hi @chris178! 1 - factory 8gb, not modded, lpddr4 2 - boot log: ▒...... [151]HELLO! BOOT0 is starting! [154]BOOT0 commit : {9f6fab4f-dirty} [168]dram_para_total:0xf [171]vaild para:6 select dram para10 [175][mmc]: mmc driver ver 2024-03-20 10:36 [184][mmc]: Wrong media type 0x0 [188][mmc]: ***Try SD card 0*** [197][mmc]: HSSDR52/SDR25 4 bit [200][mmc]: 50000000 Hz [202][mmc]: 59638 MB [205][mmc]: ***SD/MMC 0 init OK!!!*** [210]DRAM BOOT DRIVE INFO: V0.601 [215]DRAM_VCC set to 1100 mv [217]DRAM CLK =1800 MHZ [220]DRAM Type =8 (8:LPDDR4,9:LPDDR5) [320]Training result is = 7 [323]DRAM Pstate 1 training, frequency is 1200 Mhz [433]Training result is = 7 [436]DRAM Pstate 2 training, frequency is 800 Mhz [642]Training result is = 7 [645]DRAM Pstate 3 training, frequency is 400 Mhz [3829]Training result is = 7 [3832]DRAM Pstate 0 training, frequency is 1800 Mhz [3840]Actual DRAM SIZE =8192 M [3843]DRAM SIZE =8192 MBytes, para1 = 311a, para2 = 20001001, dram_tpr13 = 6067 [3858]DRAM simple test OK. [3864]error:bad magic. [3928]error: dtb not found for scp [3931]mmc not para [3933]Jump to ATF: monitor_base = 0x48000000, uboot_base = 0x4a000000, optee_base = 0x0 NOTICE: BL31: OP-TEE 32bit detected NOTICE: BL31: U-BOOT 32bit detected NOTICE: BL31: v2.5(debug):5fc237a6a NOTICE: BL31: Built : 09:05:28, Feb 26 2025 NOTICE: BL31: No DTB found. ERROR: Error initializing runtime service opteed_fast U-Boot 2018.07-12-boot-aw2501-gb2d229198b2-dirty (Jan 06 2026 - 03:45:33 +0000) Allwinner Technology [03.985]CPU: Allwinner Family [03.988]Model: Radxa Cubie A7A I2C: ready [04.052]DRAM: 8 GiB [04.061]Relocation Offset is: 75d89000 [04.114]secure enable bit: 0 [04.117]PMU: AXP8191 [04.119]PMU: AXP8191 VER_A FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL [04.131]bmu_axp515_probe pmic_bus_read fail [04.135][AXP8191] onoff status: 0x50 = 0x1, 0x51 = 0x0 [04.140][AXP8191] charge status: 0x4 = 0x0 [04.144]CPU=1014 MHz,PLL6=1200 Mhz,AHB=200 Mhz, APB1=24Mhz MBus=600Mhz [04.150]gic: sec monitor mode SPI ALL: ready [04.194]flash init start [04.196]workmode = 0,storage type = 1 [04.200][mmc]: mmc driver ver uboot2018:2024-10-18 9:01:00 -- uboot2018:2025-03-28 10:03:00 [04.208][mmc]: get sdc_type fail and use default host:tm1. [04.216][mmc]: can't find node "mmc0",will add new node [04.221][mmc]: fdt err returned <no error> [04.224][mmc]: Using default timing para [04.228][mmc]: SUNXI SDMMC Controller Version:0x50530 [04.246][mmc]: card_caps:0x3000000a [04.249][mmc]: host_caps:0x3000003f [04.252]sunxi flash init ok get value error [04.262]Loading Environment from SUNXI_FLASH... OK No ethernet found. [04.299]NOT support bridge yet [04.302]Warn: no find panel or bridge [04.403]drm hdmi get mode: 1920x1080@60Hz hdmi0@5520000: use force output detailed mode clock 139190 kHz, flags[5] H: 1920 2008 2052 2080 V: 1080 1082 1087 