  2. Yes, I opened it and it really does have the Amlogic chipset. However, it is still not booting from the USB stick. Do you have any recommendations? I’ve been stuck on this for a week and I’m quite new to this area.
  4. Had to debootstrap trixie because depmod version mismatch. Wifi 2.4 + 5 GHz + BT headphones, keyboards all work. USB is still stuck in plain charge, no micro SD. According to Gemini 3.1 Pro which I have been using, Imagination Technologies (PowerVR) BXM-4-64 MC1 would need 6.12.x kernel or newer which I have not been able to boot yet. This actually feels a bit faster than the Teclast Android even though without accel youtubes playback is quite slow. Battery life probably 5+ hours. aliexpress.com/item/1005009649297050.html keyboard + touchpad I have is a bit shady miss-clicks a bit once in a while. Might have to AI haxor some software filter to get it behave a bit better but that should not be that big of a deal. I have kind of already made up my mind, this ain't going to boot Android anymore, have to see if I grab another one at some point.
  5. I have a OpiZ2w with Armbian. I flashed a SD-card, and then I copy the system and boot to a usb- hdd (sda) and the system boot to sda Want hdd because It write much data and USB 2 don't take mush more speed. But I get a warning about a file-error or something so I run fsck on sda(hdd) was a systemdisk, but run read-only, but anyway it does not boot any more I think I can take the usb-hdd and run fsck from another computer? I have one system with Ubuntu on a Intel 6 gen, and Raspberry pi 500 and 5. The Pi-machine have raspberry-pi OS and the other Ubuntu 24.04.Does the machin or system have any singificans? Or is there another fix to fix so the /boot can find sda?
  6. @jameshartonyou can track this PR: https://github.com/armbian/build/pull/9773
  7. It's booted a bit further but I've just got a kernel panic on cpu5 DDR Version 1.25 20210517 In channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 928MHZ channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 928 MHz, current 856MHz OUT U-Boot SPL 2022.07_armbian-2022.07-Se092-P3fcd-H28b4-V0d63-Bbf55-R448a (Dec 16 2025 - 03:12:11 +0000) Trying to boot from MMC1 NOTICE: BL31: v2.13.0(release):armbian NOTICE: BL31: Built : 04:23:02, Nov 24 2025 INFO: GICv3 with legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: Maximum SPI INTID supported: 287 INFO: plat_rockchip_pmu_init(1624): pd status 3e INFO: BL31: Initializing runtime services INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2022.07_armbian-2022.07-Se092-P3fcd-H28b4-V0d63-Bbf55-R448a (Dec 16 2025 - 03:12:11 +0000) SoC: Rockchip rk3399 Reset cause: POR DRAM: 3.9 GiB PMIC: RK808 Core: 339 devices, 31 uclasses, devicetree: separate SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB MMC: mmc@fe320000: 1, mmc@fe330000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Model: Helios64 Revision: 1.2 - 4GB non ECC Net: dw_dm_mdio_init: mdio node is missing, registering legacy mdio busNo ethernet found. scanning bus for devices... Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3906 bytes read in 5 ms (762.7 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 299 bytes read in 4 ms (72.3 KiB/s) 24731811 bytes read in 1050 ms (22.5 MiB/s) 39770624 bytes read in 1684 ms (22.5 MiB/s) 90994 bytes read in 20 ms (4.3 MiB/s) 725 bytes read in 6 ms (117.2 KiB/s) Applying user provided DT overlay rockchip-rk3399-op1-opp.dtbo 780 bytes read in 5 ms (152.3 KiB/s) Applying user provided DT overlay rockchip-rk3399-l2-cache.dtbo 2825 bytes read in 41 ms (66.4 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Moving Image from 0x2080000 to 0x2200000, end=48b0000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 24731747 Bytes = 23.