  2. I have two of these cheap Chinese sticks and I was wondering if I could load a better OS onto them I think there's only a USB port
  3. Or wait until the end of the year when 6.18 will be the new Linux version, that enables pretty much everything. RK3588 Mainline Linux Status: https://gitlab.collabora.com/hardware-enablement/rockchip-3588/notes-for-rockchip-3588/-/blob/main/mainline-status.md If you really need a bleeding edge working mediaplayer, LibreElec has experimental support for R6S/R6C: Thread: https://forum.libreelec.tv/thread/29953-le13-testing-for-rk3288-rk3328-rk3399-rk3566-rk3568-rk3576-rk3588/ Downloads: https://chewitt.libreelec.tv/testing/
  4. That's why I am here To ask for help I could not find any installable packages I am a novice user
  5. You can not use android dtb. You must try without It or try the rk3399 files included in the sdcard. i cant see the second rockchip (pmic)
  6. Firstly can you actually connect to the repo without issues? I my case I was getting timeouts and i suspect it was being blocked by my ISP for whatever reason and to work around I to tether my SBC to mobile for internet via mobile data then install the packages this way. This is my current ffmpeg: ffmpeg -version ffmpeg version 5.1.4-0+deb12u1.v4l2request Copyright (c) 2000-2023 the FFmpeg de velopers built with gcc 12 (Debian 12.2.0-14) configuration: --prefix=/usr --extra-version=0+deb12u1.v4l2request --toolchain=h ardened --libdir=/usr/lib/arm-linux-gnueabihf --incdir=/usr/include/arm-linux-gn ueabihf --arch=arm --enable-gpl --disable-stripping --enable-gnutls --enable-lad spa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable -libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgls lang --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enab le-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable- libpulse --enable-librabbitmq --enable-librist --enable-librubberband --enable-l ibshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt -- enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libtwolame --enable -libv4l2 --enable-v4l2-request --enable-v4l2-m2m --enable-libvidstab --enable-li bvorbis --enable-libvpx --enable-libwebp --enable-libudev --enable-libx265 --ena ble-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi - -enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enabl e-sdl2 --disable-sndio --enable-libjxl --enable-pocketsphinx --enable-librsvg -- enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --ena ble-frei0r --enable-libx264 --enable-libplacebo --enable-librav1e --enable-share Admittedly not the most up to date as it has been a while since I last attempted. From what I can tell from the latest pages it looks like using drm* has now been replaced with v4l2request more recently. I doubt it would specifically related to the duo2 and more likely at the soc dtsi definitions level. Now I encountered many of the same problems you did earlier but the older A10/A20 VE is limited to physically access only the first 256mb of memory. The H3 does not have the same constraints. @robertoj You are using a more modern setup? what is your current reported ffmpeg version.
  7. Dear all, I got myself an Radxa Rock 5 ITX+ as I thought I'd saw that this board had premium support. After it arrived, I saw that only the ITX (non-plus) variant had premium support, which since latest Armbian release some days ago seems to has been downgraded to standard support. I cleared both the eMMC and SPI flash to make sure the preinstalled OS were gone and would not interfere with the boot up process. Then I built myself a latest image with trixie and vendor kernel but I realized that (after booting from sdcard successfully), the Nvme was never picked up. The ITX+ has two M.2 full-size slots instead of only one - and is missing the SATA controller instead. To make sure I did nothing wrong with the building process I grabbed myself some old images like e.g. Armbian_24.11.1_Rock-5-itx_bookworm_vendor_6.1.75_cinnamon-backported-mesa_desktop.img.xz Armbian_25.2.2_Rock-5-itx_bookworm_vendor_6.1.99_cinnamon-backported-mesa_desktop.img.xz but they don't show working Nvmes either. So I got myself the latest nightly Trixie build (Rolling releases images with Armbian Linux v6.1 / Build Date: Sep 6, 2025 / Debian Debian 13 (Trixie)) from https://www.armbian.com/radxa-rock-5-itx/ and booted that, to also see that both populated Nvme slots are not picked up. lspci shows two Nvmes: 0000:01:00.0 Non-Volatile memory controller: Solid State