1115 bus_format: 0 clk_set_rate: <NULL> has NULL parent [04.505]suxni tcon hdmi set rate: 139190000Hz and get diff: -139190000Hz [04.577]the secure storage item0 copy0 magic is bad [04.589]the secure storage item0 copy1 magic is bad [04.593]usb burn from boot delay time 0 [04.599]usb prepare ok [04.902]overtime [04.906]do_burn_from_boot usb : no usb exist skip update boot_param cann't get the boot_base from the env [04.917]update part info [04.922]battery temp is -1 [04.926]update bootcmd [04.934](not enough data: expected >= 8 cells, got 4 cells) Link up timeout Speed change timeout PCIe speed of Gen1 Override default fdtfile to allwinner/sun60i-a733-cubie-a7z.dtb [07.376]libfdt fdt_check_header(): FDT_ERR_BADMAGIC [07.382]libfdt fdt_path_offset() returned FDT_ERR_BADMAGIC [07.388][mmc]: get sunxi-mmc0 string failed [07.392]The storage not support sample function [07.398]## error: update_fdt_dram_para_from_bootpara : FDT_ERR_NOTFOUND ret 0 [07.408]chip id : 0x00005100 0x00004900 0x00004810 0x00001d62 [07.414]mac addr => 08:51:49:58:7f:71 [07.417]chip id : 0x00005100 0x00004900 0x00004810 0x00001d62 [07.423]mac addr => 08:51:49:58:7f:70 [07.427]/chosen/rng-seed node not exit [07.430]no battery, disabled battery functons [07.434]Could not find nodeoffset for bat_supply [07.439]update dts curr_device:0 Device: SUNXI SD/MMC Manufacturer ID: ff OEM: 0 Name: SDU1 Bus Speed: 50000000 Mode : SD High Speed (50MHz) Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 58.2 GiB Bus Width: 4-bit Erase Group Size: 512 Bytes [ufs]info:Driver version 0.0.24 2024.12.30 16:00 [ufs]info:Cal words 0x60:val 0xb0880000, 0x64:val 0x4f21a959 [ufs]err:uic c 16,uic a 0,1,0 [ufs]err:e 80000010,0,0,0,0 [ufs]err:int s 0,400 [ufs]err:Device not present [ufs]err:wait device link startup failed [ufs]info:peer link startup timeout [ufs]info:Cal words 0x60:val 0xb0880000, 0x64:val 0x4f21a959 [ufs]err:uic c 16,uic a 0,1,0 [ufs]err:e 80000010,0,0,0,0 [ufs]err:int s 0,400 [ufs]err:Device not present [ufs]err:wait device link startup failed [ufs]info:peer link startup timeout [ufs]info:Cal words 0x60:val 0xb0880000, 0x64:val 0x4f21a959 [ufs]err:uic c 16,uic a 0,1,0 [ufs]err:e 80000010,0,0,0,0 [ufs]err:int s 0,400 [ufs]err:Device not present [ufs]err:wait device link startup failed [ufs]info:peer link startup timeout [ufs]info:Cal words 0x60:val 0xb0880000, 0x64:val 0x4f21a959 [ufs]err:uic c 16,uic a 0,1,0 [ufs]err:e 80000010,0,0,0,0 [ufs]err:int s 0,400 [ufs]err:Device not present [ufs]err:wait device link startup failed [ufs]info:peer link startup timeout [ufs]err:link startup failed -6 [ufs]err:ufshcd_probe() failed -6 fail to init ufs sunxi_flash - sunxi_flash sub-system Usage: sunxi_flash sunxi_flash init storage_type sunxi_flash read mem_addr part_name [size] sunxi_flash read_mtd mem_addr part_name [size] sunxi_flash write <mem_addr> <part_name> [size] sunxi_flash write <mem_addr> <part_name> [offset] [size] sunxi_flash write_mtd <mem_addr> <part_name> sunxi_flash boot0 force_dram_update_size <new_val> sunxi_flash boot0 force_dram_update_flag <new_val> Hit any key to stop autoboot: 0 starting USB... USB0: start sunxi USB-DRD... config usb clk ok sunxi USB-DRD init ok... USB EHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found USB1: start sunxi USB1-Host... config usb clk ok sunxi USB1-Host init ok... USB EHCI 1.00 scanning bus 1 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: device type unknown ... is now current device ** Bad device usb 0 ** ** Bad device usb 0 ** mmc0 is current device Scanning mmc 0:2... Scanning mmc 0:3... Found /boot/extlinux/extlinux.conf Retrieving file: /boot/extlinux/extlinux.conf 1307 bytes read in 19 ms (66.4 KiB/s) U-Boot menu 1: Debian GNU/Linux 11 (bullseye) 5.15.147-14-a733 2: Debian GNU/Linux 11 (bullseye) 5.15.147-14-a733 (rescue target) Enter choice: 1: Debian GNU/Linux 11 (bullseye) 5.15.147-14-a733 Retrieving file: /boot/initrd.img-5.15.147-14-a733 31153067 bytes read in 1310 ms (22.7 MiB/s) Retrieving file: /boot/vmlinuz-5.15.147-14-a733 19030528 bytes read in 808 ms (22.5 MiB/s) append: root=UUID=6f750720-329a-45f0-a4b5-abc5797b040a console=ttyAS0,115200n8 rootwait clk_ignore_unused mac_addr=08:51:49:58:7f:71 mac1_addr=08:51:49:58:7f:70 quiet splash loglevel=4 rw earlycon consoleblank=0 console=tty1 coherent_pool=2M irqchip.gicv3_pseudo_nmi=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 kasan=off Retrieving file: /usr/lib/linux-image-5.15.147-14-a733/allwinner/sun60i-a733-cubie-a7z.dtb 193692 bytes read in 145 ms (1.3 MiB/s) [16.025]libfdt fdt_path_offset() returned FDT_ERR_BADMAGIC [16.034]The storage not support sample function ret 0 [16.136]mac addr => 08:51:49:58:7f:71 [16.140]mac addr => 08:51:49:58:7f:70 [16.145]no battery, disabled battery functons [16.152]update dts stop sunxi USB-DRD ok... stop sunxi USB1-Host ok... Loading Ramdisk to 4824a000, end 49fffbab ... OK ERROR: reserving fdt memory region failed (addr=48000000 size=1000000) [16.232]Starting kernel ... [16.235]total: 16235 ms [16.237][mmc]: MMC Device 2 not found [16.240][mmc]: mmc 2 not find, so not exit NOTICE: [SCP] :wait arisc ready.... NOTICE: [SCP] :arisc version: [d463b9da43dc50320f21ba51c6c51afe2db20d83] NOTICE: [SCP] :arisc startup ready NOTICE: [SCP] :arisc startup notify message feedback NOTICE: [SCP] :sunxi-arisc driver is starting NOTICE: BL3-1: Next image address = 0x40200000 NOTICE: BL3-1: Next image spsr = 0x3c5 nothing happen after that my workaround ( with claude help ) edit extlinux.conf and add mem=4G append root=UUID=0e1a597a-1884-4b41-a07c-733efecf176c console=ttyAS0,115200n8 earlyprintk=sunxi-uart,0x2500000 rootwait mem=4G clk_ignore_unused any higher value dosent work.
