You're using Hardkernel's U-Boot. Yes, it's probably more importent to read from flash memory early, at boot. Using the manufactors bootloader is the only option until the chip or whatever is supported "mainline". By the way it is behind: Linux dosn't know how to shutdown/reboot without patch (reset-meson64). How to resume, a device that doesn't have a button? Perhaps `sm reboot_reason` spits out, if triggered via IR and read out in boot.scr? I do not want to suspend/hibernate a NAS. I best go with bootcmd `bootflow scan`. If one doesn't care about flash, but doesn't want to depend on SD card to boot from e.g. SATA, an option is to run Hardkernel's Linux, once to write U-Boot to NOR flash . kexec seems to need CONFIG_PROC_KCORE, but Armbian as many others doesn't. Mainline U-Boot doesn't load Hardkernel's Linux. Perhaps just boot the spiudate.img from SD card without spiboot.img and run (sounds strange I know, but better than cross-cross-compile out-of-date). Any news on mainline (patched) support for SPI NOR flash on Odroid-HC4? Perhaps I miss just a simple thing?
That error with mkimage during nand-sata-install is fairly common on XU4 and usually harmless if the system boots fine afterwards. The tool is a bit outdated and often throws this warning even when U-Boot is written correctly. Since it’s working after reboot, I wouldn’t worry about it.
xunicatt replied to chapeaufer's topic in Allwinner sunxi
Here is the commit: https://github.com/Guation/radxa-cubie-a5e-armbian-build/commit/202f1bf3943e2a583e10405f54b206fae9991a98 -
@sivert The "edge" kernel 7.x is more or less the stock kernel from upstream. It's missing some specific K1 drivers developed by SpacemiT basically. I think, upstream devs may implement their own version, thus may need some time. I am not sure, if upstream has the necessary SoC register documentation or if they persue some reverse-engineering on this. I recommend sticking with "current". HTH // Sven-Ola
@0757myt: Thank you so much for your clarification. I am really sorry that some parts of the guide are written too briefly. Sometime I don't know how to explain all of this messy things to new users. @hmoob I looked at your board and it seems your board doesn't have a power IC. There are just some diodes and capacitors near the DC port. May be one of them get shorted or burned but they are not really important. If you are good at soldering, you can definitely find the points for + and - pin to power the board so we will have 1 more USB port. Home Assistant need docker supports. Make sure that you are using the latest image (v1.1): https://github.com/chieunhatnang-personal/RK3128-Linux-SupportingScripts/releases/tag/kernel-6.6-armbian-26-v1.1 - Yesterday
Since you cannot trust this EMMC, @magixx256 Here is how to get log2ram up and running, plus a quick way to double-check your storage health. 1. Install log2ram Manually Run these commands to pull the official repository, install it, and get it running: # Download and extract the latest release curl -L https://github.com/azlux/log2ram/archive/master.tar.gz | tar zx # Move into the folder and run the installer cd log2ram-master sudo ./install.sh # Clean up the installer files cd .. && rm -rf log2ram-master Reboot to Activate It For log2ram to properly hijack the logging system and mount it into RAM, you need to reboot the machine: sudo reboot Verify It's Working Once the box boots back up, run your status command again: systemctl status log2ram You should see an active (exited) status (which is normal for this service, as it just runs a script at boot to create the RAM disk). You can also verify it's actively mounting by checking your system disks: df -h | grep log2ram You'll see a line showing /var/log mapped to log2ram with a size of about 40MB or 50MB. 2. A Quick Note on System Stability Since log2ram holds your logs in memory and only writes them to your eMMC/SD card once a day (or right before a clean shutdown), a sudden power pull means you lose the logs from that day. -
(FIX) SV6051/P WIFI DRIVERS FOR ARMBIAN
SteeMan replied to rayhanoriginal's topic in Amlogic CPU Boxes
Please note that ophub is not Armbian. They use the Armbian name without permission, do not contribute to Armbian development nor participate in these forums. Having said that, android TV boxes are a community supported effort under Armbian. It would be appreciated if you took the time to submit a PR to include your efforts into Armbian. -
I think what you want to ask is "Can I use u-boot to boot Guix system", and the answer to THAT is probably yes, but that has nothing to do with armbian. What eselarm wrote above is what you have to learn/do and understand. IE, you would need to build Guix system using u-boot, and this forum is not the correct place to ask that question. Maybe ask in the IRC chat here https://guix.gnu.org/en/help/ and see if you can find someone that is willing to help out. Or maybe on the reddit: https://www.reddit.com/r/GUIX/ L1tech forum is pretty popular, maybe ask there: https://forum.level1techs.com/c/software/linux/27
Morales Morales replied to sicxnull's topic in Allwinner CPU Boxes
@FrancasioHi, could you direct me to the link for that image? Thanks. -
raspbian is old 32-bit ARMv6, or maybe you use wrong naming. I see orangepi pc2 is also 1GB RAM and 4x Cortex-A53. So that is the same as RPi3B+. Armbian should be 64-bit on the orangepi pc2 and if that runs fine for you with HA, then it should also run fine the same way on RPi3B+. Armbian has no 32-bit support for raspberries, so maybe have a look if there is a ready-made image. The root filesystem on the orangepi pc2 you have currently should run almost unmodified on a RPi3B+. The issue is that raspberries boot filesystem is proprietary, but if you know or get to know how it works, you could get it to run.
