  2. Hi @tmb Helios64 and Armbian are still very relevant in 2025! Thanks to this amazing community! I used mine with OpenMediaVault until a couple of MOSFETs failed and some drives stopped to spin up. Unfortunately, the original components were quite cheap. Even though I found better replacements, I didn’t want to pay for micro-soldering services, which can be pricey compared to the parts themselves (just a few euros). Instead, I built my own NAS using an Intel N100. It’s now a low-power device running a dozen Docker containers, using Home Assistant image as base. I’m totally in unsupported territory, but it works great! With this setup, OpenMediaVault can go into sleep mode when needed, and so far, it’s been working really well for me.
  3. If you learn yourself a strategy not to wipe existing installation, but dist-upgrade it and also have a flexible backup and restore for yourself, you don't need lists or so as the same set of software keeps being there. I clone installations from 1 computer to the other, so do not use new images. With tasksel you can remove and add Desktop Environments, sudo systemctl set-default <target> to changes from GUI to CLI and vice-versa. Make sure you have a serial console cable working (for CLI and no HDMI/kbd/mouse connected). But you can use 'sudo apt list --installed' on Debian systems. Cloning on x86 is easy, for ARM, you need change bootloader and kernel and some other packages. Until also all ARM computers come with UEFI bootloader/firmware. https://www.debian.org/releases/trixie/release-notes/upgrading.en.html#preparing-apt-sources-files https://digint.ch/btrbk/doc/readme.html https://btrfs.readthedocs.io/en/latest/Send-receive.html
  4. Good afternoon. Thank you for your reply. Unfortunately, I haven't had a positive experience. My apologies for misleading you, but my motherboard originally had a 618 processor. I tried creating an image for the 616 many times until I noticed that my processor was a 618. After several attempts, I was able to create an image for the 618. After receiving an image for the 618 with the panel-mipi-dbi module, I tried connecting a screen with an ili9488 chip. I can say I've taken the first step toward implementing this project. Now I need to get the screen working with the resulting image.
  5. Today
  6. Posting this interesting event, in case someone can see why it worked: Banana Pi M4 zero (H618) gained HDMI audio when upgrading to Linux 6.12.30 https://forum.armbian.com/topic/50773-bpi-m4-zero-hdmi-audio/ But in this thread, there's a report that upgrading to 6.16.8 (from 6.15.4) lost HDMI audio
  7. Can you clarify that you made a custom H618 board ?? (not exactly Orange Pi Zero 3?). If I remember correctly, you had previous success with an ili9341 and the same linux board? You need to compare the DTS that worked for you (with ilitek, ili9341, right?) and the new DTS you are trying to modify (with panel-mpi-dbi, for ili9488). Make sure you haven't changed the GPIO in the DTS, and the connections in the LCD and your Linux board. If the ili9341 was working for you with the H616 armbian configuration, changing to H618 might need changes in the LCD DTS from that change.... to make those SPI pins to be addressed correctly. That previous H616 armbian configuration... what Linux board was it meant for? Change back to the configuration that made your board work with the ili9341.
  8. Now that you can replicate the crash anytime. Right after it crashes: $ dmesg $ journalctl -u lighdtm Also, try another application that will use the LCD continuously, without starting X11: $ mplayer -vo fbdev2:/dev/fb0 videofile.mp4 (use a 320x240 approx video, so it will be smooth without hardware acceleration) If it works, then maybe X11 is the problem, not the LCD driver. I wish more people switched to 100% Wayland in their HDMI monitors and LCDs. I have a method. If you want it too: https://forum.armbian.com/topic/55882-critique-or-improve-my-method-to-get-a-lightweight-labwc-desktop/#comment-227469