Storage Technology Corporation NVMe SSD M.2 (rev 01) 0001:11:00.0 Non-Volatile memory controller: Solid State Storage Technology Corporation NVMe SSD M.2 (rev 01) Bot dmesg shows issues during boot: [ 14.165404] pci 0001:10:00.0: Primary bus is hard wired to 0 [ 14.165410] pci 0001:10:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring [ 14.165514] pci 0001:11:00.0: [1e95:3500] type 00 class 0x010802 [ 14.165568] pci 0001:11:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 14.165794] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f]) [ 14.165901] pci 0000:01:00.0: [1e95:3500] type 00 class 0x010802 [ 14.166009] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 14.166147] pci 0001:11:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0001:10:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link) [ 14.166379] cpu cpu6: l=15000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0 [ 14.166699] pci_bus 0001:11: busn_res: [bus 11-1f] end is updated to 11 [ 14.166721] pci 0001:10:00.0: BAR 8: assigned [mem 0xf1200000-0xf12fffff] [ 14.166729] pci 0001:10:00.0: BAR 6: assigned [mem 0xf1300000-0xf130ffff pref] [ 14.166729] pci 0000:01:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link) [ 14.166737] pci 0001:11:00.0: BAR 0: assigned [mem 0xf1200000-0xf1203fff 64bit] [ 14.166785] pci 0001:10:00.0: PCI bridge to [bus 11] [ 14.166792] pci 0001:10:00.0: bridge window [mem 0xf1200000-0xf12fffff] [ 14.168281] pcieport 0001:10:00.0: PME: Signaling with IRQ 128 [ 14.168548] nvme nvme0: pci function 0001:11:00.0 [ 14.168576] nvme 0001:11:00.0: enabling device (0000 -> 0002) [ 14.176536] pci 0000:00:00.0: BAR 8: assigned [mem 0xf0200000-0xf02fffff] [ 14.176542] pci 0000:00:00.0: BAR 6: assigned [mem 0xf0300000-0xf030ffff pref] [ 14.176546] pci 0000:01:00.0: BAR 0: assigned [mem 0xf0200000-0xf0203fff 64bit] [ 14.176569] pci 0000:00:00.0: PCI bridge to [bus 01-ff] [ 14.176573] pci 0000:00:00.0: bridge window [mem 0xf0200000-0xf02fffff] [ 14.177418] pcieport 0000:00:00.0: PME: Signaling with IRQ 138 [ 14.177557] nvme nvme1: pci function 0000:01:00.0 [ 14.177582] nvme 0000:01:00.0: enabling device (0000 -> 0002) [ 14.181202] nvme nvme0: Removing after probe failure status: -19 [ 14.185702] cpu cpu6: EM: OPP:1008000 is inefficient [ 14.185716] cpu cpu6: EM: OPP:816000 is inefficient [ 14.185965] cpu cpu6: EM: created perf domain [ 14.190212] nvme nvme1: Removing after probe failure status: -19 ( full log: https://paste.next.armbian.com/labujaguke.yaml ) Any idea on how to fix this and get them working? That would be really lovely, Thanks a lot for all your support!
  8. OK...I think it worked in OrangePi3 LTS 🙂 ...first, clean up the remnants: ................................................................. sudo apt purge v4l2loopback-dkms sudo apt autoremove ............................................................... armbian-config then I had to switch to a different kernel: edge:6.15.4-edge-sunxi64 ....then update the system: apt update / upgrade / reboot ! install from GitHub: v4l2loopback and then: cd ~/v4l2loopback .................................................................... VERSION=$(grep -oP 'PACKAGE_VERSION="\K[^"]+' dkms.conf) sudo cp -r . /usr/src/v4l2loopback-$VERSION sudo dkms add -m v4l2loopback -v $VERSION sudo dkms build -m v4l2loopback -v $VERSION sudo dkms install -m v4l2loopback -v $VERSION dkms status sudo modprobe v4l2loopback ls /dev/video* ................................................................... I guess it's OK now: ................................................................ but in my opinion the module is not working properly 😞
  9. It doesn't seem to make a difference:
  10. Hello @Nick A i was busy on school and my cable is delivered, i was able to use adb. Could you show me how to dunp the boot.img? @SteeMan, My box is fake and it is allwinner h313, is in 32 bit mode
  11. None of the images are no longer working for me, no matter which recent image I take, the A5E board just remains stuck with a solid blue light (with some green light flickering). I even tried compiling armbian myself, but that also didn't work. The only image working for me is the 25.02 version from earlier this year. I am using the Radxa A5E v1.2 version with 4gb ram. I also mounted the SD card to a linux machine and looked into /var/log for a boot file or reading the journal but I don't see any logs written. Have somebody stumbled unto a solution or does somebody have advice me how I can get the logs to find the culprit?
