  1. Yesterday
  2. sven-ola
    Success: tested RV2 with GPU on Armbian-noble-nightly. It's a bit hacky but should work. I created a mirror of the relevant packages from Spacmit/Bianbu. Only packages with source, specific to k1x / video / gpu plus chromium. Mirror project is here, in case you want to mirror yourself or miss a package: https://codeberg.org/sven-ola/spacemit-mirror After getting up Armbian-noble-xfce4-nightly on your Spacemit/K1 board (that includes Ky X1) Add mirror repo to /etc/apt/sources.list.d/sven-ola.sources (Note: this is experimental) Types: deb deb-src URIs: https://privat-in.de/armbian Suites: noble Components: main Signed-By: /etc/apt/trusted.gpg.d/sven-ola.gpg Get my repo key with wget -O /etc/apt/trusted.gpg.d/sven-ola.gpg https://privat-in.de/armbian/key.gpg Give the mirror some weight, add an /etc/apt/preferences.d/sven-ola file Package: * Pin: release o=Sven-Ola Pin-Priority: 1000 Install GPU support apt-get update apt-get install img-gpu-powervr apt-get dist-upgrade Note: this will downgrade mesa-25.x to mesa-24.x from Bianbu/Spacemit Install a Wayland-enabled GUI (tested: gnome) apt-get install gnome-core systemctl disable lightdm If asked, select gdm from gnome instead of lightdm from xfce4. After rebooting, click on your user, then stop and select Gnome with the lower right gearwheel icon. I also installed glmark2-es2-wayland to check if that runs. It shows 417@800x600 which is faster than software mesa...
  3. I just tested the latest Armbian distros, Armbian 26.2.0-trunk.493 XFCE and Armbian 26.2.0-trunk.493 Minimal / IOT, and none worked. Then I tried Radxa system images, rock-4se_bookworm_kde_r4.output_512.img.xz did not work. So I got confused because my Rock 4SE v 1.53 SBC worked a long time ago. Found backup of old boot image, which I used with the NVMe drive, because it could not boot on its own. And do you know what? Finally, I saw a picture on the screen with boot log information, which made me happy because it proved my SBC had not died. Then I started looking at some old system images for this board and found one which is booting, it is rock-4se_debian_bullseye_kde_b38.img.
  4. I will try!! @Lamerjack
  5. I`ll already done it. Switched to original Btt image. Understand what that board is didn`t love any sd-card. I`ll stopts on AP32GMCSH10UB-RA card. If card didn't made friends with the board it not boot,reboot`s,power off, halt`s.... IO pins i didnt use.... I`ll swithed to ch340 as uart, because it`s understand 3.3 and 5v levels. The board only 3.3 CAN i use on RP2040+can chip, what cost only 5$(in total), not 15$ for btt can. in a end of can bus i`ll use EBB42 so it`s have all i need.... It`s about I2C bus. Thats my story If u need help, free to ask. I`ll will help if i coud
  6. Well since you asked in this sub-forum, feel free to start:
  7. a few things happened since sunday: i set up a project homepage: https://langerma.github.io/dumpstore/ - screenshots, feature overview, install instructions. and a wiki of course: https://github.com/langerma/dumpstore/wiki three new things landed since the initial post: live ansible task streaming the op-log dialog now shows tasks appearing one by one as ansible runs them, instead of dumping everything at once when the playbook finishes. small thing, but makes it feel a lot more responsive. pool scrub scheduling you can now add/remove pools from the periodic scrub schedule directly from the ui. on linux it edits ZFS_SCRUB_POOLS in /etc/default/zfs (zfsutils-linux), on freebsd it manages daily_scrub_zfs_pools in /etc/periodic.conf. platform-aware, same interface. schema-driven ui all zfs property dropdowns (compression, atime, recordsize, etc.) and the shell picker for users are now driven by a single schema definition in the backend. GET /api/schema returns the full list filtered by platform. before this, the values were hardcoded in four different places — html, js, and go. adding a new property now means touching one file. nothing groundbreaking, just steady progress.
