For this 16xx displays we need to ask @Jean-Francois Lessard he was in contact with this drivers for a while. these 16xx displays will be included in the mainline 6.18 drivers as tm16xx_i2c make sure to adjust your device according to this repository to benefit from the update https://github.com/jefflessard/tm16xx-display -
Read this entire topic, It's all there, just read it
Installing SliTaz on a TV Box with Rockchip RK3229
Hqnicolas replied to MXT5's topic in Rockchip CPU Boxes
oh how cool, send a shout out: https://forum.slitaz.org/ Let me read this https://doc.slitaz.org/en:start and I will give you the answer The answer is Yes https://arm.slitaz.org/ -
does anybody have a photo of the actual chip? A3A444 isn't finding much useful in google for a datasheet
if you have tweezers and pin location for Maskroom rockchip will never be bricked thanks for sharing I use the best technique of all, trial and error, tears, screams and anger. Search for the work from @jock as @paolosabatino in github You will find all variants dts files for this chip rk3318 and rk3328 test all of them https://github.com/armbian/build/blob/main/patch/kernel/archive/rockchip64-6.6/dt/rk3318-box.dts https://github.com/armbian/build/blob/main/patch/kernel/archive/rockchip64-6.17/dt/rk3318-box.dts also, this chip allready have a topic https://forum.armbian.com/topic/26978-csc-armbian-for-rk3318rk3328-tv-box-boards/ the solution was inside of it, just search DISCLAIMER (PLEASE READ): everything you can find in this thread (binaries, texts, code snippets, etc...) are provided AS-IS and are not part of official Armbian project. For this reason not people from Armbian project nor myself are responsible for misuse or loss of functionality of hardware.
I tried to build image for my vontar h618 box (PCB FX-H618-D4-V10, 4GB Samsung memory, 32GB eMMC). I've compiled it with KERNEL_BTF=no because I have limited RAM in Linux VM - 4+GB wasn't enough for BTF building. Board starts, LAN works OK, but WIFI wasn't present in device list. then I tried to update system - update is fetched but it seems like .dts is replaced, and HDMI and LAN didn't work at all. /proc/device-tree/name is empty. I tried to add "fdtfile=sun50i-h618-transpeed-8k618-t.dtb" in /boot/armbianEnv.txt - after reboot all remains same. how to specify right device tree at boot? UPD: I've changed line to "fdtfile=allwinner/sun50i-h618-transpeed-8k618-t.dtb", dtb file seems to be loaded, but nothing happened: systemd-shutdown[1]: Failed to set watchdog hardware timeout to 10min: Invalid argument systemd-shutdown[1]: Failed to set watchdog hardware timeout to 10min: Invalid argument reboot: Restarting system U-Boot SPL 2025.01-armbian-2025.01-S6d41-P65b3-H8869-Va3a9-Bb703-R448a-dirty (Oct 08 2025 - 13:44:47 +0300) DRAM:testing 32-bit width, rank = 2 read calibration failed! testing 32-bit width, rank = 1 DRAM:Store cfg DRAM:1st writing pattern DRAM:detecting column address bits detected 11 columns DRAM:restore cfg DRAM:reconfigure for all active rows DRAM:store cfg DRAM:2nd writing pattern DRAM:detecting row address bits detected 16 rows DRAM:restoring cfg DRAM:end of auto detect dram size MBUS port 0 cfg0 0100000d cfg1 00640080 MBUS port 1 cfg0 06000009 cfg1 01000578 MBUS port 2 cfg0 0200000d cfg1 00600100 MBUS port 3 cfg0 01000009 cfg1 00500064 MBUS port 4 cfg0 20000209 cfg1 1388157c MBUS port 5 cfg0 00640209 cfg1 00200040 MBUS port 6 cfg0 00640209 cfg1 00200040 MBUS port 8 cfg0 01000009 cfg1 00400080 MBUS port 11 cfg0 01000009 cfg1 00640080 MBUS port 14 cfg0 04000009 cfg1 00400100 MBUS port 16 cfg0 2000060d cfg1 09600af0 MBUS port 21 cfg0 0800060d cfg1 02000300 MBUS port 22 cfg0 01000009 cfg1 00640080 MBUS port 25 cfg0 0064000f cfg1 00200040 MBUS port 26 cfg0 20000209 cfg1 1388157c MBUS port 37 cfg0 01000009 cfg1 00400080 MBUS port 38 cfg0 00640209 cfg1 00200040 MBUS port 39 cfg0 20000209 cfg1 1388157c MBUS port 40 cfg0 00640209 cfg1 00200040 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.10.14(debug):armbian NOTICE: BL31: Built : 13:42:51, Oct 8 2025 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0a3760, model: Transpeed 8K618-T INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: PMIC: Probing AXP305 on RSB ERROR: RSB: set run-time address: 0x10003 INFO: Could not init RSB: -65539 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2025.01-armbian-2025.01-S6d41-P65b3-H8869-Va3a9-Bb703-R448a-dirty (Oct 08 2025 - 13:44:47 +0300) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: Transpeed 8K618-T DRAM: 4 GiB Core: 68 devices, 22 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0, mmc@4021000: 2, mmc@4022000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: apply fix for AC300 ephy bb version bug ... using AC300 emac1 ephy default config ... eth0: ethernet@5030000 starting USB... Bus usb@5101000: sun4i_usb_phy phy@5100400: External vbus detected, not enabling our own vbus USB EHCI 1.00 Bus usb@5101400: USB OHCI 1.0 Bus usb@5200000: USB EHCI 1.00 Bus usb@5200400: USB OHCI 1.0 scanning bus usb@5101000 for devices... 1 USB Device(s) found scanning bus usb@5101400 for devices... 1 USB Device(s) found scanning bus usb@5200000 for devices... 1 USB Device(s) found scanning bus usb@5200400 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 4641 bytes read in 9 ms (502.9 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 267 bytes read in 5 ms (51.8 KiB/s) Load fdt: /boot/dtb/allwinner/sun50i-h618-transpeed-8k618-t.dtb 41706 bytes read in 18 ms (2.2 MiB/s) Working FDT set to 4fa00000 4203 bytes read in 17 ms (241.2 KiB/s) Applying kernel provided DT fixup script (sun50i-h616-fixup.scr) ## Executing script at 45000000 22434042 bytes read in 1151 ms (18.6 MiB/s) 32059904 bytes read in 1642 ms (18.6 MiB/s) Moving Image from 0x40080000 to 0x40200000, end=0x42170000 ## Loading init Ramdisk from Legacy Image at 4ff00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 22433978 Bytes = 21.