  2. I've seen this same issue with Discord, since March/April this year. Just going to https://discord.com/app (no login necessary) is enough to trigger it. From what I gather, this seems to be some sort of problem with the Chromium build Armbian uses (it appears to be the same build from the xtradeb ppa). This seems to happen on: 1. Raspberry Pi 4 on Armbian Ubuntu Noble 2. Some random Ubuntu VM ARM64 on Apple Silicon using Chromium from xtradeb/apps PPA 3. Dragon Q6A w/ Armbian Ubuntu Noble No workarounds seem to work. Turning off GPU acceleration, disabling sandboxing, etc. all make no difference. But it does not occur on: 1. Google Chrome 2. Chromium 145 or earlier ARM64 from Armbian or Xtradeb PPA, on all devices. Only 146 or later is affected for some reason 3. Linux Mint's Chromium x64 build 4. x64 Chromium snap package on Ubuntu I have not tested xtradeb PPA (or Armbian)'s x64 build of Chromium. Based on the above, I do not think this is an Armbian specific issue. Anyone have any ideas on where to report this?
  3. Yesterday
  4. Update: the ready-to-flash Debian 13 + KDE Plasma image is now available: https://github.com/ut-slayer/orangepi-4a-mainline/releases/tag/v0.1 Boots straight to an accelerated Plasma desktop. Feedback welcome!
  5. So you try routed AP instead of bridged. Trixie might handle 'iptables' in a different way, depends also what alternatives you have for that and/or if it is netfilter underneath. This kind of manual setup (routed, hostapd) I did before Bookworm only a few times, rest is always bridged and basically using only NM. It seems to me that something on IP layer is not accepted by your phone, so it disconnects. You need to dig more and deeper and also still take in to account what is said about that brcmf_psm_watchdog_notify issue. But it seems yest another issues.
  6. Unnoficial Image: Download Link enabled CMA, increased CMA to 32mb and enabled rknn Board logs: https://paste.armbian.com/hoqejiqeno Build logs: https://paste.armbian.eu/cekehuhule Installing ffmpeg with encoders and decoders, armhf - armv7: ffmpeg-rockchip-armhf.zip On rv1126 armbian device: cd /media/usb/esp32-rv1126-ffmpeg-rockchip ./install-on-target.sh Verify: /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -encoders | grep -Ei 'rkmpp|mpp' /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -decoders | grep -Ei 'rkmpp|mpp' /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -filters | grep -Ei 'rkrga|rga' Please don't trust pre-compiled files. compile yourself: Use this only if you really want hardware H.264 encode for the go2rtc bridge. A normal upstream FFmpeg build with --enable-rkmpp may expose Rockchip decoders but not the encoder set needed here. For encoder support, use an encoder-capable Rockchip FFmpeg fork such as nyanmisaka/ffmpeg-rockchip, which documents h264_rkmpp, hevc_rkmpp, and mjpeg_rkmpp under encoders. Build FFmpeg With RKMpp Encoders: sudo apt update sudo apt install -y \ git build-essential pkg-config cmake meson ninja-build \ yasm nasm libdrm-dev libudev-dev The MPP and RGA sources below are hosted on Gitee. If git clone prompts with Username for 'https://gitee.com':, sign in with a Gitee account. That prompt is expected for these URLs and is not an FFmpeg/RKMpp build error. Build and install Rockchip MPP runtime and headers: mkdir -p ~/src cd ~/src if [ -d rkmpp/.git ]; then git -C rkmpp pull --ff-only elif [ -e rkmpp ]; then echo "rkmpp exists but is not a git checkout; move it aside or choose a new directory" >&2 exit 1 else git clone -b jellyfin-mpp --depth=1 https://gitee.com/nyanmisaka/mpp.git rkmpp fi cd rkmpp cmake -S . -B build \ -DCMAKE_BUILD_TYPE=Release \ -DCMAKE_INSTALL_PREFIX=/usr/local \ -DBUILD_SHARED_LIBS=ON \ -DBUILD_TEST=OFF cmake --build build -j"$(nproc)" sudo cmake --install build sudo ldconfig Build and install RGA. The FFmpeg fork can use RGA for hardware color conversion/scaling; this is useful because the ESP32 camera enters as raw YUYV and encoders usually want a YUV420/NV12-style input. cd ~/src if [ -d rkrga/.git ]; then git -C rkrga pull --ff-only elif [ -e rkrga ]; then echo "rkrga exists but is not a git checkout; move it aside or choose a new directory" >&2 exit 1 else git clone -b jellyfin-rga --depth=1 https://gitee.com/nyanmisaka/rga.git rkrga fi if [ -d rkrga_build ]; then meson setup --reconfigure rkrga_build else meson setup rkrga rkrga_build \ --prefix=/usr/local \ --libdir=lib \ --buildtype=release \ --default-library=shared \ -Dcpp_args=-fpermissive \ -Dlibdrm=false \ -Dlibrga_demo=false