  2. Hi, @Harleyyyu, thanks for the copy of multitool. Sadly it behaves just like before. When turning on with the SD card inserted I only get a red LED. I saw some people saying they had luck booting from LibreELEC, but I get the exact same behavior. I do want to keep a backup of my current OS. Any next steps for debugging it? Maybe it needs a shittier SD Card?
  4. Hi guys. Just sharing my experience. After reading @Johan S success story, I bought a Transpeed 8K 4GB 64GB. (https://www.aliexpress.com/item/1005005534455685.html) Apparently, mine is different, and nothing, I've tried, worked. But sharing is caring, so here we go. 🧩 DEVICE SPECIFICATION & FULL FINDINGS SUMMARY 📦 Device Identity Model: Transpeed 8K618‑T (or clone variant) SoC: Allwinner H618 (sun50i‑h618 family) CPU: Quad‑core ARM Cortex‑A53 DRAM: 4 GB DDR3 PMIC: AXP1530 (BOOT0), AXP313 (BL31) Boot Chain: BOOT0 → BL31 → Vendor U‑Boot 2025 → Kernel 🧠 DRAM & Bootloader Behavior DRAM training succeeds at 648 MHz DRAM type: DDR3 DRAM size: 4096 MB Bootloader reports chip ID 0x2100 BL31 applies CPU errata 855873 & 1530924 Vendor U‑Boot loads: Kernel DTB Initrd (always) → cannot be disabled Vendor U‑Boot ignores Armbian boot scripts and forces initramfs boot 💾 STORAGE 1. SD Card Slot — NON‑STANDARD HARDWARE This is the root cause of all Linux failures. BOOT0 reports: card no is 2 → SD wired to MMC2, not MMC0 sdcard 2 line count 8 → 8‑bit bus width (SD normally max 4‑bit) MMC 5.1 → SD treated as eMMC, not SD Speed: 50 MHz (HSSDR52/SDR25) Vendor U‑Boot handles it Mainline Linux cannot Linux symptoms: sunxi-mmc ... data error send stop command failed lsblk hangs ls /dev/mmcblk* hangs Kernel freezes on MMC access Armbian drops to initramfs MiniArch boots but freezes shortly after Conclusion: The SD interface is electrically non‑standard and incompatible with mainline Linux. 2. eMMC Detected as /dev/mmcblk2 Stable under vendor bootloader Linux could use it — but SD instability prevents reaching userspace 🖥️ DISPLAY HDMI DDC errors: pinctrl_get for HDMI2.0 DDC fail tv_power failed Likely missing regulators in DTB HDMI output unreliable 🌐 NETWORKING Ethernet PHY: AC300 Should work under Linux if system boots Wi‑Fi: AIC8800 (doable. Android is rooted, so just copy '/aicsdio', 'aic8800_fdrv.ko' and 'aic8800_bsp.ko') 🧪 IMAGES TESTED Armbian Armbian-unofficial_25.05.0-trunk_Transpeed-8k618-t_bookworm_edge_6.12.11_server Armbian-20240726-unofficial_24.8.0-trunk_Transpeed-8k618-t_bookworm_edge_6.7.12_server Results: Always dropped to initramfs Could not mount /dev/mmcblk0p2 init=/bin/sh ignored (because vendor U‑Boot forces initrd) SD access hangs kernel No path to userspace MiniArch MiniArch-20240715-6.18.3-board-h618.transpeed-8k618-t-SD-Image MiniArch-20240715-6.18.3-board-h618.vontar_h618-SD-Image Results: Kernel boots Reaches userspace Shows login banner Then freezes due to SD/MMC errors lsblk and ls /dev/mmcblk* hang MiniArch boots further than Armbian, but still fails due to the same SD hardware issue. 🖧 UART TESTING Tried multiple UART speeds: 115200 (default) 921600 (Android kernel switches to this mid‑boot) Other speeds (varied) Findings: Vendor U‑Boot uses 115200 Android kernel switches to 921600, causing “garbage” output MiniArch & Armbian stay at 115200 UART is stable — not the issue 🧪 BOOT PARAMETER TESTING Tried: init=/bin/sh root=/dev/ram Removing root= Editing armbianEnv.txt Editing extlinux.conf Disabling overlays Changing DTBs Adding earlycon Adding rootwait Adding rootdelay=10 Findings: Vendor U‑Boot ignores Armbian boot parameters Always loads initrd → always enters initramfs init=/bin/sh never executed under Armbian MiniArch does honor init=/bin/sh, but MMC hangs prevent installation 🧨 ROOT CAUSE SUMMARY The device has non‑standard SD/MMC wiring: SD slot wired to MMC2 (normally eMMC controller) SD slot uses 8‑bit MMC mode SD slot uses MMC 5.1 protocol SD slot uses 50 MHz high‑speed timing Vendor kernel supports this Mainline Linux does not This causes: Armbian initramfs failures MiniArch kernel freezes MMC access hangs eMMC inaccessible No way to install Linux No way to reach userspace reliably This is a hardware design incompatibility, not a software bug. 🟩 FINAL ASSESSMENT The device is not compatible with mainline Linux, because: SD interface is wired incorrectly Vendor U‑Boot forces initramfs MMC controller hangs under mainline drivers eMMC cannot be accessed due to SD instability DTB regulators missing HDMI DDC errors (Wi‑Fi requires proprietary driver Android works because it uses the proprietary Allwinner MMC driver. Mainline Linux does not.) 🟦 Images
