  2. @johlnx i try img cant booting, i think X88PRO13 use ddr4 of ram. how to build for rk5328 with ddr3 of ram ? device : h96 max 8k ultra hd .dtb .dts file ⬇️ rk3528-evb2-ddr3-v10.dtb rk3528-evb2-ddr3-v10.dts
  3. Hello everyone, I am trying to install Armbian on my Android TV Box, but unfortunately, I flashed an incorrect firmware. Now the device is hard-bricked: the red and blue LEDs are blinking alternately, there is no HDMI output (black screen), and the physical reset button is not working properly. I already have an SD card loaded with the multitool to install Armbian, but I need to force the SoC into Maskrom Mode first so it can bypass the corrupted eMMC and boot from the SD card. Device Specifications: SoC: Rockchip RK3228A Board ID: T39-V1.0 Storage: eMMC (BGA type) I have attached the front and back photos of my PCB board (IMG-20260607-WA0027.jpg and IMG-20260607-WA0031.jpg) for reference. Could anyone help me identify the exact and safe test points (CLK to GND shorting points) for this specific T39-V1.0 board layout? Thank you so much for your help!
  4. just for reference: the velvet-os image mentioned above is using some old mainline u-boot with patches from warpme minimyth2 from that time - here is how it was built: https://github.com/hexdump0815/u-boot-misc/blob/230127-01/readme.h616 ... the default u-boot of this image is the tx6s one best wishes - hexdump
  5. Yesterday
  6. This week's work centers on kernel and board enablement, CI infrastructure and caching, and user-facing tooling improvements across the imager and configuration utilities. On the kernel and board front, Rockchip edge moved to 7.1 and mainline was bumped to 7.1-rc7, while the Raspberry Pi 4B legacy target was re-enabled after a brief revert of the BCM2711 kernel bumps. New board support landed for BeagleBadge and TMDS64EVM (AM64x) on the TI platform, the Anbernic RG DS RK3568 handheld as CSC, and the Youyeetoo YY3588 received a mainline DTS rework with ES8388 audio routing. Several long-standing fixes were merged, including a meson64 GPIO can_sleep regression breaking 1-Wire, JMicron JMB582/JMB585 32-bit DMA forcing, and QRB2210 U-Boot load address corrections. A substantial CI and caching effort introduces a new git_cdn module providing a GitHub caching git+http proxy, an apt-cacher-ng configng module, and multi-arch Docker images for both. GitHub Actions runners now export per-runner apt, ghcr, ccache, and proxy environments from the NetBox registry, with added retry guards, SSH/rsync timeouts, and workspace ownership reconciliation between jobs. The rootfs builder now routes mmdebstrap through APT_PROXY_ADDR when configured. User-facing changes focus on the Armbian Imager and first-run experience. The imager gained marquee scrolling for long board names, a "Create new profile" shortcut, accurate progress-phase reporting, and surfaced flash write failures in place of blank error screens. The first-login flow now runs automatically on freshly-flashed boards, and armbian-firstrun uses atomic writes for armbianEnv.txt MAC randomization to prevent corruption. #Armbian #EmbeddedLinux #Rockchip #CICD #SBC ChangesAdd images for new board and missing images for existing boards. by @jonaswood01 in armbian/armbian.github.io#329Add module_aptcacherng: apt-cacher-ng caching proxy. by @igorpecovnik in armbian/configng#935add multi-arch git_cdn image build. by @igorpecovnik in armbian/docker-armbian-build#29Add new target boards for uefi arm64/x86 edge branch. by @igorpecovnik in armbian/armbian.github.io#327add usbip support to missing current 6.18.y configs. by @EvilOlaf in armbian/build#9971add usbip to more kernels. by @EvilOlaf in armbian/build#9973arm64: dts: rockchip: yy3588: bind ES8388 codec via es8328 driver. by @SuperKali in armbian/linux-rockchip#499armbian-firstrun: use atomic write for armbianEnv.txt MAC randomization. by @mingzhangqun in armbian/build#9937ata: ahci: force 32-bit DMA for JMicron JMB582/JMB585. by @HeyMeco in armbian/linux-rockchip#504Auto-run first-login on freshly-flashed boards. by @igorpecovnik in armbian/autotests#6ayn-thor: fix fused kernel args in LinuxLoader.cfg cmdline, add rw rootwait. by @eldandaman in armbian/build#9969bcm2711: bump kernels — legacy 6.18, current 7.0, edge 7.1. by @igorpecovnik in armbian/build#9964board: add Anbernic RG