  8. was trying the Armbian Imager because i was searching for an image for OrangePI RV2 that is not in download but is in the imager utility... And the RV2 image is marked of course as WorkInProgress... But i saw that here there is also 2 image for 4a maked as community support.. (that should be better than WIP) there is a command line trixie and a noble with XFCE (that let me think that HDMI works) somebody tried these images? If are usable i will plan to order a 4A that looks more interesting than RV2
  9. Well, Orange has two SBC for AI applications : this one delivering up to 8 Tops and the other one delivering up to 20 Tops. Both are using SoC: Huawei Ascend quad-core ARM 64-bit processor It could be great to have a light/custom O.S like Armbian running on those SBC's! ;-))
  10. Well the only thing armbian-config does, is calling "armbian-install" which has been there for ages
  11. i find it is very convenient now, not only able to choose boot from nvme or sata ssd. but can also install the image from armbian-config. last time im installing armbian i need to dd the image manualy into nvme. very nice work for armbian team
  12. What firmware are you using?
  13. never heard of that one before so probably no.
  14. @xiboliyadongtu Your log seems normal. The problem is that the game is ~100Gb. I don't have that much free disk space to try. It looks like the game is running, but it's just not using the proper GPU renderer. By default, it will use the WineD3D renderer on top of OpenGL (panfrost). 1) You can try Zink by setting those vars: 2) Try Dxvk-stripped: Download Dxvk-stripped here: https://github.com/khanh-it/dxvk/releases/download/releases/dxvk-v1.6.1-stripped-msvc-output.zip and copy the files x64/d3d11.dll, x64/dxgi.dll to the game's folder (/media/xiboliyadongtu/固态/BlackDesert/) setting those vars: Start the game, and see how it goes?!
  15. Last week
  16. Find a board similar to yours and make the necessary adaptations. and on Linux Rockchip: So we can do an shutuo-v8-rk3288 compatible: many times in mainline you can do some tricks like disabling all usb
  17. so today im finally reinstall my opi5, and when choose mtd to flash i got two option, i guess the sata version is if im using sata ssd instead of nvme ssd?
  18. Thanks for your reply. Sorry for the bad identification of my SBC, (i have many ). The board is this one : https://www.armbian.com/orange-pi-5-plus/ Therefore, it seems that my bug report is relevant
  19. This 8TOPS AI computing SBC has two official o.s : ubuntu 22.04 aarch64 and OpenEuler 22.03 aarch64 Is there any Armbian .img available for this SBC ?
  20. https://www.mediafire.com/file/f2iaay5gccs163l/TV_STICK_R3_TRB.rar/file
  21. As I had read, the maximum amount of RAM the H618 handles is 4GB, so, this 8GB TV Box should be a false information.
  22. v25.11.2 for Orange Pi 5 Plus running Armbian Linux 6.1.115-vendor-rk35xx on mine. Just saying. You should use a spoiler for the slop. tl;dr: vendor kernel has exactly nothing in common with mainline besides the fact that it is supposed to run in the same hw.
  23. Many thanks for your reply. I tried FEX, but it appears that within bash, only CPU-emulated GPUs can be invoked. Consequently, I proceeded to test box64 combined with umu and protonge. After entering `export=proton_use_wined3d=1`, the launcher managed to open a black window. How should I proceed with debugging next? Much appreciated! log.txt
  24. I have Orange Pi 5 Plus 32GB RAM version (no longer being sold). Known good kernel is 6.1.75-vendor-rk35xx I just ran sudo apt update and apt upgrade, and I knew this kernel 6.12.xx wouldn't work but I rebooted to try it anyway. Broken, dead, thought it may be DTB. I kept good notes from the prior problem. This board has been rock solid stable with 6.1.75 and I'm running with NPU for AI inference (requires rknn2, not the regular rknn, current version I was working on upgrading to tonight is rknn 2.30 as loadable module (.so). I have serial connected so I can recover via U-Boot and get the kernel back to 6.1.75. Here are the fixes Claude provided based on my prior notes. I hope this helps someone. Find me on X @iDare --- Claude Opus 4.6: This is a confirmed, well-documented upstream kernel bug. Here's the full picture: Confirmed: Known RK3588 GPU Power Domain Bug The Bug (Exact Match) Sebastian Reichel from Collabora reported that the Linux kernel crashes on Rock 5B when the panthor driver is loaded. The crash involves the rockchip power management domain failing to enable the GPU domain, followed by an SError Interrupt causing a