Same problem here except there's no Desktop option. Only these: - Kernel - Storage - Access - User - Updates Got any other solutions?
Helios64 - Unable to transfer install from eMMC to SDCard
Marru_678 replied to unfnknblvbl's topic in Rockchip
You can't truly "force" the boot sequence on Helios64 since U-Boot already checks SD, eMMC, and SATA. The SD card isn't bootable if the eMMC is still booting. Things to check quickly: SD must contain a properly written raw Armbian image (dd / balenaEtcher). You can't copy files. Check that it contains a bootloader and not simply an ext4 partition. Before starting, turn off the power completely (warm reboots might disregard SD). Once the computer has started, use lsblk -f to inspect the layout of the devices. On Helios64, the mmc numbering does change, therefore tools may conceal devices to save the live rootfs from being destroyed. If you want to be 100% sure, unplug the eMMC for a short time. If it boots, the SD is OK. The boot sequence isn't the problem; the SD image is. - Yesterday
It said "archlinux" because I took something from my notes for my Arch Linux images. It was only an example command and you can put there anything on how you named the image. I did not include image creating and bootrapping an OS into the image. I mainly wanted to show you how you can build and flash your custom u-boot. You get these "idbloader.img" and "u-boot.itb" files from the steps I laid out. If you download u-boot, bl31, ddr and compile it, you will see the files in the folder. I am sure you will understand this pretty fast. :-) Create an empty img file Create a rootfs partition (should start at 16MB) Bootstrap Debian or Ubuntu into the image Then start with the u-boot stuff above. By the time 6.19 drops, you will be a master in building images. :-)
PHC support for NanoPi R76S
muetzekoeln replied to muetzekoeln's topic in Framework and userspace feature requests
yes. I tried r8125-9.016.01 but with mixed results. Ethernet addresses could not be read by the new driver. And PHC support was no longer shown after reboot. -
Edit ArmbianEnv.txt when machine is unable to boot?
Myriade replied to Myriade's topic in Rockchip CPU Boxes
The thing is that no file is present under /boot. It's true for some other folders (I can't check rn) but the /home folder is fine. It's not a missing permission problem, `sudo ls /boot` yields the same result. I'll get back at you when I can check but this seemed to be happening on 2 different computer. I just assumed that /boot is meant to be empty and gets populated at boot (and it was just strange design), since I can't see any content in /boot when mounting the sd card externally even when the box boots fine. From inside the box when it boots fine I can access the content of /boot though. I'll try to get my hands on a serial to usb cable, though this will just help to figure out why it doesn't boot, not why I can't access the content on the sd card externally. -
if you sudo apt upgrade the firmware package for the q6a breaks wifi and i believe ethernet... I do not have a concise fix for this i reflashed my device with the latest build after doing it originally to get wifi when validating the issue i had backed up the firmware etc for the default network drivers after upgrading broke the networking drivers had to restore firmware from previous build.... Would give a fix but aint that easy if you already upgraded you need to download the previous firmware put on usb stick and slap it on either that or figure out whats broken in the last one this is kind of rambling but yeah just be careful upgrading
Fairly sure the current build either includes an incorrect or no ucm config for HDMI Audio support; I've seen other builds eg rock itx have this issue but I believe this may be a potential issue for the q6a build if anyone experiences there is a solution - 1. Install alsa-ucm-conf sudo apt install -y alsa-ucm-conf 2. Download configs cd /tmp curl -sL "https://github.com/alsa-project/alsa-ucm-conf/archive/refs/heads/master.tar.gz" | tar xz 3. Copy QCS6490 configs sudo cp -r alsa-ucm-conf-master/ucm2/Qualcomm/qcs6490 /usr/share/alsa/ucm2/Qualcomm/ sudo cp -r alsa-ucm-conf-master/ucm2/conf.d/qcs6490 /usr/share/alsa/ucm2/conf.d/ 4. Copy library & codec files sudo cp -r alsa-ucm-conf-master/ucm2/lib /usr/share/alsa/ucm2/ sudo cp -r alsa-ucm-conf-master/ucm2/codecs /usr/share/alsa/ucm2 5. Restart PulseAudio systemctl --user restart pulseaudio 6. Verify HDMI audio is detected pactl list sinks short If this did not work i probably just made your issue harder to fix; However if this did work congrats enjoy not having a mute computer.
