  2. Finally, I've extracted the dtb file corresponding to the device, from Android. It is for kernel 4.4.16, so I believe it can be done something with it in order to boot Armbian. At least is a beginning
  3. None of the images are no longer working for me, no matter which recent image I take, the A5E board just remains stuck with a solid blue light (with some green light flickering). I even tried compiling armbian myself, but that also didn't work. The only image working for me is the 25.02 version from earlier this year. I am using the Radxa A5E v1.2 version with 4gb ram. I also mounted the SD card to a linux machine and looked into /var/log for a boot file or reading the journal but I don't see any logs written. Have somebody stumbled unto a solution or does somebody have advice me how I can get the logs to find the culprit?
  5. Hi, always check with "amixer" (alsa mixer) if your outputs are not muted.
  6. Hi! i already tried this without luck. Based on the version ffmpeg showed it installed the right one. I also did uninstall previous ffmpeg and verified its really gone. I still suspect there is something wrong specific for the duo2. Could you please take a look what exact version ffmpeg does show? T.
  7. I can see that after multiples update that the situation for the video acceleration seems to be better in full HD not in 4K, could you help me to understand how? In addition I'd like to add that I'm still getting problems with my Bluetooth keyboard and touch-pad being laggy especially when there is Ethernet traffic ongoing, i don't know if the bus of the Ethernet, the WiFi and Bluetooth card is shared in this SBC. Could you explain me how can i monitor this problem ? to conclude this morning I got a new packages issue, I runned the command "sudo armbianmonitor -u" and i pubblished the results to: https://paste.armbian.com/geyahoxavi
  8. Meanwhile, I upgraded the old rebooting (working) orangepi zero(1)s from U-boot "SPL 2019.04-armbian (Nov 18 2019 - 23:36:05 +0100)" to U-boot "SPL 2024.01-armbian-2024.01-S866c-P6b16-Ha5c2-V367a-Bb703-R448a (Apr 29 2025 - 02:50:09 +0000)" and they also now poweroff on reboot. So the problem is clearly u-boot, and not SD card vendor, kernel (they all run the same "6.12.43-current-sunxi #1 SMP Wed Aug 20 16:30:58 UTC 2025 armv7l") or whatever else. I'll see if I can manage to test U-boot v2025.07... Btw, one thing I noticed with old working boot.cmd/scr was that load_addr was "0x44000000" while it is now "0x45000000" - no idea what significance may have.
  9. I have an Orange Pi 5 board, installed with the 25.8 Debian Bookworm + Cinnamon desktop system. I have switched (using armbian-config) to the edge kernel in order to test the HDMI audio support in the new Linux kernel, but I'm not getting any audio out. The ALSA HDMI card seems to be present (see below), but there's no sound using speaker-test or aplay. I have enabled the hdmirx overlay through armbian-config also, but the result is the same. Is there anything extra that should be configured in order to get audio output ? Output from armbianmonitor - https://paste.armbian.com/gegorimako
  10. Yesterday
  11. One issue with Debian Trixie and encrypted root file systems is that they made some changes. There's an additional package you now need (in addition to cryptsetup-initramfs) prior to updating your initramfs so it will mount an encrypted root: systemd-cryptsetup Despite what this says, I had to install it manually. https://www.debian.org/releases/trixie/release-notes/issues.en.html#encrypted-filesystems-need-systemd-cryptsetup-package
  12. Ah yes indeed. I meant laibsch. Sorry. I made an autoRevert.sh POC that hooks into the initramfs system. Assuming the partition layout described above the following script will revert to the other partition. It is assumed that if an update happened the updater will place a testBoot1 file inside the new boot directory and reboots. During initrd time the script will check for that file and rename it to testBoot2. If the script already detects a testBoot2 it will change the symlink of /boot to the other partition and reboots. Otherwise it is assumed that once the system is up testBoot2 is deleted from the running system if everything works. The script needs to be placed into /etc/initramfs-tools/scripts/init-premount/ and busybox needs to be installed as the script needs the more sophisticated basic commands. Then rebuild initrd. #!