I have also tried to build a new image and I am now getting a new error related to 16kb size. I have previosly had success 26.2.0 trunk 151, which was able to boot and worked quite well, Excluding known issues such as HDMI support and Fan speed needing to be adjusted with a script. Issue is that this build is no longer available. I think until we get more demand from Retroid Community we might just be out of luck
guy cal replied to Igor's topic in Software, Applications, Userspace
Problem solved. I used following instructions : Install Hacs on Home Assistant - Step-by-Step [year] — LazyAdmin -
NVMe not recognized on OrangePi 5 Pro with Armbian
Folaht Pjehrsohmehj replied to Folaht Pjehrsohmehj's topic in Beginners
I bought an NVMe SSD and it is being recognized. -
Hello everydoby. I'm starting work with the same board. Do you have any new information about the images to this board?
@ulumid Ram Initialstation ist done by U-Boot with a suitibal rkbin binary located in the first sectors of mmc. This ist spezific for your Board. connect PC to serial debug console and Test If Android Boot Starts and switchover to mmc if it is pluged.
I made this to work on sbc:s both with or without a boot partition: https://github.com/UnconnectedBedna/shrink-backup Uses rsync so it's way faster than a dd. Creates an img file at minimum size. Autoexpansion on restore available for Armbian. Also contains a systemd-nspawn utility if you want to make changes to the img file itself.
Searching for testpoint for the MX10-L TVstick
Hqnicolas replied to benabed brahim's topic in Allwinner CPU Boxes
Please move to Allwinner https://forum.armbian.com/topic/56539-how-to-install-armbian-on-mx10-f3-tv-stick/ https://xdaforums.com/t/how-to-use-otg-in-twrp.3097688/ -
Title: [Working Image + Patch] Orange Pi 4A (T527) - Fast Ethernet Fixed on Mainline 7.0 Edge Hi everyone, Since the Orange Pi 4A (Allwinner T527) is currently an unmaintained community target on the bleeding-edge Mainline 7.0 Edge branch, the default images boot up completely blind with cannot attach to PHY (error: -ENODEV) errors. After a lot of debugging, I (with assistance from Gemini - who wrote this post) managed to successfully compile a full, functional Debian Trixie image where Ethernet works perfectly (capped at 100M) and the green status LED pulses a native heartbeat. The secret sauce is that the board uses a Motorcomm YT8531 transceiver, but the kernel falls back to a Generic PHY driver which fails to calibrate the high-frequency RGMII clock skews required for Gigabit speeds. Dropping the link frequency down to 100 Mbps Full Duplex bypasses the timing sensitivity completely, allowing NetworkManager to instantly pull a stable IPv4 DHCP lease! (Note: Mainline 7.0 does not yet have internal C drivers for the T527 audio codec or the SDIO mmc1 bus clocks, so internal audio and onboard Wi-Fi remain offline. Use a USB sound/Wi-Fi dongle if needed). I can't vouch whether HDMI is working or not as I was debugging it using a serial cable. 📦 Download the Image https://drive.google.com/drive/folders/1ieu3TBn2nSP0BaJvJMIhLeLM6kt-x8bX?usp=sharing 🛠️ The Device Tree Patch File I managed to diff the radxa-cubie-5e.dts file and patch it to get it to kind of work with the opi 4a. The patchfile is also in the google drive folder and supplied as an attach here. To include this in your own Armbian build environment, delete any old patches and save this file exactly as: build/userpatches/kernel/archive/sunxi-7.0/zzzz-working-opi4a.patch It wipes out the broken default configurations and replaces them with