Blind55 replied to Blind55's topic in NanoPi R6S/R6C
Ok, as promised with a report. Current setup - NanoPi R6S - Armbian Debian trixie minimal edition, with Kernel 6.1.115 - LXQT (using X11) - Jellyfin (installed via Jellyfin website instructions, NOT using armbian-config as that sets up docker and then makes it more opaque to run it with external media) - firefox Results - Jellyfin, accessed via apps for various SmartTVs (Google Chromecast, Amazon TV, etc), runs super smooth with 4K videos, indicating functioning hardware decoding. NanoPi stays very cool even for 4K transcodes. - Firefox video playback has to, like @eselarm already said, resort to software decode. NanoPi is able to play smooth up to HD level videos in firefox, but it gets pretty hot. Comments I suppose that getting firefox hardware accelerated video decode is further out of reach now that ffmpeg has DMCA-taken-down the rockchip-mpp github repository...but what do I know. I am wondering if running LXQT with wayland would offer improvements, but I am not sure it's worth the effort. I am a relatively happy camper with this setup. -
I do not know how to fix that key / verify signature issue. It might be there because of earlier diskfull. I only know I needed new keyrings, listed in the armbian list files when I did the in-place upgrade from bookworm to trixie. There is a formal method for that I think, might be here on forum. I however did copy various things from a new Armbian Trixie image. E.g. new file is now: -rw-rw-r-- 1 root root 2297 Aug 31 22:15 /usr/share/keyrings/armbian-archive-keyring.gpg ~# sha256sum /usr/share/keyrings/armbian-archive-keyring.gpg 9d0ab1676008004f1ee0bfc0f99a6043544d8bb6df3d949f9bd30066246f9095 /usr/share/keyrings/armbian-archive-keyring.gpg For Docker problem: I don't use Docker, I have no clue why that file keeps growing.
ariel1 replied to Meestor_X's topic in Allwinner sunxi
From my experience with trunk 130 the gmac is working on both ports. Wifi is not always working, sometimes a reboot may make the wifi to work. There is no USB 3.0 and HDMI is not working either. Running gdisk armbian.img made it bootable. The easiest way to run this command for me was from WSL. -
After having this happen again and investigating further, it looks like my container for transmission is writing to a log file that is just ballooning bigger and bigger until the system crashes. root@modron:/var/lib/docker/containers/899f42253bb7772351219b7a65ff21347455f11950f983fb7a8883c6b93cdb17# ls -al total 101656680 drwx--x--- 4 root root 4096 Dec 27 22:28 . drwx--x--- 22 root root 4096 Dec 27 22:28 .. -rw-r----- 1 root root 104095768576 Dec 31 15:08 899f42253bb7772351219b7a65ff21347455f11950f983fb7a8883c6b93cdb17-json.log drwx------ 2 root root 4096 Dec 27 22:28 checkpoints -rw------- 1 root root 5949 Dec 27 22:28 config.v2.json -rw------- 1 root root 1776 Dec 27 22:28 hostconfig.json -rw-r--r-- 1 root root 13 Dec 27 22:28 hostname -rw-r--r-- 1 root root 172 Dec 27 22:28 hosts drwx--x--- 2 root root 4096 Dec 27 22:28 mounts -rw-r--r-- 1 root root 336 Dec 27 22:28 resolv.conf -rw-r--r-- 1 root root 71 Dec 27 22:28 resolv.conf.hash I'm not sure what this file is. Tailing it prints this out, and I'm worried trying to load it into memory with less would cause a crash: {"log":"[warn] Error from accept() call: No file descriptors available\n","stream":"stderr","time":"2025-12-31T20:06:58.854663511Z"} {"log":"[warn] Error from accept() call: No file descriptors available\n","stream":"stderr","time":"2025-12-31T20:06:58.854793008Z"} {"log":"[warn] Error from accept() call: No file descriptors available\n","stream":"stderr","time":"2025-12-31T20:06:58.855042376Z"} {"log":"[warn] Error from accept() call: No file descriptors available\n","stream":"stderr","time":"2025-12-31T20:06:58.855144456Z"} {"log":"[warn] Error from accept() call: No file descriptors available\n","stream":"stderr","time":"2025-12-31T20:06:58.855165456Z"} {"log":"[warn] Error from accept() call: No file descriptors available\n","stream":"stderr","time":"2025-12-31T20:06:58.855213288Z"} {"log":"[warn] Error from accept() call: No file descriptors available\n","stream":"stderr","time":"2025-12-31T20:06:58.855254412Z"} {"log":"[warn] Error from accept() call: No file descriptors available\n","stream":"stderr","time":"2025-12-31T20:06:58.855304285Z"} {"log":"[warn] Error from accept() call: No file descriptors available\n","stream":"stderr","time":"2025-12-31T20:06:58.855320618Z"} {"log":"[warn] Error from accept() call: No file descriptors available\n","stream":"stderr","time":"2025-12- I've been running the 4.0.5 branch of the linuxserver.io container for transmission, I'm updating to their "latest" branch and seeing if that improves anything.