  12. I can see that after multiples update that the situation for the video acceleration seems to be better in full HD not in 4K, could you help me to understand how? In addition I'd like to add that I'm still getting problems with my Bluetooth keyboard and touch-pad being laggy especially when there is Ethernet traffic ongoing, i don't know if the bus of the Ethernet, the WiFi and Bluetooth card is shared in this SBC. Could you explain me how can i monitor this problem ? to conclude this morning I got a new packages issue, I runned the command "sudo armbianmonitor -u" and i pubblished the results to: https://paste.armbian.com/geyahoxavi
  13. Meanwhile, I upgraded the old rebooting (working) orangepi zero(1)s from U-boot "SPL 2019.04-armbian (Nov 18 2019 - 23:36:05 +0100)" to U-boot "SPL 2024.01-armbian-2024.01-S866c-P6b16-Ha5c2-V367a-Bb703-R448a (Apr 29 2025 - 02:50:09 +0000)" and they also now poweroff on reboot. So the problem is clearly u-boot, and not SD card vendor, kernel (they all run the same "6.12.43-current-sunxi #1 SMP Wed Aug 20 16:30:58 UTC 2025 armv7l") or whatever else. I'll see if I can manage to test U-boot v2025.07... Btw, one thing I noticed with old working boot.cmd/scr was that load_addr was "0x44000000" while it is now "0x45000000" - no idea what significance may have.
  14. Yesterday
  15. One issue with Debian Trixie and encrypted root file systems is that they made some changes. There's an additional package you now need (in addition to cryptsetup-initramfs) prior to updating your initramfs so it will mount an encrypted root: systemd-cryptsetup Despite what this says, I had to install it manually. https://www.debian.org/releases/trixie/release-notes/issues.en.html#encrypted-filesystems-need-systemd-cryptsetup-package
  16. Ah yes indeed. I meant laibsch. Sorry. I made an autoRevert.sh POC that hooks into the initramfs system. Assuming the partition layout described above the following script will revert to the other partition. It is assumed that if an update happened the updater will place a testBoot1 file inside the new boot directory and reboots. During initrd time the script will check for that file and rename it to testBoot2. If the script already detects a testBoot2 it will change the symlink of /boot to the other partition and reboots. Otherwise it is assumed that once the system is up testBoot2 is deleted from the running system if everything works. The script needs to be placed into /etc/initramfs-tools/scripts/init-premount/ and busybox needs to be installed as the script needs the more sophisticated basic commands. Then rebuild initrd. #!/bin/sh PREREQ="" prereqs() { echo "$PREREQ" if ! dpkg -s busybox>/dev/null 2>&1; then >&2 echo "Busybox not installed." exit 1 fi } case $1 in prereqs) prereqs exit 0 ;; esac reboot=0 echo mkdir /run/bootRevert mount /dev/mmcblk0p1 /run/bootRevert if [ -L "/run/bootRevert/boot" ]; then echo "/boot is a symlink. OK." cd /run/bootRevert currentTarget=$(readlink "boot") if [ -f "boot/testBoot2" ]; then echo -n "Reverting " if [ $currentTarget = "bootA" ]; then echo "to bootB." if [ -f "bootB/armbianEnv.txt" ]; then rm boot/testBoot2 ln -snf bootB boot reboot=1 else echo "Aborting revert. bootB seems to be empty." fi fi if [ $currentTarget = "bootB" ]; then echo "to bootA." if [ -f "bootA/armbianEnv.txt" ]; then rm boot/testBoot2 ln -snf bootA boot reboot=1 else echo "Aborting revert. bootA seems to be empty." fi fi else if [ -f "boot/testBoot1" ]; then echo "Going to testboot stage 2." mv boot/testBoot1 boot/testBoot2 else echo "No revert/testboot detected. Booting $currentTarget normally." fi fi fi cd / umount /run/bootRevert if [ $reboot = "1" ]; then sync echo "Rebooting..." reboot -f fi It seems then this concept works. As the script checks if /boot in the boot partition is a symlink and then does nothing if not it can also be placed in an unchanged armbian system without interfering. Perfect for creating new images. Still missing are the management scripts for: - converting an initially downloaded armbian image into an AB boot partition scheme - creating an image/update package from a running and well prepared or updated local armbian installation - a cronable management script to call a more specific download script and for switching partitions and rebooting - the download script that will attach to any distribution system that downloads the new update package places it into the other partition and adjusts machine identity; this download script could also just implement a backup of the running partition to the other partition so that switching back is possible if OTA is done using apt All of these can be done in shell.