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f4747000, end f5edd063 ... OK Loading Device Tree to 00000000f46c8000, end 00000000f4746fff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.18.10-current-rockchip64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #2 SMP PREEMPT Wed Feb 11 12:42:01 UTC 2026 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Kobol Helios64 [ 0.000000] printk: debug: ignoring loglevel setting. [ 0.000000] efi: UEFI not found. [ 0.000000] OF: reserved mem: Reserved memory: No reserved-memory node in the DT [ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] NODE_DATA(0) allocated [mem 0xf77c6380-0xf77c8b3f] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [ 0.000000] cma: Reserved 128 MiB at 0x00000000e8800000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.5 [ 0.000000] percpu: Embedded 34 pages/cpu s100376 r8192 d30696 u139264 [ 0.000000] pcpu-alloc: s100376 r8192 d30696 u139264 alloc=34*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GICv3 CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: root=UUID=0a68fe65-7fd3-47ab-b68f-ef2fddb464c9 rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 ubootpart=7a8c3cb1-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u earlyprintk ignore_loglevel cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory [ 0.000000] Unknown kernel command line parameters "earlyprintk splash=verbose ubootpart=7a8c3cb1-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space. [ 0.000000] printk: log buffer data + meta data: 262144 + 917504 = 1179648 bytes [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 3MB [ 0.000000] software IO TLB: area num 8. [ 0.000000] software IO TLB: mapped [mem 0x00000000f6ce3000-0x00000000f70e3000] (4MB) [ 0.000000] Fallback order for Node 0: 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1015296 [ 0.000000] Policy zone: DMA [ 0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ 0.000000] ftrace: allocating 55125 entries in 216 pages [ 0.000000] ftrace: allocated 216 pages with 4 groups [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Rude variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 [ 0.000000] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=6. [ 0.000000] RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=6. [ 0.000000] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=6. [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GIC: enabling workaround for GICv3: Insecure RK3399 integration [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: Broken GIC integration, security disabled [ 0.000000] GICv3: GICD_CTLR.DS=1, SCR_EL3.FIQ=0 [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000 [ 0.000000] ITS [mem 0xfee20000-0xfee3ffff] [ 0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @600000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000000680000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000000690000 [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000002] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001597] Console: colour dummy device 80x25 [ 0.001623] printk: legacy console [tty1] enabled [ 0.003196] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.003250] pid_max: default: 32768 minimum: 301 [ 0.003441] LSM: initializing lsm=capability,yama,apparmor [ 0.003564] Yama: becoming mindful. [ 0.004065] AppArmor: AppArmor initialized [ 0.004245] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.004307] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.009116] rcu: Hierarchical SRCU implementation. [ 0.009170] rcu: Max phase no-delay instances is 1000. [ 0.009687] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level [ 0.011405] EFI services will not be available. [ 0.012079] smp: Bringing up secondary CPUs ... [ 0.013167] Detected VIPT I-cache on CPU1 [ 0.013474] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000 [ 0.013501] GICv3: CPU1: using allocated LPI pending table @0x00000000006a0000 [ 0.013576] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.014810] Detected VIPT I-cache on CPU2 [ 0.015084] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000 [ 0.015107] GICv3: CPU2: using allocated LPI pending table @0x00000000006b0000 [ 0.015159] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.016428] Detected VIPT I-cache on CPU3 [ 0.016708] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.016731] GICv3: CPU3: using allocated LPI pending table @0x00000000006c0000 [ 0.016783] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.017959] CPU features: detected: Spectre-v2 [ 0.017975] CPU features: detected: Spectre-v3a [ 0.017988] CPU features: detected: Spectre-BHB [ 0.017998] CPU features: detected: ARM erratum 1742098 [ 0.018008] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.018016] Detected PIPT I-cache on CPU4 [ 