  5. There's no armbian community image available to this device, don't flash images from other users, you will need to build your images, for tv-box it's all at your own risk, build your armbian image by applying this custom files use this DTS
  6. You need to clear the EMMC and flash the bootloader an easy way to do it, just flash the android update image, it will flash the bootloader. if you are making experiments with this board use this bootloader
  7. Hi Armbian community I have a Giada DN74 media player and would like to install Armbian on the box. First I try (through SD card) some community maintained images like the Orange Pi RK3399 or the Firefly RK3399, but none of them worked. Some google search teach me the Rockchip SoCs have fixed boot order (SPI->eMMC->SD card), and this cause my boot issue. Then search again how boot from SD card, the only solution which I find is to erase eMMC, so I erase the eMMC using: "rkdeveloptool ef". Unfortunately the box still not want to boot, so I open the box and try to identify the UART to see what is happening during the boot. I find a 4 pin connector (see images) which I assume this is the UART console, have a label "MCU_D" (Micro Controller Units Debug?) and have 3,3V on first pin and GND on the last pin. I try to use this connector whit some USB-to-UART (PL2303 and FT232RL) with multiple baud rate (115200, 1500000) without output. At this point was able still connect the box through USB and recover Android because MaskRom mode work fine. After some reading on https://opensource.rock-chips.com/wiki_Boot_option I deiced to build u-boot using evb-rk3399_defconfig and flash to the eMMC (which wan was a big mistake). I assume the box is try to boot from eMMC, but stuck there because is only u-boot on the eMMC nothing else. Unfortunately still no UART output (maybe is not UART connector) but also no Maskrom mode. If I understand right jock guide Unbrick Part, the only option to recover the box if I short EMMC CLK pin to GND. So my question is somebody could help me identify the eMMC CLK pin? Some extra info: According the rk3399 hardware design guide, I need to find a 22 ohm resistor near to the CLK pin. The eMMC is a Kingstone EMMC32G-TX29, and the manual write different CLK frequency's, I am don't know what I need to look. I have a Fnirsi dst-210 3in1 (sure not the best), which I could use measurements but I do not know how to set the oscilloscope parameters to find the CLK.
  8. Igor
    BTF is hungry for memory, yes. KERNEL_BTF=n and it needs less. On 16Gb+ machine you should be fine. If not memory is eaten away by something else.
  9. Hi if anyone have interested, this is dtb files and orangepienv file 🙂 allwinner.zip
  10. Yesterday
  11. Hi Gaetano, Maybe the issue is with g_mass_storage rather than OTG USB? "The "dr_mode" property controls whether OTG acts a peripheral or host. By default this is set to OTG mode so you shouldn't need to change anything. In my case I prefer to have OTG set as host for which I have this simple overlay: dts-v1/; /plugin/; /{ compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20"; fragment@0{ target = <&usb_otg>; __overlay__{ dr_mode = "host"; }; }; }; I find it works ok for reading a USB stick. It could be that you have to instead change dr_mode = "peripheral" but seeing as it shows up as a drive this may not be necessary. What kernel version are you currently? Are there any errors that show up in the logs? sudo dmesg | tail -n 20 There is also usb_f_mass_storage however this would need to be manually added as it is not currently included by default within the list of installed modules (Well at least was not on the last build I ran) Best of luck Ryzer
  12. can confirm: I installed the latest image `Armbian_25.11.1_Radxa-dragon-q6a_noble_edge_6.18.0-rc6_minimal.img` and wifi works. After an `apt upgrade` wifi doesnt work anymore... Solution: same as on the Rock 5C @just_facking_about type in `sudo dpkg-reconfigure aic8800-usb-dkms` and reboot the device
  13. It's this image from @Nick A github. Armbian-unofficial_25.05.0-trunk_X98h_bookworm_edge_6.12.11_xfce_desktop.img I had to copy over a few firmware files to get wifi/bluetooth working but otherwise it's unchanged.