Joe K replied to XXXBold's topic in Orange Pi 5
Hi Igor, Thank you for your reply. I build an Image for Mekotronics R58V2, but I leaned today we dont have the R58S2 (yet) our current device is the R58s, with a build provided by Mekotronics and the HW decoding works with QT-Multimedia as playback back-end, This is this build: v26.02 rolling for Mekotronics R58S running Armbian Linux 6.1.84-vendor-rk35xx. This device is not yet supported, at least I could not find it here. I will discuss with Mekotronics to get also at least Standard support from Armbian in future. I do have also Mekototronics R58X and R58HD devices we want to use also in ffuture the have better support level here as well. I could not find any Forums related to Mekotronics devices and seams can not open one or add threads to the Rockchip rk35xx section, there loads of OragePi stuff but I could not see that officially you support any of them, anyway I gave up with them cause they are ...lets say below expectations ;-). Please give me a hint. As Iam new here please excuse if you get sometimes strange question, but Iam working with arm boards already for a while. Using CLI is not an option, we actually install LX-Qt together with the application. Thanks for helping! -
Booting from mtd/nvme should just work. Most common problems: - dirty mtd/emmc. vendor/unmatching boot loader can cause issues. - mixup between m.2 sata and actual nvme. Correct overlay/dt must be used - wrong rootfs uuid in armbianEnv.txt after running armbian-install (after done, do not reboot but mount freshly written nvme to a random folder and check if the uuid is correct)
Hi everyone, I just got an Orange Pi 5 and am experiencing the same issue as the OP. I've since then installed the bootloader on the SD card and the rootfs on the NVME drive. I don't really understand what came out of the discussion here: is it possible to boot from the MTD? Thanks a lot! EV
Igor replied to XXXBold's topic in Orange Pi 5
Gnome (wayland) desktop with kernel 6.18.y Probably this way? apt install mpv mpv --hwdec=auto test.mkv (+) Video --vid=1 (*) (hevc 1920x816 25.000fps) (+) Audio --aid=1 --alang=mul (*) (aac 2ch 48000Hz) AO: [alsa] 48000Hz stereo 2ch float VO: [gpu] 1920x816 yuv420p But something is still missing ... not hw accelerated. Sorry, not an expert here. I am happy when Chromium says it. -
A friendlier, faster, snap-free desktop install in armbian-configIf you've installed a desktop environment with armbian-config over the last few months, you may have noticed things feel different: there's a tier you can pick, the browser actually works on every arch, uninstall doesn't take half your system with it, and there's no snap pop-up surprising you on Ubuntu builds. That's not by accident — the desktop submodule has been quietly rebuilt from the ground up. Here's what landed, why we did it, and what it means for you. Pick the desktop you want — at install, and afterThree tiers, instead of one all-or-nothing install: minimal — DE + display manager + a terminal. About 500 MB. Perfect for headless boards with an occasional HDMI session, or anyone who'd rather curate apps themselves.mid — adds a WWW browser, file manager, image viewer, media player, calculator, archive tool, torrent client, and the SD-card flasher. About 1 GB. The "everyday desktop" sweet spot.full — adds LibreOffice, GIMP, Inkscape, Audacity, Thunderbird, and VS Code. About 2.5 GB. Workstation-shaped.And — because changing your mind is allowed — you can move between tiers any time without a reinstall. armbian-config --api module_desktops upgrade de=xfce tier=full computes the delta and only adds what's missing. The reverse path, downgrade, only removes packages from the original install manifest, never anything you added on your own. Snap-free Chromium, Firefox, and ThunderbirdOn Ubuntu, the apt names chromium, firefox, and thunderbird are snap-transitional packages — installing them silently pulls in snapd, runs the apps in a snap sandbox, and gives you a slow start, broken hardware acceleration, and a confusing menu of "two Chromiums" if you ever want the real thing. Armbian images don't ship snapd, so we now route those names to real, native .debs hosted