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Working FDT set to 4fa00000 Loading Ramdisk to 48a9a000, end 49fff0ba ... OK Loading Device Tree to 0000000048a27000, end 0000000048a99fff ... OK Working FDT set to 48a27000 Starting kernel ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.41 [/sbin/fsck.ext4 (1) -- /dev/mmcblk1p1] fsck.ext4 -a -C0 /dev/mmcblk1p1 armbi_root: clean, 43618/460672 files, 738631/1903616 blocks done. done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. SELinux: Could not open policy file <= /etc/selinux/default/policy/policy.34: No such file or directory Welcome to Armbian 25.11.0-trunk.38 trixie! <daemons startup> UPD2: devicetree seems to be loaded, strange that it isn't work: # cat /proc/device-tree/model Transpeed 8K618-T it seems like it's kernel-related thing? Here's full dmesg: [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.15.4-edge-sunxi64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #1 SMP PREEMPT Fri Jun 27 10:13:43 UTC 2025 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Transpeed 8K618-T [ 0.000000] efi: UEFI not found. [ 0.000000] OF: reserved mem: 0x0000000040000000..0x000000004007ffff (512 KiB) nomap non-reusable secmon@40000000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000040000000-0x000000004007ffff] [ 0.000000] node 0: [mem 0x0000000040080000-0x000000013fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000013fffffff] [ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 24 pages/cpu s58840 r8192 d31272 u98304 [ 0.000000] pcpu-alloc: s58840 r8192 d31272 u98304 alloc=24*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: root=UUID=19261dfd-7753-43cf-91f1-a7dbdbdd0887 rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 console=tty1 consoleblank=0 loglevel=1 ubootpart=0ab155bb-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=memory [ 0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=0ab155bb-01 cgroup_enable=memory", will be passed to user space. [ 0.000000] printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000f8000000-0x00000000fc000000] (64MB) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1048576 [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000713] Console: colour dummy device 80x25 [ 0.000725] printk: legacy console [tty1] enabled [ 0.000821] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.000835] pid_max: default: 32768 minimum: 301 [ 0.000943] LSM: initializing lsm=capability,yama,selinux,tomoyo [ 0.001011] Yama: becoming mindful. [ 0.001034] SELinux: Initializing. [ 0.001539] TOMOYO Linux initialized [ 0.001642] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.001668] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.003667] rcu: Hierarchical SRCU implementation. [ 0.003674] rcu: Max phase no-delay instances is 1000. [ 0.003880] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level [ 0.004075] EFI services will not be available. [ 0.004252] smp: Bringing up secondary CPUs ... [ 0.004678] Detected VIPT I-cache on CPU1 [ 0.004766] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.005273] Detected VIPT I-cache on CPU2 [ 0.005328] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.005786] Detected VIPT I-cache on CPU3 [ 0.005839] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.005913] smp: Brought up 1 node, 4 CPUs [ 0.005926] SMP: Total of 4 processors activated. [ 0.005931] CPU: All CPU(s) started at EL2 [ 0.005963] CPU features: detected: 32-bit EL0 Support [ 0.005968] CPU features: detected: 32-bit EL1 Support [ 0.005975] CPU features: detected: CRC32 instructions [ 0.005985] CPU features: detected: PMUv3 [ 0.006020] alternatives: applying system-wide alternatives [ 0.007221] Memory: 3923712K/4194304K available (15424K kernel code, 1548K rwdata, 10612K rodata, 3584K init, 805K bss, 201468K reserved, 65536K cma-reserved) [ 0.008193] devtmpfs: initialized [ 0.015645] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.015664] posixtimers hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.015708] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.016980] 24720 pages in range for non-PLT usage [ 0.017001] 516240 pages in range for PLT usage [ 0.017271] pinctrl core: initialized pinctrl subsystem [ 0.017917] DMI not present or invalid. [ 0.020332] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.021506] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.021634] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.021826] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.021867] audit: initializing netlink subsys (disabled) [ 0.022046] audit: type=2000 audit(0.020:1): state=initialized audit_enabled=0 res=1 [ 0.022522] thermal_sys: Registered thermal governor 'fair_share' [ 0.022529] thermal_sys: Registered thermal governor 'bang_bang' [ 0.022534] thermal_sys: Registered thermal governor 'step_wise' [ 0.022539] thermal_sys: Registered thermal governor 'user_space' [ 0.022583] cpuidle: using governor ladder [ 0.022612] cpuidle: using governor menu [ 0.022727] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.022811] ASID allocator initialised with 65536 entries [ 0.027793] /soc/bus@1000000/mixer@100000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.027851] /soc/clock@3001000: Fixed dependency cycle(s) with /soc/rtc@7000000 [ 0.027938] /soc/interrupt-controller@3021000: Fixed dependency cycle(s) with /soc/interrupt-controller@3021000 [ 0.028154] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/lcd-controller@6515000 [ 0.028176] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/bus@1000000/mixer@100000 [ 0.028215] /soc/lcd-controller@6515000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.028241] /soc/rtc@7000000: Fixed dependency cycle(s) with /soc/clock@3001000 [ 0.028258] /soc/rtc@7000000: Fixed dependency cycle(s) with /soc/clock@7010000 [ 0.028276] /soc/clock@7010000: Fixed dependency cycle(s) with /soc/clock@3001000 [ 0.028293] /soc/clock@7010000: Fixed dependency cycle(s) with /soc/rtc@7000000 [ 0.028495] /soc/bus@1000000/mixer@100000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.029164] /soc/clock@3001000: Fixed dependency cycle(s) with /soc/rtc@7000000 [ 0.033583] /soc/bus@1000000/mixer@100000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.033657] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/lcd-controller@6515000 [ 0.033680] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/bus@1000000/mixer@100000 [ 0.033876] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/lcd-controller@6515000 [ 0.033953] /soc/lcd-controller@6515000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.034248] /soc/clock@3001000: Fixed dependency cycle(s) with /soc/rtc@7000000 [ 0.034369] /soc/rtc@7000000: Fixed dependency cycle(s) with /soc/clock@3001000 [ 0.034436] /soc/rtc@7000000: Fixed dependency cycle(s) with /soc/clock@7010000 [ 0.034560] /soc/rtc@7000000: Fixed dependency cycle(s) with /soc/clock@7010000 [ 0.034627] /soc/clock@7010000: Fixed dependency cycle(s) with /soc/clock@3001000 [ 0.034691] /soc/clock@7010000: Fixed dependency cycle(s) with /soc/rtc@7000000 [ 0.037836] cryptd: max_cpu_qlen set to 1000 [ 0.104143] raid6: neonx8 gen() 1898 MB/s [ 0.172223] raid6: neonx4 gen() 1858 MB/s [ 0.240321] raid6: neonx2 gen() 1785 MB/s [ 0.308399] raid6: neonx1 gen() 1532 MB/s [ 0.376485] raid6: int64x8 gen() 1187 MB/s [ 0.444573] raid6: int64x4 gen() 1315 MB/s [ 0.512672] raid6: int64x2 gen() 1178 MB/s [ 0.580758] raid6: int64x1 gen() 872 MB/s [ 0.580765] raid6: using algorithm neonx8 gen() 1898 MB/s [ 0.648826] raid6: .... xor() 1393 MB/s, rmw enabled [ 0.648832] raid6: using neon recovery algorithm [ 0.649276] iommu: Default domain type: Translated [ 0.649282] iommu: DMA domain TLB invalidation policy: strict mode [ 0.650112] SCSI subsystem initialized [ 0.650236] libata version 3.00 loaded. [ 0.650421] usbcore: registered new interface driver usbfs [ 0.650461] usbcore: registered new interface driver hub [ 0.650492] usbcore: registered new device driver usb [ 0.650653] mc: Linux media interface: v0.10 [ 0.650699] videodev: Linux video capture interface: v2.00 [ 0.650780] pps_core: LinuxPPS API ver. 1 registered [ 0.650786] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.650802] PTP clock support registered [ 0.651229] Advanced Linux Sound Architecture Driver Initialized. [ 0.652054] NetLabel: Initializing [ 0.652060] NetLabel: domain hash size = 128 [ 0.652065] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 0.652127] NetLabel: unlabeled traffic allowed by default [ 0.652133] mctp: management component transport protocol core [ 0.652138] NET: Registered PF_MCTP protocol family [ 0.652386] vgaarb: loaded [ 0.652679] clocksource: Switched to clocksource arch_sys_counter [ 0.653008] VFS: Disk quotas dquot_6.6.0 [ 0.653029] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.653188] netfs: FS-Cache loaded [ 0.653315] CacheFiles: Loaded [ 0.661482] NET: Registered PF_INET protocol family [ 0.661724] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.721134] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.721244] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.721262] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.721513] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear) [ 0.722481] TCP: Hash tables configured (established 32768 bind 32768) [ 0.722600] UDP hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.722762] UDP-Lite hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.723108] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.723143] NET: Registered PF_XDP protocol family [ 0.723161] PCI: CLS 0 bytes, default 64 [ 0.723475] Unpacking initramfs... [ 0.727996] kvm [1]: nv: 566 coarse grained trap handlers [ 0.728564] kvm [1]: IPA Size Limit: 40 bits [ 0.730865] kvm [1]: vgic interrupt IRQ9 [ 0.730911] kvm [1]: Hyp nVHE mode initialized successfully [ 0.732725] Initialise system trusted keyrings [ 0.732928] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.733453] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.734205] SGI XFS with ACLs, security attributes, no debug enabled [ 0.797521] NET: Registered PF_ALG protocol family [ 0.797565] xor: automatically using best checksumming function 32regs [ 0.797577] Key type asymmetric registered [ 0.797583] Asymmetric key parser 'x509' registered [ 0.797590] Asymmetric key parser 'pkcs8' registered [ 0.797717] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242) [ 0.797966] io scheduler mq-deadline registered [ 0.798012] io scheduler bfq registered [ 0.804592] ledtrig-cpu: registered to indicate activity on CPUs [ 0.816616] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 0.820486] misc dump reg init [ 0.830701] loop: module loaded [ 0.831903] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information. [ 0.831912] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved. [ 0.833446] tun: Universal TUN/TAP device driver, 1.6 [ 0.834090] PPP generic driver version 