0.018263] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000 [ 0.018283] GICv3: CPU4: using allocated LPI pending table @0x00000000006d0000 [ 0.018332] CPU4: Booted secondary processor 0x0000000100 [0x410fd082] [ 0.019463] Detected PIPT I-cache on CPU5 [ 0.019695] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000 [ 0.019714] GICv3: CPU5: using allocated LPI pending table @0x00000000006e0000 [ 0.019754] CPU5: Booted secondary processor 0x0000000101 [0x410fd082] [ [ 2.387408] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! [ 2.394288] pca953x 2-0020: using no AI [ 2.402892] rk808-regulator rk808-regulator.2.auto: max buck steps per change: 4 [ 2.409232] vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV [ 2.427666] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges: [ 2.428440] rockchip-pcie f8000000.pcie: MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000 [ 2.429237] rockchip-pcie f8000000.pcie: IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000 [ 2.430604] rockchip-pcie f8000000.pcie: no bus scan delay, default to 0 ms [ 2.488396] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 2.628879] usb 1-1: New USB device found, idVendor=2109, idProduct=2815, bcdDevice= 7.04 [ 2.629647] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.630293] usb 1-1: Product: USB2.0 Hub [ 2.630755] usb 1-1: Manufacturer: VIA Labs, Inc. [ 2.640368] rockchip-pcie f8000000.pcie: wait 0 ms (from device tree) before bus scan [ 2.641911] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00 [ 2.642522] pci_bus 0000:00: root bus resource [bus 00-1f] [ 2.643026] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff] [ 2.643651] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff]) [ 2.644635] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400 PCIe Root Port [ 2.645329] pci 0000:00:00.0: PCI bridge to [bus 00] [ 2.645794] pci 0000:00:00.0: bridge window [mem 0x00000000-0x000fffff] [ 2.646492] pci 0000:00:00.0: supports D1 [ 2.646864] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 2.653826] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.704782] SError Interrupt on CPU5, code 0x00000000bf000002 -- SError [ 2.704804] CPU: 5 UID: 0 PID: 55 Comm: kworker/u26:1 Tainted: G M 6.18.10-current-rockchip64 #2 PREEMPT [ 2.704822] Tainted: [M]=MACHINE_CHECK [ 2.704826] Hardware name: Kobol Helios64 (DT) [ 2.704833] Workqueue: events_unbound deferred_probe_work_func [ 2.704859] pstate: 600000c5 (nZCv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 2.704871] pc : rockchip_pcie_rd_conf+0x184/0x290 [ 2.704885] lr : rockchip_pcie_rd_conf+0x178/0x290 [ 2.704894] sp : ffff800083213810 [ 2.704899] x29: ffff800083213810 x28: ffff8000824f3748 x27: 0000000000000000 [ 2.704915] x26: 0000000000000001 x25: 0000000000000000 x24: ffff800082677f70 [ 2.704930] x23: 0000000000000000 x22: ffff8000832138e4 x21: ffff800083213844 [ 2.704945] x20: 0000000000000000 x19: 0000000000000004 x18: 00000000ffffffff [ 2.704959] x17: 6572202c295d3030 x16: 2d3030207375625b x15: ffff8000832136b0 [ 2.704973] x14: ffff00000ba5ba1c x13: ffff00000ba5b290 x12: dead000000000040 [ 2.704986] x11: ffffff800000007c x10: 00000f80007fffff x9 : ffff8000808c0c48 [ 2.705000] x8 : 000000003d4d554e x7 : ffff00000ba6db80 x6 : ffff00000ba6e800 [ 2.705014] x5 : ffff00000ba6f000 x4 : ffff800087000000 x3 : 0000000000c00008 [ 2.705027] x2 : 000000000080000a x1 : ffff800087c00008 x0 : ffff800087c0000c [ 2.705043] Kernel panic - not syncing: Asynchronous SError Interrupt [ 2.705050] CPU: 5 UID: 0 PID: 55 Comm: kworker/u26:1 Tainted: G M 6.18.10-current-rockchip64 #2 PREEMPT [ 2.705064] Tainted: [M]=MACHINE_CHECK [ 2.705068] Hardware name: Kobol Helios64 (DT) [ 2.705074] Workqueue: events_unbound deferred_probe_work_func [ 2.705090] Call trace: [ 2.705095] show_stack+0x20/0x38 (C) [ 2.705115] dump_stack_lvl+0x34/0x90 [ 2.705139] dump_stack+0x18/0x28 [ 2.705153] vpanic+0x328/0x378 [ 2.705165] panic+0x68/0x70 [ 2.705175] nmi_panic+0x74/0x80 [ 2.705186] arm64_serror_panic+0x78/0x90 [ 2.705198] do_serror+0x44/0x80 [ 2.705209] el1h_64_error_handler+0x34/0x50 [ 2.705227] el1h_64_error+0x6c/0x70 [ 2.705238] rockchip_pcie_rd_conf+0x184/0x290 (P) [ 2.705251] pci_bus_read_config_dword+0x88/0xf8 [ 2.705262] pci_bus_generic_read_dev_vendor_id+0x38/0x1a0 [ 2.705277] pci_scan_single_device+0xb4/0x120 [ 2.705289] pci_scan_slot+0x74/0x218 [ 2.705301] pci_scan_child_bus_extend+0x50/0x2e0 [ 2.705314] pci_scan_bridge_extend+0x2c4/0x608 [ 2.705326] pci_scan_child_bus_extend+0x1c4/0x2e0 [ 2.705338] pci_scan_root_bus_bridge+0x6c/0xe8 [ 2.705351] pci_host_probe+0x38/0x118 [ 2.705364] rockchip_pcie_probe+0x3f0/0x510 [ 2.705373] platform_probe+0x64/0xa8 [ 2.705390] really_probe+0xc8/0x3a0 [ 2.705402] __driver_probe_device+0x84/0x170 [ 2.705415] driver_probe_device+0x44/0x120 [ 2.705427] __device_attach_driver+0xc4/0x168 [ 2.705440] bus_for_each_drv+0x90/0xf8 [ 2.705451] __device_attach+0xa8/0x1c8 [ 2.705463] device_initial_probe+0x1c/0x30 [ 2.705476] bus_probe_device+0xb4/0xc0 [ 2.705487] deferred_probe_work_func+0xa4/0x100 [ 2.705500] process_one_work+0x174/0x3e8 [ 2.705516] worker_thread+0x2dc/0x3f8 [ 2.705531] kthread+0x14c/0x208 [ 2.705546] ret_from_fork+0x10/0x20 [ 2.705563] SMP: stopping secondary CPUs [ 2.705778] Kernel Offset: disabled [ 2.705782] CPU features: 0x080000,04105800,40004001,0400421b [ 2.705792] Memory Limit: none [ 2.733695] ---[ end Kernel panic - not syncing: Asynchronous SError Interrupt ]---
  8. Current build hangs whilst booting , any ideas anyone ? DDR Version 1.25 20210517 In soft reset SRX channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 928MHZ channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 928 MHz, current 856MHz OUT U-Boot SPL 2022.07_armbian-2022.07-Se092-P3fcd-H28b4-V0d63-Bbf55-R448a (Dec 16 2025 - 03:12:11 +0000) Trying to boot from MMC1 mmc_load_image_raw_sector: mmc block read error Trying to boot from SPI Trying to boot from MMC1 NOTICE: BL31: v2.13.0(release):armbian NOTICE: BL31: Built : 04:23:02, Nov 24 2025 INFO: GICv3 with legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: Maximum SPI INTID supported: 287 INFO: plat_rockchip_pmu_init(1624): pd status 3e INFO: BL31: Initializing runtime services INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2022.07_armbian-2022.07-Se092-P3fcd-H28b4-V0d63-Bbf55-R448a (Dec 16 2025 - 03:12:11 +0000) SoC: Rockchip rk3399 Reset cause: RST DRAM: 3.9 GiB PMIC: RK808 Core: 339 devices, 31 uclasses, devicetree: separate SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB MMC: mmc@fe320000: 1, mmc@fe330000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Model: Helios64 Revision: 1.2 - 4GB non ECC Net: dw_dm_mdio_init: mdio node is missing, registering legacy mdio busNo ethernet found. scanning bus for devices... Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3906 bytes read in 5 ms (762.7 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 299 bytes read in 5 ms (57.6 KiB/s) 24731811 bytes read in 1050 ms (22.5 MiB/s) 39770624 bytes read in 1683 ms (22.5 MiB/s) 90994 bytes read in 20 ms (4.3 MiB/s) 725 bytes read in 6 ms (117.2 KiB/s) Applying user provided DT overlay rockchip-rk3399-op1-opp.dtbo 780 bytes read in 5 ms (152.3 KiB/s) Applying user provided DT overlay rockchip-rk3399-l2-cache.dtbo 2825 bytes read in 41 ms (66.4 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Moving Image from 0x2080000 to 0x2200000, end=48b0000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 24731747 Bytes = 23.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f4747000, end f5edd063 ... OK Loading Device Tree to 00000000f46c8000, end 00000000f4746fff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.18.10-current-rockchip64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #2 SMP PREEMPT Wed Feb 11 12:42:01 UTC 2026 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Kobol Helios64 [ 0.000000] printk: debug: ignoring loglevel setting. [ 0.000000] efi: UEFI not found. [ 0.000000] OF: reserved mem: Reserved memory: No reserved-memory node in the DT [ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] NODE_DATA(0) allocated [mem 0xf77c6380-0xf77c8b3f] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [ 0.000000] cma: Reserved 128 MiB at 0x00000000e8800000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.5 [ 0.000000] percpu: Embedded 34 pages/cpu s100376 r8192 d30696 u139264 [ 0.000000] pcpu-alloc: s100376 r8192 d30696 u139264 alloc=34*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GICv3 CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: root=UUID=0a68fe65-7fd3-47ab-b68f-ef2fddb464c9 rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 ubootpart=7a8c3cb1-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u earlyprintk ignore_loglevel cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory [ 0.000000] Unknown kernel command line parameters "earlyprintk splash=verbose ubootpart=7a8c3cb1-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space. [ 0.000000] printk: log buffer data + meta data: 262144 + 917504 = 1179648 bytes [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 3MB [ 0.000000] software IO TLB: area num 8. [ 0.000000] software IO TLB: mapped [mem 0x00000000f6ce3000-0x00000000f70e3000] (4MB) [ 0.000000] Fallback order for Node 0: 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1015296 [ 0.000000] Policy zone: DMA [ 0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ 0.000000] ftrace: allocating 55125 entries in 216 pages [ 0.000000] ftrace: allocated 216 pages with 4 groups [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Rude variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 [ 0.000000] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=6. [ 0.000000] RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=6. [ 0.000000] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=6. [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GIC: enabling workaround for GICv3: Insecure RK3399 integration [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: Broken GIC integration, security disabled [ 0.000000] GICv3: GICD_CTLR.DS=1, SCR_EL3.FIQ=0 [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000 [ 0.000000] ITS [mem 0xfee20000-0xfee3ffff] [ 0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @600000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000000680000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000000690000 [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001626] Console: colour dummy device 80x25 [ 0.001652] printk: legacy console [tty1] enabled [ 0.003229] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.003282] pid_max: default: 32768 minimum: 301 [ 0.003476] LSM: initializing lsm=capability,yama,apparmor [ 0.003600] Yama: becoming mindful. [ 0.004097] AppArmor: AppArmor initialized [ 0.004276] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.004337] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.009162] rcu: Hierarchical SRCU implementation. [ 0.009217] rcu: Max phase no-delay instances is 1000. [ 0.009735] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level [ 0.011454] EFI services will not be available. [ 0.012131] smp: Bringing up secondary CPUs ... [ 0.013222] Detected VIPT I-cache on CPU1 [ 0.013531] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000 [ 0.013558] GICv3: CPU1: using allocated LPI pending table @0x00000000006a0000 [ 0.013631] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.014865] Detected VIPT I-cache on CPU2 [ 0.015141] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000 [ 0.015164] GICv3: CPU2: using allocated LPI pending table @0x00000000006b0000 [ 0.015216] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.016480] Detected VIPT I-cache on CPU3 [ 0.016759] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.016782] GICv3: CPU3: using allocated LPI pending table @0x00000000006c0000 [ 0.016833] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.018025] CPU features: detected: Spectre-v2 [ 0.018042] CPU features: detected: Spectre-v3a [ 0.018054] CPU features: detected: Spectre-BHB [ 0.018065] CPU features: detected: ARM erratum 1742098 [ 0.018075] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.018083] Detected PIPT I-cache on CPU4 [ 0.018332] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000 [ 0.018352] GICv3: CPU4: using allocated LPI pending table @0x00000000006d0000 [ 0.018400] CPU4: Booted secondary processor 0x0000000100 [0x410fd082] [ 0.019532] Detected PIPT I-cache on CPU5 [ 0.019765] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000 [ 0.019785] GICv3: CPU5: using allocated LPI pending table @0x00000000006e0000 [ 0.019825] CPU5: Booted secondary processor 0x0000000101 [0x410fd082] [
  9. Thanks for doing this @ebin-dev. Any tips on how to load the alternate dtb if the hardware is so unstable that it won't even boot to the shell; I'm using 26.2.1 / 6.18.15 ?
