  2. Actually, hope is not all lost. The image downloaded for the 4c from Armbian. Has the sources set to beta. So, I changed them and was able to install armbian-config. Although it isn't officially supported on the version I'm using. It does the job. Disabled kernel and firmware updating. Also, add Radxa's Bookworm repo. Ran a upgrade and all is well. Should last me a few years. Until the day I decide I want to throw a bunch of my time at an other SBC.
  3. @John Taylor I finally had some time to test this today and it is working fine for me. I built a fresh image on an ubuntu laptop, copied the image to a SD card, it mounted fine on ubuntu, where I edited the extlinux.conf file and then used the SD card to boot on an amlogic based TV box. You mention etcher as your sd card tool. Etcher in recent versions (recent being the last two years or so) is known to have problems. It is no longer recommended for use with Armbian images. I have noticed that in particular if Etcher is burning a compressed image it doesn't work for me. But I have had some success if the image is uncompressed first. But others have reported that it fails in general.
  5. First of all, thank you to @Hqnicolas and all the members for this great effort. Just bought an H96 rk3566, having this hardware configuration: BOARD LABEL: HCY-RK3566-1X32-V20 2023-01-13 SOC RK3566 PMIC RK809-5 LAN RTL8211F DISPLAY FD6551 WIFI AIC8800D40 eMMC H26M74002HMR - SK Hynix eMMC 5.1 NAND Flash 64Gb. It seems to be a mix of the other versions described in this topic, although very close to the one of @WINEDS (thanks for the hints). Everything seems to work so far. Installed using rockchip dev tools, as advised. here its: _ _ _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ __ ___ _ __ _ __ _ _ _ _ (_) |_ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ / _/ _ \ ' \| ' \ || | ' \| | _| || | /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|_\__\___/_|_|_|_|_|_\_,_|_||_|_|\__|\_, | |___| |__/ v26.2 rolling for h96-tvbox-3566 running Armbian Linux 6.12.61-current-rockchip64 Packages: Debian stable (trixie) Support: for advanced users (rolling release) IPv4: (LAN) 192.168.111.228, 192.168.111.91 (WAN) xxxxxxxxxxx Containers: big-bear-photoprism-db Performance: Load: 8% Uptime: 46 minutes Memory usage: 6% of 7.50G CPU temp: 38°C Usage of /: 31% of 57G To enable Bluetooth I have used this small overlay in /boot/overlay-user/ (which enables SPDIF as well): /dts-v1/; /plugin/; /* &{/serial@fe650000} */ &uart1 { status = "okay"; dma-names = "tx\0rx"; bluetooth { status = "disabled"; }; }; &spdif { clock-names = "mclk\0hclk"; status="okay"; }; The followings are the drivers used for wifi-bluetooth wget https://github.com/radxa-pkg/aic8800/releases/download/4.0%2Bgit20250410.b99ca8b6-3/aic8800-firmware_4.0+git20250410.b99ca8b6-3_all.deb wget https://github.com/radxa-pkg/aic8800/releases/download/4.0%2Bgit20250410.b99ca8b6-3/aic8800-sdio-dkms_4.0+git20250410.b99ca8b6-3_all.deb dpkg -i aic8800-firmware_4.0+git20250410.b99ca8b6-3_all.deb dpkg -i aic8800-sdio-dkms_4.0+git20250410.b99ca8b6-3_all.deb Service to enable bluetooth : [Unit] Description=Bluetooth HCI Attach (AIC8800) After=systemd-modules-load.service Requires=systemd-modules-load.service After=dev-ttyS1.device Requires=dev-ttyS1.device [Service] Type=oneshot # Load AIC module ExecStartPre=/sbin/modprobe aic8800_btlpm_sdio # Just a small delay ExecStartPre=/bin/sleep 2 # Attach HCI ExecStart=/usr/bin/hciattach -s 1500000 /dev/ttyS1 any 1500000 flow nosleep To re-enable display in Linux 6.12 another small overlay is required: (the display itself it is not scrolling and available at: /sys/class/leds/display/value ) /dts-v1/; /plugin/; &{/i2c-aux-display} { compatible = "i2c-gpio"; #address-cells = <0x01>; #size-cells = <0x00>; display@24 { compatible = "fdhisi,fd6551"; reg = <0x24>; #address-cells = <0x01>; #size-cells = <0x00>; tm16xx,digits = [04 03 02 01]; tm16xx,segment-mapping = [00 01 02 03 04 05 06]; led@0,0 { reg = <0x00 0x00>; function = "alarm"; }; led@0,1 { reg = <0x00 0x01>; function = "usb"; linux,default-trigger = "usb-host"; }; led@0,2 { reg = <0x00 0x02>; function = "pause"; linux,default-trigger = "mmc2"; }; led@0,3 { reg = <0x00 0x03>; function = "play"; linux,default-trigger = "mmc0"; }; led@0,4 { reg = <0x00 0x04>; function = "colon"; }; led@0,5 { reg = <0x00 0x05>; function = "lan"; linux,default-trigger = "stmmac-0:00:link"; }; led@0,6 { reg = <0x00 0x06>; function = "wlan"; linux,default-trigger = "mmc1"; }; digits { status = "disabled"; }; leds { status = "disabled"; }; }; }; rk3566-bt-fix.dtso rk3566-led-fix.dtso
  6. My solution is to compile the image like this: ./compile.sh INSTALL_HEADERS=yes Then scp the driver on the machine, and execute echo "obj-m += panel-mtf0397swi.o" > Makefile make -C /lib/modules/`uname -r`/build M=$PWD cp panel-mtf0397swi.ko /lib/modules/$(uname -r)/kernel/drivers/gpu/drm/panel/ depmod -a
  7. Hi @eselarm, thanks for the detailed response. I've checked my boot.cmd and boot.scr is ancient ( from Aug 2023 ). I'm going to try to set the variables beforehand, as I see in the output they are blank ( devtype, devnum, prefix ). When I succeed I guess the next step will be to set these variables in U-Boot, but nowadays there's no gpt partition table in SPI with the uboot_env, so I guess will need to figure it out later ( via env or find the boot.scr in the NVMe ), first I want to try to boot from NVMe manually. Thanks again
  8. Hello everyone,does anyone have working armbian for rockchip 3228a with lpddr3 for x96q V20?
  9. Easy is what standard Debian (12 and 13) does: NetworkManager and openresolv/resolvconf , even for complex setup of VLANs and bridges, Virtual Machines. Canonical/Ubuntu have invented netplan.io, so they manage NM and systemd-networkd with a yaml script. Easy for them as large organization for business customers. Might not for you as image downloader, as it introduces extra yaml while .nmconnection files are easy to copy between hosts. Also, systemd-resolved might be used, which is actually a sort of local DNS server. It should enable high performance I guess, by default caching enabled, but is that applicable for a simple ARM SBC connected to an ISP router, I don't know. I know is needs extra work for me. So you need to dig into that. Or not use Ubuntu at all. I anyway do not use images, only for testing for others, not to use them myself. It is simply using apt for (dist-)upgrades and so I use standard Debian upgrade method to get from Bookworm to Trixie and keep my KDE as I use that mostly. Also switching kernel, just via apt removals/installs and/or bootmanager. If you get stuck, use sudo nmtui to set an extra network profile connection with fixed IP, known DNS maybe. Done that many times to get things running although not permanent good solution.
  10. Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + DXVK-stripped v1.6.1 ~60fps@720p Left 4 Dead
  11. Hello, im trying to flash back Android in the nand, but i can't seem to be able to put the motherboard in maskrom mode. any help would be appreciated.
  12. Hello there. I have more or less the same request as @tmb I bought Helios64 when it came out and had to stop using it when the core team shut down in 2021. Since 2021, all storage has been managed by my Proxmox server. But I'm currently thinking about upgrading the hardware of my PC and my Proxmox server. And my Helios64 is still there, not being used for anything, which is a shame. Do you think that in 2025, we will be able to use the Helios64 as a NAS server for “family” storage and homelab storage needs ? If so, with which OS / App? Lastest Armbian / Openmediavault ? Thank you.
  13. Thank you for testing!
  14. Hey there! I’ve been running Home Assistant Supervised on Armbian for a while, but lately I keep seeing a repeat issue after system upgrades (Docker or kernel updates). After upgrading, some HA containers stop unexpectedly, for example: odroid-c2-homeassistant:2025.12.2 exits with code 137 aarch64-addon-configurator:5.8.0 exits with code 143 My current setup runs on Helios64/RK3399 · kernel 6.12.58-current-rockchip64 · Docker CE 29.1.3 (f52814d). After digging a bit, I noticed this line in dmesg right after the failures -> apparmor="DENIED" operation="signal" profile="hassio-supervisor" signal=kill I also found the small watchdog script (supervisor_fix.sh) that restarts the Supervisor when it reports unhealthy, but the upgrade breakage seems to slip through. I’m just thinking out loud here, but maybe something like a post-upgrade AppArmor refresh, or some other small adjustment, could help ? Not sure what makes the most sense, so any input would be really appreciated. Thanks for your time and for all the work you put into Armbian!
  15. meco
    Tech news feed
    The one time I used my iPad autocorrect comes to bite me
  16. For this device, ttyS2 is used for BT, but the problem was that the system was trying to use it for logging. After modifying that part in boot.cmd and rebooting, the firmware came up.
  17. Works just fine on last version. Thanks a lot !!! <pre> $ zcat /proc/config.gz | grep DP| grep ROCK CONFIG_ROCKCHIP_ANALOGIX_DP=y CONFIG_ROCKCHIP_CDN_DP=y CONFIG_ROCKCHIP_DW_DP=y CONFIG_PHY_ROCKCHIP_DP=y CONFIG_PHY_ROCKCHIP_DPHY_RX0=m CONFIG_PHY_ROCKCHIP_INNO_CSIDPHY=m CONFIG_PHY_ROCKCHIP_INNO_DSIDPHY=m CONFIG_PHY_ROCKCHIP_SAMSUNG_HDPTX=m CONFIG_PHY_ROCKCHIP_USBDP=m CONFIG_PHY_ROCKCHIP_DP=y </pre>
  18. Yesterday
  19. SCSI works fine with linux Mainline at least (6.16, 6.17 & 6.18) since few month now.
  20. my Rupa 88 Pro 20, wifi/bt chip is cdtech 208821c (rtl8821cs), with real 4g32 had no bluetooth with mmie4jbcu's dtb or the included box-demo.dtb. with a lil help from claude.ai, i mix mmie4jbcu's dtb with x96x6.dtb from another thread here. et voilá bluetooth is working after apt install armbian-firmware-full rk3566-box-X88PRO20.dtb
  21. So, here's what I had to do to successfully build the image. First, I corrected my board file in the config/board/orangepizero3.csc directory. The processor value was incorrect, it was 616, so I set it to 618. Menuconf suggested selecting a board with a 618 chip, but in the board file it was listed as family 616. Later, I copied my board file to the userpatches directory and added the value CONFIG_DRM_PANEL_MIPI_DBI=m. Then I ran the image build script with the menuconf viewer. I was surprised that the CONFIG_DRM_PANEL_MIPI_DBI parameter already had the value "m"; previously, it was empty. After all these manipulations, the build went smoothly. Thank you so much for your support.
  22. Hi I was able to build an image with the panel-mipi-dbi module enabled. My previous image had the module disabled, so it took me a couple of days to figure it out. As I found out, for my version of the board, which uses the 618 chip, I needed to adjust a line in the bootconfig to build my board. It specified the 616 chip. But that's probably not the reason for the success. After I built the image, applied the binary, and dts, the screen was still white after rebooting. user@orangepizero3:~/v0_ips_touch_display$ cd user@orangepizero3:~$ sudo modinfo panel-mipi-dbi filename: /lib/modules/6.16.8-edge-sunxi64/kernel/drivers/gpu/drm/tiny/panel-mipi-dbi.ko license: GPL author: Noralf Trønnes description: MIPI DBI compatible display panel driver alias: of:N*T*Cpanel-mipi-dbi-spiC* alias: of:N*T*Cpanel-mipi-dbi-spi alias: spi:panel-mipi-dbi-spi depends: drm_mipi_dbi,backlight intree: Y name: panel_mipi_dbi vermagic: 6.16.8-edge-sunxi64 SMP preempt mod_unload aarch64 user@orangepizero3:~$ dmesg | grep spi [ 2.466658] sun6i-spi 5010000.spi: Error applying setting, reverse things back [ 2.467167] sun6i-spi 5011000.spi: cannot register SPI host [ 2.474140] sun6i-spi 5010000.spi: Error applying setting, reverse things back [ 2.474558] sun6i-spi 5011000.spi: cannot register SPI host [ 3.584770] panel-mipi-dbi-spi spi1.0: supply power not found, using dummy regulator [ 3.603713] panel-mipi-dbi-spi spi1.0: supply io not found, using dummy regulator [ 3.603960] panel-mipi-dbi-spi spi1.0: Direct firmware load for panel-mipi-dbi-spi.bin failed with error -2 [ 3.603975] panel-mipi-dbi-spi spi1.0: No config file found for compatible 'panel-mipi-dbi-spi' (error=-2) [ 3.603983] panel-mipi-dbi-spi spi1.0: probe with driver panel-mipi-dbi-spi failed with error -2 [ 12.001666] OF: /soc/spi@5011000/ads7846@1: Read of boolean property 'ti,swap-xy' with a value. [ 12.001860] ads7846 spi1.1: supply vcc not found, using dummy regulator [ 12.004761] ads7846 spi1.1: touchscreen, irq 77 [ 12.007680] input: ADS7846 Touchscreen as /devices/platform/soc/5011000.spi/spi_master/spi1/spi1.1/input/input10 [ 12.018707] spi-nor spi0.0: supply vcc not found, using dummy regulator [ 12.018953] spi-nor spi0.0: supply vdd not found, using dummy regulator
  23. /dts-v1/; /memreserve/ 0x0000000048000000 0x0000000001000000; / { interrupt-parent = <0x1>; #address-cells = <0x2>; #size-cells = <0x2>; model = "sun50iw9"; compatible = "allwinner,h616", "arm,sun50iw9p1"; clocks { compatible = "allwinner,clk-init"; device_type = "clocks"; #address-cells = <0x2>; #size-cells = <0x2>; ranges; reg = <0x0 0x3001000 0x0 0x1000 0x0 0x7010000 0x0 0x400 0x0 0x7000000 0x0 0x4>; losc { #clock-cells = <0x0>; compatible = "allwinner,fixed-clock"; clock-frequency = <0x8000>; clock-output-names = "losc"; linux,phandle = <0x1e>; phandle = <0x1e>; }; iosc { #clock-cells = <0x0>; compatible = "allwinner,fixed-clock"; clock-frequency = <0xf42400>; clock-output-names = "iosc"; linux,phandle = <0x20>; phandle = <0x20>; }; hosc { #clock-cells = <0x0>; compatible = "allwinner,fixed-clock"; clock-frequency = <0x16e3600>; clock-output-names = "hosc"; linux,phandle = <0x9>; phandle = <0x9>; }; osc48m { #clock-cells = <0x0>; compatible = "allwinner,fixed-clock"; clock-frequency = <0x2dc6c00>; clock-output-names = "osc48m"; linux,phandle = <0xa>; phandle = <0xa>; }; hoscdiv32k { #clock-cells = <0x0>; compatible = "allwinner,fixed-clock"; clock-frequency = <0x8000>; clock-output-names = "hoscdiv32k"; linux,phandle = <0xe1>; phandle = <0xe1>; }; pll_periph0div25m { #clock-cells = <0x0>; compatible = "allwinner,fixed-clock"; clock-frequency = <0x17d7840>; clock-output-names = "pll_periph0div25m"; linux,phandle = <0xe2>; phandle = <0xe2>; }; pll_cpu { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; clock-output-names = "pll_cpu"; linux,phandle = <0xd5>; phandle = <0xd5>; }; pll_ddr0 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; clock-output-names = "pll_ddr0"; linux,phandle = <0xda>; phandle = <0xda>; }; pll_ddr1 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; clock-output-names = "pll_ddr1"; linux,phandle = <0xe3>; phandle = <0xe3>; }; pll_periph0 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; assigned-clocks = <0x2>; assigned-clock-rates = <0x23c34600>; lock-mode = "new"; clock-output-names = "pll_periph0"; linux,phandle = <0x2>; phandle = <0x2>; }; pll_periph1 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; assigned-clocks = <0x3>; assigned-clock-rates = <0x23c34600>; lock-mode = "new"; clock-output-names = "pll_periph1"; linux,phandle = <0x3>; phandle = <0x3>; }; pll_gpu { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; clock-output-names = "pll_gpu"; linux,phandle = <0xdc>; phandle = <0xdc>; }; pll_video0x4 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; clock-output-names = "pll_video0x4"; linux,phandle = <0x8>; phandle = <0x8>; }; pll_video1 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; assigned-clocks = <0x4>; assigned-clock-rates = <0x19bfcc00>; clock-output-names = "pll_video1"; linux,phandle = <0x4>; phandle = <0x4>; }; pll_video2 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; assigned-clocks = <0x5>; clock-output-names = "pll_video2"; linux,phandle = <0x5>; phandle = <0x5>; }; pll_ve { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; device_type = "clk_pll_ve"; lock-mode = "new"; clock-output-names = "pll_ve"; linux,phandle = <0x26>; phandle = <0x26>; }; pll_de { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; assigned-clocks = <0x6>; assigned-clock-rates = <0x297c1e00>; lock-mode = "new"; clock-output-names = "pll_de"; linux,phandle = <0x6>; phandle = <0x6>; }; pll_csi { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; lock-mode = "new"; clock-output-names = "pll_csi"; linux,phandle = <0xa5>; phandle = <0xa5>; }; pll_audiox4 { #clock-cells = <0x0>; compatible = "allwinner,pll-clock"; assigned-clocks = <0x7>; assigned-clock-rates = <0x5dc0000>; lock-mode = "new"; clock-output-names = "pll_audiox4"; linux,phandle = <0x7>; phandle = <0x7>; }; pll_periph0x2 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x2>; clock-mult = <0x2>; clock-div = <0x1>; clock-output-names = "pll_periph0x2"; linux,phandle = <0xc>; phandle = <0xc>; }; pll_periph0x4 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x2>; clock-mult = <0x4>; clock-div = <0x1>; clock-output-names = "pll_periph0x4"; linux,phandle = <0xe4>; phandle = <0xe4>; }; periph32k { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x2>; clock-mult = <0x2>; clock-div = <0x8f0d>; clock-output-names = "periph32k"; linux,phandle = <0xe5>; phandle = <0xe5>; }; pll_periph1x2 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x3>; clock-mult = <0x2>; clock-div = <0x1>; clock-output-names = "pll_periph1x2"; linux,phandle = <0x86>; phandle = <0x86>; }; pll_audio { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x7>; clock-mult = <0x1>; clock-div = <0x4>; clock-output-names = "pll_audio"; linux,phandle = <0x60>; phandle = <0x60>; }; pll_audiox2 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x7>; clock-mult = <0x1>; clock-div = <0x2>; clock-output-names = "pll_audiox2"; linux,phandle = <0xe6>; phandle = <0xe6>; }; pll_video0 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x8>; clock-mult = <0x1>; clock-div = <0x4>; clock-output-names = "pll_video0"; linux,phandle = <0xe7>; phandle = <0xe7>; }; pll_video1x4 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x4>; clock-mult = <0x4>; clock-div = <0x1>; clock-output-names = "pll_video1x4"; linux,phandle = <0xe8>; phandle = <0xe8>; }; pll_video2x4 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x5>; clock-mult = <0x4>; clock-div = <0x1>; clock-output-names = "pll_video2x4"; linux,phandle = <0xe9>; phandle = <0xe9>; }; hoscd2 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x9>; clock-mult = <0x1>; clock-div = <0x2>; clock-output-names = "hoscd2"; linux,phandle = <0xea>; phandle = <0xea>; }; osc48md4 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0xa>; clock-mult = <0x1>; clock-div = <0x4>; clock-output-names = "osc48md4"; linux,phandle = <0x52>; phandle = <0x52>; }; pll_periph0d6 { #clock-cells = <0x0>; compatible = "allwinner,fixed-factor-clock"; clocks = <0x2>; clock-mult = <0x1>; clock-div = <0x6>; clock-output-names = "pll_periph0d6"; linux,phandle = <0xeb>; phandle = <0xeb>; }; cpu { #clock-cells = <0x0>; compatible = "allwinner,cpu-clock"; clock-output-names = "cpu"; linux,phandle = <0xec>; phandle = <0xec>; }; axi { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "axi"; linux,phandle = <0xed>; phandle = <0xed>; }; cpuapb { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "cpuapb"; linux,phandle = <0xee>; phandle = <0xee>; }; psi { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "psi"; linux,phandle = <0xef>; phandle = <0xef>; }; ahb1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ahb1"; linux,phandle = <0xf0>; phandle = <0xf0>; }; ahb2 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ahb2"; linux,phandle = <0xf1>; phandle = <0xf1>; }; ahb3 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ahb3"; linux,phandle = <0xf2>; phandle = <0xf2>; }; apb1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "apb1"; linux,phandle = <0xf3>; phandle = <0xf3>; }; apb2 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "apb2"; linux,phandle = <0xb7>; phandle = <0xb7>; }; mbus { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "mbus"; linux,phandle = <0xf4>; phandle = <0xf4>; }; de { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clock-parents = <0x6>; assigned-clock-rates = <0x297c1e00>; assigned-clocks = <0xb>; clock-output-names = "de"; linux,phandle = <0xb>; phandle = <0xb>; }; g2d { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clock-parents = <0xc>; assigned-clock-rates = <0x11e1a300>; assigned-clocks = <0xd>; clock-output-names = "g2d"; linux,phandle = <0xd>; phandle = <0xd>; }; di { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clock-parents = <0xc>; assigned-clock-rates = <0x11e1a300>; assigned-clocks = <0xe>; clock-output-names = "di"; linux,phandle = <0xe>; phandle = <0xe>; }; gpu0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "gpu0"; linux,phandle = <0xdd>; phandle = <0xdd>; }; gpu1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "gpu1"; linux,phandle = <0xde>; phandle = <0xde>; }; ce { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ce"; linux,phandle = <0xb5>; phandle = <0xb5>; }; ve { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ve"; linux,phandle = <0x27>; phandle = <0x27>; }; dma { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "dma"; linux,phandle = <0x1f>; phandle = <0x1f>; }; msgbox { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "msgbox"; linux,phandle = <0x21>; phandle = <0x21>; }; hwspinlock_rst { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "hwspinlock_rst"; linux,phandle = <0x22>; phandle = <0x22>; }; hwspinlock_bus { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "hwspinlock_bus"; linux,phandle = <0x23>; phandle = <0x23>; }; hstimer { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "hstimer"; linux,phandle = <0xf5>; phandle = <0xf5>; }; avs { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "avs"; linux,phandle = <0xf6>; phandle = <0xf6>; }; dbgsys { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "dbgsys"; linux,phandle = <0xf7>; phandle = <0xf7>; }; pwm { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "pwm"; linux,phandle = <0x9b>; phandle = <0x9b>; }; iommu { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "iommu"; linux,phandle = <0xdb>; phandle = <0xdb>; }; sdram { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdram"; linux,phandle = <0xf8>; phandle = <0xf8>; }; nand0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "nand0"; linux,phandle = <0xbb>; phandle = <0xbb>; }; nand1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "nand1"; linux,phandle = <0xbc>; phandle = <0xbc>; }; sdmmc0_mod { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc0_mod"; linux,phandle = <0x8d>; phandle = <0x8d>; }; sdmmc0_bus { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc0_bus"; linux,phandle = <0x8e>; phandle = <0x8e>; }; sdmmc0_rst { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc0_rst"; linux,phandle = <0x8f>; phandle = <0x8f>; }; sdmmc1_mod { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc1_mod"; linux,phandle = <0x93>; phandle = <0x93>; }; sdmmc1_bus { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc1_bus"; linux,phandle = <0x94>; phandle = <0x94>; }; sdmmc1_rst { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc1_rst"; linux,phandle = <0x95>; phandle = <0x95>; }; sdmmc2_mod { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc2_mod"; linux,phandle = <0x87>; phandle = <0x87>; }; sdmmc2_bus { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc2_bus"; linux,phandle = <0x88>; phandle = <0x88>; }; sdmmc2_rst { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "sdmmc2_rst"; linux,phandle = <0x89>; phandle = <0x89>; }; uart0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "uart0"; linux,phandle = <0x29>; phandle = <0x29>; }; uart1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "uart1"; linux,phandle = <0x2c>; phandle = <0x2c>; }; uart2 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "uart2"; linux,phandle = <0x2f>; phandle = <0x2f>; }; uart3 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "uart3"; linux,phandle = <0x32>; phandle = <0x32>; }; uart4 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "uart4"; linux,phandle = <0x35>; phandle = <0x35>; }; uart5 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "uart5"; linux,phandle = <0x38>; phandle = <0x38>; }; twi0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "twi0"; linux,phandle = <0x3b>; phandle = <0x3b>; }; twi1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "twi1"; linux,phandle = <0x3e>; phandle = <0x3e>; }; twi2 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "twi2"; linux,phandle = <0x41>; phandle = <0x41>; }; twi3 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "twi3"; linux,phandle = <0x44>; phandle = <0x44>; }; twi4 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "twi4"; linux,phandle = <0x47>; phandle = <0x47>; }; scr0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "scr0"; linux,phandle = <0xb6>; phandle = <0xb6>; }; spi0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "spi0"; linux,phandle = <0x7d>; phandle = <0x7d>; }; spi1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "spi1"; linux,phandle = <0x81>; phandle = <0x81>; }; ephy_25m { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ephy_25m"; linux,phandle = <0xcd>; phandle = <0xcd>; }; gmac0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "gmac0"; linux,phandle = <0xcc>; phandle = <0xcc>; }; gmac1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "gmac1"; linux,phandle = <0xd0>; phandle = <0xd0>; }; gpadc { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "gpadc"; linux,phandle = <0xca>; phandle = <0xca>; }; ts { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ts"; linux,phandle = <0xc0>; phandle = <0xc0>; }; ths { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ths"; linux,phandle = <0xc3>; phandle = <0xc3>; }; spdif { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "spdif"; linux,phandle = <0x61>; phandle = <0x61>; }; dmic { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "dmic"; linux,phandle = <0x64>; phandle = <0x64>; }; codec_1x { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "codec_1x"; linux,phandle = <0x67>; phandle = <0x67>; }; codec_4x { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "codec_4x"; linux,phandle = <0xf9>; phandle = <0xf9>; }; ahub { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "ahub"; linux,phandle = <0x6a>; phandle = <0x6a>; }; usbphy0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbphy0"; linux,phandle = <0x4d>; phandle = <0x4d>; }; usbphy1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbphy1"; linux,phandle = <0x54>; phandle = <0x54>; }; usbphy2 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbphy2"; linux,phandle = <0x58>; phandle = <0x58>; }; usbphy3 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbphy3"; linux,phandle = <0x5c>; phandle = <0x5c>; }; usbohci0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci0"; linux,phandle = <0x50>; phandle = <0x50>; }; usbohci0_12m { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci0_12m"; linux,phandle = <0x51>; phandle = <0x51>; }; usbohci1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci1"; linux,phandle = <0x56>; phandle = <0x56>; }; usbohci1_12m { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci1_12m"; linux,phandle = <0x57>; phandle = <0x57>; }; usbohci2 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci2"; linux,phandle = <0x5a>; phandle = <0x5a>; }; usbohci2_12m { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci2_12m"; linux,phandle = <0x5b>; phandle = <0x5b>; }; usbohci3 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci3"; linux,phandle = <0x5e>; phandle = <0x5e>; }; usbohci3_12m { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbohci3_12m"; linux,phandle = <0x5f>; phandle = <0x5f>; }; usbehci0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbehci0"; linux,phandle = <0x4f>; phandle = <0x4f>; }; usbehci1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbehci1"; linux,phandle = <0x55>; phandle = <0x55>; }; usbehci2 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbehci2"; linux,phandle = <0x59>; phandle = <0x59>; }; usbehci3 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbehci3"; linux,phandle = <0x5d>; phandle = <0x5d>; }; usb3_0_host { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usb3_0_host"; linux,phandle = <0xfa>; phandle = <0xfa>; }; usbotg { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "usbotg"; linux,phandle = <0x4e>; phandle = <0x4e>; }; lradc { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "lradc"; linux,phandle = <0xcb>; phandle = <0xcb>; }; hdmi { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clock-parents = <0x5>; assigned-clocks = <0xf>; clock-output-names = "hdmi"; linux,phandle = <0xf>; phandle = <0xf>; }; hdmi_slow { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clocks = <0x10>; clock-output-names = "hdmi_slow"; linux,phandle = <0x10>; phandle = <0x10>; }; hdmi_cec { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clocks = <0x11>; clock-output-names = "hdmi_cec"; linux,phandle = <0x11>; phandle = <0x11>; }; display_top { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "display_top"; linux,phandle = <0x98>; phandle = <0x98>; }; tcon_lcd { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "tcon_lcd"; assigned-clock-parents = <0x8>; assigned-clocks = <0x12>; linux,phandle = <0x12>; phandle = <0x12>; }; tcon_lcd1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "tcon_lcd1"; assigned-clock-parents = <0x4>; assigned-clocks = <0x13>; linux,phandle = <0x13>; phandle = <0x13>; }; tcon_tv { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clock-parents = <0x5>; assigned-clocks = <0x14>; clock-output-names = "tcon_tv"; linux,phandle = <0x14>; phandle = <0x14>; }; tcon_tv1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clock-parents = <0x4>; assigned-clocks = <0x15>; clock-output-names = "tcon_tv1"; linux,phandle = <0x15>; phandle = <0x15>; }; lvds { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "lvds"; assigned-clocks = <0x16>; linux,phandle = <0x16>; phandle = <0x16>; }; tve { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "tve"; assigned-clock-parents = <0x4>; assigned-clocks = <0x17>; linux,phandle = <0x17>; phandle = <0x17>; }; tve_top { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "tve_top"; assigned-clock-parents = <0x4>; assigned-clocks = <0x18>; linux,phandle = <0x18>; phandle = <0x18>; }; csi_top { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "csi_top"; linux,phandle = <0xa4>; phandle = <0xa4>; }; csi_master0 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "csi_master0"; linux,phandle = <0xa6>; phandle = <0xa6>; }; csi_master1 { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "csi_master1"; linux,phandle = <0xa7>; phandle = <0xa7>; }; hdmi_hdcp { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; assigned-clock-parents = <0x3>; assigned-clocks = <0x19>; clock-output-names = "hdmi_hdcp"; linux,phandle = <0x19>; phandle = <0x19>; }; pio { #clock-cells = <0x0>; compatible = "allwinner,periph-clock"; clock-output-names = "pio"; linux,phandle = <0x1d>; phandle = <0x1d>; }; cpurcir { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurcir"; linux,phandle = <0x25>; phandle = <0x25>; }; hosc32k { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "hosc32k"; linux,phandle = <0x1a>; phandle = <0x1a>; }; losc_out { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; assigned-clock-parents = <0x1a>; assigned-clocks = <0x1b>; clock-output-names = "losc_out"; linux,phandle = <0x1b>; phandle = <0x1b>; }; cpurcpus_pll { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurcpus_pll"; linux,phandle = <0xfb>; phandle = <0xfb>; }; cpurcpus { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurcpus"; linux,phandle = <0xfc>; phandle = <0xfc>; }; cpurahbs { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurahbs"; linux,phandle = <0xfd>; phandle = <0xfd>; }; cpurapbs1 { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurapbs1"; linux,phandle = <0xfe>; phandle = <0xfe>; }; cpurapbs2_pll { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurapbs2_pll"; linux,phandle = <0xff>; phandle = <0xff>; }; cpurapbs2 { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurapbs2"; linux,phandle = <0x100>; phandle = <0x100>; }; cpurpio { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "cpurpio"; linux,phandle = <0x1c>; phandle = <0x1c>; }; dcxo_out { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "dcxo_out"; linux,phandle = <0x101>; phandle = <0x101>; }; stwi { #clock-cells = <0x0>; compatible = "allwinner,periph-cpus-clock"; clock-output-names = "stwi"; linux,phandle = <0x4a>; phandle = <0x4a>; }; }; soc@03000000 { compatible = "simple-bus"; #address-cells = <0x2>; #size-cells = <0x2>; ranges; device_type = "soc"; linux,phandle = <0x102>; phandle = <0x102>; pinctrl@07022000 { compatible = "allwinner,sun50iw9p1-r-pinctrl"; reg = <0x0 0x7022000 0x0 0x400>; clocks = <0x1c>; device_type = "r_pio"; gpio-controller; interrupt-controller; #interrupt-cells = <0x3>; #size-cells = <0x0>; #gpio-cells = <0x6>; linux,phandle = <0x103>; phandle = <0x103>; s_rsb0@0 { allwinner,pins = "PL0", "PL1"; allwinner,function = "s_rsb0"; allwinner,muxsel = <0x2>; allwinner,drive = <0x2>; allwinner,pull = <0x1>; linux,phandle = <0x104>; phandle = <0x104>; }; s_twi0@0 { allwinner,pins = "PL0", "PL1"; allwinner,pname = "s_twi0_scl", "s_twi0_sda"; allwinner,function = "s_twi0"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x4b>; phandle = <0x4b>; }; s_twi0@1 { allwinner,pins = "PL0", "PL1"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x4c>; phandle = <0x4c>; }; }; pinctrl@0300b000 { compatible = "allwinner,sun50iw9p1-pinctrl"; reg = <0x0 0x300b000 0x0 0x400>; interrupts = <0x0 0x33 0x4 0x0 0x34 0x4 0x0 0x35 0x4 0x0 0x2b 0x4 0x0 0x36 0x4 0x0 0x37 0x4 0x0 0x38 0x4 0x0 0x39 0x4>; device_type = "pio"; clocks = <0x1d 0x1e 0x9>; gpio-controller; interrupt-controller; #interrupt-cells = <0x3>; #size-cells = <0x0>; #gpio-cells = <0x6>; input-debounce = <0x0 0x0 0x0 0x0 0x0 0x0 0x0>; linux,phandle = <0x53>; phandle = <0x53>; clk_losc@0 { allwinner,pins = "PG10"; allwinner,function = "x32kfout"; allwinner,muxsel = <0x3>; allwinner,drive = <0x2>; allwinner,pull = <0x1>; linux,phandle = <0xd3>; phandle = <0xd3>; }; s_cir0@0 { allwinner,pins = "PH10"; allwinner,function = "ir"; allwinner,muxsel = <0x3>; allwinner,drive = <0x2>; allwinner,pull = <0x1>; linux,phandle = <0x24>; phandle = <0x24>; }; vdevice@0 { allwinner,pins = "PA1", "PA2"; allwinner,function = "Vdevice"; allwinner,muxsel = <0x5>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0xb4>; phandle = <0xb4>; }; uart0@1 { allwinner,pins = "PH0", "PH1"; allwinner,function = "uart0"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x2b>; phandle = <0x2b>; }; uart1@0 { allwinner,pins = "PG6", "PG7", "PG8", "PG9"; allwinner,pname = "uart1_tx", "uart1_rx", "uart1_rts", "uart1_cts"; allwinner,function = "uart1"; allwinner,muxsel = <0x2>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x2d>; phandle = <0x2d>; }; uart1@1 { allwinner,pins = "PG6", "PG7", "PG8", "PG9"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x2e>; phandle = <0x2e>; }; uart2@0 { allwinner,pins = "PH5", "PH6", "PH7", "PH8"; allwinner,pname = "uart2_tx", "uart2_rx", "uart2_rts", "uart2_cts"; allwinner,function = "uart2"; allwinner,muxsel = <0x2>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x30>; phandle = <0x30>; }; uart2@1 { allwinner,pins = "PH5", "PH6", "PH7", "PH8"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x31>; phandle = <0x31>; }; uart3@0 { allwinner,pins = "PI9", "PI10", "PI11", "PI12"; allwinner,pname = "uart3_tx", "uart3_rx", "uart3_rts", "uart3_cts"; allwinner,function = "uart3"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x33>; phandle = <0x33>; }; uart3@1 { allwinner,pins = "PI9", "PI10", "PI11", "PI12"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x34>; phandle = <0x34>; }; uart4@0 { allwinner,pins = "PI13", "PI14", "PI15", "PI16"; allwinner,pname = "uart4_tx", "uart4_rx", "uart4_rts", "uart4_cts"; allwinner,function = "uart4"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x36>; phandle = <0x36>; }; uart4@1 { allwinner,pins = "PI13", "PI14", "PI15", "PI16"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x37>; phandle = <0x37>; }; uart5@0 { allwinner,pins = "PH2", "PH3"; allwinner,pname = "uart3_tx", "uart3_rx"; allwinner,function = "uart5"; allwinner,muxsel = <0x2>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x39>; phandle = <0x39>; }; uart5@1 { allwinner,pins = "PH2", "PH3"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x3a>; phandle = <0x3a>; }; twi0@0 { allwinner,pins = "PA0", "PA1"; allwinner,pname = "twi0_scl", "twi0_sda"; allwinner,function = "twi0"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x3c>; phandle = <0x3c>; }; twi0@1 { allwinner,pins = "PA0", "PA1"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x3d>; phandle = <0x3d>; }; twi1@0 { allwinner,pins = "PA2", "PA3"; allwinner,pname = "twi1_scl", "twi1_sda"; allwinner,function = "twi1"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x3f>; phandle = <0x3f>; }; twi1@1 { allwinner,pins = "PA2", "PA3"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x40>; phandle = <0x40>; }; twi2@0 { allwinner,pins = "PE20", "PE21"; allwinner,pname = "twi2_scl", "twi2_sda"; allwinner,function = "twi2"; allwinner,muxsel = <0x5>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x42>; phandle = <0x42>; }; twi2@1 { allwinner,pins = "PE20", "PE21"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x43>; phandle = <0x43>; }; twi3@0 { allwinner,pins = "PA10", "PA11"; allwinner,pname = "twi3_scl", "twi3_sda"; allwinner,function = "twi3"; allwinner,muxsel = <0x2>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x45>; phandle = <0x45>; }; twi3@1 { allwinner,pins = "PA10", "PA11"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x46>; phandle = <0x46>; }; twi4@0 { allwinner,pins = "PG15", "PG16"; allwinner,pname = "twi4_scl", "twi4_sda"; allwinner,function = "twi4"; allwinner,muxsel = <0x5>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x48>; phandle = <0x48>; }; twi4@1 { allwinner,pins = "PG15", "PG16"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x49>; phandle = <0x49>; }; ts0@0 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11"; allwinner,pname = "ts0_clk", "ts0_err", "ts0_sync", "ts0_dvld", "ts0_d0", "ts0_d1", "ts0_d2", "ts0_d3", "ts0_d4", "ts0_d5", "ts0_d6", "ts0_d7"; allwinner,function = "ts0"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0xc1>; phandle = <0xc1>; }; ts0_sleep@0 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11"; allwinner,pname = "ts0_clk", "ts0_err", "ts0_sync", "ts0_dvld", "ts0_d0", "ts0_d1", "ts0_d2", "ts0_d3", "ts0_d4", "ts0_d5", "ts0_d6", "ts0_d7"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0xc2>; phandle = <0xc2>; }; spi0@0 { allwinner,pins = "PC0", "PC2", "PC4", "PC15", "PC16"; allwinner,pname = "spi0_sclk", "spi0_mosi", "spi0_miso", "spi0_wp", "spi0_hold"; allwinner,function = "spi0"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x7e>; phandle = <0x7e>; }; spi0@1 { allwinner,pins = "PC3", "PC7"; allwinner,pname = "spi0_cs0", "spi0_cs1"; allwinner,function = "spi0"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x7f>; phandle = <0x7f>; }; spi0@2 { allwinner,pins = "PC0", "PC2", "PC3", "PC4", "PC7", "PC15", "PC16"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x80>; phandle = <0x80>; }; spi1@0 { allwinner,pins = "PH6", "PH7", "PH8"; allwinner,pname = "spi1_sclk", "spi1_mosi", "spi1_miso"; allwinner,function = "spi1"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x82>; phandle = <0x82>; }; spi1@1 { allwinner,pins = "PH5", "PH9"; allwinner,pname = "spi1_cs0", "spi1_cs1"; allwinner,function = "spi1"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x83>; phandle = <0x83>; }; spi1@2 { allwinner,pins = "PH5", "PH6", "PH7", "PH8", "PH9"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x84>; phandle = <0x84>; }; sdc0@0 { allwinner,pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; allwinner,function = "sdc0"; allwinner,muxsel = <0x2>; allwinner,drive = <0x3>; allwinner,pull = <0x1>; linux,phandle = <0x90>; phandle = <0x90>; }; sdc0@1 { allwinner,pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x91>; phandle = <0x91>; }; sdc0@2 { allwinner,pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; allwinner,function = "uart0_jtag"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x92>; phandle = <0x92>; }; sdc1@0 { allwinner,pins = "PG0", "PG1", "PG2", "PG3", "PG4", "PG5"; allwinner,function = "sdc1"; allwinner,muxsel = <0x2>; allwinner,drive = <0x3>; allwinner,pull = <0x1>; linux,phandle = <0x96>; phandle = <0x96>; }; sdc1@1 { allwinner,pins = "PG0", "PG1", "PG2", "PG3", "PG4", "PG5"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x97>; phandle = <0x97>; }; sdc2@0 { allwinner,pins = "PC1", "PC5", "PC6", "PC8", "PC9", "PC10", "PC11", "PC13", "PC14", "PC15", "PC16"; allwinner,function = "sdc2"; allwinner,muxsel = <0x3>; allwinner,drive = <0x2>; allwinner,pull = <0x1>; linux,phandle = <0x8a>; phandle = <0x8a>; }; sdc2@1 { allwinner,pins = "PC0", "PC1", "PC5", "PC6", "PC8", "PC9", "PC10", "PC11", "PC13", "PC14", "PC15", "PC16"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x8c>; phandle = <0x8c>; }; sdc2@2 { allwinner,pins = "PC0"; allwinner,function = "sdc2"; allwinner,muxsel = <0x3>; allwinner,drive = <0x2>; allwinner,pull = <0x2>; linux,phandle = <0x8b>; phandle = <0x8b>; }; spdif@0 { allwinner,pins = "PH2", "PH3", "PH4"; allwinner,function = "spdif"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x62>; phandle = <0x62>; }; spdif_sleep@0 { allwinner,pins = "PH2", "PH3", "PH4"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x63>; phandle = <0x63>; }; dmic@0 { allwinner,pins = "PI0", "PI1", "PI2", "PI3", "PI4"; allwinner,function = "dmic"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x65>; phandle = <0x65>; }; dmic_sleep@0 { allwinner,pins = "PI0", "PI1", "PI2", "PI3", "PI4"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x66>; phandle = <0x66>; }; ahub_daudio0@0 { allwinner,pins = "PA6", "PA7", "PA8", "PA9"; allwinner,function = "h_pcm0"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x105>; phandle = <0x105>; }; ahub_daudio0_sleep@0 { allwinner,pins = "PA6", "PA7", "PA8", "PA9"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x106>; phandle = <0x106>; }; h_ahub_daudio0@0 { allwinner,pins = "PI0", "PI1", "PI2", "PI3", "PI4"; allwinner,function = "h_pcm0"; allwinner,muxsel = <0x4>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x6b>; phandle = <0x6b>; }; h_ahub_daudio0_sleep@0 { allwinner,pins = "PI0", "PI1", "PI2", "PI3", "PI4"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x6c>; phandle = <0x6c>; }; ahub_daudio2@0 { allwinner,pins = "PG10", "PG11", "PG12", "PG13", "PG14"; allwinner,function = "h_pcm2"; allwinner,muxsel = <0x2>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x6d>; phandle = <0x6d>; }; ahub_daudio2_sleep@0 { allwinner,pins = "PG10", "PG11", "PG12", "PG13", "PG14"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x6e>; phandle = <0x6e>; }; ahub_daudio3@0 { allwinner,pins = "PH5", "PH6", "PH7", "PH8", "PH9"; allwinner,function = "h_pcm3"; allwinner,muxsel = <0x3>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x6f>; phandle = <0x6f>; }; ahub_daudio3_sleep@0 { allwinner,pins = "PH5", "PH6", "PH7", "PH8", "PH9"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x70>; phandle = <0x70>; }; csi1@0 { allwinner,pins = "PE0", "PE2", "PE3", "PE4", "PE5", "PE6", "PE7", "PE8", "PE9", "PE10", "PE11", "PE12", "PE13", "PE14", "PE15", "PE16", "PE17", "PE18", "PE19"; allwinner,pname = "csi1_pck", "csi1_hsync", "csi1_vsync", "csi1_d0", "csi1_d1", "csi1_d2", "csi1_d3", "csi1_d4", "csi1_d5", "csi1_d6", "csi1_d7", "csi1_d8", "csi1_d9", "csi1_d10", "csi1_d11", "csi1_d12", "csi1_d13", "csi1_d14", "csi1_d15"; allwinner,function = "csi1"; allwinner,muxsel = <0x2>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0xb0>; phandle = <0xb0>; }; csi1@1 { allwinner,pins = "PE0", "PE2", "PE3", "PE4", "PE5", "PE6", "PE7", "PE8", "PE9", "PE10", "PE11", "PE12", "PE13", "PE14", "PE15", "PE16", "PE17", "PE18", "PE19"; allwinner,pname = "csi1_pck", "csi1_hsync", "csi1_vsync", "csi1_d0", "csi1_d1", "csi1_d2", "csi1_d3", "csi1_d4", "csi1_d5", "csi1_d6", "csi1_d7", "csi1_d8", "csi1_d9", "csi1_d10", "csi1_d11", "csi1_d12", "csi1_d13", "csi1_d14", "csi1_d15"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0xb1>; phandle = <0xb1>; }; csi_mclk0@0 { allwinner,pins = "PG19"; allwinner,pname = "csi_mclk0"; allwinner,function = "csi_mclk0"; allwinner,muxsel = <0x3>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xa8>; phandle = <0xa8>; }; csi_mclk0@1 { allwinner,pins = "PG19"; allwinner,pname = "csi_mclk0"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xa9>; phandle = <0xa9>; }; csi_cci0@0 { allwinner,pins = "PG17", "PG18"; allwinner,pname = "csi_cci0_sck", "csi_cci0_sda"; allwinner,function = "csi_cci0"; allwinner,muxsel = <0x3>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xac>; phandle = <0xac>; }; csi_cci0@1 { allwinner,pins = "PG17", "PG18"; allwinner,pname = "csi_cci0_sck", "csi_cci0_sda"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xad>; phandle = <0xad>; }; csi_mclk1@0 { allwinner,pins = "PE1"; allwinner,pname = "csi_mclk1"; allwinner,function = "csi_mclk1"; allwinner,muxsel = <0x2>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xaa>; phandle = <0xaa>; }; csi_mclk1@1 { allwinner,pins = "PE1"; allwinner,pname = "csi_mclk1"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xab>; phandle = <0xab>; }; csi_cci1@0 { allwinner,pins = "PE20", "PE21"; allwinner,pname = "csi_cci1_sck", "csi_cci1_sda"; allwinner,function = "csi_cci1"; allwinner,muxsel = <0x2>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xae>; phandle = <0xae>; }; csi_cci1@1 { allwinner,pins = "PE20", "PE21"; allwinner,pname = "csi_cci1_sck", "csi_cci1_sda"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x2>; allwinner,pull = <0x0>; linux,phandle = <0xaf>; phandle = <0xaf>; }; scr0@0 { allwinner,pins = "PG13", "PG14", "PG10", "PG11", "PG12"; allwinner,pname = "scr0_rst", "scr0_det", "scr0_vccen", "scr0_sck", "scr0_sda"; allwinner,function = "sim0"; allwinner,muxsel = <0x4>; allwinner,drive = <0x0>; allwinner,pull = <0x1>; linux,phandle = <0xb8>; phandle = <0xb8>; }; scr0@1 { allwinner,pins = "PG8", "PG9"; allwinner,pname = "scr0_vppen", "scr0_vppp"; allwinner,function = "sim0"; allwinner,muxsel = <0x4>; allwinner,drive = <0x0>; allwinner,pull = <0x1>; linux,phandle = <0xb9>; phandle = <0xb9>; }; scr0@2 { allwinner,pins = "PG8", "PG9", "PG10", "PG11", "PG12", "PG13", "PG14"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x0>; allwinner,pull = <0x0>; linux,phandle = <0xba>; phandle = <0xba>; }; scr1@0 { allwinner,pins = "PH5", "PH6", "PH2", "PH3", "PH4"; allwinner,pname = "scr1_rst", "scr1_det", "scr1_vccen", "scr1_sck", "scr1_sda"; allwinner,function = "sim1"; allwinner,muxsel = <0x5>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x107>; phandle = <0x107>; }; scr1@1 { allwinner,pins = "PH0", "PH1"; allwinner,pname = "scr1_vppen", "scr1_vppp"; allwinner,function = "sim1"; allwinner,muxsel = <0x5>; allwinner,drive = <0x1>; allwinner,pull = <0x1>; linux,phandle = <0x108>; phandle = <0x108>; }; scr1@2 { allwinner,pins = "PH0", "PH1", "PH2", "PH3", "PH4", "PH5", "PH6"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x109>; phandle = <0x109>; }; nand0@2 { allwinner,pins = "PC0", "PC1", "PC2", "PC3", "PC4", "PC5", "PC6", "PC7", "PC8", "PC9", "PC10", "PC11", "PC12", "PC13", "PC14", "PC15", "PC16"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0xbf>; phandle = <0xbf>; }; ac200@2 { allwinner,pins = "PB0"; allwinner,function = "ac200"; allwinner,muxsel = <0x2>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x10a>; phandle = <0x10a>; }; ac200@3 { allwinner,pins = "PB0"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x1>; allwinner,pull = <0x0>; linux,phandle = <0x10b>; phandle = <0x10b>; }; gmac@0 { allwinner,pins = "PI0", "PI1", "PI2", "PI3", "PI4", "PI5", "PI6", "PI7", "PI8", "PI9", "PI10", "PI11", "PI12", "PI13", "PI14", "PI15", "PI16"; allwinner,function = "gmac0"; allwinner,muxsel = <0x2>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0xce>; phandle = <0xce>; }; gmac@1 { allwinner,pins = "PI0", "PI1", "PI2", "PI3", "PI4", "PI5", "PI6", "PI7", "PI8", "PI9", "PI10", "PI11", "PI12", "PI13", "PI14", "PI15", "PI16"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0xcf>; phandle = <0xcf>; }; gmac1@0 { allwinner,pins = "PA0", "PA1", "PA2", "PA3", "PA4", "PA5", "PA6", "PA7", "PA8", "PA9"; allwinner,function = "gmac1"; allwinner,muxsel = <0x2>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0xd1>; phandle = <0xd1>; }; gmac1@1 { allwinner,pins = "PA0", "PA1", "PA2", "PA3", "PA4", "PA5", "PA6", "PA7", "PA8", "PA9"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0xd2>; phandle = <0xd2>; }; lvds0@0 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7"; allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7"; allwinner,function = "lvds0"; allwinner,muxsel = <0x3>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x10c>; phandle = <0x10c>; }; lvds0@1 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7"; allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7"; allwinner,function = "lvds0_suspend"; allwinner,muxsel = <0x7>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x10d>; phandle = <0x10d>; }; lvds1@0 { allwinner,pins = "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,pname = "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,function = "lvds1"; allwinner,muxsel = <0x3>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x10e>; phandle = <0x10e>; }; lvds1@1 { allwinner,pins = "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,pname = "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,function = "lvds1_suspend"; allwinner,muxsel = <0x7>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x10f>; phandle = <0x10f>; }; lvds2link@0 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,function = "lvds1"; allwinner,muxsel = <0x3>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x110>; phandle = <0x110>; }; lvds2link@1 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD8", "PD9", "PD6", "PD7", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD18", "PD19", "PD16", "PD17"; allwinner,function = "lvds1_suspend"; allwinner,muxsel = <0x7>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x111>; phandle = <0x111>; }; rgb24@0 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19", "PD20", "PD21", "PD22", "PD23", "PD24", "PD25", "PD26", "PD27"; allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19", "PD20", "PD21", "PD22", "PD23", "PD24", "PD25", "PD26", "PD27"; allwinner,function = "rgb24"; allwinner,muxsel = <0x2>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x99>; phandle = <0x99>; }; rgb24@1 { allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19", "PD20", "PD21", "PD22", "PD23", "PD24", "PD25", "PD26", "PD27"; allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19", "PD20", "PD21", "PD22", "PD23", "PD24", "PD25", "PD26", "PD27"; allwinner,function = "rgb24_suspend"; allwinner,muxsel = <0x7>; allwinner,drive = <0x3>; allwinner,pull = <0x0>; linux,phandle = <0x9a>; phandle = <0x9a>; }; pwm5@0 { allwinner,pins = "PA12"; allwinner,function = "pwm5"; allwinner,muxsel = <0x2>; allwinner,drive = <0xffffffff>; allwinner,pull = <0x0>; allwinner,data = <0xffffffff>; linux,phandle = <0xa2>; phandle = <0xa2>; }; pwm5@1 { allwinner,pins = "PA12"; allwinner,function = "io_disabled"; allwinner,muxsel = <0x7>; allwinner,drive = <0xffffffff>; allwinner,pull = <0x0>; allwinner,data = <0xffffffff>; linux,phandle = <0xa3>; phandle = <0xa3>; }; standby@0 { allwinner,pins = "PH6"; allwinner,function = "gpio_out"; allwinner,muxsel = <0x1>; allwinner,data = <0x0>; allwinner,drive = <0x0>; allwinner,pull = <0x0>; linux,phandle = <0xe0>; phandle = <0xe0>; }; standby@1 { allwinner,pins = "PH7"; allwinner,function = "gpio_out"; allwinner,muxsel = <0x1>; allwinner,data = <0x0>; allwinner,drive = <0x2>; allwinner,pull = <0x2>; linux,phandle = <0xdf>; phandle = <0xdf>; }; standby@2 { allwinner,pins = "PG16"; allwinner,function = "gpio_in"; allwinner,muxsel = <0x0>; allwinner,data = <0x0>; allwinner,drive = <0x0>; allwinner,pull = <0x0>; linux,phandle = <0x112>; phandle = <0x112>; }; card0_boot_para@0 { linux,phandle = <0x184>; phandle = <0x184>; allwinner,pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; allwinner,function = "card0_boot_para"; allwinner,pname = "sdc_d1", "sdc_d0", "sdc_clk", "sdc_cmd", "sdc_d3", "sdc_d2"; allwinner,muxsel = <0x2>; allwinner,pull = <0x1>; allwinner,drive = <0x3>; allwinner,data = <0xffffffff>; }; card2_boot_para@0 { linux,phandle = <0x185>; phandle = <0x185>; allwinner,pins = "PC5", "PC6", "PC10", "PC13", "PC15", "PC8", "PC9", "PC11", "PC14", "PC16", "PC1"; allwinner,function = "card2_boot_para"; allwinner,pname = "sdc_clk", "sdc_cmd", "sdc_d0", "sdc_d1", "sdc_d2", "sdc_d3", "sdc_d4", "sdc_d5", "sdc_d6", "sdc_d7", "sdc_emmc_rst"; allwinner,muxsel = <0x3>; allwinner,pull = <0x1>; allwinner,drive = <0x3>; allwinner,data = <0xffffffff>; }; card2_boot_para@1 { linux,phandle = <0x186>; phandle = <0x186>; allwinner,pins = "PC0"; allwinner,function = "card2_boot_para"; allwinner,pname = "sdc_ds"; allwinner,muxsel = <0x3>; allwinner,pull = <0x2>; allwinner,drive = <0x3>; allwinner,data = <0xffffffff>; }; twi_para@0 { linux,phandle = <0x187>; phandle = <0x187>; allwinner,pins = "PH14", "PH15"; allwinner,function = "twi_para"; allwinner,pname = "twi_scl", "twi_sda"; allwinner,muxsel = <0x2>; allwinner,pull = <0xffffffff>; allwinner,drive = <0xffffffff>; allwinner,data = <0xffffffff>; }; uart_para@0 { linux,phandle = <0x188>; phandle = <0x188>; allwinner,pins = "PH0", "PH1"; allwinner,function = "uart_para"; allwinner,pname = "uart_debug_tx", "uart_debug_rx"; allwinner,muxsel = <0x2>; allwinner,pull = <0x1>; allwinner,drive = <0xffffffff>; allwinner,data = <0xffffffff>; }; jtag_para@0 { linux,phandle = <0x189>; phandle = <0x189>; allwinner,pins = "PH9", "PH10", "PH11", "PH12"; allwinner,function = "jtag_para"; allwinner,pname = "jtag_ms", "jtag_ck", "jtag_do", "jtag_di"; allwinner,muxsel = <0x3>; allwinner,pull = <0xffffffff>; allwinner,drive = <0xffffffff>; allwinner,data = <0xffffffff>; }; uart0@0 { linux,phandle = <0x18a>; phandle = <0x18a>; allwinner,pins = "PH0", "PH1"; allwinner,function = "uart0"; allwinner,pname = "uart0_tx", "uart0_rx"; allwinner,muxsel = <0x2>; allwinner,pull = <0x1>; allwinner,drive = <0xffffffff>; allwinner,data = <0xffffffff>; }; nand0@0 { linux,phandle = <0x18b>; phandle = <0x18b>; allwinner,pins = "PC0", "PC1", "PC2", "PC4", "PC6", "PC7", "PC8", "PC9", "PC10", "PC11", "PC12", "PC13", "PC14"; allwinner,function = "nand0"; allwinner,pname = "nand0_we", "nand0_ale", "nand0_cle", "nand0_nre", "nand0_d0", "nand0_d1", "nand0_d2", "nand0_d3", "nand0_d4", "nand0_d5", "nand0_d6", "nand0_d7", "nand0_ndqs"; allwinner,muxsel = <0x2>; allwinner,pull = <0x0>; allwinner,drive = <0x1>; allwinner,data = <0xffffffff>; }; nand0@1 { linux,phandle = <0x18c>; phandle = <0x18c>; allwinner,pins = "PC3", "PC5", "PC15", "PC16"; allwinner,function = "nand0"; allwinner,pname = "nand0_ce0", "nand0_rb0", "nand0_ce1", "nand0_rb1"; allwinner,muxsel = <0x2>; allwinner,pull = <0x1>; allwinner,drive = <0x1>; allwinner,data = <0xffffffff>; }; }; auto_print { device_type = "auto_print"; status = "okay"; }; dma-controller@03002000 { compatible = "allwinner,sun50i-dma"; reg = <0x0 0x3002000 0x0 0x1000>; interrupts = <0x0 0x2a 0x4>; clocks = <0x1f>; #dma-cells = <0x1>; linux,phandle = <0x113>; phandle = <0x113>; }; mbus-controller@047fa000 { compatible = "allwinner,sun50i-mbus"; reg = <0x0 0x47fa000 0x0 0x1000>; #mbus-cells = <0x1>; linux,phandle = <0x114>; phandle = <0x114>; }; arisc { compatible = "allwinner,sunxi-arisc"; #address-cells = <0x2>; #size-cells = <0x2>; clocks = <0x1e 0x20 0x9 0x2>; clock-names = "losc", "iosc", "hosc", "pll_periph0"; powchk_used = <0x0>; power_reg = <0x2309621>; system_power = <0x32>; }; arisc_space { compatible = "allwinner,arisc_space"; space1 = <0x48040000 0x0 0x14000>; space2 = <0x48100000 0x18000 0x4000>; space3 = <0x48104000 0x0 0x1000>; space4 = <0x48105000 0x0 0x1000>; }; standby_space { compatible = "allwinner,sun50iw9-usbstandby"; space1 = <0x40020000 0x0 0x800>; }; msgbox@03003000 { compatible = "allwinner,msgbox"; clocks = <0x21>; clock-names = "clk_msgbox"; reg = <0x0 0x3003000 0x0 0x1000>; interrupts = <0x0 0x27 0x1>; status = "okay"; linux,phandle = <0x115>; phandle = <0x115>; }; hwspinlock@3004000 { compatible = "allwinner,sunxi-hwspinlock"; clocks = <0x22 0x23>; clock-names = "clk_hwspinlock_rst", "clk_hwspinlock_bus"; reg = <0x0 0x3004000 0x0 0x1000>; num-locks = <0x8>; status = "okay"; linux,phandle = <0x116>; phandle = <0x116>; }; s_cir@07040000 { compatible = "allwinner,s_cir"; reg = <0x0 0x7040000 0x0 0x400>; interrupts = <0x0 0x6a 0x4>; pinctrl-names = "default"; pinctrl-0 = <0x24>; clocks = <0x9 0x25>; supply = "vcc-pl"; supply_vol = "3300000"; status = "okay"; s_cir0_used = <0x1>; ir_power_key_code0 = <0x40>; ir_addr_code0 = <0xfe01>; ir_power_key_code1 = <0x1a>; ir_addr_code1 = <0xfb04>; ir_power_key_code2 = <0xf2>; ir_addr_code2 = <0x2992>; ir_power_key_code3 = <0x57>; ir_addr_code3 = <0x9f00>; ir_power_key_code4 = <0xdc>; ir_addr_code4 = <0x4cb3>; ir_power_key_code5 = <0x18>; ir_addr_code5 = <0xff00>; ir_power_key_code6 = <0xdc>; ir_addr_code6 = <0xdd22>; ir_power_key_code7 = <0xd>; ir_addr_code7 = <0xbc00>; ir_power_key_code8 = <0x4d>; ir_addr_code8 = <0x4040>; ir_power_key_code9 = <0x51>; ir_addr_code9 = <0x7f80>; wakeup-source; linux,phandle = <0x117>; phandle = <0x117>; }; timer@03009000 { compatible = "allwinner,sun4i-a10-timer"; device_type = "soc_timer"; reg = <0x0 0x3009000 0x0 0x400>; interrupts = <0x0 0x30 0x4>; clocks = <0x9>; linux,phandle = <0x118>; phandle = <0x118>; }; rtc@07000000 { compatible = "allwinner,sunxi-rtc"; device_type = "rtc"; auto_switch; wakeup-source; reg = <0x0 0x7000000 0x0 0x200>; interrupts = <0x0 0x68 0x4>; gpr_offset = <0x100>; gpr_len = <0x8>; gpr_cur_pos = <0x6>; linux,phandle = <0x119>; phandle = <0x119>; }; watchdog@030090a0 { compatible = "allwinner,sun50i-wdt"; reg = <0x0 0x30090a0 0x0 0x20>; interrupts = <0x0 0x32 0x4>; linux,phandle = <0x11a>; phandle = <0x11a>; }; ve@01c0e000 { compatible = "allwinner,sunxi-cedar-ve"; reg = <0x0 0x1c0e000 0x0 0x1000 0x0 0x3000000 0x0 0x10 0x0 0x3001000 0x0 0x1000>; interrupts = <0x0 0x5d 0x4>; clocks = <0x26 0x27>; iommus = <0x28 0x3 0x1>; linux,phandle = <0x11b>; phandle = <0x11b>; }; vp9@01c00000 { compatible = "allwinner,sunxi-google-vp9"; reg = <0x0 0x1c00000 0x0 0x1000 0x0 0x3000000 0x0 0x10 0x0 0x3001000 0x0 0x1000>; interrupts = <0x0 0x5a 0x4>; clocks = <0x26>; iommus = <0x28 0x2 0x1>; #clocks = <0xc>; linux,phandle = <0x11c>; phandle = <0x11c>; }; uart@05000000 { compatible = "allwinner,sun50i-uart"; device_type = "uart0"; reg = <0x0 0x5000000 0x0 0x400>; interrupts = <0x0 0x0 0x4>; clocks = <0x29>; pinctrl-names = "default", "sleep"; pinctrl-1 = <0x2b>; uart0_port = <0x0>; uart0_type = <0x2>; status = "okay"; linux,phandle = <0x11d>; phandle = <0x11d>; pinctrl-0 = <0x18a>; }; uart@05000400 { compatible = "allwinner,sun50i-uart"; device_type = "uart1"; reg = <0x0 0x5000400 0x0 0x400>; interrupts = <0x0 0x1 0x4>; clocks = <0x2c>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x2d>; pinctrl-1 = <0x2e>; uart1_port = <0x1>; uart1_type = <0x4>; status = "okay"; linux,phandle = <0x11e>; phandle = <0x11e>; }; uart@05000800 { compatible = "allwinner,sun50i-uart"; device_type = "uart2"; reg = <0x0 0x5000800 0x0 0x400>; interrupts = <0x0 0x2 0x4>; clocks = <0x2f>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x30>; pinctrl-1 = <0x31>; uart2_port = <0x2>; uart2_type = <0x4>; status = "disabled"; linux,phandle = <0x11f>; phandle = <0x11f>; }; uart@05000c00 { compatible = "allwinner,sun50i-uart"; device_type = "uart3"; reg = <0x0 0x5000c00 0x0 0x400>; interrupts = <0x0 0x3 0x4>; clocks = <0x32>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x33>; pinctrl-1 = <0x34>; uart3_port = <0x3>; uart3_type = <0x4>; status = "disabled"; linux,phandle = <0x120>; phandle = <0x120>; }; uart@05001000 { compatible = "allwinner,sun50i-uart"; device_type = "uart4"; reg = <0x0 0x5001000 0x0 0x400>; interrupts = <0x0 0x4 0x4>; clocks = <0x35>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x36>; pinctrl-1 = <0x37>; uart4_port = <0x4>; uart4_type = <0x4>; status = "disabled"; linux,phandle = <0x121>; phandle = <0x121>; }; uart@05001400 { compatible = "allwinner,sun50i-uart"; device_type = "uart5"; reg = <0x0 0x5001400 0x0 0x400>; interrupts = <0x0 0x5 0x4>; clocks = <0x38>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x39>; pinctrl-1 = <0x3a>; uart5_port = <0x5>; uart5_type = <0x2>; status = "disabled"; linux,phandle = <0x122>; phandle = <0x122>; }; twi@0x05002000 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-twi"; device_type = "twi0"; reg = <0x0 0x5002000 0x0 0x400>; interrupts = <0x0 0x6 0x4>; clocks = <0x3b>; clock-frequency = <0x61a80>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x3c>; pinctrl-1 = <0x3d>; status = "disable"; linux,phandle = <0x123>; phandle = <0x123>; }; twi@0x05002400 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-twi"; device_type = "twi1"; reg = <0x0 0x5002400 0x0 0x400>; interrupts = <0x0 0x7 0x4>; clocks = <0x3e>; clock-frequency = <0x30d40>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x3f>; pinctrl-1 = <0x40>; status = "disable"; linux,phandle = <0x124>; phandle = <0x124>; }; twi@0x05002800 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-twi"; device_type = "twi2"; reg = <0x0 0x5002800 0x0 0x400>; interrupts = <0x0 0x8 0x4>; clocks = <0x41>; clock-frequency = <0x30d40>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x42>; pinctrl-1 = <0x43>; status = "disable"; linux,phandle = <0x125>; phandle = <0x125>; }; twi@0x05002c00 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-twi"; device_type = "twi3"; reg = <0x0 0x5002c00 0x0 0x400>; interrupts = <0x0 0x9 0x4>; clocks = <0x44>; clock-frequency = <0x30d40>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x45>; pinctrl-1 = <0x46>; status = "okay"; linux,phandle = <0x126>; phandle = <0x126>; }; twi@0x05003000 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-twi"; device_type = "twi4"; reg = <0x0 0x5003000 0x0 0x400>; interrupts = <0x0 0xa 0x4>; clocks = <0x47>; clock-frequency = <0x30d40>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x48>; pinctrl-1 = <0x49>; status = "disable"; linux,phandle = <0x127>; phandle = <0x127>; }; twi@0x07081400 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-twi"; device_type = "twi5"; reg = <0x0 0x7081400 0x0 0x400>; interrupts = <0x0 0x69 0x4>; clocks = <0x4a>; clock-frequency = <0x30d40>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x4b>; pinctrl-1 = <0x4c>; status = "okay"; no_suspend = <0x1>; linux,phandle = <0x128>; phandle = <0x128>; pmu { compatible = "x-powers,axp1530"; reg = <0x36>; wakeup-source; linux,phandle = <0x129>; phandle = <0x129>; standby_param { vcc-dram = <0x4>; linux,phandle = <0x12a>; phandle = <0x12a>; }; regulators { dcdc1 { regulator-name = "axp1530-dcdc1"; regulator-min-microvolt = <0x7a120>; regulator-max-microvolt = <0x33e140>; regulator-step-delay-us = <0x19>; regulator-final-delay-us = <0x32>; regulator-always-on; linux,phandle = <0x12b>; phandle = <0x12b>; }; dcdc2 { regulator-name = "axp1530-dcdc2"; regulator-min-microvolt = <0x7a120>; regulator-max-microvolt = <0x177fa0>; regulator-step-delay-us = <0x19>; regulator-final-delay-us = <0x32>; regulator-ramp-delay = <0xc8>; regulator-always-on; linux,phandle = <0xd8>; phandle = <0xd8>; }; dcdc3 { regulator-name = "axp1530-dcdc3"; regulator-min-microvolt = <0x7a120>; regulator-max-microvolt = <0x1c1380>; regulator-step-delay-us = <0x19>; regulator-final-delay-us = <0x32>; regulator-always-on; linux,phandle = <0x12c>; phandle = <0x12c>; }; ldo1 { regulator-name = "axp1530-aldo1"; regulator-min-microvolt = <0x7a120>; regulator-max-microvolt = <0x3567e0>; regulator-step-delay-us = <0x19>; regulator-final-delay-us = <0x32>; regulator-always-on; linux,phandle = <0x68>; phandle = <0x68>; }; ldo2 { regulator-name = "axp1530-dldo1"; regulator-min-microvolt = <0x7a120>; regulator-max-microvolt = <0x3567e0>; regulator-step-delay-us = <0x19>; regulator-final-delay-us = <0x32>; regulator-always-on; linux,phandle = <0x69>; phandle = <0x69>; }; }; }; }; usbc0@0 { device_type = "usbc0"; compatible = "allwinner,sunxi-otg-manager"; usb_port_type = <0x1>; usb_detect_type = <0x1>; usb_id_gpio; usb_det_vbus_gpio; usb_drv_vbus_gpio; usb_host_init_state = <0x0>; usb_regulator_io = "nocare"; usb_wakeup_suspend = <0x2>; usb_luns = <0x3>; usb_serial_unique = <0x0>; usb_serial_number = "20080411"; rndis_wceis = <0x1>; wakeup-source; status = "okay"; usb_detect_mode = <0x0>; linux,phandle = <0x12d>; phandle = <0x12d>; }; udc-controller@0x05100000 { compatible = "allwinner,sunxi-udc"; reg = <0x0 0x5100000 0x0 0x1000 0x0 0x0 0x0 0x100>; interrupts = <0x0 0x19 0x4>; clocks = <0x4d 0x4e>; status = "okay"; linux,phandle = <0x12e>; phandle = <0x12e>; }; ehci0-controller@0x05101000 { compatible = "allwinner,sunxi-ehci0"; reg = <0x0 0x5101000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x1a 0x4>; clocks = <0x4d 0x4f>; hci_ctrl_no = <0x0>; status = "okay"; linux,phandle = <0x12f>; phandle = <0x12f>; }; ohci0-controller@0x05101400 { compatible = "allwinner,sunxi-ohci0"; reg = <0x0 0x5101000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x1b 0x4>; clocks = <0x4d 0x50 0x51 0x52 0x9 0x1e>; hci_ctrl_no = <0x0>; status = "okay"; linux,phandle = <0x130>; phandle = <0x130>; }; usbc1@0 { device_type = "usbc1"; usb_drv_vbus_gpio = <0x53 0x7 0x8 0x0 0x1 0xffffffff 0xffffffff>; usb_host_init_state = <0x1>; usb_regulator_io = "nocare"; usb_wakeup_suspend = <0x2>; wakeup-source; status = "okay"; linux,phandle = <0x131>; phandle = <0x131>; }; ehci1-controller@0x05200000 { compatible = "allwinner,sunxi-ehci1"; reg = <0x0 0x5200000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x1c 0x4>; clocks = <0x54 0x55>; hci_ctrl_no = <0x1>; status = "okay"; linux,phandle = <0x132>; phandle = <0x132>; }; ohci1-controller@0x05200400 { compatible = "allwinner,sunxi-ohci1"; reg = <0x0 0x5200000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x1d 0x4>; clocks = <0x54 0x56 0x57 0x52 0x9 0x1e>; hci_ctrl_no = <0x1>; status = "okay"; linux,phandle = <0x133>; phandle = <0x133>; }; usbc2@0 { device_type = "usbc2"; usb_drv_vbus_gpio; usb_host_init_state = <0x1>; usb_regulator_io = "nocare"; usb_wakeup_suspend = <0x2>; wakeup-source; status = "okay"; linux,phandle = <0x134>; phandle = <0x134>; }; ehci2-controller@0x05310000 { compatible = "allwinner,sunxi-ehci2"; reg = <0x0 0x5310000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x1e 0x4>; clocks = <0x58 0x59>; hci_ctrl_no = <0x2>; status = "okay"; linux,phandle = <0x135>; phandle = <0x135>; }; ohci2-controller@0x05310400 { compatible = "allwinner,sunxi-ohci2"; reg = <0x0 0x5310000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x1f 0x4>; clocks = <0x58 0x5a 0x5b 0x52 0x9 0x1e>; hci_ctrl_no = <0x2>; status = "okay"; linux,phandle = <0x136>; phandle = <0x136>; }; usbc3@0 { device_type = "usbc3"; usb_drv_vbus_gpio; usb_host_init_state = <0x1>; usb_regulator_io = "nocare"; usb_wakeup_suspend = <0x2>; wakeup-source; status = "okay"; linux,phandle = <0x137>; phandle = <0x137>; }; ehci3-controller@0x05311000 { compatible = "allwinner,sunxi-ehci3"; reg = <0x0 0x5311000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x20 0x4>; clocks = <0x5c 0x5d>; hci_ctrl_no = <0x3>; status = "okay"; linux,phandle = <0x138>; phandle = <0x138>; }; ohci3-controller@0x05311400 { compatible = "allwinner,sunxi-ohci3"; reg = <0x0 0x5311000 0x0 0xfff 0x0 0x0 0x0 0x100 0x0 0x5100000 0x0 0x1000>; interrupts = <0x0 0x21 0x4>; clocks = <0x5c 0x5e 0x5f 0x52 0x9 0x1e>; hci_ctrl_no = <0x3>; status = "okay"; linux,phandle = <0x139>; phandle = <0x139>; }; ac200_codec { compatible = "allwinner,ac200_codec"; status = "disabled"; linux,phandle = <0x13a>; phandle = <0x13a>; }; spdif-controller@0x05093000 { compatible = "allwinner,sunxi-spdif"; reg = <0x0 0x5093000 0x0 0x40>; clocks = <0x60 0x7 0x61>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x62>; pinctrl-1 = <0x63>; device_type = "spdif"; status = "okay"; linux,phandle = <0x75>; phandle = <0x75>; }; dmic-controller@0x05095000 { compatible = "allwinner,sunxi-dmic"; reg = <0x0 0x5095000 0x0 0x50>; clocks = <0x60 0x7 0x64>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x65>; pinctrl-1 = <0x66>; device_type = "dmic"; status = "disabled"; linux,phandle = <0x76>; phandle = <0x76>; }; codec@0x05096000 { compatible = "allwinner,sunxi-internal-codec"; reg = <0x0 0x5096000 0x0 0x31c>; clocks = <0x60 0x7 0x67>; device_type = "codec"; status = "okay"; adcdrc_cfg = <0x0>; adchpf_cfg = <0x0>; dacdrc_cfg = <0x0>; dachpf_cfg = <0x0>; fmin_gain = <0x3>; linein_gain = <0x3>; digital_vol = <0x0>; lineout_vol = <0x1a>; ramp_func_used = <0x1>; avcc-supply = <0x68>; vcc33_audio-supply = <0x69>; linux,phandle = <0x78>; phandle = <0x78>; }; cpudai-controller@0x05096000 { compatible = "allwinner,sunxi-internal-cpudai"; reg = <0x0 0x5096000 0x0 0x31c>; device_type = "cpudai"; status = "okay"; linux,phandle = <0x77>; phandle = <0x77>; }; cpudai0-controller@0x05097000 { compatible = "allwinner,sunxi-ahub-cpudai"; reg = <0x0 0x5097000 0x0 0xadf>; id = <0x0>; status = "okay"; linux,phandle = <0x79>; phandle = <0x79>; }; cpudai1-controller@0x05097000 { compatible = "allwinner,sunxi-ahub-cpudai"; reg = <0x0 0x5097000 0x0 0xadf>; id = <0x1>; status = "okay"; linux,phandle = <0x7a>; phandle = <0x7a>; }; cpudai2-controller@0x05097000 { compatible = "allwinner,sunxi-ahub-cpudai"; reg = <0x0 0x5097000 0x0 0xadf>; id = <0x2>; status = "okay"; linux,phandle = <0x7b>; phandle = <0x7b>; }; cpudai3-controller@0x05097000 { compatible = "allwinner,sunxi-ahub-cpudai"; reg = <0x0 0x5097000 0x0 0xadf>; id = <0x3>; status = "okay"; linux,phandle = <0x13b>; phandle = <0x13b>; }; ahub_codec@0x05097000 { compatible = "allwinner,sunxi-ahub"; reg = <0x0 0x5097000 0x0 0xadf>; clocks = <0x60 0x7 0x6a>; status = "okay"; linux,phandle = <0x7c>; phandle = <0x7c>; }; ahub_daudio0@0x05097000 { compatible = "allwinner,sunxi-ahub-daudio"; reg = <0x0 0x5097000 0x0 0xadf>; clocks = <0x60 0x7 0x6a>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x6b>; pinctrl-1 = <0x6c>; tdm_num = <0x0>; device_type = "ahub_daudio0"; status = "okay"; pinconfig = <0x1>; frametype = <0x0>; pcm_lrck_period = <0x20>; slot_width_select = <0x20>; daudio_master = <0x4>; audio_format = <0x1>; signal_inversion = <0x1>; tdm_config = <0x1>; mclk_div = <0x0>; linux,phandle = <0x71>; phandle = <0x71>; }; ahub_daudio1@0x05097000 { compatible = "allwinner,sunxi-ahub-daudio"; reg = <0x0 0x5097000 0x0 0xadf>; clocks = <0x60 0x7 0x6a>; tdm_num = <0x1>; device_type = "ahub_daudio1"; status = "okay"; pinconfig = <0x0>; frametype = <0x0>; pcm_lrck_period = <0x20>; slot_width_select = <0x20>; daudio_master = <0x4>; audio_format = <0x1>; signal_inversion = <0x1>; tdm_config = <0x1>; mclk_div = <0x1>; linux,phandle = <0x72>; phandle = <0x72>; }; ahub_daudio2@0x05097000 { compatible = "allwinner,sunxi-ahub-daudio"; reg = <0x0 0x5097000 0x0 0xadf>; clocks = <0x60 0x7 0x6a>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x6d>; pinctrl-1 = <0x6e>; tdm_num = <0x2>; device_type = "ahub_daudio2"; status = "disabled"; pinconfig = <0x1>; frametype = <0x0>; pcm_lrck_period = <0x20>; slot_width_select = <0x20>; daudio_master = <0x4>; audio_format = <0x1>; signal_inversion = <0x1>; tdm_config = <0x1>; mclk_div = <0x4>; linux,phandle = <0x73>; phandle = <0x73>; }; ahub_daudio3@0x05097000 { compatible = "allwinner,sunxi-ahub-daudio"; reg = <0x0 0x5097000 0x0 0xadf>; clocks = <0x60 0x7 0x6a>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x6f>; pinctrl-1 = <0x70>; tdm_num = <0x3>; device_type = "ahub_daudio3"; status = "disabled"; pinconfig = <0x1>; frametype = <0x0>; pcm_lrck_period = <0x20>; slot_width_select = <0x20>; daudio_master = <0x4>; audio_format = <0x1>; signal_inversion = <0x1>; tdm_config = <0x1>; mclk_div = <0x4>; linux,phandle = <0x74>; phandle = <0x74>; }; sound@0 { compatible = "allwinner,sunxi-daudio0-machine"; sunxi,cpudai-controller = <0x71>; device_type = "snddaudio0"; status = "okay"; linux,phandle = <0x13c>; phandle = <0x13c>; }; sound@1 { compatible = "allwinner,sunxi-hdmi-machine"; sunxi,cpudai-controller = <0x72>; device_type = "sndhdmi"; status = "okay"; linux,phandle = <0x13d>; phandle = <0x13d>; }; sound@2 { compatible = "allwinner,sunxi-daudio2-machine"; sunxi,cpudai-controller = <0x73>; device_type = "snddaudio2"; status = "disabled"; linux,phandle = <0x13e>; phandle = <0x13e>; }; sound@3 { compatible = "allwinner,sunxi-daudio3-machine"; sunxi,cpudai-controller = <0x74>; device_type = "snddaudio3"; status = "disabled"; linux,phandle = <0x13f>; phandle = <0x13f>; }; sound@4 { compatible = "allwinner,sunxi-spdif-machine"; sunxi,spdif-controller = <0x75>; device_type = "sndspdif"; status = "okay"; linux,phandle = <0x140>; phandle = <0x140>; }; sound@5 { compatible = "allwinner,sunxi-dmic-machine"; sunxi,dmic-controller = <0x76>; device_type = "snddmic"; status = "disabled"; linux,phandle = <0x141>; phandle = <0x141>; }; sound@6 { compatible = "allwinner,sunxi-codec-machine"; sunxi,cpudai-controller = <0x77>; sunxi,audio-codec = <0x78>; device_type = "sndcodec"; status = "okay"; linux,phandle = <0x142>; phandle = <0x142>; }; sound@7 { compatible = "allwinner,sunxi-ahub-machine"; sunxi,cpudai-controller0 = <0x79>; sunxi,cpudai-controller1 = <0x7a>; sunxi,cpudai-controller2 = <0x7b>; sunxi,audio-codec = <0x7c>; device_type = "sndahub"; status = "okay"; linux,phandle = <0x143>; phandle = <0x143>; }; spi@05010000 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-spi"; device_type = "spi0"; reg = <0x0 0x5010000 0x0 0x1000>; interrupts = <0x0 0xc 0x4>; clocks = <0x2 0x7d>; clock-frequency = <0x5f5e100>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x7e 0x7f>; pinctrl-1 = <0x80>; spi0_cs_number = <0x1>; spi0_cs_bitmap = <0x1>; status = "disabled"; linux,phandle = <0x144>; phandle = <0x144>; }; spi@05011000 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun50i-spi"; device_type = "spi1"; reg = <0x0 0x5011000 0x0 0x1000>; interrupts = <0x0 0xd 0x4>; clocks = <0x2 0x81>; clock-frequency = <0x5f5e100>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x82 0x83>; pinctrl-1 = <0x84>; spi1_cs_number = <0x1>; spi1_cs_bitmap = <0x1>; status = "disable"; spi_slave_mode = <0x0>; linux,phandle = <0x145>; phandle = <0x145>; spi_board1 { device_type = "spi_board1"; compatible = "rohm,dh2228fv"; spi-max-frequency = <0x5f5e100>; reg = <0x0>; spi-rx-bus-width = <0x1>; spi-tx-bus-width = <0x1>; }; }; pcie@0x05400000 { #address-cells = <0x3>; #size-cells = <0x2>; compatible = "allwinner,sun50i-pcie"; reg = <0x0 0x5400000 0x0 0x2000 0x0 0x5410000 0x0 0x10000>; reg-names = "dbi", "config"; device_type = "pci"; ranges = <0x800 0x0 0x5410000 0x0 0x5410000 0x0 0x10000 0x81000000 0x0 0x0 0x0 0x5e00000 0x0 0x10000 0x82000000 0x0 0x5500000 0x0 0x5500000 0x0 0x800000>; num-lanes = <0x1>; interrupts = <0x0 0x7f 0x4 0x0 0x7e 0x4>; interrupt-names = "msi"; #interrupt-cells = <0x1>; interrupt-map-mask = <0x0 0x0 0x0 0x0>; interrupt-map = <0x0 0x0 0x0 0x1 0x85 0x0 0x7f 0x4>; status = "okay"; linux,phandle = <0x146>; phandle = <0x146>; }; sdmmc@04022000 { compatible = "allwinner,sunxi-mmc-v4p6x"; device_type = "sdc2"; reg = <0x0 0x4022000 0x0 0x1000>; interrupts = <0x0 0x25 0x4>; clocks = <0x9 0x86 0x87 0x88 0x89>; clock-names = "osc24m", "pll_periph", "mmc", "ahb", "rst"; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x8a 0x8b>; pinctrl-1 = <0x8c>; bus-width = <0x8>; cap-mmc-highspeed; cap-cmd23; mmc-cache-ctrl; non-removable; max-frequency = <0x5f5e100>; cap-erase; mmc-high-capacity-erase-size; no-sdio; no-sd; sdc_tm4_sm0_freq0 = <0x0>; sdc_tm4_sm0_freq1 = <0x0>; sdc_tm4_sm1_freq0 = <0x0>; sdc_tm4_sm1_freq1 = <0x0>; sdc_tm4_sm2_freq0 = <0x0>; sdc_tm4_sm2_freq1 = <0x0>; sdc_tm4_sm3_freq0 = <0x5000000>; sdc_tm4_sm3_freq1 = <0x5>; sdc_tm4_sm4_freq0 = <0x50000>; sdc_tm4_sm4_freq1 = <0x4>; status = "disabled"; mmc-ddr-1_8v; mmc-hs200-1_8v; mmc-hs400-1_8v; sunxi-power-save-mode; sunxi-dis-signal-vol-sw; ctl-spec-caps = <0x8>; vmmc-supply = <0x69>; vqmmc-supply = <0x68>; linux,phandle = <0x147>; phandle = <0x147>; }; sdmmc@04020000 { compatible = "allwinner,sunxi-mmc-v4p1x"; device_type = "sdc0"; reg = <0x0 0x4020000 0x0 0x1000>; interrupts = <0x0 0x23 0x4>; clocks = <0x9 0x86 0x8d 0x8e 0x8f>; clock-names = "osc24m", "pll_periph", "mmc", "ahb", "rst"; pinctrl-names = "default", "sleep", "uart_jtag"; pinctrl-0 = <0x90>; pinctrl-1 = <0x91>; pinctrl-2 = <0x92>; max-frequency = <0x8f0d180>; bus-width = <0x4>; cd-gpios = <0x53 0x8 0x10 0x6 0x1 0x3 0xffffffff>; cap-sd-highspeed; cap-wait-while-busy; no-sdio; no-mmc; sunxi-power-save-mode; status = "okay"; cd-used-24M; sd-uhs-sdr50; sd-uhs-ddr50; sd-uhs-sdr104; ctl-spec-caps = <0x8>; vmmc-supply = <0x69>; vqmmc33sw-supply = <0x69>; vdmmc33sw-supply = <0x69>; vqmmc18sw-supply = <0x68>; vdmmc18sw-supply = <0x68>; linux,phandle = <0x148>; phandle = <0x148>; }; sdmmc@04021000 { compatible = "allwinner,sunxi-mmc-v4p1x"; device_type = "sdc1"; reg = <0x0 0x4021000 0x0 0x1000>; interrupts = <0x0 0x24 0x4>; clocks = <0x9 0x86 0x93 0x94 0x95>; clock-names = "osc24m", "pll_periph", "mmc", "ahb", "rst"; pinctrl-names = "default", "sleep"; pinctrl-0 = <0x96>; pinctrl-1 = <0x97>; max-frequency = <0x8f0d180>; bus-width = <0x4>; keep-power-in-suspend; sunxi-dly-52M-ddr4 = <0x1 0x0 0x0 0x0 0x2>; sunxi-dly-104M = <0x1 0x0 0x0 0x0 0x1>; sunxi-dly-208M = <0x1 0x0 0x0 0x0 0x1>; status = "okay"; no-mmc; no-sd; cap-sd-highspeed; sd-uhs-sdr50; sd-uhs-ddr50; sd-uhs-sdr104; sunxi-dis-signal-vol-sw; cap-sdio-irq; ignore-pm-notify; ctl-spec-caps = <0x8>; linux,phandle = <0xd4>; phandle = <0xd4>; }; disp@01000000 { compatible = "allwinner,sunxi-disp"; reg = <0x0 0x1000000 0x0 0x1400000 0x0 0x6510000 0x0 0x200 0x0 0x6511000 0x0 0x1000 0x0 0x6512000 0x0 0x1000 0x0 0x6515000 0x0 0x1000 0x0 0x6516000 0x0 0x1000>; interrupts = <0x0 0x58 0x4 0x0 0x40 0x4 0x0 0x41 0x4 0x0 0x42 0x4 0x0 0x43 0x4>; clocks = <0xb 0x98 0x12 0x13 0x14 0x15 0x16>; boot_disp = <0x0>; fb_base = <0x0>; iommus = <0x28 0x0 0x0>; status = "okay"; disp_init_enable = <0x1>; disp_mode = <0x0>; screen0_output_type = <0x3>; screen0_output_mode = <0xa>; screen0_output_format = <0x0>; screen0_output_bits = <0x0>; screen0_output_eotf = <0x4>; screen0_output_cs = <0x101>; screen0_output_dvi_hdmi = <0x2>; screen0_output_range = <0x2>; screen0_output_scan = <0x0>; screen0_output_aspect_ratio = <0x8>; screen1_output_type = <0x2>; screen1_output_mode = <0xb>; screen1_output_format = <0x1>; screen1_output_bits = <0x0>; screen1_output_eotf = <0x4>; screen1_output_cs = <0x104>; screen1_output_dvi_hdmi = <0x0>; screen1_output_range = <0x2>; screen1_output_scan = <0x0>; screen1_output_aspect_ratio = <0x8>; dev0_output_type = <0x4>; dev0_output_mode = <0xa>; dev0_screen_id = <0x0>; dev0_do_hpd = <0x1>; dev1_output_type = <0x2>; dev1_output_mode = <0xb>; dev1_screen_id = <0x1>; dev1_do_hpd = <0x1>; dev2_output_type = <0x0>; def_output_dev = <0x0>; hdmi_mode_check = <0x1>; fb0_format = <0x0>; fb0_width = <0x500>; fb0_height = <0x2d0>; fb1_format = <0x0>; fb1_width = <0x0>; fb1_height = <0x0>; chn_cfg_mode = <0x1>; disp_para_zone = <0x1>; linux,phandle = <0x149>; phandle = <0x149>; }; tv0@01c94000 { compatible = "allwinner,sunxi-tv"; reg = <0x0 0x6520000 0x0 0x100 0x0 0x6524000 0x0 0x3fc>; clocks = <0x18 0x17>; device_type = "tv0"; pinctrl-names = "active", "sleep"; status = "okay"; dac_src0 = <0x0>; dac_type0 = <0x0>; interface = <0x1>; linux,phandle = <0x14a>; phandle = <0x14a>; }; lcd0@01c0c000 { compatible = "allwinner,sunxi-lcd0"; pinctrl-names = "active", "sleep"; status = "okay"; lcd_used = <0x0>; lcd_driver_name = "default_lcd"; lcd_backlight = <0x32>; lcd_if = <0x0>; lcd_x = <0x500>; lcd_y = <0x320>; lcd_width = <0x96>; lcd_height = <0x5e>; lcd_dclk_freq = <0x46>; lcd_pwm_used = <0x0>; lcd_pwm_ch = <0x0>; lcd_pwm_freq = <0xc350>; lcd_pwm_pol = <0x0>; lcd_pwm_max_limit = <0xff>; lcd_hbp = <0x14>; lcd_ht = <0x58a>; lcd_hspw = <0xa>; lcd_vbp = <0xa>; lcd_vt = <0x32e>; lcd_vspw = <0x5>; lcd_lvds_if = <0x0>; lcd_lvds_colordepth = <0x0>; lcd_lvds_mode = <0x0>; lcd_frm = <0x0>; lcd_hv_clk_phase = <0x0>; lcd_hv_sync_polarity = <0x0>; lcd_gamma_en = <0x0>; lcd_bright_curve_en = <0x0>; lcd_cmap_en = <0x0>; deu_mode = <0x0>; lcdgamma4iep = <0x16>; smart_color = <0x5a>; lcd_pin_power = "bldo1"; lcd_power = "dc1sw"; pinctrl-0 = <0x99>; pinctrl-1 = <0x9a>; linux,phandle = <0x14b>; phandle = <0x14b>; }; lcd1@01c0c001 { compatible = "allwinner,sunxi-lcd1"; pinctrl-names = "active", "sleep"; status = "okay"; linux,phandle = <0x14c>; phandle = <0x14c>; }; boot_disp { compatible = "allwinner,boot_disp"; linux,phandle = <0x14d>; phandle = <0x14d>; }; hdmi@06000000 { compatible = "allwinner,sunxi-hdmi"; reg = <0x0 0x6000000 0x0 0x100000>; interrupts = <0x0 0x3f 0x0>; clocks = <0xf 0x10 0x19 0x11>; status = "okay"; hdmi_used = <0x1>; hdmi_power_cnt = <0x2>; hdmi_power0 = "vcc-hdmi"; hdmi_power1 = "vdd-hdmi"; hdmi_hdcp_enable = <0x1>; hdmi_hdcp22_enable = <0x1>; hdmi_cts_compatibility = <0x0>; hdmi_cec_support = <0x0>; hdmi_cec_super_standby = <0x0>; hdmi_skip_bootedid = <0x1>; ddc_en_io_ctrl = <0x0>; power_io_ctrl = <0x0>; linux,phandle = <0x14e>; phandle = <0x14e>; }; g2d@01480000 { compatible = "allwinner,sunxi-g2d"; reg = <0x0 0x1480000 0x0 0x3ffff>; interrupts = <0x0 0x5a 0x4>; clocks = <0xd>; iommus = <0x28 0x6 0x1>; linux,phandle = <0x14f>; phandle = <0x14f>; }; tr@01000000 { compatible = "allwinner,sun50i-tr"; reg = <0x0 0x1000000 0x0 0x200bc>; interrupts = <0x0 0x60 0x4>; clocks = <0xb>; status = "okay"; linux,phandle = <0x150>; phandle = <0x150>; }; pwm@0300a000 { compatible = "allwinner,sunxi-pwm"; reg = <0x0 0x300a000 0x0 0x3ff>; clocks = <0x9b>; pwm-number = <0x6>; pwm-base = <0x0>; pwms = <0x9c 0x9d 0x9e 0x9f 0xa0 0xa1>; linux,phandle = <0x151>; phandle = <0x151>; }; pwm0@0300a000 { compatible = "allwinner,sunxi-pwm0"; pinctrl-names = "active", "sleep"; reg_base = <0x300a000>; linux,phandle = <0x9c>; phandle = <0x9c>; }; pwm1@0300a000 { compatible = "allwinner,sunxi-pwm1"; pinctrl-names = "active", "sleep"; reg_base = <0x300a000>; linux,phandle = <0x9d>; phandle = <0x9d>; }; pwm2@0300a000 { compatible = "allwinner,sunxi-pwm2"; pinctrl-names = "active", "sleep"; reg_base = <0x300a000>; linux,phandle = <0x9e>; phandle = <0x9e>; }; pwm3@0300a000 { compatible = "allwinner,sunxi-pwm3"; pinctrl-names = "active", "sleep"; reg_base = <0x300a000>; linux,phandle = <0x9f>; phandle = <0x9f>; }; pwm4@0300a000 { compatible = "allwinner,sunxi-pwm4"; pinctrl-names = "active", "sleep"; reg_base = <0x300a000>; linux,phandle = <0xa0>; phandle = <0xa0>; }; pwm5@0300a000 { compatible = "allwinner,sunxi-pwm5"; pinctrl-names = "active", "sleep"; reg_base = <0x300a000>; pinctrl-0 = <0xa2>; pinctrl-1 = <0xa3>; clk_bypass_output = <0x1>; linux,phandle = <0xa1>; phandle = <0xa1>; }; ac200 { compatible = "allwinner,sunxi-ac200"; status = "okay"; tv_used = <0x1>; tv_twi_used = <0x1>; tv_twi_id = <0x3>; tv_twi_addr = <0x10>; tv_pwm_ch = <0x5>; linux,phandle = <0x152>; phandle = <0x152>; }; vind@0 { compatible = "allwinner,sunxi-vin-media", "simple-bus"; #address-cells = <0x2>; #size-cells = <0x2>; ranges; device_id = <0x0>; vind0_clk = <0x16e36000>; reg = <0x0 0x6600800 0x0 0x200 0x0 0x6600000 0x0 0x800>; clocks = <0xa4 0xa5 0xa6 0x9 0xa5 0xa7 0x9 0xa5>; pinctrl-names = "mclk0-default", "mclk0-sleep", "mclk1-default", "mclk1-sleep"; pinctrl-0 = <0xa8>; pinctrl-1 = <0xa9>; pinctrl-2 = <0xaa>; pinctrl-3 = <0xab>; status = "okay"; linux,phandle = <0x153>; phandle = <0x153>; cci@0 { compatible = "allwinner,sunxi-csi_cci"; reg = <0x0 0x6614000 0x0 0x400>; interrupts = <0x0 0x4b 0x4>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0xac>; pinctrl-1 = <0xad>; device_id = <0x0>; status = "okay"; linux,phandle = <0x154>; phandle = <0x154>; }; cci@1 { compatible = "allwinner,sunxi-csi_cci"; reg = <0x0 0x6614400 0x0 0x400>; interrupts = <0x0 0x4c 0x4>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0xae>; pinctrl-1 = <0xaf>; device_id = <0x1>; status = "okay"; linux,phandle = <0x155>; phandle = <0x155>; }; csi@0 { device_type = "csi0"; compatible = "allwinner,sunxi-csi"; reg = <0x0 0x6601000 0x0 0x1000>; interrupts = <0x0 0x49 0x4>; device_id = <0x0>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x156>; phandle = <0x156>; }; csi@1 { device_type = "csi1"; compatible = "allwinner,sunxi-csi"; reg = <0x0 0x6602000 0x0 0x1000>; interrupts = <0x0 0x4a 0x4>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0xb0>; pinctrl-1 = <0xb1>; device_id = <0x1>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x157>; phandle = <0x157>; }; mipi@0 { compatible = "allwinner,sunxi-mipi"; reg = <0x0 0x660c000 0x0 0x1000>; interrupts = <0x0 0x4d 0x4>; device_id = <0x0>; status = "okay"; linux,phandle = <0x158>; phandle = <0x158>; }; isp@0 { compatible = "allwinner,sunxi-isp"; device_id = <0x0>; status = "okay"; linux,phandle = <0x159>; phandle = <0x159>; }; isp@1 { compatible = "allwinner,sunxi-isp"; device_id = <0x1>; status = "okay"; linux,phandle = <0x15a>; phandle = <0x15a>; }; scaler@0 { compatible = "allwinner,sunxi-scaler"; device_id = <0x0>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x15b>; phandle = <0x15b>; }; scaler@1 { compatible = "allwinner,sunxi-scaler"; device_id = <0x1>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x15c>; phandle = <0x15c>; }; scaler@2 { compatible = "allwinner,sunxi-scaler"; device_id = <0x2>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x15d>; phandle = <0x15d>; }; scaler@3 { compatible = "allwinner,sunxi-scaler"; device_id = <0x3>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x15e>; phandle = <0x15e>; }; scaler@4 { compatible = "allwinner,sunxi-scaler"; device_id = <0x4>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x15f>; phandle = <0x15f>; }; scaler@5 { compatible = "allwinner,sunxi-scaler"; device_id = <0x5>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x160>; phandle = <0x160>; }; actuator@0 { device_type = "actuator0"; compatible = "allwinner,sunxi-actuator"; actuator0_name = "ad5820_act"; actuator0_slave = <0x18>; actuator0_af_pwdn; actuator0_afvdd = "afvcc-csi"; actuator0_afvdd_vol = <0x2ab980>; status = "disabled"; linux,phandle = <0xb3>; phandle = <0xb3>; }; flash@0 { device_type = "flash0"; compatible = "allwinner,sunxi-flash"; flash0_type = <0x2>; flash0_en; flash0_mode; flash0_flvdd = [00]; flash0_flvdd_vol; device_id = <0x0>; status = "disabled"; linux,phandle = <0xb2>; phandle = <0xb2>; }; sensor@0 { device_type = "sensor0"; compatible = "allwinner,sunxi-sensor"; sensor0_mname = "ov5640"; sensor0_twi_cci_id = <0x0>; sensor0_twi_addr = <0x78>; sensor0_mclk_id = <0x0>; sensor0_pos = "rear"; sensor0_isp_used = <0x0>; sensor0_fmt = <0x0>; sensor0_stby_mode = <0x0>; sensor0_vflip = <0x0>; sensor0_hflip = <0x0>; sensor0_cameravdd-supply; sensor0_cameravdd_vol = <0x2ab980>; sensor0_iovdd-supply; sensor0_iovdd_vol = <0x2ab980>; sensor0_avdd-supply; sensor0_avdd_vol = <0x2ab980>; sensor0_dvdd-supply; sensor0_dvdd_vol = <0x16e360>; sensor0_power_en; sensor0_reset = <0x53 0x4 0xe 0x1 0x0 0x1 0x0>; sensor0_pwdn = <0x53 0x4 0x10 0x1 0x0 0x1 0x0>; sensor0_sm_vs; flash_handle = <0xb2>; act_handle = <0xb3>; device_id = <0x0>; status = "okay"; linux,phandle = <0x161>; phandle = <0x161>; }; sensor@1 { device_type = "sensor1"; compatible = "allwinner,sunxi-sensor"; sensor1_mname = "ov5647"; sensor1_twi_cci_id = <0x1>; sensor1_twi_addr = <0x6c>; sensor1_mclk_id = <0x1>; sensor1_pos = "front"; sensor1_isp_used = <0x0>; sensor1_fmt = <0x0>; sensor1_stby_mode = <0x0>; sensor1_vflip = <0x0>; sensor1_hflip = <0x0>; sensor1_cameravdd-supply; sensor1_cameravdd_vol = <0x2ab980>; sensor1_iovdd-supply; sensor1_iovdd_vol = <0x2ab980>; sensor1_avdd-supply; sensor1_avdd_vol = <0x2ab980>; sensor1_dvdd-supply; sensor1_dvdd_vol = <0x16e360>; sensor1_power_en; sensor1_reset = <0x53 0x4 0xe 0x1 0x0 0x1 0x0>; sensor1_pwdn = <0x53 0x4 0xf 0x1 0x0 0x1 0x0>; sensor1_sm_vs; flash_handle; act_handle; device_id = <0x1>; status = "okay"; linux,phandle = <0x162>; phandle = <0x162>; }; vinc@0 { device_type = "vinc0"; compatible = "allwinner,sunxi-vin-core"; reg = <0x0 0x6609000 0x0 0x200>; interrupts = <0x0 0x45 0x4>; vinc0_csi_sel = <0x0>; vinc0_mipi_sel = <0x0>; vinc0_isp_sel = <0x0>; vinc0_isp_tx_ch = <0x0>; vinc0_rear_sensor_sel = <0x0>; vinc0_front_sensor_sel = <0x0>; vinc0_sensor_list = <0x0>; device_id = <0x0>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x163>; phandle = <0x163>; }; vinc@1 { device_type = "vinc1"; compatible = "allwinner,sunxi-vin-core"; reg = <0x0 0x6609200 0x0 0x200>; interrupts = <0x0 0x46 0x4>; vinc1_csi_sel = <0x0>; vinc1_mipi_sel = <0x0>; vinc1_isp_sel = <0x0>; vinc1_isp_tx_ch = <0x0>; vinc1_rear_sensor_sel = <0x0>; vinc1_front_sensor_sel = <0x0>; vinc1_sensor_list = <0x0>; device_id = <0x1>; iommus = <0x28 0x4 0x1>; status = "okay"; linux,phandle = <0x164>; phandle = <0x164>; }; vinc@2 { device_type = "vinc2"; compatible = "allwinner,sunxi-vin-core"; reg = <0x0 