2.4.2 [ 0.834237] PPP BSD Compression module registered [ 0.834244] PPP Deflate Compression module registered [ 0.834289] PPP MPPE Compression module registered [ 0.834296] NET: Registered PF_PPPOX protocol family [ 0.835684] usbcore: registered new interface driver usblp [ 0.835734] usbcore: registered new interface driver usb-storage [ 0.835991] mousedev: PS/2 mouse device common for all mice [ 0.837250] sun6i-rtc 7000000.rtc: registered as rtc0 [ 0.837272] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-02T02:49:37 UTC (96577) [ 0.837691] i2c_dev: i2c /dev entries driver [ 0.838464] usbcore: registered new interface driver uvcvideo [ 0.838474] Driver for 1-wire Dallas network protocol. [ 0.839693] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 0.841140] SMCCC: SOC_ID: ID = jep106:091e:1823 Revision = 0x00000002 [ 0.841189] hid: raw HID events driver (C) Jiri Kosina [ 0.841354] usbcore: registered new interface driver usbhid [ 0.841360] usbhid: USB HID core driver [ 0.842211] cedrus 1c0e000.video-codec: Device registered as /dev/video0 [ 0.843540] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available [ 0.852148] gnss: GNSS driver registered with major 239 [ 0.852507] usbcore: registered new interface driver snd-usb-audio [ 0.857235] NET: Registered PF_INET6 protocol family [ 1.809114] Freeing initrd memory: 21908K [ 1.852299] Segment Routing with IPv6 [ 1.852400] In-situ OAM (IOAM) with IPv6 [ 1.852559] NET: Registered PF_PACKET protocol family [ 1.852603] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 1.852761] 8021q: 802.1Q VLAN Support v1.8 [ 1.852833] 9pnet: Installing 9P2000 support [ 1.852934] Key type dns_resolver registered [ 1.866864] registered taskstats version 1 [ 1.867272] Loading compiled-in X.509 certificates [ 1.879248] zswap: loaded using pool lzo/zsmalloc [ 1.879519] Key type .fscrypt registered [ 1.879526] Key type fscrypt-provisioning registered [ 1.881026] Btrfs loaded, zoned=no, fsverity=no [ 1.881240] Key type encrypted registered [ 1.894341] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 1.894719] sun50i-h616-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver [ 1.896199] ehci-platform 5101000.usb: EHCI Host Controller [ 1.896223] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 1 [ 1.896561] ehci-platform 5200000.usb: EHCI Host Controller [ 1.896580] ehci-platform 5200000.usb: new USB bus registered, assigned bus number 2 [ 1.897000] sun50i-h616-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator [ 1.897028] ohci-platform 5101400.usb: Generic Platform OHCI controller [ 1.897047] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 3 [ 1.897049] ehci-platform 5200000.usb: irq 24, io mem 0x05200000 [ 1.897157] ohci-platform 5101400.usb: irq 25, io mem 0x05101400 [ 1.897300] ehci-platform 5101000.usb: irq 23, io mem 0x05101000 [ 1.897634] ohci-platform 5200400.usb: Generic Platform OHCI controller [ 1.897652] ohci-platform 5200400.usb: new USB bus registered, assigned bus number 4 [ 1.897721] ohci-platform 5200400.usb: irq 27, io mem 0x05200400 [ 1.897795] axp20x-i2c 0-0036: AXP20x variant AXP313a found [ 1.897982] axp20x-i2c 0-0036: AXP20X driver loaded [ 1.900578] sun50i_cpufreq_nvmem: sun50i-cpufreq-nvmem: unknown speed bin 0x2100, using default bin 0 [ 1.900594] sun50i_cpufreq_nvmem: Using CPU speed bin speed0 [ 1.904300] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 1.908708] ehci-platform 5200000.usb: USB 2.0 started, EHCI 1.00 [ 1.908863] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.15 [ 1.908872] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.908879] usb usb2: Product: EHCI Host Controller [ 1.908884] usb usb2: Manufacturer: Linux 6.15.4-edge-sunxi64 ehci_hcd [ 1.908890] usb usb2: SerialNumber: 5200000.usb [ 1.909336] hub 2-0:1.0: USB hub found [ 1.909359] hub 2-0:1.0: 1 port detected [ 1.910551] sun50i-h616-pinctrl 300b000.pinctrl: initialized sunXi PIO driver [ 1.911538] printk: legacy console [ttyS0] disabled [ 1.924687] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00 [ 1.924799] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.15 [ 1.924806] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.924811] usb usb1: Product: EHCI Host Controller [ 1.924815] usb usb1: Manufacturer: Linux 6.15.4-edge-sunxi64 ehci_hcd [ 1.924819] usb usb1: SerialNumber: 5101000.usb [ 1.925150] hub 1-0:1.0: USB hub found [ 1.925169] hub 1-0:1.0: 1 port detected [ 1.932133] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 293, base_baud = 1500000) is a 16550A [ 1.932186] printk: legacy console [ttyS0] enabled [ 1.953845] 5000400.serial: ttyS1 at MMIO 0x5000400 (irq = 294, base_baud = 1500000) is a 16550A [ 1.954482] Registered IR keymap rc-empty [ 1.954540] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0 [ 1.954633] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter [ 1.954733] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input0 [ 1.955041] sunxi-ir 7040000.ir: initialized sunXi IR driver [ 1.956585] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator [ 1.956816] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.15 [ 1.956828] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.956836] usb usb3: Product: Generic Platform OHCI controller [ 1.956843] usb usb3: Manufacturer: Linux 6.15.4-edge-sunxi64 ohci_hcd [ 1.956850] usb usb3: SerialNumber: 5101400.usb [ 1.957325] hub 3-0:1.0: USB hub found [ 1.957352] hub 3-0:1.0: 1 port detected [ 1.957850] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.15 [ 1.957863] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.957871] usb usb4: Product: Generic Platform OHCI