloader can boot kernel 6.18.8 but I ran into other issue like freezing system for a couple of minutes so that I'd say to avoid use old MTD image with 26.2 6.18 kernel.
  8. Have you tried the install instructions and build from here: https://www.armbian.com/amlogic-s9xx-tv-box/
  9. Yesterday
  10. On my Gentoo setup, I never had any USB issues before 6.6, even without the usbcore.autosuspend=-1 option. With 6.6, though, USB doesn’t work for me even with that option enabled. The fix from all2 worked for me, so thanks to that I put together what I think is a slightly more robust solution:
  11. Armbian supports boards, not bare SoCs. This thread is about xt-q8l-v10 rk3288 board, which is supported by community and not officially. If you want official support, prefer a SBC which is declared as officially supported, like the Asus Tinkerboard. Community supported boards are "best effort", officially supported boards are usually checked before new armbian releases to maintain general support and functionality.
  12. Hello everyone, good day. I have a problem and I want to share it with you, maybe we can find a solution. I have a Next MyBox Android box, model H313, with 2GB of RAM (I don't know the LDDR3 type, but I think it's LDDR3). I want to install Armbian on this device via an SD card, but I have a problem: the eMMC flash memory was faulty and causing a short circuit. I removed and cleaned it, but now when I try to install Armbian like X96Q with the SD card, I can't see a display or an IP address on my router. There's no HDMI display either. If you have any information about this, could you please share it?
  13. @GBEM , Hi are you sure wifi is attached to sdmmc1 ? here is my log: root@h96-tvbox-3566:~# dmesg | grep -i sdio [ 2.961741] mmc2: new UHS-I speed SDR50 SDIO card at address 390b [ 12.974586] aicbsp: aicbsp_sdio_probe:1 vid:0xC8A1 did:0x0082 [ 12.977567] aicbsp: aicbsp_sdio_probe:2 vid:0xC8A1 did:0x0182 [ 12.977586] aicbsp: aicbsp_sdio_probe after replace:1 [ 12.977595] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 150 MHz [ 12.977600] aicbsp: aicwf_sdio_reg_init [ 12.993394] rwnx_load_firmware :firmware path = /lib/firmware/aic8800_fw/SDIO/aic8800D80/fw_patch_table_8800d80_u02.bin [ 13.093862] rwnx_load_firmware :firmware path = /lib/firmware/aic8800_fw/SDIO/aic8800D80/fw_adid_8800d80_u02.bin [ 13.127689] rwnx_load_firmware :firmware path = /lib/firmware/aic8800_fw/SDIO/aic8800D80/fw_patch_8800d80_u02.bin [ 13.143887] rwnx_load_firmware :firmware path = /lib/firmware/aic8800_fw/SDIO/aic8800D80/fw_patch_8800d80_u02_ext0.bin [ 13.400664] rwnx_load_firmware :firmware path = /lib/firmware/aic8800_fw/SDIO/aic8800D80/fmacfw_8800d80_u02.bin [ 14.275914] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 150 MHz [ 14.275939] aicsdio: aicwf_sdio_reg_init [ 14.284873] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 150 MHz [ 14.305375] aicbsp: sdio_err:<aicwf_sdio_bus_pwrctl,1404>: bus down [ 439.182900] aicwf_sdio mmc2:390b:1 wlan0: CLOSE [ 520.391280] aicwf_sdio mmc2:390b:1 wlan0: CLOSE [ 683.043492] aicwf_sdio mmc2:390b:1 wlan0: CLOSE It seems attached to sdmmc2, then in case there is a need a possible device tree could be (73 is 2 B1 as in your file): &sdmmc2 { bus-width = <4>; non-removable; cap-sdio-irq; keep-power-in-suspend; reset-gpios = <&gpio2 9 GPIO_ACTIVE_HIGH>; /* gpio-73 */ status = "okay"; };
  14. UPDATE for Multitool Finally I managed to let the Opensource OP-TEE work with the rockchip miniloader! This means that the Multitool should now work on any board, without freezes and booting issues! The new version can be downloaded from the first page of this thread. Please report if it works for you, thanks!