DS (RK3568 dual 4" 640x480 handheld) as CSC. by @crackerjacques in armbian/build#9934bootscript: rk35xx: simplify armbianEnv.txt corruption detection. by @mingzhangqun in armbian/build#9953bump mainline to 7.1-rc7. by @EvilOlaf in armbian/build#9950ci: build current apt-cacher-ng image (trixie/3.7.x). by @igorpecovnik in armbian/docker-armbian-build#28ci: cache GitHub runners from NetBox to github-runners.jq. by @igorpecovnik in armbian/armbian.github.io#328docs(git_cdn): add GCDN001 help header/footer markdown. by @igorpecovnik in armbian/configng#939docs: document gitproxy GITHUB_MIRROR and GITPROXY_ADDRESS. by @igorpecovnik in armbian/documentation#925feat(boards): scroll long board names with marquee. by @SuperKali in armbian/imager#146feat(flash): show only the progress phases that will actually run. by @SuperKali in armbian/imager#148feat(profiles): add "Create new profile" shortcut to the flash picker. by @SuperKali in armbian/imager#147Fix auto-firstlogin in CI: ssh-dut 1234 fallback + reconcile trigger. by @igorpecovnik in armbian/autotests#7fix(extensions/lvm): Fix support for non-ext filesystems. by @ojafuenf in armbian/build#9889fix(interactive): parse case alternatives in get_kernel_info_for_branch. by @iav in armbian/build#9798fix(mvebu-6.18): drop SysRq-via-BREAK patch, fixed upstream in 6.18.35. by @iav in armbian/build#9958fix(rockchip64-7.0): drop SysRq-via-BREAK patch, fixed upstream in 7.0.12. by @igorpecovnik in armbian/build#9956fix(rootfs/qemu-static): use direct armhf exec probe instead of broken arch-test gate. by @iav in armbian/build#9820fix(ui): keep marquee text aligned while scrolling. by @SuperKali in armbian/imager#149Fix: EasePi-A2 Boot & Ethernet on Vendor Kernel. by @ifroncy01 in armbian/build#9946gha/chunks: export per-runner apt/ghcr/ccache env from runner registry. by @igorpecovnik in armbian/os#471gha/chunks: export per-runner caches in images job. by @igorpecovnik in armbian/os#472gha: add retry and empty-result guard to NetBox server list step. by @igorpecovnik in armbian/os#469gha: add ssh/rsync timeouts to image upload so dead servers fail fast. by @igorpecovnik in armbian/os#473image/compress-checksum: cap compression threads (default 32). by @igorpecovnik in armbian/build#9949meson64: fix GPIO can_sleep regression that breaks w1-gpio (1-Wire). by @adeepn in armbian/build#9959module_aptcacherng: use current ghcr.io/armbian image. by @igorpecovnik in armbian/configng#937orangepi4pro: Add Orange Pi 4 Pro board photo. by @shkolnik in armbian/armbian.github.io#330qrb2210: fix U-Boot load addresses and root partition for 2GB variant. by @govindsi in armbian/build#9925README: document full image catalog (framework, automation, caching proxies). by @igorpecovnik in armbian/docker-armbian-build#31Revert "bcm2711: bump kernels — legacy 6.18, current 7.0, edge 7.1". by @EvilOlaf in armbian/build#9965rk35: add rk3568 DDR 1056MHz v1.23 and BL31 v1.45. by @crackerjacques in armbian/rkbin#45rockchip: bump edge kernel to 7.1. by @paolosabatino in armbian/build#9955rootfs: route mmdebstrap through APT_PROXY_ADDR when set. by @igorpecovnik in armbian/build#9961rpi4b: re-enable legacy target. by @EvilOlaf in armbian/build#9968rtl8192eu: fix -Wmissing-prototypes for 121 functions. by @iav in armbian/build#9963runner-clean: export per-runner proxy env and route git via git_cdn. by @igorpecovnik in armbian/actions#20runner-clean: export per-runner xz memory cap (IMAGE_XZ_MEMLIMIT). by @igorpecovnik in armbian/actions#22runner-clean: normalize git_proxy to one trailing slash. by @igorpecovnik in armbian/actions#21runner-clean: selectively chown root-owned workspace files before checkout. by @igorpecovnik in armbian/actions#23runner-cleanup: chown workspace after each job via JOB_COMPLETED hook. by @igorpecovnik in armbian/configng#944runner-cleanup: give job-completed hook a .sh extension. by @igorpecovnik in armbian/configng#945runner-cleanup: keep Armbian build images, stop wiping build cache hourly. by @igorpecovnik in armbian/configng#943runners: derive host from github_label custom field. by @igorpecovnik in armbian/armbian.github.io#331runners: make remove work via --api with named params and a range. by @igorpecovnik in armbian/configng#942software: add git_cdn module (GitHub caching git+http proxy). by @igorpecovnik in