controller [ 1.957878] usb usb4: Manufacturer: Linux 6.15.4-edge-sunxi64 ohci_hcd [ 1.957885] usb usb4: SerialNumber: 5200400.usb [ 1.958321] sunxi-mmc 4020000.mmc: Got CD GPIO [ 1.958395] hub 4-0:1.0: USB hub found [ 1.958424] hub 4-0:1.0: 1 port detected [ 1.958473] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq [ 1.980751] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 1.981082] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode [ 1.981600] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 2.026689] mmc1: new high speed SDHC card at address 1234 [ 2.027500] mmcblk1: mmc1:1234 SA08G 7.41 GiB [ 2.029537] mmcblk1: p1 [ 2.054946] clk: Disabling unused clocks [ 2.055089] PM: genpd: Disabling unused power domains [ 2.055101] ALSA device list: [ 2.055106] #0: h616-audio-codec [ 2.056849] Freeing unused kernel memory: 3584K [ 2.056979] Run /init as init process [ 2.056983] with arguments: [ 2.056987] /init [ 2.056990] with environment: [ 2.056993] HOME=/ [ 2.056997] TERM=linux [ 2.057001] splash=verbose [ 2.057004] ubootpart=0ab155bb-01 [ 2.057008] cgroup_enable=memory [ 2.064266] fbcon: Taking over console [ 2.075723] mmc0: new high speed SDIO card at address 0001 [ 2.235558] mmc2: new HS200 MMC card at address 0001 [ 2.236406] mmcblk2: mmc2:0001 HBG4e\x05 29.1 GiB [ 2.245344] mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 [ 2.252029] mmcblk2boot0: mmc2:0001 HBG4e\x05 4.00 MiB [ 2.255191] mmcblk2boot1: mmc2:0001 HBG4e\x05 4.00 MiB [ 2.412744] usb 4-1: new low-speed USB device number 2 using ohci-platform [ 2.582940] usb_phy_generic usb_phy_generic.1.auto: dummy supplies not allowed for exclusive requests (id=vbus) [ 2.583479] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver [ 2.583504] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 5 [ 2.583975] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.15 [ 2.583988] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.583995] usb usb5: Product: MUSB HDRC host driver [ 2.584001] usb usb5: Manufacturer: Linux 6.15.4-edge-sunxi64 musb-hcd [ 2.584007] usb usb5: SerialNumber: musb-hdrc.2.auto [ 2.589640] hub 5-0:1.0: USB hub found [ 2.589679] hub 5-0:1.0: 1 port detected [ 2.651852] usb 4-1: New USB device found, idVendor=04d9, idProduct=1603, bcdDevice= 3.10 [ 2.651879] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.651886] usb 4-1: Product: USB Keyboard [ 2.651892] usb 4-1: Manufacturer: [ 2.669092] input: USB Keyboard as /devices/platform/soc/5200400.usb/usb4/4-1/4-1:1.0/0003:04D9:1603.0001/input/input1 [ 2.813424] hid-generic 0003:04D9:1603.0001: input,hidraw0: USB HID v1.10 Keyboard [ USB Keyboard] on usb-5200400.usb-1/input0 [ 2.831654] input: USB Keyboard System Control as /devices/platform/soc/5200400.usb/usb4/4-1/4-1:1.1/0003:04D9:1603.0002/input/input2 [ 2.885250] input: USB Keyboard Consumer Control as /devices/platform/soc/5200400.usb/usb4/4-1/4-1:1.1/0003:04D9:1603.0002/input/input3 [ 2.885744] hid-generic 0003:04D9:1603.0002: input,hidraw1: USB HID v1.10 Device [ USB Keyboard] on usb-5200400.usb-1/input1 [ 3.431403] EXT4-fs (mmcblk1p1): mounted filesystem 19261dfd-7753-43cf-91f1-a7dbdbdd0887 ro with writeback data mode. Quota mode: none. [ 3.698271] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist. [ 4.711748] systemd[1]: System time advanced to built-in epoch: Tue 2025-09-09 11:38:33 EEST [ 4.996658] systemd[1]: systemd 257.8-1~deb13u2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE) [ 4.996764] systemd[1]: Detected architecture arm64. [ 5.038431] systemd[1]: Hostname set to <transpeed-8k618-t>. [ 5.387846] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported. [ 6.905977] systemd[1]: Queued start job for default target graphical.target. [ 6.954803] systemd[1]: Created slice system-getty.slice - Slice /system/getty. [ 6.957116] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe. [ 6.958937] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty. [ 6.960152] systemd[1]: Created slice user.slice - User and Session Slice. [ 6.960510] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch. [ 6.961364] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point. [ 6.961507] systemd[1]: Expecting device dev-ttyS0.device - /dev/ttyS0... [ 6.961776] systemd[1]: Reached target slices.target - Slice Units. [ 6.961909] systemd[1]: Reached target swap.target - Swaps. [ 6.977468] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket. [ 6.978394] systemd[1]: Listening on syslog.socket - Syslog Socket. [ 6.986417] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption. [ 6.986963] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe. [ 6.987389] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log). [ 6.987943] systemd[1]: Listening on systemd-journald.socket - Journal Sockets. [ 6.988169] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 6.988261] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 6.988615] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket. [ 6.988977] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket. [ 6.989585] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages). [ 6.996152] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System... [ 7.000167] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock... [ 7.003876] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System... [ 7.004522] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing). [ 7.005072] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab). [ 7.010397] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock... [ 7.021814] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout... [ 