  2. hello i have updated with wrong firmware throw usb c nothing happens when flashing with USB_Burning_Tool or booting from sd card this box has no recovery button only on off inside earsphone
  4. Please provide more information on what your are experiencing and what you have tried already
  5. Yesterday
  6. It looks like knotes has been replaced with Marknotes. Remove knotes and, if you like, install marknotes. It is supposed to import your old knotes data.
  7. The 6.18.0-rc5 kernel doesn't require any patches, just have to been build with DRM_ACCEL_ROCKET.
  8. Hi, I currently have the issue of a non working usb port on my odroidhc4. dmesg output: [ 133.464610] usb usb1-port2: connect-debounce failed The port does not show up when lsusb is entered. uname -a: Linux odroidhc4 6.12.56-current-meson64 #1 SMP PREEMPT Wed Oct 29 13:09:02 UTC 2025 aarch64 GNU/Linux I solved this temporairly a while ago by booting an older kernel (linux-image-6.12.43+deb12-arm64) like mentioned here: Are there any progresses on how to fix this reliably? Because I think still running kernel 6.6.63 is not save. Thanks for your answer in advance, if you need more information I am happy to deliver.
  9. xNiux
    Odroid M2 16G
    Ok, after search, NPU is not integrate in the kernel. So ... It need patched kernel recompilation. I will try that later.
  10. https://drive.google.com/file/d/1vyQGR8kgzhCzmwuXhb8q5j707U9IXFob/view?usp=sharing The file in this shared link is the image file provided by the manufacturer for my Android device. I hope it will be useful, and thank you for your help! I can't compile a custom Armbian image and hope to get help from the community.@Hqnicolas
  11. You can ask for other users to publish they ROM images, but, the ideal way is to compile your own images, since this is a custom driver, I think it's a safe way to go. You can share some pictures images from the board, so we can confirm your WiFi board and lan chip.
  12. Did you also install the dtb that belongs to that kernel version? You could check if the dtbo is compatible with your dtb with: fdtoverlay -v -i /boot/dtb/current.dtb -o /tmp/test.dtb your-overlay.dtbo It would be better to compile the dts with armbian-add-overlay your-overlay.dts so it will automatically install it to /boot/overlay-user and added to your armbianEnv.txt. In this way it also won't get overwritten when you update the dtb. And of course like Werner said, check the debug serial console, you'll see much more detailed information. And check if the symlinks are correctly linked to your kernel version. ls -l /boot
  13. It's more than a year later - but the update to the distro-agnostic.sh to copy resolv.conf also fixed my native build as well. DNS for the apt/image build process was failing before I did that.
  14. Last week
  15. I have that line also: [ 0.496136] rockchip-pm-domain fd8d8000.power-management:power-controller: Failed to enable supply: -517 [ 0.938478] rockchip-pm-domain fd8d8000.power-management:power-controller: Failed to create device link (0x180) with supplier 2-0042 for /power-management@fd8d8000/power-controller/power-domain@8 [ 1.224290] rockchip-pm-domain fd8d8000.power-management:power-controller: Failed to enable supply: -517 [ 1.237338] rockchip-pm-domain fd8d8000.power-management:power-controller: Failed to create device link (0x180) with supplier 2-0042 for /power-management@fd8d8000/power-controller/power-domain@8 [ 1.294276] rockchip-pm-domain fd8d8000.power-management:power-controller: Failed to create device link (0x180) with supplier spi2.0 for /power-management@fd8d8000/power-controller/power-domain@12 [ 17.384495] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdba4000.video-codec [ 17.385477] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdba8000.video-codec [ 17.386457] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdbac000.video-codec [ 17.387427] rockchip-pm-domain fd8d8000.power-management:power-controller: sync_state() pending due to fdc40100.video-codec But VPU seems to be working anyway:
  16. I have now built the module with the armbian build framework and then it works.
  17. xNiux
    Odroid M2 16G
    I tried the lastest version "Armbian_community_25.11.0-trunk.472_Odroidm2_trixie_edge_6.18.0-rc5_minimal.img". But NPU is not mentioned in dmesg. Also, I have this red line. what could be the effect on the system ?
  18. Hi, just to give a maybe final feedback on this topic: Although it is not a really satisfying solution, I decided to switch off the sysrq functionality by setting kernel.sysrq=0 in /etc/sysctl.conf. This was 1 month ago and there were no sysrq events in my logs since then. So for now this is a "good enough" solution for me. Thank you all for your support, I learned again a lot ...