fi meson compile -C rkrga_build sudo meson install -C rkrga_build sudo ldconfig Build FFmpeg to /opt/ffmpeg-rockchip so it does not overwrite the system FFmpeg: set -e cd ~/src if [ -d ffmpeg-rockchip/.git ]; then git -C ffmpeg-rockchip pull --ff-only elif [ -e ffmpeg-rockchip ]; then echo "ffmpeg-rockchip exists but is not a git checkout; move it aside or choose a new directory" >&2 exit 1 else git clone --depth=1 https://github.com/nyanmisaka/ffmpeg-rockchip.git ffmpeg-rockchip fi cd ffmpeg-rockchip make distclean >/dev/null 2>&1 || true # RV1126 is ARMv7-A. Disabling ARMv5TE avoids assembler failures in # libavcodec/arm/mlpdsp_armv5te.S on some armhf toolchains. PKG_CONFIG_PATH=/usr/local/lib/pkgconfig:/usr/local/lib/arm-linux-gnueabihf/pkgconfig:/usr/lib/arm-linux-gnueabihf/pkgconfig \ ./configure \ --prefix=/opt/ffmpeg-rockchip \ --enable-gpl \ --enable-version3 \ --enable-libdrm \ --enable-rkmpp \ --enable-rkrga \ --disable-armv5te \ --enable-shared \ --disable-static \ --disable-doc \ --disable-debug make -j"$(nproc)" sudo make install echo /opt/ffmpeg-rockchip/lib | sudo tee /etc/ld.so.conf.d/ffmpeg-rockchip.conf sudo ldconfig This only disables FFmpeg's CPU hand-written assembly. It does not disable the Rockchip MPP encoder or RGA support, and it is acceptable for this camera path because the input is only 320x240 @ 3 fps. Verify that FFmpeg was built with actual encoders: /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -encoders | grep -Ei 'rkmpp|mpp' /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -decoders | grep -Ei 'rkmpp|mpp' /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -filters | grep -Ei 'rkrga|rga' Expected Result: /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -encoders | grep -Ei 'rkmpp|mpp' /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -decoders | grep -Ei 'rkmpp|mpp' /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -filters | grep -Ei 'rkrga|rga' V..... h264_rkmpp Rockchip MPP (Media Process Platform) H264 encoder (codec h264) V..... hevc_rkmpp Rockchip MPP (Media Process Platform) HEVC encoder (codec hevc) V..... mjpeg_rkmpp Rockchip MPP (Media Process Platform) MJPEG encoder (codec mjpeg) V..... av1_rkmpp Rockchip MPP (Media Process Platform) AV1 decoder (codec av1) V..... h263_rkmpp Rockchip MPP (Media Process Platform) H263 decoder (codec h263) V..... h264_rkmpp Rockchip MPP (Media Process Platform) H264 decoder (codec h264) V..... hevc_rkmpp Rockchip MPP (Media Process Platform) HEVC decoder (codec hevc) V..... mjpeg_rkmpp Rockchip MPP (Media Process Platform) MJPEG decoder (codec mjpeg) V..... mpeg1_rkmpp Rockchip MPP (Media Process Platform) MPEG1VIDEO decoder (codec mpeg1video) V..... mpeg2_rkmpp Rockchip MPP (Media Process Platform) MPEG2VIDEO decoder (codec mpeg2video) V..... mpeg4_rkmpp Rockchip MPP (Media Process Platform) MPEG4 decoder (codec mpeg4) V..... vp8_rkmpp Rockchip MPP (Media Process Platform) VP8 decoder (codec vp8) V..... vp9_rkmpp Rockchip MPP (Media Process Platform) VP9 decoder (codec vp9) ... overlay_rkrga VV->V Rockchip RGA (2D Raster Graphic Acceleration) video compositor ... scale_rkrga V->V Rockchip RGA (2D Raster Graphic Acceleration) video resizer and format converter ... vpp_rkrga V->V Rockchip RGA (2D Raster Graphic Acceleration) video post-process (scale/crop/transpose)
  7. Gemini info 😞 ..... In the official, pure Armbian for Banana Pi M2 Pro, enabling SPI is currently extremely difficult (and even impossible for the average user) If you absolutely need the SPI bus for your project: Operating system change: SPI works without any problems on official system images provided directly by the board manufacturer (BPI-M2 Pro Debian/Ubuntu with kernel 4.9 from Amlogic). The manufacturer uses an older but fully modified kernel (Kernel BSP), where all pins are rigidly and correctly assigned. Or... Staying with Armbian: If you must stick with Armbian, it's safer to abandon SPI attempts and—if possible—connect the target device to a free I2C bus or UART serial communication (which work flawlessly in Armbian on this board). But ultimately, the Armbian system developer will have to decide. 🙂 Check https://docs.banana-pi.org/en/BPI-M2_Pro/BananaPi_BPI-M2_Pro Firmware Armbian (bookworm): https://drive.google.com/drive/folders/1DPkc7AHEZVS7PT_yzhNH1Dfuiz99mE0p
  8. I'm facing the same issue and haven't found a way to enable USB 3.0. There doesn't seem to be an overlay like the one in Radxa OS for enabling it. If anyone knows how to get USB 3.0 working, I'd really appreciate the help.