on apt.armbian.com. The desktop install path writes an apt pin priority file at /etc/apt/preferences.d/armbian-desktops that forces our packages to win over the snap-shims — even on systems where the snap version is technically newer. The result: apt install chromium gives you a real, native Chromium. No snapd. No surprise pop-ups. On amd64 systems, the browser slot maps to Google Chrome (also from apt.armbian.com); on RISC-V Ubuntu builds you get real Firefox. Debian releases keep using upstream chromium / firefox-esr — those have always been real .debs and need no help. One desktop, every supported distro and archEach DE — XFCE, GNOME, KDE Plasma, KDE Neon, MATE, Cinnamon, i3-wm, xmonad, Enlightenment, Budgie, Deepin — is now a single declarative YAML file in the configng repo. The engine works out which packages exist on which release on which arch, substitutes per-platform replacements where needed, and silently drops broken ones. Same XFCE definition runs on Debian bookworm/trixie/forky and Ubuntu noble/resolute across arm64 / amd64 / armhf / riscv64. Adding a new desktop environment is a YAML edit and a smoke test — no per-distro shell scripts, no codepaths to chase. Clean uninstall, every timeEvery desktop install records a manifest of exactly which packages it added — under /etc/armbian/desktop/<de>.packages. Removal undoes only those. Packages that were already on your system before you installed the desktop stay put. No more "I uninstalled XFCE and lost half my system." The little stuff that's easy to missAuto-login that doesn't trash your config. Enable / disable autologin for gdm3, sddm, or lightdm via in-place sed edits — your WaylandEnable=false and other tweaks survive.Container-aware. Same code path works inside Docker without trying to start a display manager. CI builds and scripted installs work without special-casing.U2F security keys. Plug in your Yubikey and WebAuthn just works — the udev rules ship via libfido2-1 on resolute, libu2f-udev on older releases.Printer panel works. GNOME Settings → Printers no longer says "some settings cannot be unlocked" — cups-pk-helper ships with every desktop install now.VS Code from us, not Microsoft's repo. Installing code no longer prompts you to add Microsoft's apt source — we host the real package, the prompt is suppressed, the pin keeps Microsoft from sneaking in over the top.A weekly self-audit catches driftA scheduled Claude AI supported GitHub Actions workflow scans the YAML matrix against armbian/build's supported releases and the live Debian/Ubuntu archives — flags releases not yet covered, flags packages that no longer exist upstream — then opens a PR with proposed YAML fixes. Dead packages and missing releases stop accumulating silently. Try itOn any modern Armbian install: sudo armbian-config # or scripted: sudo armbian-config --api module_desktops install de=xfce tier=full sudo armbian-config --api module_desktops upgrade de=xfce tier=full sudo armbian-config --api module_desktops downgrade de=xfce tier=mid sudo armbian-config --api module_desktops remove de=xfce Supported desktops today: XFCE, GNOME, KDE Plasma, KDE Neon (Ubuntu noble only), MATE, Cinnamon, i3-wm and xmonad, Enlightenment, Budgie and Deepin experimental. Supported targets: Debian bookworm / trixie / forky and Ubuntu noble / resolute on every Armbian arch. View the full article
Can you post logs of both working and not working boards? If they are exactly the same software, it sounds like a hardware issue. If the HardKernel images works as expected, perhaps you've updated all 3, but not rebooted the working one yet?
@tiobily Is your a7z factory 8GB or modded out of curiosity (lpddr4 or lpddr5) ? Are you able to connect serial console onto uart0 (pb9, pb10) header pins (3.3V TTL uart adapter) and see right after power is applied to the board the debug of dram detection and training? Debug will show if full 8GB is being detected - once this is confirmed, we can take it from there.
I got into similar situation and Loader mode is not working now. How did you manage to restore the box? Have you found the correct pins to short? Thank you a lot in advance :) -
@ioncube Were you able to use VPU with Jellyfin?
