  2. Weird. Check logs and verify matching - mac - if not changing random - is usually safest way. I haven't played under network manger lately ... perhaps there lies the problem or network devices gets up with a delay. I will try to recreate during week.
  3. OS is stable, errors you are experiencing are likely related to faulty HW component as @eselarm already exposed. And we would most likely notice such anomaly before it gets to you. There are thousands of users and this is the only report of this kind ... Boards are going to the market at high rate, while users support remains more or less the same in past 10 years https://docs.armbian.com/User-Guide_Board-Support-Rules/ Community builds and their upgrades are untested as size of Armbian can only cope with a small selection of boards we call as "standard support", where we have volunteers behind. Community builds are on Debian / Arch images level, but packed with more features. https://github.com/armbian/community?tab=readme-ov-file#purpose-of-this-repository For those - Armbian provides build and hosting infrastructure, place to meet - this forum - while everything else is anyone's problem.
  5. Aliexpress item: https://pl.aliexpress.com/item/1005006249858881.html Extracted dtb and dts files attached. It boots Warpme/miniarch image for X96 with LPDDR3 RAM https://github.com/warpme/miniarch/releases/download/f3b14fbae071/MiniArch-20240715-6.16.1-board-h313.x96_q_lpddr3-SD-Image.img.xz However internal Ethernet port is silent. It can work through USB->ETH adapter though. Any Idea on how to make Ethernet working? sun50.dtb sun50.dts
  6. Hi. Did you add / enable required overlays ? https://chatgpt.com/share/68a49507-d420-8005-a687-04d8daf0e93a It looks like kernel support is enabled.
  7. Collabora is heading to Amsterdam with talks, demos, and workshops covering Embedded Linux, KernelCI, Bluetooth & Auracast, mainline video capture for Rockchip, and more. Join us to see our latest open source work in action! View the full article
  8. @prahal - I tried a number of those images but none worked. With RoobiOS I see that all of the blue lights below the SATA ports (i.e. on the underside of the board) light up as blue for a couple of seconds, then they turn off and then they flash twice ... the screen comes on and after a couple of error messages the Installation GUI starts. With the images from the links you provided, I don't get the blue lights (although I do get a yellow network link light). However ... in RoobiOS I'm given the option of various images to install ... including the option for "custom" - I've selected that and entered https://fi.mirror.armbian.de/incoming/prahal/rock-5-itx/archive/Armbian_25.8.1_Rock-5-itx_bookworm_current_6.12.41_minimal.img.xz This gives a circle (of death?!) and "Loading ..." in RoobiOS but I see there's flashing green light on the ethernet port - which suggests that there's activity so maybe it's just a slow download?
  9. ... straightforward and smooth.
  10. With linux 6.12 the optimizations in /etc/rc.local do not apply anymore since some configuration options have vanished. So if you like to have a stable 2.5Gbit/s network connection without timeouts, linux-6.6 is still recommended (bookworm and trixie). You can build it yourself using an Armbian snapshot (from Dec. 2024) or download a recent linux-6.6.100 from here.
  11. Yesterday
  12. Try this image https://github.com/NickAlilovic/build/releases/download/20250306/Armbian-unofficial_25.05.0-trunk_X98h_bookworm_edge_6.12.11_xfce_desktop.img.xz
  13. Try to upload the old and new driver to an AI with you overlay included. Here it gives some suggestions for what you can try. The power sequence seems to be changed with the new driver and it might be too fast for your display. It suggests to put some parameters in the overlay to delay some parts, with higher chance with the first 3: Under "dsi0_panel: panel@0 {" prepare-delay-ms = <120>; reset-delay-ms = <50>; init-delay-ms = <150>; enable-delay-ms = <50>; disable-delay-ms = <50>; unprepare-delay-ms = <120>;
  14. https://github.com/armbian/build/pull/8517 appears to fix my SFP problems.
  15. I'm trying to install Armbian on the Tanix Tx1 Soc Allwinner H313 Mini TV Box, but this box doesn't have an SD card slot. How do I install Armbian on this box without an SD card?
  16. @schunckt Yes, I should have clarified that drm-copy is an argument is for MPV, which according to the guide mentioned above should allow the frame-buffer to be accessed directly. It is worth noting that mpv makes use of ffmpeg under the hood. Tried with ffplay once but did not have much luck with it. last I checked VLC is not supported other than the legacy vaapi. Please see: https://linux-sunxi.org/Sunxi-Cedrus You can use the sample media from linaro: https://samplemedia.linaro.org/ Just to check are you using the ffmpeg-v4l2-request?
  17. v25.8.1 for Rock 5B Plus running Armbian Linux 6.1.115-vendor-rk35xx
  18. Hello everyone! Could you help find image for x96q v.5.1. which have stable wifi and ethernet?!
  19. That's exactly what I did. I wrote a replacement for the .not_logged_in_yet file in my customize-image.sh with pre-set parameters, just like I create /root/provisioning.sh. I was just wondering if there were any other ways to do this.
  20. Device: Orange Pi 5 Plus DE: KDE-Neon Kernel: 6.1.115-vendor-rk35xx Last Friday, reported after updating KDE-Neon, it no longer boot up to KDE Plasma desktop successfully. After today's system update (using tty), reboot and it boot up successfully to KDE Plasma desktop.
  21. Hey, thanks for the reply. So there's actually no VAAPI driver available? Just OpenCL? Also, what is the recommended image for this?
  22. MOD: Your attitude of taking but not contributing and being abrasive is not welcome here. You received a warning now and will be unable to post to this forum for a few days. You were warned by several people many times before. If you still don't get the message and do not change course, expect to be blocked completely from Armbian. Be constructive, contribute or be gone.
  23. https://github.com/armbian/build/pull/8447#issuecomment-3195333910
  24. @jock @MattWestB thank you for you help! Sorry for the late reply. Im did update the dtb files jock said, and usb 3.0 work better now, but not as stable as 100%. Sometimes it still hang on reboot unless i disconnect the device on usb 3.0 port and re-insert power for complete reboot and booting, and sometimes it boot without recognise the device on usb 3.0 port. And sometimes the WiFi drop connection and reconnect repeatedly many times without dmesg errors, and need manual reboot. So maybe im just unlucky getting the bad batch of H96 Max. Due to the needed of stability, especially with the usb port, i switching to Dell Wyse 3040 for now. It's was fun playing with armbian and rockchip. Thank you for your contribution @jock 🥰
  25. Hey phoenix 0025m bro. My Tx3 Mini motherboard is same as yours. Did you have any success installing custom rom on it?