  9. Hi, I can confirm that the issue is present in Armbian v26.5.1 with current kernel versions 6.18.x, and that it is resolved in the edge kernels 6.19.x and 7.1.x. Armbian v26.5.1 - current kernel 6.18.x - NOT OK (many retrans and ~368 Mb/sec): root@odroidtest:~# grep -a --null-data U-Boot /dev/mtd0ro U-Boot SPL 2026.01_armbian-2026.01-S127a-Pb401-H8652-Vab81-Bd0d2-R448a (May 20 2026 - 22:28:40 +0000) root@odroidtest:~# uname -a Linux odroidtest 6.18.35-current-rockchip64 #2 SMP PREEMPT Tue Jun 9 10:28:53 UTC 2026 aarch64 GNU/Linux root@odroidtest:~# iperf3 -c 192.168.0.1 Connecting to host 192.168.0.1, port 5201 [ 5] local 192.168.0.15 port 42940 connected to 192.168.0.1 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 43.0 MBytes 360 Mbits/sec 199 26.9 KBytes [ 5] 1.00-2.00 sec 44.9 MBytes 376 Mbits/sec 172 26.9 KBytes [ 5] 2.00-3.00 sec 41.8 MBytes 350 Mbits/sec 188 39.6 KBytes [ 5] 3.00-4.00 sec 45.1 MBytes 379 Mbits/sec 178 33.9 KBytes [ 5] 4.00-5.00 sec 41.9 MBytes 351 Mbits/sec 185 17.0 KBytes [ 5] 5.00-6.00 sec 46.5 MBytes 390 Mbits/sec 168 35.4 KBytes [ 5] 6.00-7.00 sec 42.8 MBytes 359 Mbits/sec 170 24.0 KBytes [ 5] 7.00-8.00 sec 47.0 MBytes 394 Mbits/sec 164 31.1 KBytes [ 5] 8.00-9.00 sec 41.0 MBytes 344 Mbits/sec 178 18.4 KBytes [ 5] 9.00-10.00 sec 44.8 MBytes 375 Mbits/sec 167 15.6 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 439 MBytes 368 Mbits/sec 1769 sender [ 5] 0.00-10.00 sec 438 MBytes 368 Mbits/sec receiver iperf Done. Armbian v26.5.1 - edge kernel 6.19 - OK root@odroidtest:~# grep -a --null-data U-Boot /dev/mtd0ro U-Boot SPL 2026.01_armbian-2026.01-S127a-Pb401-H8652-Vab81-Bd0d2-R448a (May 20 2026 - 22:28:40 +0000) root@odroidtest:~# uname -a Linux odroidtest 6.19.0-edge-rockchip64 #1 SMP PREEMPT Sun Feb 8 21:03:27 UTC 2026 aarch64 GNU/Linux root@odroidtest:~# iperf3 -c 192.168.0.1 Connecting to host 192.168.0.1, port 5201 [ 5] local 192.168.0.15 port 35634 connected to 192.168.0.1 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 113 MBytes 950 Mbits/sec 0 1.81 MBytes [ 5] 1.00-2.00 sec 111 MBytes 933 Mbits/sec 0 1.81 MBytes [ 5] 2.00-3.00 sec 112 MBytes 944 Mbits/sec 0 1.81 MBytes [ 5] 3.00-4.00 sec 113 MBytes 947 Mbits/sec 0 1.81 MBytes [ 5] 4.00-5.00 sec 112 MBytes 941 Mbits/sec 0 1.81 MBytes [ 5] 5.00-6.00 sec 111 MBytes 933 Mbits/sec 0 1.81 MBytes [ 5] 6.00-7.00 sec 113 MBytes 948 Mbits/sec 0 1.81 MBytes [ 5] 7.00-8.00 sec 111 MBytes 934 Mbits/sec 1 929 KBytes [ 5] 8.00-9.00 sec 113 MBytes 948 Mbits/sec 0 929 KBytes [ 5] 9.00-10.00 sec 113 MBytes 944 Mbits/sec 0 929 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 1.10 GBytes 942 Mbits/sec 1 sender [ 5] 0.00-10.00 sec 1.09 GBytes 939 Mbits/sec receiver iperf Done. Armbian v26.5.1 - edge kernel 7.1 - OK root@odroidtest:~# grep -a --null-data U-Boot /dev/mtd0ro U-Boot SPL 2026.01_armbian-2026.01-S127a-Pb401-H8652-Vab81-Bd0d2-R448a (May 20 2026 - 22:28:40 +0000) root@odroidtest:~# uname -a Linux odroidtest 7.1.0-edge-rockchip64 #1 SMP PREEMPT Sun Jun 14 14:58:38 UTC 2026 aarch64 GNU/Linux root@odroidtest:~# iperf3 -c 192.168.0.1 Connecting to host 192.168.0.1, port 5201 [ 5] local 192.168.0.15 port 37256 connected to 192.168.0.1 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 114 MBytes 958 Mbits/sec 0 1.72 MBytes [ 5] 1.00-2.00 sec 111 MBytes 933 Mbits/sec 0 1.72 MBytes [ 5] 2.00-3.00 sec 113 MBytes 948 Mbits/sec 0 1.72 MBytes [ 5] 3.00-4.00 sec 112 MBytes 944 Mbits/sec 0 1.72 MBytes [ 5] 4.00-5.00 sec 112 MBytes 936 Mbits/sec 0 1.72 MBytes [ 5] 5.00-6.00 sec 113 MBytes 947 Mbits/sec 0 1.72 MBytes [ 5] 6.00-7.00 sec 112 MBytes 935 Mbits/sec 0 1.72 MBytes [ 5] 7.00-8.00 sec 113 MBytes 945 Mbits/sec 0 1.72 MBytes [ 5] 8.00-9.00 sec 112 MBytes 943 Mbits/sec 0 2.19 MBytes [ 5] 9.00-10.00 sec 112 MBytes 937 Mbits/sec 0 2.19 MBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 1.10 GBytes 943 Mbits/sec 0 sender [ 5] 0.00-10.00 sec 1.10 GBytes 941 Mbits/sec receiver iperf Done.