  19. You should check uboot logs if the dtbo is loaded correctly. You can get those using a debug serial console. If you don't know what that is or how to connect: https://debug.armbian.de
  20. @blackc Exact the original U-boot DRAM settings from your boot.bin or an update. https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/page/23/#findComment-218660 If you are still having issues ask the sunxi guys on IRC. https://oftc.catirclogs.org/linux-sunxi/2025-11-14
  21. Hello, I've been using https://joshua-riek.github.io/ubuntu-rockchip-download/boards/orangepi-5-plus.html with a custom kernel that I built to activate my TPM2.0 device and it works. Now I'm asked to use an UEFI compatible image with my Orange Pi 5 Plus. So what I did is more or less the same thing that in here But instead of the legacy kernel I used the 6.1.115-rockchip-vendor-rk35xx kernel and my device booted, I got an HDMI output, etc. And then I updated it to my custom kernel (6.1.0-1027-rockchip) that has the necessary configurations to allow TPM over SPI. Now I'm trying to activate my TPM2.0 as I did before. To do that I added my compiled *.dtbo (rk3588-spi0-tpm-cs1.dtbo) to /boot/dtb/rockchip/overlay and activated it with armbian-config. After reboot this is my /boot/armbianEnv.txt orangepi@uefi-arm64:~$ cat /boot/armbianEnv.txt verbosity=1 bootlogo=true console=both extraargs=cma=256M overlay_prefix=rk3588 fdtfile=rockchip/rk3588-orangepi-5-plus.dtb rootdev=UUID=3e555b58-fdf4-4e2f-a3af-a8ecfd8034b6 rootfstype=ext4 overlays=spi0-tpm-cs1 param_spidev_spi_bus=0 However I still can't see my tpm under /dev/. I don't know what I'm missing, I'm quite new to this sorry Thank you for your time
  22. Could you please tell me in detail how to use these files? My knowledge of Linux is very limited. Do I need to recompile a custom image suitable for myself, or how should I use these files to carry out specific operations to solve my problem? Thank you.
  23. I am an Linux Beginner and I only can use Terminal for copy/paste issues. For many months my Raspberry Pi 5 runs perfectly with Armbian. But when I try to update the system in the Discover App, I get the following error message: The following packages have unmet dependencies: kpim6-akonadi: Kollidiert mit: knotes but 4:24.05.2+p24.04+vstable+git20240705.1500-0 is to be installed Kollidiert mit: kpim6-akonadi-notes but 4:24.08.3+p24.04+vstable+git20241129.1417-0 is to be installed Can someone please help me to get my system up-to-date? Thanks in advance!
  24. Yes, i know, but i think this is mostly UBoot DRAM controller parameters problem. May be someone have any suggestions about it...
  25. Armbian Bookworm 25.8.1. (minimal) Odroid XU4 with 32GB eMMc After lots of searching and trying 2017 Hardkernel solutions and github etc - And this forum suggestions - I could never get get it to boot. I think this is partly because things have changed since 2016/17. I did not have my eMMc on an usb adapter. Just installed, brand new (untouched from China) eMMc and a imaage install on MicroSD of Armbian. The method I believed should work was "armbian-install". But, it had errors while using mkpartimage. I put debug statements in the script and found the particular instance of invoking mkpartimage. Actually the issue is; 2 files are missing from /boot folder. Current SD installation image of Armbian minimal only creates one fdisk (MBR) partition on which /boot is a folder. I tried for ages to create a separate /boot partition. Maybe, since I have now succeeded with an eMMc install, I might try doing a separate root and boot. The 2 missing files are armbianEnv.txt and boot.cmd If one "touch"es armbianEnv.txt then - if it doesn't exist it will be created - if it does then no harm done. If one copies boot.ini to boot.cmd then these two things will satisfy armbian-install. Amrbian-install correctly changes the R/O of mmcblkXboot1 (where X is emmc device number) write the boot stuff and markit back R/O. It also ensures that armbianEnv.txt has got correct entries in it. In summary Install eMMc and Micro SD in XU4 Ensure SD/eMMc switch set to SD and boot armbian from SD Login as root or use sudo touch /boot/armbianEnv.txt cp /boot/boot.ini /boot/boot.cmd armbian-install choose the install and boot from eMMc option shutdown change switch to boot armbian from eMMc boot
  26. Hi @djurny Just to inform you that, after cleaning out some mess I made, your overlay and armbianEnv.txt update to make the external RTC ds3231 to work, did the job. For my SBC's I use the Banana Pi M2 Zero and v25.5 rolling for Banana Pi M2 Zero running Armbian Linux 6.6.75-current-sunxi My application needs to work in the field as an Access Point with an RTC, the right date and time is important info in the diagnostics of my applications. A remark on the mentioned Armbian release: For using the GPIO pins of the SBC, python3-libgpiod works great. I use USB camera's (V4L2 camera). After any update or upgrade, my USB camera's won't work anymore. Not really a problem for me, because I'm happy as it works right now, no updates or upgrades needed. Thanks again for your great help. Met vriendelijke groet, Ed
  27. https://github.com/armbian/build/blob/main/config/boards/retroidpocket-rp5.csc https://github.com/armbian/build/blob/main/config/boards/retroidpocket-rpmini.csc You can build images on your own. https://docs.armbian.com/User-Guide_Board-Support-Rules/#community-maintained