  14. Hey Paul! Thanks for flagging this, going to look at it today and send a patch, the name probably got changed in the TI tree relatively recently so hadn't caught it yet. Best, Andrei
  15. I would first check the link, what is on the other side, etc. Also do a flood ping with large enough packages. Or UDP flood, not sure how to do that. Iperf3 might be easier. I have no clue about Radxa OS, never really used it. Maybe also do test boot with mainline based kernel, 6.19 edge I think. And what U-Boot version is used. I use Tianocore EDK2 UEFI v1.1, that might also have effect.
  16. Hi, i think the rpm setting-step's of the onboard fan is to low. - how can this be adjusted? SBC: Rock5b
  17. If there is anyone still running an older version of the kernel and the USB-C is working it would be helpful if I can get a copy of your rk3588s-odroid-m2.dtb.
  18. Last week
  19. https://github.com/armbian/os/pull/426 Once automation finishes - couple of hours, repo will have a missing package. Workaround: manually install package from https://packages.debian.org/forky/zfs-zed
  20. Igor
    Linux Headers
    Headers are present. https://imola.armbian.com/apt/pool/main/l/linux-headers-current-rockchip64/ Upgrade packages to latest and try again.
  21. etcher did decompess before flash to the SD card
  22. Hi @Anto, Igor has built that version if you look in his post above: https://forum.armbian.com/applications/core/interface/file/attachment.php?id=15377&key=f234d69d5a19f0081fdad46abb21cc36
  23. Version 3 Has been released! Complete UI Overhaul The entire user interface has been rebuilt from the ground up using Qt QML, delivering a modern automotive HMI experience optimized for touchscreen displays. New Home Screen - Large centered clock with configurable 12-hour/24-hour format - Gradient background (#00021A → #001D3F) - Swipe navigation to media player - Clean, minimal design with Readex Pro typography New Bottom Navigation Dock - 5-button dock: Home | Music | Android Auto | Volume | Settings - Always visible for quick access (except when running AA) - Icon-based navigation with visual feedback New Music Player - Album art display with track metadata - Playback controls (Previous, Play/Pause, Next) - Integrated with system media Redesigned Settings - Modern two-column layout with left sidebar navigation - 8 categories: General, Video, Audio, Input, Bluetooth, WiFi, System, About - Toggle switches, sliders, and radio buttons - Real-time system info (CPU temp, memory, frequency) - Live date/time display in header New Features - 12/24-Hour Time Toggle: Switch between time formats in Settings → General - Readex Pro Font: Variable weight font for consistent automotive typography - Modernized UI: The Original Crankshaft-NG was just not suitable for car use so i had to refresh it Technical Changes - Qt Widgets → QML Migration — Complete rewrite of UI layer - UIBackend Bridge — New C++ backend class exposing 50+ properties to QML - EGLFS Optimized — Designed for direct framebuffer rendering - No Animations — Instant transitions for 1GB RAM constraint - Centralized Theming — Theme.qml singleton for consistent styling Removed - GPIO settings (not applicable to TV Boxes) - DAC settings (using ALSA directly) - RTC settings (no CMOS battery, NTP only) - TSL2561 light sensor support (Pi-specific) - Camera module settings (Pi-specific) Bug Fixes - Fixed Cursor issue by utilizing Cursor plane (41, z-pos 2) - Fixed std::mutex missing include in RtAudioOutput - Fixed ColorOverlay import for Qt GraphicalEffects - Fixed time display showing 24hr with AM/PM suffix - Fixed buffer overflow warning in FFmpegDrmVideoOutput - Fixed QCursor conversion error in autoapp.cpp Known Issues: - Music player metadata not populated (requires media service integration, will be done in the next patch) - Volume popup not implemented (this require modifying the asound.conf before implementing) Issues? Open a ticket in https://github.com/Harleythetech/openauto-rk3229-armbian/issues Download https://github.com/Harleythetech/openauto-rk3229-armbian/releases/tag/oark322x-V3.0.0-alpha
  24. Some context: https://docs.armbian.com/User-Guide_FAQ/#why-things-stop-working The hardest part and expensive for time is keeping functions working while kernel changes, goes up. Image you are referring too is probably a demo image with some ancient kernel that will never be changed. This is usual way to sell hardware. It is made to work, but you will stay at this very old SW stack without any real option to change or fix anything. All functions on 300+ boards, which on top of extreme diversity, have also different revisions, quality issue ... is already not possible to keep up by entire open source community. Armbian is small part focused into SBCs and we do what we can. Work we are doing is never complete, we (nobody) can't solve bugs and especially not near to (expected) real-time. We (or community open source in total) can address a problem within weeks or months fastest as resources are tiny compared to problems that are constantly found in open source code that somebody else made. We have no option to expand the team / project as users don't care about well being of SW developers. We can only try to keep SW stack operational on a best effort principle. Once this job becomes too expensive (<1% of costs share is on users side), we have to step back and declare support as "community". We will continue to build and ship images as they might still work for some use cases and as downstream projects will provide those Armbian images anyway.