  10. Last week
  11. Next week we'll be in Santa Fe, Argentina, for DebConf 2026! Catch our 2 talks covering the latest Apertis developments and toolkits in Debian. View the full article
  12. This week's updates center on expanded board support, Rockchip and Qualcomm platform maturation, and build system refinements. New hardware coverage grew across multiple SoC families, with the Lubancat 5IO (RK3588), KickPi K3B, Mellow Fly C5 3D printer board, and community support for the Orange Pi Zero 3W (Allwinner A733). The Arduino UNO Q advanced to mainline 7.1 on the edge kernel and gained desktop hardware acceleration via Mesa pinned to Trixie backports, while the BeagleY-AI received ISP, IMX219, and VPAC patches. Companion fixes addressed NVMe/SD boot conflicts on the NanoPi M6, Ethernet on the BigTreeTech CB1, and AIC8800 UART Bluetooth on Orange Pi A733 hardware. Rockchip work concentrated on the YY3588 and CM3588-NAS platforms, with device tree cleanups, a corrected HDMI-RX detect GPIO, and quieter DRM logging for dw-hdmi-qp and dw-dp bridges. Newer bl31, bl32, and DDR blobs landed for RK3576, and stale U-Boot was refreshed fleet-wide to resolve a SWIG build break. On the Qualcomm side, SC8280XP was refactored from a board to a family configuration, and the Radxa Dragon Q8B gained UFS image provisioning, QDL flashing support via the imager, and a mainline 7.1 edge target for the Q6A variant. Build and tooling improvements included a new show-extensions CLI command, a switch from the adduser suite to useradd/groupadd during first login, non-interactive Dpkg conffile handling in chroot, and clang compatibility fixes for carried Rockchip64 patches and SpacemiT RTL8852BS builds. The mainline kernel target advanced to 7.2-rc2, and MGLRU was enabled across sunxi, sunxi64, and sun60iw2 kernel configurations. #Armbian #EmbeddedLinux #Rockchip #Qualcomm #SBC ChangesAdd board: Lubancat 5IO (RK3588). by @lch08 in armbian/build#10029Add kickpi-k3b board and KICKPI vendor image. by @retro98boy in armbian/armbian.github.io#355Arduino UNO Q: bump edge kernel to mainline 7.1. by @SuperKali in armbian/build#10171arduino-uno-q: add BOARD_MAINTAINER, INTRODUCED, KERNEL_TEST_TARGET. by @igorpecovnik in armbian/build#10161arduino-uno-q: enable desktop hardware acceleration in Debian Trixie by pinning Mesa to trixie-backports. by @sdeleeuw in armbian/build#10160arm64: dts: rockchip: fix dynamic dclk for CM3588-NAS. by @rpardini in armbian/linux-rockchip#502arm64: dts: rockchip: overlay: yy3588: disable eDP overlay temporarily. by @SuperKali in armbian/linux-rockchip#509arm64: dts: rockchip: yy3588: drop non-existent SPI NOR flash. by @SuperKali in armbian/linux-rockchip#512arm64: dts: rockchip: yy3588: drop unused wifi_disable regulator. by @SuperKali in armbian/linux-rockchip#510BeagleY-AI Add Patches for ISP + IMX219 & VPAC. by @Grippy98 in armbian/build#10129Bigtreetech CB2: bump u-boot to 2026.04. by @JohnTheCoolingFan in armbian/build#10144boards/youyeetoo-yy3588: name audio outputs on pipewire too. by @SuperKali in armbian/build#10146cli: add show-extensions command to list extension hook points. by @iav in armbian/build#10023config: build and expose q8b UFS images on the debian:trixie base. by @SuperKali in armbian/os#478config: drop radxa-dragon-q6a from apps and community trixie base. by @SuperKali in armbian/os#479desktops: add libspa-0.2-bluetooth for OOB Bluetooth headphone audio. by @igorpecovnik in armbian/configng#948drm/bridge: dw-hdmi-qp: limit DDC i2c retries on NACK. by @SuperKali in armbian/linux-rockchip#513drm/rockchip: dw-dp: ratelimit AUX timeout logging. by @SuperKali in armbian/linux-rockchip#514feat(qdl): serve the board registry from the API. by @SuperKali in armbian/imager#163Feat: Add support for the Mellow Fly C5 3D Printer board. by @deece in armbian/build#9584feat: flash locally-built UFS images over QDL. by @SuperKali in armbian/imager#164firstlogin: use useradd/groupadd instead of the adduser suite. by @igorpecovnik in armbian/build#10127Fix ethernet on BigTreeTech CB1. by @JohnTheCoolingFan in armbian/build#10155fix(chroot): add Dpkg conffile options to prevent