  2. expected. HDMI or hw support in general in 6.12.y is very basic and I am often impressed that hdmi actually works on some boards with this kernel. tl;dr: use vendor or edge kernels If need stuff running. current won't receive any further feature updates but security fixed only.
  3. Hi, I have a few sbcs live while most are laying on the shelf waiting for tests. I have a PiHole on an Orangepi One Plus. On a ROC RK3399 PC PLUS I have paperless-ngx running in Docker. On an OPi5 Plus I have Invidious, yourspotify and something else I frequently forget about. Most likely something from similar importance
  5. Hi @AaronNGray, Did you check if there is indeed an SD card inserted? If so, try to remove it then re-insert it while the system has booted. Also, seems that you have an NVMe storage device attached, on which the OS was installed - not the SD card as you mentioned? As @laibsch mentioned, the eMMC is detected and available as /dev/mmcblk0, but seems that SD card is not seen (if it was inserted). Grt,
  6. Yesterday
  7. First test was in a CLI environment so running fullscreen. Self built with no media related changes to the configuration. Edge build around kernel 6.15.0 and running on Pcduino2 For the second test I used the build scripts to create a desktop image which came to be less of a headache because less dependencies had to resolved than working purely with CLI only. This was built around kernel 6.15.4 and running on Pcduino3. This time got a blue screen within the window and lots of errors relating to dmabuf. test2.txt I currently have CMA set to 64mb, although this is overridden by the shared-dma-pool within the sun7i-a20.dtsi
  8. Probably worth a shot - I had an install one time that gave me fits at initial boot. For giggles I expanded the FS using Gparted in linux to fill the entire card. It solved that problem for me.
  9. Thanks! My opi zero 2w was intermittently crashing, I think I bumped a component off soldering the pin header on, so I am going to get a new one and see if it does any better. Will update in a few days once it arrives.
  10. @psygnosis Do you have any heat sink or other cooling on your orangepione? Is your environment hot? At idle (480MHz) your machine is running quite hot, over 55 deg. The idle cpu speed is the minimum that the os can manage and so the os it doing the best it can.
  11. Ok, thank you! I've made an issue on github: https://github.com/armbian/build/issues/8403
  12. You will have to uninstall the upstream wireguard as that will remove the dependancy on the non-armbian kernel.
  13. Accidentally included a duplicate in the previous post's image. Here is the missing SBC...I note this one has 32gb of ram vs the other's 16gb.
  14. I am Running Armbian 24.5.1 Jammy with Linux 6.1.115-vendor-rk35xx on Radxa Rock5b (and it works great!!) when running sudo apt dist-upgrade or sudo apt upgrade I get Die folgenden Pakete sind zurückgehalten worden: armbian-bsp-cli-rock-5b " Packages retained" apt list --installed | grep armbian-bsp-cli-rock-5b gives: armbian-bsp-cli-rock-5b-legacy/jammy,now 24.5.1 arm64 [installiert] armbian-bsp-cli-rock-5b/jammy,now 24.5.1 arm64 [Installiert,aktualisierbar auf: 25.5.1] ## installed, can be updated can/shall I force the the use of "armbian-bsp-cli-rock-5b/jammy,now 24.5.1 arm64 [Installiert,aktualisierbar auf: 25.5.1]" ? how? what is the correct procedure to update to 25.5.x? thanks
  15. all those things are wow give kodi a try? https://kodi.tv/
  16. It is documented there: So when booted from SD you need to copy over the u-boot image to SD card and do from there: dd if=cubie_a5e_spi_nor_raw_050624.img of=/dev/mtdblock0 But that won't you get NVMe support on Armbian as Cubie A5E NVMe support just isn't in the kernel, not even the dev version.
  17. I assume you didn't change your power supply or add more things to USB? This could trigger crash. It would help if you could catch the crash. Enable more verbosity (loglevel) might give some clues, otherwise this can represent more serious debug / not easy to catch and resolve.
  18. I don't have time to work on this right away, so to make sure this does not fall off the radar, I opened a ticket in the tracker.
  19. Last week
  20. The Gnome desktop Power off menu selection and `sudo shutdown now` both reboot rather than powering down.
  21. yeah, frustration is quite clear, but probably it is manufacturer who should be most/only interested in that. that also cost quite a lot, so it is probably better to demand where money were paid to, i guess.
  22. That is the expected behavior. You always need to "install" u-boot after a new version from apt. The apt package just provides the binaries that you can install.
  23. Tried rk3318 debian 12 with linux kernel 6.1.63 or up to 6.12.39 and no hdmi output, I installed on SD card. Though debian 11 with kernel 5.15.35 works Interesting thing that debian 12 with linux kernel 6.16.0-rc3 worked Is there anything I can do to provide useful information to debug?
  24. And it turns out that nothing can be done? For some reason, it works for everyone, but something happened to me and it doesn't work anymore.
  25. use my works: h616.tar.xz
  26. follow the official instructions, change these dts to user overlay, simplicifed deployment just use `sudo make install` h616.tar.xz
  27. Currently I am running HA supervised on Debian 12 bookworm. Debian boots from USB drive without any issue. So your suggestion should work I believe. Thanks for the suggestion. You are quick as always to reply.