clean, compiling mainline mappings. You can then build the image using this: ./compile.sh build BOARD=orangepi-4a BRANCH=edge BUILD_DESKTOP=no BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=trixie USERPATCHES_ALLOWED=yes SYSTEM_VERBOSE=yes FORCE_REBUILD=yes 📝 Step-by-Step Instructions to Lock Down the 100M Connection Because the Generic PHY driver cannot process 1Gbps packets correctly, the interface will sit in an unconfigured DOWN loop upon initial boot. Run these steps via your serial terminal loop to bring it online and automate it: Force the hardware down to 100M to clear the packet queue: sudo ethtool -s end0 speed 100 duplex full autoneg off Tell NetworkManager to explicitly negotiate the port: sudo nmcli device connect end0 Make the 100M setting permanent so it survives a reboot: sudo nmcli connection add type ethernet con-name eth-100m ifname end0 802-3-ethernet.auto-negotiate no 802-3-ethernet.speed 100 802-3-ethernet.duplex full ipv4.method auto ipv6.method disabled Automate the green status heartbeat LED: Open /etc/rc.local and add this line right above exit 0 echo heartbeat > /sys/class/leds/green:status/trigger Reboot, and you should have a 100% automated, maintenance-free, fully operational network target - with some tweaking will hopefully get you to the next stage as apt will be working. Hope this helps anyone else struggling to get this community board running on modern releases! zzzz-radxa-to-orangepi4a-fix.patch
Same situation here. The Orange Pi CM4 is not officially supported by Armbian and it doesn't look like it will be anytime soon. The Banana Pi CM4 image works best as a base (same SoC), but expect some missing features like NPU/video acceleration depending on the kernel. Official Orange Pi images are easier but come with all the usual vendor kernel issues.
This week's work centers on a comprehensive CI pipeline overhaul, expanded board and SoC support, and notable U-Boot and kernel modernization across Rockchip platforms. A substantial portion of the changes target CI infrastructure hardening in the new os-ci-test repository, including self-contained release handling, GHCR authentication via builtin tokens, watchdog-based auto-retry for stalled runs, proxy normalization, and sane build timeouts (60m packages, 30m/60m images). Related fixes in armbian/actions resolve datacenter runner proxy issues, while a rootfs change strips mmdebstrap's apt proxy from shipped images. Codeowners pruning of inactive maintainers and a Docker per-build image tag for parallel builds round out the developer-experience work. On the platform side, new board and SoC enablement continues with cix-p1 support, Orange Pi 4 Pro (Allwinner A733) community files, and Radxa Dragon Q6A audio, Chromium, and libbpf fixes. RK3506 and RK3506B are now split with proper ROCKUSB_BLOB handling, and Helios4 gains dual-PWM fan control on 6.18. Kernel configurations enable ATH9K_HTC, NFS client across all three kernels, and REALTEK_PHY_HWMON on rockchip64, while an RK3588 I2S MCLK regression is corrected. U-Boot modernization is broad: rk3308 boards (Rock Pi S, Rock S0) move from v2024.10 to v2026.07 with booti FDT fixes, Khadas VIM3 jumps to v2026.04, and VIM1/VIM2 receive khadas-uboot 0.17.3. The MediaTek Genio and NIO-12L platforms transition to pure mainline v7.1.y with loadaddr fixes for large kernels and initrds, and UEFI builds bump to v7.1 with Phytium dwmac rework. #Armbian #EmbeddedLinux #Rockchip #UBoot #CI Changes(#9400 P2b) Replace echo|pipe subshells with here-strings/parameter expansion. by @iav in armbian/build#9947Add AX210 