  2. I have stopped working with the box, since mine failed, and the Raspberry Pi zero is cheap again. The last old image was working well before my box failed, the S805 was no longer supported when I started using it. I had bought it for $1 at a hamfest as a project to figure them out.
  3. Yesterday
  4. Generally debugging is done through the UART connector: https://debug.armbian.de/
  5. I would first suggest that you read this post: That may give you lots of reasons why you shouldn't depending on what your goals are. Installing armbian on a TV Box depends on the TV Box. Each CPU has differing levels of support (from none to fairly well supported in mainline linux). And then given there are hundreds of different TV Boxes, each will have different sets of working/non-working features depending on a variety of factors. As far as supporting a USB audio device, it shouldn't be any different than support for the device on any other linux platform/distribution. On Armbian you may need to install the linux-firmware-full package to get the driver support as by default Armbian ships with a slimed down set of firmware support.
  6. Hello, how are you? With all due respect, could someone help me get an Armbian image for my TV box with an Amlogic S805 processor? Thank you very much.
  7. until
    5:00 PM EST
  8. https://time.is/London
  9. Hey, I have a Banana PI M3 root@192.168.178.193's password: _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| v25.5.1 for Banana Pi running Armbian Linux 6.12.30-current-sunxi Packages: Ubuntu stable (noble) IPv4: (LAN) 192.168.178.193 (WAN) 87.160.68.42 Performance: Load: 20% Up time: 26 min Memory usage: 11% of 959M CPU temp: 47°C Usage of /: 5% of 29G Commands: Configuration : armbian-config Monitoring : htop I installed the latest image, since I had trouble to boot my old configuration. After I installed it at my TV for debuging I just saw the first boot-sequence until usually the ubuntu-boot starts in a new screen. There came no screen an the device was not available via ssh or ping. - So I decided to check the SD-Card in my ubuntu laptop. There were errrors which have been fixed. Afterwards I had still the same black screen after boot-prompt. So I was sure copied all of my files via nautilus and thought, why not starting from beginning. So I installed the latest image. - This image bootet perfect. There were a screen and I installed the user and admin credentials. - After a system update unfortunately I have the same black-screen after boot-prompt. The device is avaliable via ssh. So if we have to do debuging there is no chance without HDMI... So I think it is essential to solve this issue... @Igor Unfortunately the problem has to get solved, even when just one person is doing the HDMI-stuff. But if we don't get it resloved I see no debug-possiblities anymore if there is no ssh! - So w
  10. the kernel I'm using now is 6.12.35, the kernel that failed was 6.12.20 until 6.12.30 the lcd didn't work, but after a few updates to 6.12.30 it worked again.
  11. I believe you are likely going to struggle with that approach. But I think before you ask us maybe you should say first why you chose the platform that you are considering. If it is "that is the cheapest I could find" then you might have heard about the saying "buy cheap, buy twice".
  12. Oh right, that is fairly old. My USB sticks are not in exFat format which may explain why I have not encoutered such issues. I will have to try re-formatting one as exFat to see if encounter the same kind of issue. That said after a bit of digging, it could be related to this? https://www.cvedetails.com/cve/CVE-2025-22036/
  13. That is a wise thing to do and might be a good default for armbian to adopt.
  14. Hi All, I stumbled on this group after finding Rocket Streaming Audio Server that is either Windows or Linux. My application desire is to use a cheap Android TV box and connect a USB audio input device, and stream it live to a weblink. So, being completely new to this group (not new to AndroidTV boxes), would Armbian running on a cheap TV box support a USB on-the-go audio device? Or any reason it would or wouldn't? Then, next, I haven't read every piece of info on how to convert the boxes, but I read some general info on other sites. Is the mod terribly difficult? Do they all require physical mods? THANK YOU!
  15. OK, can you do the following for me, please, to be sure this is properly fixed? Kindly share the console output for me to have a look at. sudo apt reinstall wireless-regdb dpkg -S /lib/firmware/regulatory.db* Then reboot and see if your problem remains fixed. For now, I suggest you keep the wireless-regdb-2025.02.20.tar.xz file around on the NanoPi in case you need it again.
  16. This is nothing new, its Windows related issue. Probably had something with the drivers. But ultimately I just use a older windows version, I had a machine running a Windows 10 1809 LTSC and for some reason it works there. One thing that also works is using a ubuntu live CD and using the upgrade_tool for rockchip.
  17. Collabora is proud to sponsor this year's annual Debian conference, taking place in Brest, France. Join us as we showcase the latest with Apertis, discuss Debian running on mobile devices, and more. View the full article
  18. Thank you c0rnelius, this was the solution ! Now the flashdrive is listed again Regards Bernd
  19. Same problem: Bus 001 Device 004: ID 14b0:0206 StarTech.com Ltd. 008-2DR166 I've blocked kernel updates via /etc/apt/preferences: Package: base-files Pin: version * Pin-Priority: -1 Package: armbian-bsp-cli-odroidhc4-current Pin: version * Pin-Priority: -1 Package: armbian-firmware Pin: version * Pin-Priority: -1 Package: linux-dtb-current-meson64 Pin: version * Pin-Priority: -1 Package: linux-image-current-meson64 Pin: version * Pin-Priority: -1 Package: linux-u-boot-odroidhc4-current Pin: version * Pin-Priority: -1
  20. Ugoos AM9 DTB extracted from stock firmware,if it helps someone. AM9dtb.zip
  21. Hi,anyone intrested in porting armbian linux to Ugoos AM9 s905x5(64bit) I can provide necessary files from root partitions,device tree and stuff like that. Any help is appreciated 😊
  22. Used HW and SW: Odroid N2+ 4GB with 32 GB eMMC Sandisk 32 GB SD card SW: Armbian_25.5.1_Odroidn2_bookworm_current_6.12.28_minimal.img If I write the image to the SD card (using Balena Etcher), the system boots up and works fine. If I write the image in the same way to the eMMC using an adapter (with Balena Etcher), the system does not boot – only the red LED stays on. Booting via SD card with system and boot files transferred to eMMC using armbian-install also doesn't work. The system fails to boot again. The switch on the N2+ is in the correct position. The eMMC module is functional – if I write CoreELEC or Android images to it, everything works and the system boots correctly. Similar experiences have been described on the forum in the past. Is there any up-to-date procedure to resolve this? Thank you for all the advice and help.
  23. @laibschThe nano pi neo air uses the Ampak AP6212. Here are the modules loaded. lsmod | grep brcmfmac brcmfmac_wcc 12288 0 brcmfmac 192512 1 brcmfmac_wcc brcmutil 12288 1 brcmfmac cfg80211 618496 1 brcmfmac I didn't see a change in this output before/after I installed the patch fix above. dpkg -l wireless-regdb Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name Version Architecture Description +++-==============-============-============-====================================== ii wireless-regdb 2022.06.06-1 all wireless regulatory database for Linux