0x6609400 0x0 0x200>; interrupts = <0x0 0x47 0x4>; vinc2_csi_sel = <0x0>; vinc2_mipi_sel = <0x0>; vinc2_isp_sel = <0x0>; vinc2_isp_tx_ch = <0x0>; vinc2_rear_sensor_sel = <0x0>; vinc2_front_sensor_sel = <0x0>; vinc2_sensor_list = <0x0>; device_id = <0x2>; iommus = <0x28 0x4 0x1>; status = "disabled"; linux,phandle = <0x165>; phandle = <0x165>; }; vinc@3 { device_type = "vinc3"; compatible = "allwinner,sunxi-vin-core"; reg = <0x0 0x6609600 0x0 0x200>; interrupts = <0x0 0x48 0x4>; vinc3_csi_sel = <0x0>; vinc3_mipi_sel = <0x0>; vinc3_isp_sel = <0x0>; vinc3_isp_tx_ch = <0x0>; vinc3_rear_sensor_sel = <0x0>; vinc3_front_sensor_sel = <0x0>; vinc3_sensor_list = <0x0>; device_id = <0x3>; iommus = <0x28 0x4 0x1>; status = "disabled"; linux,phandle = <0x166>; phandle = <0x166>; }; vinc@4 { device_type = "vinc4"; compatible = "allwinner,sunxi-vin-core"; reg = <0x0 0x6609800 0x0 0x200>; interrupts = <0x0 0x4f 0x4>; vinc4_csi_sel = <0x1>; vinc4_mipi_sel = <0xff>; vinc4_isp_sel = <0x1>; vinc4_isp_tx_ch = <0x0>; vinc4_rear_sensor_sel = <0x1>; vinc4_front_sensor_sel = <0x1>; vinc4_sensor_list = <0x0>; device_id = <0x4>; iommus = <0x28 0x5 0x1>; status = "disabled"; linux,phandle = <0x167>; phandle = <0x167>; }; vinc@5 { device_type = "vinc5"; compatible = "allwinner,sunxi-vin-core"; reg = <0x0 0x6609a00 0x0 0x200>; interrupts = <0x0 0x50 0x4>; vinc5_csi_sel = <0x1>; vinc5_mipi_sel = <0xff>; vinc5_isp_sel = <0x1>; vinc5_isp_tx_ch = <0x0>; vinc5_rear_sensor_sel = <0x1>; vinc5_front_sensor_sel = <0x1>; vinc5_sensor_list = <0x0>; device_id = <0x5>; iommus = <0x28 0x5 0x1>; status = "disabled"; linux,phandle = <0x168>; phandle = <0x168>; }; }; vdevice@0 { compatible = "allwinner,sun50i-vdevice"; device_type = "Vdevice"; pinctrl-names = "default"; interrupt-parent = <0x53>; interrupts = <0x0 0x3 0x4>; pinctrl-0 = <0xb4>; test-gpios = <0x53 0x0 0x0 0x1 0x2 0x2 0x1>; status = "okay"; linux,phandle = <0x169>; phandle = <0x169>; }; emce@01905000 { compatible = "allwinner,sunxi-emce"; device_name = "emce"; reg = <0x0 0x1905000 0x0 0x100>; clock-frequency = <0x11e1a300>; linux,phandle = <0x16a>; phandle = <0x16a>; }; ce@1904000 { compatible = "allwinner,sunxi-ce"; device_name = "ce"; reg = <0x0 0x1904000 0x0 0xa0 0x0 0x1904800 0x0 0xa0>; interrupts = <0x0 0x5b 0x1 0x0 0x5c 0x1>; clock-frequency = <0x11e1a300>; clocks = <0xb5 0xc>; linux,phandle = <0x16b>; phandle = <0x16b>; }; deinterlace@0x01420000 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sunxi-deinterlace"; reg = <0x0 0x1420000 0x0 0x40000>; interrupts = <0x0 0x59 0x4>; clocks = <0xe 0xc>; iommus = <0x28 0x1 0x1>; status = "okay"; linux,phandle = <0x16c>; phandle = <0x16c>; }; smartcard@0x05005000 { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sunxi-scr"; device_type = "scr0"; reg = <0x0 0x5005000 0x0 0x400>; interrupts = <0x0 0x8 0x4>; clocks = <0xb6 0xb7>; clock-frequency = <0x16e3600>; pinctrl-names = "default", "sleep"; pinctrl-0 = <0xb8 0xb9>; pinctrl-1 = <0xba>; status = "disabled"; linux,phandle = <0x16d>; phandle = <0x16d>; }; nand0@04011000 { compatible = "allwinner,sun50iw9-nand"; device_type = "nand0"; reg = <0x0 0x4011000 0x0 0x1000>; interrupts = <0x0 0x22 0x4>; clocks = <0xc 0xbb 0xbc>; pinctrl-names = "default", "sleep"; pinctrl-1 = <0xbf>; nand0_regulator1 = "vcc-nand"; nand0_regulator2 = "none"; nand0_cache_level = <0x55aaaa55>; nand0_flush_cache_num = <0x55aaaa55>; nand0_capacity_level = <0x55aaaa55>; nand0_id_number_ctl = <0x55aaaa55>; nand0_print_level = <0x55aaaa55>; nand0_p0 = <0x55aaaa55>; nand0_p1 = <0x55aaaa55>; nand0_p2 = <0x55aaaa55>; nand0_p3 = <0x55aaaa55>; chip_code = "sun50iw9"; status = "disabled"; linux,phandle = <0x16e>; phandle = <0x16e>; nand0_support_2ch = <0x0>; pinctrl-0 = <0x18b 0x18c>; }; ts0@05060000 { compatible = "allwinner,sun50i-tsc"; device_type = "ts0"; reg = <0x0 0x5060000 0x0 0x1000>; interrupts = <0x0 0x11 0x4>; clocks = <0x2 0xc0>; clock-frequency = <0x7270e00>; pinctrl-names = "ts0-default", "ts0-sleep"; pinctrl-0 = <0xc1>; pinctrl-1 = <0xc2>; ts0config = <0x1>; status = "okay"; linux,phandle = <0x16f>; phandle = <0x16f>; }; thermal_sensor { compatible = "arm,sun50iw9p1"; reg = <0x0 0x5070400 0x0 0x400>; clocks = <0xc3>; clock-names = "bus"; nvmem-cells = <0xc4>; nvmem-cell-names = "calibration"; nvmem-names = "sid"; nvmem = <0xc5>; #thermal-sensor-cells = <0x1>; linux,phandle = <0xc6>; phandle = <0xc6>; }; thermal-zones { cpu_thermal_zone { polling-delay-passive = <0x1f4>; polling-delay = <0x3e8>; thermal-sensors = <0xc6 0x2>; sustainable-power = <0x3e8>; k_po = <0x14>; k_pu = <0x28>; k_i = <0x0>; trips { linux,phandle = <0x170>; phandle = <0x170>; trip-point@0 { temperature = <0xea60>; type = "passive"; hysteresis = <0x0>; linux,phandle = <0x171>; phandle = <0x171>; }; trip-point@1 { temperature = <0x11170>; type = "passive"; hysteresis = <0x0>; linux,phandle = <0xc7>; phandle = <0xc7>; }; cpu_crit@0 { temperature = <0x1c138>; type = "critical"; hysteresis = <0x0>; linux,phandle = <0x172>; phandle = <0x172>; }; }; cooling-maps { map0 { trip = <0xc7>; cooling-device = <0xc8 0xffffffff 0xffffffff>; contribution = <0x400>; }; map1 { trip = <0xc7>; cooling-device = <0xc9 0xffffffff 0xffffffff>; contribution = <0x400>; }; }; }; gpu_thermal_zone { polling-delay-passive = <0x1f4>; polling-delay = <0x3e8>; thermal-sensors = <0xc6 0x0>; sustainable-power = <0x44c>; }; ve_thermal_zone { polling-delay-passive = <0x0>; polling-delay = <0x0>; thermal-sensors = <0xc6 0x1>; }; ddr_thermal_zone { polling-delay-passive = <0x0>; polling-delay = <0x0>; thermal-sensors = <0xc6 0x3>; }; }; gpadc { compatible = "allwinner,sunxi-gpadc"; reg = <0x0 0x5070000 0x0 0x400>; interrupts = <0x0 0x12 0x0>; clocks = <0xca>; status = "okay"; channel_num = <0x1>; channel_select = <0x1>; channel_data_select = <0x0>; channel_compare_select = <0x1>; channel_cld_select = <0x1>; channel_chd_select = <0x0>; channel0_compare_lowdata = <0x19f0a0>; channel0_compare_higdata = <0x124f80>; key_cnt = <0x5>; key0_vol = <0x73>; key0_val = <0x73>; key1_vol = <0xf0>; key1_val = <0x72>; key2_vol = <0x168>; key2_val = <0x8b>; key3_vol = <0x1e0>; key3_val = <0x1c>; key4_vol = <0x258>; key4_val = <0x66>; linux,phandle = <0x173>; phandle = <0x173>; }; keyboard { compatible = "allwinner,keyboard_1350mv"; reg = <0x0 0x5070800 0x0 0x400>; clocks = <0xcb>; interrupts = <0x0 0x14 0x0>; status = "okay"; key_cnt = <0x5>; key0 = <0xd2 0x73>; key1 = <0x19a 0x72>; key2 = <0x24e 0x8b>; key3 = <0x2ee 0x1c>; key4 = <0x370 0xac>; linux,phandle = <0x174>; phandle = <0x174>; }; eth@05020000 { compatible = "allwinner,sunxi-gmac"; reg = <0x0 0x5020000 0x0 0x10000 0x0 0x3000030 0x0 0x4>; interrupts = <0x0 0xe 0x4>; interrupt-names = "gmacirq"; clocks = <0xcc 0xcd>; clock-names = "gmac", "ephy"; device_type = "gmac0"; pinctrl-0 = <0xce>; pinctrl-1 = <0xcf>; pinctrl-names = "default", "sleep"; phy-mode; tx-delay = <0x7>; rx-delay = <0x1f>; phy-rst; gmac-power0; gmac-power1; gmac-power2; status = "disable"; linux,phandle = <0x175>; phandle = <0x175>; }; eth@05030000 { compatible = "allwinner,sunxi-gmac"; reg = <0x0 0x5030000 0x0 0x10000 0x0 0x3000034 0x0 0x4>; interrupts = <0x0 0xf 0x4>; interrupt-names = "gmacirq"; clocks = <0xd0>; clock-names = "gmac"; device_type = "gmac1"; pinctrl-0 = <0xd1>; pinctrl-1 = <0xd2>; pinctrl-names = "default", "sleep"; phy-mode = "rmii"; tx-delay = <0x7>; rx-delay = <0x1f>; phy-rst; gmac-power0; gmac-power1; gmac-power2; status = "okay"; linux,phandle = <0x176>; phandle = <0x176>; }; gpio_encrypt { compatible = "allwinner,gpio_encrypt"; gpio_number_sun = <0x5>; gpio1_value = <0x0>; gpio2_value = <0x0>; gpio3_value = <0x0>; gpio4_value = <0x0>; gpio5_value = <0x0>; gpio1_pin = <0x53 0x8 0x1 0x1 0xffffffff 0xffffffff 0x0>; gpio2_pin = <0x53 0x8 0x2 0x1 0xffffffff 0xffffffff 0x0>; gpio3_pin = <0x53 0x8 0x3 0x1 0xffffffff 0xffffffff 0x0>; gpio4_pin = <0x53 0x8 0x4 0x1 0xffffffff 0xffffffff 0x0>; gpio5_pin = <0x53 0x8 0x5 0x1 0xffffffff 0xffffffff 0x0>; status = "disable"; linux,phandle = <0x177>; phandle = <0x177>; }; fd650 { compatible = "oranth,fd650"; status = "okay"; fd650_gpio_clk = <0x53 0x8 0xb 0x1 0xffffffff 0xffffffff 0x0>; fd650_gpio_dat = <0x53 0x8 0xc 0x1 0xffffffff 0xffffffff 0x0>; }; wlan { compatible = "allwinner,sunxi-wlan"; clocks = <0x1b>; pinctrl-0 = <0xd3>; pinctrl-names = "default"; wlan_busnum = <0x1>; wlan_power; wlan_io_regulator; wlan_regon = <0x53 0x6 0x12 0x1 0xffffffff 0xffffffff 0x0>; wlan_hostwake = <0x53 0x6 0xf 0x6 0xffffffff 0xffffffff 0x0>; chip_en; power_en; status = "okay"; linux,phandle = <0x178>; phandle = <0x178>; }; bt { compatible = "allwinner,sunxi-bt"; clocks = <0x1b>; bt_power; bt_io_regulator; bt_rst_n = <0x53 0x6 0x13 0x1 0xffffffff 0xffffffff 0x0>; status = "okay"; linux,phandle = <0x179>; phandle = <0x179>; }; btlpm { compatible = "allwinner,sunxi-btlpm"; uart_index = <0x1>; bt_wake = <0x53 0x6 0x11 0x1 0xffffffff 0xffffffff 0x1>; bt_hostwake = <0x53 0x6 0x10 0x6 0xffffffff 0xffffffff 0x0>; status = "okay"; linux,phandle = <0x17a>; phandle = <0x17a>; }; addr_mgt { compatible = "allwinner,sunxi-addr_mgt"; type_addr_wifi = <0x0>; type_addr_bt = <0x0>; type_addr_eth = <0x0>; status = "okay"; linux,phandle = <0x17b>; phandle = <0x17b>; }; sprd-marlin3 { compatible = "sprd,marlin3"; reset-gpios = <0x53 0x6 0x13 0x1 0xffffffff 0xffffffff 0x0>; enable-gpios = <0x53 0x6 0x12 0x1 0xffffffff 0xffffffff 0x0>; m2-to-ap-irq-gpios = <0x53 0x6 0x10 0x6 0xffffffff 0xffffffff 0x0>; sdhci-name = <0xd4>; sprd,btwf-file-name = "/vendor/etc/firmware/wcnmodem.bin"; sprd,gnss-file-name = "/vendor/etc/firmware/gnssmodem.bin"; adma-tx; adma-rx; data-irq; linux,phandle = <0x17c>; phandle = <0x17c>; }; gpio_para { device_type = "gpio_para"; status = "okay"; compatible = "allwinner,sunxi-init-gpio"; gpio_num = <0x2>; gpio_pin_1 = <0x53 0x7 0x6 0x1 0xffffffff 0xffffffff 0x1>; gpio_pin_2 = <0x53 0x7 0x7 0x1 0xffffffff 0xffffffff 0x0>; normal_led = "gpio_pin_1"; standby_led = "gpio_pin_2"; easy_light_used = <0x1>; normal_led_light = <0x1>; standby_led_light = <0x1>; }; product { device_type = "product"; version = "100"; machine = "evb"; }; platform { device_type = "platform"; eraseflag = <0x1>; debug_mode = <0x3>; }; target { device_type = "target"; boot_clock = <0x3f0>; storage_type = <0xffffffff>; advert_enable = <0x0>; burn_key = <0x1>; dragonboard_test = <0x0>; auto_fel = <0x1>; }; power_sply { device_type = "power_sply"; dcdc2_vol = <0xf4628>; aldo1_vol = <0xf4948>; dldo1_vol = <0xf4f24>; }; axp1530_power_sply { device_type = "axp1530_power_sply"; dcdc2_vol = <0xf4628>; aldo1_vol = <0xf4948>; dldo1_vol = <0xf4f24>; }; axp806_power_sply { device_type = "axp806_power_sply"; dcdce_vol = <0xf4f24>; aldo1_vol = <0xf4f24>; bldo1_vol = <0xf4948>; }; card_boot { device_type = "card_boot"; logical_start = <0xa000>; sprite_gpio0 = <0x53 0x7 0x6 0x1 0xffffffff 0xffffffff 0x1>; }; boot_init_gpio { device_type = "boot_init_gpio"; status = "okay"; gpio0 = <0x53 0x7 0x6 0x1 0xffffffff 0xffffffff 0x1>; gpio1 = <0x53 0x7 0x7 0x1 0xffffffff 0xffffffff 0x0>; }; ir_boot_recovery { device_type = "ir_boot_recovery"; status = "okay"; ir_work_mode = <0x2>; ir_press_times = <0x1>; ir_detect_time = <0x7d0>; ir_key_no_duplicate = <0x0>; ir_recovery_key_code0 = <0x45>; ir_addr_code0 = <0x4040>; ir_recovery_key_code1 = <0x49>; ir_addr_code1 = <0x7f80>; }; key_boot_recovery { device_type = "key_boot_recovery"; recovery_key_used = <0x1>; press_mode_enable = <0x0>; key_work_mode = <0x2>; short_press_mode = <0x0>; long_press_mode = <0x1>; key_press_time = <0x7d0>; recovery_key = <0x53 0x7 0x9 0x0 0xffffffff 0xffffffff 0xffffffff>; }; pm_para { device_type = "pm_para"; standby_mode = <0x1>; }; card0_boot_para { device_type = "card0_boot_para"; card_ctrl = <0x0>; card_high_speed = <0x1>; card_line = <0x4>; pinctrl-0 = <0x184>; }; card2_boot_para { device_type = "card2_boot_para"; card_ctrl = <0x2>; card_high_speed = <0x1>; card_line = <0x8>; pinctrl-0 = <0x185 0x186>; sdc_ex_dly_used = <0x2>; sdc_io_1v8 = <0x1>; sdc_tm4_win_th = <0xa>; }; gpio_bias { device_type = "gpio_bias"; pc_bias = <0x708>; }; twi_para { device_type = "twi_para"; twi_port = <0x0>; pinctrl-0 = <0x187>; }; uart_para { device_type = "uart_para"; uart_debug_port = <0x0>; pinctrl-0 = <0x188>; }; jtag_para { device_type = "jtag_para"; jtag_enable = <0x1>; pinctrl-0 = <0x189>; }; clock { device_type = "clock"; pll4 = <0x12c>; pll6 = <0x258>; pll8 = <0x168>; pll9 = <0x129>; pll10 = <0x108>; }; dram_select_para { device_type = "dram_select_para"; select_mode = <0x0>; select_gpio0 = <0x53 0x8 0xe 0x0 0x1 0xffffffff 0xffffffff>; select_gpio1 = <0x53 0x8 0xf 0x0 0x1 0xffffffff 0xffffffff>; select_gpio2 = <0x53 0x8 0x10 0x0 0x1 0xffffffff 0xffffffff>; select_gpio3; }; dram_para1 { device_type = "dram_para1"; dram_clk = <0x258>; dram_type = <0x3>; dram_dx_odt = <0x3030303>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0x1c12>; dram_odt_en = <0x1>; dram_para1 = <0x30fb>; dram_para2 = <0x0>; dram_mr0 = <0x840>; dram_mr1 = <0x4>; dram_mr2 = <0x8>; dram_mr3 = <0x0>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; dram_tpr0 = <0xc0000a05>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr6 = <0x33808080>; dram_tpr10 = <0x2f0006>; dram_tpr11 = <0xddddcccc>; dram_tpr12 = <0xeddc7564>; dram_tpr13 = <0x40>; }; dram_para2 { device_type = "dram_para2"; dram_clk = <0x258>; dram_type = <0x3>; dram_dx_odt = <0x3030303>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0x1c12>; dram_odt_en = <0x1>; dram_para1 = <0x30fb>; dram_para2 = <0x0>; dram_mr0 = <0x840>; dram_mr1 = <0x4>; dram_mr2 = <0x8>; dram_mr3 = <0x0>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; dram_tpr0 = <0xc0000a05>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr6 = <0x33808080>; dram_tpr10 = <0x2f0006>; dram_tpr11 = <0xddddcccc>; dram_tpr12 = <0xeddc7564>; dram_tpr13 = <0x40>; }; dram_para3 { device_type = "dram_para3"; dram_clk = <0x258>; dram_type = <0x3>; dram_dx_odt = <0x3030303>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0x1c12>; dram_odt_en = <0x1>; dram_para1 = <0x30fb>; dram_para2 = <0x0>; dram_mr0 = <0x840>; dram_mr1 = <0x4>; dram_mr2 = <0x8>; dram_mr3 = <0x0>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; dram_tpr0 = <0xc0000a05>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr6 = <0x33808080>; dram_tpr10 = <0x2f0006>; dram_tpr11 = <0xddddcccc>; dram_tpr12 = <0xeddc7564>; dram_tpr13 = <0x40>; }; dram_para4 { device_type = "dram_para4"; dram_clk = <0x258>; dram_type = <0x3>; dram_dx_odt = <0x3030303>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0x1c12>; dram_odt_en = <0x1>; dram_para1 = <0x30fb>; dram_para2 = <0x0>; dram_mr0 = <0x840>; dram_mr1 = <0x4>; dram_mr2 = <0x8>; dram_mr3 = <0x0>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; dram_tpr0 = <0xc0000a05>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr6 = <0x33808080>; dram_tpr10 = <0x2f0006>; dram_tpr11 = <0xddddcccc>; dram_tpr12 = <0xeddc7564>; dram_tpr13 = <0x40>; }; dram_para5 { device_type = "dram_para5"; dram_clk = <0x258>; dram_type = <0x3>; dram_dx_odt = <0x3030303>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0x1c12>; dram_odt_en = <0x1>; dram_para1 = <0x30fb>; dram_para2 = <0x0>; dram_mr0 = <0x840>; dram_mr1 = <0x4>; dram_mr2 = <0x8>; dram_mr3 = <0x0>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; dram_tpr0 = <0xc0000a05>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr6 = <0x33808080>; dram_tpr10 = <0x2f0006>; dram_tpr11 = <0xddddcccc>; dram_tpr12 = <0xeddc7564>; dram_tpr13 = <0x40>; }; dram_para6 { device_type = "dram_para6"; dram_clk = <0x258>; dram_type = <0x3>; dram_dx_odt = <0x3030303>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0x1c12>; dram_odt_en = <0x1>; dram_para1 = <0x30fb>; dram_para2 = <0x0>; dram_mr0 = <0x840>; dram_mr1 = <0x4>; dram_mr2 = <0x8>; dram_mr3 = <0x0>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; dram_tpr0 = <0xc0000a05>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr6 = <0x33808080>; dram_tpr10 = <0x2f0006>; dram_tpr11 = <0xddddcccc>; dram_tpr12 = <0xeddc7564>; dram_tpr13 = <0x40>; }; dram_para7 { device_type = "dram_para7"; dram_clk = <0x258>; dram_type = <0x3>; dram_dx_odt = <0x3030303>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0x1f12>; dram_odt_en = <0x1>; dram_para1 = <0x30fb>; dram_para2 = <0x0>; dram_mr0 = <0x840>; dram_mr1 = <0x4>; dram_mr2 = <0x8>; dram_mr3 = <0x0>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; dram_tpr0 = <0xc0001002>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr6 = <0x33808080>; dram_tpr10 = <0x2f1107>; dram_tpr11 = <0xddddcccc>; dram_tpr12 = <0xeddc7665>; dram_tpr13 = <0x40>; }; secure { device_type = "secure"; dram_region_mbytes = <0x50>; drm_region_mbytes = <0x0>; drm_region_start_mbytes = <0x0>; }; }; aliases { serial0 = "/soc@03000000/uart@05000000", "/soc@03000000/uart@05000000"; serial1 = "/soc@03000000/uart@05000400", "/soc@03000000/uart@05000400"; serial2 = "/soc@03000000/uart@05000800", "/soc@03000000/uart@05000800"; serial3 = "/soc@03000000/uart@05000c00", "/soc@03000000/uart@05000c00"; serial4 = "/soc@03000000/uart@05001000", "/soc@03000000/uart@05001000"; serial5 = "/soc@03000000/uart@05001400", "/soc@03000000/uart@05001400"; twi0 = "/soc@03000000/twi@0x05002000", "/soc@03000000/twi@0x05002000"; twi1 = "/soc@03000000/twi@0x05002400", "/soc@03000000/twi@0x05002400"; twi2 = "/soc@03000000/twi@0x05002800", "/soc@03000000/twi@0x05002800"; twi3 = "/soc@03000000/twi@0x05002c00", "/soc@03000000/twi@0x05002c00"; twi4 = "/soc@03000000/twi@0x05003000", "/soc@03000000/twi@0x05003000"; twi5 = "/soc@03000000/twi@0x07081400", "/soc@03000000/twi@0x07081400"; spi0 = "/soc@03000000/spi@05010000", "/soc@03000000/spi@05010000"; spi1 = "/soc@03000000/spi@05011000", "/soc@03000000/spi@05011000"; ir0 = "/soc@03000000/s_cir@07040000", "/soc@03000000/s_cir@07040000"; pcie = "/soc@03000000/pcie@0x05400000", "/soc@03000000/pcie@0x05400000"; scr0 = "/soc@03000000/smartcard@0x05005000", "/soc@03000000/smartcard@0x05005000"; gmac0 = "/soc@03000000/eth@05020000", "/soc@03000000/eth@05020000"; gmac1 = "/soc@03000000/eth@05030000", "/soc@03000000/eth@05030000"; global_timer0 = "/soc@03000000/timer@03009000", "/soc@03000000/timer@03009000"; mmc0 = "/soc@03000000/sdmmc@04020000", "/soc@03000000/sdmmc@04020000"; mmc2 = "/soc@03000000/sdmmc@04022000", "/soc@03000000/sdmmc@04022000"; nand0 = "/soc@03000000/nand0@04011000", "/soc@03000000/nand0@04011000"; disp = "/soc@03000000/disp@01000000", "/soc@03000000/disp@01000000"; lcd0 = "/soc@03000000/lcd0@01c0c000", "/soc@03000000/lcd0@01c0c000"; lcd1 = "/soc@03000000/lcd1@01c0c001", "/soc@03000000/lcd1@01c0c001"; hdmi = "/soc@03000000/hdmi@06000000", "/soc@03000000/hdmi@06000000"; pwm = "/soc@03000000/pwm@0300a000", "/soc@03000000/pwm@0300a000"; tv0 = "/soc@03000000/tv0@01c94000", "/soc@03000000/tv0@01c94000"; ac200 = "/soc@03000000/ac200", "/soc@03000000/ac200"; boot_disp = "/soc@03000000/boot_disp", "/soc@03000000/boot_disp"; pmu0 = "/soc@03000000/twi@0x07081400/pmu", "/soc@03000000/twi@0x07081400/pmu"; standby_param = "/soc@03000000/twi@0x07081400/pmu/standby_param", "/soc@03000000/twi@0x07081400/pmu/standby_param"; linux,phandle = <0x17d>; phandle = <0x17d>; }; chosen { bootargs = "earlyprintk=sunxi-uart,0x05000000 loglevel=8 initcall_debug=1 console=ttyS0 init=/init"; linux,initrd-start = <0x0 0x0>; linux,initrd-end = <0x0 0x0>; }; firmware { android { compatible = "android,firmware"; boot_devices = "soc/sdc0,soc/sdc2,soc"; vbmeta { compatible = "android,vbmeta"; parts = "vbmeta,vbmeta_system,vbmeta_vendor,boot,super,recovery"; }; }; optee { compatible = "linaro,optee-tz"; method = "smc"; }; }; cpus { #address-cells = <0x2>; #size-cells = <0x0>; cpu@0 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x0>; enable-method = "psci"; clocks = <0xd5>; operating-points-v2 = <0xd6>; cpu-idle-states = <0xd7>; dynamic-power-coefficient = <0x64>; #cooling-cells = <0x2>; cpu-supply = <0xd8>; linux,phandle = <0xc8>; phandle = <0xc8>; }; cpu@1 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x1>; enable-method = "psci"; clocks = <0xd5>; operating-points-v2 = <0xd6>; cpu-idle-states = <0xd7>; #cooling-cells = <0x2>; }; cpu@2 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x2>; enable-method = "psci"; clocks = <0xd5>; operating-points-v2 = <0xd6>; cpu-idle-states = <0xd7>; #cooling-cells = <0x2>; }; cpu@3 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x3>; enable-method = "psci"; clocks = <0xd5>; operating-points-v2 = <0xd6>; cpu-idle-states = <0xd7>; #cooling-cells = <0x2>; }; idle-states { entry-method = "arm,psci"; cpu-sleep-0 { compatible = "arm,idle-state"; arm,psci-suspend-param = <0x10000>; entry-latency-us = <0x2e>; exit-latency-us = <0x3b>; min-residency-us = <0xdf2>; local-timer-stop; linux,phandle = <0xd7>; phandle = <0xd7>; }; }; }; opp_l_table { compatible = "allwinner,sun50i-operating-points"; nvmem-cells = <0xd9>; nvmem-cell-names = "speed"; opp-shared; linux,phandle = <0xd6>; phandle = <0xd6>; opp@480000000-0 { opp-hz = <0x0 0x1c9c3800>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x33>; }; opp@480000000-1 { opp-hz = <0x0 0x1c9c3800>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0xc>; }; opp@600000000-0 { opp-hz = <0x0 0x23c34600>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x23>; }; opp@600000000-1 { opp-hz = <0x0 0x23c34600>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0xc>; }; opp@720000000 { opp-hz = <0x0 0x2aea5400>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x30>; }; opp@792000000-0 { opp-hz = <0x0 0x2f34f600>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x3>; }; opp@792000000-1 { opp-hz = <0x0 0x2f34f600>; opp-microvolt = <0xe57e0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0xc>; }; opp@936000000 { opp-hz = <0x0 0x37ca3a00>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x30>; }; opp@1008000000-0 { opp-hz = <0x0 0x3c14dc00>; opp-microvolt = <0xe09c0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x1>; }; opp@1008000000-1 { opp-hz = <0x0 0x3c14dc00>; opp-microvolt = <0xdbba0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x2>; }; opp@1008000000-2 { opp-hz = <0x0 0x3c14dc00>; opp-microvolt = <0xf9060>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0xc>; }; opp@1008000000-3 { opp-hz = <0x0 0x3c14dc00>; opp-microvolt = <0xe7ef0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x30>; }; opp@1104000000 { opp-hz = <0x0 0x41cdb400>; opp-microvolt = <0xf4240>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x30>; }; opp@1200000000-0 { opp-hz = <0x0 0x47868c00>; opp-microvolt = <0xef420>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x1>; }; opp@1200000000-1 { opp-hz = <0x0 0x47868c00>; opp-microvolt = <0xea600>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x2>; }; opp@1200000000-2 { opp-hz = <0x0 0x47868c00>; opp-microvolt = <0x10c8e0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0xc>; }; opp@1200000000-3 { opp-hz = <0x0 0x47868c00>; opp-microvolt = <0x100590>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x30>; }; opp@1296000000-0 { opp-hz = <0x0 0x4d3f6400>; opp-microvolt = <0x10c8e0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x2>; }; opp@1296000000-1 { opp-hz = <0x0 0x4d3f6400>; opp-microvolt = <0x111700>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x8>; }; opp@1320000000 { opp-hz = <0x0 0x4ead9a00>; opp-microvolt = <0x10c8e0>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x30>; }; opp@1344000000 { opp-hz = <0x0 0x501bd000>; opp-microvolt = <0x111700>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x4>; }; opp@1416000000-0 { opp-hz = <0x0 0x54667200>; opp-microvolt = <0x118c30>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x10>; }; opp@1416000000-1 { opp-hz = <0x0 0x54667200>; opp-microvolt = <0x11b340>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x20>; }; opp@1416000000 { opp-hz = <0x0 0x54667200>; opp-microvolt = <0x118c30>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x10>; }; opp@1512000000 { opp-hz = <0x0 0x5a1f4a00>; opp-microvolt = <0x111700>; clock-latency-ns = <0x3b9b0>; opp-supported-hw = <0x1>; }; opp@480000000-ab { opp-hz = <0x0 0x1c9c3800>; opp-microvolt-a1 = <0xdbba0>; opp-microvolt-b1 = <0xdbba0>; opp-microvolt-b0 = <0xdbba0>; opp-microvolt-c0 = <0xdbba0>; opp-microvolt-c1 = <0xdbba0>; opp-microvolt-c2 = <0xdbba0>; clock-latency-ns = <0x3b9b0>; }; opp@600000000-ab { opp-hz = <0x0 0x23c34600>; opp-microvolt-b0 = <0xdbba0>; opp-microvolt-c0 = <0xdbba0>; opp-microvolt-c2 = <0xdbba0>; clock-latency-ns = <0x3b9b0>; }; opp@720000000-ab { opp-hz = <0x0 0x2aea5400>; opp-microvolt-a1 = <0xdbba0>; opp-microvolt-b1 = <0xdbba0>; opp-microvolt-c1 = <0xe7ef0>; clock-latency-ns = <0x3b9b0>; }; opp@792000000-ab { opp-hz = <0x0 0x2f34f600>; opp-microvolt-b0 = <0xdbba0>; opp-microvolt-c0 = <0xe57e0>; opp-microvolt-c2 = <0xe57e0>; clock-latency-ns = <0x3b9b0>; }; opp@936000000-ab { opp-hz = <0x0 0x37ca3a00>; opp-microvolt-c1 = <0xe7ef0>; clock-latency-ns = <0x3b9b0>; }; opp@1008000000-ab { opp-hz = <0x0 0x3c14dc00>; opp-microvolt-b0 = <0xe09c0>; opp-microvolt-c0 = <0xf9060>; opp-microvolt-c1 = <0xf4240>; opp-microvolt-c2 = <0xf9060>; clock-latency-ns = <0x3b9b0>; }; opp@1032000000-ab { opp-hz = <0x0 0x3d831200>; opp-microvolt-a1 = <0xdbba0>; opp-microvolt-b1 = <0xdbba0>; clock-latency-ns = <0x3b9b0>; }; opp@1104000000-ab { opp-hz = <0x0 0x41cdb400>; opp-microvolt-a1 = <0xe7ef0>; opp-microvolt-b1 = <0xe7ef0>; opp-microvolt-c1 = <0x100590>; clock-latency-ns = <0x3b9b0>; }; opp@1200000000-ab { opp-hz = <0x0 0x47868c00>; opp-microvolt-a1 = <0xf4240>; opp-microvolt-b1 = <0xf4240>; opp-microvolt-b0 = <0xef420>; opp-microvolt-c0 = <0x10c8e0>; opp-microvolt-c1 = <0x10c8e0>; opp-microvolt-c2 = <0x10c8e0>; clock-latency-ns = <0x3b9b0>; }; opp@1296000000-ab { opp-hz = <0x0 0x4d3f6400>; opp-microvolt-a1 = <0x100590>; opp-microvolt-b1 = <0x100590>; clock-latency-ns = <0x3b9b0>; }; opp@1320000000-ab { opp-hz = <0x0 0x4ead9a00>; opp-microvolt-c1 = <0x11b340>; clock-latency-ns = <0x3b9b0>; }; opp@1344000000-ab { opp-hz = <0x0 0x501bd000>; opp-microvolt-c0 = <0x111700>; opp-microvolt-c2 = <0x111700>; clock-latency-ns = <0x3b9b0>; }; opp@1416000000-ab { opp-hz = <0x0 0x54667200>; opp-microvolt-a1 = <0x10c8e0>; opp-microvolt-b1 = <0x10c8e0>; clock-latency-ns = <0x3b9b0>; }; opp@1512000000-ab { opp-hz = <0x0 0x5a1f4a00>; opp-microvolt-a1 = <0x11b340>; opp-microvolt-b1 = <0x11b340>; opp-microvolt-b0 = <0x111700>; clock-latency-ns = <0x3b9b0>; }; }; psci { compatible = "arm,psci-1.0"; method = "smc"; }; n_brom { compatible = "allwinner,n-brom"; reg = <0x0 0x0 0x0 0xa000>; }; s_brom { compatible = "allwinner,s-brom"; reg = <0x0 0x0 0x0 0x10000>; }; sram_ctrl { device_type = "sram_ctrl"; compatible = "allwinner,sram_ctrl"; reg = <0x0 0x3000000 0x0 0x100>; }; sram_a1 { compatible = "allwinner,sram_a1"; reg = <0x0 0x20000 0x0 0x8000>; }; sram_a2 { compatible = "allwinner,sram_a2"; reg = <0x0 0x100000 0x0 0x14000>; }; prcm { compatible = "allwinner,prcm"; reg = <0x0 0x1f01400 0x0 0x400>; }; s_cpuscfg { compatible = "allwinner,s_cpuscfg"; reg = <0x0 0x1f01c00 0x0 0x400>; }; ion { compatible = "allwinner,sunxi-ion"; heap_sys_user@0 { compatible = "allwinner,sys_user"; heap-name = "sys_user"; heap-id = <0x0>; heap-base = <0x0>; heap-size = <0x0>; heap-type = "ion_system"; }; heap_cma@0 { compatible = "allwinner,cma"; heap-name = "cma"; heap-id = <0x4>; heap-base = <0x0>; heap-size = <0x0>; heap-type = "ion_cma"; }; heap_secure@0 { compatible = "allwinner,secure"; heap-name = "secure"; heap-id = <0x6>; heap-base = <0x0>; heap-size = <0x0>; heap-type = "ion_secure"; }; }; dram { compatible = "allwinner,dram"; clocks = <0xda>; clock-names = "pll_ddr"; dram_clk = <0x2d0>; dram_type = <0x7>; dram_zq = <0x3f3fdd>; dram_odt_en = <0x9988eeee>; dram_para1 = <0x30fa>; dram_para2 = <0x1000>; dram_mr0 = <0x0>; dram_mr1 = <0xc3>; dram_mr2 = <0x6>; dram_mr3 = <0x1>; dram_tpr0 = <0x0>; dram_tpr1 = <0x0>; dram_tpr2 = <0x0>; dram_tpr3 = <0x0>; dram_tpr4 = <0x0>; dram_tpr5 = <0x0>; dram_tpr6 = <0x2fb08080>; dram_tpr7 = <0x0>; dram_tpr8 = <0x0>; dram_tpr9 = <0x0>; dram_tpr10 = <0x402f4469>; dram_tpr11 = <0xe0f0d0d>; dram_tpr12 = <0x11131213>; dram_tpr13 = <0x60>; linux,phandle = <0x17e>; phandle = <0x17e>; device_type = "dram"; dram_dx_odt = <0x6060606>; dram_dx_dri = <0xd0d0d0d>; dram_ca_dri = <0x1919>; dram_mr4 = <0x0>; dram_mr5 = <0x0>; dram_mr6 = <0x0>; dram_mr11 = <0x0>; dram_mr12 = <0x0>; dram_mr13 = <0x0>; dram_mr14 = <0x0>; dram_mr16 = <0x0>; dram_mr17 = <0x0>; dram_mr22 = <0x0>; }; memory@40000000 { device_type = "memory"; reg = <0x0 0x40000000 0x0 0x20000000>; }; interrupt-controller@03020000 { compatible = "arm,cortex-a15-gic", "arm,cortex-a9-gic"; #interrupt-cells = <0x3>; #address-cells = <0x0>; device_type = "gic"; interrupt-controller; reg = <0x0 0x3021000 0x0 0x1000 0x0 0x3022000 0x0 0x2000 0x0 0x3024000 0x0 0x2000 0x0 0x3026000 0x0 0x2000>; interrupts = <0x1 0x9 0xf04>; interrupt-parent = <0x85>; linux,phandle = <0x85>; phandle = <0x85>; }; interrupt-controller@0 { compatible = "allwinner,sunxi-wakeupgen"; interrupt-controller; #interrupt-cells = <0x3>; interrupt-parent = <0x85>; linux,phandle = <0x1>; phandle = <0x1>; }; intc-nmi@07010320 { compatible = "allwinner,sun8i-nmi"; interrupt-parent = <0x85>; #interrupt-cells = <0x2>; #address-cells = <0x0>; interrupt-controller; reg = <0x0 0x7010320 0x0 0xc>; pad-control-v1 = <0x7000208>; interrupts = <0x0 0x67 0x4>; linux,phandle = <0x17f>; phandle = <0x17f>; }; sunxi-sid@03006000 { compatible = "allwinner,sunxi-sid"; device_type = "sid"; reg = <0x0 0x3006000 0x0 0x1000>; linux,phandle = <0x180>; phandle = <0x180>; }; sunxi-sid-ng@03006000 { compatible = "allwinner,sun50iw9p1-sid"; reg = <0x0 0x3006000 0x0 0x1000>; #address-cells = <0x1>; #size-cells = <0x1>; linux,phandle = <0xc5>; phandle = <0xc5>; speed@00 { reg = <0x0 0x2>; linux,phandle = <0xd9>; phandle = <0xd9>; }; calib@14 { reg = <0x14 0x8>; linux,phandle = <0xc4>; phandle = <0xc4>; }; }; sunxi-chipid@03006200 { compatible = "allwinner,sunxi-chipid"; device_type = "chipid"; reg = <0x0 0x3006200 0x0 0x200>; linux,phandle = <0x181>; phandle = <0x181>; }; timer_arch { compatible = "arm,armv8-timer"; interrupts = <0x1 0xd 0xf08 0x1 0xe 0xf08 0x1 0xb 0xf08 0x1 0xa 0xf08>; clock-frequency = <0x16e3600>; interrupt-parent = <0x85>; arm,no-tick-in-suspend; }; pmu { compatible = "arm,armv8-pmuv3"; interrupts = <0x0 0x8c 0x4 0x0 0x8d 0x4 0x0 0x8e 0x4 0x0 0x8f 0x4>; }; dramfreq { compatible = "allwinner,sunxi-dramfreq"; reg = <0x0 0x4002000 0x0 0x1000 0x0 0x4003000 0x0 0x3000 0x0 0x3001000 0x0 0x1000>; interrupts = <0x0 0x21 0x4>; clocks = <0xda>; status = "okay"; }; uboot { linux,phandle = <0x182>; phandle = <0x182>; }; iommu@030f0000 { compatible = "allwinner,sunxi-iommu"; reg = <0x0 0x30f0000 0x0 0x1000>; interrupts = <0x0 0x3d 0x4>; interrupt-names = "iommu-irq"; clocks = <0xdb>; clock-names = "iommu"; #iommu-cells = <0x2>; status = "okay"; linux,phandle = <0x28>; phandle = <0x28>; }; gpu@0x01800000 { device_type = "gpu"; compatible = "arm,mali-midgard"; reg = <0x0 0x1800000 0x0 0x10000>; interrupts = <0x0 0x5f 0x4 0x0 0x60 0x4 0x0 0x61 0x4>; interrupt-names = "JOB", "MMU", "GPU"; clocks = <0xdc 0xdd 0xde>; clock-names = "clk_parent", "clk_mali", "clk_bak"; #cooling-cells = <0x2>; gpu_idle = <0x1>; dvfs_status = <0x0>; operating-points = <0x927c0 0xe7ef0 0x8ca00 0xe7ef0 0x83d60 0xe7ef0 0x7b0c0 0xe7ef0>; linux,phandle = <0xc9>; phandle = <0xc9>; ipa_dvfs { compatible = "arm,mali-simple-power-model"; static-coefficient = <0x4268>; dynamic-coefficient = <0x2ee>; ts = <0x3e2da 0x2568 0xffffff98 0x4>; thermal-zone = "gpu_thermal_zone"; ss-coefficient = <0x24>; ff-coefficient = <0x123>; linux,phandle = <0x183>; phandle = <0x183>; }; }; box_start_os0 { compatible = "allwinner,box_start_os"; start_type = <0x1>; irkey_used = <0x0>; pmukey_used = <0x0>; pmukey_num = <0x0>; led_power = <0x0>; led_state = <0x0>; pinctrl-0 = <0xdf>; pinctrl-1 = <0xe0>; }; __symbols__ { clk_losc = "/clocks/losc"; clk_iosc = "/clocks/iosc"; clk_hosc = "/clocks/hosc"; clk_osc48m = "/clocks/osc48m"; clk_hoscdiv32k = "/clocks/hoscdiv32k"; clk_pll_periph0div25m = "/clocks/pll_periph0div25m"; clk_pll_cpu = "/clocks/pll_cpu"; clk_pll_ddr0 = "/clocks/pll_ddr0"; clk_pll_ddr1 = "/clocks/pll_ddr1"; clk_pll_periph0 = "/clocks/pll_periph0"; clk_pll_periph1 = "/clocks/pll_periph1"; clk_pll_gpu = "/clocks/pll_gpu"; clk_pll_video0x4 = "/clocks/pll_video0x4"; clk_pll_video1 = "/clocks/pll_video1"; clk_pll_video2 = "/clocks/pll_video2"; clk_pll_ve = "/clocks/pll_ve"; clk_pll_de = "/clocks/pll_de"; clk_pll_csi = "/clocks/pll_csi"; clk_pll_audiox4 = "/clocks/pll_audiox4"; clk_pll_periph0x2 = "/clocks/pll_periph0x2"; clk_pll_periph0x4 = "/clocks/pll_periph0x4"; clk_periph32k = "/clocks/periph32k"; clk_pll_periph1x2 = "/clocks/pll_periph1x2"; clk_pll_audio = "/clocks/pll_audio"; clk_pll_audiox2 = "/clocks/pll_audiox2"; clk_pll_video0 = "/clocks/pll_video0"; clk_pll_video1x4 = "/clocks/pll_video1x4"; clk_pll_video2x4 = "/clocks/pll_video2x4"; clk_hoscd2 = "/clocks/hoscd2"; clk_osc48md4 = "/clocks/osc48md4"; clk_pll_periph0d6 = "/clocks/pll_periph0d6"; clk_cpu = "/clocks/cpu"; clk_axi = "/clocks/axi"; clk_cpuapb = "/clocks/cpuapb"; clk_psi = "/clocks/psi"; clk_ahb1 = "/clocks/ahb1"; clk_ahb2 = "/clocks/ahb2"; clk_ahb3 = "/clocks/ahb3"; clk_apb1 = "/clocks/apb1"; clk_apb2 = "/clocks/apb2"; clk_mbus = "/clocks/mbus"; clk_de = "/clocks/de"; clk_g2d = "/clocks/g2d"; clk_di = "/clocks/di"; clk_gpu0 = "/clocks/gpu0"; clk_gpu1 = "/clocks/gpu1"; clk_ce = "/clocks/ce"; clk_ve = "/clocks/ve"; clk_dma = "/clocks/dma"; clk_msgbox = "/clocks/msgbox"; clk_hwspinlock_rst = "/clocks/hwspinlock_rst"; clk_hwspinlock_bus = "/clocks/hwspinlock_bus"; clk_hstimer = "/clocks/hstimer"; clk_avs = "/clocks/avs"; clk_dbgsys = "/clocks/dbgsys"; clk_pwm = "/clocks/pwm"; clk_iommu = "/clocks/iommu"; clk_sdram = "/clocks/sdram"; clk_nand0 = "/clocks/nand0"; clk_nand1 = "/clocks/nand1"; clk_sdmmc0_mod = "/clocks/sdmmc0_mod"; clk_sdmmc0_bus = "/clocks/sdmmc0_bus"; clk_sdmmc0_rst = "/clocks/sdmmc0_rst"; clk_sdmmc1_mod = "/clocks/sdmmc1_mod"; clk_sdmmc1_bus = "/clocks/sdmmc1_bus"; clk_sdmmc1_rst = "/clocks/sdmmc1_rst"; clk_sdmmc2_mod = "/clocks/sdmmc2_mod"; clk_sdmmc2_bus = "/clocks/sdmmc2_bus"; clk_sdmmc2_rst = "/clocks/sdmmc2_rst"; clk_uart0 = "/clocks/uart0"; clk_uart1 = "/clocks/uart1"; clk_uart2 = "/clocks/uart2"; clk_uart3 = "/clocks/uart3"; clk_uart4 = "/clocks/uart4"; clk_uart5 = "/clocks/uart5"; clk_twi0 = "/clocks/twi0"; clk_twi1 = "/clocks/twi1"; clk_twi2 = "/clocks/twi2"; clk_twi3 = "/clocks/twi3"; clk_twi4 = "/clocks/twi4"; clk_scr0 = "/clocks/scr0"; clk_spi0 = "/clocks/spi0"; clk_spi1 = "/clocks/spi1"; clk_ephy_25m = "/clocks/ephy_25m"; clk_gmac0 = "/clocks/gmac0"; clk_gmac1 = "/clocks/gmac1"; clk_gpadc = "/clocks/gpadc"; clk_ts = "/clocks/ts"; clk_ths = "/clocks/ths"; clk_spdif = "/clocks/spdif"; clk_dmic = "/clocks/dmic"; clk_codec_1x = "/clocks/codec_1x"; clk_codec_4x = "/clocks/codec_4x"; clk_ahub = "/clocks/ahub"; clk_usbphy0 = "/clocks/usbphy0"; clk_usbphy1 = "/clocks/usbphy1"; clk_usbphy2 = "/clocks/usbphy2"; clk_usbphy3 = "/clocks/usbphy3"; clk_usbohci0 = "/clocks/usbohci0"; clk_usbohci0_12m = "/clocks/usbohci0_12m"; clk_usbohci1 = "/clocks/usbohci1"; clk_usbohci1_12m = "/clocks/usbohci1_12m"; clk_usbohci2 = "/clocks/usbohci2"; clk_usbohci2_12m = "/clocks/usbohci2_12m"; clk_usbohci3 = "/clocks/usbohci3"; clk_usbohci3_12m = "/clocks/usbohci3_12m"; clk_usbehci0 = "/clocks/usbehci0"; clk_usbehci1 = "/clocks/usbehci1"; clk_usbehci2 = "/clocks/usbehci2"; clk_usbehci3 = "/clocks/usbehci3"; clk_usb3_0_host = "/clocks/usb3_0_host"; clk_usbotg = "/clocks/usbotg"; clk_lradc = "/clocks/lradc"; clk_hdmi = "/clocks/hdmi"; clk_hdmi_slow = "/clocks/hdmi_slow"; clk_hdmi_cec = "/clocks/hdmi_cec"; clk_display_top = "/clocks/display_top"; clk_tcon_lcd = "/clocks/tcon_lcd"; clk_tcon_lcd1 = "/clocks/tcon_lcd1"; clk_tcon_tv = "/clocks/tcon_tv"; clk_tcon_tv1 = "/clocks/tcon_tv1"; clk_lvds = "/clocks/lvds"; clk_tve = "/clocks/tve"; clk_tve_top = "/clocks/tve_top"; clk_csi_top = "/clocks/csi_top"; clk_csi_master0 = "/clocks/csi_master0"; clk_csi_master1 = "/clocks/csi_master1"; clk_hdmi_hdcp = "/clocks/hdmi_hdcp"; clk_pio = "/clocks/pio"; clk_cpurcir = "/clocks/cpurcir"; clk_hosc32k = "/clocks/hosc32k"; clk_losc_out = "/clocks/losc_out"; clk_cpurcpus_pll = "/clocks/cpurcpus_pll"; clk_cpurcpus = "/clocks/cpurcpus"; clk_cpurahbs = "/clocks/cpurahbs"; clk_cpurapbs1 = "/clocks/cpurapbs1"; clk_cpurapbs2_pll = "/clocks/cpurapbs2_pll"; clk_cpurapbs2 = "/clocks/cpurapbs2"; clk_cpurpio = "/clocks/cpurpio"; clk_dcxo_out = "/clocks/dcxo_out"; clk_stwi = "/clocks/stwi"; soc = "/soc@03000000"; r_pio = "/soc@03000000/pinctrl@07022000"; s_rsb0_pins_a = "/soc@03000000/pinctrl@07022000/s_rsb0@0"; s_twi0_pins_a = "/soc@03000000/pinctrl@07022000/s_twi0@0"; s_twi0_pins_b = "/soc@03000000/pinctrl@07022000/s_twi0@1"; pio = "/soc@03000000/pinctrl@0300b000"; clk_losc_pins_a = "/soc@03000000/pinctrl@0300b000/clk_losc@0"; s_cir0_pins_a = "/soc@03000000/pinctrl@0300b000/s_cir0@0"; vdevice_pins_a = "/soc@03000000/pinctrl@0300b000/vdevice@0"; uart0_pins_a = "/soc@03000000/pinctrl@0300b000/uart0@0"; uart0_pins_b = "/soc@03000000/pinctrl@0300b000/uart0@1"; uart1_pins_a = "/soc@03000000/pinctrl@0300b000/uart1@0"; uart1_pins_b = "/soc@03000000/pinctrl@0300b000/uart1@1"; uart2_pins_a = "/soc@03000000/pinctrl@0300b000/uart2@0"; uart2_pins_b = "/soc@03000000/pinctrl@0300b000/uart2@1"; uart3_pins_a = "/soc@03000000/pinctrl@0300b000/uart3@0"; uart3_pins_b = "/soc@03000000/pinctrl@0300b000/uart3@1"; uart4_pins_a = "/soc@03000000/pinctrl@0300b000/uart4@0"; uart4_pins_b = "/soc@03000000/pinctrl@0300b000/uart4@1"; uart5_pins_a = "/soc@03000000/pinctrl@0300b000/uart5@0"; uart5_pins_b = "/soc@03000000/pinctrl@0300b000/uart5@1"; twi0_pins_a = "/soc@03000000/pinctrl@0300b000/twi0@0"; twi0_pins_b = "/soc@03000000/pinctrl@0300b000/twi0@1"; twi1_pins_a = "/soc@03000000/pinctrl@0300b000/twi1@0"; twi1_pins_b = "/soc@03000000/pinctrl@0300b000/twi1@1"; twi2_pins_a = "/soc@03000000/pinctrl@0300b000/twi2@0"; twi2_pins_b = "/soc@03000000/pinctrl@0300b000/twi2@1"; twi3_pins_a = "/soc@03000000/pinctrl@0300b000/twi3@0"; twi3_pins_b = "/soc@03000000/pinctrl@0300b000/twi3@1"; twi4_pins_a = "/soc@03000000/pinctrl@0300b000/twi4@0"; twi4_pins_b = "/soc@03000000/pinctrl@0300b000/twi4@1"; ts0_pins_a = "/soc@03000000/pinctrl@0300b000/ts0@0"; ts0_pins_b = "/soc@03000000/pinctrl@0300b000/ts0_sleep@0"; spi0_pins_a = "/soc@03000000/pinctrl@0300b000/spi0@0"; spi0_pins_b = "/soc@03000000/pinctrl@0300b000/spi0@1"; spi0_pins_c = "/soc@03000000/pinctrl@0300b000/spi0@2"; spi1_pins_a = "/soc@03000000/pinctrl@0300b000/spi1@0"; spi1_pins_b = "/soc@03000000/pinctrl@0300b000/spi1@1"; spi1_pins_c = "/soc@03000000/pinctrl@0300b000/spi1@2"; sdc0_pins_a = "/soc@03000000/pinctrl@0300b000/sdc0@0"; sdc0_pins_b = "/soc@03000000/pinctrl@0300b000/sdc0@1"; sdc0_pins_c = "/soc@03000000/pinctrl@0300b000/sdc0@2"; sdc1_pins_a = "/soc@03000000/pinctrl@0300b000/sdc1@0"; sdc1_pins_b = "/soc@03000000/pinctrl@0300b000/sdc1@1"; sdc2_pins_a = "/soc@03000000/pinctrl@0300b000/sdc2@0"; sdc2_pins_b = "/soc@03000000/pinctrl@0300b000/sdc2@1"; sdc2_pins_c = "/soc@03000000/pinctrl@0300b000/sdc2@2"; spdif_pins_a = "/soc@03000000/pinctrl@0300b000/spdif@0"; spdif_pins_b = "/soc@03000000/pinctrl@0300b000/spdif_sleep@0"; dmic_pins_a = "/soc@03000000/pinctrl@0300b000/dmic@0"; dmic_pins_b = "/soc@03000000/pinctrl@0300b000/dmic_sleep@0"; ahub_daudio0_pins_a = "/soc@03000000/pinctrl@0300b000/ahub_daudio0@0"; ahub_daudio0_pins_b = "/soc@03000000/pinctrl@0300b000/ahub_daudio0_sleep@0"; ahub_daudio0_pins_c = "/soc@03000000/pinctrl@0300b000/h_ahub_daudio0@0"; ahub_daudio0_pins_d = "/soc@03000000/pinctrl@0300b000/h_ahub_daudio0_sleep@0"; ahub_daudio2_pins_a = "/soc@03000000/pinctrl@0300b000/ahub_daudio2@0"; ahub_daudio2_pins_b = "/soc@03000000/pinctrl@0300b000/ahub_daudio2_sleep@0"; ahub_daudio3_pins_a = "/soc@03000000/pinctrl@0300b000/ahub_daudio3@0"; ahub_daudio3_pins_b = "/soc@03000000/pinctrl@0300b000/ahub_daudio3_sleep@0"; csi1_pins_a = "/soc@03000000/pinctrl@0300b000/csi1@0"; csi1_pins_b = "/soc@03000000/pinctrl@0300b000/csi1@1"; csi_mclk0_pins_a = "/soc@03000000/pinctrl@0300b000/csi_mclk0@0"; csi_mclk0_pins_b = "/soc@03000000/pinctrl@0300b000/csi_mclk0@1"; csi_cci0_pins_a = "/soc@03000000/pinctrl@0300b000/csi_cci0@0"; csi_cci0_pins_b = "/soc@03000000/pinctrl@0300b000/csi_cci0@1"; csi_mclk1_pins_a = "/soc@03000000/pinctrl@0300b000/csi_mclk1@0"; csi_mclk1_pins_b = "/soc@03000000/pinctrl@0300b000/csi_mclk1@1"; csi_cci1_pins_a = "/soc@03000000/pinctrl@0300b000/csi_cci1@0"; csi_cci1_pins_b = "/soc@03000000/pinctrl@0300b000/csi_cci1@1"; scr0_pins_a = "/soc@03000000/pinctrl@0300b000/scr0@0"; scr0_pins_b = "/soc@03000000/pinctrl@0300b000/scr0@1"; scr0_pins_c = "/soc@03000000/pinctrl@0300b000/scr0@2"; scr1_pins_a = "/soc@03000000/pinctrl@0300b000/scr1@0"; scr1_pins_b = "/soc@03000000/pinctrl@0300b000/scr1@1"; scr1_pins_c = "/soc@03000000/pinctrl@0300b000/scr1@2"; nand0_pins_a = "/soc@03000000/pinctrl@0300b000/nand0@0"; nand0_pins_b = "/soc@03000000/pinctrl@0300b000/nand0@1"; nand0_pins_c = "/soc@03000000/pinctrl@0300b000/nand0@2"; ccir_clk_pin_a = "/soc@03000000/pinctrl@0300b000/ac200@2"; ccir_clk_pin_b = "/soc@03000000/pinctrl@0300b000/ac200@3"; gmac_pins_a = "/soc@03000000/pinctrl@0300b000/gmac@0"; gmac_pins_b = "/soc@03000000/pinctrl@0300b000/gmac@1"; gmac1_pins_a = "/soc@03000000/pinctrl@0300b000/gmac1@0"; gmac1_pins_b = "/soc@03000000/pinctrl@0300b000/gmac1@1"; lvds0_pins_a = "/soc@03000000/pinctrl@0300b000/lvds0@0"; lvds0_pins_b = "/soc@03000000/pinctrl@0300b000/lvds0@1"; lvds1_pins_a = "/soc@03000000/pinctrl@0300b000/lvds1@0"; lvds1_pins_b = "/soc@03000000/pinctrl@0300b000/lvds1@1"; lvds2link_pins_a = "/soc@03000000/pinctrl@0300b000/lvds2link@0"; lvds2link_pins_b = "/soc@03000000/pinctrl@0300b000/lvds2link@1"; rgb24_pins_a = "/soc@03000000/pinctrl@0300b000/rgb24@0"; rgb24_pins_b = "/soc@03000000/pinctrl@0300b000/rgb24@1"; pwm5_pin_a = "/soc@03000000/pinctrl@0300b000/pwm5@0"; pwm5_pin_b = "/soc@03000000/pinctrl@0300b000/pwm5@1"; standby_red = "/soc@03000000/pinctrl@0300b000/standby@0"; standby_blue = "/soc@03000000/pinctrl@0300b000/standby@1"; standby_bt = "/soc@03000000/pinctrl@0300b000/standby@2"; dma0 = "/soc@03000000/dma-controller@03002000"; mbus0 = "/soc@03000000/mbus-controller@047fa000"; msgbox = "/soc@03000000/msgbox@03003000"; hwspinlock = "/soc@03000000/hwspinlock@3004000"; s_cir0 = "/soc@03000000/s_cir@07040000"; soc_timer0 = "/soc@03000000/timer@03009000"; rtc = "/soc@03000000/rtc@07000000"; wdt = "/soc@03000000/watchdog@030090a0"; ve = "/soc@03000000/ve@01c0e000"; vp9 = "/soc@03000000/vp9@01c00000"; uart0 = "/soc@03000000/uart@05000000"; uart1 = "/soc@03000000/uart@05000400"; uart2 = "/soc@03000000/uart@05000800"; uart3 = "/soc@03000000/uart@05000c00"; uart4 = "/soc@03000000/uart@05001000"; uart5 = "/soc@03000000/uart@05001400"; twi0 = "/soc@03000000/twi@0x05002000"; twi1 = "/soc@03000000/twi@0x05002400"; twi2 = "/soc@03000000/twi@0x05002800"; twi3 = "/soc@03000000/twi@0x05002c00"; twi4 = "/soc@03000000/twi@0x05003000"; twi5 = "/soc@03000000/twi@0x07081400"; pmu0 = "/soc@03000000/twi@0x07081400/pmu"; standby_param = "/soc@03000000/twi@0x07081400/pmu/standby_param"; reg_dcdc1 = "/soc@03000000/twi@0x07081400/pmu/regulators/dcdc1"; reg_dcdc2 = "/soc@03000000/twi@0x07081400/pmu/regulators/dcdc2"; reg_dcdc3 = "/soc@03000000/twi@0x07081400/pmu/regulators/dcdc3"; reg_aldo1 = "/soc@03000000/twi@0x07081400/pmu/regulators/ldo1"; reg_dldo1 = "/soc@03000000/twi@0x07081400/pmu/regulators/ldo2"; usbc0 = "/soc@03000000/usbc0@0"; udc = "/soc@03000000/udc-controller@0x05100000"; ehci0 = "/soc@03000000/ehci0-controller@0x05101000"; ohci0 = "/soc@03000000/ohci0-controller@0x05101400"; usbc1 = "/soc@03000000/usbc1@0"; ehci1 = "/soc@03000000/ehci1-controller@0x05200000"; ohci1 = "/soc@03000000/ohci1-controller@0x05200400"; usbc2 = "/soc@03000000/usbc2@0"; ehci2 = "/soc@03000000/ehci2-controller@0x05310000"; ohci2 = "/soc@03000000/ohci2-controller@0x05310400"; usbc3 = "/soc@03000000/usbc3@0"; ehci3 = "/soc@03000000/ehci3-controller@0x05311000"; ohci3 = "/soc@03000000/ohci3-controller@0x05311400"; ac200_codec = "/soc@03000000/ac200_codec"; spdif = "/soc@03000000/spdif-controller@0x05093000"; dmic = "/soc@03000000/dmic-controller@0x05095000"; codec = "/soc@03000000/codec@0x05096000"; cpudai = "/soc@03000000/cpudai-controller@0x05096000"; ahub_cpudai0 = "/soc@03000000/cpudai0-controller@0x05097000"; ahub_cpudai1 = "/soc@03000000/cpudai1-controller@0x05097000"; ahub_cpudai2 = "/soc@03000000/cpudai2-controller@0x05097000"; ahub_cpudai3 = "/soc@03000000/cpudai3-controller@0x05097000"; ahub_codec = "/soc@03000000/ahub_codec@0x05097000"; ahub_daudio0 = "/soc@03000000/ahub_daudio0@0x05097000"; ahub_daudio1 = "/soc@03000000/ahub_daudio1@0x05097000"; ahub_daudio2 = "/soc@03000000/ahub_daudio2@0x05097000"; ahub_daudio3 = "/soc@03000000/ahub_daudio3@0x05097000"; snddaudio0 = "/soc@03000000/sound@0"; sndhdmi = "/soc@03000000/sound@1"; snddaudio2 = "/soc@03000000/sound@2"; snddaudio3 = "/soc@03000000/sound@3"; sndspdif = "/soc@03000000/sound@4"; snddmic = "/soc@03000000/sound@5"; sndcodec = "/soc@03000000/sound@6"; sndahub = "/soc@03000000/sound@7"; spi0 = "/soc@03000000/spi@05010000"; spi1 = "/soc@03000000/spi@05011000"; pcie = "/soc@03000000/pcie@0x05400000"; sdc2 = "/soc@03000000/sdmmc@04022000"; sdc0 = "/soc@03000000/sdmmc@04020000"; sdc1 = "/soc@03000000/sdmmc@04021000"; disp = "/soc@03000000/disp@01000000"; tv0 = "/soc@03000000/tv0@01c94000"; lcd0 = "/soc@03000000/lcd0@01c0c000"; lcd1 = "/soc@03000000/lcd1@01c0c001"; boot_disp = "/soc@03000000/boot_disp"; hdmi = "/soc@03000000/hdmi@06000000"; g2d = "/soc@03000000/g2d@01480000"; soc_tr = "/soc@03000000/tr@01000000"; pwm = "/soc@03000000/pwm@0300a000"; pwm0 = "/soc@03000000/pwm0@0300a000"; pwm1 = "/soc@03000000/pwm1@0300a000"; pwm2 = "/soc@03000000/pwm2@0300a000"; pwm3 = "/soc@03000000/pwm3@0300a000"; pwm4 = "/soc@03000000/pwm4@0300a000"; pwm5 = "/soc@03000000/pwm5@0300a000"; ac200 = "/soc@03000000/ac200"; vind0 = "/soc@03000000/vind@0"; csi_cci0 = "/soc@03000000/vind@0/cci@0"; csi_cci1 = "/soc@03000000/vind@0/cci@1"; csi0 = "/soc@03000000/vind@0/csi@0"; csi1 = "/soc@03000000/vind@0/csi@1"; mipi0 = "/soc@03000000/vind@0/mipi@0"; isp0 = "/soc@03000000/vind@0/isp@0"; isp1 = "/soc@03000000/vind@0/isp@1"; scaler0 = "/soc@03000000/vind@0/scaler@0"; scaler1 = "/soc@03000000/vind@0/scaler@1"; scaler2 = "/soc@03000000/vind@0/scaler@2"; scaler3 = "/soc@03000000/vind@0/scaler@3"; scaler4 = "/soc@03000000/vind@0/scaler@4"; scaler5 = "/soc@03000000/vind@0/scaler@5"; actuator0 = "/soc@03000000/vind@0/actuator@0"; flash0 = "/soc@03000000/vind@0/flash@0"; sensor0 = "/soc@03000000/vind@0/sensor@0"; sensor1 = "/soc@03000000/vind@0/sensor@1"; vinc0 = "/soc@03000000/vind@0/vinc@0"; vinc1 = "/soc@03000000/vind@0/vinc@1"; vinc2 = "/soc@03000000/vind@0/vinc@2"; vinc3 = "/soc@03000000/vind@0/vinc@3"; vinc4 = "/soc@03000000/vind@0/vinc@4"; vinc5 = "/soc@03000000/vind@0/vinc@5"; Vdevice = "/soc@03000000/vdevice@0"; emce = "/soc@03000000/emce@01905000"; cryptoengine = "/soc@03000000/ce@1904000"; di = "/soc@03000000/deinterlace@0x01420000"; scr0 = "/soc@03000000/smartcard@0x05005000"; nand0 = "/soc@03000000/nand0@04011000"; ts0 = "/soc@03000000/ts0@05060000"; ths = "/soc@03000000/thermal_sensor"; cpu_trips = "/soc@03000000/thermal-zones/cpu_thermal_zone/trips"; cpu_threshold = "/soc@03000000/thermal-zones/cpu_thermal_zone/trips/trip-point@0"; cpu_target = "/soc@03000000/thermal-zones/cpu_thermal_zone/trips/trip-point@1"; cpu_crit = "/soc@03000000/thermal-zones/cpu_thermal_zone/trips/cpu_crit@0"; gpadc = "/soc@03000000/gpadc"; keyboard0 = "/soc@03000000/keyboard"; gmac0 = "/soc@03000000/eth@05020000"; gmac1 = "/soc@03000000/eth@05030000"; gpio_encrypt = "/soc@03000000/gpio_encrypt"; wlan = "/soc@03000000/wlan"; bt = "/soc@03000000/bt"; btlpm = "/soc@03000000/btlpm"; addr_mgt = "/soc@03000000/addr_mgt"; sprd_marlin3 = "/soc@03000000/sprd-marlin3"; aliases = "/aliases"; cpu0 = "/cpus/cpu@0"; CPU_SLEEP_0 = "/cpus/idle-states/cpu-sleep-0"; cpu_opp_l_table = "/opp_l_table"; dram = "/dram"; gic = "/interrupt-controller@03020000"; wakeupgen = "/interrupt-controller@0"; nmi_intc = "/intc-nmi@07010320"; sid = "/sunxi-sid@03006000"; sunxi_sid = "/sunxi-sid-ng@03006000"; speedbin_efuse = "/sunxi-sid-ng@03006000/speed@00"; ths_calib = "/sunxi-sid-ng@03006000/calib@14"; chipid = "/sunxi-chipid@03006200"; uboot = "/uboot"; mmu_aw = "/iommu@030f0000"; gpu = "/gpu@0x01800000"; ipa_dvfs = "/gpu@0x01800000/ipa_dvfs"; }; };
  24. I want to know that too
  25. @martinayotte Hello. Seems once you was dig into this problem too.
  26. There a more important things to do (first). Like even creating a package for the OPI5 as a quick scan reveals there is none. So currently an option is to compile U-Boot yourself with added Btrfs support. And/or also do that on github and make pull request. Over time, more U-Boot will support Btrfs I guess, so how do you think people should spent their time. I did look into armbian-install but it is not according to my wishes/methods. It should work, but more work for me to revert/change than just use manual rsync and btrfs options as I want it. I have some backup/cloning scripting that fits Opensuse methods, not Debian. Your other option is to simply install/copy manually and maintain an extra boot/1st partition, FAT formatted. Several old installs do it like that and it is anyway you have to deal with for 'normal' UEFI computers. So that is why I do that. For simple/cheap/headless SBCs, just U-Boot and single partition is very much preferred I think, as that means less objects to maintain and also it allows seamless systemd-nspawn startup/run. That is very handy method of doing things with images. As with multiple partition you need losetup first and select/mount rootfs partition as well manually. I also use extra 1stFAT so it is easier to experiment and switch bootloader and various boot methods/files. Or build your own image with Armbian build, then 1 linux commandline, 'push-button', if you would select /dev/mmcblk0 as image target and have your buildhost running from NVME. Also note that there is the tool btrfs-convert, it works on various SBC images, if you also change/fix boot settings. For Armbian, I think only change is the rootfstype= line in armbianEnv.txt And what works for several UEFI machines is that you add the boot partitions at the end, so you can just shrink rootfs partition a bit, no complete recreate, that might save time when full 4TB HDD. It must have the correct type then so 0xEF00 (ESP), so Windows oriented users will easily get in trouble. Not sure if that also works for Linux only method, seems 0xEA00, but would expect that. Anyway, this is all fixing afterwards options, it of course won't play nice with Ext4 auto expand filesystem method in every SBC image nowadays (eating your SD-card, you never manage to undo).
  27. That's surprising. All I knew so far was that modules need to be present, either built-in or as dynamically loaded modules. Do you have a reference for this anomaly?
  28. Hey. I have no idea whether this will work for the H313 but I got my H713 Projector rooted using the following method. I'm assuming you at least have the stock firmware, but if not, it seems you can grab it here: https://androidpctv.com/firmware-android-tv-box-h96-max-h313 I dislike Windows so I was irritated that PhoenixSuit only seemed to run well on that platform, and ImgRePacker wasn't great either but then I found this project on GitHub: https://github.com/uictorius/imagewty-tool I'm unsure how you'd do this on Windows and I assume you know of a way to flash your box with a custom img file, but this was my work flow: 1. Back up your original img somewhere safe. Don't play around with this file. 2. Grab the latest available version of Magisk from https://github.com/topjohnwu/Magisk/releases. You want the APK file. 3. Go to this Project on GitHub. CircleTeam provide a browser based method of doing this here: https://circlecashteam.github.io/MagiskPatcher/ 4. Using imagewty-tool you first want to grab your boot partition. Run this against your copy of your firmware img. Let's say it's called update.img: imagewty-tool extract update.img 5. This will extract a bunch of FEX files to a directory called update.img.dump. You want to find the file called "boot.fex" 6. Now copy that file and rename it to "boot.img". Go to the MagiskPatcher site. 7. Upload the "boot.img" file at "Upload boot image" and the Magisk APK at "Upload Magisk APK". 8. Select armeabi-v7a radio button, then check every box below except "Recovery Mode" and click "Patch". 9. After a minute or two, the program will download a new patched boot.img to your Downloads folder. 10. Let's say it's called "new-boot.img", you'll want to rename it as "boot.fex" and overwrite the original boot.fex file in the update.img.dump directory. 11. Run imagewty-tool again, but this time: imagewty-tool repack update.img.dump new-image.img The beauty of this is that repacking recalculates all V-file checksums automatically. 12. Flash new-image.img to your box whatever way you're used to doing it with PhoenixSuit or whatever. However, you're not done. 13. Hopefully the box boots up. Get to adb, grab the Magisk APK again and run: adb install Magisk*.apk Once installed, open the Magisk app up and it will say it needs to complete installation, so go ahead and allow that install. Select the Recommended radio button to install and then reboot. 14. Assuming all went well it should boot back up for you. Run this to check root: adb shell su whoami If all went well it should say "root" in your terminal rather than "shell". A dialogue will pop up on the Android screen asking to allow root privileges so go ahead and allow those.
