I forgot to specify that I tried different combinations in the config. With any of these configurations in this tool after each restart the Wi-Fi module is not recognized. All the time is written - unknown
@Benedito Portela you are a long term user on this forum to don't know that debugging is a MUST !!!!!!! And you have such WONDERFULL uart pads, even with names ( tx rx gnd) ... why don't you use them and let all of us know what going in your box ??😇 😉
Hello @alg_42 You have only 1 GB of space in /tmp. This is tmpfs, so it uses your RAM. It is not enough to unpack your backup into. You can increase the size but the Pine64 either has only 512MB or 1GB of RAM, so that is not a good idea. I suggest you temporarily deactivate the /tmp mount instead, reboot, complete your backup and then reactivate the /tmp mount and reboot again. Armbian puts /tmp on tmpfs so that the frequent writes to it do not wear out your flash so it is important you reactivated it later on and don't leave it on your main partition indefinitely. Can you share the output of "grep tmp /etc/fstab" with us?
I'm, using one of those CH340 based usb-uart dongles https://www.aliexpress.com/w/wholesale-usb-uart-ch340.html but that normally most usb-uart dongles would work https://www.aliexpress.com/w/wholesale-usb-uart.html just make sure to check that it has / uses 3.3V io levels. Not 5V io levels as that may damage the processor (cpu / soc) for the pins connection review the user manual http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/service-and-support/Orange-Pi-Zero-3.html it is the 3 pins labelled Debug TTL UART on their board photo http://www.orangepi.org/img/zero3/0627-zero3 (6).png --- off-topic: for these small boards, I've basically stopped running them with an LCD monitor and keyboard as I find it a hassle as I'm using a desktop PC and trying to share the monitor. I mostly use them 'headless' using the usb-uart port. And in fact, after you setup the network appropriately e.g. set a static IP address or install avahi, the usb-uart console is no longer needed for static (fixed) IP address it is covered in the networking guide https://docs.armbian.com/User-Guide_Networking/ for avahi (MDNS) > apt install avahi-daemon avahi-utils edit /etc/avahi/avahi-daemon.conf [publish] publish-workstation=yes you can find the board on the ethernet over MDNS e.g. https://github.com/hrzlgnm/mdns-browser and you can ssh into the board over the network, e.g. using putty https://www.putty.org/
@RaptorSDS, it is a eMCP (kmqn10006m-b318), in others board, that use same type chip, working no problems, in this board, do not working nothing, it is lock, red led turn on! Before use the multitools, the board do not boot from my system in sdcard, it is not a good indicator and even so i did the burning image in board, It was stupid of me! I hope find the maskrom pin, it is a new board, do not believe that i lost it! Thank by attention!
Did a lspci and it only returns 1 NIC device on the pci bus...
There is no moonlight-qt packaged in this ppa for noble, you can build from source: https://salsa.debian.org/amazingfate/moonlight-qt -
Is there any trick to make use of the integrated fan on Radxa 25W PoE Hat? I'm using 4GB Radxa Rock 5C Lite Armbian_25.5.1_Rock-5c_bookworm_vendor_6.1.115_minimal Some guides mention that one should enable an overlay. I didn't find any relevant overlays in armbian-config. In the Radxa repo I found rock-5a-radxa-25w-poe.dts which specifies that it's also compatible with Rock 5C. I've compiled it and enabled it, but by default the fan is not spinning (on high temps) and I'm not sure how to investigate that.
SteeMan replied to tasknodes's topic in Amlogic CPU Boxes
What build of armbian are you using? Please provide the exact steps you are having problems with, your description of the problem is not clear. -
Connect to the orange pi's serial port with a usb-serial from your laptop. Make sure you connect the TX with the RX, and viceversa. The speed is 115200. You will see booting messages, before the login prompt. If nothing works, re-write the img to the microSD.
Hello i have an Tanix tx3 mini,with s905w processor. After a boot fail i can restore armbian, and i must to flash again android, and the box Is work again. Now i can't flash armbian because the box don't boot from microSD, any help?
@Benedito Portela be aware this looks like a eMCP (emmc and RAM in one chip) , do you try running from a usb drive
please tell us do have try setup LED-config in rk322x-config tool
How do I check the logs if I'm not able to login? This is where it's stuck at.