Armbian 25.11.2 Noble XFCE (BSP Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + dgVoodoo2 (https://github.com/dege-diosg/dgVoodoo2/releases) + DXVK-stripped v1.6.1 ~60fps@720p Need For Speed Most Wanted -
https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first/#comment-199170
- 1 reply
1
I have the following (maybe stupid) question, what needs to be done to be able to use all the features of the RK3588 by adding the dts file. Example: there used to be /dev/tpm0 which has been missing for several versions. As I said earlier, the latest dts is much shorter. My question is not an attempt to nitpick, but a serious question. And what can I help with. As in my case, there is a peculiarity. I have a FriendlyElec NanoPC-T6 and it is used in "production" in my network. And I do not have the opportunity to reinstall it. I would like to make a dts file that allows using the full functionality of the RK3588. Again, I want to say, I do not want to blame anyone or nitpick, but to find a solution, and whether I can help with anything and if Yes, how and with what. P.S. Since today is the 31st, if you want we can postpone the discussion until January 1st or 2nd
Hello SteeMan, Thank you I am going to look for a usb a to usb a cable Maybe ik can make one myself Happy New Year 🎉🎉🎉
I have an old MXQ Pro 4K (based on the original S905, not S905X or S905D, the original S905) which I tried to install armbian on, but I didn't know extra things were needed to set up uboot and dtb correctly, so I just flashed the image, put the SD card in my box, ran `reboot update` from Android to boot to the SD card, it showed the MXQ Pro logo, rebooted, went back to the MXQ Pro logo, and I can't get it to go past that. My box has a weird firmware issue (started immediately after a firmware restore so I don't think it's hardware damage) where the button in the headphone jack just... doesn't work, even when holding it, it still tries to boot to the eMMC, and now I have no way of getting back into Android, and I can't boot from the SD card due to the button not working, so, is there any hope for my box here? Or have I effectively hard bricked it? I don't have a USB-A to USB-A cable for USB burning tool, and I will not be purchasing one, this was a spare box I've had laying around for eons and I don't think it's worth spending any money on -- I could probably get a much better box for the same money.
http://blog.armbian.com/content/images/2025/12/githubhighlights-2.pngThis week in Armbian development saw a series of refinements and maintenance updates across the build and configuration repositories. Contributors focused on workflow standardization, cosmetic improvements such as board name adjustments, and documentation enhancements. Several technical fixes addressed typos, property mispellings, and package issues, while platform support was expanded with kernel and boot improvements for devices like the Mekotronics R58-4x4 and MusePi Pro. Notable changes also included vendor reorganization and the addition of fallback logic for Ubuntu LTS releases. Overall, the activity reflects ongoing efforts to streamline processes and bolster hardware compatibility. Adjusting board names - cosmetic issue. by @igorpecovnik in armbian/build#9116chore: cleanup mirror_to_codeberg.yml workflow. by @igorpecovnik in armbian/build#9133chore: standardize workflow names. by @igorpecovnik in armbian/build#9130chore: update copyright years to 2026. by @igorpecovnik in armbian/build#9129Create mirror_to_codeberg.yml. by @EvilOlaf in armbian/build#9131docs: improve README and add Armbian Imager promotion. by @igorpecovnik in armbian/build#9128dts: orangepi-4-lts: fix mispelled disable properites. by @EvilOlaf in armbian/build#9123Fix dialog typo. by @SergeantSerk in armbian/configng#716fix(apt-utils): add fallback for Ubuntu LTS releases without -updates suffix in JSON. by @adeepn in armbian/build#9117fix(rootfs): unset GIT_FIXED_WORKDIR after debootstrap/mmdebstrap clone. by @QwaSeeK in armbian/build#9132Genio: Change INSTALL_ARMBIAN_FIRMWARE to 'yes'. by @HeyMeco in armbian/build#9134gha: check-pr-pictures: allow declare -g BOARD_VENDOR=. by @rpardini in armbian/build#9142mekotronics-r58-4x4: enable edge branch with mainline kernel & u-boot. by @rpardini in armbian/build#9127Missing upstream package mousetweaks. by @igorpecovnik in armbian/build#9143Move boards with vendor intel_amd under generic vendor. by @igorpecovnik in armbian/build#9122SpacemiT: Fixup eMMC boot on the MusePi Pro "SPINOR". by @pyavitz in armbian/build#9141sunxi: backport A523/T527 related patches from 6.19-rc1 and #8831. by @EvilOlaf in armbian/build#9106View the full article