  17. Board say Orange Pi 5 V1.2
  18. Hi , I am unable to boot my RK3568 board and cannot get it into MaskROM mode for recovery. The boot process fails with a "Synchronous Abort" in U-Boot SPL during DDR initialization. The device gets stuck in a boot loop. It starts DDR training (`ddrconfig:0`) but fails with a Data Abort exception. Standard methods to enter MaskROM /Loader have not worked. I have attached the full serial log (Boot_log.txt). Any guidance would be greatly appreciated. Thank you. Boot_log.txt
  19. @fabiobassa Not work, I did wrongly or something. The rk322x image didn't have this ap6330 dtb overlay, so I pull it from another armbian image
  20. Are u kidding me? This is freaking awesome Thanks guys, I will be patiently waiting..
  21. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
  22. Finally there is a proper tor-browser available for arm64/aarch64: 1. Goto https://nightlies.tbb.torproject.org/nightly-builds/tor-browser-builds/ 2. Navigate into: tbb-nightly.<date>/nightly-linux-aarch64/ 3. Download tor-browser-linux-aarch64-tbb-nightly.<date>.tar.xz 4. Unpack with tar -Jxvf and run tor-browser/start-tor-browser.desktop Yay! (I'm sure you can compile it too from their github page)
  23. Hey, has anyone tried using the BPI-3C1-27? Just wondering about price and if it’s really in stock.
  24. Last week
  25. Search my threads with keyword "ili9341". Post a photo of your wiring, a schematic, and what did you try within armbian... in this thread.
  26. This is similar to physical damage to the SD card
  27. Those are standard kernel patches. Do you mean Armbian build system does not support multiple patches in a single file? If so, you can download each of the 14 patches individually and then apply them. Or you can try reformatting the combined patch file as a single patch.
  28. Dear Community, I currently want to reduce the transmission power of the NanoPi Neo Air. This means that I simply want to be able to set the Wifi transmission power in 10% steps, for example. What I have already tried: Instructions according to Wiki: OpenWrt image is not flashed. No access via browser. But it doesn't matter: max. transmission power is used in AP mode. Setting as in the Wiki image "TransmitPower:auto" probably does not apply here anyway. Network Manager TUI via "sudo nmtui" has no such settings. Adjust the NVRAM files in "/lib/firmware/brcm" or "/lib/firmware/ap6212" step by step. All changes are saved in the txt file but not written to the host driver. The tests do not recognise any changes. No matter how I adjust the values. (Many different attempts) Firmware patch ("brcmfmac43430a1-sdio.bin") with HxD: The place where "Maxp2ga0" is set is found & edited in binary file. --> 07 60 3F 60 6D 61 78 70 32 67 61 30 = `?`maxp2ga0 Bytes for maxp2ga0: 07 60Bytes for maxp2ga1: 3F 60 3F 60 → 0x603F or 0x3F60 → similar, typically 0x60 = 96 → 20 dBm (Both antenna values have been set) Unfortunately, this change is not loaded into the host driver on the chip either... Continue working on existing "locked" firmware with Seemoo Lab? (unlikely) Throttling Tx-Power via command "sudo iw dev wlan0 set txpower fixed 1500" Change is displayed under "iwconfig wlan0", but it is either overwritten directly or not taken into account at all. No change is noticeable in the tests, no matter how low the value is set. Other firmware & NVRAM tested: Wifi does not start at all (IP rebount reconnect try xx) or the W-Lan is not visible. Maybe you can start here again and find a working firmware that is not "locked"? Which software to use? I test with Putty via the wifi connection. I use the following command: for i in $(seq 1 30); do iw dev wlan0 station dump | awk '/signal/ {print $2}'; sleep 1; done \ | awk '{x[NR]=$1; s+=$1} END{ if (NR>0) {mean=s/NR; for(i=1;i<=NR;i++) v+=(x[i]-mean)^2; sd=sqrt(v/NR); print 'N="NR, "mean="mean, "sd="sd} }' This measures the connection strength in dBm every second, 30 times, and only outputs the mean value. I always have the same 3 measurement positions with the exact same antenna alignment. (In a corridor: 3m, 12m, 25m) Interesting stuff: sudo iw phy phy0 info dmesg | tail -n 50 | grep -i brcmfmac File paths: /lib/firmware/brcm & /lib/firmware/AP6212 CC code (country) is not set by default: "sudo iw reg get" & "sudo iw reg set DE" Are there any other approaches or have I overlooked something? Thank you very much for your help!