interactive prompts. by @Grippy98 in armbian/build#10134fix: stop setting LC_ALL in armbian-lang.sh. by @saschabuehrle in armbian/build#10132generate-build-lists: only gate manual runs on team membership. by @igorpecovnik in armbian/armbian.github.io#353jethome: fix jethub-burn extension: add BETA=yes support. by @adeepn in armbian/build#10152k3-beagle: fix malformed csi0-imx219 overlay patch (bad hunk count). by @igorpecovnik in armbian/build#10136kde-neon: switch to resolute base, then disable (broken). by @igorpecovnik in armbian/configng#949kickpik2b: Change vendor from SoC-level to board-level (KICKPI). by @retro98boy in armbian/build#10143mainline: bump to 7.2-rc2. by @EvilOlaf in armbian/build#10150Makena: add SC8280XP firehose and Radxa Dragon Q8B UFS provisioning. by @SuperKali in armbian/qcombin#3media: rockchip: hdmirx: quiet signal-not-lock polling spam. by @SuperKali in armbian/linux-rockchip#515Meson64: Update Waveshare CM4-IO-BASE-B DTS and add emc2305 fixups for driver to BLEEDINGEDGE branch. by @pyavitz in armbian/build#10169nanopi-m6: fix nvme prevents sd card from booting. by @efectn in armbian/build#10170orangepizero3w: Add community support for Orange Pi Zero 3W (Allwinner A733). by @shkolnik in armbian/build#10103Radxa Dragon Q6A: add mainline 7.1 edge kernel target. by @SuperKali in armbian/build#10162release-targets: add radxa-dragon-q8b with ufs extension. by @SuperKali in armbian/armbian.github.io#354rk3576: newer blobs bl31/bl32/ddr. by @rpardini in armbian/rkbin#49rockchip64: fix clang -Wincompatible-pointer-types-discards-qualifiers in carried patches. by @iav in armbian/build#10140rockchip64: yy3588: fix HDMI-RX detect GPIO to GPIO1_D5. by @SuperKali in armbian/build#10151rockchip: bump stale u-boot to fix the SWIG build break (fleet). by @igorpecovnik in armbian/build#10107SC8280XP: Initial refactor from board to family config. by @HeyMeco in armbian/build#9818SpacemiT: Add a current branch to the K3 and update K1 current kernel source URL. by @pyavitz in armbian/build#10138spacemit: rtl8852bs: guard GCC-only warning flags for clang builds. by @iav in armbian/build#10139sun60iw2: bring up AIC8800 UART Bluetooth on the Orange Pi A733 boards. by @shkolnik in armbian/build#10149sunxi, sunxi64, sun60iw2: enable MGLRU in kernel config. by @ValdikSS in armbian/build#10133sunxi: mellowflyc5: port U-Boot to v2026.07 & enable network boot. by @deece in armbian/build#10165Use relative symbolic links for some BSP files. by @retro98boy in armbian/build#10145View the full article
  13. This week's updates center on expanded board support, Rockchip and Qualcomm platform maturation, and build system refinements. New hardware coverage grew across multiple SoC families, with the Lubancat 5IO (RK3588), KickPi K3B, Mellow Fly C5 3D printer board, and community support for the Orange Pi Zero 3W (Allwinner A733). The Arduino UNO Q advanced to mainline 7.1 on the edge kernel and gained desktop hardware acceleration via Mesa pinned to Trixie backports, while the BeagleY-AI received ISP, IMX219, and VPAC patches. Companion fixes addressed NVMe/SD boot conflicts on the NanoPi M6, Ethernet on the BigTreeTech CB1, and AIC8800 UART Bluetooth on Orange Pi A733 hardware. Rockchip work concentrated on the YY3588 and CM3588-NAS platforms, with device tree cleanups, a corrected HDMI-RX detect GPIO, and quieter DRM logging for dw-hdmi-qp and dw-dp bridges. Newer bl31, bl32, and DDR blobs landed for RK3576, and stale U-Boot was refreshed fleet-wide to resolve a SWIG build break. On the Qualcomm side, SC8280XP was refactored from a board to a family configuration, and the Radxa Dragon Q8B gained UFS image provisioning, QDL flashing support via the imager, and a mainline 7.1 edge target for the Q6A variant. Build and tooling improvements included a new show-extensions CLI command, a switch from the adduser suite to useradd/groupadd during first login, non-interactive Dpkg conffile handling in chroot, and clang compatibility fixes for carried Rockchip64 patches and SpacemiT RTL8852BS builds. The mainline kernel target advanced to 7.2-rc2, and MGLRU was enabled across sunxi, sunxi64, and