  2. We don't deal with android. I suggest to ask at xda developer forums or similar.
  3. Just a wild guess: The code from orangepi wiringpi is old and no longer compatible with newer python which is shipped in Trixie.
  4. Success! It's still showing that first error, but using meson-gxbb-wetek-play2.dtb it was able to boot up and configure. Wifi works also. You guys are amazing! Thanks for all your inputs.
  5. I'm trying to download and reinstall android os on an x88 pro 10 to try and get it working. I have downloaded the file and flashed the device several times but cannot get past the boot up screen I have attached a usb keyboard and mouse but no luck.looking for someone i can chat with step by step
  6. Hello everyone! First of all, thanks for the useful thread. I'd like to know if you got the files for the SD card, Guillaume lopéré. And if installing this armbian I'd be able to use the tv box as a home server, deploying a Node.js project and using Docker. Best Regards, Gilliard
  7. Today
  8. can you please share the config for the 3568 / or patch so I can refer to for the 3399 chip? Thank you!
  9. I tried Armbian_community_25.11.0-trunk.413_Aml-s9xx-box_plucky_edge_6.18.0-rc3.img I think the same is happening ... I did end up with the first error, as seen in the first pic above: https://photos.app.goo.gl/Y5GM3a6XUy6SZ6JA6 But then I got a nice Armbian splash screen, eventually it ended up going to initramfs, but interestingly no error about waiting for the FS was reported this time.. .... Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... BusyBox v1.37.0 (Ubuntu 1:1.97.0-4ubuntul) built-in shell (ash) Enter ‘help' for a list of built-in commands. (initramfs)
  10. Try a build using a newer edge kernel as a test
  11. Just for fun? for Vendor u-boot I like the ArmSom RK3568 SDK https://github.com/gitacodes/armsom_rk3568_SDK it works fine in all my boards... for mainline U-boot, https://docs.armbian.com/Developer-Guide_Overview/
  12. You need to imagine it as a chip, the entire board; each change to the board alters the description of the "chip" you're referring to. Search for your board model on the forum. I don't own any boards using RK3399, but I believe you can find several users mentioning the board on the forum. for YY3568 board, the factory already have all information https://wiki.youyeetoo.com/en/YY3568/sdCardSystem
  13. Sure.. appreciate the guidance... I am using Armbian_community_25.11.0-trunk.413_Aml-s9xx-box_noble_current_6.12.57_minimal So far I tried 2 different SDCards, one recent sandisk 32G (a good one) and one china fake that says 512GB .. both did the same thing. I also tried 2 dtb so far: meson-gxbb-p201.dtb and meson-gxbb-p200.dtb .. will try a few more before I send this to the EcoCenter. This box seems to be a lot more rare than I expected, so totally get why anyone (including me) would want to invest a lot of effort in getting it to run.
  14. Yesterday
  15. You can try different dtbs, different sdcards (older/smaller/slower = more compatible) and potentially a newer or older kernel. These failure to read the sdcard have been occuring more and more recently. No one has had time to reproduce and figure out the cause. I didn't see where you mentioned what build you are using, that would be helpful information
  16. Error trying to run apt upgrade. Here is the error I receive: The following packages have unmet dependencies: armbian-bsp-cli-rpi4b-current : Depends: base-files (>= 25.8.2) but 25.8.1-12.4+deb12u11-bookworm is to be installed E: Unable to correct problems, you have held broken packages. I am not sure how to resolve this. Help will be greatly appreciated.
  17. Just an FYI i just tried it with a different armbian version and it works fine. it works with Armbian_25.5.1_Orangepi5-plus_bookworm_current_6.12.28_xfce_desktop.img it doesn't work with Armbian_25.8.1_Orangepi5-plus_trixie_current_6.12.43_xfce_desktop.img
  18. Hi, I am quite familiar with github, I'll submit a PR asap.
  19. The /boot/firmware/cmdline.txt requires: console=serial0,115200 The /boot/firmware/config.txt requires: enable_uart=1 That's it.
  20. @laibsch - I have my clearfog booting directly off SATA at this point. I achieved this a while ago by writing a "special" uboot binary to the very start of my SATA SSD, and later by writing an enhanced uboot image via `armbian-config` to SPI flash which doesn't require anything else. It's a very simple configuration now and much preferred over the old way. Good luck keeping your system operational and running well!
  21. I just did a simple test that always worked on Intel CPUs with with logitech C310 on ROCK5B with 6.1.115 kernel /usr/share/jellyfin-ffmpeg/ffmpeg -y -hide_banner -f video4linux2 -input_format yuv420p -video_size 640x480 -framerate 30 -i /dev/v4l/by-id/usb-046d_081b_9061E8E0-video-index0 -map v -c:v h264_rkmpp -f mpegts webcam.ts Output file plays fine, good motion, same as if I use normal ffmpeg and just non-accel h264 codec, although CPU load is then about 20% for the ffmpeg process, while when using rkmpp it is below 1% For higher resolution, I think C310 internal MJPG is needed, but that is normal, USB2 has limited bandwidth.
  22. My rk3588 devices are e.g. exposing this: v4l2-compliance-odroid-m2.txt And here is the visualization of a video pipeline: video-pipeline.pdf Watch out for the v4l2slh265dec component.