7.033445] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes... [ 7.042251] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs... [ 7.063844] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... [ 7.073767] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... [ 7.086154] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse... [ 7.087084] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67). [ 7.104248] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules... [ 7.104489] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 7.104853] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 7.122632] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials... [ 7.127539] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices... [ 7.137029] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System. [ 7.137757] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock. [ 7.139856] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System. [ 7.161570] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes. [ 7.163388] systemd[1]: fake-hwclock-load.service: Deactivated successfully. [ 7.164166] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock. [ 7.165895] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 7.166617] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 7.167703] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 7.168380] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 7.169817] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root). [ 7.173367] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems... [ 7.177503] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully... [ 7.179095] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 7.179933] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs. [ 7.184039] fuse: init (API version 7.43) [ 7.186468] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System... [ 7.190703] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 7.191663] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse. [ 7.205225] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System... [ 7.234008] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System. [ 7.244798] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System. [ 7.248975] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules. [ 7.253665] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables... [ 7.299369] EXT4-fs (mmcblk1p1): re-mounted 19261dfd-7753-43cf-91f1-a7dbdbdd0887 r/w. [ 7.310754] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems. [ 7.312796] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials. [ 7.331358] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc). [ 7.331611] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 7.335370] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed... [ 7.335602] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 7.392937] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables. [ 7.526733] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout. [ 7.718931] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices. [ 8.157121] systemd[1]: Finished systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully. [ 8.159637] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met. [ 8.165560] systemd[1]: Starting systemd-resolved.service - Network Name Resolution... [ 8.170151] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev... [ 8.248470] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev. [ 8.250750] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems. [ 8.257187] systemd[1]: Mounting tmp.mount - /tmp... [ 8.262377] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files... [ 8.318886] systemd[1]: Mounted tmp.mount - /tmp. [ 8.319484] systemd[1]: Reached target local-fs.target - Local File Systems. [ 8.326726] systemd[1]: Listening on systemd-sysext.socket - System Extension Image Management. [ 8.330796] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config... [ 8.339093] systemd[1]: Starting console-setup.service - Set console font and keymap... [ 8.347485] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data... [ 8.401908] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats... [ 8.475602] systemd[1]: Finished console-setup.service - Set console font and keymap. [ 8.501895] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 266 (systemd-binfmt) [ 8.522813] systemd[1]: Received SIGRTMIN+20 from PID 161 (plymouthd). [ 8.562744] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data. [ 9.135553] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System... [ 9.200463] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files. [ 9.213023] zram: Added device: zram0 [ 9.214516] zram: Added device: zram1 [ 9.217055] zram: Added device: zram2 [ 9.218426] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen... [ 9.228325] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System. [ 9.246450] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats. [ 9.433695] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0. [ 9.456729] random: crng init done [ 11.847701] zram0: detected capacity change from 0 to 4018328 [ 11.916645] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 11.916865] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 11.916988] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 11.917101] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 11.917179] sun8i-ce 1904000.crypto: Register cbc(aes) [ 11.917252] sun8i-ce 1904000.crypto: Register ecb(aes) [ 11.917273] sun8i-ce 1904000.crypto: Register cbc(des3_ede) [ 11.917293] sun8i-ce 1904000.crypto: Register ecb(des3_ede) [ 11.917313] sun8i-ce 1904000.crypto: Register md5 [ 11.917334] sun8i-ce 1904000.crypto: Register sha1 [ 11.917356] sun8i-ce 1904000.crypto: Register sha224 [ 11.917377] sun8i-ce 1904000.crypto: Register sha256 [ 11.917398] sun8i-ce 1904000.crypto: Register sha384 [ 11.917418] sun8i-ce 1904000.crypto: Register sha512 [ 11.917439] sun8i-ce 1904000.crypto: Register stdrng [ 11.917561] sun8i-ce 1904000.crypto: CryptoEngine Die ID 0 [ 12.118689] Adding 2009160k swap on /dev/zram0. Priority:5 extents:1 across:2009160k SS [ 12.185804] systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed. [ 12.186497] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes). [ 12.186656] systemd[1]: systemd-machine-id-commit.service - Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id). [ 12.259708] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen. [ 12.260592] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid). [ 12.261327] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch. [ 12.261532] systemd[1]: Reached target paths.target - Path Units. [ 12.347893] zram1: detected capacity change from 0 to 102400 [ 12.407256] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 12.417358] systemd[1]: Started systemd-resolved.service - Network Name Resolution. [ 12.426064] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 12.426728] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 12.441526] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid). [ 12.441679] systemd[1]: Reached target nss-lookup.target - Host and Network Name Lookups. [ 12.442398] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 12.442888] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages). [ 12.443204] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing). [ 12.446693] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock... [ 12.451454] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... [ 12.451767] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67). [ 12.452202] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc). [ 12.452456] systemd[1]: systemd-machine-id-commit.service - Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id). [ 12.452516] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 12.452810] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met. [ 12.452899] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 12.452949] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 12.523888] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 12.524664] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 12.525669] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 12.528169] systemd[1]: fake-hwclock-load.service: Deactivated successfully. [ 12.529066] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock. [ 12.548237] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3 [ 12.554293] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.transpeed,8k618-t.bin failed with error -2 [ 12.560120] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config. [ 12.564924] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging... [ 12.580014] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2 [ 13.275775] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging. [ 13.283666] systemd[1]: Starting systemd-journald.service - Journal Service... [ 13.438057] systemd-journald[425]: Collecting audit messages is disabled. [ 13.532888] systemd[1]: Started systemd-journald.service - Journal Service. [ 13.580761] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50 [ 13.630339] systemd-journald[425]: Received client request to flush runtime journal. [ 15.061746] systemd-journald[425]: /var/log/journal/86d178a1f5114188b9ed8fe9a41fe517/system.journal: Realtime clock jumped backwards relative to last journal entry, rotating. [ 15.061790] systemd-journald[425]: Rotating system journal. [ 21.976349] RPC: Registered named UNIX socket transport module. [ 21.976376] RPC: Registered udp transport module. [ 21.976383] RPC: Registered tcp transport module. [ 21.976389] RPC: Registered tcp-with-tls transport module. [ 21.976394] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 37.296144] systemd-journald[425]: Received client request to relinquish /var/log/journal/86d178a1f5114188b9ed8fe9a41fe517 access.
Assuming that you installed the standard image, then I suspect this is the same bug that I identified here: I submitted a PR to patch this, which has been accepted into Armbian, but it won't have flowed through into the releases yet, so you will need to build the image (instructions also linked in the subsequent post)
Radxa-cubie-a5e second Ethernet port not work after update
Samixa replied to Samixa's topic in Allwinner sunxi
Maybe this -> https://github.com/torvalds/linux/commit/a15f095b590bcc1968fbf2ced8fe87fbd8d012e0 -
Hi, for 2 day i am searching for set a bootlogo on the screen while loading klipper but all i get is the linux text that fly by. I set bootlogo= true in armbianEnv.txt does not help i can't find any other option. There should also be Splash can find any decent information about that either So is it possible to show a logo at booting klipper, if yes is it also possible to change it to custom logo or video because it would be nicer to show a logo or video then al these linux lines And i am not a professional programmer so easy language if possible
Yep, looks like it's about the netplan renderer. I've tried the actual image instead of the one I built locally and even just a reboot is able to reproduce the issue. The main difference is that on the image I built networking was via NetworkManager by default, while the image on the website uses systemd-networkd.