  10. Just a small note here - I recently added Bianbu desktop (can be installed from armbian-config), where acceleration works on K1 based Musebook (legacy kernel). This should be possible to adopt to any other K1 board. Youtube video works fine in Chromium ...
  11. This will be addressed shortly. I will update this thread when the fix is merged
  12. "mmc1(part 0) is current device". Is that really a usb? Never seen a usb be named that, sound more like an internal storage.
  13. The MLIR pipeline, lowering from TOSA to TIM-VX C++, is now available here: https://github.com/MaverickLong/MLIR-TIM-VX It's *kinda* working, currently only supports conv2d (image processing) CNN models or simple MLPs, and it's far from mature, so expect a lot of errors. With this (plus the unified driver) we are heading towards running any ML model on the NPU...
  14. Yesterday
  15. At Radxa's suggestion I grabbed their latest image `rock-5t_bookworm_kde_r5.output_512.img` which contains `DDR b8ce94f14b cym 25/09/26-15:48.05,fwver: v1.20` and `stress-ng` now passes without any errors.
  16. Does the box have an sd card slot and have you tried booting from that? (That is the common method). Also are you sure the box has an s905x3? Have you opened the box and inspected the chip? You might want to try all the uboot binaries just in case.
  17. Thanks. URL is https://paste.armbian.com/liqeyelovi
  18. I am trying to boot from a USB stick, but it shows the error you can see in the screenshot. I am using the update button on the back of the TV box. It does start the boot process from the USB, but according to the error message it seems unable to actually read the drive. I have been stuck on this issue for several days now.
  19. The s905x3 one. Also, how are you booting this? You say it doesn't recognize usb, so what are you using to boot Armbian?
  20. Ubuntu 26.04 with or without KDE Plasma with working drivers for WiFi, GPU, Nic, Bluetooth. Enjoy! https://github.com/mack42/OrangePi5Pro Note: There are Minimal and Graphical images available. It also supports installing to the NVME.
  21. Thank you very much for your responses, it totally make sense. I will try to build it myself, tho I have never done that, and my knowledge is very limited. I'd love to help one day, but this really is beyond what I can offer, for now.
  22. Thanks for clarifying. And which would be the correct version of u‑boot for my BTV OTT BOX (model B11, Amlogic S905X3)? I admit I’m a bit lost at this point.
  23. The screen shot you have shows you are using the Ugoos X3 version of uboot. That will not work as that is specific to that box.
  24. moved post to correct forum
  25. Friends, as shown in the image, I am trying to install a Linux system on this BTV: OTT BOX, model B11 with an Amlogic S905X3 CPU. However, I am not succeeding because it cannot read the USB drive. I have already tried changing the .ext, attempted to burn the image using Rufus, Balena, and nothing worked. I am using a Multilaser USB drive which I believe is 2.0. At the moment I don’t have another USB drive or memory card to test. Any suggestions?
  26. Well if you want to live on the edge, then use code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } egde as branch instead of code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } current