If anybody needs a simple way to check text on the web or extract text from online PDFs on low‑spec SBCs, here is surf.py. It’s a tiny Python‑based terminal browser designed for boards like Orange Pi Zero, so you’re not completely blind internet‑wise even without a full browser. Starts with: ./surf.py domain.com Dependencies outside standard library: requests, PyPDF2. surf.py
jock replied to Alexander Polko's topic in Rockchip CPU Boxes
Hello, you can only boot from sdcard with that device if you follow the rockchip boot sequence, ie: you have to pack u-boot and trust.img using loaderimage tool from rockchip rkbin repository. That tools decorates the uboot/trust.img binaries with some signature and checksum, then you have to put on specific positions on your sdcard and the miniloader, residing in the emmc, will boot from sdcard once it validates correctly the binaries you supplied. You may take a look to my multitool github project for some reference. I have you same box and it boots on mine. Unfortunately on this particular box, the manufacturer disabled the sdcard boot at SoC/hardware level: this means that the trick to erase the internal flash to boot from sdcard, which worked fine for older SoCs, does not always work with rk3528-based (and probably other rk35xx) boards -
XXXBold replied to XXXBold's topic in Orange Pi 5
@Igor Thanks for the answer! So you run the latest Armbian to test? https://armbian.com/boards/orangepi5 from here? Which image? Would using the CLI version also work (I don't need a desktop). Can you maybe also verify if HEVC works? (H264 works also quite okay in pure CPU iirc). -
Anyone has a working image with GPU / VPU support? In the official Jammy I am using VPU is supported via gstreamer / CEDRA https://github.com/defencedog/orangepi4A/tree/main/GPU_VPU
hello i have ths a7z with 8gb ram. Actualy im using with only 4gb (ok for my application). I can boot only if i set mem=4g. Any workaround for that? i tried all images ive found and no one can boot with 8gb.
Beginner friendly help to boot linux in Allwinner
Werner replied to Hyper Fox's topic in Allwinner CPU Boxes
moved -
Hyper Fox replied to Hyper Fox's topic in Allwinner CPU Boxes
Heads up i dont have pc if the process needs it mainly if there's any other way do let me know -
Hello guys i want to use linux on mx pro tv box from pendrive when i flash armbian image to pendrive and click the secret button on box nothing boots up can any one guide me on this thankyou:)
moved to tvboxes
Reserved for updates. -
Help needed S905 SOC Bricked No sdcard slot
kar 412 replied to Information Tech's topic in Amlogic CPU Boxes
i am working on same box you can contact me for its fix -
DISCLAIMERS (PLEASE READ): - Everything in this post is provided AS-IS. This is not an official Armbian-supported target, and neither the Armbian project nor I am responsible for any damage, data loss, or broken devices caused by flashing or testing these images. - As with other TV boxes, please assume there may be board variants, undocumented hardware changes, weak power supplies, and marginal NAND/eMMC chips. Test carefully before writing anything to internal storage. - Please keep discussion and support in the forum thread, not in the official Armbian issue tracker. Hi all, I would like to share my work on bringing Armbian to Rockchip RK3128 TV boxes. These boxes are quite old now, and I do not think they are especially common anymore. Still, I suspect a lot of people may have one lying around somewhere in a drawer, unused after Android updates stopped or the original firmware became too slow to care about. I also had several of them lying around at home, which is what pushed me to start this project in the first place. Since I could not find an RK3128 Armbian effort comparable to the RK322x one, I decided to try doing the port myself. Another important motivation was simply to reduce e-waste: if even some of these old boxes can be turned into usable Linux machines again instead of being thrown away, that already feels worthwhile to me. First and foremost, I want to send special thanks to @jock and @fabiobassa for their RK322x TV box work on this forum. Their work was the foundation that made this RK3128 effort much easier to start from. 1. Main references and source code: Blog post with the full write-up: https://chieunhatnang.de/p/building-armbian-for-rockchip-rk3128/ Follow-up post for kernel 6.6.89 work: https://chieunhatnang.de/p/building-armbian-for-rockchip-rk3128-part-2/ Build scripts and releases: https://github.com/chieunhatnang-personal/RK3128-Linux-SupportingScripts RK3128 kernel 4.4 tree: https://github.com/chieunhatnang-personal/linux-kernel-4.4-rk3128-tvbox RK3128 kernel 6.6 tree: https://github.com/chieunhatnang-personal/linux-kernel-6.6-rk3128-tvbox 2. Current status At the moment I have two kernel lines: `4.4.194`, the older vendor-based line, which is already usable in practice `6.6.89`, the newer line, which allows these boxes to run a more up-to-date Armbian userspace What works in the current build: Custom U-Boot based on Rockchip U-Boot 2017.09 All four CPU cores, up to 1.2 GHz CPU frequency scaling and governors DRAM frequency control, both dynamic and fixed NAND, eMMC, SD card, and USB booting. The booting order is: USB >> SD Card >> NAND/eMMC (NAND and eMMC cannot be enabled at the same time because they share pins) OTG and EHCI/OHCI USB support Ethernet Wi-Fi support for SSV6051P, ESP8089, and several Realtek chips GPU acceleration UART1 and UART2, configurable Kernel `6.6.89` status in a bit more detail: CPU DVFS is stable after replacing the inherited/leakage-based OPP assumptions with a board-specific RK3128-safe table. The stable points I ended up using are `216 / 408 / 600 / 816 / 1008 / 1200 MHz` DMC / RAM devfreq works. In practice, simply enabling `dmc` works much better than I first expected, and boards can settle at different normal rates such as `396 MHz` or `456 MHz` GPU on `6.6.89` uses `Lima`, not the old Mali blob stack. That gives a maintainable Mesa/DRM path and hardware-accelerated OpenGL ES instead of depending on a legacy userspace blob VPU/video decode is still the weak point. I tried both `RKMPP` and `Hantro/V4L2` directions, but video processing is still limited, so I do not consider this a polished media-playback setup yet What does not work yet / known limitations: Bluetooth: not implemented or at least not validated, because I do not have a board with Bluetooth to test VPU / hardware video decoding is not in good shape yet SD card and SDIO Wi-Fi are currently using PIO mode on both kernel lines. This is slower than DMA, but stable enough for normal use 3. Image implementation I also made two RK3128 Armbian images based on existing RK322x Armbian images rather than building everything from scratch: Armbian 22.02: Based on the build provided by @jock, running kernel 4.4.189 Armbian 26.02: Based on the official Armbian build for rk322x, running kernel 6.6.89 In both cases, the idea was the same: keep the working RK322x Armbian userspace as a base, then replace the RK322x-specific parts with RK3128 ones, while the kernels themselves are based on Rockchip kernel sources. Compared with the original RK322x images, the RK3128 work mainly replaces or adds: boot.cmd / boot.scr changes so the boot flow can handle NAND and USB properly RK3128-specific Wi-Fi drivers and boot-time module loading logic rk3128-config a delayed Wi-Fi loader service RK3128-specific motd information the RK3128 kernel, DTB, and overlays For the `6.6.89` image specifically, there is some extra image-level cleanup and repackaging: remove the RK322x kernel / dtb / u-boot / BSP packages from the donor image pin those RK322x packages so they do not come back on upgrade install the RK3128 `6.6.89` Debian kernel packages rebuild the BSP package under the RK3128 name 4. Quick installation notes All required files are available from the releases page: The releaes page: https://github.com/chieunhatnang-personal/RK3128-Linux-SupportingScripts/releases Armbian 26.02 image: https://github.com/chieunhatnang-personal/RK3128-Linux-SupportingScripts/releases/download/kernel-6.6-armbian-26-v1.0/A26-release-20260415.zip Armbian 22.02 image: https://github.com/chieunhatnang-personal/RK3128-Linux-SupportingScripts/releases/download/kernel-4.4-armbian-22-v1.1/release-20260412.zip There are three installation layouts that are currently supported: 1. SD card only Pros: safest option, does not touch internal storage, easy to test and easy to remove, and if a board has an SD slot it can still be useful even when NAND/eMMC is completely dead Cons: slower than internal storage, and not every board has an SD slot Best for: first boot, testing, and boards where you want to keep the original Android install untouched 2. Full install to NAND / eMMC Pros: fastest and cleanest setup, uses the internal storage already present on the board Cons: overwrites the