Any news on this subject ? Official Ubuntu is too limited .... I'm thinking to change to armbian my server ..... To install it, does it need a full recompilation ? or is there an img ? where can I find the DTB file for M2 ?
guenter replied to Hqnicolas's topic in Rockchip CPU Boxes
@Hqnicolas I'm a bit late because I have overlooked your request for testing. Now I can confirm that the AuxDisplay works correctly with my H96_tvbox_3566 (with AIC 8800 wlan chip). Thank you for your effort. -
Hardware: OrangePI-5-Plus (rk3588), with "32 GB" of RAM Operating System: Debian Trixie (pure, except EFI boot and Armbian edge kernel) Root File System: Ext4 (encrypted) Desktop: KDE Plasma 6.3.6 (wayland, GDM3), KDE Frameworks version: 6.13.0, QT version: 6.8.2 EFI Source: https://github.com/edk2-porting/edk2-rk3588 The boot messages, after a few starts (spaced apart) of the low-memory-monitor.service, say there's a failure to start it. After booting is complete, here's a screenshot of the output of: systemctl status low-memory-monitor.service This error didn't show up until I installed a number of packages. I tracked down the offending package from the Trixie repository: Package: xfsprogs Version: 6.13.0-2+b1 Size: 4774 kB Description: A set of commands to use the XFS filesystem, including mkfs.xfs Once this package was removed, the error vanished, and a repeat of the above Status command reported low-memory-monitor-service as active and okay. I also found that, while the error occurred with the Armbian edge 6.16.4 kernel, it did NOT occur with the Debian 6.16.3 kernel. Kernel With The Error (kernel source: Armbian trixie) --------------------- Package: linux-image-edge-rockchip64 (Armbian Linux edge kernel image 6.16.4-edge-rockchip64) Version: 25.8.1 Size: 282 MB Kernel Without The Error (kernel source: Debian trixie-backports) ------------------------ Package: linux-image-6.16.3+deb13-arm64-unsigned (Linux 6.16 for 64-bit ARMv8 machines) Version: 6.16.3-1~bpo13+1 Size: 210 MB I also briefly tried regressing the Armbian edge kernel from 25.8.1 (6.16.4) to the previously available version of 25.5.2, which was 6.16.0-rc3 (I think). The error occurred with that kernel as well. An Effect of This Bug (Possibly) When this error was showing up, I was once using the internet (firefox-esr package version 140.3.1esr-1~deb13u1) for a while, when after closing it, I discovered that my desktop background image had changed on its own. I could not change it back, no matter what I did (in the KDE settings gui). I could change it to something else, but whenever I changed it back, the altered image returned instead of what it should have been. But once I rebooted, the background was back to normal. While this one experience (very much an outlier) may not be conclusive, it is indicative of a possible memory leak.
ARM CPU running Linux 2GB RAM NPU for AI (maybe as little as CV) ARM MPU running Sketch (Arduino) https://store-usa.arduino.cc/products/uno-q Closed source
apt install f2fs-tools
Blank monitor arter login armbian ubuntu cinnamon
SteeMan replied to Anang Wahyudi's topic in Amlogic CPU Boxes
Is your monitor a standard 1080p resolution or something else? If you try a server build that doesn't load a graphical interface does it work? Have you tried something more standard like gnome instead of cinnamon? -
Hey @amazingfate, I have an issue with the build-in IR receiver on my OPI5+: ##O#O## OS: Armbian 25.8.1 noble aarch64 ####### Host: Orange Pi 5 Plus ########### Kernel: 6.1.115-vendor-rk35xx ############# Uptime: 2 mins ############### Packages: 1934 (dpkg), 5 (snap) ################ Shell: bash 5.2.21 ################# Resolution: 3840x2160 ##################### DE: GNOME 46.0 ##################### WM: Mutter ################# WM Theme: Adwaita Theme: Adwaita [GTK2/3] Icons: Adwaita [GTK2/3] Terminal: x-terminal-emul CPU: (8) @ 1.800GHz Memory: 2585MiB / 15957MiB After a reboot it works just fine, but once I suspend/resume it stops working. Logs look clear of errors. I have tried to troubleshoot with ChatGPT but goin' in circles and gave up. Lastly ended up with some speculations from it like: static int rockchip_pwm_remotectl_resume(struct device *dev) { struct remotectl_dev *rc_dev = dev_get_drvdata(dev); // Re-init or restart the device if (rc_dev && rc_dev->restart) rc_dev->restart(rc_dev); return 0; } static const struct dev_pm_ops rockchip_pwm_remotectl_pm_ops = { .resume = rockchip_pwm_remotectl_resume, }; static struct platform_driver rockchip_pwm_remotectl_driver = { .probe = rockchip_pwm_remotectl_probe, .driver = { .name = "rockchip_pwm_remotectl", .pm = &rockchip_pwm_remotectl_pm_ops, }, }; Do you think this is the problem, or if not can I share some details so you can try to find it?
Not an Armbian image. If you want to use this one, try to get support from where you got the image from.
I have a TV box with 1.5 GB lpddr3 that has been running Manjaro Arm without any problems for a long time. I used this TV box to add lpddr3 support to the dram driver many years ago. You can get the latest patch for 6GBIT lpddr3 support here: https://github.com/iuncuim/manjaro-h616/blob/main/uboot-t98-h2b-lp3/0007-shrink-ram.patch
From the Circuit Schematic it looks like the Radxa Rock 5B+ RK3588 GPIO0-C0 is the fan I/O, GPIO pin 24, if thats correct. I will verify I can access this on the Armbian distro.