Thank you! I will try it tomorrow. What is spi1_cs0_pin and spi1_cs1_pin equal to, in Orange Pi Zero 2W, and in Opiz3? Is it defined in the spi-spidev dtso, or in the main opiz3/opiz2w dts? I need to have it correctly in the main DTS, because the LCD driver doesn't use spidev (and it would conflict). cs0 matches the pin position in raspberry pi: pin 24.... so it would make sense if cs1 is pin 26. Reference. This is the patch that changes the opiz3/2w DTS https://forum.armbian.com/topic/50418-dont-use-kernel-61216-on-sunxi64/page/2/#findComment-216934
Thats the Plan I just wanted to update my fork first in case any problems occured before submitting. Just wanted to check, seeming as I am covering 2 areas (dts patches and drm patches) would you still prefer this to be in a single commit? The original purposing being to add hdmi support for the Pcduino2 and Pcduino3, but evolved due to the drm breakages.
tanod replied to maximumsettings's topic in Orange Pi 5
####### ----------- ##O#O## OS: Armbian 25.5.1 noble aarch64 ####### Host: Orange Pi 5 Plus ########### Kernel: 6.1.115-vendor-rk35xx ############# Uptime: 22 hours, 13 mins ############### Packages: 1704 (dpkg), 5 (snap) ################ Shell: bash 5.2.21 ################# Resolution: 3840x2160 ##################### DE: GNOME 46.0 ##################### WM: Mutter ################# WM Theme: Adwaita Theme: Adwaita [GTK2/3] Icons: Adwaita [GTK2/3] Terminal: x-terminal-emul CPU: (8) @ 1.800GHz Memory: 8987MiB / 15958MiB I did: add-apt-repository ppa:liujianfeng1994/rockchip-multimedia && apt update Игн:1 https://repo.vivaldi.com/stable/deb stable InRelease Изт:2 https://repo.vivaldi.com/stable/deb stable Release [3840 B] Изт:3 https://repo.vivaldi.com/stable/deb stable Release.gpg [833 B] Изт:4 https://packages.microsoft.com/repos/code stable InRelease [3590 B] Поп:5 https://github.armbian.com/configng stable InRelease Поп:6 http://ports.ubuntu.com noble InRelease Поп:8 https://ppa.launchpadcontent.net/liujianfeng1994/rockchip-multimedia/ubuntu noble InRelease Изт:9 http://ports.ubuntu.com noble-security InRelease [126 kB] Изт:10 https://repo.vivaldi.com/stable/deb stable/main arm64 Packages [1942 B] Поп:7 http://distrohub.kyiv.ua/armbian noble InRelease Изт:11 https://repo.vivaldi.com/stable/deb stable/main arm64 Contents (deb) [13,8 kB] Изт:12 https://packages.microsoft.com/repos/code stable/main arm64 Packages [19,4 kB] Изт:13 https://packages.microsoft.com/repos/code stable/main amd64 Packages [19,3 kB] Изт:14 https://packages.microsoft.com/repos/code stable/main armhf Packages [19,5 kB] Изт:15 http://ports.ubuntu.com noble-updates InRelease [126 kB] Изт:16 http://ports.ubuntu.com noble-backports InRelease [126 kB] Изт:17 http://ports.ubuntu.com noble-security arm64 Contents (deb) [90,7 MB] Изт:18 http://ports.ubuntu.com noble-updates/main arm64 Packages [1490 kB] Изт:19 http://ports.ubuntu.com noble-updates arm64 Contents (deb) [95,2 MB] Изт:20 http://ports.ubuntu.com noble-updates/restricted arm64 Packages [1962 kB] Изт:21 http://ports.ubuntu.com noble-updates/universe arm64 Packages [1376 kB] /etc/apt/sources.list.d/liujianfeng1994-ubuntu-rockchip-multimedia-noble.sources:URIs: https://ppa.launchpadcontent.net/liujianfeng1994/rockchip-multimedia/ubuntu/ apt policy moonlight-qt N: Packet moonlight-qt cannot be found @NicoD, @amazingfate can you help? -
Hi there. Maybe I'm doing something wrong, but how do I get WIFi to work on a board with an ESP8089 module? The first message says that this module is supported. Based on the answers from the respected @jock , this module is also supported. Maybe someone will help and give a clear answer or an algorithm for launching. I tried 2 images - the current and Armbian_24.2.5.-trunk_Rk322x-box_jammy_current_6.6.22_minimal.img.xz
In collaboration with Inria, the French Institute for Research in Computer Science and Automation, Tathagata Roy shares the progress made over the past year on the CoccinelleForRust project, co-sponsored by Collabora View the full article
Hi everyone, i bought a MX10 tvbox, to try my system in H313 box, but the box came in is a RK3228A, so i try install my system, that working well in others rk3229 boxes, i did it how normal protocol, boot from multitools card, did it Android image backup and burned my OK image, turner off, and don't working, black screen e red led on! Do not boot from other sdcards and multiools sdcard too! I do not found the Maskrom pin, i believe to be a new board design, if anybody know this board, i do glad by help-me! Thanks!!!
nope, just checked.