sun60iw2 kernel configurations. #Armbian #EmbeddedLinux #Rockchip #Qualcomm #SBC ChangesAdd board: Lubancat 5IO (RK3588). by @lch08 in armbian/build#10029Add kickpi-k3b board and KICKPI vendor image. by @retro98boy in armbian/armbian.github.io#355Arduino UNO Q: bump edge kernel to mainline 7.1. by @SuperKali in armbian/build#10171arduino-uno-q: add BOARD_MAINTAINER, INTRODUCED, KERNEL_TEST_TARGET. by @igorpecovnik in armbian/build#10161arduino-uno-q: enable desktop hardware acceleration in Debian Trixie by pinning Mesa to trixie-backports. by @sdeleeuw in armbian/build#10160arm64: dts: rockchip: fix dynamic dclk for CM3588-NAS. by @rpardini in armbian/linux-rockchip#502arm64: dts: rockchip: overlay: yy3588: disable eDP overlay temporarily. by @SuperKali in armbian/linux-rockchip#509arm64: dts: rockchip: yy3588: drop non-existent SPI NOR flash. by @SuperKali in armbian/linux-rockchip#512arm64: dts: rockchip: yy3588: drop unused wifi_disable regulator. by @SuperKali in armbian/linux-rockchip#510BeagleY-AI Add Patches for ISP + IMX219 & VPAC. by @Grippy98 in armbian/build#10129Bigtreetech CB2: bump u-boot to 2026.04. by @JohnTheCoolingFan in armbian/build#10144boards/youyeetoo-yy3588: name audio outputs on pipewire too. by @SuperKali in armbian/build#10146cli: add show-extensions command to list extension hook points. by @iav in armbian/build#10023config: build and expose q8b UFS images on the debian:trixie base. by @SuperKali in armbian/os#478config: drop radxa-dragon-q6a from apps and community trixie base. by @SuperKali in armbian/os#479desktops: add libspa-0.2-bluetooth for OOB Bluetooth headphone audio. by @igorpecovnik in armbian/configng#948drm/bridge: dw-hdmi-qp: limit DDC i2c retries on NACK. by @SuperKali in armbian/linux-rockchip#513drm/rockchip: dw-dp: ratelimit AUX timeout logging. by @SuperKali in armbian/linux-rockchip#514feat(qdl): serve the board registry from the API. by @SuperKali in armbian/imager#163Feat: Add support for the Mellow Fly C5 3D Printer board. by @deece in armbian/build#9584feat: flash locally-built UFS images over QDL. by @SuperKali in armbian/imager#164firstlogin: use useradd/groupadd instead of the adduser suite. by @igorpecovnik in armbian/build#10127Fix ethernet on BigTreeTech CB1. by @JohnTheCoolingFan in armbian/build#10155fix(chroot): add Dpkg conffile options to prevent interactive prompts. by @Grippy98 in armbian/build#10134fix: stop setting LC_ALL in armbian-lang.sh. by @saschabuehrle in armbian/build#10132generate-build-lists: only gate manual runs on team membership. by @igorpecovnik in armbian/armbian.github.io#353jethome: fix jethub-burn extension: add BETA=yes support. by @adeepn in armbian/build#10152k3-beagle: fix malformed csi0-imx219 overlay patch (bad hunk count). by @igorpecovnik in armbian/build#10136kde-neon: switch to resolute base, then disable (broken). by @igorpecovnik in armbian/configng#949kickpik2b: Change vendor from SoC-level to board-level (KICKPI). by @retro98boy in armbian/build#10143mainline: bump to 7.2-rc2. by @EvilOlaf in armbian/build#10150Makena: add SC8280XP firehose and Radxa Dragon Q8B UFS provisioning. by @SuperKali in armbian/qcombin#3media: rockchip: hdmirx: quiet signal-not-lock polling spam. by @SuperKali in armbian/linux-rockchip#515Meson64: Update Waveshare CM4-IO-BASE-B DTS and add emc2305 fixups for driver to BLEEDINGEDGE branch. by @pyavitz in armbian/build#10169nanopi-m6: fix nvme prevents sd card from booting. by @efectn in armbian/build#10170orangepizero3w: Add community support for Orange Pi Zero 3W (Allwinner A733). by @shkolnik in armbian/build#10103Radxa Dragon Q6A: add mainline 7.1 edge kernel target. by @SuperKali in armbian/build#10162release-targets: add radxa-dragon-q8b with ufs extension. by @SuperKali in armbian/armbian.github.io#354rk3576: newer blobs bl31/bl32/ddr. by @rpardini in armbian/rkbin#49rockchip64: fix clang -Wincompatible-pointer-types-discards-qualifiers in carried patches. by @iav in armbian/build#10140rockchip64: yy3588: fix HDMI-RX detect GPIO to GPIO1_D5. by @SuperKali in armbian/build#10151rockchip: bump stale u-boot to fix the SWIG build break (fleet). by @igorpecovnik