armbian/configng#938sunxi: patch maint. by @EvilOlaf in armbian/build#9957Surface flash write failures instead of a blank error screen. by @SuperKali in armbian/imager#150ti: configs: boards: Add initial BeagleBadge board support. by @jonaswood01 in armbian/build#9935ti: configs: boards: Add TMDS64EVM (AM64x SoC) board support. by @jonaswood01 in armbian/build#9962uwe5622: fix -Wmissing-prototypes warnings (155 -> 2). by @iav in armbian/build#9970Wifi: enable, connect every board, and record interfaces + IPs in NetBox. by @igorpecovnik in armbian/autotests#9youyeetoo-yy3588: rework DTS for mainline and switch audio to ES8388. by @SuperKali in armbian/build#9960View the full article
  7. This week's work centers on kernel and board enablement, CI infrastructure and caching, and user-facing tooling improvements across the imager and configuration utilities. On the kernel and board front, Rockchip edge moved to 7.1 and mainline was bumped to 7.1-rc7, while the Raspberry Pi 4B legacy target was re-enabled after a brief revert of the BCM2711 kernel bumps. New board support landed for BeagleBadge and TMDS64EVM (AM64x) on the TI platform, the Anbernic RG DS RK3568 handheld as CSC, and the Youyeetoo YY3588 received a mainline DTS rework with ES8388 audio routing. Several long-standing fixes were merged, including a meson64 GPIO can_sleep regression breaking 1-Wire, JMicron JMB582/JMB585 32-bit DMA forcing, and QRB2210 U-Boot load address corrections. A substantial CI and caching effort introduces a new git_cdn module providing a GitHub caching git+http proxy, an apt-cacher-ng configng module, and multi-arch Docker images for both. GitHub Actions runners now export per-runner apt, ghcr, ccache, and proxy environments from the NetBox registry, with added retry guards, SSH/rsync timeouts, and workspace ownership reconciliation between jobs. The rootfs builder now routes mmdebstrap through APT_PROXY_ADDR when configured. User-facing changes focus on the Armbian Imager and first-run experience. The imager gained marquee scrolling for long board names, a "Create new profile" shortcut, accurate progress-phase reporting, and surfaced flash write failures in place of blank error screens. The first-login flow now runs automatically on freshly-flashed boards, and armbian-firstrun uses atomic writes for armbianEnv.txt MAC randomization to prevent corruption. #Armbian #EmbeddedLinux #Rockchip #CICD #SBC ChangesAdd images for new board and missing images for existing boards. by @jonaswood01 in armbian/armbian.github.io#329Add module_aptcacherng: apt-cacher-ng caching proxy. by @igorpecovnik in armbian/configng#935add multi-arch git_cdn image build. by @igorpecovnik in armbian/docker-armbian-build#29Add new target boards for uefi arm64/x86 edge branch. by @igorpecovnik in armbian/armbian.github.io#327add usbip support to missing current 6.18.y configs. by @EvilOlaf in armbian/build#9971add usbip to more kernels. by @EvilOlaf in armbian/build#9973arm64: dts: rockchip: yy3588: bind ES8388 codec via es8328 driver. by @SuperKali in armbian/linux-rockchip#499armbian-firstrun: use atomic write for armbianEnv.txt MAC randomization. by @mingzhangqun in armbian/build#9937ata: ahci: force 32-bit DMA for JMicron JMB582/JMB585. by @HeyMeco in armbian/linux-rockchip#504Auto-run first-login on freshly-flashed boards. by @igorpecovnik in armbian/autotests#6ayn-thor: fix fused kernel args in LinuxLoader.cfg cmdline, add rw rootwait. by @eldandaman in armbian/build#9969bcm2711: bump kernels — legacy 6.18, current 7.0, edge 7.1. by @igorpecovnik in armbian/build#9964board: add Anbernic RG DS (RK3568 dual 4" 640x480 handheld) as CSC. by @crackerjacques in armbian/build#9934bootscript: rk35xx: simplify armbianEnv.txt corruption detection. by @mingzhangqun in armbian/build#9953bump mainline to 7.1-rc7. by @EvilOlaf in armbian/build#9950ci: build current apt-cacher-ng image (trixie/3.7.x). by @igorpecovnik in armbian/docker-armbian-build#28ci: cache GitHub runners from NetBox to github-runners.jq. by @igorpecovnik in armbian/armbian.github.io#328docs(git_cdn): add GCDN001 help header/footer markdown. by @igorpecovnik in armbian/configng#939docs: document gitproxy GITHUB_MIRROR and GITPROXY_ADDRESS. by @igorpecovnik in armbian/documentation#925feat(boards): scroll long board names with marquee. by @SuperKali