This is an awesome effort from you all! I purchased a v3. 1 2gb ddr3 version off ebay for 25usd and tried out the mate graphical image and it worked like a charm. Just some feedback for you all and others like me that read this forum. 996mb ram I think it is as reported by other users also. Vulkan graphics seem to be working, WiFi and usb ports all working out of the box. Bluetooth appears but I didn't try to connect to any devices yet. I even tried the tiny stories 656k ollama llm to see if that would work and its pretty fast with some bad stories haha even the 1b parameter model loaded but it's barely working. I will try llama.c next to try get some. Kind of acceleration from the gpu. Supertuxkart runs very smoothly. I installed on a 32gb SanDisk tf card with no worries flashing using etcher. It's quite a capable little machine. I even managed to compile a game I'm building at the moment for Linux + dos called deadseas which runs rather well. I havnt tried sound or anything yet as I'm direct into an old monitor via hdmi > dvi. So much better than the stock Android that the x96q comes with. Anyway thanks for your efforts!
I've got an Pine64 a that was one of the Kickstarter models. For a couple of years I've been running OctoPrint on it to run my Qidi i-mates 3d printer. Recently I decided to update from jammy to noble, before I did that I made a backup of my OctoPrint settings and files through the OctoPrint GUI in case of problems. I got a really messed inconsistent with all sorts of dependencies errors because the apt dist-upgrade seemed to freeze and after several hours of no movement I rebooted. As expected it was the mess. I spent about an hour on fixing dependencies but decided it just wasn't worth it as the only thing running is OctoPrint. When I went to restore OctoPrint, I got an error message about not enough space. When I did a df -m , I had plenty of space on the main partition, I posted on the OctoPrint forum and it was pointed out that my /tmp was tiny. Would anyone have any ideas of what is going on and what I can do to fix it? Here's the OctoPrint Error: Uploading backup, this can take a while. Please wait... Restoring from backup... Unpacking backup to /tmp/tmpf_d22xwu...Removing temporary unpacked folderError while running restoreTraceback (most recent call last): File "/home/ageoffri/OctoPrint/lib/python3.12/site-packages/octoprint/plugins/backup/__init__.py", line 1243, in _restore_backup zip.extract(member, temp) File "/usr/lib/python3.12/zipfile/__init__.py", line 1726, in extract return self._extract_member(member, path, pwd) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.12/zipfile/__init__.py", line 1802, in _extract_member shutil.copyfileobj(source, target) File "/usr/lib/python3.12/shutil.py", line 204, in copyfileobj fdst_write(buf)OSError: [Errno 28] No space left on device Restore failed! Chec And here's the df -m : Filesystem 1M-blocks Used Available Use% Mounted on tmpfs 198 4 195 2% /run /dev/mmcblk0p1 59861 3078 56137 6% / tmpfs 988 1 988 1% /dev/shm tmpfs 5 0 5 0% /run/lock tmpfs 988 0 988 0% /tmp /dev/zram1 47 3 41 6% /var/log tmpfs 198 1 198 1% /run/user/1000
Im currently trying to implement gpu support, but ive been stuck on the same error since a few days. Heres my armbianmonitor -u output: https://paste.armbian.com/uforekotuw root@radxa-cubie-a5e:~# cat /sys/kernel/debug/pm_genpd/pm_genpd_summary domain status children performance /device runtime status managed by ------------------------------------------------------------------------------ pd1_gpu off-0 0 pd1_pcie off-0 0 pd1_nand off-0 0 pd1_de off-0 0 pd1_vo1 off-0 0 4510000.ethernet suspended 0 SW pd1_vo0 off-0 0 pd1_vi off-0 0 pd1_ve off-0 0 pd_riscv off-0 0 pd_sram off-0 0 pd_npu off-0 0 pd_dsp off-0 0 dmesg | grep -i "gpu\|mali" [ 1.836128] panfrost 1800000.gpu: clock rate = 432000000 [ 1.848131] panfrost 1800000.gpu: gpu soft reset timed out, attempting hard reset [ 1.858262] panfrost 1800000.gpu: gpu hard reset timed out [ 1.858486] panfrost 1800000.gpu: Fatal error during GPU init [ 1.858674] panfrost 1800000.gpu: probe with driver panfrost failed with error -110
You need to check the disk space, apparently you are out of space and the daemon is not logging.