kernel panic. Patchwork The Armbian forum thread from a Rock 5B user shows the identical crash signature to yours: The crash trace shows rockchip-pm-domain fd8d8000.power-management:power-controller: failed to get ack on domain 'gpu' followed by SError Interrupt on CPU5, code 0x00000000be000411 with the panic originating from panthor_init calling through rockchip_pd_power_on. Armbian Community Forums That user confirmed downgrading to kernel 6.12 fixed it for the edge branch. Root Cause The GPU power domain requires the GPU voltage regulator to be enabled before the power domain can be turned on. The regulator is enabled at boot time but automatically gets disabled when there are no users. If the GPU driver probes late, the system tries to enable the power domain without the regulator, causing an SError. Patchwork Your boot log confirms this exactly: rockchip-pm-domain: Looking up gpu-supply property in node /power-management@fd8d8000/power-controller failed No gpu-supply in the DT = panthor tries to power on GPU domain = bus fault = SError = kernel panic. The Fix (Upstream, Merged) The patch series adds GPU power domain regulator dependency for RK3588, including a specific DTS change for the Orange Pi 5 Plus (rk3588-orangepi-5-plus.dts). Linaro The v6 patchset was merged (commit f94500eb7328) into Heiko Stübner's tree. It landed in the regulator tree for-next and was applied to the Rockchip DTS tree. Patchew However, this fix is in kernel 6.15+ (merge window). Your vendor kernel 6.1.75 doesn't have it, and the panthor DT overlay is apparently being applied without the matching power domain fix. What Happened on Your Board Your apt upgrade likely updated the panthor DT overlay (rockchip-rk3588-panthor-gpu.dtbo) to a newer version that activates the mainline panthor driver path, but the vendor kernel 6.1.75's rockchip-pm-domain driver lacks the regulator handling code. The overlay enables the GPU node for panthor but doesn't add the gpu-supply property to the power domain controller node. Other Users Hit This Too Multiple Armbian forum threads report the OPi5 with kernel 6.12 failing to boot with kernel panic, and the 6.12.58 minimal image also has non-boot reports. Armbian Community Forums Another user reported their OPi5 Plus stayed stuck on kernel 6.1.75 even after apt upgrade to Armbian 25.2.2, suggesting the kernel package wasn't being updated through normal channels. Armbian Community Forums Recovery Plan Step 1: Boot via U-Boot serial (known-good commands) setenv initrd_addr_r 0x0a000000 ext4load nvme 0:4 ${kernel_addr_r} /boot/vmlinuz-6.1.75-vendor-rk35xx ext4load nvme 0:4 0x0a000000 /boot/uInitrd-6.1.75-vendor-rk35xx ext4load nvme 0:4 ${fdt_addr_r} /boot/dtb/rockchip/rk3588-orangepi-5-plus.dtb setenv bootargs console=ttyS2,1500000 root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 booti ${kernel_addr_r} ${initrd_addr_r}:${filesize} ${fdt_addr_r} This bypasses the panthor overlay entirely (loads base DTB directly). Step 2: Once booted, disable the overlay and pin the kernel bash # Comment out panthor overlay sudo sed -i 's/^overlays=panthor-gpu/#overlays=panthor-gpu/' /boot/armbianEnv.txt # Pin ALL kernel packages sudo apt-mark hold linux-image-vendor-rk35xx linux-dtb-vendor-rk35xx \ linux-headers-vendor-rk35xx linux-u-boot-orangepi5-plus-vendor # Verify apt-mark showhold cat /boot/armbianEnv.txt Step 3: Check what actually changed bash # See if a new kernel was installed dpkg -l | grep linux-image ls -lt /boot/vmlinuz* ls -lt /boot/dtb/rockchip/rk3588-orangepi-5-plus.dtb # Check overlay timestamp ls -lt /boot/dtb/rockchip/overlay/rockchip-rk3588-panthor-gpu.dtbo # Check apt history cat /var/log/apt/history.log | tail -50 Step 4 (Future): Proper Fix Options Once stable, you have two paths to properly restore GPU acceleration: A) Stay on 6.1.75 vendor + add gpu-supply to a custom overlay: dts // Custom overlay that adds gpu-supply to power-controller // This is the DTS fix from the upstream patchset &power_controller { gpu-supply = <&vdd_gpu_s0>; }; B) Wait for Armbian to ship a vendor kernel with the fix backported, or move to a mainline kernel (6.15+) once the full patchset is in a stable release. Are you at the serial console now? Let's get you booted.
  25. Meson 8B is codename of s805 means its not 4k at all bro mine is also 8B i checked it with adb
  26. Actually no. While 6.12.y may be an LTS kernel, support for rk3588 was barely there so very few boards actually work with this. I suggest to download/build an image with either "vendor" kernel 6.1.115 or "edge" with >=6.18.y. This should work better.