firmware a0-72. by @ginkage in armbian/firmware#130Add cix-p1 support. by @EvilOlaf in armbian/build#9854add firmware for xiaomi-sheng. by @code002-2 in armbian/firmware#131boards: fix ayn child boards dropped from build matrix (inventory can't follow source). by @igorpecovnik in armbian/build#10054ci(build-all): drop dispatch inputs, always run with fixed defaults. by @igorpecovnik in armbian/os-ci-test#6ci(nightly): expose only branch + version override on dispatch. by @igorpecovnik in armbian/os-ci-test#4ci(watchdog): manual trigger to re-run a run's failed jobs. by @igorpecovnik in armbian/os-ci-test#15ci: blank ambient http(s)_proxy so the runner map is authoritative. by @igorpecovnik in armbian/os-ci-test#18ci: bump build retry attempts 3 → 8. by @igorpecovnik in armbian/os-ci-test#13ci: bump softprops/action-gh-release v2 -> v3 (Node 24). by @igorpecovnik in armbian/os-ci-test#2ci: cosmetic — 'Build' job label, one-line matrix job name. by @igorpecovnik in armbian/os-ci-test#12ci: create + read releases in this repo (self-contained test CI). by @igorpecovnik in armbian/os-ci-test#1ci: DOCKER_SKIP_UPDATE=no (pull & rebuild image, safer). by @igorpecovnik in armbian/os-ci-test#21ci: drop "(cronjob)" suffix from build workflow names. by @igorpecovnik in armbian/os-ci-test#7ci: drop build retry attempts 8 -> 3. by @igorpecovnik in armbian/os-ci-test#19ci: drop the version-only assets-for-download artifact. by @igorpecovnik in armbian/os-ci-test#10ci: expose Framework build branch input on build-all. by @igorpecovnik in armbian/os-ci-test#20ci: ghcr login with builtin GITHUB_TOKEN, mirroring armbian/os. by @igorpecovnik in armbian/os-ci-test#9ci: label chunk jobs with hash-free matrix.name. by @igorpecovnik in armbian/os-ci-test#17ci: probe apt proxy before exporting it (drop stale entries). by @igorpecovnik in armbian/os-ci-test#16ci: push artifacts to org ghcr via ACCESS_TOKEN. by @igorpecovnik in armbian/os-ci-test#5ci: push OCI artifacts to armbian/os via ACCESS_TOKEN. by @igorpecovnik in armbian/os-ci-test#11ci: sane build timeouts (packages 60m, images 30m compute / 60m job). by @igorpecovnik in armbian/os-ci-test#22ci: watchdog to auto-retry runner-stalled runs. by @igorpecovnik in armbian/os-ci-test#14codeowners: drop inactive maintainers (>=365d) from PR pings. by @igorpecovnik in armbian/build#10044Enable 1 GHz frequency for Panthor. by @ginkage in armbian/build#10067Enable 1 GHz frequency for Panthor on mainline. by @ginkage in armbian/build#10035family-rockchip: Split RK3506 / RK3506B. Add ROCKUSB_BLOB. Cleanup overrides. by @vidplace7 in armbian/build#10017firmware: download kernel before removing old (anti-brick) + repo menu badge fix. by @igorpecovnik in armbian/configng#947Fix led trigger for nanopi 5s led-lan2. by @ruabmbua in armbian/build#10028fix(cache): show UFS as its own badge in the cache manager. by @SuperKali in armbian/imager#161fix(ci): cache real build/cache/* dirs so OCI memoization persists. by @igorpecovnik in armbian/os-ci-test#8fix(devices): hide internal/system disks from flash targets (#159). by @SuperKali in armbian/imager#160fix(docker): unique per-build image tag for parallel builds on a shared daemon. by @igorpecovnik in armbian/build#9878genio, nio-12l: bump to pure mainline v7.1.y + loadaddr fixes. by @rpardini in armbian/build#10034genio: u-boot: mt8195 (nio-12l): update addr's map patch for large kernels/initrds. by @rpardini in armbian/build#10039gha-matrix: add short hash-free name to matrix items for job labels. by @igorpecovnik in armbian/build#10053gha: DOCKER_SKIP_UPDATE=no. by @rpardini in armbian/os#476git-ref2info: support gitproxy (git_cdn) source for Makefile version fetch. by @igorpecovnik in armbian/build#10066HOTFIX runner-clean: only clear proxy env, never set it to acng (fixes datacenter runners). by @igorpecovnik in armbian/actions#25kernel configs: enable CONFIG_ATH9K_HTC (Atheros USB wifi), DEBUGFS off. by @igorpecovnik in armbian/build#10032kernel configs: enable NFS client on the 3 kernels that lacked it (NFS rootfs). by @igorpecovnik in armbian/build#10042kernel/rockchip64: fix RK3588 I2S MCLK clk_disable_unused regression. by @SuperKali in armbian/build#10049khadas-vim1 / khadas-vim2: bump prebuilt u-boot blob to khadas-uboot 0.17.3. by @igorpecovnik in armbian/build#9994khadas-vim3: bump mainline u-boot to v2026.04. by @igorpecovnik in armbian/build#10013maint: rewrite various patchsets. by @EvilOlaf in armbian/build#10012mvebu: drive both PWM fans on Helios4 (dual PWM per GPIO bank, 6.18). by @iav in armbian/build#10021mvebu: fix some dmesg warnings for Helios4 . by @neheb in armbian/build#10024orangepi4pro: Add community support for Orange Pi 4 Pro (Allwinner A733) [new files only]. by @shkolnik in armbian/build#9967radxa-cubie-a7z: add board image. by @shkolnik in armbian/armbian.github.io#346radxa-dragon-q6a: fix audio UCM bump, Chromium zink gate, libbpf build. by @SuperKali in armbian/build#10019Rename radxa-cubie-a7z to cubie-a7z for naming consistency. by @shkolnik in armbian/armbian.github.io#347Revert "Enable 1 GHz frequency for Panthor on mainline". by @EvilOlaf in armbian/build#10048rk3308 (rockpi-s, rock-s0): u-boot v2024.10 -> v2026.07 + fix booti FDT. by @igorpecovnik in armbian/build#10062rock-s0: drop u-boot v1.1 MMC patch that can't apply to v2026.07. by @igorpecovnik in armbian/build#10068rockchip64-7.0: drop deprecated patchset. by @EvilOlaf in armbian/build#10038rockchip64: current/edge: enable REALTEK_PHY_HWMON. by @rpardini in armbian/build#10052rockchip64: enable v7.2-rc1 via bleedingedge . by @EvilOlaf in armbian/build#10073rockchip64_common: collapse line-continued expansion exec to single line. by @rpardini in armbian/build#10059rootfs: strip mmdebstrap's apt proxy so it doesn't ship in the image. by @igorpecovnik in armbian/build#10058runner-clean: normalize http(s)_proxy to runner's advertised apt proxy. by @igorpecovnik in armbian/actions#24scripts: fix js-yaml ESM default-import break in actions report. by @igorpecovnik in armbian/armbian.github.io#343stubble: add host dependencies. by @amazingfate in armbian/build#10020stubble: only add host deps when KERNEL_DO_STUBBLE=yes. by @igorpecovnik in armbian/build#10022u-boot/legacy/u-boot-radxa-rk35xx: change a file here to force all rk vendor u-boots to rebuild. by @rpardini in armbian/build#10070u-boot: debug produced binaries with dumpimage -l as well as binwalk. by @rpardini in armbian/build#10063u-boot: v2026.04: own rk3588 blueberry & mixtile DTs (drop kernel symlinks). by @igorpecovnik in armbian/build#10041uefi: bump to v7.1 + arm64:phytium-dwmac rework + x86:applet2. by @rpardini in armbian/build#10033View the full article
Looks like some good progress with an rk3518 here:
Hey there! Got a generic AndroidTV box (branded as "MORTAL") from AliExpress out of curiosity. It has suspicious applications baked in that cannot be disabled, so I want to flash it with clean custom firmware. Chipset is RK3518, wifi is AIC8800D80, PCB is DR822.R1.1.1.C6.02.V1.1.3.260526. Very happy to find your work, as Armbian seemed like the best bet here. Going to try out your build in the next few days and report back here.