  9. Here the workaround to get a "gdm" login screen: root@ password: _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| v25.11.2 for Khadas VIM3 running Armbian Linux 6.12.58-current-meson64 Performance: Load: 25% Uptime: 4 minutes Local users: 3 Memory usage: 8% of 3.68G CPU temp: 38°C Usage of /: 11% of 58G RX today: 920 MiB Tips: Armbian config utility https://tinyurl.com/yc39n6m3 Commands: Configuration : armbian-config Monitoring : htop root@khadas-vim3:~# systemctl --failed UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. Issue #1: No login screen on HDMI: root@khadas-vim3:~# systemctl status gdm.service ● gdm.service - GNOME Display Manager Loaded: loaded (/usr/lib/systemd/system/gdm.service; static) Active: active (running) since Mon 2025-12-15 17:25:25 CET; 4min 28s ago Process: 2684 ExecStartPre=/usr/share/gdm/generate-config (code=exited, status=0/SUCCESS) Main PID: 2699 (gdm3) Tasks: 4 (limit: 4215) Memory: 8.9M (peak: 10.4M) CPU: 414ms CGroup: /system.slice/gdm.service └─2699 /usr/sbin/gdm3 Dec 15 17:27:04 khadas-vim3 gdm3[2699]: Gdm: on_display_added: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed Dec 15 17:27:04 khadas-vim3 gdm3[2699]: Gdm: on_display_removed: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed Dec 15 17:28:40 khadas-vim3 gdm3[2699]: Gdm: GdmDisplay: Session never registered, failing Dec 15 17:28:40 khadas-vim3 gdm3[2699]: Gdm: on_display_added: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed Dec 15 17:28:40 khadas-vim3 gdm3[2699]: Gdm: on_display_removed: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed Dec 15 17:28:40 khadas-vim3 gdm-autologin][3881]: PAM unable to dlopen(pam_gnome_keyring.so): /usr/lib/security/pam_gnome_keyring.so: cannot open shared object file: No > Dec 15 17:28:40 khadas-vim3 gdm-autologin][3881]: PAM adding faulty module: pam_gnome_keyring.so Dec 15 17:28:40 khadas-vim3 gdm-autologin][3881]: pam_unix(gdm-autologin:session): session opened for user amach(uid=1000) by amach(uid=0) Dec 15 17:28:41 khadas-vim3 gdm3[2699]: Gdm: on_display_added: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed Dec 15 17:28:41 khadas-vim3 gdm3[2699]: Gdm: on_display_removed: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed root@khadas-vim3:~# ll /dev/dri/ total 0 drwxr-xr-x 2 root root 140 Dec 15 17:25 by-path crw-rw----+ 1 root video 226, 0 Dec 15 17:25 card0 crw-rw----+ 1 root video 226, 1 Dec 15 17:25 card1 crw-rw----+ 1 root video 226, 2 Dec 15 17:25 card2 crw-rw----+ 1 root render 226, 128 Dec 15 17:25 renderD128 crw-rw----+ 1 root render 226, 129 Dec 15 17:25 renderD129 root@khadas-vim3:~# udevadm info /dev/dri/card0 P: /devices/platform/soc/ff900000.vpu/drm/card0 M: card0 R: 0 U: drm T: drm_minor 😧 c 226:0 N: dri/card0 L: 0 S: dri/by-path/platform-ff900000.vpu-card E: DEVPATH=/devices/platform/soc/ff900000.vpu/drm/card0 E: DEVNAME=/dev/dri/card0 E: DEVTYPE=drm_minor E: MAJOR=226 E: MINOR=0 E: SUBSYSTEM=drm E: USEC_INITIALIZED=2805131 E: ID_PATH=platform-ff900000.vpu E: ID_PATH_TAG=platform-ff900000_vpu E: ID_FOR_SEAT=drm-platform-ff900000_vpu E: DEVLINKS=/dev/dri/by-path/platform-ff900000.vpu-card E: TAGS=:master-of-seat:uaccess:seat: E: CURRENT_TAGS=:master-of-seat:uaccess:seat: root@khadas-vim3:~# udevadm info /dev/dri/card1 P: /devices/platform/soc/ffe40000.gpu/drm/card1 M: card1 R: 1 U: drm T: drm_minor 😧 c 226:1 N: dri/card1 L: 0 S: dri/by-path/platform-ffe40000.gpu-card E: DEVPATH=/devices/platform/soc/ffe40000.gpu/drm/card1 E: DEVNAME=/dev/dri/card1 E: DEVTYPE=drm_minor E: MAJOR=226 E: MINOR=1 E: SUBSYSTEM=drm E: USEC_INITIALIZED=7219633 E: ID_PATH=platform-ffe40000.gpu E: ID_PATH_TAG=platform-ffe40000_gpu E: GDM_NUMBER_OF_GRAPHICS_CARDS=3 E: ID_FOR_SEAT=drm-platform-ffe40000_gpu E: DEVLINKS=/dev/dri/by-path/platform-ffe40000.gpu-card E: TAGS=:seat:master-of-seat:uaccess: E: CURRENT_TAGS=:seat:master-of-seat:uaccess: root@khadas-vim3:~# udevadm info /dev/dri/card2 P: /devices/platform/etnaviv/drm/card2 M: card2 R: 2 U: drm T: drm_minor 😧 c 226:2 N: dri/card2 L: 0 S: dri/by-path/platform-etnaviv-card E: DEVPATH=/devices/platform/etnaviv/drm/card2 E: DEVNAME=/dev/dri/card2 E: DEVTYPE=drm_minor E: MAJOR=226 E: MINOR=2 E: SUBSYSTEM=drm E: USEC_INITIALIZED=7215211 E: ID_PATH=platform-etnaviv E: ID_PATH_TAG=platform-etnaviv E: GDM_NUMBER_OF_GRAPHICS_CARDS=3 E: ID_FOR_SEAT=drm-platform-etnaviv E: DEVLINKS=/dev/dri/by-path/platform-etnaviv-card E: TAGS=:master-of-seat:uaccess:seat: E: CURRENT_TAGS=:master-of-seat:uaccess:seat: WORKAROUND - Issue #1: root@khadas-vim3:/dev/dri# mv card2 card2out root@khadas-vim3:/dev/dri# ll total 0 drwxr-xr-x 2 root root 140 Dec 15 17:33 by-path crw-rw----+ 1 root video 226, 0 Dec 15 17:35 card0 crw-rw----+ 1 root video 226, 1 Dec 15 17:25 card1 crw-rw----+ 1 root video 226, 2 Dec 15 17:25 card2out crw-rw----+ 1 root render 226, 128 Dec 15 17:25 renderD128 crw-rw----+ 1 root render 226, 129 Dec 15 17:25 renderD129 root@khadas-vim3:/dev/dri# systemctl restart gdm.service root@khadas-vim3:/dev/dri# systemctl status gdm.service ● gdm.service - GNOME Display Manager Loaded: loaded (/usr/lib/systemd/system/gdm.service; static) Active: active (running) since Mon 2025-12-15 17:38:56 CET; 7s ago Process: 8999 ExecStartPre=/usr/share/gdm/generate-config (code=exited, status=0/SUCCESS) Main PID: 9006 (gdm3) Tasks: 5 (limit: 4215) Memory: 6.2M (peak: 7.2M) CPU: 172ms CGroup: /system.slice/gdm.service └─9006 /usr/sbin/gdm3 Dec 15 17:38:56 khadas-vim3 systemd[1]: Starting gdm.service - GNOME Display Manager... Dec 15 17:38:56 khadas-vim3 systemd[1]: Started gdm.service - GNOME Display Manager. Dec 15 17:38:56 khadas-vim3 gdm-autologin][9011]: PAM unable to dlopen(pam_gnome_keyring.so): /usr/lib/security/pam_gnome_keyring.so: cannot open shared object file: No > Dec 15 17:38:56 khadas-vim3 gdm-autologin][9011]: PAM adding faulty module: pam_gnome_keyring.so Dec 15 17:38:56 khadas-vim3 gdm-autologin][9011]: pam_unix(gdm-autologin:session): session opened for user amach(uid=1000) by amach(uid=0) Dec 15 17:38:56 khadas-vim3 gdm3[9006]: Gdm: on_display_added: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed Dec 15 17:38:56 khadas-vim3 gdm3[9006]: Gdm: on_display_removed: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed --- Issue #2: Missing Display resolution 3440x1440 for Display Dell U3415W connected to HDMI: root@khadas-vim3:/home/amach# cat xrandr.txt Screen 0: minimum 16 x 16, current 2560 x 1440, maximum 32767 x 32767 HDMI-1 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 800mm x 330mm 2560x1440 59.91*+ 1920x1440 59.90 1600x1200 59.87 1440x1080 59.87 1400x1050 59.86 1280x1024 59.76 1280x960 59.94 1152x864 59.78 1024x768 59.68 800x600 59.86 640x480 59.38 320x240 59.52 1920x1200 59.88 1680x1050 59.85 1440x900 59.89 1280x800 59.81 1152x720 59.75 960x600 59.63 928x580 59.88 800x500 59.50 768x480 59.38 720x480 59.71 640x400 59.20 320x200 58.96 2048x1152 59.90 1920x1080 59.88 1600x900 59.82 1368x768 59.88 1280x720 59.86 1024x576 59.90 864x486 59.45 720x400 59.55 640x350 59.77 root@khadas-vim3:/dev/dri# inxi -Gxx Graphics: Device-1: meson-g12a-vpu driver: meson_drm v: N/A bus-ID: N/A chip-ID: amlogic:ff900000 Device-2: meson-g12a-mali driver: panfrost v: kernel bus-ID: N/A chip-ID: amlogic:ffe40000 Device-3: meson-g12a-dw-hdmi driver: meson_dw_hdmi v: N/A bus-ID: N/A chip-ID: amlogic:ff600000 Display: server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.6 compositor: gnome-shell v: 46.0 driver: X: loaded: modesetting gpu: meson_drm,panfrost,meson_dw_hdmi tty: 170x62 Monitor-1: HDMI-A-1 model: Dell U3415W res: 3440x1440 dpi: 109 diag: 865mm (34.1") API: EGL v: 1.5 platforms: gbm: drv: etnaviv surfaceless: drv: panfrost inactive: wayland,x11 API: OpenGL v: 3.1 compat-v: 2.1 vendor: mesa v: 25.0.7-0ubuntu0.24.04.2 note: console (EGL sourced) renderer: Vivante GC8000 rev 7120, Mali-G52 (Panfrost) Please let me know or test to set the display resolution to 3440x1440 - Thank you