  25. A month ago when doing test boots and power measurements, see I discovered that when using the RPL 27W 'Pi5' PSU, the NanoPi-R6C with the indicated bootloader(s) and kernel(s) sticks to 5V. But when using a 45W USB-C PD PSU from a HP laptop or 60W USB-C PD PSU white-label, switch is made I saw on a USB-C PD power measurement device that was also in the chain. More detailed USB-C PD protocol analysis seems to be needed in order to figure out what happens. One could guess 3A is requested at highest possible voltage as with the 45W PSU, I saw 15V. 9V or 12V would also be OK, but the PD handler cannot be 100% sure I think, depends also what is inserted in USB type-A ports on device etc.
  26. does emmc working yet?
  27. armbianmonitor - u result: https://paste.armbian.com/nocetohemu Best regards Rolf
  28. @Nick A Oh yeah, I did change a few things as well for type c. Maybe the drm heap changes are not needed after all. Looking at my changes. husb311 is now under drivers/power/typec, so just enable it. et7304 is not included in the original bsp, radxa team added them later so simply apply this same patch. https://github.com/radxa/allwinner-bsp/commit/156b6578cc173855b41ea311a229403ccbadb17c
  29. With new python based build system there is error compiling headers while installing headers deb. Im not sure is it because of new build system or the problem is in 6.1.15 kernel branch. My compile command was: ./compile.sh BOARD=orangepione BRANCH=current BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_ONLY=yes KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,img SKIP_EXTERNAL_TOOLCHAINS=no BUILD_KSRC=no PRIVATE_CCACHE=yes RELEASE=bionic ARTIFACT_IGNORE_CACHE=yes BUILD_KSRC=yes KERNEL_GIT=full While installing i got: igor@honeypot:~/trash/debs$ ls -1 armbian-config_23.05.0-trunk_all.deb armbian-firmware_1-SA56ad-Bf566_all.deb linux-dtb-current-sunxi_6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8_armhf.deb linux-headers-current-sunxi_6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8_armhf.deb linux-image-current-sunxi_6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8_armhf.deb linux-u-boot-orangepione-current_2022.07-Se092-P12e0-Be261_armhf.deb igor@honeypot:~/trash/debs$ sudo dpkg -i * [sudo] password for igor: (Reading database ... 107907 files and directories currently installed.) Preparing to unpack armbian-config_23.05.0-trunk_all.deb ... Unpacking armbian-config (23.05.0-trunk) over (23.02.0-82) ... dpkg: warning: downgrading armbian-firmware from 23.02.0-82 to 1-SA56ad-Bf566 Preparing to unpack armbian-firmware_1-SA56ad-Bf566_all.deb ... Unpacking armbian-firmware (1-SA56ad-Bf566) over (23.02.0-82) ... dpkg: warning: downgrading linux-dtb-current-sunxi from 23.02.0-82 to 6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8 Preparing to unpack linux-dtb-current-sunxi_6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8_armhf.deb ... Armbian 'linux-dtb-current-sunxi' for '6.1.15-sunxi': 'preinst' starting. + rm -rf /boot/dtb + rm -rf /boot/dtb-6.1.15-sunxi + set +x Armbian 'linux-dtb-current-sunxi' for '6.1.15-sunxi': 'preinst' finishing. Unpacking linux-dtb-current-sunxi (6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8) over (23.02.0-82) ... dpkg: warning: downgrading linux-headers-current-sunxi from 23.02.0-82 to 6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8 Preparing to unpack linux-headers-current-sunxi_6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8_armhf.deb ... Armbian 'linux-headers-current-sunxi' for '6.1.15-sunxi': 'preinst' starting. + [[ -d /usr/src/linux-headers-6.1.15-sunxi ]] + set +x Armbian 'linux-headers-current-sunxi' for '6.1.15-sunxi': 'preinst' finishing. Unpacking linux-headers-current-sunxi (6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8) over (23.02.0-82) ... dpkg: warning: downgrading linux-image-current-sunxi from 23.02.0-82 to 6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8 Preparing to unpack linux-image-current-sunxi_6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8_armhf.deb ... Armbian 'linux-image-current-sunxi' for '6.1.15-sunxi': 'preinst' starting. + export 'DEB_MAINT_PARAMS=upgrade 23.02.0-82 6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8' + DEB_MAINT_PARAMS='upgrade 23.02.0-82 6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8' + export INITRD=Yes + INITRD=Yes + test -d /etc/kernel/preinst.d + run-parts --arg=6.1.15-sunxi --arg=/boot/vmlinuz-6.1.15-sunxi /etc/kernel/preinst.d update-initramfs: Deleting /boot/initrd.img-5.15.93-sunxi Removing obsolete file uInitrd-5.15.93-sunxi + mountpoint -q /boot + set +x Armbian 'linux-image-current-sunxi' for '6.1.15-sunxi': 'preinst' finishing. Unpacking linux-image-current-sunxi (6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8) over (23.02.0-82) ... Preparing to unpack linux-u-boot-orangepione-current_2022.07-Se092-P12e0-Be261_armhf.deb ... Unpacking linux-u-boot-orangepione-current (2022.07-Se092-P12e0-Be261) over (23.02.0-82) ... Setting up armbian-config (23.05.0-trunk) ... Setting up armbian-firmware (1-SA56ad-Bf566) ... Setting up linux-dtb-current-sunxi (6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8) ... Armbian 'linux-dtb-current-sunxi' for '6.1.15-sunxi': 'postinst' starting. + cd /boot + ln -sfT dtb-6.1.15-sunxi dtb + set +x Armbian 'linux-dtb-current-sunxi' for '6.1.15-sunxi': 'postinst' finishing. Setting up linux-headers-current-sunxi (6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8) ... Armbian 'linux-headers-current-sunxi' for '6.1.15-sunxi': 'postinst' starting. + cd /usr/src/linux-headers-6.1.15-sunxi ++ grep -c processor /proc/cpuinfo + NCPU=4 + echo 'Compiling kernel-headers tools (6.1.15-sunxi) using 4 CPUs - please wait ...' Compiling kernel-headers tools (6.1.15-sunxi) using 4 CPUs - please wait ... + yes '' + make ARCH=arm oldconfig HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o HOSTCC scripts/kconfig/confdata.o HOSTCC scripts/kconfig/expr.o LEX scripts/kconfig/lexer.lex.c YACC scripts/kconfig/parser.tab.[ch] HOSTCC scripts/kconfig/lexer.lex.o HOSTCC scripts/kconfig/menu.o HOSTCC scripts/kconfig/parser.tab.o HOSTCC scripts/kconfig/preprocess.o HOSTCC scripts/kconfig/symbol.o HOSTCC scripts/kconfig/util.o HOSTLD scripts/kconfig/conf # # configuration written to .config # + make ARCH=arm -j4 scripts SYNC include/config/auto.conf.cmd HOSTCC scripts/dtc/dtc.o HOSTCC scripts/dtc/flattree.o HOSTCC scripts/dtc/fstree.o HOSTCC scripts/dtc/data.o HOSTCC scripts/dtc/livetree.o HOSTCC scripts/dtc/treesource.o HOSTCC scripts/dtc/srcpos.o HOSTCC scripts/dtc/checks.o HOSTCC scripts/dtc/util.o LEX scripts/dtc/dtc-lexer.lex.c YACC scripts/dtc/dtc-parser.tab.[ch] HOSTCC scripts/dtc/libfdt/fdt.o HOSTCC scripts/dtc/libfdt/fdt_ro.o HOSTCC scripts/dtc/libfdt/fdt_wip.o HOSTCC scripts/dtc/libfdt/fdt_sw.o HOSTCC scripts/dtc/libfdt/fdt_rw.o HOSTCC scripts/dtc/libfdt/fdt_strerror.o HOSTCC scripts/dtc/libfdt/fdt_empty_tree.o HOSTCC scripts/dtc/libfdt/fdt_addresses.o HOSTCC scripts/dtc/libfdt/fdt_overlay.o HOSTCC scripts/dtc/fdtoverlay.o HOSTCC scripts/dtc/dtc-lexer.lex.o HOSTCC scripts/dtc/dtc-parser.tab.o HOSTLD scripts/dtc/fdtoverlay HOSTLD scripts/dtc/dtc HOSTCC scripts/bin2c HOSTCC scripts/kallsyms HOSTCC scripts/recordmcount HOSTCC scripts/selinux/genheaders/genheaders HOSTCC scripts/selinux/mdp/mdp HOSTCC