in armbian/imager#146feat(flash): show only the progress phases that will actually run. by @SuperKali in armbian/imager#148feat(profiles): add "Create new profile" shortcut to the flash picker. by @SuperKali in armbian/imager#147Fix auto-firstlogin in CI: ssh-dut 1234 fallback + reconcile trigger. by @igorpecovnik in armbian/autotests#7fix(extensions/lvm): Fix support for non-ext filesystems. by @ojafuenf in armbian/build#9889fix(interactive): parse case alternatives in get_kernel_info_for_branch. by @iav in armbian/build#9798fix(mvebu-6.18): drop SysRq-via-BREAK patch, fixed upstream in 6.18.35. by @iav in armbian/build#9958fix(rockchip64-7.0): drop SysRq-via-BREAK patch, fixed upstream in 7.0.12. by @igorpecovnik in armbian/build#9956fix(rootfs/qemu-static): use direct armhf exec probe instead of broken arch-test gate. by @iav in armbian/build#9820fix(ui): keep marquee text aligned while scrolling. by @SuperKali in armbian/imager#149Fix: EasePi-A2 Boot & Ethernet on Vendor Kernel. by @ifroncy01 in armbian/build#9946gha/chunks: export per-runner apt/ghcr/ccache env from runner registry. by @igorpecovnik in armbian/os#471gha/chunks: export per-runner caches in images job. by @igorpecovnik in armbian/os#472gha: add retry and empty-result guard to NetBox server list step. by @igorpecovnik in armbian/os#469gha: add ssh/rsync timeouts to image upload so dead servers fail fast. by @igorpecovnik in armbian/os#473image/compress-checksum: cap compression threads (default 32). by @igorpecovnik in armbian/build#9949meson64: fix GPIO can_sleep regression that breaks w1-gpio (1-Wire). by @adeepn in armbian/build#9959module_aptcacherng: use current ghcr.io/armbian image. by @igorpecovnik in armbian/configng#937orangepi4pro: Add Orange Pi 4 Pro board photo. by @shkolnik in armbian/armbian.github.io#330qrb2210: fix U-Boot load addresses and root partition for 2GB variant. by @govindsi in armbian/build#9925README: document full image catalog (framework, automation, caching proxies). by @igorpecovnik in armbian/docker-armbian-build#31Revert "bcm2711: bump kernels — legacy 6.18, current 7.0, edge 7.1". by @EvilOlaf in armbian/build#9965rk35: add rk3568 DDR 1056MHz v1.23 and BL31 v1.45. by @crackerjacques in armbian/rkbin#45rockchip: bump edge kernel to 7.1. by @paolosabatino in armbian/build#9955rootfs: route mmdebstrap through APT_PROXY_ADDR when set. by @igorpecovnik in armbian/build#9961rpi4b: re-enable legacy target. by @EvilOlaf in armbian/build#9968rtl8192eu: fix -Wmissing-prototypes for 121 functions. by @iav in armbian/build#9963runner-clean: export per-runner proxy env and route git via git_cdn. by @igorpecovnik in armbian/actions#20runner-clean: export per-runner xz memory cap (IMAGE_XZ_MEMLIMIT). by @igorpecovnik in armbian/actions#22runner-clean: normalize git_proxy to one trailing slash. by @igorpecovnik in armbian/actions#21runner-clean: selectively chown root-owned workspace files before checkout. by @igorpecovnik in armbian/actions#23runner-cleanup: chown workspace after each job via JOB_COMPLETED hook. by @igorpecovnik in armbian/configng#944runner-cleanup: give job-completed hook a .sh extension. by @igorpecovnik in armbian/configng#945runner-cleanup: keep Armbian build images, stop wiping build cache hourly. by @igorpecovnik in armbian/configng#943runners: derive host from github_label custom field. by @igorpecovnik in armbian/armbian.github.io#331runners: make remove work via --api with named params and a range. by @igorpecovnik in armbian/configng#942software: add git_cdn module (GitHub caching git+http proxy). by @igorpecovnik in armbian/configng#938sunxi: patch maint. by @EvilOlaf in armbian/build#9957Surface flash write failures instead of a blank error screen. by @SuperKali in armbian/imager#150ti: configs: boards: Add initial BeagleBadge board support. by @jonaswood01 in armbian/build#9935ti: configs: boards: Add TMDS64EVM (AM64x SoC) board support. by @jonaswood01 in armbian/build#9962uwe5622: fix -Wmissing-prototypes warnings (155 -> 2). by @iav in armbian/build#9970Wifi: enable, connect every board, and record interfaces + IPs in NetBox. by @igorpecovnik in armbian/autotests#9youyeetoo-yy3588: rework DTS for mainline and switch audio to ES8388. by @SuperKali in armbian/build#9960View the full article
  8. @kimo Can you post your uart data?