original Android install, and old NAND/eMMC may already be unreliable Best for: boards with healthy internal storage when you want a fully self-contained install 3. Hybrid install: bootloader on NAND / eMMC, rootfs on USB or SD card Pros: usually the most practical option for old TV boxes, works well when internal storage is only reliable enough for bootloader pieces, and can also help on boxes with problematic Android boot behavior Cons: more manual than the other methods, still depends on internal storage for the bootloader, and performance depends on the USB drive or SD card used Best for: boxes with weak or aging internal NAND/eMMC, or boxes where you want to avoid a full install to internal storage I describe each method in more detail below. 4.1. Install and boot from SD card Prepare: idbloader.img uboot.img trust.img rootfs.img Create an MBR partition table on the SD card, leave the first 16 MB empty, create one Linux partition, then write: idbloader.img to the raw device at seek=64 uboot.img to the raw device at seek=16384 trust.img to the raw device at seek=24576 rootfs.img to the first partition, not to the whole disk Example: DEV=/dev/sdX sudo parted -s "$DEV" mklabel msdos sudo parted -s "$DEV" mkpart primary ext4 16MB 100% sudo partprobe "$DEV" sudo dd if=idbloader.img of="$DEV" seek=64 conv=fsync sudo dd if=uboot.img of="$DEV" seek=16384 conv=fsync sudo dd if=trust.img of="$DEV" seek=24576 conv=fsync sudo dd if=rootfs.img of="${DEV}1" bs=4M status=progress conv=fsync sync I also provide a bootcardmaker.sh helper script in the same release directory to simplify this process. 4. 2. Full install to NAND / eMMC Prepare: rkxx_loader_vx.xx.xxx.bin parameter.txt uboot.img trust.img rootfs.img Then: Boot the board normally Connect a USB cable to the OTG port Open RKDevTool v2.69 In Advanced Function, erase the first 0x10000 sectors with Start LBA = 0x0 and Count = 0x10000 Press ResetDevice Wait for the board to return in MaskROM mode Go to Download Image Flash Loader, parameter, U-Boot, Trust, and rootfs 4. 3. Hybrid install: bootloader on NAND / eMMC, rootfs on USB or SD card This is the layout I use most often, and in practice it is probably the most useful one for old TV boxes. It is especially useful when internal NAND/eMMC is still good enough for Loader / parameter / U-Boot / Trust, but not reliable enough for a full root filesystem. A common symptom on these old boxes is that Android starts to boot and then hangs, or that the internal storage is simply too unreliable to trust with a full install. In this hybrid layout: Internal NAND/eMMC stores Loader, parameter, U-Boot, and Trust The root filesystem lives on USB or SD card Important: rootfs.img is a filesystem image, not a full disk image Write rootfs.img to a partition such as /dev/sdX1, not to the whole device Tools like BalenaEtcher are the wrong fit for this particular image layout Example: sudo dd if=rootfs.img of=/dev/sdX1 bs=4M status=progress conv=fsync sync 4.4. Post-install configuration After the board boots successfully, you can configure it either from the local console over HDMI or remotely over SSH if Ethernet is connected. Default login: user: root password: 1234 The first login will ask you to change the password. After that, run: rk3128-config This is the board-specific configuration tool for enabling and adjusting hardware features that may differ between RK3128 boxes. The most important options are: Wi-Fi chip selection RAM dynamic frequency: disabled by default. Enabling it can improve performance, but on some boards it may cause kernel hangs. If that happens, switch it back to disabled SD card storage enablement when booting from another device Display resolution OTG mode selection 5. Testing feedback is welcome If anyone here has RK3128 boards and wants to test, feedback would be very useful, especially for: Board photos and PCB markings Whether the board uses NAND or eMMC Boot method that works: SD, USB, NAND, eMMC Which Wi-Fi chip is present Serial logs, dmesg, and failure reports If there is enough interest and enough board coverage, I would be happy to keep improving this, cleaning it up further, and making it easier for other people to test. 6. Credits - @jock and @fabiobassa for the RK322x TV box work on the Armbian forum, which provided the main starting point, the images and practical reference for this RK3128 effort - Rockchip for the original kernel code base used as the foundation for both kernel lines