  15. @jock Hi, I have updated the build source for the leds overlay files (leds 6 and 7) for both the the rockchip64 H50 tvbox and the T9 tvbox, for kernels 6.12 (old non scrolling driver) and 6.18 (new scrolling driver) the version for 6.18 is also fine for 6.19. Have a look at my fork in https://github.com/gpaesano/build. Some modifications are just refinements other are functional. I have built all the images and variants on a ubuntu linux and are running well. I am not familiar with pull requests and do not want to be impolite, so If you think there is some added value please support it. All the best @GmP
  16. If anyone is still interested, I have a Helios 64 that I assembled, looked at, but never got around to using for more than a couple hours. Works fine, does not yet have the 2.5GB fix but I have the instructions for same. No idea what to ask for it but it certainly isn't doing me any good sitting on my shelf. Have the manual, SATA drive bay adapters for 2.5" drives and the like. Make me an offer and pay shipping from Oregon. Let's talk!
  17. https://github.com/armbian/community/releases/download/26.2.0-trunk.385/Armbian_community_26.2.0-trunk.385_Rk3318-box_trixie_current_6.18.8_minimal.img.xz this is the latest console build compatible with T9. You will need to configure a little bit the environment after booting to enable all the features via ssh and wired lan. If the device is still on android the best is to follow the tutorial from @jock in
  18. Thank you. I couldn't even think of such a thing. Lord, why is it necessary to preserve the state of indicators that are needed precisely to show the state of something?
  19. @Nick A No problem. Thanks for your Armbian build as well! I am also looking forward to mainline. Currently I still didn't find open source Mesa driver for Allwinner BSP, GLES is only available as pre-compiled binary for Debian (haven't tested it but it's in the Radxa images). There already are mainline Mesa/Linux IMG GPU supports so I hope things can be ported to mainline soon. Please let me know if anyone finds the source code for Mesa BSP.
  20. All things are possible. The question is who's interested in doing (or funding) the work, and if technical data is available to do it. The build system is at https://github.com/armbian/build. If you know how to build a kernel, device tree, and bootloader, you can define how to do those steps there.
  21. Last week
  22. Bookworm. But my point was the version 35.1 is what got installed when I ran the scripts in the first post. If the script installed 37 for you because you're on Ubuntu then I probably am on the wrong track. Yes I believe it does this. I was just pointing out that drm_prime works for me but I guess that could just be due to different hardware on the device. I'm not using an Orange Pi.
  23. @Brow Mosh AI is wrong. Mainline supports - Your PMIC - Your DRAM timing - Your HDMI (Patches have been around for years but not accepted in mainline yet. I included it in my builds.) - Your regulators Supported in mainline but might need some dts changes. - Your weird SD wiring - Your eMMC layout ( Could be a gpio# issue) If you are booting into the kernel then I believe your SD is somewhat working. Maybe you need few tweaks to your dts or your DRAM settings are off. A failing or cheap SD card could also be your issue. Kernel boots Reaches userspace Shows login banner Without a DTS I can’t help you much. Also, can you post some boot logs. FEL over USB is your last option. It is possible. But I don't think your AI model will help much. I noticed with some AI models they will encourage you to quit when they can't find the correct information. The owner of the AI model wants you to pay for their deep learning version.
  24. Version 3.1.0 Has been released! I won't be going into details like last time, this build also includes the fixes for "known issues" from version 3 Alpha build. Bugs Found? Open a ticket in https://github.com/Harleythetech/openauto-rk3229-armbian/issues Download: Github: OpenAuto RK322x - oark322x-3.1.0-beta
  25. @marcosdsdba Can you take a picture or just tell us the Wi-Fi chip you have on your board?
  26. I buy a different USB uart Usbuart Maybe I can do what you suggest. I need to wait to the item arrives at my home. When It arrives I post here to the device read uart method.
  27. I am trying to setup Raxda Display 8 HD with Radxa ROCK 3A. On official Radxa OS, I used Rsetup tool to setup overlay for `Radxa Display 8 HD' using official guide. How can I do same on Dedicated applications images with Armbian Linux v6.12 ( Home Assistant ) ? I have read Device Tree overlays guide on armbian docs but I can't find overlay for lcd display in files:
  28. Thank you! That worked like a charm
  29. Thanks for the feedback , i have finally downloaded this version and burn into sd card , put in sd card then reconnect power, the system normal boot i cant see armbian screen, the blue light is on, and nothing on screen or dark screen can someone point me please what is happening.