  9. I tried but failed because I didn't understand at first, but now I understand part of it, and my TV box is malfunctioning. The problem is that when I plug in the power cord with the adapter, no lights or anything come on, but when I plug in the USB cable near the LAN port, it starts up normally (because I initially followed method 4.2. Full install to NAND / eMMC). Now I've flashed the Android firmware and it's working, but the error is as I described above. So, is the power IC dead or is the problem somewhere else?
  10. Nice work! I saw those messages but couldn't download it Can you tell me how you built it? or could you upload it again to filebin.net if possible.. I need the image too
  11. Last week
  12. I have sent a new pr. basically you do something like this: code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } ./compile.sh BOARD=orangepioneplus BRANCH=edge kernel-config This will spawn a kernel menuconfig where you can modify the kernel config. This menu also takes all necessary dependencies into account. Once everything is done the kernel config file in config/kernel is modified. If you use a tool like vscode this will automatically visualize. If you manually change the kernel config file and want to check if your settings are persistent to rewriting you can use the code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } rewrite-kernel-config command similar to the one above.
  13. Sorry, I dont know how to do this. Either I will need more guidance in how to do it, or we will have live with adding the usbip module options also to the edge configs and keep the fingers crossed future major kernel versions will have a better merge outcome.
  14. hehe, yes. because on every new major kernel version the same stuff occurs: rollover and adjust the (huge) patchset to the new version. Because patches were copied, this resulted in these large line numbers. in any case, kernel rewrite addresses things like unmet dependencies, hence throwing stuff out which would not work this way anyway. to make sure it is persistent, use kernel-config to spawn a menu config and enable the necessary options. The resulting kernel config should persist.
  15. Armbian 26.05.0 Noble KDE-Plasma (Kernel: 7.1.0-rc7-bleedingedge-rockchip64) + PanVk - Mesa 26.2.0-devel (git-a0859b31b0) + Box64 arm64 v0.4.3 e694f2ca8 (https://ryanfortner.github.io/box64-debs/) + wine-11.9-staging-tkg-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/) + DXVK-stripped v2.7.1 ~30fps@1080p Assassin's Creed: Director's Cut Edition
  16. I see. I will check. Furthermore: The usbip config was present but got lost between Armbian 26.2 and 26.5. I see frequent PRs which do "Automatic: kernel config rewrite". How can we make sure these changes get persisted and not lost again? However the automated kernel config rewrite works, also needs to consider usbip. Edit: In concrete, it got removed with PR 9381: https://github.com/armbian/build/pull/9381/changes?mode=single#diff-9a3979f7f80525cd7ddd10a00d15aa3e4156c49357184ef9405432599e85a588 The PR talks about "groundhog day". I guess there is a process behind to "generate" a more than 100k lines PR?
  17. I'd check all "edge" configs for the presence of usbip. at one of those at least a build test should occur
  18. How did you determine which configs to edit? Can I simply send a PR without testing? I guess there is a CI behind which takes care of testing?