  10. Sorry for taking so long to try this, I decided to solder thicker and shorter wires onto the board to make sure that isn't the issue. Unfortunately it still crashes after a short while but nothing is seen in ssh session: ~# tail -f /var/log/Xorg.0.log [ 34.652] (II) event1 - sunxi-ir: device is a keyboard [ 34.722] (**) sunxi-ir: Applying InputClass "libinput keyboard catchall" [ 34.722] (II) Using input driver 'libinput' for 'sunxi-ir' [ 34.722] (**) sunxi-ir: always reports core events [ 34.722] (**) Option "Device" "/dev/input/event1" [ 34.722] (II) libinput: sunxi-ir: is a virtual subdevice [ 34.722] (**) Option "config_info" "udev:/sys/devices/platform/soc/7040000.ir/rc/rc0/input1/event1" [ 34.722] (II) XINPUT: Adding extended input device "sunxi-ir" (type: KEYBOARD, id 😎 [ 34.722] (**) Option "xkb_model" "pc105" [ 34.722] (**) Option "xkb_layout" "us" I am going to mess with the SPI frequency and see if that makes any difference. ----- edit ----- I actually found out that the desktop only freezes whenever I stop using the mouse for 5 seconds.
  11. BOOTFS_TYPE=fat is part of the aml-s9xx-box.tvb config file and has always been. So I'm not sure what your comment is referring to, but it seems to be off topic for this thread which is about instructions for using the aml-s9xx-box Armbian builds.
  12. Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + wine-10.14-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.14) + WineD3D / Zink (OpenGL) ~30fps@720p (this game is capped at 30fps) NARUTO SHIPPUDEN - Ultimate Ninja STORM 3 Full Burst HD
  13. @Trinom I know this post is really old but I have to chime in on this. The instructions that @Igor gave you says to use Armbian to boot the device with then use the commands given to install Armbian. Raspbian is not Armbian. Just sayin' Just trying to figure out what or where you were reading.
  14. With the following options configured as a built-in module, the issue does not happen anymore on a poweron. CONFIG_TYPEC=y CONFIG_TYPEC_TCPM=y CONFIG_TYPEC_TCPCI=y CONFIG_TYPEC_FUSB302=y CONFIG_PHY_ROCKCHIP_USBDP=y I can create a pull request for the linux-rockchip64-edge.config file. But not sure what the general consensus on the kernel options for Armbian kernels is. Maybe it is also fixable via some code change, but that would be something for a real kernel developer.
  15. After applying these settings, TomeRaider can be run perfectly now, Thank you !
  16. https://github.com/lanefu/fan-control-rock5b-poe
  17. No You can try to set env: export BOX64_PREFER_EMULATED=1
  18. Have you ever met the issue "lack of OpenAl32.dll". I try to run "isaac:rebirth" and come out cannot find "openAl32.dll", I got a copy of openAl32.dll from my windows laptop and put it into $WINEPREIX/windows/system32 or the game's executable file folder, cannot get the right result.
  19. What is happening with the board maintainer in general? I think they have been incommunicado pretty much since the first release and now is the time to do something (especially since the board has been "upgraded" now). One more detail. The filesystem does get expanded to fill the whole SD. Which part of the booting process does this happen at? Is there any way to set journal or dmesg logging to a file while not being able to log in (ie by editing a config file, or maybe crontab but externally?)
  20. You extract and copy the x64/d3d11.dll, x64/dxgi.dll files to the game's executable file folder. So no need to change anything in $WINEPREFIX dir.
  21. Everytime you change you wine version, should the $WINEPREFIX dir such as ~/.wine/driver_c should be deleted and install DVXK dll again?
  22. Wrong serial console set in kernel parameter could be a reason for having not output afterwards, so the suggestion isnt completely off. Though no clue what might be correct here.
  23. No, because as mentioned, we need to wait until the bump to 6.18 is approved and merged. Then the work for more recent AW SoCs can be rebased on top of that.
  24. According to the schematic it seems like pwm is used for that. That would need to be enabled as device tree overlay. https://dl.radxa.com/accessories/25w-poe/radxa_25w_poe_plus_hat_v1.2_schematic.pdf Not sure if there is further/DIY programming necessary to make it work.
  25. This was fixed quite recently:https://github.com/armbian/build/pull/9039 Upgrading uboot package does not automatically rewrite the binaries. It just provides them for manual rewrite. So upgrading this package should not do any harm without actually writing the boot loader.
