pkfox Posted April 5, 2019 Posted April 5, 2019 Hi all, thanks to you guys on here I now have a fully functioning 4 * SSD drive NanoPiM4 using the SATA hat. What I'd like to do now, is, place the drives in some sort of drive enclosure that would have 4 SATA data inputs and be powered by the molex on the hat. Is it possible and is there such an animal ?
NicoD Posted April 5, 2019 Posted April 5, 2019 I'd say make one yourselfs. Just buy 4 2.5" hard disk holders and build a metal frame that you can slide the holders in. There are "4 bay hard disk enclosures", but they almost all have an USB3 output.
lanefu Posted April 5, 2019 Posted April 5, 2019 So I'm doing something similar, but with 3.5" drives... I found a bay adapter that made a perfect cage.. you can probably find something similar for 2.5" https://www.amazon.com/dp/B07KFX5RWZ?ref=ppx_pop_mob_ap_share
frauhottelmann Posted April 5, 2019 Posted April 5, 2019 On 4/5/2019 at 1:22 PM, lanefu said: So I'm doing something similar, but with 3.5" drives... I found a bay adapter that made a perfect cage.. you can probably find something similar for 2.5" https://www.amazon.com/dp/B07KFX5RWZ?ref=ppx_pop_mob_ap_share Expand I have that enclosure. You can get it from aliexpress for less than half of that price (the one on the German Amazon shipped from China anyway). For 2.5" maybe this one: Mediasonic 4 x 2.5”
lanefu Posted April 5, 2019 Posted April 5, 2019 On 4/5/2019 at 1:34 PM, frauhottelmann said: I have that enclosure. You can get it from aliexpress for less than half of that price (the one on the German Amazon shipped from China anyway). Expand I'm spoiled in the states.. I had free next day delivery. That 2.5 mediasonic you found looks awesome
pfry Posted April 5, 2019 Posted April 5, 2019 I prefer the Supermicro for build quality: https://www.supermicro.com/products/accessories/mobilerack/CSE-M14TQC.cfm It may be possible to locate an OEM version for less money. I'd also lose the 40mm 15000RPM fan (may or may not be an exaggeration) and use something different to push air through it. One of my favorites is the Sanyo Denki (same brand that comes with the Supermicro), e.g.: https://products.sanyodenki.com/en/sanace/dc/counter-rotating-fan/9CRA0912P0G001/ The counter-rotating fans give you good static pressure for use with filters. Note that you'll want to use a PWM controller with it* - it's hilariously frantic at full speed. Motorized impellers have generally better performance than axial fans, but are more involved to mount and duct. * I usually just use a potentiometer to ground. PWM presents a variable voltage, usually 0-5V; any fan that can run with an open PWM line has a built-in voltage source, which can be shunted to ground through the pot - no additional components needed. If you wish to control it via software, all you need is a PWM output. Probably more than you want to get into, but what the hey.
pkfox Posted April 6, 2019 Author Posted April 6, 2019 On 4/5/2019 at 1:06 PM, NicoD said: I'd say make one yourselfs. Just buy 4 2.5" hard disk holders and build a metal frame that you can slide the holders in. There are "4 bay hard disk enclosures", but they almost all have an USB3 output. Expand Thanks Nico
pkfox Posted April 6, 2019 Author Posted April 6, 2019 On 4/5/2019 at 7:40 PM, pfry said: I prefer the Supermicro for build quality: https://www.supermicro.com/products/accessories/mobilerack/CSE-M14TQC.cfm It may be possible to locate an OEM version for less money. I'd also lose the 40mm 15000RPM fan (may or may not be an exaggeration) and use something different to push air through it. One of my favorites is the Sanyo Denki (same brand that comes with the Supermicro), e.g.: https://products.sanyodenki.com/en/sanace/dc/counter-rotating-fan/9CRA0912P0G001/ The counter-rotating fans give you good static pressure for use with filters. Note that you'll want to use a PWM controller with it* - it's hilariously frantic at full speed. Motorized impellers have generally better performance than axial fans, but are more involved to mount and duct. * I usually just use a potentiometer to ground. PWM presents a variable voltage, usually 0-5V; any fan that can run with an open PWM line has a built-in voltage source, which can be shunted to ground through the pot - no additional components needed. If you wish to control it via software, all you need is a PWM output. Probably more than you want to get into, but what the hey. Expand Here we go again 😁 what is a PWM ?
pkfox Posted April 6, 2019 Author Posted April 6, 2019 Thanks chaps I went with the SuperMicro in the end
martinayotte Posted April 6, 2019 Posted April 6, 2019 On 4/6/2019 at 8:39 AM, pkfox said: what is a PWM ? Expand Pulse Width Modulation ... It is a square wave where the highs and lows can vary in length, and when filtered out with a capacitor, you end up with a voltage output from 0V to x.xxV. This method is used in many kind of circuit, such controlling the brightness of an LCD, and here in the above post, the speed of a motor fan.
pkfox Posted April 6, 2019 Author Posted April 6, 2019 On 4/6/2019 at 12:48 PM, martinayotte said: Pulse Width Modulation ... It is a square wave where the highs and lows can vary in length, and when filtered out with a capacitor, you end up with a voltage output from 0V to x.xxV. Did method is used in many kind of circuit, such controlling the brightness of an LCD, and here in the above post, the speed of a motor fan. Expand Thanks ( glazes over ) :-)