GBEM replied to Hqnicolas's topic in Rockchip CPU Boxes
Greetings, H96 Max V56 developers, I got 1Gb Ethernet, basic WiFi6, and the full Bluetooth5.4 suite of capabilities from the new H96 hardware, running my 6.12.44 kernel, Home Assistant OS port. Thanks especially @WINEDS for the stellar foundation, and to @GmP for the final piece of the Bluetooth puzzle. GBEM 👽 -
Hello - Very new to this all and trying to learn my way around. I have an OPi4a which I was previously using for octoprint, etc. Was able to get it going using OrangePi's provided Ubuntu22.04 Jammy image, but am needing to reconfigure and was interested in armbian as the official images from OrangePi can be hard to access at times (site seems to intermittently go down / time out?), and from what I've seen there's very limited support from the manufacturer. Anyways - for the uninitiated, what is the status of the image for the 4a? Seeing the most recent post - does the backport being merged mean that it is possible to build from armbian main? Which target board should be selected? I am not seeing an option for the 4a, or any with the T527 chip. Alternatively, the most recent image I'm seeing is from @JuanEsf - to get this to work do I just need to use something like balena and flash from URL? Very new to all this, any help is appreciated.
Ngô Huỳnh Ngọc Khánh replied to sicxnull's topic in Allwinner CPU Boxes
The x96q-v5-1 image support aic8800 wifi chip without modify anything from dtb. Follow this https://github.com/LYU4662/aic8800-sdio-linux-1.0, the AIC8800 and alternate based on AIC8800 will work! -
Well, at this point, hard to say what's going on: I'm not sure what happened during my chroot sessions but it looks like / in now non crypted and the boot options were completely overridden by who know's what verbosity=1 bootlogo=false console=both extraargs=cma=256M overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588-rock-5-itx.dtb rootdev=UUID=92f542d4-5a03-424e-b953-e711111186dc rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u And I can boot without having to luks decrypt. It is probably a side effect of what I mounted in the chroot (/run /sys, etc) but I did not know this was even possible and I would be interested in theories or possible explanations. Thanks to all of you, especially @IBV
Will you please give the detail step?I flash "Armbian 25.11.2 trixie" ,but I can't find any useful dtbo file.
Rock Pi S no CLK signal on SPI1
solaris3308 replied to Martin Petrašovský's topic in Radxa Rock Pi S
How can you active spi support?I burn " 25.11.2" image,but I can't find any overlay of spi ,uart or i2c. This is my system status: cat /etc/os-release PRETTY_NAME="Armbian 25.11.2 trixie" NAME="Debian GNU/Linux" VERSION_ID="13" VERSION="13 (trixie)" VERSION_CODENAME=trixie DEBIAN_VERSION_FULL=13.2 ID=debian HOME_URL="https://www.armbian.com" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" ARMBIAN_PRETTY_NAME="Armbian 25.11.2 trixie" uname -a Linux Pi-s 6.12.58-current-rockchip64 #3 SMP PREEMPT Thu Nov 13 20:34:41 UTC 2025 aarch64 GNU/Linux ls /boot/dtb/rockchip/overlay/rk3308* /boot/dtb/rockchip/overlay/rk3308-b@1.3ghz.dtbo /boot/dtb/rockchip/overlay/rk3308-otg-host.dtbo /boot/dtb/rockchip/overlay/rk3308-bs@1.3ghz.dtbo /boot/dtb/rockchip/overlay/rk3308-s0-ext-antenna.dtbo /boot/dtb/rockchip/overlay/rk3308-bs.dtbo -
Post the UART log.
@Werner OK, since I have a few Duos (v1.0 and v1.1) I tried same Jammy with 6.1.63 kernel SD in each and let idle. The 1.1 with copper heatsink runs about 40C, the 1.1 with same aluminum heat sink runs around 45C. The v1.0 runs around 50C. So weird. I'll try latest build, but stress-ng causing thermal shutdowns worries me. I used to run decent loads on these little boards. Good thing is thermal shutdown works or it would burn up the board.