scripts/sorttable HOSTCC scripts/asn1_compiler HOSTCC scripts/insert-sys-cert + make ARCH=arm -j4 M=scripts/mod/ CC scripts/mod/empty.o HOSTCC scripts/mod/mk_elfconfig CC scripts/mod/devicetable-offsets.s UPD scripts/mod/devicetable-offsets.h MKELF scripts/mod/elfconfig.h HOSTCC scripts/mod/modpost.o HOSTCC scripts/mod/sumversion.o HOSTCC scripts/mod/file2alias.o HOSTLD scripts/mod/modpost MODPOST scripts/mod/Module.symvers + make ARCH=arm -j4 tools/objtool DESCEND objtool HOSTCC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/fixdep.o HOSTLD /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/fixdep-in.o LINK /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/fixdep CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/weak.o CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/check.o MKDIR /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/arch/arm/ LD /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/arch/arm/objtool-in.o CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/special.o CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/exec-cmd.o check.c:11:10: fatal error: arch/elf.h: No such file or directory 11 | #include <arch/elf.h> | ^~~~~~~~~~~~ compilation terminated. make[3]: *** [/usr/src/linux-headers-6.1.15-sunxi/tools/build/Makefile.build:97: /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/check.o] Error 1 make[3]: *** Waiting for unfinished jobs.... special.c:14:10: fatal error: arch/special.h: No such file or directory 14 | #include <arch/special.h> | ^~~~~~~~~~~~~~~~ compilation terminated. CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/help.o make[3]: *** [/usr/src/linux-headers-6.1.15-sunxi/tools/build/Makefile.build:97: /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/special.o] Error 1 CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/pager.o make[2]: *** [Makefile:54: /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/objtool-in.o] Error 2 make[2]: *** Waiting for unfinished jobs.... CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/parse-options.o CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/run-command.o CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/sigchain.o CC /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/subcmd-config.o LD /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/libsubcmd-in.o AR /usr/src/linux-headers-6.1.15-sunxi/tools/objtool/libsubcmd.a make[1]: *** [Makefile:73: objtool] Error 2 make: *** [Makefile:1437: tools/objtool] Error 2 dpkg: error processing package linux-headers-current-sunxi (--install): installed linux-headers-current-sunxi package post-installation script subprocess returned error exit status 2 Setting up linux-image-current-sunxi (6.1.15-S4261-D4dc8-Pd2ed-C54bbHfe66-Bd6b8) ... Armbian 'linux-image-current-sunxi' for '6.1.15-sunxi': 'postinst' starting. + export 'DEB_MAINT_PARAMS=configure 23.02.0-82' + DEB_MAINT_PARAMS='configure 23.02.0-82' + export INITRD=Yes + INITRD=Yes + test -d /etc/kernel/postinst.d + run-parts --arg=6.1.15-sunxi --arg=/boot/vmlinuz-6.1.15-sunxi /etc/kernel/postinst.d update-initramfs: Generating /boot/initrd.img-6.1.15-sunxi update-initramfs: Converting to u-boot format + echo 'Armbian: update last-installed kernel symlink to '\''zImage'\''...' Armbian: update last-installed kernel symlink to 'zImage'... + ln -sfv vmlinuz-6.1.15-sunxi /boot/zImage '/boot/zImage' -> 'vmlinuz-6.1.15-sunxi' + touch /boot/.next + set +x Armbian 'linux-image-current-sunxi' for '6.1.15-sunxi': 'postinst' finishing. Setting up linux-u-boot-orangepione-current (2022.07-Se092-P12e0-Be261) ... Errors were encountered while processing: linux-headers-current-sunxi