in armbian/build#10107SC8280XP: Initial refactor from board to family config. by @HeyMeco in armbian/build#9818SpacemiT: Add a current branch to the K3 and update K1 current kernel source URL. by @pyavitz in armbian/build#10138spacemit: rtl8852bs: guard GCC-only warning flags for clang builds. by @iav in armbian/build#10139sun60iw2: bring up AIC8800 UART Bluetooth on the Orange Pi A733 boards. by @shkolnik in armbian/build#10149sunxi, sunxi64, sun60iw2: enable MGLRU in kernel config. by @ValdikSS in armbian/build#10133sunxi: mellowflyc5: port U-Boot to v2026.07 & enable network boot. by @deece in armbian/build#10165Use relative symbolic links for some BSP files. by @retro98boy in armbian/build#10145View the full article
  14. Link Star H68K is, according to multiple sources, exactly the same as Hinlink H68K. But that's not the problem (yet). I'd been using an old version of RKDevTool (2.84 IIRC) which was unable to load the .img file from the Armbian site, but uninformative as to the nature of the problem. Updating to RKDevTool 3.37 at least yielded an error message when attempting to load the image: Googling this suggests a corrupted download (not the problem here, the SHA sum matches) or a raw .img format rather than the packed .img format expected by RKDevTool. So I compiled an image according to the Armbian Build Framework instructions. Same error message. More Googling suggests that a couple of Linux CLI utilities, upgrade_tool or rkdeveloptool, may be able to flash a raw image to the board's EMMC. More later...
  15. With the aid of Claude.Ai .. v26.5.1 for Rock 5A running Armbian Linux 6.18.35-current-rockchip64 Starting Point is the Radxa DTS needed to add an include ... #include <dt-bindings/soc/rockchip,vop2.h> Modified this section. Changed the compatible string, added the power-supply key and fixed the active area (width and height) dsi0_panel: panel@0 { status = "okay"; compatible = "panel-dsi-simple"; reg = <0>; backlight = <&dsi0_backlight>; power-supply = <&vcc_lcd_mipi0>; vdd-supply = <&vcc_lcd_mipi0>; vccio-supply = <&vcc_1v8_s0>; reset-gpios = <&gpio3 RK_PC1 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&dsi0_lcd_rst_gpio>; prepare-delay-ms = <120>; reset-delay-ms = <120>; init-delay-ms = <120>; enable-delay-ms = <100>; disable-delay-ms = <120>; unprepare-delay-ms = <120>; width-mm = <135>; height-mm = <217>; Modified this section (renamed the endpoint) &mipi_dcphy0 { status = "okay"; }; &route_dsi0 { status = "okay"; connect = <&vp3_out_dsi0>; }; &dsi0_in_vp2 { status = "disabled"; }; &dsi0_in_vp3 { status = "okay"; }; to simply &mipidcphy0 { status = "okay"; }; Added this section / endpoint &vp3 { #address-cells = <1>; #size-cells = <0>; vp3_out_dsi0: endpoint@ROCKCHIP_VOP2_EP_MIPI0 { reg = <ROCKCHIP_VOP2_EP_MIPI0>; remote-endpoint = <&dsi0_in_vp3>; }; }; And then completely redid the i2c touch controller section to be &i2c5 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c5m2_xfer>; clock-frequency = <400000>; #address-cells = <1>; #size-cells = <0>; gt9xx: gt9271@14 { status = "okay"; compatible = "goodix,gt9271"; reg = <0x14>; pinctrl-names = "default"; pinctrl-0 = <&gt9xx_gpio>; interrupt-parent = <&gpio3>; interrupts = <RK_PC6 IRQ_TYPE_EDGE_FALLING>; irq-gpios = <&gpio3 RK_PC6 GPIO_ACTIVE_HIGH>; reset-gpios = <&gpio3 RK_PC5 GPIO_ACTIVE_HIGH>; touchscreen-size-x = <1200>; touchscreen-size-y = <1920>; AVDD28-supply = <&vcc_tp>; VDDIO-supply = <&vcc_tp>; }; Final DTS is attached. Worked for 6.18.53. I had Claude write a bash script to pull everything and make the required changes and compile the device tree and can make it available, if needed. rock-5a-radxa-display-10fhd.dts
  16. @Guido Giuntoli You are a candidate to test the new feature. https://github.com/armbian/build/pull/10113
  17. I successfully got the Radxa Display10FHD display working this weekend on Armbian 26.5.1 (Gnome) after extensive Claude AI help in fixing default Radxa DTS. I'll do a separate post / topic for that but it involved refactoring some of the endpoints, adding a missing header and fixing the touchscreen driver name. I used Claude and it was really helpful.