/bin/sh PREREQ="" prereqs() { echo "$PREREQ" if ! dpkg -s busybox>/dev/null 2>&1; then >&2 echo "Busybox not installed." exit 1 fi } case $1 in prereqs) prereqs exit 0 ;; esac reboot=0 echo mkdir /run/bootRevert mount /dev/mmcblk0p1 /run/bootRevert if [ -L "/run/bootRevert/boot" ]; then echo "/boot is a symlink. OK." cd /run/bootRevert currentTarget=$(readlink "boot") if [ -f "boot/testBoot2" ]; then echo -n "Reverting " if [ $currentTarget = "bootA" ]; then echo "to bootB." if [ -f "bootB/armbianEnv.txt" ]; then rm boot/testBoot2 ln -snf bootB boot reboot=1 else echo "Aborting revert. bootB seems to be empty." fi fi if [ $currentTarget = "bootB" ]; then echo "to bootA." if [ -f "bootA/armbianEnv.txt" ]; then rm boot/testBoot2 ln -snf bootA boot reboot=1 else echo "Aborting revert. bootA seems to be empty." fi fi else if [ -f "boot/testBoot1" ]; then echo "Going to testboot stage 2." mv boot/testBoot1 boot/testBoot2 else echo "No revert/testboot detected. Booting $currentTarget normally." fi fi fi cd / umount /run/bootRevert if [ $reboot = "1" ]; then sync echo "Rebooting..." reboot -f fi It seems then this concept works. As the script checks if /boot in the boot partition is a symlink and then does nothing if not it can also be placed in an unchanged armbian system without interfering. Perfect for creating new images. Still missing are the management scripts for: - converting an initially downloaded armbian image into an AB boot partition scheme - creating an image/update package from a running and well prepared or updated local armbian installation - a cronable management script to call a more specific download script and for switching partitions and rebooting - the download script that will attach to any distribution system that downloads the new update package places it into the other partition and adjusts machine identity; this download script could also just implement a backup of the running partition to the other partition so that switching back is possible if OTA is done using apt All of these can be done in shell.
  13. Board say Orange Pi 5 V1.2
  14. Hi , I am unable to boot my RK3568 board and cannot get it into MaskROM mode for recovery. The boot process fails with a "Synchronous Abort" in U-Boot SPL during DDR initialization. The device gets stuck in a boot loop. It starts DDR training (`ddrconfig:0`) but fails with a Data Abort exception. Standard methods to enter MaskROM /Loader have not worked. I have attached the full serial log (Boot_log.txt). Any guidance would be greatly appreciated. Thank you. Boot_log.txt
  15. ohh I see. Anyways I can't seem to make it detectable by the Windows RKDevTool, I turn the maskrom mode correctly but then all of the commands fail. It really sucks to have a device this powerful and not being able to do anything because of those crappy dtb files. Thank you anyways!
  16. @fabiobassa Not work, I did wrongly or something. The rk322x image didn't have this ap6330 dtb overlay, so I pull it from another armbian image
  17. No, the support for rk3399 is quite good. The problem is that each box/board needs someone to develop a device tree (dtb) for that box/board and each is different depending on the specifics of that box/board. That is what is lacking to support your box. (and if your box has obscure hardware on it, then those drivers may also be lacking)
  18. I have the same Android TV, and I've been trying to boot Armbian but I don't seem to successfully accomplish it. I believe we are all alone with this, and nobody will ever help us. Maybe RK3399 SoC is still problematic after 9 years.
  19. @tofamus30 You said box Is 322x You said wifi Is 6330 But then you tried dtbo from 3318 board Not sure if is gonna work
  20. Are u kidding me? This is freaking awesome Thanks guys, I will be patiently waiting..
  21. R76S will be supported, but its too early at this stage. We setup download page https://www.armbian.com/nanopi-r76s/ but no images yet.
  22. Thank you for the advice @MattWestB, But I already tried all available LED-config options, booting fine, but none working
  23. Oh right, I forgot about that. Luckily the rk3576 is already maturing in the Linux kernel. In that case we will just hope for the best. Thank you for your time. edit: Could this topic be moved to https://forum.armbian.com/forum/176-other-families/
  24. Try different LED-config then its also changing the hardware for the SD-Card interfaces = WiFi module but prepare that it can ending with not booteball system.
  25. Probably marking on the board is the only what really matters.
  26. Armbian does not accept new boards for official support unless there is funding involved. However anyone from the community can step up and add it as community-supported.
  27. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
  28. Hi guys, I would like to make a support request for the: NanoPi-R76S ($49): https://www.friendlyelec.com/index.php?route=product/product&product_id=308 Thank you for considering. Dantes
