Sorry, bad copy-paste, using meson-gxl-s905x-p212.dtb USB ports don't work. Changed to meson-gxm-q201.dtb USB ports work, managed to get to desktop but no wired network. I see the port up but it tells me the cable is disconnected. Going to try meson-gxm-s912-libretech-pc.dtb and see how it goes. I just want to say, thank you SteeMan, thanks to your post and your instructions, I might be able to use this old box for something useful.
@jock, I got my version of Multiool at the top of this topic, to be exact, it was https://users.armbian.com/jock/web/rk3318/multitool.img.xz -
Update: I managed to brick my box to a dead Android screen. Then got it upgraded to Android 7.1.1 cause I finally found an image. Booted armbian and it gets all the way to log in screen using the meson-gxm-s912-mecool-bb2-pro.dtb but it doesn't detect anything on the USB ports with a "debounce" error on both of them and seems that the nic is up but I don't see the box in my DHCP server. Any advice is greatly appreciated Best regards
Hello again I have recreated /var/log/nginx and also /var/spool/postfix as it wasn't also not copied and postfix@-.service didn't start. Now I see that /srv does not get populated with the mount points of disks by-uuid... Excuse me if I repeat my question: what gets copied over with armbian-install? Just to have a list of what I have to recreate. Thank you.
No one has ever submitted this for inclusion in Armbian. This is a community supported board. If anyone were to submit this as a PR it would almost certainly be included as the approval process for community supported boards is a low bar, basically that it doesn't break the build.
This is my current uptime, with a running smb, torrent server, and 4 docker containers. It's a shame that the voltage fix never seems to be “officially” adopted. A system hardly needs to be any more stable than this
I am using :- [ Ubuntu 24.04 (Noble)](https://dl.armbian.com/rock-5b-plus/Noble_vendor_server) from :- [Radxa Rock 5B Plus - Armbian](https://www.armbian.com/rock-5b-plus/) Trying to turn fan on on Radxa Rock 5B+ selecting the device using armbian-config actually makes it disappear I am getting `line 3: echo: write error:Device or resource busy`
https://apt.armbian.com/ Expired Certificate
Werner replied to ER Samson's topic in Advanced users - Development
We're aware -
duplicate
I have tried A lot of ROMs and they do not work. The device is not working now. Please help. Thank you.
cmosetick replied to ER Samson's topic in Advanced users - Development
I'm also seeing the expired LE Certificate today. I posted my report in the Beginners Section here to get more visibility, but it's waiting for moderator approval. -
Err:6 https://apt.armbian.com noble InRelease Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification. [IP: 152.53.81.238 443]
Let's Encrypt Certificate has expired for apt.armbian.com openssl s_client -connect apt.armbian.com:443 -servername apt.armbian.com < /dev/null 2>&1 | grep -E "(Verify return code|subject|issuer|notBefore|notAfter)" notAfter=Sep 25 23:05:16 2025 GMT notAfter=Sep 25 23:05:16 2025 GMT subject=CN=apt.armbian.com issuer=C=US, O=Let's Encrypt, CN=E6 Verify return code: 10 (certificate has expired)
@JaydenWithaWhy Multitool is supposed to resize the partition to the whole size of the media as soon as you run it for the first time on the box. About the "command not found" and black box issues, I'm not aware about. When you see the Terms, you can scroll up and down and Enter key will just proceed to the main menu. Where did you download the software?
Could you please be more explicit or point me to some tutorial? In the readme the only info I can see are how to build U-Boot for s905x in the version I already have, or newer but for different chips s905x2 and s905x3. Thanks again for your help -
Hello! I am quite new to using Armbian, and I have been having some trouble trying to boot into Multitool. Before I explain my problem, I will describe what I have been using, which is an RK3328 X88 Pro 10. The image I tried using alongside Multitool was Armbian_23.11.1_RK3328-Box_jammy_current_6.1.63.img. First off the bat, Multitool was only 377 MB, even though the min SD I was using is 117 GB, which I am not sure if that was done on purpose, but I made it more difficult to find an image that fit. Next, when Mulitool booted in, I was greeted with the Terms of Software page, which would only let me scroll up and down. If I try any other keyboard keys (I do not have the remote; it has been lost for years). A black box from the bottom of the screen, opening some kind of terminal, saying "Line 17: command not found" when it opens, all I can do is type like a text editor where hitting enter does not get a response from the software. I don't know what to do at all, so I hope one of you guys could understand the predicament I'm in -
If you're still able to boot from microsd (which should be prefered over emmc if Armbian uboot is used) you can chroot into the system on eMMC and downgrade packages, either manually (apt/dpkg) or with armbian-config.