  18. Hi @Nick A — great work on these builds, I've been testing both your BSP (v0.6.4, kernel 6.6.98) and Mainline (V0.1, kernel 6.18.19) images on a Cubie A7Z with a custom carrier board. Both work well for general use. I've been trying to get a W5500 SPI-to-Ethernet chip working on SPI2 and ran into a consistent issue across both kernels that might be worth looking at. Issue: sunxi-spi-ng child device never gets probed The SPI2 controller itself initialises correctly on both kernels: sunxi-spi-ng 2542000.spi: probe success (Version 2.5.4) But the child device (spi2.0) never gets a driver bound to it. The w5100-spi driver is loaded, the modalias matches (spi:w5500), fw_devlink=off is set, yet: echo spi2.0 | tee /sys/bus/spi/drivers/w5100/bind → No such device echo spi2.0 | tee /sys/bus/spi/drivers_probe → accepted, no effect, zero dmesg output Dynamic debug enabled (module w5100 +p) → zero probe activity This reproduces on: Radxa BSP kernel 5.15.147-21-a733 (official r6 image) Your BSP build kernel 6.6.98 Your Mainline build kernel 6.18.19 All three use the same spi-sunxi-ng.ko / spi_sunxi_ng driver (same allwinner,sunxi-spi-v1.3 compatible string). Hardware confirmed good: the same W5500 chip on the same physical pins works perfectly when an ESP32-S3 is plugged in instead — DHCP, real network data, everything. Raw spidev access on the Radxa also reads correct W5500 registers. The bug is specifically in sunxi-spi-ng's child device registration preventing any driver from binding. Overlay used: dts /dts-v1/; /plugin/; &spi2 { status = "okay"; sunxi,spi-bus-mode = <1>; sunxi,spi-cs-mode = <0>; eth0: ethernet@0 { compatible = "wiznet,w5500"; reg = <0>; spi-max-frequency = <20000000>; }; }; Note: sunxi,spi-bus-mode = <0> is rejected at probe time with error -22 ("unsupport hw bus mode 0x0"), so <1> is the only accepted value. Has anyone else seen this? Is there a known workaround for getting SPI child devices to bind under sunxi-spi-ng on A733?
  19. nevermind, it can infact run armbian, but only by booting using a usb stick(change root drive using bootargs) only. The fx6 still have an un-bypassable secure boot, so booting using usb stick is the only option here, also it works great with the banana pi m4's firmware
  20. @erebus041 were you able to install Armbian on the TV box?
  21. No. There is basically no open source resources going to the amlogic CPUs these days. Generally Amlogic doesn't support or help open source development, so most developers have moved on to other platforms (rockchip and allwinner) that are somewhat more supportive.
  22. split into new topic for the reason above.
  23. Sorry Ryzer, I missed your last post. For the WiFi, I use morrow_nr drivers, it is a lengthy process to compile the driver, but it works. This is the wifi dongle, using RTL8812BU: https://www.amazon.com.au/Adapter-(AC1200-867Mbps-WPS,Support-10-6-10-15/dp/B09BNJPQYT What I also found is that a significant change has happened between kernel 5 and 6 with regards to OTG. I tried to lay with that a bit, but I am out of my depth and didn't get anywhere with it: &usbotg_hs { compatible = "st,stm32mp15-hsotg", "snps,dwc2"; dr_mode = "otg"; usb-role-switch; <------ this is the major change between kernel 5 and 6 wrt OTG /* Other DWC2 specific properties and PHY configuration / ... }; Then on the user side, setting up the gadget requires the following: To switch to device mode echo "device" > /sys/class/usb_role/.dwc2-role-switch/role To switch to host mode echo "host" > /sys/class/usb_role/*.dwc2-role-switch/role
  24. @y52 very cool!
  25. Hey, thanks for the PSU suggestion! I actually tested the power theory by stripping all USB accessories (dongles, hubs, keyboard) and running just the board + HDMI, but it still drops to initramfs. I also know the PSU and hardware are 100% good because DietPi boots perfectly on this exact same setup. I dug around in the initramfs shell and ran blkid. Here is the output: /dev/mmcblk1: PTUUID="[uuid]" PTTYPE="gpt" The issue: The kernel sees the raw SD card, but it's completely blind to the partitions (p1, p2). It looks like this specific build might be missing the ext4 drivers in the initramfs, which is why it can't find the UUID to mount the rootfs. For the devs, here is the exact image causing the issue: Armbian_26.2.1_Radxa-zero3_trixie_vendor_6.1.115_minimal.img (Flashed via BalenaEtcher, verified successfully, and ignored all Windows format prompts). I'm switching over to the official Radxa Debian image for now so I can finally get my onboard AIC8800 Wi-Fi working, but I wanted to drop these debug notes here in case this is a regression in the recent build.
  26. It's and old Allwinner chip, ARMv7-based. GPU is PowerVR SGX544MP1, which is not supported in Mesa and will not work in Armbian. Wi-Fi is AP6212, a Broadcom/Synaptics SYN43436S chip, should work fine. Armbian build for M3 is community-supported, by @AaronNGray. Maybe they'll shed more light on this board.