  19. Wow, this is great! Thanks for the super fast response. Could this be also enabled in edge builds?
  20. You was right, i entered wrong name in /boot/armbianEnv.txt now it is: verbosity=7 bootlogo=false console=both extraargs=cma=256M overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=... rootfstype=ext4 overlays=orangepi-5-ap6275p usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u But wifi still not working I also recorded successful launch of Joshua-Riek ubuntu Both with dtb files loading log Armbian Working FDT set to 12000000 398 bytes read in 56 ms (6.8 KiB/s) Applying kernel provided DT overlay rockchip-rk3588-orangepi-5-ap6275p.dtbo Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Ubuntu Joshua-Riek Retrieving file: /boot/initrd.img-6.1.0-1025-rockchip 16754764 bytes read in 1362 ms (11.7 MiB/s) Retrieving file: /boot/vmlinuz-6.1.0-1025-rockchip 53682688 bytes read in 4334 ms (11.8 MiB/s) append: root=UUID=... rootwait rw console=ttyS2,1500000 console=tty1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory Retrieving file: /lib/firmware/6.1.0-1025-rockchip/device-tree/rockchip/rk3588s-orangepi-5.dtb 260529 bytes read in 287 ms (885.7 KiB/s) Retrieving file: /lib/firmware/6.1.0-1025-rockchip/device-tree/rockchip/overlay/orangepi-5-ap6275p.dtbo 398 bytes read in 329 ms (1000 Bytes/s) Fdt Ramdisk skip relocation and key differense in the end: Armbian -> [ 117.425678] rk-pcie fe190000.pcie: PCIe Link Fail, LTSSM is 0x3, hw_retries=0 Joshuas Ubuntu -> [ 20.633531] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x30011 Ai tolds me it is PHY problems or wrons vcc3v3_pcie2x1l2 power consumption setup but is same for Joshua-Riek and Armbian (1800000 mA) Attaching full logs u-Ubuntu a-Armbian a_wifi_uart_debug u_wifi_uart_debug
  21. https://github.com/armbian/build/pull/9971
  22. It doesn't even attempt to load which is odd. usually it tells you that it (at least) attempts to load in both success and failure cases. Everything else looks pretty normal.
  23. So i catch uboot log. But i dont really understand what is whrong Maybe this ## Flattened Device Tree blob at 12000000 Booting using the fdt blob at 0x12000000 Working FDT set to 12000000 Loading Ramdisk to ebc82000, end ecbff1c5 ... OK Loading Device Tree to 00000000ecdef000, end 00000000ece94fff ... OK Working FDT set to ecdef000 Also pinning full boot file (i colapsed repeading lines) a_wifi_uart_debug
  24. I hope this is the right place for such a finding. If not, please forgive me. My Orange PI Zero 3 got upgraded to Armbian 26.05 yesterday. Usbip modules are gone: Using armbian 26.05: ls -l /usr/lib/modules/$(uname -r)/kernel/drivers/usb/usbip ls: cannot access '/usr/lib/modules/6.18.33-current-sunxi64/kernel/drivers/usb/usbip': No such file or directory After downgrading using armbian config to linux-image-current-sunxi64=25.11.2 (v6.12.58) Note: Armbian 26.02 is not available via armbian-config. ls -ld /usr/lib/modules/$(uname -r)/kernel/drivers/usb/usbip drwxr-xr-x 2 root root 4096 Jun 14 00:11 /usr/lib/modules/6.12.58-current-sunxi64/kernel/drivers/usb/usbip As soon as it becomes available for the officially supported odroidc2, I will test, too.
  25. @alexc Hi, thanks for the response and for the patch! Just to clarify — we actually used your PCIe BSP fix (commit a9eaa51d) and the stock, unmodified hailo_pci 4.21.0 driver from the official Hailo GitHub (v4.21.0 tag). No changes were made to the Hailo driver side at all. Earlier in the process we had experimented with workarounds on the Hailo driver (INTx bypass + polling thread), but those were reverted completely before the final test. The report describes the end state: your kernel patch + stock driver. Result with your fix: hailo 0000:04:00.0: Enabled MSI interrupt No INTx fallback, no polling. Load average dropped from 18+ to ~12, Frigate CPU from ~485% to ~83% (real inference on 9 cameras). Regarding the GitHub PR / kernel patch — that would be great. The fix is clearly in the right place (PCIe driver), and a proper patch submission would help other Allwinner A733 users with PCIe devices.
  26. There is only this overlay for vendor kernel: /usr/lib/linux-image-6.1.115-vendor-rk35xx/rockchip/overlay/radxa-zero3-rpi-camera-v1.3.dtbo The mainline based kernel, what you use, there is none. So you would need to port it, from this radxa03 SBC or look at other devicetree overlay files, maybe from RadxaOS, maybe from RPiOS See 'man dtc' as a start, it might be a complete renaming of a lot of the .dtso file is needed, maybe it is just an enable line.
  27. I put image 7.1 for humanus here but now it has been removed due to running of space on my drive