  23. As a trusted partner of industry leaders like CLAAS, Ag Leader, and CCI, we are delighted to exhibit for the first time at one of the world’s leading agricultural trade fairs, taking place November 9–15. Meet us at the Digital Farm Center in Hall 21! View the full article
  24. I know I am bringing this back from the dead but i am having issued getting wiringop-python installed. with the fallowing i was able to do a gpio readall echo "BOARD=orangepi5plus" | sudo tee /etc/orangepi-release but when i get errors from the sudo python3 setup.py install. (wiringpi_warp.c:3901:29: error: implicit declaration of function 'getGpioNum' [-Wimplicit-function-declaration]) # get the dependencies sudo apt-get update sudo apt-get -y install git swig python3-dev python3-setuptools # clone wiringOP-python repo, the branch should be "next" and NOT "main" or "master" git clone --recursive https://github.com/orangepi-xunlong/wiringOP-Python -b next cd wiringOP-Python git submodule update --init --remote python3 generate-bindings.py > bindings.i sudo python3 setup.py install is there a fix for this?
  25. @jock this is the user-overlay patch I am using to enable both leds on the board. The "working" led is as usual a couple of alternating leds of red/blue. The led-ir is a standalone blue, I have triggered one to the "timer" and the other to "activity" , both running. I can confirm bluetooth, IR remote receiver are also working. Bluetooth needs BCM.hd (I have used BCM43342.hcd). For the wifi 2/5G the correct overlay is rk3318-box-wlan-ap6334. HDMI, despite apparently is initialized correctly and answering to all commands still gives a black screen. rk3318-box-led-overlay-ledA.dtso.txt
  26. Wow.. I don't know how that brainfart happened. Used the correct uboot I managed to get somewhere. I tried to use the meson-gxbb-p201 but seems that the FS cannot be found... will try others but wondering if I should be tweaking UUIDs given the errors I am seeing: https://photos.app.goo.gl/Y5GM3a6XUy6SZ6JA6 https://photos.app.goo.gl/Qq3EPGScPUFWfuQP6 I do seem to have mmcblk1 (and mmcblk1boot0, etc..) in /dev if I poke around. Not sure if trying new dtb is a good approach or should I try to add the delay like the error suggests.
  27. There should be a big difference in speed and powerconsumption; As I indicated in earlier post, edge kernel has no video encoding working, so at least is is SW encode. Debian/standard ffmpeg for aarch64 only had/has v4l2m2m, no dedicated RKMPP also no old OpenMAX rpi methods (in the past). I think this works for Qualcomm SoCs, but no others I am aware of. If you use RK35xx RKMPP I see almost 5x real-time speed for 1080p50 and low CPU load. See example below: root@rock5b:~# ffmpeg -hide_banner -codecs | grep -e h264_v4l2m2m -e h264_rkmpp DEV.LS h264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (decoders: h264 h264_v4l2m2m h264_cuvid) (encoders: libx264 libx264rgb h264_nvenc h264_v4l2m2m h264_vaapi h264_vulkan) root@rock5b:~# /usr/share/jellyfin-ffmpeg/ffmpeg -hide_banner -codecs | grep -e h264_v4l2m2m -e h264_rkmpp DEV.LS h264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (decoders: h264 h264_v4l2m2m h264_rkmpp h264_cuvid) (encoders: libx264 libx264rgb h264_nvenc h264_v4l2m2m h264_rkmpp) root@rock5b:~# /usr/share/jellyfin-ffmpeg/ffmpeg -y -hide_banner -c:v hevc_rkmpp -i /lan/record/2025-11-04-NPO-1.ts -map v -c:v h264_rkmpp -f mpegts /dev/null Input #0, mpegts, from '/lan/record/2025-11-04-NPO-1.ts': Duration: 06:59:01.58, start: 14798.887378, bitrate: 4058 kb/s Program 1 Metadata: service_name : NPO 1 service_provider: KPN Stream #0:0[0x1b63]: Video: hevc (Main) ([36][0][0][0] / 0x0024), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 50 fps, 50 tbr, 90k tbn Stream #0:1[0x1b64](dut): Audio: aac_latm (HE-AAC) ([17][0][0][0] / 0x0011), 48000 Hz, stereo, fltp Stream #0:2[0x1b69](dut): Audio: aac_latm (HE-AAC) ([17][0][0][0] / 0x0011), 48000 Hz, stereo, fltp (visual impaired) (descriptions) Stream #0:3[0x1b65](dut): Subtitle: dvb_teletext (libzvbi_teletextdec) ([6][0][0][0] / 0x0006), 492x250 No Program Stream #0:4[0x12]: Data: epg Stream mapping: Stream #0:0 -> #0:0 (hevc (hevc_rkmpp) -> h264 (h264_rkmpp)) Press [q] to stop, [?] for help Output #0, mpegts, to '/dev/null': Metadata: encoder : Lavf61.7.100 Stream #0:0: Video: h264 (High), nv12(tv, bt709, progressive), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 2000 kb/s, 50 fps, 90k tbn Metadata: encoder : Lavc61.19.101 h264_rkmpp ^C[out#0/mpegts @ 0xaaaaea74fce0] Error writing trailer: Immediate exit requesteds speed=4.86x [out#0/mpegts @ 0xaaaaea74fce0] Error closing file: Immediate exit requested [out#0/mpegts @ 0xaaaaea74fce0] video:61287KiB audio:0KiB subtitle:0KiB other streams:0KiB global headers:0KiB muxing overhead: 6.096897% frame=12559 fps=244 q=25.0 Lsize= 65024KiB time=00:04:11.16 bitrate=2120.9kbits/s speed=4.87x ^C^CReceived > 3 system signals, hard exiting
  28. My understanding is that ffmpeg needs to be compiled to do hardware acceleration. I use it (straight from the Debian repository) to transcode videos on my RK3588 board (Orange PI 5 Plus) running the Armbian edge kernel, and it runs just as fast as the vendor-compiled ffmpeg did using the Orange Pi company's vendor kernel.
